  3. Einsteigerfragen
  4. Installation
  5. Passwort Iobroker über Mac-Terminal anders?
133 Beiträge 11 Kommentatoren 22.4k Aufrufe 9 Beobachtet
  • U Offline
    U Offline
    uliauer44
    #90
    @thomas-braun said in Passwort Iobroker über Mac-Terminal anders?:
    iob diag
    Here it comes....
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.61-v8+
          Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     14:55:01 up 1 day, 22:27,  3 users,  load average: 0.58, 0.62, 0.34
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release '' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2024-10-25 14:55:01 CEST
               Universal time: Fri 2024-10-25 12:55:01 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin gpio i2c spi
    iobroker
    HOME=/home/iobroker
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            1.8G        1.4G        236M         34M        216M        349M
    Swap:            99M         99M        0.0K
    Total:          1.9G        1.5G        236M
    Active iob-Instances: 	20
             1849 M total memory
             1396 M used memory
              168 M active memory
             1283 M inactive memory
              236 M free memory
               27 M buffer memory
              189 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    top - 14:55:02 up 1 day, 22:27,  3 users,  load average: 0.58, 0.62, 0.34
    Tasks: 209 total,   1 running, 208 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 13.9 us,  6.9 sy,  0.0 ni, 79.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   1849.2 total,    235.6 free,   1395.8 used,    217.8 buff/cache
    MiB Swap:    100.0 total,      0.0 free,    100.0 used.    348.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    [sudo] password for iobroker:
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       15G  7.1G  6.5G  53% /
    devtmpfs       devtmpfs  763M     0  763M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  1.2M  369M   1% /run
    /dev/mmcblk0p1 vfat      255M   34M  222M  13% /boot
    tmpfs          tmpfs     185M   20K  185M   1% /run/user/1000
    [Wed Oct 23 16:27:32 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:26:FE:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bbc14122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Oct 23 16:27:33 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Wed Oct 23 16:27:33 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Wed Oct 23 16:27:33 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Wed Oct 23 16:27:33 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Wed Oct 23 16:27:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Oct 23 16:27:35 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.9G	/var/
    1.5G	/var/log/journal/60dd197ce1dd470bacf92c92630f1c5a
    1.5G	/var/log
    184M	/var/lib
    Archived and active journals take up 1.4G in the file system.
    /opt/iobroker/backups:
    279M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    378M	/opt/iobroker/iobroker-data/
    298M	/opt/iobroker/iobroker-data/files
    99M	/opt/iobroker/iobroker-data/files/vis-2-beta
    52M	/opt/iobroker/iobroker-data/files/javascript.admin
    47M	/opt/iobroker/iobroker-data/backup-objects
    27M	/opt/iobroker/iobroker-data/objects.jsonl
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    9.7M	/opt/iobroker/iobroker-data/files/vis-2-beta/material-icons/knx-uf.json
    8.5M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
    8.0M	/opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    nodejs: 		N/A
    /usr/bin/node 		v16.17.0
    /usr/bin/npm 		8.15.0
    /usr/bin/npx 		8.15.0
    /usr/bin/corepack 	0.12.1
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.17.0-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
     *** 16.17.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u5 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 4.0.23, hostname: iobroker      , alive, uptime: 165159)
    Core adapters versions
    js-controller: 	4.0.23
    admin: 		6.13.16
    javascript: 	7.1.4
    nodejs modules from github: 	2
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
      system.adapter.habpanel.0               : habpanel              : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 - disabled, port: 0
      system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
    + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 - disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 6.13.16 [Updatable]
    Adapter    "backitup"     : 3.0.25   , installed 2.11.0 [Updatable]
    Adapter    "denon"        : 1.15.12  , installed 1.15.5 [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.9  [Updatable]
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hm-rega"      : 5.1.0    , installed 4.0.0  [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.17.0 [Updatable]
    Adapter    "hue"          : 3.12.0   , installed 3.10.1 [Updatable]
    Adapter    "ical"         : 1.15.0   , installed 1.13.3 [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
    Controller "js-controller": 6.0.11   , installed 4.0.23 [Updatable]
    Adapter    "openweathermap": 1.1.2   , installed 1.0.4  [Updatable]
