  4. iobroker.js-con 100% cpu
    6.4k
86 Beiträge 9 Kommentatoren 13.7k Aufrufe 8 Beobachtet
  • spicerS Offline
    spicerS Offline
    spicer
    schrieb am zuletzt editiert von spicer
    @marc-berg
    Hier mal der log der letzten 2 Minuten:
    2024-10-29 17:39:36.406  - info: admin.0 (1274) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts
    2024-10-29 17:39:36.406  - info: admin.0 (1274) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts-show
    2024-10-29 17:39:54.140  - info: admin.0 (1274) ==> Connected system.user.admin from ::ffff:192.168.1.10
    2024-10-29 17:39:55.212  - info: admin.0 (1274) ==> Connected system.user.admin from ::ffff:192.168.1.10
    2024-10-29 17:40:00.033  - info: javascript.0 (2413) script.js.common.Ping_zu_ESP_Garage: ESP Garage erreichbar
    2024-10-29 17:40:00.037  - info: javascript.0 (2413) script.js.common.Ping_zu_Shelly_Boilersteuerung: erreichbar
    2024-10-29 17:40:10.047  - info: mqtt.1 (2853) Client [mosqsub|32094-Dachrollo] connected with secret 1730220010046_3539
    2024-10-29 17:40:10.053  - info: mqtt.1 (2853) Client [mosqsub|32094-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-10-29 17:40:10.252  - info: mqtt.1 (2853) Client [mosqsub|32094-Dachrollo] publishOnSubscribe
    2024-10-29 17:40:10.254  - info: mqtt.1 (2853) Client [mosqsub|32094-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:10.341  - info: mqtt.1 (2853) Client [mosqsub|32096-Dachrollo] connected with secret 1730220010340_4058
    2024-10-29 17:40:10.345  - info: mqtt.1 (2853) Client [mosqsub|32096-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-10-29 17:40:10.544  - info: mqtt.1 (2853) Client [mosqsub|32096-Dachrollo] publishOnSubscribe
    2024-10-29 17:40:10.546  - info: mqtt.1 (2853) Client [mosqsub|32096-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:10.688  - info: mqtt.1 (2853) Client [mosqsub|32098-Dachrollo] connected with secret 1730220010671_5897
    2024-10-29 17:40:10.690  - info: mqtt.1 (2853) Client [mosqsub|32098-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-10-29 17:40:10.895  - info: mqtt.1 (2853) Client [mosqsub|32098-Dachrollo] publishOnSubscribe
    2024-10-29 17:40:10.898  - info: mqtt.1 (2853) Client [mosqsub|32098-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:10.985  - info: mqtt.1 (2853) Client [mosqsub|32100-Dachrollo] connected with secret 1730220010984_9685
    2024-10-29 17:40:10.994  - info: mqtt.1 (2853) Client [mosqsub|32100-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-10-29 17:40:11.198  - info: mqtt.1 (2853) Client [mosqsub|32100-Dachrollo] publishOnSubscribe
    2024-10-29 17:40:11.201  - info: mqtt.1 (2853) Client [mosqsub|32100-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:11.287  - info: mqtt.1 (2853) Client [mosqsub|32102-Dachrollo] connected with secret 1730220011286_3077
    2024-10-29 17:40:11.289  - info: mqtt.1 (2853) Client [mosqsub|32102-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-10-29 17:40:11.490  - info: mqtt.1 (2853) Client [mosqsub|32102-Dachrollo] publishOnSubscribe
    2024-10-29 17:40:11.493  - info: mqtt.1 (2853) Client [mosqsub|32102-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:11.594  - info: mqtt.1 (2853) Client [mosqpub|32104-Dachrollo] connected with secret 1730220011591_1055
    2024-10-29 17:40:11.598  - info: mqtt.1 (2853) Client [mosqpub|32104-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:11.689  - info: mqtt.1 (2853) Client [mosqpub|32106-Dachrollo] connected with secret 1730220011689_2907
    2024-10-29 17:40:11.692  - info: mqtt.1 (2853) Client [mosqpub|32106-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:11.787  - info: mqtt.1 (2853) Client [mosqpub|32108-Dachrollo] connected with secret 1730220011786_3598
    2024-10-29 17:40:11.792  - info: mqtt.1 (2853) Client [mosqpub|32108-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:11.881  - info: mqtt.1 (2853) Client [mosqpub|32110-Dachrollo] connected with secret 1730220011880_7167
