  4. [gelöst]PV-Forecast Probleme mit solcast!
    6.3k
83 Beiträge 19 Kommentatoren 18.3k Aufrufe 20 Beobachtet
  • icebearI icebear
    @arteck said in PV-Forecast Probleme mit solcast!:
    ich weiss nicht...
    die scripte sind alle lauffähig und werden auch genutzt.. also kein plan
    Es läuft jetzt, die Daten kommen auch. Vielleicht war ich einfach zu ungeduldig und mußte das erstmal einen kompletten Tag laufen lassen.
    Ein Problem hab ich allerdings noch, im Protokoll meckert er an das 'toLog is not defined'
    javascript.0
    2024-10-15 09:01:01.502	error	at processTimers (node:internal/timers:519:7)
    javascript.0
    2024-10-15 09:01:01.502	error	at listOnTimeout (node:internal/timers:581:17)
    javascript.0
    2024-10-15 09:01:01.502	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3219:34)
    javascript.0
    2024-10-15 09:01:01.499	error	at Object.<anonymous> (script.js.get_solcast_data:189:17)
    javascript.0
    2024-10-15 09:01:01.499	error	at genGraphAnlegen (script.js.get_solcast_data:402:5)
    javascript.0
    2024-10-15 09:01:01.499	error	at genGraph (script.js.get_solcast_data:451:16)
    javascript.0
    2024-10-15 09:01:01.499	error	script.js.get_solcast_data: TypeError: Cannot read properties of undefined (reading 'setStateAsync')
    javascript.0
    2024-10-15 09:01:01.476	error	at processTimers (node:internal/timers:519:7)
    javascript.0
    2024-10-15 09:01:01.475	error	at listOnTimeout (node:internal/timers:581:17)
    javascript.0
    2024-10-15 09:01:01.473	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3219:34)
    javascript.0
    2024-10-15 09:01:01.473	error	at Object.<anonymous> (script.js.get_solcast_data:188:17)
    javascript.0
    2024-10-15 09:01:01.473	error	at genGraphAnlegen (script.js.get_solcast_data:402:5)
    javascript.0
    2024-10-15 09:01:01.473	error	at genGraph (script.js.get_solcast_data:451:16)
    javascript.0
    2024-10-15 09:01:01.473	error	script.js.get_solcast_data: TypeError: Cannot read properties of undefined (reading 'setStateAsync')
    javascript.0
    2024-10-15 09:01:01.468	error	at processTimers (node:internal/timers:519:7)
    javascript.0
    2024-10-15 09:01:01.466	error	at listOnTimeout (node:internal/timers:581:17)
    javascript.0
    2024-10-15 09:01:01.463	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3219:34)
    javascript.0
    2024-10-15 09:01:01.460	error	at Object.<anonymous> (script.js.get_solcast_data:192:17)
    javascript.0
    2024-10-15 09:01:01.452	error	Error in callback: ReferenceError: toLog is not defined
    bekomm ich das noch irgendwie weg?
    arteckA Offline
    arteckA Offline
    arteck
    @icebear sagte in PV-Forecast Probleme mit solcast!:
    toLog
    lösch die Zeile 1024
    toLog(' -----------------    Batterie NOTLADEN ' + _bydDirectSOC + ' %', true);
    icebearI 1 Antwort Letzte Antwort
    • arteckA arteck
      toLog
      icebearI Online
      icebearI Online
      icebear
      Hm, ich benutze ja nur das 'get_solcast_data' Script, da gibt es keine Zeile 1024, bzw eine Zeile die so aussieht wie in deinem Post.
      Ich hoffe ich gehe recht in der Annahme, das das beim 'get_solcast_Data' Script ähnlich ist und so hab ich zum Testen mal die Zeilen mit toLog auskommentiert (42, 46 und 191) :
      schedule({ astro: 'sunrise' }, () => {
          initialPV();
          let url = `${seite2}/forecasts?format=json&api_key=${key_id}`;
          //toLog(`Hole PV ${name2}`, true);
          requestData(url, name2);
          url = `${seite1}/forecasts?format=json&api_key=${key_id}`;
          //toLog(`Hole PV ${name1}`, true);
          requestData(url, name1);
      sowie:
                     setState(`${mainObject}.lastUpdated`, { val: moment().valueOf(), ack: true });
                      //toLog(`Hole PV ${seite}`, true);
      • icebearI icebear
        Guten Morgen
        Kümmert sich eigentlich noch jemand um den PV-Forecast Adapter?
