  4. EMS-ESP mit ipinside funktioniert nicht mehr?
17 Beiträge 6 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • F felixrhoese
    @mcm1957
    Danke für den Hinweis!
    Adapter: EMS-ESP 4.8.0
    Admin: 7.0.23
    Js-controller: 8.3.1
    Node: 18.17.1
    O/S: Linux auf Raspberry pi3
    Log des Adapters mit Level DEBUG:
    2024-09-14 09:31:51.979 - info: host.iobroker-pi "system.adapter.ems-esp.0" enabled
    2024-09-14 09:31:52.135 - info: host.iobroker-pi instance system.adapter.ems-esp.0 started with pid 19751
    2024-09-14 09:31:56.436 - info: ems-esp.0 (19751) starting. Version 4.8.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v18.17.1, js-controller: 5.0.19
    2024-09-14 09:31:56.939 - info: ems-esp.0 (19751) InfluxDB 1.x - Retention: 730 days --- Adapterversion: 4.0.2
    2024-09-14 09:32:00.037 - info: javascript.0 (13044) script.js.common.10_Heizung.Temperatur_Mean24h: 0
    2024-09-14 09:32:06.462 - info: host.iobroker-pi stopInstance system.adapter.ems-esp.0 (force=false, process=true)
    2024-09-14 09:32:06.473 - info: ems-esp.0 (19751) Got terminate signal TERMINATE_YOURSELF
    2024-09-14 09:32:06.478 - info: ems-esp.0 (19751) terminating
    2024-09-14 09:32:06.481 - info: ems-esp.0 (19751) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-09-14 09:32:06.517 - info: host.iobroker-pi stopInstance system.adapter.ems-esp.0 send kill signal
    2024-09-14 09:32:07.120 - info: host.iobroker-pi instance system.adapter.ems-esp.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-09-14 09:32:10.138 - info: host.iobroker-pi instance system.adapter.ems-esp.0 started with pid 19766
    2024-09-14 09:32:13.802 - info: ems-esp.0 (19766) starting. Version 4.8.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v18.17.1, js-controller: 5.0.19
    2024-09-14 09:32:14.187 - info: ems-esp.0 (19766) InfluxDB 1.x - Retention: 730 days --- Adapterversion: 4.0.2
    2024-09-14 09:32:20.329 - info: javascript.0 (13044) script.js.common.10_Heizung.Temperature_Mean3h: NaN
    2024-09-14 09:32:34.908 - error: ems-esp.0 (19766) error reading KM200 gateway (wrong ip address) - stop KM200 read: http://TK-850-JH3E-NET
    Hinweis: Die IP Adresse bzw. der Hostname sind definitiv korrekt. In der MyBuderus App kann ich die Live Daten auch alle sehen.
    Output von iob diag IN DER LANGFASSUNG
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: iobroker-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7+
          Architecture: arm
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     09:43:31 up 1 day, 13:28,  1 user,  load average: 1.67, 0.84, 0.52
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-09-14 09:43:31 CEST
               Universal time: Sat 2024-09-14 07:43:31 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:           972M        729M         52M         36M        190M        187M
    Swap:           99M         99M        0.0K
    Total:         1.1G        829M         52M
    Active iob-Instances:   11
              972 M total memory
              729 M used memory
              326 M active memory
              537 M inactive memory
               52 M free memory
               28 M buffer memory
              162 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    top - 09:43:31 up 1 day, 13:28,  1 user,  load average: 1.67, 0.84, 0.52
    Tasks: 132 total,   1 running, 131 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    972.8 total,     51.9 free,    729.4 used,    191.4 buff/cache
    MiB Swap:    100.0 total,      0.2 free,     99.8 used.    187.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       57G  5.7G   49G  11% /
    devtmpfs       devtmpfs  454M     0  454M   0% /dev
    tmpfs          tmpfs     487M     0  487M   0% /dev/shm
    tmpfs          tmpfs     487M   50M  438M  11% /run
    tmpfs          tmpfs     487M     0  487M   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      247M   49M  198M  20% /boot
    tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
    [Thu Sep 12 20:14:39 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=d677b88f-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Sep 12 20:14:42 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Thu Sep 12 20:14:42 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Thu Sep 12 20:14:44 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Thu Sep 12 20:14:44 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Sep 12 20:14:44 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Sep 12 20:14:47 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Fri Sep 13 20:17:02 2024] [<802b0ee8>] (filemap_fault) from [<8042d260>] (ext4_filemap_fault+0x38/0x4c)
    [Fri Sep 13 20:17:02 2024] [<8042d228>] (ext4_filemap_fault) from [<802e8900>] (__do_fault+0x48/0x14c)
    Show mounted filesystems:
    TARGET                                SOURCE         FSTYPE     OPTIONS
    /                                     /dev/mmcblk0p2 ext4       rw,noatime
    |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=464768k,nr_inodes=116192,mode=755
    | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
    | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
    |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
    | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
    | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
    | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
    | | |-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
    | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
    | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
    | | `-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
    | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
    | `-/sys/kernel/config                configfs       configfs   rw,relatime
    |-/proc                               proc           proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=33,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
    | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
    | `-/run/user/1000                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=99608k,mode=700,uid=1000,gid=1000
    `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.7G    /var/
    834M    /var/lib
    739M    /var/lib/influxdb
    703M    /var/lib/influxdb/data
    656M    /var/lib/influxdb/data/iobroker/autogen
    Archived and active journals take up 48.6M in the file system.