    2024-10-29 17:40:11.883  - info: mqtt.1 (2853) Client [mosqpub|32110-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:11.977  - info: mqtt.1 (2853) Client [mosqpub|32112-Dachrollo] connected with secret 1730220011977_2620
    2024-10-29 17:40:11.980  - info: mqtt.1 (2853) Client [mosqpub|32112-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:12.264  - info: mqtt.1 (2853) Client [mosqpub|32127-Dachrollo] connected with secret 1730220012263_3993
    2024-10-29 17:40:12.267  - info: mqtt.1 (2853) Client [mosqpub|32127-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:12.487  - info: mqtt.1 (2853) Client [mosqpub|32133-Dachrollo] connected with secret 1730220012483_2896
    2024-10-29 17:40:12.489  - info: mqtt.1 (2853) Client [mosqpub|32133-Dachrollo] connection closed: disconnected
    2024-10-29 17:40:15.215  - info: admin.0 (1274) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts-show
    2024-10-29 17:40:15.216  - info: admin.0 (1274) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts
    2024-10-29 17:40:26.015  - info: host.iobroker instance system.adapter.solarmanpv.0 in version "0.6.1" started with pid 3525
    2024-10-29 17:40:28.155  - info: solarmanpv.0 (3525) starting. Version 0.6.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.18.0, js-controller: 6.0.11
    2024-10-29 17:40:39.735  - info: solarmanpv.0 (3525) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-10-29 17:40:40.303  - info: host.iobroker instance system.adapter.solarmanpv.0 having pid 3525 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-10-29 17:41:09.838  - info: mqtt.1 (2853) Client [mosqsub|32159-Dachrollo] connected with secret 1730220069837_6569
    2024-10-29 17:41:09.840  - info: mqtt.1 (2853) Client [mosqsub|32159-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-10-29 17:41:10.040  - info: mqtt.1 (2853) Client [mosqsub|32159-Dachrollo] publishOnSubscribe
    2024-10-29 17:41:10.044  - info: mqtt.1 (2853) Client [mosqsub|32159-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:10.137  - info: mqtt.1 (2853) Client [mosqsub|32161-Dachrollo] connected with secret 1730220070134_4114
    2024-10-29 17:41:10.141  - info: mqtt.1 (2853) Client [mosqsub|32161-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-10-29 17:41:10.342  - info: mqtt.1 (2853) Client [mosqsub|32161-Dachrollo] publishOnSubscribe
    2024-10-29 17:41:10.345  - info: mqtt.1 (2853) Client [mosqsub|32161-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:10.430  - info: mqtt.1 (2853) Client [mosqsub|32163-Dachrollo] connected with secret 1730220070430_9522
    2024-10-29 17:41:10.432  - info: mqtt.1 (2853) Client [mosqsub|32163-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-10-29 17:41:10.632  - info: mqtt.1 (2853) Client [mosqsub|32163-Dachrollo] publishOnSubscribe
    2024-10-29 17:41:10.634  - info: mqtt.1 (2853) Client [mosqsub|32163-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:10.754  - info: mqtt.1 (2853) Client [mosqsub|32165-Dachrollo] connected with secret 1730220070754_549
    2024-10-29 17:41:10.758  - info: mqtt.1 (2853) Client [mosqsub|32165-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-10-29 17:41:10.958  - info: mqtt.1 (2853) Client [mosqsub|32165-Dachrollo] publishOnSubscribe
    2024-10-29 17:41:11.034  - info: mqtt.1 (2853) Client [mosqsub|32165-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:11.064  - info: mqtt.1 (2853) Client [mosqsub|32167-Dachrollo] connected with secret 1730220071062_4274
    2024-10-29 17:41:11.066  - info: mqtt.1 (2853) Client [mosqsub|32167-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-10-29 17:41:11.266  - info: mqtt.1 (2853) Client [mosqsub|32167-Dachrollo] publishOnSubscribe
    2024-10-29 17:41:11.268  - info: mqtt.1 (2853) Client [mosqsub|32167-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:11.370  - info: mqtt.1 (2853) Client [mosqpub|32169-Dachrollo] connected with secret 1730220071368_6906
