  4. Node-Red
  5. [Gelöst] Alexa - Geräte reagieren nicht mehr
    6.4k
95 Beiträge 8 Kommentatoren 19.2k Aufrufe 5 Beobachtet
  • Hant0rH Hant0r
    @samson71
    Danke dir, hier das Log:
    ℹ ioBroker läuft in einem Docker auf einer Diskstation
                            v.2024-10-19
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v9.1.1
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               CEST +0200
    User-ID:                0
    Display-Server:         false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    Recommended versions are nodejs 20.18.0 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:             12G        5.9G        377M        148M        6.6G        6.5G
    Swap:           9.6G         49M        9.5G
    Total:           21G        6.0G        9.9G
    Active iob-Instances:   42
    Upgrade policy: patch
    ioBroker Core:          js-controller           6.0.11
                            admin                   7.1.5
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                26969
    States:                 23419
    Size of iob-Database:
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/objects.json.bak2
    19M     /opt/iobroker/iobroker-data/objects.json.migrated
    19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    23M     /opt/iobroker/iobroker-data/states.jsonl
    4.8M    /opt/iobroker/iobroker-data/states.json.migrated
    4.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    da_WoodyD Offline
    da_WoodyD Offline
    @hant0r was ist so schwer zu verstehen? Full iobdiag, nicht die summery.
    Hant0rH 1 Antwort Letzte Antwort
    • Hant0rH Hant0r
      @samson71
                              v.2024-10-19
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.1
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                0
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      MEMORY:
      Swap:           9.6G         49M        9.5G
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                26969
      States:                 23419
      Samson71S Offline
      Samson71S Offline
      Samson71
      @hant0r sagte in Alexa - Geräte reagieren nicht mehr:
      Ist "nur" der Summary, nicht das vollständige iob diag, aber
      Da bin ich dann auch vermutlich raus.
      Markus
      Bitte beachten:
      • da_WoodyD da_Woody
        Hant0rH Offline
        Hant0rH Offline
        Hant0r
        @da_woody
        mia culpa
        Script v.2024-10-19
        *** BASE SYSTEM ***
        Hardware Vendor : Synology
        Kernel          : x86_64
        Userland        : 64 bit
        Docker          : v9.1.1
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         11:02:48 up  1:32,  0 user,  load average: 1.57, 1.48, 2.06
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        *** TIME AND TIMEZONES ***
        Mon Oct 21 09:02:48 UTC 2024
        Mon Oct 21 11:02:48 CEST 2024
        CEST +0200
        Etc/UTC
        *** Users and Groups ***
        User that called 'iob diag':
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/opt/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             12G        6.0G        278M        148M        6.6G        6.4G
        Swap:           9.6G         51M        9.5G
        Total:           21G        6.1G        9.8G
                11822 M total memory
                 5720 M used memory
                 5573 M active memory
                 4202 M inactive memory
                  265 M free memory
                   15 M buffer memory
                 6273 M swap cache
                 9143 M total swap
                   49 M used swap
                 9094 M free swap
        top - 11:02:48 up  1:32,  0 user,  load average: 1.57, 1.48, 2.06
        Tasks:  46 total,   1 running,  45 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  11822.1 total,    263.8 free,   5722.7 used,   6289.3 buff/cache
        MiB Swap:   9143.9 total,   9094.5 free,     49.4 used.   6099.5 avail Mem
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem             Type   Size  Used Avail Use% Mounted on
        /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /
        tmpfs                  tmpfs   64M     0   64M   0% /dev
        tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
        shm                    tmpfs   64M     0   64M   0% /dev/shm
        /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /opt/iobroker
        /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /etc/hosts
        tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
        tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
        tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
        [Mon Oct 21 09:30:50 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
        [Mon Oct 21 09:30:50 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Oct 21 09:30:51 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
        [Mon Oct 21 09:30:51 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Oct 21 09:30:56 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
        [Mon Oct 21 09:30:56 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Oct 21 09:30:57 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
        [Mon Oct 21 09:30:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
        [Mon Oct 21 09:32:14 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
        Show mounted filesystems:
        TARGET             SOURCE        FSTYPE OPTIONS
        /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/d0da882db770853523f873ac478c26d97178e91ced4edd23e43bbcbc3faff250]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=3717,subvol=/@syno/@docker/btrfs/subvolumes/d0da882db770853523f873ac478c26d97178e91ced4edd23e43bbcbc3faff250
        |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/ioBroker_data]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker/ioBroker_data
