  4. bekomme den Sonoff 3 USB Dongle auch nicht auf grün.
    1.9k
39 Beiträge 6 Kommentatoren 3.5k Aufrufe 2 Beobachtet
  • werner2000xW Offline
    werner2000x
    schrieb am zuletzt editiert von werner2000x
    Ich bekomme den Sonoff 3 USB Dongle auch nicht auf grün.
    Hier der Log:
    2024-10-14 13:15:28.822  - error: zigbee.0 (14782) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl                us_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0"
    2024-10-14 13:15:28.825  - error: zigbee.0 (14782) Failed to start Zigbee
    2024-10-14 13:15:28.825  - error: zigbee.0 (14782) Error herdsman start
    2024-10-14 13:15:28.829  - info: zigbee.0 (14782) Installed Version: iobroker.zigbee@1.10.3
    2024-10-14 13:15:38.829  - info: zigbee.0 (14782) Try to reconnect. 1 attempts left
    2024-10-14 13:15:38.830  - info: zigbee.0 (14782) Starting Zigbee  npm ...
    2024-10-14 13:15:38.845  - error: zigbee.0 (14782) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl                us_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0"
    2024-10-14 13:15:38.846  - error: zigbee.0 (14782) Failed to start Zigbee
    2024-10-14 13:15:38.846  - error: zigbee.0 (14782) Error herdsman start
    2024-10-14 13:15:38.854  - info: zigbee.0 (14782) Installed Version: iobroker.zigbee@1.10.3
    zigbee.0
    2024-10-14 13:59:56.344	error	Error herdsman start
    zigbee.0
    2024-10-14 13:59:56.343	error	Failed to start Zigbee
    zigbee.0
    2024-10-14 13:59:56.342	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
    zigbee.0
    2024-10-14 13:59:56.120	info	Installed Version: iobroker.zigbee@1.10.3
    zigbee.0
    2024-10-14 13:59:56.092	info	Starting Zigbee npm ...
    zigbee.0
    2024-10-14 13:59:56.090	info	Try to reconnect. 1 attempts left
    zigbee.0
    2024-10-14 13:59:46.084	error	Error herdsman start
    zigbee.0
    2024-10-14 13:59:46.083	error	Failed to start Zigbee
    zigbee.0
    2024-10-14 13:59:46.082	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    Ich habe mal testweise auf Version 1.10.9 installiert - leider auch ohne Erfolg. Auch die Baudrate auf 38400 half nicht.
    Raspi4 8 GB mit Aqara Zigbee USB, iob
    Innogy Smarthome
    Bosch Bridge 2
    HUE Bridge
    OpenWB Wallbox mit EVU Kit
    Google Nest Pro Hub
    HA auf uGreen dxp4800
    • werner2000xW werner2000x
      Hier der Log:
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      @werner2000x sagte in [gelöst] Sonoff Zigbee 3.0 Dongle E startet nicht (mehr):
      Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0
      Und wie lautet der Link richtig?
      Steht z. B. in der Langfassung von
      iob diag
      drin.
      werner2000xW 1 Antwort Letzte Antwort
        iob diag
        drin.
        werner2000x
        @thomas-braun Hier der Log USB:
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the l                      inks 'by-id':
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-i                      f00-port0
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        zigbee.0
        2024-10-14 14:58:10.324	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"3a137e30f6e6ed11a179cf770b2af5ab","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0","vendorId":"10c4","productId":"ea60"}]
        zigbee.0
        2024-10-14 14:58:10.159	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        zigbee.0
        2024-10-14 15:41:05.058	error	Error herdsman start
        zigbee.0
        2024-10-14 15:41:05.057	error	Failed to start Zigbee
        zigbee.0
        2024-10-14 15:41:05.056	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
        zigbee.0
        2024-10-14 15:41:04.879	info	Installed Version: ioBroker/ioBroker.zigbee
        zigbee.0
        2024-10-14 15:41:04.865	info	Starting Zigbee npm ...
