  4. EMS-ESP mit ipinside funktioniert nicht mehr?
17 Beiträge 6 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • F felixrhoese
    Danke für den Hinweis!
    Ich habe die Neuinstallation durchgeführt. Leider ohne Erfolg.
    Hier die Diag:
                            v.2024-05-22
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.47+rpt-rpi-v8
        Architecture: arm64
    Kernel:                 aarch64
    Userland:               64 bit
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v20.17.0
    /usr/bin/node           v20.17.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    Recommended versions are nodejs 20.17.0 and npm 10.8.2
    MEMORY:
    Mem:            951M        506M        101M         12K        411M        445M
    Swap:           209M        124M         85M
    Total:          1.2G        630M        186M
    Active iob-Instances:   3
    Upgrade policy: none
    ioBroker Core:          js-controller           6.0.11
                            admin                   7.0.23
    Objects type: jsonl
    States  type: jsonl
    Objects:                203
    States:                 109
    Size of iob-Database:
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    1.9M    /opt/iobroker/iobroker-data/states.jsonl
    Im Log sieht es so aus:
    2024-09-15 17:45:20.885 - info: host.raspberrypi instance system.adapter.ems-esp.0 in version "4.8.0" started with pid 13020
    2024-09-15 17:45:26.224 - info: ems-esp.0 (13020) starting. Version 4.8.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v20.17.0, js-controller: 6.0.11
    2024-09-15 17:45:26.498 - info: ems-esp.0 (13020) KM200 no database instance selected for recordings
    2024-09-15 17:45:26.843 - info: discovery.0 (13014) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
    2024-09-15 17:45:27.333 - info: javascript.0 (13007) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
    2024-09-15 17:45:27.866 - info: javascript.0 (13007) requesting all states
    2024-09-15 17:45:27.869 - info: javascript.0 (13007) requesting all objects
    2024-09-15 17:45:28.840 - warn: javascript.0 (13007) Configured latitude is not a number - check (instance/system) configuration
    2024-09-15 17:45:28.843 - warn: javascript.0 (13007) Configured longitude is not a number - check (instance/system) configuration
    2024-09-15 17:45:28.845 - info: javascript.0 (13007) received all objects
    2024-09-15 17:45:28.858 - info: javascript.0 (13007) received all states
    2024-09-15 17:45:47.131 - error: ems-esp.0 (13020) error reading KM200 gateway (wrong ip address) - stop KM200 read: http://192.168.178.84
    Hat jemand noch eine Idee?
    Vielen Dank und viele Grüße Felix
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @felixrhoese sagte in EMS-ESP mit ipinside funktioniert nicht mehr?:
    Langfassung von iobdiag zeigen und ein Tip: mit einem RPI3 mit 1GB Ram kommst Du nicht weit !
    Lehrling seit 1975 !!!
    • F felixrhoese
      Hier die Diag:
                              v.2024-05-22
             Icon name: computer
          Architecture: arm64
      Kernel:                 aarch64
      Userland:               64 bit
      User-ID:                1000
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
      Swap:           209M        124M         85M
                              admin                   7.0.23
      Objects type: jsonl
      States  type: jsonl
      Objects:                203
      States:                 109
      (wrong ip address)
      Welche IP Addresse ist denn die richtige?
      F 2 Antworten Letzte Antwort
        (wrong ip address)
        felixrhoese
        Die IP Adresse ist die 192.168.178.84.
        Ich habe zwischenzeitlich auch Testweise eine Instanz vom Home Assistanz hochgezogen. Dort gibt des die Bosch Thermostat Integration, die nutzt direkt die Cloud. Da geht alles problemlos. Nur ist der Home Assistant nicht so komfortabel wie der IO Broker. Ich fürchte, die alte Integration über das KM200 Modul direkt, ohne die Nutzung der Cloud geht einfach nicht mehr, wegen FW Update seitens Buderus.
        Probiere aber gerne weiter. Ansonsten werde ich mir eine Instanz vom Home Assistant auf dem kleinen Pi laufen lassen und mir für den IO Broker einen neuen holen. Danke für eure Mühen. VG Felix
          (wrong ip address)
          felixrhoese
          Problem gelöst. Offenbar wurde das Format der Passworteingabe geändert. Es dürfen nun keine Bindestriche mehr genutzt werden. In der Adapter Ansicht ist auch noch das Ausrufezeichen zu sehen. Trotzdem ist in der Objektansicht alles aktuell. Sehr seltsam. Danke an alle, die mitgeholfen haben! VG Felix
          • L Offline
            luxusl
            @felixrhoese
            Welche Änderung musstest du im iobroker vornehmen, dass der Adapter wieder funktioniert?
            • L luxusl
              @felixrhoese
              @luxusl sagte in EMS-ESP mit ipinside funktioniert nicht mehr?:
              @felixrhoese
              • L Offline
                luxusl
                @Homoran
                Das habe ich gelesen, nur welche Konsequenz hat dies schlussendlich? einfach die Bindestriche löschen geht nicht...
                • L luxusl
                  @Homoran
                  Natürlich nicht!
                  Du musst das Passwort ändern
                  L 1 Antwort Letzte Antwort
                    Natürlich nicht!
                    luxusl
                    @homoran ich habe eine Buderus, da wüsste ich nicht wie ich das Gateway-Passwort im Gerät ändern kann. Das Passwort ist mit einem Aufkleber sogar außen aufgebracht? Mit der App Buderus MyDevice finde ich keine Änderungsmöglichkeit.
                    • L luxusl
                      @luxusl dann kann ich dir nicht mehr helfen.
                      Vielleicht weiss @felixrhoese wie