        |-/opt/userscripts /dev/mapper/cachedev_0[/@syno/docker/userscripts]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker/userscripts
        |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/resolv.conf
        |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hostname
        `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/d2bc4a1fdf829e456d5ca93c9d5d815829f4572f4fdeae36884f4dfd61ea0bb2/hosts
        /var:
        39M     /var/
        37M     /var/lib
        19M     /var/lib/apt/lists
        19M     /var/lib/apt
        18M     /var/lib/dpkg
        /opt/iobroker/backups:
        629M    /opt/iobroker/backups/
        339M    /opt/iobroker/backups/Doorbird
        323M    /opt/iobroker/backups/Doorbird/Motion
        17M     /opt/iobroker/backups/Doorbird/Doorbell
        1.5M    /opt/iobroker/backups/scripts
        /opt/iobroker/iobroker-data:
        1.6G    /opt/iobroker/iobroker-data/
        1.1G    /opt/iobroker/iobroker-data/files
        615M    /opt/iobroker/iobroker-data/files/javascript.admin
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        556M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        29M     /opt/iobroker/iobroker-data/states.jsonl
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyUSB0
        *** NodeJS-Installation ***
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        nodejs:
          Installed: 18.20.4-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
         *** 18.20.4-1nodesource1 1001
               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.20.3-1nodesource1 1001
             18.20.2-1nodesource1 1001
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 1673)
        iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 1657)
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     8
        +-- iobroker.jablotron@0.1.3 (git+ssh://git@github.com/DEV2DEV-DE/ioBroker.jablotron.git#dc1b1e9d33abbd52148eb75e0a6d64f0cefbef19)
        +-- iobroker.javascript@8.8.3 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#840d03855636c4271971afc202532d008c22d264)
        +-- iobroker.mbus@2.7.0 (git+ssh://git@github.com/Apollon77/ioBroker.mbus.git#98a7dec9f646d76637fceca690092e6175665472)
        +-- iobroker.spritmonitor@0.0.2-beta.10 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#9ae450bb73048774252ab422c33750af4f6f3904)
        +-- iobroker.tapo@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#a0e9a3b930c67eceaee5f97d2a48094434838d36)
        +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
        +-- iobroker.tibberlink@3.5.1 (git+ssh://git@github.com/Hombach/ioBroker.tibberlink.git#6352b26d3016d46845aff2d6d5b81a7041794292)
        +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
        Adapter State
        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.backitup.1               : backitup              : iobroker-slave                           -  enabled
          system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
          system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker-slave                           -  enabled
        + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
          system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
        + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
        + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
        + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
        + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
        + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
        + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
          system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
          system.adapter.node-red.1               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
        + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
        + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
        + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
        + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
        + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
        + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
        + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
        + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
        + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
        + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 -  enabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 -  enabled
          system.adapter.vis-players.0            : vis-players           : ioBroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        │ (index) │        name        │                           url                           │ auto upgrade │
        │    0    │ 'Stable (default)' │    'http://download.iobroker.net/sources-dist.json'     │     true     │
        │    1    │  'Beta (latest)'   │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        │    2    │       'List'       │        'http://download.iobroker.net/list.html'         │    false     │
        Installed ioBroker-Instances
        Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": aborted
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "cameras"      : 2.1.2    , installed 2.1.2
        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
        Adapter    "dysonairpurifier": 3.2.3 , installed 3.2.3
        Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
        Adapter    "followthesun" : 0.5.1    , installed 0.5.1
        Adapter    "hs100"        : 2.2.0    , installed 2.2.0
        Adapter    "hue"          : 3.12.0   , installed 3.12.0
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "jablotron"    : 0.1.3    , installed 0.1.3
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "mbus"         : 2.7.0    , installed 2.7.0