    Adapter    "pushover"     : 4.1.0    , installed 3.0.6  [Updatable]
    Adapter    "samsung"      : 0.6.1    , installed 0.5.11 [Updatable]
    Adapter    "socketio"     : 6.7.1    , installed 6.5.5  [Updatable]
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 0.3.11 [Updatable]
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.0.3 [Updatable]
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.3.25 [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.3   , installed 1.8.24 [Updatable]
    Objects and States
    Objects: 	6827
    States: 	5615
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 325
    *** Listening Ports ***
    tcp        0      0 192.168.178.22:9292     0.0.0.0:*               LISTEN      1000       45177      6369/io.hm-rpc.1
    tcp        0      0 192.168.178.22:2010     0.0.0.0:*               LISTEN      1000       45202      6386/io.hm-rpc.2
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       43296      6175/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       42823      6175/iobroker.js-co
    tcp        0      0 192.168.178.22:2001     0.0.0.0:*               LISTEN      1000       41943      6322/io.hm-rpc.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          866244     82966/cupsd
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       46259      6524/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11603      571/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       40887      6193/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       46229      6479/io.web.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       45400      6535/io.terminal.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          866243     82966/cupsd
    tcp6       0      0 :::34957                :::*                    LISTEN      1000       43687      6494/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11605      571/sshd: /usr/sbin
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          868513     82968/cups-browsed
    udp        0      0 0.0.0.0:52180           0.0.0.0:*                           108        14204      340/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13063      468/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14202      340/avahi-daemon: r
    udp6       0      0 :::44790                :::*                                108        14205      340/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14203      340/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13290      468/dhcpcd
    2024-10-25 14:55:48.028  - error: hue.0 (6272) Could not poll all: unauthorized user
    2024-10-25 14:55:48.559  - info: hue.0 (6272) Push connection error: Forbidden
    2024-10-25 14:55:48.710  - error: hue.0 (6272) unauthorized user
    2024-10-25 14:55:48.711  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
    2024-10-25 14:55:53.984  - info: hue.0 (6272) Push connection error: Forbidden
    2024-10-25 14:55:54.197  - error: hue.0 (6272) unauthorized user
    2024-10-25 14:55:54.198  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
    2024-10-25 14:55:58.048  - error: hue.0 (6272) Could not poll all: unauthorized user
    2024-10-25 14:55:59.487  - info: hue.0 (6272) Push connection error: Forbidden
    2024-10-25 14:55:59.647  - error: hue.0 (6272) unauthorized user
    2024-10-25 14:55:59.647  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
    2024-10-25 14:56:04.949  - info: hue.0 (6272) Push connection error: Forbidden
    2024-10-25 14:56:05.098  - error: hue.0 (6272) unauthorized user
    2024-10-25 14:56:05.098  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
    2024-10-25 14:56:08.066  - error: hue.0 (6272) Could not poll all: unauthorized user
    2024-10-25 14:56:10.395  - info: hue.0 (6272) Push connection error: Forbidden
    2024-10-25 14:56:10.552  - error: hue.0 (6272) unauthorized user
    2024-10-25 14:56:10.553  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
    2024-10-25 14:56:15.848  - info: hue.0 (6272) Push connection error: Forbidden
    2024-10-25 14:56:15.996  - error: hue.0 (6272) unauthorized user
    2024-10-25 14:56:15.996  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
    2024-10-25 14:56:18.081  - error: hue.0 (6272) Could not poll all: unauthorized user
    2024-10-25 14:56:21.282  - info: hue.0 (6272) Push connection error: Forbidden
    2024-10-25 14:56:21.441  - error: hue.0 (6272) unauthorized user
    2024-10-25 14:56:21.448  - warn: hue.0 (6272) Could not get configuration from HUE bridge (192.168.178.111:443)
    iob diag has finished.
    Press any key for a summary
    Hier noch die anschließende Summary:
    Copy text starting here:
    			v.2024-10-19
             Icon name: computer
          Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		64 bit
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    Boot Target: 		graphical.target
    Pending OS-Updates: 	325
    Pending iob updates: 	22
    Nodejs-Installation:
    nodejs: 		N/A
    /usr/bin/npm 		8.15.0
    /usr/bin/npx 		8.15.0
    Recommended versions are nodejs 18.20.4 and npm 10.7.0
    Wrong installation path detected. This needs to be fixed.