    /opt/iobroker/backups:
    31M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    272M    /opt/iobroker/iobroker-data/
    206M    /opt/iobroker/iobroker-data/files
    138M    /opt/iobroker/iobroker-data/files/javascript.admin
    118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    8.0M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/61.54b23816.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    nodejs:                 N/A
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    admin:          7.0.23
    javascript:     8.3.1
    nodejs modules from github:     1
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled, compact disabled
    + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled, compact disabled
    + system.adapter.history.0                : history               : iobroker-pi                              -  enabled, compact disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, compact disabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled, compact disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iobroker-pi                              -  enabled, compact disabled, port: 1885, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker-pi                              -  enabled, compact disabled
    + system.adapter.telegram.0               : telegram              : iobroker-pi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : iobroker-pi                              - disabled, compact disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Ich sehe selbst gerade, dass es wohl auch ein Problem mit dem NodeJS System gibt. Ich werde versuchen das zu fixen, auch wenn ich keine Ahnung habe.
    Danke für jede Hilfe!
    Felix
    @felixrhoese sagte in EMS-ESP mit ipinside funktioniert nicht mehr?:
    (buster)
    Muss komplett von Grund auf NEUINSTALLIERT werden.
    Diesmal dann in der 64Bit-Lite-Version.
    Und
    F 1 Antwort Letzte Antwort
      (buster)
      Und
      felixrhoese
      Ich habe die Neuinstallation durchgeführt. Leider ohne Erfolg.
      Hier die Diag:
                              v.2024-05-22
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.47+rpt-rpi-v8
          Architecture: arm64
      Kernel:                 aarch64
      Userland:               64 bit
      User-ID:                1000
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      Recommended versions are nodejs 20.17.0 and npm 10.8.2
      MEMORY:
      Mem:            951M        506M        101M         12K        411M        445M
      Swap:           209M        124M         85M
      Total:          1.2G        630M        186M
      Active iob-Instances:   3
      Upgrade policy: none
      ioBroker Core:          js-controller           6.0.11
                              admin                   7.0.23
      Objects type: jsonl
      States  type: jsonl
      Objects:                203
      States:                 109
      Size of iob-Database:
      20M     /opt/iobroker/iobroker-data/objects.jsonl
      1.9M    /opt/iobroker/iobroker-data/states.jsonl
      Im Log sieht es so aus:
      2024-09-15 17:45:20.885 - info: host.raspberrypi instance system.adapter.ems-esp.0 in version "4.8.0" started with pid 13020
      2024-09-15 17:45:26.224 - info: ems-esp.0 (13020) starting. Version 4.8.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v20.17.0, js-controller: 6.0.11
      2024-09-15 17:45:26.498 - info: ems-esp.0 (13020) KM200 no database instance selected for recordings
      2024-09-15 17:45:26.843 - info: discovery.0 (13014) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
      2024-09-15 17:45:27.333 - info: javascript.0 (13007) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
      2024-09-15 17:45:27.866 - info: javascript.0 (13007) requesting all states
      2024-09-15 17:45:27.869 - info: javascript.0 (13007) requesting all objects
      2024-09-15 17:45:28.840 - warn: javascript.0 (13007) Configured latitude is not a number - check (instance/system) configuration
      2024-09-15 17:45:28.843 - warn: javascript.0 (13007) Configured longitude is not a number - check (instance/system) configuration
      2024-09-15 17:45:28.845 - info: javascript.0 (13007) received all objects
      2024-09-15 17:45:28.858 - info: javascript.0 (13007) received all states
      2024-09-15 17:45:47.131 - error: ems-esp.0 (13020) error reading KM200 gateway (wrong ip address) - stop KM200 read: http://192.168.178.84
      Hat jemand noch eine Idee?
