  3. Einsteigerfragen
  4. Installation
  5. IOBroker startet nicht mehr nach Updates
32 Beiträge 5 Kommentatoren 4.2k Aufrufe 6 Beobachtet
  • T thomke67
    @samson71
    Schon mal Danke, dass du Hilfe anbietest.
    Hier das Resultat aus iob diag
    Copy text starting here:
    ```bash
                            v.2024-08-12
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    User-ID:                1000
    Display-Server:         true
    Pending OS-Updates:     0
    (node:3171) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
        at new NodeError (internal/errors.js:322:7)
        at Loader.builtinStrategy (internal/modules/esm/translators.js:289:11)
        at new ModuleJob (internal/modules/esm/module_job.js:63:26)
        at Loader.getModuleJob (internal/modules/esm/loader.js:258:11)
        at async ModuleWrap.<anonymous> (internal/modules/esm/module_job.js:78:21)
        at async Promise.all (index 2)
        at async link (internal/modules/esm/module_job.js:83:9)
    (Use `node --trace-warnings ...` to show where the warning was created)
    (node:3171) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
    (node:3171) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v14.21.3
    /usr/bin/node           v14.21.3
    /usr/bin/npm            6.14.18
    /usr/bin/npx            6.14.18
    /usr/bin/corepack       0.15.1
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:           3.8G        239M        3.0G         24M        633M        3.4G
    Swap:           99M          0B         99M
    Total:         3.9G        239M        3.1G
    Active iob-Instances:   0
    (node:3238) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
    (node:3238) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
    (node:3238) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    (node:3252) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
    (node:3252) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
    (node:3252) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    ioBroker Core:          js-controller
    (node:3267) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
    (node:3267) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
    (node:3267) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                            admin
    (node:3281) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
    (node:3281) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
    (node:3281) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    19M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    14M     /opt/iobroker/iobroker-data/states.jsonl
    1.2M    /opt/iobroker/iobroker-data/states.json.migrated
    1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    Samson71S Offline
    Samson71S Offline
    Samson71
    @thomke67
    Neben der Tatsache, dass ein "Summary" nicht die Langfassung ist, kann man das Problem aber schon sehen. Debian 10 (Buster) ist lange tot. Sofern Du versucht hast auf Nodejs 20 upzudaten ist klar, dass es klemmt. Das läuft nicht mehr mit Buster.
    Downgrade auf Nodejs 18, Rest soweit wie möglich aktuell, Backup machen und das in eine frische ioBroker-Installation in einem neu installierten Debian 12 (64bit ohne Desktop) einspielen. Ein direktes Update von Debian 10 auf 12 funktioniert nicht!
    EDIT
    Sehe gerade, dass Du noch Uralt unterwegs bist mit Nodejs14. Minimum für die meisten Adapter ist mittlerweile 18. Hatte zuerst nach der Anzeige mit Buster nicht weitergelesen. Ich vermute daher, dass da auch jede Menge Systemupdates fehlen.
    Um das bis auf Maximum hochzuziehen bin ich auch nicht fit genug. Da muss unser @Thomas-Braun besser mal mit draufgucken.
    Markus
    Bitte beachten:
    • Samson71S Samson71
      @thomke67
      EDIT
      thomke67
      schrieb am zuletzt editiert von thomke67
      @samson71 Vielen Dank
      @Thomas-Braun Was ist jetzt genau zu tun? Bin nicht so im Linux unterwegs. Ich habe immer mal wieder Updates über die Konsole gemacht. Das ich jetzt so weit hinten liegen soll, ist mir gar nicht aufgefallen.
      Gruß,
      Thomas
      • T thomke67
        CodierknechtC Offline
        Codierknecht
        @thomke67 sagte in IOBroker startet nicht mehr nach Updates:
        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • CodierknechtC Codierknecht
          thomke67
          @codierknecht Wird dabei die alte Version überschrieben, oder muss ich die manuell löschen?
          Zudem ist bei mir die Installation auf einer SSD. Das habe ich vor langer Zeit mal gemacht und jetzt weiß ich nicht mehr, wie ich damals vorgegangen bin. War bestimmt eine Schritt für Schritt Anleitung.
          Gruß,
          Thomas
          Samson71S T 2 Antworten Letzte Antwort
          • T thomke67
            Samson71S Offline
            Samson71S Offline
            Samson71
            @thomke67
            Wenn Du das direkt auf der alten Karte machst ist alles futsch. Ich würde eine neue SD-Karte nehmen. Dann bleibt die alte zur Sicherheit erhalten. Die Neuinstallation ist ja nur die eine Seite. Die Aktualisierung und das Backup vom Altsystem die andere Seite.
            Markus
            Bitte beachten:
              @thomke67
              thomke67
              @samson71 Da steckt keine Karte mehr drin.
              Gruß,
              Thomas
              Samson71S Thomas BraunT 3 Antworten Letzte Antwort
              • T thomke67
                Samson71S Offline
                Samson71S Offline
                Samson71
                @thomke67
                Auf jeden Fall ist das Altsystem futsch, wenn Du da direkt ein neues Bookworm draufklatscht. Deswegen mein Hinweis auf einen alternativen Datenträger oder was auch immer und Aktualisierung des Altsystems soweit wie möglich und davon dann ein Backup.
                Markus
                Bitte beachten:
                • T thomke67
                  @thomke67
                  iob nodejs-update 18
                  Dann damit den ioBroker auf den aktuellen Stand bringen (und zwar vollständig, inkl. js-controller).
                  Davon dann ein Backup ziehen und damit auf ein frisch von Grundauf neuinstalliertes Betriebssystem umziehen.