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "openknx"      : 0.9.0    , installed 0.7.0  [Updatable]
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "tibberlink"   : 3.4.10   , installed 3.5.1
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        26969
        States:         23347
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 10.1.0.1:8100           0.0.0.0:*               LISTEN      1000       845424     -
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       742643     -
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       739941     -
        tcp        0      0 127.0.0.11:44407        0.0.0.0:*               LISTEN      0          734875     -
        tcp6       0      0 :::3500                 :::*                    LISTEN      1000       749767     -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       740119     -
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       760148     -
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       762097     -
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       750748     -
        udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       755103     -
        udp        0      0 127.0.0.11:45913        0.0.0.0:*                           0          734874     -
        udp        0      0 0.0.0.0:54315           0.0.0.0:*                           1000       751514     -
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       755873     -
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       760072     -
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       760073     -
        2024-10-21 10:47:31.595  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.wochentag
        2024-10-21 10:47:31.595  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.datum
        2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.uhrzeit
        2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxadresse
        2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxport
        2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxuser
        2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxpassword
        2024-10-21 10:47:31.596  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdbname
        2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdaylight
        2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxdblokal
        2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.influxssl
        2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.huawei.demodaten
        2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.homeassistant.status
        2024-10-21 10:47:31.597  - info: mqtt.0 (1671) Publishing state mqtt.0.test
        2024-10-21 10:47:31.598  - info: mqtt.0 (1671) Publishing state mqtt.0.solaranzeige.test.test
        2024-10-21 10:47:32.169  - info: mqtt.0 (1671) All states published
        2024-10-21 10:49:16.192  - info: javascript.0 (202) script.js.Doorbird.OpenDoor: Tür wurde geöffnet von: Kathi
        2024-10-21 11:00:00.037  - info: host.ioBroker instance system.adapter.ical.0 in version "1.15.0" started with pid 3312
        2024-10-21 11:00:00.162  - info: javascript.0 (202) script.js.common.Zentralfunktionen.Astrozeiten_in_Datenpunkte: Astro: Gültige Zeiten: [aktueller Tag: 7] | [nächster Tag: 7] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
        2024-10-21 11:00:10.900  - info: host.ioBroker instance system.adapter.ical.0 having pid 3312 terminated with code 0 (NO_ERROR)
        2024-10-21 11:00:23.035  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3355
        2024-10-21 11:00:35.974  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 3355 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-10-21 11:01:38.078  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
        2024-10-21 11:01:38.550  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
        2024-10-21 11:01:48.542  - info: javascript.0 (202) script.js.common.Verbraucher.Switch-HWR: Hue-Switch - Waschmaschine = 1002
        iob diag has finished.
        Samson71S da_WoodyD 2 Antworten Letzte Antwort
        • Hant0rH Hant0r
          @da_woody
          mia culpa
          Script v.2024-10-19
          *** BASE SYSTEM ***
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v9.1.1
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
          CEST +0200
          Etc/UTC
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/opt/iobroker
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           9.6G         51M        9.5G
                   5720 M used memory
                    265 M free memory
                     15 M buffer memory
                   6273 M swap cache
                   9143 M total swap
                     49 M used swap
                   9094 M free swap
          *** FILESYSTEM ***
          /var:
          39M     /var/
          37M     /var/lib
          19M     /var/lib/apt
          18M     /var/lib/dpkg
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.1.5
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        26969
          States:         23347
          Pending Updates: 0
          Samson71S Offline
          Samson71S Offline
          Samson71
          @hant0r
          Das Einzige was ich Dir sagen kann ist, dass Du Dein Docker-Image von 9.1.1 auf 10.0.0 anheben musst für Nodejs 20 (latest v9 wäre auch 9.1.2). Ob das aber das Problem löst, kann ich nicht beurteilen.
          Markus
          Bitte beachten:
          • Samson71S Samson71
            @hant0r
            Hant0rH Offline
            Hant0rH Offline
            Hant0r
            @samson71 Danke dir, schaue ich mir mal an und hebe es auf die v10
            • Hant0rH Offline
              Hant0rH Offline
              Hant0r
              @samson71
              So bin nun auf Version 10 :)
              NodeRed lässt sich innerhalb von ioBroker aber immer noch nicht öffnen.
