  4. Node-Red
  5. [Gelöst] Alexa - Geräte reagieren nicht mehr
    6.4k
95 Beiträge 8 Kommentatoren 19.2k Aufrufe 5 Beobachtet
  • Hant0rH Hant0r
    @da_woody
    mia culpa
    Script v.2024-10-19
    *** BASE SYSTEM ***
    Hardware Vendor : Synology
    Kernel          : x86_64
    Userland        : 64 bit
    Docker          : v9.1.1
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:02:48 up  1:32,  0 user,  load average: 1.57, 1.48, 2.06
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
    Mon Oct 21 09:02:48 UTC 2024
    Mon Oct 21 11:02:48 CEST 2024
    CEST +0200
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             12G        6.0G        278M        148M        6.6G        6.4G
    Swap:           9.6G         51M        9.5G
    Total:           21G        6.1G        9.8G
    Active iob-Instances:   42
            11822 M total memory
             5720 M used memory
             5573 M active memory
             4202 M inactive memory
              265 M free memory
               15 M buffer memory
             6273 M swap cache
             9143 M total swap
               49 M used swap
             9094 M free swap
    top - 11:02:48 up  1:32,  0 user,  load average: 1.57, 1.48, 2.06
    Tasks:  46 total,   1 running,  45 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  11822.1 total,    263.8 free,   5722.7 used,   6289.3 buff/cache
    MiB Swap:   9143.9 total,   9094.5 free,     49.4 used.   6099.5 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /opt/iobroker
    /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /etc/hosts
    tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
    tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
    tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
    [Mon Oct 21 09:30:50 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Mon Oct 21 09:30:50 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Oct 21 09:30:51 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Mon Oct 21 09:30:51 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Oct 21 09:30:56 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Mon Oct 21 09:30:56 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Oct 21 09:30:57 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Mon Oct 21 09:30:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Mon Oct 21 09:32:14 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    Show mounted filesystems:
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/d0da882db770853523f873ac478c26d97178e91ced4edd23e43bbcbc3faff250]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=3717,subvol=/@syno/@docker/btrfs/subvolumes/d0da882db770853523f873ac478c26d97178e91ced4edd23e43bbcbc3faff250
    |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/ioBroker_data]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker/ioBroker_data
    |-/opt/userscripts /dev/mapper/cachedev_0[/@syno/docker/userscripts]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker/userscripts
    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/resolv.conf
    |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hostname
    `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hosts
    /var:
    39M     /var/
    37M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    18M     /var/lib/dpkg
    /opt/iobroker/backups:
    629M    /opt/iobroker/backups/
    339M    /opt/iobroker/backups/Doorbird
    323M    /opt/iobroker/backups/Doorbird/Motion
    17M     /opt/iobroker/backups/Doorbird/Doorbell
    1.5M    /opt/iobroker/backups/scripts
    /opt/iobroker/iobroker-data:
    1.6G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/files
    615M    /opt/iobroker/iobroker-data/files/javascript.admin
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    556M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/objects.json.bak2
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    29M     /opt/iobroker/iobroker-data/states.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.4-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
     *** 18.20.4-1nodesource1 1001
           1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.3-1nodesource1 1001
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 1673)
    iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 1657)
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     8
    +-- iobroker.jablotron@0.1.3 (git+ssh://git@github.com/DEV2DEV-DE/ioBroker.jablotron.git#dc1b1e9d33abbd52148eb75e0a6d64f0cefbef19)
    +-- iobroker.javascript@8.8.3 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#840d03855636c4271971afc202532d008c22d264)
    +-- iobroker.mbus@2.7.0 (git+ssh://git@github.com/Apollon77/ioBroker.mbus.git#98a7dec9f646d76637fceca690092e6175665472)
    +-- iobroker.spritmonitor@0.0.2-beta.10 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#9ae450bb73048774252ab422c33750af4f6f3904)
    +-- iobroker.tapo@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#a0e9a3b930c67eceaee5f97d2a48094434838d36)
    +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
    +-- iobroker.tibberlink@3.5.1 (git+ssh://git@github.com/Hombach/ioBroker.tibberlink.git#6352b26d3016d46845aff2d6d5b81a7041794292)
    +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.backitup.1               : backitup              : iobroker-slave                           -  enabled
      system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker-slave                           -  enabled
    + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
      system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
    + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
    + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
    + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.node-red.1               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
    + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
    + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
    + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 -  enabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 -  enabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ (index) │        name        │                           url                           │ auto upgrade │
    │    0    │ 'Stable (default)' │    'http://download.iobroker.net/sources-dist.json'     │     true     │
    │    1    │  'Beta (latest)'   │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    │    2    │       'List'       │        'http://download.iobroker.net/list.html'         │    false     │
    Upgrade policy: patch
    Installed ioBroker-Instances
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": aborted
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
    Adapter    "dysonairpurifier": 3.2.3 , installed 3.2.3
    Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
    Adapter    "followthesun" : 0.5.1    , installed 0.5.1
    Adapter    "hs100"        : 2.2.0    , installed 2.2.0
    Adapter    "hue"          : 3.12.0   , installed 3.12.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "jablotron"    : 0.1.3    , installed 0.1.3
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "mbus"         : 2.7.0    , installed 2.7.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openknx"      : 0.9.0    , installed 0.7.0  [Updatable]
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tibberlink"   : 3.4.10   , installed 3.5.1
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        26969
    States:         23347
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.1.0.1:8100           0.0.0.0:*               LISTEN      1000       845424     -
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       742643     -
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       739941     -
    tcp        0      0 127.0.0.11:44407        0.0.0.0:*               LISTEN      0          734875     -
    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       749767     -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       740119     -
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       760148     -
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       762097     -
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       750748     -
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       755103     -
    udp        0      0 127.0.0.11:45913        0.0.0.0:*                           0          734874     -
    udp        0      0 0.0.0.0:54315           0.0.0.0:*                           1000       751514     -
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       755873     -
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       760072     -
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       760073     -
    2024-10-21 10:47:31.595  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.wochentag
    2024-10-21 10:47:31.595  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.datum
    2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.uhrzeit
    2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxadresse
    2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxport
    2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxuser
    2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxpassword
    2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdbname
    2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdaylight
    2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdblokal
    2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxssl
    2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.demodaten
    2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.homeassistant.status
    2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.test
    2024-10-21 10:47:31.598  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.test.test
    2024-10-21 10:47:32.169  - info: mqtt.0 (1671) All states published
    2024-10-21 10:49:16.192  - info: javascript.0 (202) script.js.Doorbird.OpenDoor: Tür wurde geöffnet von: Kathi
    2024-10-21 11:00:00.037  - info: host.ioBroker instance system.adapter.ical.0 in version "1.15.0" started with pid 3312
    2024-10-21 11:00:00.162  - info: javascript.0 (202) script.js.common.Zentralfunktionen.Astrozeiten_in_Datenpunkte: Astro: Gültige Zeiten: [aktueller Tag: 7] | [nächster Tag: 7] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
    2024-10-21 11:00:10.900  - info: host.ioBroker instance system.adapter.ical.0 having pid 3312 terminated with code 0 (NO_ERROR)
    2024-10-21 11:00:23.035  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3355
    2024-10-21 11:00:35.974  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 3355 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-10-21 11:01:38.078  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
    2024-10-21 11:01:38.550  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
    2024-10-21 11:01:48.542  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
    iob diag has finished.
    Samson71S Offline
    Samson71S Offline
    Samson71
    @hant0r
    Das Einzige was ich Dir sagen kann ist, dass Du Dein Docker-Image von 9.1.1 auf 10.0.0 anheben musst für Nodejs 20 (latest v9 wäre auch 9.1.2). Ob das aber das Problem löst, kann ich nicht beurteilen.
    Markus
    Bitte beachten:
    Hant0rH 1 Antwort Letzte Antwort
    • Samson71S Samson71
      @hant0r
      Hant0rH Offline
      Hant0rH Offline
      Hant0r
      @samson71 Danke dir, schaue ich mir mal an und hebe es auf die v10
      • Hant0rH Offline
        Hant0rH Offline
        Hant0r
        @samson71
        So bin nun auf Version 10 :)
        NodeRed lässt sich innerhalb von ioBroker aber immer noch nicht öffnen.