        Seit vorgestern funktioniert die Abfrage der Forecast-Daten bei Solcast nicht mehr.
        Fehlermeldung ist > AxiosError: Request failed with status code 403
        Github Issue sind erstellt!
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @icebear said in PV-Forecast Probleme mit solcast!:
        Guten Morgen
        Um die URSPRÜNGLICHE Frage zu beantworten:
        JA
        Es gibt eine neue Version 4.0.0.
        Rückmeldungen zum Adapter - gerne auch positive im Sinne von es geht -sind gern gesehen.
        Zitat:
        https://forum.iobroker.net/topic/77375/pv-forecast-probleme-mit-solcast/20
        Version 4.0.0 testen, Plants neu anlegen (braucht ja nur noch die Resource ID), fertig.
        Sollte etwas nicht gehen: Issue auf GitHub öffnen und vernünftig beschreiben.
        Diskussionen zu Skripts weichen eigentlich vom Thema (siehe Eröffnungsposting) ab und sollten in einem Support / Diskussionstopicc für das jeweilige Scritp geführt werden da sie mitz dem Adapter eher wenig zu tun haben.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • mcm1957M mcm1957
          Guten Morgen
          JA
          icebearI Online
          icebearI Online
          icebear
          @mcm1957 said in PV-Forecast Probleme mit solcast!:
          Leider ist das ganze mit den zusätzlichen Post's hier etwas aus dem Ruder gelaufen, und war so ja auch garnicht gedacht. Sorry dafür!
          Noch einmal möchte ich mich bei @haus-automatisierung für seinen schnellen und unermüdlichen Einsatz beim beheben des Problems Danke sagen!
          Zumindest bei mir funktioniert der Adapter mit 'solcast jetzt wieder zu 100% .
          Ich glaube wir können das jetzt hiermit beschließen.
          • icebearI icebear
            Taddy81
            schrieb am zuletzt editiert von Taddy81
            hat sich erledigt
            Proxmox 3Node Cluster, IOBroker in LXC
            PV Visualisierung und Steuerung mit NodeRed und Grafana
            • T Taddy81
              hat sich erledigt
              icebearI Online
              icebearI Online
              icebear
              @taddy81
              Hallo, da es hier nur um die vorübergehend nicht zur Verfügung stehenden Vorhersagen vom PV-Forecast Adapter bei 'solcast' ging und das Problem ja mit der Version 4.0.0 behoben ist, mußt du am besten deine Frage im ursprünglichen Thread posten.
              Test PV-Forecast Adapter
              • icebearI icebear
                @taddy81
                anbima
                Bei mir wird die 4.0 nicht angezeigt.
                Ich habe auch "Adapter auf Updates prüfen" gemacht, aber es bleibt beim 3.0.0
                Muss ich da noch warten?
                • A anbima
                  haus-automatisierungH Offline
                  @anbima sagte in [gelöst]PV-Forecast Probleme mit solcast!:
                  Wie immer bei neuen Versionen: Ist nur im Beta-Repo bisher.
                  Alternativ über npm installieren (nie über GitHub-Urls bitte).
                  📚 Meine Dokumentation
                    anbima
                    @haus-automatisierung said in [gelöst]PV-Forecast Probleme mit solcast!:
                    Wie mache ich das über npm?
                    Welchen Befehl muss ich im Rasp eingeben?
                    Oder geht das direkt aus dem ioBroker?
                    • A anbima
                      Klar. Adapter-Tab. Experten-Modus. GitHub Octocat anklicken. Tab npm. pvforecast auswählen.
                      Generell mal die ioBroker-Grundlagen anschauen
                      A 2 Antworten Letzte Antwort
                        anbima
                        Vielen Dank.
                        Ich hatte das schon mal gelesen, aber den GitHub-Button glatt übersehen.
                        Im Experten-Modus war ich schon...
                          Ich bestelle das Thema mal ab, geht ja gar nicht mehr um den Adapter. Hatte auf Feedback vom TO gehofft.
