  4. [Gelöst] CPU-Last & Temperatur von entferntem RasPi auslesen
raspberry pi
42 Beiträge 5 Kommentatoren 5.6k Aufrufe 3 Beobachtet
    @nwh sagte in Test Adapter rpi2 2.x:
    Mein IOB läuft in einem Container am Nas.
    und was soll da ein Adapter für den RaspberryPi bewirken?
    NWHN Offline
    NWHN Offline
    NWH
    Wofür ist den der Adapter?
    Man kann damit den Raspi auslesen, oder etwa nicht?
    Würde gerne CPU Last und Temp sehen.
    • NWHN NWH
      Habe ich gemacht, leider nein.
      $ iobroker add rpi2 auto --host iobroker --debug
      NPM version: 10.8.2Installing iobroker.rpi2@2.2.1... (System call)
      > iobroker.rpi2@2.2.1 preinstall> sudo apt-get install -y libgpiod-dev || exit 0sudo: unable to resolve host iobroker: Name or service not known
      Reading package lists...
      Building dependency tree...Reading state information...
      The following additional packages will be installed:
      libgpiod2
      Suggested packages: libgpiod-doc
      The following NEW packages will be installed:
      libgpiod-dev libgpiod2
      0 upgraded, 2 newly installed, 0 to remove and 29 not upgraded.Need to get 96,7 kB of archives.After this operation, 493 kB of additional disk space will be used.Get:1 http://deb.debian.org/debian bookworm/main amd64 libgpiod2 amd64 1.6.3-1+b3 [39,0 kB]
      Get:2 http://deb.debian.org/debian bookworm/main amd64 libgpiod-dev amd64 1.6.3-1+b3 [57,7 kB]
      debconf: unable to initialize frontend: Dialogdebconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78, <> line 2.)debconf: falling back to frontend: Readlinedebconf: unable to initialize frontend: Readlinedebconf: (This frontend requires a controlling tty.)debconf: falling back to frontend: Teletype
      dpkg-preconfigure: unable to re-open stdin:
      Fetched 96,7 kB in 0s (503 kB/s)Selecting previously unselected package libgpiod2:amd64.(Reading database ... (Reading database ... 5%(Reading database ... 10%(Reading database ... 15%(Reading database ... 20%(Reading database ... 25%(Reading database ... 30%(Reading database ... 35%(Reading database ... 40%(Reading database ... 45%(Reading database ... 50%(Reading database ... 55%(Reading database ... 60%(Reading database ... 65%(Reading database ... 70%(Reading database ... 75%(Reading database ... 80%(Reading database ... 85%(Reading database ... 90%(Reading database ... 95%(Reading database ... 100%(Reading database ... 30815 files and directories currently installed.)Preparing to unpack .../libgpiod2_1.6.3-1+b3_amd64.deb ...
      Unpacking libgpiod2:amd64 (1.6.3-1+b3) ...
      Selecting previously unselected package libgpiod-dev:amd64.
      Preparing to unpack .../libgpiod-dev_1.6.3-1+b3_amd64.deb ...
      Unpacking libgpiod-dev:amd64 (1.6.3-1+b3) ...
      Setting up libgpiod2:amd64 (1.6.3-1+b3) ...
      Setting up libgpiod-dev:amd64 (1.6.3-1+b3) ...
      Processing triggers for libc-bin (2.36-9+deb12u8) ...
      > node-dht-sensor@0.4.3 install> node-gyp configure
      gyp info it worked if it ends with ok
      gyp info using node-gyp@10.2.0
      gyp info using node@20.18.0 | linux | x64
      gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
      gyp info spawn /usr/bin/python3
      gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/20.18.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
      gyp info ok
      > opengpio@1.0.16 install> node-gyp rebuild
      gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/20.18.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
      gyp info spawn make
      gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      make: Entering directory '/opt/iobroker/node_modules/opengpio/build'
      CXX(target) Release/obj.target/opengpio/cpp/opengpio.o
      In file included from /opt/iobroker/node_modules/opengpio/node_modules/node-addon-api/napi.h:13, from ../cpp/opengpio.cpp:1:/opt/iobroker/.cache/node-gyp/20.18.0/include/node/node_api.h:83:54: fatal error: opening dependency file ./Release/.deps/Release/obj.target/opengpio/cpp/opengpio.o.d.raw: No such file or directory 83 | NAPI_MODULE_INIT() { return regfunc(env, exports); } | ^/opt/iobroker/node_modules/opengpio/node_modules/node-addon-api/napi-inl.h:355:3: note: in expansion of macro ‘NAPI_MODULE’../cpp/opengpio.cpp:374:1: note: in expansion of macro ‘NODE_API_MODULE’
      compilation terminated.