        Script v.2024-10-19
        *** BASE SYSTEM ***
        Kernel          : x86_64
        Userland        : 64 bit
        Docker          : v10.0.0
        Kernel          : x86_64
        Userland        : 64 bit
         12:28:51 up  2:58,  0 user,  load average: 2.51, 2.39, 2.18
        CPU threads: 4
        Mon Oct 21 10:28:51 UTC 2024
        Mon Oct 21 12:28:51 CEST 2024
        CEST +0200
        Etc/UTC
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/opt/iobroker
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             12G        5.3G        319M        147M        7.3G        7.1G
        Swap:           9.6G         95M        9.5G
        Total:           21G        5.3G        9.8G
                 5008 M used memory
                 5857 M active memory
                 4104 M inactive memory
                  303 M free memory
                   20 M buffer memory
                 6942 M swap cache
                 9143 M total swap
                   90 M used swap
                 9053 M free swap
        top - 12:28:52 up  2:58,  0 user,  load average: 2.47, 2.38, 2.18
        Tasks:  46 total,   2 running,  44 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  11822.1 total,    302.4 free,   5009.0 used,   6963.5 buff/cache
        MiB Swap:   9143.9 total,   9053.1 free,     90.8 used.   6813.1 avail Mem
        *** FILESYSTEM ***
        /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /opt/userscripts
        /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/c2b15a3e833836e6da787d233446ae3804fc6db06265af79ef2c8f42737601a0]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=3981,subvol=/@syno/@docker/btrfs/subvolumes/c2b15a3e833836e6da787d233446ae3804fc6db06265af79ef2c8f42737601a0
        |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/resolv.conf
        |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hostname
        `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hosts
        /var:
        34M     /var/
        32M     /var/lib
        19M     /var/lib/apt
        13M     /var/lib/dpkg
        29M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
        USB-Devices by-id:
        HINT:
        /dev/ttyUSB0
        /usr/bin/nodejs         v20.18.0
        /usr/bin/node           v20.18.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.18.0-1nodesource1
          Candidate: 20.18.0-1nodesource1
          Version table:
         *** 20.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 726)
        iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 3136)
        admin:          7.1.5
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        26969
        States:         23419
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Pending Updates: 0
        tcp        0      0 10.1.0.1:8100           0.0.0.0:*               LISTEN      1000       1671508    -
        tcp        0      0 127.0.0.11:35365        0.0.0.0:*               LISTEN      0          1650777    -
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1651429    -
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1657631    -
        tcp6       0      0 :::3500                 :::*                    LISTEN      1000       1653573    -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1659405    -
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1671493    -
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1677436    -
        udp        0      0 127.0.0.11:34303        0.0.0.0:*                           0          1650776    -
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       1664540    -
        udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       1665311    -
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1665591    -
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1671412    -
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1671413    -
        udp        0      0 0.0.0.0:56567           0.0.0.0:*                           1000       1664947    -
        2024-10-21 12:19:41.529  - info: energiefluss.0 (971) starting. Version 3.6.1 in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.18.0, js-controller: 6.0.11
        2024-10-21 12:19:41.563  - info: energiefluss.0 (971) Starting Energiefluss Adapter
        2024-10-21 12:19:42.114  - info: energiefluss.0 (971) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
        2024-10-21 12:19:42.126  - info: energiefluss.0 (971) Adapter started and listening to 18 States
        2024-10-21 12:19:42.801  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#208C4F#1.Relay0.gesamt successfully
        2024-10-21 12:19:42.804  - info: sourceanalytix.0 (807) Initialising (5 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#2176BA#1.Relay0.gesamt"
        2024-10-21 12:19:45.653  - info: tapo.0 (911) Start first Update
        2024-10-21 12:19:46.350  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#2176BA#1.Relay0.gesamt successfully
        2024-10-21 12:19:46.351  - info: sourceanalytix.0 (807) Initialising (6 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#5773B0#1.Relay0.gesamt"
        2024-10-21 12:19:48.792  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#5773B0#1.Relay0.gesamt successfully
        2024-10-21 12:19:48.793  - info: sourceanalytix.0 (807) Initialising (7 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#578088#1.Relay0.gesamt"
        2024-10-21 12:19:50.511  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#578088#1.Relay0.gesamt successfully
        2024-10-21 12:19:50.511  - info: sourceanalytix.0 (807) Initialising (8 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#AB969F#1.Relay0.gesamt"
        2024-10-21 12:19:52.350  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#AB969F#1.Relay0.gesamt successfully
        2024-10-21 12:19:52.351  - info: sourceanalytix.0 (807) Initialising (9 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#B582F5#1.Relay0.gesamt"
        2024-10-21 12:19:53.535  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#B582F5#1.Relay0.gesamt successfully
        2024-10-21 12:19:53.544  - info: sourceanalytix.0 (807) Successfully activated SourceAnalytix for 9 of 9 states, will do my Job until you stop me!