        zigbee.0
        2024-10-14 15:41:04.863	info	Try to reconnect. 1 attempts left
        zigbee.0
        2024-10-14 15:40:54.858	error	Error herdsman start
        zigbee.0
        2024-10-14 15:40:54.858	error	Failed to start Zigbee
        zigbee.0
        2024-10-14 15:40:54.857	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        Innogy Smarthome
        Bosch Bridge 2
        HUE Bridge
        Google Nest Pro Hub
          USB-Devices by-id:
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          @werner2000x
          Zieh den Stick mal für 1 bis 2 Minuten raus und schau dann mal.
            werner2000x
            @thomas-braun Leider kein Erfolg:
            zigbee.0
            2024-10-14 16:11:14.225	error	Error herdsman start
            zigbee.0
            2024-10-14 16:11:14.225	error	Failed to start Zigbee
            zigbee.0
            2024-10-14 16:11:14.224	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
            zigbee.0
            2024-10-14 16:11:14.051	info	Installed Version: ioBroker/ioBroker.zigbee
            zigbee.0
            2024-10-14 16:11:14.023	info	Starting Zigbee npm ...
            zigbee.0
            2024-10-14 16:11:14.022	info	Try to reconnect. 1 attempts left
            zigbee.0
            2024-10-14 16:11:04.018	error	Error herdsman start
            zigbee.0
            2024-10-14 16:11:04.018	error	Failed to start Zigbee
            zigbee.0
            2024-10-14 16:11:04.016	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
            Innogy Smarthome
            Bosch Bridge 2
            HUE Bridge
            Google Nest Pro Hub
            Thomas BraunT haselchenH 2 Antworten Letzte Antwort
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              @werner2000x
              Welche Firmware verwendet der Stick und was ist im Adapter eingetragen?
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                haselchenH Offline
                haselchenH Offline
                haselchen
                @werner2000x
                Zeig mal nen Screenshot von den Einstellungen im Zigbee Adapter.
                  @werner2000x
                  werner2000x
                  @thomas-braun Wie komme ich auf die Firmwareversion?
                  Auf den Button Firmware updaten reagiert das System nicht.
                  Innogy Smarthome
                  Bosch Bridge 2
                  HUE Bridge
                  Google Nest Pro Hub
                    @werner2000x
                    Änder mal den Typ auf EZirgendwas.
                    Ich meine der Stick würde nicht den TI-Stack verwenden.
                      @werner2000x
                      werner2000x
                      @thomas-braun Es Koomen zwar keine Fehlermeldungen, aber Infos.
                      zigbee.0
                      2024-10-14 17:44:38.122	info	Installed Version: ioBroker/ioBroker.zigbee
                      zigbee.0
                      2024-10-14 17:44:37.771	info	Starting Zigbee npm ...
                      zigbee.0
                      2024-10-14 17:44:37.768	info	delete old Backup files. keep only last 10
                      zigbee.0
                      2024-10-14 17:44:37.662	info	starting. Version 1.10.9 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
                      Der Status bleibt gelb.
                      Jetzt kommen doch noch Fehler.
                      zigbee.0
                      2024-10-14 17:47:09.029	error	Error herdsman start
                      zigbee.0
                      2024-10-14 17:47:09.029	error	Failed to start Zigbee
                      zigbee.0
                      2024-10-14 17:47:09.027	error	Starting zigbee-herdsman problem : "Failure to connect"
                      Innogy Smarthome
                      Bosch Bridge 2
                      HUE Bridge
                      Google Nest Pro Hub
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @werner2000x
                        Also , mehrere Sachen.
                        Angefangen oben links .
                        Drück mal auf den Pfeil und zeig was Du für Auswahlmöglichkeiten hast .
                        Vermutlich musst Du gleich die erste Auswahl nehmen. tty/USB
                        Dann rechts lass mal auf die TI….C…. Einstellung.
                        Unten bei Sendeleistung drückst du auf den Pfeil und stellst Low ein.
                          werner2000x
                          @haselchen Auswahlmenü:screenshotAuswahl.jpg
                          Innogy Smarthome
                          Bosch Bridge 2
                          HUE Bridge
                          Google Nest Pro Hub
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @werner2000x
                            Also mein Bester, wo ist oben links 😉
                            Bei der Auswahl die du jetzt gezeigt hast , nimmst du das Erste.
