  3. Off Topic
  4. Pflege des Betriebssystems
  5. nodejs update
nodejs update
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
28 Beiträge 7 Kommentatoren 5.9k Aufrufe 3 Beobachtet
  • jolu1705J jolu1705
    iob diag output
                            v.2024-10-19
       Static hostname: optiplex7050
             Icon name: computer-desktop
               Chassis: desktop
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-33-amd64
          Architecture: x86-64
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    Recommended versions are nodejs 20.18.0 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:             15G        427M         13G        3.0M        2.0G         15G
    Swap:           976M          0B        976M
    Total:           16G        427M         14G
    Active iob-Instances:   1
    Upgrade policy: none
    ioBroker Core:          js-controller           6.0.11
                            admin                   7.4.0
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : optiplex7050                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.web.0                    : web                   : optiplex7050                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                122613
    States:                 94763
    Size of iob-Database:
    65M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    20M     /opt/iobroker/iobroker-data/states.jsonl
    3.3M    /opt/iobroker/iobroker-data/states.json.migrated
    3.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    @jolu1705
    Passt also jetzt.
    Aber dein Betriebssystem ist EndOfLife.
    Installier da Debian 12 'Bookworm'.
      iob diag output
                              v.2024-10-19
                 Chassis: desktop
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1000
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
      Swap:           976M          0B        976M
      Total:           16G        427M         14G
                              admin                   7.4.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                122613
      States:                 94763
      Ro75R Offline
      Ro75R Offline
      Ro75
      @jolu1705 Die Langfassung bitte. Du bist als BETA-Tester unterwegs!?
      Ro75.
      jolu1705J 1 Antwort Letzte Antwort
      • Ro75R Ro75
        Ro75.
        jolu1705J Offline
        jolu1705J Offline
        jolu1705
        schrieb am zuletzt editiert von jolu1705
        @ro75 Was heisst das ich bin als Beta Tester unterwegs?
        @thomas-braun said in nodejs update: ok mach ich
        @jolu1705
        Passt also jetzt.
        Ro75R 1 Antwort Letzte Antwort
          @jolu1705
          Passt also jetzt.
          Ro75R Offline
          Ro75R Offline
          Ro75
          @jolu1705 naja admin 7.4.0 ist nicht stable. Stable ist 7.1.5
          Deswegen mal die Langfassung.
          Ro75.
          • Ro75R Ro75
            Ro75.
            jolu1705J Offline
            jolu1705J Offline
            jolu1705
            @ro75 said in nodejs update:
            Ro75.
            Wie komm ich denn vom Beta Baum wieder auf die Stable Schiene?
              Ro75.
              Ro75R Offline
              Ro75R Offline
              Ro75
              @jolu1705 Erst einmal bitte die Langfassung.
              Ro75.
              • Ro75R Ro75
                Ro75.
                jolu1705J Offline
                jolu1705J Offline
                jolu1705
                @ro75
                Das Update von Bullseye auf Bookwork scheint das Problem gelöst zu haben. Ich habe nun Version 20.18 laut Übersicht
                  @ro75
                  Ro75R Offline
                  Ro75R Offline
                  Ro75
                  schrieb am zuletzt editiert von Ro75
                  @jolu1705 Oh Oh. Nur Bruchstücke. Hilfe ist fast nicht möglich. Wie hast du Debian 11 auf 12 gebracht? Ich hoffe mit neuem Image. Ein direktes Update von 11 auf 12 ist nicht möglich, zumindest nicht ohne weitere zeitaufwendige und nervige Folgeprobleme.
                  Ro75.
                  jolu1705J Meister MopperM 2 Antworten Letzte Antwort
                    @jolu1705
                    Passt also jetzt.
                    T Nicht stören
                    T Nicht stören
                    ticaki
                    @thomas-braun sagte in nodejs update:
                    Nur aus Interesse - Die 11 ist doch LTS und noch bis 2026 supported
                    Spenden
                    • Ro75R Ro75
                      Ro75.
                      jolu1705J Offline
                      jolu1705J Offline
                      jolu1705
                      @ro75 dist-upgrade nach Änderungen der sources.
                      iobroker läuft und nodejs update scheinbar auch denn der Alias Adapter konnte nun ohne Probleme auf v2.0 gebracht werden.
                      Danke erst einmal!
                        Danke erst einmal!
                        Ro75R Offline
                        Ro75R Offline
                        Ro75
                        @jolu1705 das wird nichts. Aber mache deinen Weg, scheinbar interessieren dich ja nicht die Infos und Aussagen der Helfenden.
                        Ro75.
                        • Ro75R Ro75
                          Ro75.
                          Meister MopperM Online
                          Meister Mopper
                          @ro75 sagte in nodejs update:
                          Stimmt bei einem RPI, einen LXC habe ich problemlos von bullsyeye auf bookworm bekommen.
                          Proxmox und HA ...