        2024-10-21 12:19:58.405  - info: alexa2.0 (436) Subscribing to states...
        2024-10-21 12:20:00.139  - info: alexa2.0 (436) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2024-10-21 12:20:11.758  - info: pvforecast.0 (949) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
        2024-10-21 12:20:23.112  - info: alexa2.0 (436) Initialization Done ...
        2024-10-21 12:23:31.035  - info: host.ioBroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1212
        2024-10-21 12:23:34.216  - info: openweathermap.0 (1212) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
        2024-10-21 12:23:49.101  - info: openweathermap.0 (1212) Terminated (NO_ERROR): Without reason
        2024-10-21 12:23:49.627  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 1212 terminated with code 0 (NO_ERROR)
        • Hant0rH Hant0r
          @da_woody
          mia culpa
          Script v.2024-10-19
          *** BASE SYSTEM ***
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v9.1.1
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
          CEST +0200
          Etc/UTC
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/opt/iobroker
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           9.6G         51M        9.5G
                   5720 M used memory
                    265 M free memory
                     15 M buffer memory
                   6273 M swap cache
                   9143 M total swap
                     49 M used swap
                   9094 M free swap
          *** FILESYSTEM ***
          /var:
          39M     /var/
          37M     /var/lib
          19M     /var/lib/apt
          18M     /var/lib/dpkg
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.1.5
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        26969
          States:         23347
          Pending Updates: 0
          da_WoodyD Offline
          da_WoodyD Offline
          @hant0r schon ok, mit nodered kann ich dir nicht helfen.
          systemupdate sollte aber immer vorrangig sein.
          allerdings verstehe ich auch nicht, warum du nodered für alexa brauchst. meine shelly dingens werden über den skill automatisch erkannt.
          Dr. BakteriusD 1 Antwort Letzte Antwort
          • da_WoodyD da_Woody
            Dr. BakteriusD Online
            Dr. Bakterius
            @da_woody sagte in Alexa - Geräte reagieren nicht mehr:
            Weil man damit ganz leicht eigene Geräte für Alexa anlegen kann. So kann ich meine Rollläden und die Markise mit Alexa steuern (und noch einiges anderes). Das ginge sonst nicht (ohne ioBroker-Cloud).
            • P Offline
              peterfido
              @dr-bakterius
              iob fix
              hast Du schon ausgeführt? Alexa krams braucht den Port 80, den 'schaltet' der fix wieder nutzbar.
              Ansonsten in den Node-Red-Adapter Einstellungen den Sicherheismodus aktivieren und gucken, ob Du dann drau kommst. Der Sicherheitmodus deaktiviert die Nodes alle, um hängende 'Programme' bearbeiten zu können.
              Peterfido
                Hant0rH Offline
                Hant0rH Offline
                Hant0r
                @dr-bakterius sagte in Alexa - Geräte reagieren nicht mehr:
                Genau so ist es. Ich nutze es, um Geräte zu simulieren, um Digne wie Rolladen, KNX Komponenten und Co zu steuern.
                @peterfido sagte in Alexa - Geräte reagieren nicht mehr:
                Habe ich ausgeführt, da sonst der "diag" Befehl nicht funktionierte. Mal sehen ob es geholfen hat.
                Seltsam ist ja aber, dass es mal klappt und dann wieder nicht.
                Ich werde es mal die Tage beobachten
                • Hant0rH Offline
                  Hant0rH Offline
                  Hant0r
                  Habes es nun paar Tage beobachtet. Gefühlt ist es etwas besser geworden, aber es kommt dennoch vor, dass die Alexa sagt "Das Gerät antwortet nicht" ... im ioBroker steht nichts im Log.
                  Öffne ich Node-Red, um es dort ggf. zu debuggen, geht es natürlich wieder als wäre nichts gewesen :(
                  • Hant0rH Offline
                    Hant0rH Offline
                    Hant0r
                    schrieb am zuletzt editiert von Hant0r
                    Ich habe es nun oft bemerkt, Alexa sagt erst "Gerät reagiert leider nicht", man wartet paar Sekunden und versuche es erneut und es funktioniert.
