  4. Neuer Adapter für Roborock-Staubsauger
1.1k Beiträge 155 Kommentatoren 499.4k Aufrufe 137 Beobachtet
  • T Taddy81
    Ich bekomme den Updater irgendwie nicht installiert, wo ist denn hier der Fehler?
     iobroker url https://github.com/copystring/ioBroker.roborock --host IOBroker --debug
    install copystring/ioBroker.roborock#55d231dfd585a3d93537081d313ef52daa272acd
    Installing copystring/ioBroker.roborock#55d231dfd585a3d93537081d313ef52daa272acd... (System call)
    npm warn skipping integrity check for git dependency ssh://git@github.com/copystring/ioBroker.roborock.git
    npm warn deprecated npmlog@7.0.1: This package is no longer supported.
    npm warn deprecated are-we-there-yet@4.0.2: This package is no longer supported.
    npm warn deprecated gauge@5.0.2: This package is no longer supported.
    npm warn deprecated sinon@9.2.4: 16.1.1
    > node dist/install.js
    RequestError: getaddrinfo EAI_AGAIN github.com
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-02T11_12_49_396Z-debug-0.log
    npm warn skipping integrity check for git dependency ssh://git@github.com/copystring/ioBroker.roborock.gitnpm warn deprecated npmlog@7.0.1: This package is no longer supported.npm warn deprecated are-we-there-yet@4.0.2: This package is no longer supported.npm warn deprecated gauge@5.0.2: This package is no longer supported.npm warn deprecated sinon@9.2.4: 16.1.1RequestError: getaddrinfo EAI_AGAIN github.comnpm error code 1npm error path /opt/iobroker/node_modules/go2rtc-staticnpm error command failednpm error command sh -c node dist/install.jsnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-02T11_12_49_396Z-debug-0.loghost.IOBroker Cannot install copystring/ioBroker.roborock#55d231dfd585a3d93537081d313ef52daa272acd: 1
    ERROR: Process exited with code 25
    #677
    @taddy81
    Grundsätzlich funktioniert das.
    $ iobroker url copystring/ioBroker.roborock --host chet --debug
    Installing copystring/ioBroker.roborock... (System call)
    Support for loading ES Module in require() is an experimental feature and might change at any time(Use `node --trace-warnings ...` to show where the warning was created)
    > go2rtc-static@1.9.4 install> node dist/install.js
    > node install.js
    added 223 packages, and changed 1 package in 1m227 packages are looking for funding run `npm fund` for details
    upload [13] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [7] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [2] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
    Updating objects from io-package.json for adapter "roborock" with version "0.6.17"
    Process exited with code 0
    Ist immer ein Hinweis auf Netzwerk-Trouble. github.com kann nicht erreicht werden.
    • T Taddy81
      #678
      @taddy81
      Verwende
      iobroker url copystring/ioBroker.roborock --host IOBroker --debug
      auf dem System...
      • T Online
        T Online
        Taddy81
        #679
        Danke,
        hat funktioniert.
        Dein Code hat geklappt, warum hat denn der GitHub Repo nicht geklappt hat?
        Ein Problem war bei mir noch, dass meine Firewall die URL von Roborock blockiert hat. Ist nun aber gefixt und ich kann auf die Instanz zugreifen.
        Vielen Dank
        Proxmox 3Node Cluster, IOBroker in LXC
        PV Visualisierung und Steuerung mit NodeRed und Grafana
        • T Taddy81
          Danke,
          hat funktioniert.
          Vielen Dank
          #680
          @taddy81 sagte in Neuer Adapter für Roborock-Staubsauger:
          Was genau hast du denn wo ausgewählt?
            breaksrmine
            #681
            Seit 2 Tagen gabs in iOS ein Update der Roborock App sieht auch optisch anders aus. Seitdem funktioniert in ioBroker die Steuerung nicht mehr. Ich bekomm werte soweit alles gut aber keine Reaktion beim z.b starten des Saugers.
            Jemand das gleiche Problem ?
            C H 2 Antworten Letzte Antwort
            • B breaksrmine
              chuck2941
              #682
              @breaksrmine Also ich habe kein Update, die App sieht immer noch gleich aus und die Steuerung über ioBroker funktioniert.
              Was aber immer im Log kommt wenn der Sauger läuft ist folgendes
              roborock.0
              2024-11-02 23:08:28.092	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map.mapData" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:28.092	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map.mapBase64Truncated" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:28.091	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map.mapBase64" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.935	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.task_id" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.934	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.clean_times" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.933	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.dirty_replenish" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.932	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.manual_replenish" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.932	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.cleaned_area" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.931	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.map_flag" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.930	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.wash_count" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.930	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.avoid_count" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.929	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.dust_collection_status" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.929	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.finish_reason" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.928	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.clean_type" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.928	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.start_type" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.927	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.complete" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.926	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.error" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.925	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.area" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.924	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.duration" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.923	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.end" has no existing object, this might lead to an error in future versions
              roborock.0
              2024-11-02 23:08:27.923	warn	State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.22.begin" has no existing object, this might lead to an error in future versions
              Ich kann die Einträge nicht finden in den Objekten
              • B breaksrmine
                hansano
                schrieb am zuletzt editiert von hansano
                #683
                @breaksrmine
                Das kann ich so bestätigen, ist bei mir auch so
                Edit: nach Neustart des Adapters läuft es wieder
                • E Online
                  E Online
                  erickuttruff
                  schrieb am zuletzt editiert von erickuttruff
                  #684
                  Failed to execute get_map_v1 on robot 2BFDPXMouOnerH911HQrgP (roborock.vacuum.a51): TypeError: The "chunk" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Array at _write (node:internal/streams/writable:480:13) at Gzip.Writable.end (node:internal/streams/writable:821:17) at zlibBuffer (node:zlib:129:10) at Object.asyncBufferWrapper [as gzip] (node:zlib:776:12) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:70:11) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                  Ich habe immer sehr viele Fehler wie im Screenshot zu sehen... An was liegt es?