    Please execute
    iob nodejs-update
    to fix these errors.
    MEMORY:
    Mem:            1.8G        1.4G        135M         35M        300M        332M
    Swap:            99M         99M          0B
    Total:          1.9G        1.5G        135M
    ioBroker Core: 		js-controller 		4.0.23
    			admin 			6.13.16
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		6827
    States: 		5615
    Size of iob-Database:
    8.1M	/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    iobroker@iobroker:~ $
    @Meister-Mopper : Sehr hilfreicher Kommentar....weil ich auch andere Dinge im Leben zu tun habe....
    • Thomas BraunT Online
      #91
      @uliauer44
      Bring das Ding auf Stand...
      iob nodejs-update
      iob stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      Und leg dir einen User an.
      U 1 Antwort Letzte Antwort
        @uliauer44
        iob nodejs-update
        iob stop
        sudo apt update
        sudo reboot
        U Offline
        U Offline
        uliauer44
        #92
        Ja, den Hinweis mit dem NodeJS habe ich auch gesehen - Update läuft gerade...
        • U uliauer44
          U Offline
          U Offline
          uliauer44
          schrieb am zuletzt editiert von uliauer44
          #93
          @uliauer44
          So. NodeJS Update hat geklappt - auch die anderen Update/Upgrade Befehle habe ich ausgeführt.
          Danke schonmal, Thomas, für Deine Hilfe!
          Leider immer noch kein aktualisierter JS-Controller im Host sichtbar.
          Wie meinst Du das genau mit dem neuen User? Und zum Verständnis: Was ist das Problem mit dem bisherigen?
          (Und ja, ich sollte ja nach Anleitung damals einen neuen User anlegen, der "pi" offensichtlich ersetzt hat...)
          Soll ich das mit dem gefixten NodeJS einfach nochmal probieren mit der JS-Controller Update-Routine?
          Oder ist die eh identisch mit den Upgrade-Zeilen, die Du mir geschrieben hast?
          • U uliauer44
            @uliauer44
            #94
            @uliauer44
            Stand nun?
            Aktuellen Lauf von
            iob diag
            zeigen. Zusammenfassung reicht.
              @uliauer44
              Stand nun?
              Aktuellen Lauf von
              iob diag
              U Offline
              U Offline
              uliauer44
              #95
              @thomas-braun ```
              			v.2024-10-19
                       Icon name: computer
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Kernel: 		aarch64
              Userland: 		64 bit
              User-ID: 		1000
              Pending OS-Updates: 	0
              /usr/bin/nodejs 	v20.18.0
              /usr/bin/node 		v20.18.0
              /usr/bin/npm 		10.8.2
              /usr/bin/npx 		10.8.2
              /usr/bin/corepack 	0.29.3
              nodeJS installation is correct
              MEMORY:
              Mem:            1.8G        1.1G        127M         37M        577M        600M
              Swap:            99M        5.0M         94M
              Total:          1.9G        1.1G        222M
              			admin 			6.13.16
              Objects type: jsonl
              States  type: jsonl
              Objects: 		6827
              States: 		5617
              1.9M	/opt/iobroker/iobroker-data/states.jsonl
              Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
              • U uliauer44
                @thomas-braun ```
                			v.2024-10-19
                         Icon name: computer
                      Architecture: arm64
                Kernel: 		aarch64
                Userland: 		64 bit
                User-ID: 		1000
                /usr/bin/npm 		10.8.2
                /usr/bin/npx 		10.8.2
                MEMORY:
                Swap:            99M        5.0M         94M
                			admin 			6.13.16
                Objects type: jsonl
                States  type: jsonl
                Objects: 		6827
                States: 		5617
                #96
                @uliauer44
                iob update
                iob upgrade all -y
                iob stop
                iob upgrade self
                iob start
                  @uliauer44
                  iob update
                  iob upgrade all -y
                  iob stop
                  iob upgrade self
                  iob start
                  U Offline
                  U Offline
                  uliauer44
                  #97
                  SUPER. Herzlichen Dank, Thomas - scheint soweit nun alles geklappt zu haben.