      make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'
      gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack Error: ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/opengpio/build/node_gyp_bins'gyp ERR! System Linux 4.4.302+gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.18.0gyp ERR! node-gyp -v v10.2.0gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
      npm error code 7
      npm error path /opt/iobroker/node_modules/opengpio
      npm error command failednpm error command sh -c node-gyp rebuild
      npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-11-13T19_42_00_802Z-debug-0.log
      sudo: unable to resolve host iobroker: Name or service not knowndebconf: unable to initialize frontend: Dialogdebconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78, <> line 2.)debconf: falling back to frontend: Readlinedebconf: unable to initialize frontend: Readlinedebconf: (This frontend requires a controlling tty.)debconf: falling back to frontend: Teletypedpkg-preconfigure: unable to re-open stdin: gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@20.18.0 | linux | x64gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/20.18.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info ok gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@20.18.0 | linux | x64gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/20.18.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]In file included from /opt/iobroker/node_modules/opengpio/node_modules/node-addon-api/napi.h:13, from ../cpp/opengpio.cpp:1:/opt/iobroker/.cache/node-gyp/20.18.0/include/node/node_api.h:83:54: fatal error: opening dependency file ./Release/.deps/Release/obj.target/opengpio/cpp/opengpio.o.d.raw: No such file or directory 83 | NAPI_MODULE_INIT() { return regfunc(env, exports); } | ^/opt/iobroker/node_modules/opengpio/node_modules/node-addon-api/napi-inl.h:355:3: note: in expansion of macro ‘NAPI_MODULE’../cpp/opengpio.cpp:374:1: note: in expansion of macro ‘NODE_API_MODULE’compilation terminated.make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack Error: ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/opengpio/build/node_gyp_bins'gyp ERR! System Linux 4.4.302+gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.18.0gyp ERR! node-gyp -v v10.2.0gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-11-13T19_42_00_802Z-debug-0.loghost.iobroker Cannot install iobroker.rpi2@2.2.1: 7
      ERROR: Process exited with code 25
      Der Code baut auf der Hardware wohl nicht.
      Ja, aber der Adapter muss dazu auch auf einem Raspi laufen und nicht auf deinem NAS (mit steinaltem Kernel).
      • NWHN NWH
        aber nur wenn der Adapter auf dem Raspi läuft
        sieht nicht danach aus
        • NWHN NWH
          Das würde ich per kleinem Skript machen.
          NWHN 1 Antwort Letzte Antwort
            NWHN Offline
            NWHN Offline
            NWH
            @thomas-braun @Homoran
            Mein IOb läuft jetzt seit ca. 6 Jahren am Nas im Container und das eigentlich ohne Probleme.
            Wenn mal was nicht ging, war immer ich Schuld.
            Wie kann so ein Script aussehen? Kannst du mir hierbei helfen.
            • NWHN NWH
              das ist ja durchaus möglich und auch normal.
              Aber jetzt gehts um einen Adapter, der Werte aus dem RaspberryPi Betriebssystem ausliest
              oder läuft das Raspberry Pi OS bei dir im Container.
              Ansonsten verstehe ich nicht was du uns sagen willst.
              • NWHN NWH
                Da ich nicht der begnadete javascript-Coder bin eher nicht.
                Ich würde da was in einem Blockly aus SSH-Verbindung und den Kommandozeilenprogrammen per EXEC basteln.
                  Ich weiss auch nicht wue du an die Temperatur des Containers kommen willst ;-)
                  @NWH
                  du willst doch bestimmt die Werte des Hostsystems haben, oder?
                  Ab hier gehört es aber nicht mehr zum Test des neuen rpi2-Adapters!
                    @NWH
                    NWHN Offline
                    NWHN Offline
                    NWH
                    @homoran sagte in Test Adapter rpi2 2.x:
                    @NWH
                    Nein, es läuft nur der IOB im Container.
                    Ich habe noch einen zusätzlichen Raspi wo ich die WP auslese.
                    @Thomas-Braun
                    Blockly wäre mir auch Recht. Aber mit Kommandozeilenprogrammen per EXEC noch nie gehört 🙄
                    • NWHN NWH
                      @NWH
                      @Thomas-Braun
                      @nwh ich hab das mal ausgegliedert!
                      Bitte Threadtitel an dein "Problem" anpassen.
                      @nwh sagte in cpu Last und Temperatur von entferntem RasPi auslesen:
                      @NWH
                      ein Container hat keine Temperatur ;-)
                      und ein RasPi ist er auch nicht.
                      Was genau willst du?
                        @NWH
                        @homoran sagte in cpu Last und Temperatur von entferntem RasPi auslesen:
                        Per 'Fernzugang'/SSH die Werte eines RPi auslesen.
                        • NWHN Offline
                          NWHN Offline
                          NWH
                          @NWH
                          Ich will die CPU Last und die Temperatur vom Raspi auslesen.
                          Das sind 2 Physisch unterschiedliche Geräte.
                          1x Nas mit einem Container wo der Iob läuft.
                          1x Raspi mit Raspina OS wo ein Script läuft. Hat nicht mit Iob zu tun.