                  • E erickuttruff
                    #685
                    @erickuttruff sagte in Neuer Adapter für Roborock-Staubsauger:
                    Text bitte auch als TEXT in CodeTags eingebettet posten. Mit bunte Bildchens kann man nix anfangen.
                    E 1 Antwort Letzte Antwort
                      E Online
                      E Online
                      erickuttruff
                      #686
                      @thomas-braun: Ich habe den Beitrag korrigiert...
                      • H hansano
                        @breaksrmine
                        breaksrmine
                        #687
                        @hansano bei mir auch so jetzt :-)
                        • R Online
                          R Online
                          RISSN
                          #688
                          unhandled promise rejection: Login returned empty userdata.
                          Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          Error in getUserData: Login returned empty userdata.
                          Diese Fehler bekomme ich nach dem Updaten auf Version:
                          v0.6.17. Auch ein rücksetzen auf die Vorgängerversion bliebt ohne Erfolg. Hat das vielleicht noch jemand?
                          • Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            #689
                            @rissn Meld dich mal in der App neu an, die hatte ein Update.
                            Danach gehts wieder.
                            Persönlicher Support
                            Spenden -> paypal.me/J3YC33
                            R B 2 Antworten Letzte Antwort
                            • Jey CeeJ Jey Cee
                              R Online
                              R Online
                              RISSN
                              #690
                              @jey-cee vielen Dank, dass war es 👍
                              • Jey CeeJ Jey Cee
                                breaksrmine
                                schrieb am zuletzt editiert von breaksrmine
                                #691
                                @jey-cee danke geht wieder !
                                • C Offline
                                  chuck2941
                                  #692
                                  Hallo, jedesmal wenn der S8 in Aktion ist wird mir der Log mit Warnungen vollgeschrieben, weiß jemand was das ist?
                                  In den Objekten gibt es keine Einträge dazu.
                                  24-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapBase64Truncated" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapData" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:04.432 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.begin" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:04.433 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.end" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.duration" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.area" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:04.435 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.error" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.complete" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.start_type" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:04.437 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.clean_type" has no existing object, this might lead to an error in future versions
                                  2024-11-26 08:09:04.438 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.finish_reason" has no existing object, this might lead to an error in future versions
                                  T E 2 Antworten Letzte Antwort
                                  • MatzebhvM Offline
                                    MatzebhvM Offline
                                    Matzebhv
                                    #693
                                    Moin,
                                    ich habe seit heute den S8 MaxV Ultra.
                                    Hier kann anscheinend die Karte nicht mehr gezogen werden, das Log läuft über mit:
                                    Failed to execute get_map_v1 on robot xxxxxxxxxxT0dDsc9ju (roborock.vacuum.a97): Error: Failed to convert JavaScript value `Undefined` into rust type `String` at /opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:647:29 at Array.forEach (<anonymous>) at MapCreator.canvasMap (/opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:624:30) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:84:46)
                                    Wird das bei dem Modell noch nicht unterstützt?
                                    Bei dem Vorgänger S6MaxV Ultra hatte ich das Problem nicht.
                                    Habe die Karte jetzt erstmal deaktiviert.
                                    Matze
                                    • H Offline
                                      hansano
                                      #694
                                      Bekomme seit ein paa Tage folgende Fehlermeldung:
                                      roborock.0
                                      2024-11-30 11:31:54.304	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
                                      roborock.0
                                      2024-11-30 11:12:54.298	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
                                      roborock.0
                                      2024-11-30 10:59:54.296	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
                                      roborock.0
                                      roborock.0
                                      Hat noch jemand das Problem und eventuell eine Lösung?
                                      • H hansano
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        D Online
                                        D Online
                                        docsnyder7
                                        #695
                                        bei mir schauts seit dem Update auf js 7.0.3 so aus
                                        roborock.0
                                        	2024-11-30 13:45:33.234	error	Login returned empty userdata.
                                        roborock.0
                                        	2024-11-30 13:45:33.233	error	Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:85:20)
                                        roborock.0
                                        	2024-11-30 13:45:33.228	error	unhandled promise rejection: Login returned empty userdata.
                                        roborock.0
                                        	2024-11-30 13:45:33.228	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        roborock.0
                                        	2024-11-30 13:45:33.202	error	Error in getUserData: Login returned empty userdata.
                                        roborock.0
                                        	2024-11-30 13:45:32.838	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                        roborock.0
                                        	2024-11-30 13:45:32.814	info	starting. Version 0.6.17 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.1, js-controller: 7.0.3
                                        userdaten stehen im Adapter und sind auch korrekt
                                        JackDanielJ 1 Antwort Letzte Antwort
                                        • C chuck2941
                                          Tom_W
                                          #696
                                          @chuck2941
                                          Hallo Chuck2941,
                                          das ist bei mir genau das selbe. Hast du schon rausgefunden was dagegen hilft?