                  Bei der ersten Runde von "iob upgrade all -y" hatte er noch einige Fehlermeldungen bezüglich der zu alten Version von JS-controller,
                  nach "upgrade self" hat er diesen aber nun auch brav auf 6.0.11 aktualisiert....!
                  Sollte ich nun trotzdem noch eine neuen User anlegen? Oder ist das jetzt obsolet?
                  Hier nochmal die aktuellste Summary von "iob diag":
                  			v.2024-10-19
                           Icon name: computer
                        Architecture: arm64
                  Kernel: 		aarch64
                  Userland: 		64 bit
                  User-ID: 		1000
                  Pending iob updates: 	0
                  /usr/bin/npm 		10.8.2
                  /usr/bin/npx 		10.8.2
                  Recommended versions are nodejs 20.18.0 and npm 10.8.2
                  MEMORY:
                  Mem:            1.8G        1.2G         97M         38M        507M        498M
                  Swap:            99M         99M        0.0K
                  Total:          1.9G        1.3G         97M
                  Upgrade policy: none
                  ioBroker Core: 		js-controller 		6.0.11
                  			admin 			7.1.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		6881
                  States: 		5625
                  29M	/opt/iobroker/iobroker-data/objects.jsonl
                  4.5M	/opt/iobroker/iobroker-data/states.jsonl
                  Was ja immer noch geblieben ist, ist die bullseye/bookworm Meldung.....Was mach ich damit?
                  • U uliauer44
                    			v.2024-10-19
                             Icon name: computer
                          Architecture: arm64
                    Kernel: 		aarch64
                    Userland: 		64 bit
                    User-ID: 		1000
                    /usr/bin/npm 		10.8.2
                    /usr/bin/npx 		10.8.2
                    MEMORY:
                    Swap:            99M         99M        0.0K
                    			admin 			7.1.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		6881
                    States: 		5625
                    #98
                    @uliauer44 sagte in Passwort Iobroker über Mac-Terminal anders?:
                    Was mach ich damit?
                    @meister-mopper sagte in Passwort Iobroker über Mac-Terminal anders?:
                    Mach den ganzen Bums neu
                    Das kann man nicht updaten.
                    Bookworm ist intern deutlich verändert worden
                    Da geht nur eine Neuinstallation mit anschließendem Einspielen des Backups
                    • U uliauer44
                      			v.2024-10-19
                               Icon name: computer
                            Architecture: arm64
                      Kernel: 		aarch64
                      Userland: 		64 bit
                      User-ID: 		1000
                      /usr/bin/npm 		10.8.2
                      /usr/bin/npx 		10.8.2
                      MEMORY:
                      Swap:            99M         99M        0.0K
                      			admin 			7.1.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		6881
                      States: 		5625
                      #99
                      Nein, das ist nicht obsolet.
                      Denn im Zuge von
                      wirst du von dem jetzigen Stand ein Backup anlegen und dann damit in ein frisch, von Grund auf neuinstalliertes 'Bookworm' umziehen. Dann auch gleich mit individuellem username.
                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                        Denn im Zuge von
                        U Offline
                        U Offline
                        uliauer44
                        #100
                        Okay.
                        Hab jetzt beim Backup machen ein paar kleine Fehler bekommen...
                        16:13:10.980
                        WARN
                        jarvis
                        settings "theme" not found
                        16:13:13.822
                        WARN
                        nodered
                        no node-red database found!!
                        Ist da was Wichtiges dabei, das ich vor dem Wechsel auf bookworm noch fixen sollte?
                        • U uliauer44
                          Okay.
                          16:13:10.980
                          WARN
                          jarvis
                          16:13:13.822
                          WARN
                          nodered
                          #101
                          Kann ich dir nicht sagen, verwende weder node-red noch jarvis.
                            U Offline
                            U Offline
                            uliauer44
                            #102
                            Okay, dann ist es ja jedenfalls nix existenziell erforderliches ;-)
                            Sorry für die Noob-Frage: Wie lege ich jetzt den neuen User an?
                            Den Pi-Imager habe ich schon auf dem Mac am Start...
