  3. Einsteigerfragen
  4. Installation
  5. vw-connect Adapter nicht mehr verfügbar
29 Beiträge 4 Kommentatoren 3.8k Aufrufe 4 Beobachtet
    @wibear
    Ja, der kann nur ohne laufende iob-Prozesse funktionieren.
    iob stop
    iob fix
    W Offline
    W Offline
    wibear
    Ausgeführt und IOB gestartet
    Welcome to the ioBroker installation fixer!
      Script version: 2024-10-22
      You might need to enter your password a couple of times.
      Installing prerequisites (1/5)
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
    Hit:4 https://packages.grafana.com/oss/deb stable InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:6 https://repos.influxdata.com/debian bullseye InRelease
    Reading package lists... Done
    E: Unable to locate package polkitd
    Installed polkitd
      Checking ioBroker user and directory permissions (2/5)
    This system does not support setting default permissions.
    Do not use npm to manually install adapters unless you know what you are doing!
      Check and cleanup npm temporary directories (3/5)
    Done.
      Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
      Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
      Your installation was fixed successfully
      Run iobroker start to start ioBroker again!
    • W wibear
      Installed polkitd
      Done.
      Autostart enabled!
      @wibear
      Dann dürfte ja jetzt auch
      iob diag
      laufen.
      W 1 Antwort Letzte Antwort
        @wibear
        iob diag
        laufen.
        W Offline
        W Offline
        wibear
        @thomas-braun sagte in vw-connect Adapter nicht mehr verfügbar:
        leider nicht:
        *** iob diag is starting up, please wait ***
        iob diag needs to be updated. Please execute 'iobroker fix' first.
        • W wibear
          leider nicht:
          @wibear
          sudo apt update && sudo apt install distro-info
          Wobei das eigentlich auch der Fixer hätte fixen sollen...
            @wibear
            W Offline
            W Offline
            wibear
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:5 https://repos.influxdata.com/debian bullseye InRelease
            Hit:6 https://packages.grafana.com/oss/deb stable InRelease
            All packages are up to date.
            distro-info is already the newest version (1.0+deb11u1).
            distro-info set to manually installed.
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            • W wibear
              @wibear
              Sollte eigentlich dann aber funktionieren.
              distro-info --stable
              sagt? Und bitte immer die vollständige Ein- wie Ausgaben zeigen.
                @wibear
                W Offline
                W Offline
                wibear
                Unbekannt?
                wibear@iobroker-pi:~ $ distro-info --stable
                -bash: distro-info: command not found
                • W wibear
                  Unbekannt?
                  @wibear
                  ??? Du hast es aber doch installiert???
                  ls -la /usr/bin/distro-info
                  echo $PATH
                  sagt?
                    @wibear
                    Ist hier verfügbar. Sowohl über npm/beta wie auch github.
                    Dein Setup sieht wie aus?
                    iob diag
                    mal anschauen.
                    W Offline
                    W Offline
                    wibear
                    Wie finde ich das?
                      @wibear
                      echo $PATH
                      sagt?
                      W Offline
                      W Offline
                      wibear
                      sagt?
                      echo $PATH
                      lrwxrwxrwx 1 root root 20 Oct 29  2023 /usr/bin/distro-info -> raspbian-distro-info
                      /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                      • W wibear
                        sagt?
                        echo $PATH
                        @wibear sagte in vw-connect Adapter nicht mehr verfügbar:
                        Die Version ist mir unbekannt. Magst du mal die Raspbian-Version von iob-diag testen?
                        https://forum.iobroker.net/topic/59549/iob-diag-skript
                        Und mal die Ausgabe von
                        apt policy distro-info
                        noch?
                        W 2 Antworten Letzte Antwort
                          noch?
                          W Offline
                          W Offline
                          wibear
                          wibear@iobroker-pi:~ $ raspbian-distro-info
                          -bash: raspbian-distro-info: command not found
                          distro-info:
                            Installed: 1.0+deb11u1
                            Candidate: 1.0+deb11u1
                            Version table:
                           *** 1.0+deb11u1 500
                                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package   s
                          Command not founf:
                          • W wibear
                            distro-info:
                              Version table:
                             *** 1.0+deb11u1 500
                            Command not founf:
                            @wibear
                            Eigentlich ergibt das nicht viel Sinn...
                            ls -l /usr/bin/raspbian-distro-info
                            ls -l /usr/bin/debian-distro-info
                            ls -l /usr/bin/ubuntu-distro-info
                            sagt?