      Vielen Dank und viele Grüße Felix
      DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
      • F felixrhoese
        Hier die Diag:
                                v.2024-05-22
               Icon name: computer
            Architecture: arm64
        Kernel:                 aarch64
        Userland:               64 bit
        User-ID:                1000
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        MEMORY:
        Swap:           209M        124M         85M
                                admin                   7.0.23
        Objects type: jsonl
        States  type: jsonl
        Objects:                203
        States:                 109
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        Langfassung von iobdiag zeigen und ein Tip: mit einem RPI3 mit 1GB Ram kommst Du nicht weit !
        Lehrling seit 1975 !!!
        • F felixrhoese
          Hier die Diag:
                                  v.2024-05-22
                 Icon name: computer
              Architecture: arm64
          Kernel:                 aarch64
          Userland:               64 bit
          User-ID:                1000
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Swap:           209M        124M         85M
                                  admin                   7.0.23
          Objects type: jsonl
          States  type: jsonl
          Objects:                203
          States:                 109
          (wrong ip address)
          Welche IP Addresse ist denn die richtige?
          F 2 Antworten Letzte Antwort
            (wrong ip address)
            felixrhoese
            Die IP Adresse ist die 192.168.178.84.
            Ich habe zwischenzeitlich auch Testweise eine Instanz vom Home Assistanz hochgezogen. Dort gibt des die Bosch Thermostat Integration, die nutzt direkt die Cloud. Da geht alles problemlos. Nur ist der Home Assistant nicht so komfortabel wie der IO Broker. Ich fürchte, die alte Integration über das KM200 Modul direkt, ohne die Nutzung der Cloud geht einfach nicht mehr, wegen FW Update seitens Buderus.
            Probiere aber gerne weiter. Ansonsten werde ich mir eine Instanz vom Home Assistant auf dem kleinen Pi laufen lassen und mir für den IO Broker einen neuen holen. Danke für eure Mühen. VG Felix
              (wrong ip address)
              felixrhoese
              Problem gelöst. Offenbar wurde das Format der Passworteingabe geändert. Es dürfen nun keine Bindestriche mehr genutzt werden. In der Adapter Ansicht ist auch noch das Ausrufezeichen zu sehen. Trotzdem ist in der Objektansicht alles aktuell. Sehr seltsam. Danke an alle, die mitgeholfen haben! VG Felix
              • L Offline
                luxusl
                @felixrhoese
                Welche Änderung musstest du im iobroker vornehmen, dass der Adapter wieder funktioniert?
                • L luxusl
                  @felixrhoese
                  @luxusl sagte in EMS-ESP mit ipinside funktioniert nicht mehr?:
                  @felixrhoese
                  • L Offline
                    luxusl
                    @Homoran
                    Das habe ich gelesen, nur welche Konsequenz hat dies schlussendlich? einfach die Bindestriche löschen geht nicht...
                    • L luxusl
                      @Homoran
                      Natürlich nicht!
                      Du musst das Passwort ändern
                      L 1 Antwort Letzte Antwort
                        Natürlich nicht!
                        luxusl
                        @homoran ich habe eine Buderus, da wüsste ich nicht wie ich das Gateway-Passwort im Gerät ändern kann. Das Passwort ist mit einem Aufkleber sogar außen aufgebracht? Mit der App Buderus MyDevice finde ich keine Änderungsmöglichkeit.
                        • L luxusl
                          @luxusl dann kann ich dir nicht mehr helfen.
                          Vielleicht weiss @felixrhoese wie