                            • haselchenH haselchen
                              @werner2000x
                              werner2000x
                              @haselchen Also den com anschluss auswählen.
                              Dort gibt es keine Auswahl, nur den bisher installierten.
                              Innogy Smarthome
                              Bosch Bridge 2
                              HUE Bridge
                              Google Nest Pro Hub
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @werner2000x
                                Wenn du da auf den Pfeil klickst kommt keine Auswahlmöglichkeit ? 🤔
                                  @werner2000x
                                  werner2000x
                                  @haselchen wenn ich state cleanup mache kommt noch:
                                  /dev/ttyUSB0
                                  Innogy Smarthome
                                  Bosch Bridge 2
                                  HUE Bridge
                                  Google Nest Pro Hub
                                    /dev/ttyUSB0
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @werner2000x
                                    Den nimmst du .
                                    Und unten noch Low einstellen und dann den Adapter neu starten.
                                    Und dann zeigst du bitte das Log.
                                      @werner2000x
                                      Den nimmst du .
                                      werner2000x
                                      @haselchen Es kommen noch Fehler:
                                      zigbee.0
                                      2024-10-14 18:17:46.104	error	Error herdsman start
                                      zigbee.0
                                      2024-10-14 18:17:46.103	error	Failed to start Zigbee
                                      zigbee.0
                                      2024-10-14 18:17:46.102	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                      zigbee.0
                                      2024-10-14 18:21:48.322	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"3a137e30f6e6ed11a179cf770b2af5ab","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0","vendorId":"10c4","productId":"ea60"}]
                                      zigbee.0
                                      2024-10-14 18:21:48.135	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                      zigbee.0
                                      2024-10-14 18:21:45.344	error	Error herdsman start
                                      zigbee.0
                                      2024-10-14 18:21:45.344	error	Failed to start Zigbee
                                      zigbee.0
                                      2024-10-14 18:21:45.343	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                                      Innogy Smarthome
                                      Bosch Bridge 2
                                      HUE Bridge
                                      Google Nest Pro Hub
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @werner2000x
                                        Ok gerade quergelesen .
                                        Nimm bei Coordinator den EZSP.
                                        Und wichtig , es darf nix anderes laufen wo auf den Stick zugegriffen wird , als Beispiel Homeassistant.
                                        Edit: und die URL vom Stick, die du vorher hattest … dev/…..
                                        Mit dem Tool kannste resetten oder die nötige Firmware aufspielen.
                                        https://zig-star.com/radio-docs/zigstar-multi-tool/
                                          @werner2000x
                                          werner2000x
                                          @haselchen Den EZSP gibt es in zwei versionen.
                                          Wieder Fehler:
                                          zigbee.0
                                          2024-10-14 18:27:58.032	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"3a137e30f6e6ed11a179cf770b2af5ab","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0","vendorId":"10c4","productId":"ea60"}]
                                          zigbee.0
                                          2024-10-14 18:27:57.884	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                          zigbee.0
                                          2024-10-14 18:27:08.051	info	Installed Version: ioBroker/ioBroker.zigbee
                                          zigbee.0
                                          2024-10-14 18:27:07.719	info	Starting Zigbee npm ...
                                          zigbee.0
                                          2024-10-14 18:27:07.717	info	delete old Backup files. keep only last 10
                                          zigbee.0
                                          2024-10-14 18:27:07.618	info	starting. Version 1.10.9 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
                                          zigbee.0
                                          2024-10-14 18:26:52.141	info	terminating
                                          zigbee.0
                                          2024-10-14 18:26:51.658	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          zigbee.0
                                          2024-10-14 18:26:51.655	info	terminating
                                          zigbee.0
                                          2024-10-14 18:26:51.642	info	Zigbee: disabling joining new devices.
                                          zigbee.0
                                          2024-10-14 18:26:51.637	info	cleaned everything up...
                                          zigbee.0
                                          2024-10-14 18:26:51.634	info	Got terminate signal TERMINATE_YOURSELF
                                          Innogy Smarthome
                                          Bosch Bridge 2
                                          HUE Bridge
                                          Google Nest Pro Hub