    2024-10-29 17:41:11.373  - info: mqtt.1 (2853) Client [mosqpub|32169-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:11.466  - info: mqtt.1 (2853) Client [mosqpub|32171-Dachrollo] connected with secret 1730220071465_7954
    2024-10-29 17:41:11.468  - info: mqtt.1 (2853) Client [mosqpub|32171-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:11.574  - info: mqtt.1 (2853) Client [mosqpub|32173-Dachrollo] connected with secret 1730220071573_7598
    2024-10-29 17:41:11.577  - info: mqtt.1 (2853) Client [mosqpub|32173-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:11.689  - info: mqtt.1 (2853) Client [mosqpub|32175-Dachrollo] connected with secret 1730220071686_3418
    2024-10-29 17:41:11.692  - info: mqtt.1 (2853) Client [mosqpub|32175-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:11.785  - info: mqtt.1 (2853) Client [mosqpub|32177-Dachrollo] connected with secret 1730220071785_4540
    2024-10-29 17:41:11.787  - info: mqtt.1 (2853) Client [mosqpub|32177-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:12.102  - info: mqtt.1 (2853) Client [mosqpub|32192-Dachrollo] connected with secret 1730220072083_5782
    2024-10-29 17:41:12.104  - info: mqtt.1 (2853) Client [mosqpub|32192-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:12.272  - info: mqtt.1 (2853) Client [mosqpub|32198-Dachrollo] connected with secret 1730220072272_4085
    2024-10-29 17:41:12.274  - info: mqtt.1 (2853) Client [mosqpub|32198-Dachrollo] connection closed: disconnected
    2024-10-29 17:41:50.877  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] connected with secret 1730220110871_4120
    2024-10-29 17:41:51.030  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
    2024-10-29 17:41:51.046  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
    2024-10-29 17:41:51.046  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
    2024-10-29 17:41:51.046  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
    2024-10-29 17:41:51.047  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] connection closed: disconnected
    2024-10-29 17:41:51.230  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-10-29 17:41:51.247  - info: mqtt.1 (2853) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-10-29 17:41:51.526  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] connected with secret 1730220111511_8377
    2024-10-29 17:41:51.671  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
    2024-10-29 17:41:51.690  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
    2024-10-29 17:41:51.690  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
    2024-10-29 17:41:51.690  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
    2024-10-29 17:41:51.871  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-10-29 17:41:51.891  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-10-29 17:41:51.892  - info: mqtt.1 (2853) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-10-29 17:41:52.292  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1730220112290_6243
    2024-10-29 17:41:52.307  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
    2024-10-29 17:41:52.307  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
    2024-10-29 17:41:52.521  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
    2024-10-29 17:42:00.035  - info: javascript.0 (2413) script.js.common.Ping_zu_Shelly_Boilersteuerung: erreichbar
    2024-10-29 17:42:00.053  - info: javascript.0 (2413) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 57.6 °C
    2024-10-29 17:42:00.054  - info: javascript.0 (2413) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 56.2 °C
    2024-10-29 17:42:00.054  - info: javascript.0 (2413) script.js.common.Ping_zu_ESP_Garage: ESP Garage erreichbar
    2024-10-29 17:42:00.060  - info: javascript.0 (2413) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 199
     MB von 2048MB (10%)
    2024-10-29 17:42:00.064  - info: javascript.0 (2413) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 4300
     MB von 922MB (466%)
    2024-10-29 17:42:09.489  - info: mqtt.1 (2853) Client [mosqsub|32224-Dachrollo] connected with secret 1730220129488_7150