                          Danke an @SmartHomer-0 für die Rückmeldung.
                          D Online
                          D Online
                          docsnyder7
                          Auch hier mit dem Update wieder alles Bestens!
                          Danke Matthias
                            anbima
                            Funktioniert wieder bestens. Vielen Dank.
                            Ich hätte da noch was anderes.
                            Wir haben ja bei Solcast das Problem mit den Updates, dass die "alten" Daten vom Tag verloren gehen.
                            Dafür hätte ich eine Lösung.
                            Du machst um 5 Uhr in der früh eine Abfrage, wie es bisher ist.
                            Bei der nächsten Abfrage (sagen wir mal alle 240 Minuten) kommt eine zusätzliche Abfrage beim Import der Daten rein:
                            wenn timestamp == heute && uhrzeit > 5 uhr dann
                            wenn import-wert != 0 wert importieren sonst nicht.
                            Somit würden die Werte von früheren Stunden des Tages erhalten bleiben und die neuen werden aktualisiert.
                            Was hältst du davon?
                            arteckA haus-automatisierungH 2 Antworten Letzte Antwort
                            • A anbima
                              arteckA Offline
                              arteckA Offline
                              arteck
                              mal von abgesehen das bei solcast man NUR 10 freie abfragen hat und die Daten dir nix bringen vor dem Sonnenaufgang zu holen..
                              schmeiss die Daten in influxDB oder mysql oder oder..
                              • arteckA arteck
                                anbima
                                @arteck said in [gelöst]PV-Forecast Probleme mit solcast!:
                                Derzeit werden die Daten bereits um 1 Uhr geholt.
                                Und um 5 Uhr ist im Sommer kurz vor Sonnenaufgang.
                                Die 10 freien Abfragen könnte man ja schön über den Tag verteilen. Der Abfrageintervall ist ja bei forecast.solar schon vorhanden und könnte da auch verwendet werden.
                                Das mit der Datenbank könnte man machen, wäre dann aber nicht erforderlich. Nicht jeder möchte hierfür eine Datenbank anlegen.
                                • A anbima
                                  Schon klar wie das technisch umsetzbar wäre. Aber guck mal den Code an. Alles ist auf forecast solar ausgelegt und solcadt wurde nachträglich oben drauf gebaut.
                                  So wird zB auch das Format von Solcast in das von Forecast Solar konvertiert, damit man die ganze Logik beibehalten konnte.
                                  Es wäre also ein größerer Eingriff das komplett zu trennen. Aber ich freue mich immer über Mitarbeitende am Adapter.
                                  A A 2 Antworten Letzte Antwort
                                    anbima
                                    schrieb am zuletzt editiert von anbima
                                    An welcher Stelle in der main.js schreibst du die Daten in die Objekte?
                                    Ich bin zwar kein Programmierer, aber vielleicht bekomme ich das hin.
                                    Nur den ganzen Code zu durchsuchen ist sehr aufwendig.
                                    Nachtrag.
                                    Kannst du mir vielleicht folgendes beantworten:
                                    So wie ich das sehen kann, werden die Daten nur in die Objekte der einzelnen plants geschrieben, wenn diese vorhanden sind. Löscht du die Inhalte alle, bevor du diese neu in die Objekte schreibst? Wenn ja, wo wird dies gemacht?
                                    • A anbima
                                      Nachtrag.
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      https://github.com/iobroker-community-adapters/ioBroker.pvforecast/blob/3ef9743f113e0c4a53a7f1841748131e5b1d66a3/main.js#L185
                                      T A 2 Antworten Letzte Antwort
                                      • arteckA arteck
                                        TimoWald
                                        Wo stelle ich den Abfrageinterval ein bzw wo stelle ich ein um wieviel Uhr eine Abfrage stattfinden soll?
                                        • T TimoWald
                                          anbima
                                          @timowald said in [gelöst]PV-Forecast Probleme mit solcast!:
                                          Der Abfrageintervall ist ein Problem, da bei einem neuen Abruf alle Daten bis zum aktuellen Zeitpunkt weg sind. Du kannst es einfach den Abapter neu starten, dann macht es einen neuen Abruf.
                                          Wenn sich einige melden, vielleicht macht es @haus-automatisierung dann :-)