                            @thomas-braun sagte in cpu Last und Temperatur von entferntem RasPi auslesen:
                            dann hab ich mit dem provisorischen Threadtitel doch getroffen.
                            dann geht es um den hier?
                            @NWH
                            läuft da iobroker als slave drauf?
                              @NWH
                              NWHN Offline
                              NWHN Offline
                              NWH
                              @NWH
                              Nein, wie gesagt Raspin OS und ein Script.
                              • NWHN NWH
                                @NWH
                                @nwh Da haben sich unsere Posts überschnitten.
                                Das wird nicht so einfach per script aus dem Container zu lösen sein.
                                Du musst ja Zugriff auf den anderen Raspi bekommen
                                aber ggf. anders herum.
                                Vom Raspi per simple API auf den Container zugreifen.
                                Hab aber keine Ahnung wie!
                                NWHN CodierknechtC 2 Antworten Letzte Antwort
                                  NWHN Offline
                                  NWHN Offline
                                  NWH
                                  mhhh
                                  ChatGPT meinte:
                                  Um die CPU-Temperatur und -Auslastung deines Raspberry Pi auszulesen und im ioBroker darzustellen, kannst du die Daten mit einem Shell-Skript sammeln und dann über den ioBroker-Adapter „Systeminfo“ oder „Javascript“ zur Anzeige bringen.
                                  Allerdings möchte ich nicht haben das die Daten am Raspi gespeichert werden.
                                  Ich kenn mich hier nicht so gut aus, aber kann man den Pfad wo anders hin ändern?
                                  Das wäre das Script
                                  #!/bin/bash
                                  # cpu_data.sh
                                  # CPU-Temperatur
                                  temp=$(vcgencmd measure_temp | egrep -o '[0-9]*\.[0-9]*')
                                  # CPU-Auslastung
                                  usage=$(top -bn1 | grep "Cpu(s)" | sed "s/.*, *\([0-9.]*\)%* id.*/\1/" | awk '{print 100 - $1}')
                                  # Ausgabe
                                  echo "temp=$temp"
                                  echo "usage=$usage"
                                  und hier das 2te Script
                                  const exec = require('child_process').exec;
                                  function readCpuData() {
                                      // Befehl für die CPU-Temperatur
                                      exec("vcgencmd measure_temp", (error, stdout, stderr) => {
                                          if (error) {
                                              console.error(`exec error: ${error}`);
                                              return;
                                          const temp = parseFloat(stdout.replace('temp=', '').replace("'C\n", ''));
                                          setState("javascript.0.raspberrypi.temp", temp);
                                      // Befehl für die CPU-Auslastung
                                      exec("top -bn1 | grep 'Cpu(s)' | sed 's/.*, *\\([0-9.]*\\)%* id.*/\\1/' | awk '{print 100 - $1}'", (error, stdout, stderr) => {
                                          if (error) {
                                              return;
                                          const usage = parseFloat(stdout);
                                          setState("javascript.0.raspberrypi.usage", usage);
                                  // CPU-Daten alle 10 Sekunden abrufen
                                  schedule("*/10 * * * * *", readCpuData);
                                  • NWHN NWH
                                    mhhh
                                    ChatGPT meinte:
                                    Das wäre das Script
                                    #!/bin/bash
                                    # cpu_data.sh
                                    # CPU-Temperatur
                                    # CPU-Auslastung
                                    # Ausgabe
                                    echo "temp=$temp"
                                    echo "usage=$usage"
                                            if (error) {
                                                return;
                                            if (error) {
                                                return;
                                    @nwh ich weiss nicht wie du die Aufgabe gestellt hast, die Antwort klingt aber nach einem laufenden ioBroker auf dem Raspi
                                      CodierknechtC Offline
                                      Codierknecht
                                      Nicht unbedingt.
                                      Wie wäre es mit SNMP?
                                      Auf den Raspi kommt der Daemon und mit ioBroker kommt man mit dem SNMP-Adapter da ran.
                                      Ich habe keinen Raspi. Aber wenn ich einen zu überwachen hätte, würde ich das mit Zabbix machen und auf dem Pi den Agent installieren.
                                      Liegt aber auch daran, dass ich sowieso jeden Furz und Feuerstein mit Zabbix überwache 😁
                                      HmIP|ZigBee|Tasmota|Unifi
                                      Zabbix Certified Specialist
                                      • CodierknechtC Codierknecht
                                        Nicht unbedingt.
                                        @codierknecht sagte in CPU-Last und Temperatur von entferntem RasPi auslesen:
                                        Nicht unbedingt.
                                        das braucht auch einen Zugriff 😀
                                          NWHN Offline
                                          NWHN Offline
                                          NWH
                                          @homoran sagte in CPU-Last und Temperatur von entferntem RasPi auslesen:
                                          Findest du, ich hätte es so interpretiert wie ich es gerne hätte.
                                          Frage war, wie einen Raspi auslesen und im Iobroker integrieren