    2024-10-29 17:42:09.496  - info: mqtt.1 (2853) Client [mosqsub|32224-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-10-29 17:42:09.696  - info: mqtt.1 (2853) Client [mosqsub|32224-Dachrollo] publishOnSubscribe
    2024-10-29 17:42:09.698  - info: mqtt.1 (2853) Client [mosqsub|32224-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:09.784  - info: mqtt.1 (2853) Client [mosqsub|32226-Dachrollo] connected with secret 1730220129783_376
    2024-10-29 17:42:09.792  - info: mqtt.1 (2853) Client [mosqsub|32226-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-10-29 17:42:09.991  - info: mqtt.1 (2853) Client [mosqsub|32226-Dachrollo] publishOnSubscribe
    2024-10-29 17:42:09.995  - info: mqtt.1 (2853) Client [mosqsub|32226-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:10.083  - info: mqtt.1 (2853) Client [mosqsub|32228-Dachrollo] connected with secret 1730220130082_8766
    2024-10-29 17:42:10.085  - info: mqtt.1 (2853) Client [mosqsub|32228-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-10-29 17:42:10.290  - info: mqtt.1 (2853) Client [mosqsub|32228-Dachrollo] publishOnSubscribe
    2024-10-29 17:42:10.295  - info: mqtt.1 (2853) Client [mosqsub|32228-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:10.385  - info: mqtt.1 (2853) Client [mosqsub|32230-Dachrollo] connected with secret 1730220130381_2598
    2024-10-29 17:42:10.391  - info: mqtt.1 (2853) Client [mosqsub|32230-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-10-29 17:42:10.606  - info: mqtt.1 (2853) Client [mosqsub|32230-Dachrollo] publishOnSubscribe
    2024-10-29 17:42:10.613  - info: mqtt.1 (2853) Client [mosqsub|32230-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:10.709  - info: mqtt.1 (2853) Client [mosqsub|32232-Dachrollo] connected with secret 1730220130702_1490
    2024-10-29 17:42:10.713  - info: mqtt.1 (2853) Client [mosqsub|32232-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-10-29 17:42:10.926  - info: mqtt.1 (2853) Client [mosqsub|32232-Dachrollo] publishOnSubscribe
    2024-10-29 17:42:10.931  - info: mqtt.1 (2853) Client [mosqsub|32232-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:11.029  - info: mqtt.1 (2853) Client [mosqpub|32234-Dachrollo] connected with secret 1730220131025_2941
    2024-10-29 17:42:11.033  - info: mqtt.1 (2853) Client [mosqpub|32234-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:11.126  - info: mqtt.1 (2853) Client [mosqpub|32236-Dachrollo] connected with secret 1730220131125_3706
    2024-10-29 17:42:11.128  - info: mqtt.1 (2853) Client [mosqpub|32236-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:11.223  - info: mqtt.1 (2853) Client [mosqpub|32238-Dachrollo] connected with secret 1730220131223_4616
    2024-10-29 17:42:11.226  - info: mqtt.1 (2853) Client [mosqpub|32238-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:11.318  - info: mqtt.1 (2853) Client [mosqpub|32240-Dachrollo] connected with secret 1730220131318_7545
    2024-10-29 17:42:11.320  - info: mqtt.1 (2853) Client [mosqpub|32240-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:11.464  - info: mqtt.1 (2853) Client [mosqpub|32242-Dachrollo] connected with secret 1730220131450_8743
    2024-10-29 17:42:11.468  - info: mqtt.1 (2853) Client [mosqpub|32242-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:11.765  - info: mqtt.1 (2853) Client [mosqpub|32257-Dachrollo] connected with secret 1730220131764_8864
    2024-10-29 17:42:11.767  - info: mqtt.1 (2853) Client [mosqpub|32257-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:11.990  - info: mqtt.1 (2853) Client [mosqpub|32263-Dachrollo] connected with secret 1730220131973_9098
    2024-10-29 17:42:11.992  - info: mqtt.1 (2853) Client [mosqpub|32263-Dachrollo] connection closed: disconnected
    2024-10-29 17:42:25.976  - info: mqtt.1 (2853) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
    Alle Minuten kommen MQTT Daten von der Wetterstation rein. Sieht für mich sorichtig aus.