              Script v.2024-10-19
              *** BASE SYSTEM ***
              Kernel          : x86_64
              Userland        : 64 bit
              Docker          : v10.0.0
              Kernel          : x86_64
              Userland        : 64 bit
               12:28:51 up  2:58,  0 user,  load average: 2.51, 2.39, 2.18
              CPU threads: 4
              Mon Oct 21 10:28:51 UTC 2024
              Mon Oct 21 12:28:51 CEST 2024
              CEST +0200
              Etc/UTC
              root
              HOME=/root
              GROUPS=root
              iobroker
              HOME=/opt/iobroker
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:             12G        5.3G        319M        147M        7.3G        7.1G
              Swap:           9.6G         95M        9.5G
              Total:           21G        5.3G        9.8G
                       5008 M used memory
                       5857 M active memory
                       4104 M inactive memory
                        303 M free memory
                         20 M buffer memory
                       6942 M swap cache
                       9143 M total swap
                         90 M used swap
                       9053 M free swap
              top - 12:28:52 up  2:58,  0 user,  load average: 2.47, 2.38, 2.18
              Tasks:  46 total,   2 running,  44 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :  11822.1 total,    302.4 free,   5009.0 used,   6963.5 buff/cache
              MiB Swap:   9143.9 total,   9053.1 free,     90.8 used.   6813.1 avail Mem
              *** FILESYSTEM ***
              /dev/mapper/cachedev_0 btrfs  7.0T  2.0T  5.0T  29% /opt/userscripts
              /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/c2b15a3e833836e6da787d233446ae3804fc6db06265af79ef2c8f42737601a0]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=3981,subvol=/@syno/@docker/btrfs/subvolumes/c2b15a3e833836e6da787d233446ae3804fc6db06265af79ef2c8f42737601a0
              |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/resolv.conf
              |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hostname
              `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/49d967840f2c6469a3d6e81af42c835c14961f840646beadad9f9ae2b7654bd8/hosts
              /var:
              34M     /var/
              32M     /var/lib
              19M     /var/lib/apt
              13M     /var/lib/dpkg
              29M     /opt/iobroker/iobroker-data/objects.jsonl
              24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
              USB-Devices by-id:
              HINT:
              /dev/ttyUSB0
              /usr/bin/nodejs         v20.18.0
              /usr/bin/node           v20.18.0
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.29.3
              nodejs:
                Installed: 20.18.0-1nodesource1
                Candidate: 20.18.0-1nodesource1
                Version table:
               *** 20.18.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 726)
              iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 3136)
              admin:          7.1.5
              javascript:     8.8.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        26969
              States:         23419
              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
              Pending Updates: 0
              tcp        0      0 10.1.0.1:8100           0.0.0.0:*               LISTEN      1000       1671508    -
              tcp        0      0 127.0.0.11:35365        0.0.0.0:*               LISTEN      0          1650777    -
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1651429    -
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1657631    -
              tcp6       0      0 :::3500                 :::*                    LISTEN      1000       1653573    -
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1659405    -
              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1671493    -
              tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1677436    -
              udp        0      0 127.0.0.11:34303        0.0.0.0:*                           0          1650776    -
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       1664540    -
              udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       1665311    -
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1665591    -
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1671412    -
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1671413    -
              udp        0      0 0.0.0.0:56567           0.0.0.0:*                           1000       1664947    -
              2024-10-21 12:19:41.529  - info: energiefluss.0 (971) starting. Version 3.6.1 in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.18.0, js-controller: 6.0.11
              2024-10-21 12:19:41.563  - info: energiefluss.0 (971) Starting Energiefluss Adapter
              2024-10-21 12:19:42.114  - info: energiefluss.0 (971) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
              2024-10-21 12:19:42.126  - info: energiefluss.0 (971) Adapter started and listening to 18 States
              2024-10-21 12:19:42.801  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#208C4F#1.Relay0.gesamt successfully
              2024-10-21 12:19:42.804  - info: sourceanalytix.0 (807) Initialising (5 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#2176BA#1.Relay0.gesamt"
              2024-10-21 12:19:45.653  - info: tapo.0 (911) Start first Update
              2024-10-21 12:19:46.350  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#2176BA#1.Relay0.gesamt successfully
              2024-10-21 12:19:46.351  - info: sourceanalytix.0 (807) Initialising (6 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#5773B0#1.Relay0.gesamt"
              2024-10-21 12:19:48.792  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#5773B0#1.Relay0.gesamt successfully
              2024-10-21 12:19:48.793  - info: sourceanalytix.0 (807) Initialising (7 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#578088#1.Relay0.gesamt"
              2024-10-21 12:19:50.511  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#578088#1.Relay0.gesamt successfully
              2024-10-21 12:19:50.511  - info: sourceanalytix.0 (807) Initialising (8 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#AB969F#1.Relay0.gesamt"
              2024-10-21 12:19:52.350  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#AB969F#1.Relay0.gesamt successfully
              2024-10-21 12:19:52.351  - info: sourceanalytix.0 (807) Initialising (9 of 9) "javascript.0.ShellyVerbrauch.SHPLG-S#B582F5#1.Relay0.gesamt"
              2024-10-21 12:19:53.535  - info: sourceanalytix.0 (807) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#B582F5#1.Relay0.gesamt successfully
              2024-10-21 12:19:53.544  - info: sourceanalytix.0 (807) Successfully activated SourceAnalytix for 9 of 9 states, will do my Job until you stop me!