                              noch?
                              W Offline
                              W Offline
                              wibear
                              ```bash
                                                      v.2024-10-26 Raspbian
                                 Static hostname: iobroker-pi
                                       Icon name: computer
                                Operating System: Raspbian GNU/Linux 11 (bullseye)
                                          Kernel: Linux 6.1.21-v7l+
                                    Architecture: arm
                              Kernel:                 armv7l
                              Userland:               32 bit
                              User-ID:                1000
                              Display-Server:         false
                              Boot Target:            multi-user.target
                              Pending OS-Updates:     0
                              Pending iob updates:    0
                              Nodejs-Installation:
                              /usr/bin/nodejs         v20.18.0
                              /usr/bin/node           v20.18.0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              /usr/bin/corepack       0.29.3
                              Recommended versions are nodejs 20.18.0 and npm 10.8.2
                              nodeJS installation is correct
                              MEMORY:
                              Mem:            3.9G        1.3G        1.9G        1.0M        688M        2.5G
                              Swap:            99M          0B         99M
                              Total:          4.0G        1.3G        2.0G
                              Active iob-Instances:   23
                              Upgrade policy: patch
                              ioBroker Core:          js-controller           6.0.11
                                                      admin                   7.1.5
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects:                6233
                              States:                 5240
                              Size of iob-Database:
                              15M     /opt/iobroker/iobroker-data/objects.jsonl
                              9.4M    /opt/iobroker/iobroker-data/states.jsonl
                              Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                              • W wibear
                                ```bash
                                         Icon name: computer
                                      Architecture: arm
                                Kernel:                 armv7l
                                Userland:               32 bit
                                User-ID:                1000
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                MEMORY:
                                Swap:            99M          0B         99M
                                                        admin                   7.1.5
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                6233
                                States:                 5240
                                @wibear
                                Die Langfassung? Da dürfte es ein paar Fehler hageln.
                                  @wibear
                                  W Offline
                                  W Offline
                                  wibear
                                  Die Langfassung
                                  Wie bekomme ich diese?
                                    @wibear
                                    W Offline
                                    W Offline
                                    wibear
                                    ```bash
                                    Script v.2024-10-26 Raspbian
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm
                                    OS is similar to: debian
                                    Model           : Raspberry Pi 4 Model B Rev 1.5
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : armv7l
                                    Userland        : 32 bit
                                    Systemuptime and Load:
                                     19:54:22 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
                                    CPU threads: 4
                                    *** LIFE CYCLE STATUS ***
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    *** TIME AND TIMEZONES ***
                                                   Local time: Sat 2024-10-26 19:54:22 CEST
                                               Universal time: Sat 2024-10-26 17:54:22 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** Users and Groups ***
                                    User that called 'iob diag':
                                    wibear
                                    HOME=/home/wibear
                                    GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    *** DISPLAY-SERVER SETUP ***
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.9G        1.3G        1.9G        1.0M        702M        2.5G
                                    Swap:            99M          0B         99M
                                             3887 M total memory
                                             1291 M used memory
                                              238 M active memory
                                             1638 M inactive memory
                                             1894 M free memory
                                               79 M buffer memory
                                              622 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    top - 19:54:23 up  3:49,  1 user,  load average: 0.76, 0.51, 0.37
                                    Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  2.9 us,  0.0 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   3887.9 total,   1893.7 free,   1291.5 used,    702.7 buff/cache
                                    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2542.6 avail Mem
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** DMESG CRITICAL ERRORS ***
                                    No critical errors detected
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G   12G   17G  41% /
                                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                    tmpfs          tmpfs     778M  1.1M  777M   1% /run
                                    /dev/mmcblk0p1 vfat      255M   60M  196M  24% /boot
                                    tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                                    [Sat Oct 26 16:05:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:E1:EF:16 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Sat Oct 26 16:05:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Sat Oct 26 16:05:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Sat Oct 26 16:05:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    Show mounted filesystems:
                                    TARGET  SOURCE         FSTYPE OPTIONS
                                    /       /dev/mmcblk0p2 ext4   rw,noatime
                                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                    4.6G    /var/
                                    2.9G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
                                    2.9G    /var/log
                                    856M    /var/cache
                                    Archived and active journals take up 2.8G in the file system.