    Bleibt zu sagen, dass unter der alten Installation auf dem RPI3 keine 100% CPU gebraucht wurden.
    Habe ja beim RPI5 nur alles restored mittels Backitup.
    Wenn ich den MQTT Adapter pausiere, ist die CPU auf 2% !
    Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
    (Murphys Gesetz)
    • spicerS spicer
      @marc-berg
       MB von 2048MB (10%)
       MB von 922MB (466%)
      @spicer und was rattert da im Millisekundentakt durch?
      spicerS 1 Antwort Letzte Antwort
        spicerS Offline
        spicerS Offline
        spicer
        Alle 1 Minute kommen da die verschiedenen Daten von der Wetterstation.
        (Murphys Gesetz)
        wendy2702W Marc BergM 2 Antworten Letzte Antwort
        • spicerS spicer
          wendy2702W Online
          wendy2702W Online
          @spicer ist die Wetterstation der “Aussenfühler” ?
          • wendy2702W wendy2702
            spicerS Offline
            spicerS Offline
            spicer
            @wendy2702 Jep
            (Murphys Gesetz)
            • spicerS spicer
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              @spicer
              Hast du das Loglevel der MQTT.1 Instanz mal auf "debug" gestellt? Dann sieht man vielleicht mehr. So sieht das erstmal unspektakulär aus.
              • spicerS spicer
                @wendy2702 Jep
                wendy2702W Online
                wendy2702W Online
                @spicer der verliert scheinbar im Millisekunden Takt die Verbindung
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  @wendy2702 sagte in iobroker.js-con 100% cpu:
                  Oder ein ungünstig progammiertes Script, welches sich anmeldet, Wert subscribed, sich abmeldet, sich wieder anmeldet, nächsten Wert subscribed, ...
                  Darauf deutet der Name hin.
                  spicerS 2 Antworten Letzte Antwort
                  • Marc BergM Marc Berg
                    spicerS Offline
                    spicerS Offline
                    spicer
                    @marc-berg
                    Das könnte gut sein. Ich werd mal meine Scripts (Python und BASH) überprüfen.
                    (Murphys Gesetz)
                      spicerS Offline
                      spicerS Offline
                      spicer
                      @marc-berg
                      Du hast mich auf die richtige Fährte gebracht. Wenn ich die MQTT Server IP ändere (ins Leere), sieht top so aus:
                      (Murphys Gesetz)
                      • spicerS spicer
                        @marc-berg
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        @spicer sagte in iobroker.js-con 100% cpu:
                        @marc-berg sagte in iobroker.js-con 100% cpu:
                          spicerS Offline
                          spicerS Offline
                          spicer
                          @marc-berg
                          Ja, aber da kann so viel Output, dass top 300% CPU anzeigte ^^
                          (Murphys Gesetz)
                          • spicerS spicer
                            @marc-berg
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            @marc-berg
                            Das sagt aber schon alles. Ich bleibe dabei: eine Schleife.
                              @marc-berg
                              spicerS Offline
                              spicerS Offline
                              spicer
                              @marc-berg
                              Jo, das glaube ich Dir.
                              Muss nun suchen :(
                              Ist ziemlich viel.
                              (Murphys Gesetz)
                              • spicerS spicer
                                @marc-berg
                                Muss nun suchen :(
                                Ist ziemlich viel.
                                Marc BergM Offline
                                Marc BergM Offline
                                Marc Berg
                                Muss nun suchen
                                Aber wenn du das Debug-Log kurz anmachst, dann wirst du sicher Hinweise sehen.