                          • T ticaki
                            @ticaki sagte in nodejs update:
                            für LTS gilt
                            • jolu1705J Offline
                              jolu1705J Offline
                              jolu1705
                              CPU: 26,33 %
                              RAM: 24 %
                              Betriebszeit: 0h
                              Verfügbar: 6.0.11
                              Installiert: 6.0.11
                              Ereignisse: ⇥43 / ↦13
                              Plattform: linux
                              Betriebssystem: linux
                              Architektur: x64
                              CPUs: 4
                              Geschwindigkeit: 3453 MHz
                              Modell: Intel(R) Core(TM) i5-6600 CPU @ 3.30GHz
                              RAM: 15.5 GB
                              System-Betriebszeit: 00:03:28
                              Node.js: v20.18.0
                              time: 1732105108632
                              timeOffset: -60
                              NPM: 10.8.2
                              Adapter-Anzahl: 547
                              Datenträgergröße: 232.2 GB
                              Freier Festplattenspeicher: 211.4 GB
                              Aktive Instanzen: 47
                              Pfad: /opt/iobroker/
                              Betriebszeit: 00:03:21
                              aktiv: true
                              _nodeCurrent: 20.18.0
                              _nodeNewest: 20.18.0
                              _nodeNewestNext: 20.18.0
                              _npmCurrent: 10.8.2
                              _npmNewest: 10.8.2
                              _npmNewestNext: 10.8.2
                              cat /etc/os-release
                              PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
                              NAME="Debian GNU/Linux"
                              VERSION_ID="12"
                              VERSION="12 (bookworm)"
                              VERSION_CODENAME=bookworm
                              ID=debian
                              HOME_URL="https://www.debian.org/"
                              SUPPORT_URL="https://www.debian.org/support"
                              BUG_REPORT_URL="https://bugs.debian.org/"
                              Alle Adapter sind normal hochgefahren, bisher sehe ich keine Probleme.
                              @Ro75 Ich verstehe Deine Bedenken. Sollte es Probleme geben werde ich das System komplett neu aufsetzen .
                              Ro75R HomoranH 2 Antworten Letzte Antwort
                                CPU: 26,33 %
                                RAM: 24 %
                                Betriebszeit: 0h
                                Verfügbar: 6.0.11
                                Installiert: 6.0.11
                                Plattform: linux
                                Architektur: x64
                                CPUs: 4
                                RAM: 15.5 GB
                                Node.js: v20.18.0
                                time: 1732105108632
                                timeOffset: -60
                                NPM: 10.8.2
                                Adapter-Anzahl: 547
                                aktiv: true
                                _npmCurrent: 10.8.2
                                _npmNewest: 10.8.2
                                cat /etc/os-release
                                VERSION_ID="12"
                                ID=debian
                                Ro75R Offline
                                Ro75R Offline
                                Ro75
                                @jolu1705 mach was du willst und möchtest. 4 mal wurde nach der Langfassung gefragt. Keine Infos dazu, immer was anderes. So kann man dem der Hilfe sucht, nicht helfen.
                                Ro75.
                                  CPU: 26,33 %
                                  RAM: 24 %
                                  Betriebszeit: 0h
                                  Verfügbar: 6.0.11
                                  Installiert: 6.0.11
                                  Plattform: linux
                                  Architektur: x64
                                  CPUs: 4
                                  RAM: 15.5 GB
                                  Node.js: v20.18.0
                                  time: 1732105108632
                                  timeOffset: -60
                                  NPM: 10.8.2
                                  Adapter-Anzahl: 547
                                  aktiv: true
                                  _npmCurrent: 10.8.2
                                  _npmNewest: 10.8.2
                                  cat /etc/os-release
                                  VERSION_ID="12"
                                  ID=debian
                                  @jolu1705 wo bleibt die Ausgabe der Langfassung von iob diag??
                                  (vor dem ganzen Gefrickel)
                                  • T ticaki
                                    @ticaki
                                    Aber LTS ist ja nur noch 'am Tropf hängen' und wird nicht mehr aktiv gepflegt.
                                    Man betreibt ein Debian nicht ohne sehr, sehr gute Gründe im LTS-Status.
                                    'Ich habe keine Lust und Zeit und keine Ahnung davon' ist keiner der guten Gründe.
                                    Edit: Und jetzt etwas ausführlicher:
                                    Mit dem Festhalten an nur noch mit den allernotwendigsten Patches versorgten Releases manövrierst du dich in die gleiche Sackgasse, in der die 'Raspberry-Buster - nodejs 20 kann nicht mehr installiert werden' oder 'libudev ist kaputt'-User sich auch immer befinden.
                                    nodejs rollt ja z. B. alle 6 Monate weiter zu einem neuen Major-Release und kann und muss dann natürlich keine Rücksicht auf abgekündigte Versionen nehmen. Und deswegen baut ein nodejs@20 nicht mehr auf einem 32bit-ARM-Raspberry10 'Buster'. glibc zu alt und die wird auch nicht mehr angepackt, weil EOL.
                                    LTS kannst du nur fahren, wenn da auf keinen Fall noch irgendwas in aktuellerer Version hinzukommen wird und es irgendwelche Anwendungen gibt, die nicht mir der aktuellen stable kompatibel sind.
                                    Das betrifft aber in der Regel eher Unternehmen oder sonstige größere Institutionen mit besonderer Software, nicht den ioBroker-User.
                                    Nicht umsonst gibt es ja ein Jahr 'Übergangsfrist', sobald ein neues Stable-Release herauskommt. Und da Debian 12 / Bookworm im Juni 2023 released wurde ist folgerichtig für Debian 11 / Bullseye zum 14.08.2024 das 'EndOfLife' verkündet worden.
                                    Edit2: Und aus genau diesem Grund ist auch das tolle 'Never tatsch a runninck süstäm' ganz großer Bullshit. Denn irgendwann 'runnt' das 'never getatschte' System nämlich 'aus heiterem Himmel' auf einmal nicht mehr.