              2024-10-21 12:19:58.405  - info: alexa2.0 (436) Subscribing to states...
              2024-10-21 12:20:00.139  - info: alexa2.0 (436) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2024-10-21 12:20:11.758  - info: pvforecast.0 (949) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
              2024-10-21 12:20:23.112  - info: alexa2.0 (436) Initialization Done ...
              2024-10-21 12:23:31.035  - info: host.ioBroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1212
              2024-10-21 12:23:34.216  - info: openweathermap.0 (1212) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
              2024-10-21 12:23:49.101  - info: openweathermap.0 (1212) Terminated (NO_ERROR): Without reason
              2024-10-21 12:23:49.627  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 1212 terminated with code 0 (NO_ERROR)
              • Hant0rH Hant0r
                @da_woody
                mia culpa
                Script v.2024-10-19
                *** BASE SYSTEM ***
                Kernel          : x86_64
                Userland        : 64 bit
                Docker          : v9.1.1
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 4
                CEST +0200
                Etc/UTC
                root
                HOME=/root
                GROUPS=root
                iobroker
                HOME=/opt/iobroker
                Desktop:
                Terminal:
                *** MEMORY ***
                Swap:           9.6G         51M        9.5G
                         5720 M used memory
                          265 M free memory
                           15 M buffer memory
                         6273 M swap cache
                         9143 M total swap
                           49 M used swap
                         9094 M free swap
                *** FILESYSTEM ***
                /var:
                39M     /var/
                37M     /var/lib
                19M     /var/lib/apt
                18M     /var/lib/dpkg
                USB-Devices by-id:
                HINT:
                /dev/ttyUSB0
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.1.5
                javascript:     8.8.3
                Adapter State
                + instance is alive
                Objects and States
                Objects:        26969
                States:         23347
                Pending Updates: 0
                da_WoodyD Offline
                da_WoodyD Offline
                @hant0r schon ok, mit nodered kann ich dir nicht helfen.
                systemupdate sollte aber immer vorrangig sein.
                allerdings verstehe ich auch nicht, warum du nodered für alexa brauchst. meine shelly dingens werden über den skill automatisch erkannt.
                Dr. BakteriusD 1 Antwort Letzte Antwort
                  Dr. BakteriusD Online
                  Dr. Bakterius
                  @da_woody sagte in Alexa - Geräte reagieren nicht mehr:
                  Weil man damit ganz leicht eigene Geräte für Alexa anlegen kann. So kann ich meine Rollläden und die Markise mit Alexa steuern (und noch einiges anderes). Das ginge sonst nicht (ohne ioBroker-Cloud).
                  • P Offline
                    peterfido
                    @dr-bakterius
                    iob fix
                    hast Du schon ausgeführt? Alexa krams braucht den Port 80, den 'schaltet' der fix wieder nutzbar.
                    Ansonsten in den Node-Red-Adapter Einstellungen den Sicherheismodus aktivieren und gucken, ob Du dann drau kommst. Der Sicherheitmodus deaktiviert die Nodes alle, um hängende 'Programme' bearbeiten zu können.
                    Peterfido
                      Hant0rH Offline
                      Hant0rH Offline
                      Hant0r
                      @dr-bakterius sagte in Alexa - Geräte reagieren nicht mehr:
                      Genau so ist es. Ich nutze es, um Geräte zu simulieren, um Digne wie Rolladen, KNX Komponenten und Co zu steuern.