                                  Muss nun suchen
                                  Ist zwar jetzt etwas OT hier, aber hier einer der wirklichen Gründe, warum man keine GUI auf einem Server laufen hat:
                                  https://www.phoronix.com/news/X.Org-CVE-2024-9632
                                  Was nicht läuft und am besten auch erst gar nicht installiert ist kann auch nicht anfällig für eine 'Privilege Escalation' sein.
                                  • spicerS Offline
                                    spicerS Offline
                                    spicer
                                    Hab das Problem gefunden.
                                    Alle 30 Sekunden oder teilweise sogar 10 Sekunden wurde der MQTT Server mit sub/pub's gelöchert.
                                    Wenn das geschieht, geht die CPU für ca 30 Sekunden auf 100%.
                                    Das war natürlich zuviel.
                                    Habe jetzt das Intervall (ausser Regen und Wind Warnung) auf mind 2 Minuten gesetzt.
                                    So beruhigt sich das Ganze immer für ca 90 Sekunden.
                                    (Murphys Gesetz)
                                    • spicerS Offline
                                      spicerS Offline
                                      spicer
                                      Konnte die Situation weiter entschärfen, in dem ich alles MQTT auf dem RPI1, welches für die Dachfenster und Rollo Steuerung zuständig ist, sammle.
                                      Sende dann nur alle paar Minuten MQTT Daten an das RPI5.
                                      Einzig die Windgeschwindigkeit sende ich jede minute (das ist ein String von 3-4 Zeichen).
                                      Es fällt auf, dass der ioBroker Adapter MQTT auch nur bei diesem empfangenen MQTT Datensatz die CPU für fast 30 Sekunden auf 100-106% (laut top) treibt.
                                      Es sieht so aus, dass da der Adapter auch "etwas komisches" macht. Wenn ihr mich fragt, mit dem Adapter stimmt was nicht.
                                      So viel Rechenleistung wegen einem einzigen Subscribe (Datenempfang) von zBsp "0.1".
                                      Ein Loop kann es nicht sein, weil das Gleiche geschieht, wenn ich die Instanz Javascript stoppe.
                                      Befriedigend ist die jetzige Lösung bzw Verhalten nicht.
                                      PS:
                                      Beim RPI1 zeigt top unter 1% Auslastung, obschon da jede Sekunde Mosquitto Daten reinschneien.
                                      Dieses hat einen Bruchteil der Rechenleistung des RPI5!
                                      Wenn ich auf dem RPI1 top ausführe, ist meistens top der belastendste Task ^^
                                      (Murphys Gesetz)
                                      • spicerS spicer
                                        PS:
                                        spicerS Offline
                                        spicerS Offline
                                        spicer
                                        @spicer
                                        Bitte testet doch mal selber und meldet es gegebenenfalls dem Dev.
                                        Es könnte ja auch sein, dass das nur bei Raspberry OS so ist und nicht bei Raspbian.
                                        deCONZ zBsp hatte genau dieses Problem!
                                        Eine if Abfrage ging auf "raspbian" und nicht auf "debian", was Raspberry OS heute ausgibt.
                                        (Murphys Gesetz)
                                        • spicerS spicer
                                          @spicer
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @spicer said in iobroker.js-con 100% cpu:
                                          @spicer
                                          Dass ein IF nicht geht klingt mal komisch. Wahrscheinlich meinst du eher, dass eine Abfrage eines APIs andere Werte geliefert hat.
                                          EGAL:
                                          Bitte gib doch bei allen solchen Problemmeldungen gesammelt die Versionsinfos an. Ich kann aus deinen letzen Beiträgen weder die Adapetr version noch js.controller, node, os etc herauslesen.
                                          Und natürlich stellt sich die Frage was der Adapetr im DEBUG bzw. SILLY Mode loggt wenn er so ausgelastet ist / wird.
                                          Support Repositoryverwaltung.
                                          LESEN - gute Forenbeitrage