                                    /opt/iobroker/backups:
                                    82M     /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    886M    /opt/iobroker/iobroker-data/
                                    744M    /opt/iobroker/iobroker-data/files
                                    617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                    12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                    10M     /opt/iobroker/iobroker-data/states.jsonl
                                    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                    USB-Devices by-id:
                                    No Devices found 'by-id'
                                    *** NodeJS-Installation ***
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Installed: 20.18.0-1nodesource1
                                      Candidate: 20.18.0-1nodesource1
                                      Version table:
                                     *** 20.18.0-1nodesource1 600
                                            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                         20.17.0-1nodesource1 600
                                         20.16.0-1nodesource1 600
                                         20.15.1-1nodesource1 600
                                         20.15.0-1nodesource1 600
                                         20.14.0-1nodesource1 600
                                         20.13.1-1nodesource1 600
                                         20.13.0-1nodesource1 600
                                         20.12.2-1nodesource1 600
                                         20.12.1-1nodesource1 600
                                         20.12.0-1nodesource1 600
                                         20.11.1-1nodesource1 600
                                         20.11.0-1nodesource1 600
                                         20.10.0-1nodesource1 600
                                         20.9.0-1nodesource1 600
                                         20.8.1-1nodesource1 600
                                         20.8.0-1nodesource1 600
                                         20.7.0-1nodesource1 600
                                         20.6.1-1nodesource1 600
                                         20.6.0-1nodesource1 600
                                         20.5.1-1nodesource1 600
                                         20.5.0-1nodesource1 600
                                         20.4.0-1nodesource1 600
                                         20.3.1-1nodesource1 600
                                         20.3.0-1nodesource1 600
                                         20.2.0-1nodesource1 600
                                         20.1.0-1nodesource1 600
                                         20.0.0-1nodesource1 600
                                         12.22.12~dfsg-1~deb11u5 500
                                    No problems detected
                                    Errors in npm tree: 0
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    iobroker-pi         iobroker-pi (version: 6.0.11, hostname: iobroker-pi   , alive, uptime: 4054)
                                    Core adapters versions
                                    js-controller:  6.0.11
                                    admin:          7.1.5
                                    javascript:     8.8.3
                                    nodejs modules from github:     0
                                    Adapter State
                                    + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
                                    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                    + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
                                    + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                                    + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
                                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
                                    + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
                                      system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
                                    + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
                                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
                                    + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
                                    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                    + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
                                      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                                    + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
                                      system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
                                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
                                    + instance is alive
                                    ioBroker-Repositories
                                    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                                    Active repo(s): stable
                                    Installed ioBroker-Instances
                                    Used repository: stable
                                    Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                    Adapter    "ems-esp"      : 4.8.0    , installed 4.8.0
                                    Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                                    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                    Controller "js-controller": 6.0.11   , installed 6.0.11
                                    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                    Adapter    "web"          : 6.2.5    , installed 6.2.5
                                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                    Objects and States
                                    Objects:        6233
                                    States:         5240
                                    Hit:2 https://repos.influxdata.com/debian bullseye InRelease
                                    Hit:3 https://packages.grafana.com/oss/deb stable InRelease
                                    Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                                    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        12074      793/influxd
                                    tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       115695     11790/io.hm-rpc.1
                                    tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       116210     11809/io.hm-rpc.2
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14292      833/sshd: /usr/sbin
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       113621     11529/iobroker.js-c
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       113626     11529/iobroker.js-c
                                    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14324      864/dnsmasq
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       117355     11859/io.shelly.0
                                    tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       116245     11826/io.mqtt.0
                                    tcp        0      0 192.168.178.10:18701    0.0.0.0:*               LISTEN      1001       115664     11771/io.hm-rpc.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          12057      833/sshd: /usr/sbin
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      111        16019      1633/grafana
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        16546      793/influxd
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       117499     11995/io.simple-api
