  4. Fehler beim js-conroller Update von 3.1.6 auf 6.0.11
14 Beiträge 6 Kommentatoren 616 Aufrufe 4 Beobachtet
    @ml sagte in Fehler beim js-conroller Update von 3.1.6 auf 6.0.11:
    C:\Program Files\
    @Codierknecht
    Schaut mir nach Windooze aus.
    CodierknechtC Offline
    Codierknecht
    @thomas-braun sagte in Fehler beim js-conroller Update von 3.1.6 auf 6.0.11:
    Hast Recht - übersehen.
    @ML Dann also mal versuchen, den Kram Schritt für Schritt hochzuziehen.
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • CodierknechtC Codierknecht
      ML
      @codierknecht
      hier die Langfassung:
      C:\Program Files\iobroker\SmartHomeNEU>iob diag
      Commands:
      iobroker setup [--objects <host>] [--states <host>] [custom]
      iobroker start - starts the js-controller
      iobroker stop - stops the js-controller
      iobroker start <adapter>[.instance] - starts a specified adapter instance
      iobroker stop <adapter>.[instance] - stops a specified adapter instance
      iobroker start all - starts js-controller and all adapters
      iobroker restart - restarts the js-controller
      iobroker restart <adapter>[.instance] - restarts a specified adapter
      iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
          --wait stops the execution until the debugger is attached.
          --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
      iobroker info - shows the host info
      iobroker logs [adapter] [--watch] [--lines=1000]
      iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
      iobroker install <adapter> - installs a specified adapter
      iobroker rebuild <adapter>|self [--install]
      iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
      iobroker del <adapter> - remove adapter from system
      iobroker del <adapter>.<instance> - remove adapter instance
      iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
      iobroker upgrade [repository url]
      iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
      iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
      iobroker upload <pathToLocalFile> <pathIniobroker>
      iobroker upload all - upload all adapter files to make them available for instances
      iobroker upload <adapter> - upload specified adapter files to make them available for instances
      iobroker object get <id> - get object specified by id
      iobroker object set <id> <json-value> - set object with the given id by providing a new json object
      iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
      iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
      iobroker object del <id|pattern> [--yes]
      iobroker object chmod <object-mode> [state-mode] <id>
      iobroker object chown <user> <group> <id>
      iobroker object list <id>
      iobroker state get <id> - get state, specified by id
      iobroker state getplain <id> [--pretty]
      iobroker state getvalue <id>
      iobroker state set <id> <value> [ack]
      iobroker state del <id>
      iobroker message <adapter>[.instance] <command> [<message>]
      iobroker list <type> [filter]
      iobroker chmod <mode> <file>
      iobroker chown <user> <group> <file>
      iobroker touch <file>
      iobroker rm <file>
      iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
      iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
      iobroker file rm <iobroker-path-to-delete>
      iobroker file sync
      iobroker user add <user> [--ingroup group] [--password pass]
      iobroker user del <user>
      iobroker user passwd <user> [--password pass]
      iobroker user enable <user>
      iobroker user disable <user>
      iobroker user get <user>
      iobroker user check <user> [--password pass]
      iobroker group add <group>
      iobroker group del <group>
      iobroker group list <group>
      iobroker group enable <group>
      iobroker group disable <group>
      iobroker group get <group>
      iobroker group adduser <group> <user>
      iobroker group deluser <group> <user>
      iobroker host this
      iobroker host <hostname>
      iobroker host set <hostname>
      iobroker host remove <hostname>
      iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
      iobroker license <license.file or license.text>
      iobroker cert create
      iobroker cert view [<certificate name>]
      iobroker clean
      iobroker backup
      iobroker restore <backup name or path> - restore a specified backup
      iobroker validate <backup name or path> - validate a specified backup
      iobroker <command> --timeout 5000
      iobroker status [all|<adapter>.<instance>]
      iobroker repo [name]
      iobroker repo add <name> <path or url>
      iobroker repo set <name>
      iobroker repo del <name>
      iobroker uuid
      iobroker unsetup
      iobroker fix - execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost <enable|disable> [--secure true|false]
      iobroker multihost browse
      iobroker multihost connect
      iobroker compact status - show if compact mode is enabled in general
      iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
      iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
      iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
      iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
      iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
      iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
      iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
      iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
      iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
      iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
      iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
      iobroker version [adapter] - show version of js-controller or specified adapter
      iobroker [adapter] -v - show version of js-controller or specified adapter
      Options:
        --help     Show help  [boolean]
        --version  Show version number  [boolean]
      • M ML
        @codierknecht
        Commands:
        iobroker rm <file>
        iobroker file sync
        iobroker host this
        iobroker clean
        iobroker backup
        iobroker uuid
        iobroker unsetup
        Options:
        @ml
        iob diag
        funktioniert unter Windows nicht, das hilft also nicht weiter.
        • arteckA Offline
          arteckA Offline
          arteck
          installier parallel ein neues iobroker und kopiere nur den iobroker-data Ordner da rein .. das neue starten und warten
          zur sicherheit das alte erstmal zip'en
            ML
            @arteck
            hat soweit erstmal funktioniert.
            jetzt kommt nur noch:
            admin.0 2024-11-11 20:25:38.033 warn Cannot read file ("admin.admin"/"admin.svg"): Not exists
            als Fehlermeldung
            • M ML
              @arteck
              als Fehlermeldung
              S Abwesend
              S Abwesend
              Shadowhunter23
              schrieb am zuletzt editiert von Shadowhunter23
              @ml
              gibt's iobroker upload admin unter Windows?
              Ich hatte das zuletzt auch bei Linux in Verbindung mit Backitup. Nachdem ich eine neue Installation ( mit Backitup ) gemacht hatte war das eine dauerhafte Meldung. Befehl siehe zuvor hat geholfen.
              Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
              ioBroker Backup Analyzer
              • S Shadowhunter23
                @ml
                @shadowhunter23 sagte in Fehler beim js-conroller Update von 3.1.6 auf 6.0.11:
                warum nicht?
                  warum nicht?
                  S Abwesend
                  S Abwesend
                  Shadowhunter23
                  @homoran sagte in Fehler beim js-conroller Update von 3.1.6 auf 6.0.11:
                  Ich schreibe lieber so als wenn ich unwissend sage: iobroker upload admin
                  Und es geht dann nicht... Bei Linux hätte ich sofort das als Lösung genannt.
                    ML
                    @shadowhunter23
                    Muss ich den iobroker vorher stoppen ?
                    • M ML
                      @shadowhunter23
                      S Abwesend
                      S Abwesend
                      Shadowhunter23
                      @ml
                      Auch hier kann ich sagen, unter Linux kann man das machen ohne iobroker zu stoppen. Sorry ich verwende kein Windows in Verbindung mit iobroker. Schätzen würde ich dass die Funktion gleich funktioniert wie bei Linux.
                      • S Shadowhunter23
                        @ml
                        ML
                        @shadowhunter23
                        hat funktioniert