                      @peterfido sagte in Alexa - Geräte reagieren nicht mehr:
                      Habe ich ausgeführt, da sonst der "diag" Befehl nicht funktionierte. Mal sehen ob es geholfen hat.
                      Seltsam ist ja aber, dass es mal klappt und dann wieder nicht.
                      Ich werde es mal die Tage beobachten
                      • Hant0rH Offline
                        Hant0rH Offline
                        Hant0r
                        Habes es nun paar Tage beobachtet. Gefühlt ist es etwas besser geworden, aber es kommt dennoch vor, dass die Alexa sagt "Das Gerät antwortet nicht" ... im ioBroker steht nichts im Log.
                        Öffne ich Node-Red, um es dort ggf. zu debuggen, geht es natürlich wieder als wäre nichts gewesen :(
                        • Hant0rH Offline
                          Hant0rH Offline
                          Hant0r
                          schrieb am zuletzt editiert von Hant0r
                          Ich habe es nun oft bemerkt, Alexa sagt erst "Gerät reagiert leider nicht", man wartet paar Sekunden und versuche es erneut und es funktioniert.
                          Im Node-Red kommt im Debug auch nichts an, wenn Alexa das Gerät nicht findet. Würde daher Node-Red ausschließen (oder?)
                          Ro75R 1 Antwort Letzte Antwort
                          • Hant0rH Hant0r
                            Ro75R Offline
                            Ro75R Offline
                            Ro75
                            @hant0r sschon mal das komplette Netzwerk neu gestartet? Alle Echos, und LAN, WLAN, Zigbee-Geräte?
                            Ro75.
                            • Ro75R Ro75
                              Ro75.
                              Hant0rH Offline
                              Hant0rH Offline
                              Hant0r
                              @ro75
                              ne bisher noch nicht. Mache ich mal.
                              Gar nicht so einfach alles im Haus neu zu starten... Aber auch die Batterie betriebenen Zigbee Geräte?
                              • Ro75R Offline
                                Ro75R Offline
                                Ro75
                                Nein. Aber Router (FB?), Echos...
                                Ro75.
                                • Dr. BakteriusD Online
                                  Dr. Bakterius
                                  schrieb am zuletzt editiert von Dr. Bakterius
                                  Und den Rechner auf dem der ioBroker läuft nicht vergessen!
                                  Nachdem heute ja die Zeitumstellung war, könnte man den FI testen und so automatisch alle Geräte die am Strom hängen auch neu starten.
                                    da_WoodyD Offline
                                    da_WoodyD Offline
                                    nuja, das könnte bei raspis mit sd eventuell ungesund sein... mir hats bei stromausfall schon meinen synology router gekillt.
                                    Thomas BraunT Dr. BakteriusD 2 Antworten Letzte Antwort
                                      Nicht nur für die. Das findet kein Gerät wirklich prickelnd.
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        @thomas-braun klar, mein server hats bis jetzt aber überlebt... ;)
                                        wollte damit nur sagen, alles runterfahren, dann kann man FI testen und alles in der richtigen reihenfolge wieder starten.
                                        mein kabelrouter ist als reines modem in betrieb. nach so einem blödsinn kam es schon vor, daß sich der router, oder ein pc beim provider angemeldet hat, weil der kabelrouter zu spät dran war mit einloggen. ergo, kein inet zugriff. anruf bei kabel+, reset vom kabeldingens, klappt wieder. geht schneller, als alles wieder selbst neu starten.
                                        • Ro75R Ro75
                                          Ro75.
                                          Hant0rH Offline
                                          Hant0rH Offline
                                          Hant0r
                                          @ro75 sagte in Alexa - Geräte reagieren nicht mehr:
                                          Ro75.
                                          Habe ich alle mal neu gestartet.
                                          Als Netzwerk setze ich auch das Unifi-System ohne FritzBox etc. - da geht das zum Glück recht easy :)
                                          Würde bei mir nicht viel passieren, es hängt alles hinter einer USV, genau damit es mir meine Synology und Rest nicht killt ;)
                                          Ich beobachte das Verhalten mal weiter