                    Im Node-Red kommt im Debug auch nichts an, wenn Alexa das Gerät nicht findet. Würde daher Node-Red ausschließen (oder?)
                    Ro75R 1 Antwort Letzte Antwort
                    • Hant0rH Hant0r
                      Ro75R Offline
                      Ro75R Offline
                      Ro75
                      @hant0r sschon mal das komplette Netzwerk neu gestartet? Alle Echos, und LAN, WLAN, Zigbee-Geräte?
                      Ro75.
                      • Ro75R Ro75
                        Ro75.
                        Hant0rH Offline
                        Hant0rH Offline
                        Hant0r
                        @ro75
                        ne bisher noch nicht. Mache ich mal.
                        Gar nicht so einfach alles im Haus neu zu starten... Aber auch die Batterie betriebenen Zigbee Geräte?
                        • Ro75R Offline
                          Ro75R Offline
                          Ro75
                          @hant0r sagte in Alexa - Geräte reagieren nicht mehr:
                          Nein. Aber Router (FB?), Echos...
                          Ro75.
                          • Dr. BakteriusD Online
                            Dr. Bakterius
                            schrieb am zuletzt editiert von Dr. Bakterius
                            Und den Rechner auf dem der ioBroker läuft nicht vergessen!
                            Nachdem heute ja die Zeitumstellung war, könnte man den FI testen und so automatisch alle Geräte die am Strom hängen auch neu starten.
                              da_WoodyD Offline
                              da_WoodyD Offline
                              nuja, das könnte bei raspis mit sd eventuell ungesund sein... mir hats bei stromausfall schon meinen synology router gekillt.
                              Thomas BraunT Dr. BakteriusD 2 Antworten Letzte Antwort
                                Nicht nur für die. Das findet kein Gerät wirklich prickelnd.
                                  da_WoodyD Offline
                                  da_WoodyD Offline
                                  @thomas-braun klar, mein server hats bis jetzt aber überlebt... ;)
                                  wollte damit nur sagen, alles runterfahren, dann kann man FI testen und alles in der richtigen reihenfolge wieder starten.
                                  mein kabelrouter ist als reines modem in betrieb. nach so einem blödsinn kam es schon vor, daß sich der router, oder ein pc beim provider angemeldet hat, weil der kabelrouter zu spät dran war mit einloggen. ergo, kein inet zugriff. anruf bei kabel+, reset vom kabeldingens, klappt wieder. geht schneller, als alles wieder selbst neu starten.
                                  • Ro75R Ro75
                                    Ro75.
                                    Hant0rH Offline
                                    Hant0rH Offline
                                    Hant0r
                                    @ro75 sagte in Alexa - Geräte reagieren nicht mehr:
                                    Ro75.
                                    Habe ich alle mal neu gestartet.
                                    Als Netzwerk setze ich auch das Unifi-System ohne FritzBox etc. - da geht das zum Glück recht easy :)
                                    Würde bei mir nicht viel passieren, es hängt alles hinter einer USV, genau damit es mir meine Synology und Rest nicht killt ;)
                                    Ich beobachte das Verhalten mal weiter
                                      Dr. Bakterius
                                      Deshalb investiert man auch in eine USV. Einen unangekündigten Stromausfall kann es immer geben. Oder eine Spannungsspitze. Aber natürlich fährt man vor einem FI-Test empfindliche Geräte kontrolliert herunter (wenn sie nicht von einer USV gebuffert werden).
                                      • Hant0rH Hant0r
                                        Ro75.
                                        Dr. Bakterius
                                        Auch sämtliche Aktoren (Shelly, Tasmota-Steckdosen, ESP, ...)? Meine Rechner und das gesamte Netzwerk (Modem, USG, Switche, Accesspoints) hängen auch bei mir an einer USV. Die werden natürlich kontrolliert neu gestartet wenn es notwendig ist.
                                          da_WoodyD Offline
                                          da_WoodyD Offline
                                          @dr-bakterius hast Recht, bin da noch faul. Der Server in der Werkstatt ist ja an einer usv. Der Router im Haus noch nicht.
                                          Tipps für neue Geräte?