                            Ah....sehe jetzt gerade erst in Deiner Anleitung, dass dort der user eingerichtet wird....also geh ich das mal komplett durch....
                            • U uliauer44
                              #103
                              Direkt im Imager macht man das. Nenn den uli oder sonst wie, aber NICHT iobroker.
                                U Offline
                                U Offline
                                uliauer44
                                #104
                                Okay. Soweit in der Spur (Das "aktualisieren" nach dem Install läuft jetzt schon sehr lange, aber das ist vermutlich in Ordnung, nur langsam)
                                Ich habe aber noch ein anderes Problem:
                                Ich kann mich aktuell (das habe ich VOR dem gerade laufenden Aktualisieren festgestellt) nur über die WLAN IP-Adresse anmelden.
                                Über die LAN-Verbindung bekomme ich folgende Meldung:
                                ssh uli@192.168.178.22
                                @    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
                                IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
                                Someone could be eavesdropping on you right now (man-in-the-middle attack)!
                                It is also possible that a host key has just been changed.
                                The fingerprint for the ED25519 key sent by the remote host is
                                SHA256:/5CJrlsdDnAGxI3m86IinQQWAnl8aPr/ZuQYdpGCx7k.
                                Please contact your system administrator.
                                Add correct host key in /Users/ulimaxbook/.ssh/known_hosts to get rid of this message.
                                Offending ED25519 key in /Users/ulimaxbook/.ssh/known_hosts:5
                                Host key for 192.168.178.22 has changed and you have requested strict checking.
                                Host key verification failed.
                                Hinweis: Beide IP-Adressen sind bei mir in der Fritzbox fest zugewiesen (22 für LAN, 180 für WLAN)
                                • U uliauer44
                                  #105
                                  Die genannte Datei muss angepasst werden. Wenn du nur den Eintrag löschst wird bei erneuter Verbingsaufnahme der Schlüssel neugeschrieben.
                                  U 2 Antworten Letzte Antwort
                                    U Offline
                                    U Offline
                                    uliauer44
                                    #106
                                    Wie mache ich das?
                                    • U uliauer44
                                      Wie mache ich das?
                                      #107
                                      Wie mache ich das?
                                      Mit einem Editor?
                                        Wie mache ich das?
                                        Mit einem Editor?
                                        U Offline
                                        U Offline
                                        uliauer44
                                        #108
                                        Ja, aber was? Die Datei besteht hieraus....
                                        iobroker.local ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIB6C+A2ymodV55rvTFDxK3JjffFTd3EDdpu8NN6VakAo
                                        iobroker.local ssh-rsa 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
                                        iobroker.local ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBDTtZUIPIaqODccZayvOy0e4KmigwO9OTDZgyZhNlywVbT9SZI8Gt7rHgbvwk6mJkcb6Ipw2Wy98G4G6vEawUV0=
                                        sftp.hidrive.strato.com ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIKj++KINkipb3Uh30rB+BpR0TArchTWDoetSEKpymo9o
                                        192.168.178.22 ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIB6C+A2ymodV55rvTFDxK3JjffFTd3EDdpu8NN6VakAo
                                        192.168.178.222 ssh-rsa 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
                                        192.168.178.180 ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIHqO6j6Mlm1GWCwtVXM4BcpetfY/i0JK0d3Ot9fkVI+8
                                        192.168.178.180 ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABgQCjBGIWZayXiB6ow4INofNriYhxMIoso8ap5Xq+8vW4eF0flR7HdcoKD/1kLZV2o3/TAejemcMiCwR1gHrN8aHBeBA3OWHqzc6H/nZMolAlUjJuSk6ql+XtUQ7+1d5IkFym9/aWUPLOugkD2zNj98Ld8I5s7MzgbdY5idMUp3Mi6askoBkhgvtIv7ziruSnvVx1h/AQE2t/uCeQ/7tGehA+KQChhbuAeEEYKmyIb8svehPgdxapYXMWGrUXkUJ3hOBKHqp9ybFomLOCu/
                                        • U uliauer44
                                          #109
                                          @uliauer44
                                          Also Zeile 5.
                                          Die fängt ja auch mit der IP an, für die der Key sich geändert hat.