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       115812     11548/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       119220     12011/io.web.0
                                    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14323      864/dnsmasq
                                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14320      864/dnsmasq
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11895      616/dhclient
                                    udp        0      0 0.0.0.0:60117           0.0.0.0:*                           108        1632       380/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1630       380/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        1631       380/avahi-daemon: r
                                    udp6       0      0 :::47912                :::*                                108        1633       380/avahi-daemon: r
                                    2024-10-26 19:35:59.872  - info: netatmo-crawler.0 (14397) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                    2024-10-26 19:36:00.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14397 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-10-26 19:38:20.696  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.7
                                    2024-10-26 19:40:20.611  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 10.8
                                    2024-10-26 19:40:55.044  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14653
                                    2024-10-26 19:40:57.906  - info: netatmo-crawler.0 (14653) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                    2024-10-26 19:40:57.974  - info: netatmo-crawler.0 (14653) Getting data for stationid:70:ee:50:33:0f:3e
                                    2024-10-26 19:41:17.205  - info: netatmo-crawler.0 (14653) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                    2024-10-26 19:41:17.737  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14653 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-10-26 19:41:19.284  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
                                    2024-10-26 19:45:50.558  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.2
                                    2024-10-26 19:45:55.020  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 14873
                                    2024-10-26 19:45:57.866  - info: netatmo-crawler.0 (14873) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                    2024-10-26 19:45:57.927  - info: netatmo-crawler.0 (14873) Getting data for stationid:70:ee:50:33:0f:3e
                                    2024-10-26 19:45:58.878  - info: netatmo-crawler.0 (14873) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                    2024-10-26 19:45:59.413  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 14873 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-10-26 19:50:55.023  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 16135
                                    2024-10-26 19:50:58.133  - info: netatmo-crawler.0 (16135) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.0, js-controller: 6.0.11
                                    2024-10-26 19:50:58.197  - info: netatmo-crawler.0 (16135) Getting data for stationid:70:ee:50:33:0f:3e
                                    2024-10-26 19:50:59.665  - info: netatmo-crawler.0 (16135) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                    2024-10-26 19:51:00.207  - info: host.iobroker-pi instance system.adapter.netatmo-crawler.0 having pid 16135 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-10-26 19:51:51.107  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.5
                                    2024-10-26 19:52:35.857  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.7
                                    2024-10-26 19:52:50.596  - info: javascript.0 (11619) script.js.common.Pumpensteuerung: 11.6
                                    2024-10-26 19:54:34.254  - info: javascript.0 (11619) script.js.common.Alarm-Pumpe: 1
                                    • W wibear
                                      Die Langfassung
                                      @wibear
                                      Die läuft vor der Zusammenfassung über deinen Bildschirm.
                                      • W wibear
                                        Hallo zusammen, der vw-connect Adapter sowie seine Instanz waren bis zuletzt noch installiert und haben funktioniert.. Nach einem Backup-Recovery verschwand der Adapter aus der Liste und ich kann ihn nicht finden, auch bei GitHub nicht.
                                        Ist was dazu bekannt?
                                        Danke und Grüße
                                        mcm1957M Offline
                                        mcm1957M Offline
                                        mcm1957
                                        @wibear said in vw-connect Adapter nicht mehr verfügbar:
                                        Danke und Grüße
                                        Der Adapter vw-connect ist nur mehr im LATEST / BETA repository verfügbar:
                                        Der Maintainer hat keine aktuelle Version für das Stable Repository bereitgestellt und auch auf mehrfache Nachfrage nicht bestätigt, dass die (eher veraltete) Version im Stable Repository noch funktionstüchtig ist. Siehe https://github.com/TA2k/ioBroker.vw-connect/issues/316
                                        Es gibt daher von diesem Adapter derzeit nur eine BETA Version im LATEST Repository. Wenn du diese BETA Version installieren willst, kannst du das durch Auswahl des Beta Repositories oder über "von NPM installieren" im Expertenmodus machen. Bite beachte, dass BETA Versionen generell zum Testen gedacht sind und für produktive Systeme nicht empfohlen werden. Es steht dir frei, den Maintainer zu ersuchen eine geeignete Version für STABLE bereitzustellen.
                                        Bezüglich INSTALLATION von Github noch die nachfolgende Information:
                                        Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                                        Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                                        Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                                        Und falls es irgendwie unklar ist:
                                        ioBroker unterstützt folgende Arten von Installation:
                                        • aus dem STABLE Repository
                                          Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                                        • aus dem LATEST Repository
                                          Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                                        • direkt von GITHUB
                                          Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                                        • direkt von npm
                                          Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                                        Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
                                        Support Repositoryverwaltung.
                                        LESEN - gute Forenbeitrage
                                        • mcm1957M mcm1957
                                          Danke und Grüße
                                          • direkt von GITHUB
                                          • direkt von npm
                                          W Offline
                                          W Offline
                                          wibear
                                          @mcm1957
                                          Guten Morgen und danke für den Hinweis. Ich habe mich einfach gewundert, warum dieser Adapter plötzlich verschwunden ist. Schade, dass er nicht weiter entwickelt wird.