                  Hattest du nodejs@20 per
                  iob nodejs-update
                  vorgenommen? Denn eigentlich sollte das nicht möglich sein.
                  Muss ich dann nochmal in den Code schauen, warum das nicht erkannt wurde.
                  • T thomke67
                    @thomke67
                    Kannst du mir mal aus dem jetzigen System die Ausgabe von
                    cat /etc/debian_version
                    mitteilen?
                      @thomke67
                      iob nodejs-update
                      thomke67
                      Ich habe node.js Version 18 installiert und das System ist wieder da. Vielen Dank!!!!!!
                      Es war aber wohl auf Version 14, oder?
                      ioBroker nodejs fixer 2024-06-20
                      You requested to install latest version from nodejs v18 tree.
                      Your current setup is:
                      We found these nodejs versions available for installation:
                      nodejs:
                        Installed: 14.21.3-deb-1nodesource1
                        Candidate: 14.21.3-deb-1nodesource1
                        Version table:
                       *** 14.21.3-deb-1nodesource1 1001
                              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                           10.24.0~dfsg-1~deb10u3 500
                      Nothing to do - Your installation is using the correct paths.
                      You are running nodejs v14.21.3. Do you want to install latest version from nodejs v.18 tree?
                      Press <y> to continue or any other key to quit
                      Trying to fix your installation now. Please be patient.
                      rm: cannot remove '/etc/apt/keyrings/nodesource.gpg'$'\n''/usr/share/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
                      Waiting for ioBroker to shut down - Give me a minute...
                      Removing dfsg-nodejs
                      *** These repos are active on your system:
                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:2 https://apt.pivccu.de/piVCCU stable InRelease
                      Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                      Reading package lists... Done
                      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                      Package: nodejs
                      Pin: origin deb.nodesource.com
                      Pin-Priority: 1001
                      *** These repos are active after the adjustments:
                      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
                      Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                      Get:5 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [10.2 kB]
                      Fetched 22.4 kB in 1s (21.2 kB/s)
                      Installing nodejs now!
                      Exact recommended version unknown, installing a fallback!
                      (Reading database ... 129820 files and directories currently installed.)
                      Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
                      Detected old npm client, removing...
                      Unpacking nodejs (18.0.0-1nodesource1) over (14.21.3-deb-1nodesource1) ...
                      Setting up nodejs (18.0.0-1nodesource1) ...
                      Processing triggers for man-db (2.8.5-2+deb10u1) ...
                      Updating fallback to latest nodejs v18 release
                      (Reading database ... 130626 files and directories currently installed.)
                      Preparing to unpack .../nodejs_18.20.4-1nodesource1_armhf.deb ...
                      Unpacking nodejs (18.20.4-1nodesource1) over (18.0.0-1nodesource1) ...
                      Setting up nodejs (18.20.4-1nodesource1) ...
                      v18.20.4 has been installed! You are using the latest version now!
                      Installing the nodejs!
                      We tried our best to fix your nodejs. Please run iob diag again to verify.
                      *** RESTARTING ioBroker NOW! ***
                       Please refresh or restart your browser in a few moments.
                      pi@raspberrypi:~ $
                      Gruß,
                      Thomas
                        @thomke67
                        mitteilen?
                        thomke67
                        @thomas-braun Debian Version 10.13
                        Gruß,
                        Thomas
                        • T thomke67
                          @thomke67
                          Bitte vollständige Ein- wie Ausgaben in CodeTags zeigen. Also genauso wie es dann auch auf deinem Bildschirm ausgespuckt wird.
                            @thomke67
                            thomke67
                            @thomas-braun Hier die Ausgabe:
                            pi@raspberrypi:~ $ cat /etc/debian_version
                            10.13
                            pi@raspberrypi:~ $
                            Gruß,
                            Thomas
                            • T thomke67
                              10.13
                              pi@raspberrypi:~ $
                              @thomke67
                              Jetzt siehst du auch warum ich da so genau nachfrage...
                              Debian Version 10.13 ist nicht gleich 10.13
                              Ich muss die Abfrage in nodejs-update dann entsprehend ergänzen.
                                @thomke67
                                thomke67
                                @thomas-braun Ok!
                                Und wie komme ich jetzt für mich am Einfachsten von Debian Buster auf die aktuellste Version?
                                Gruß,
                                Thomas
                                CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
                                • T thomke67
                                  @thomas-braun Ok!
                                  Codierknecht
                                  wurde doch schon mehrfach geschrieben:
                                  • T thomke67
                                    thomke67
                                    @codierknecht Es wurde genau einmal geschrieben und da waren meine Fragen:
                                    Backitup hat bei mir die Backups auf einen NAS geschrieben. Die stehen mir also jetzt unabhängig von der SSD zur Verfügung.
                                    Ich weiß aber echt nicht mehr, wie ich von der SD Karte auf die SSD umgezogen bin. Das System lief jetzt einige Jahre super stabil! Und wenn ich mich nicht ganz täusche, dann habe ich die Version des Debians schon mal von einer alten Version auf Buster hochgezogen. Ich habe nämlich irgendwo noch in einem Script einen String durch "buster" ersetzt und dann ging es.
                                    Aber das ist alles schon sehr lange her.....
                                    Gruß,
                                    Thomas
                                    • T thomke67
                                      @thomas-braun Ok!
                                      Der einfachste, weil auch einzige sinnvolle Weg zu einem Raspberry OS 12 'Bookworm' ist eine komplette Neuinstallation.
                                      • T thomke67
                                        Das funktioniert im Fall von 'Raspberry OS 12' nicht.
                                          thomke67
                                          @thomas-braun Ok, verstanden. Also wäre das die normale Vorgehensweise:
                                          1. Ein neues Image auf die SSD schreiben
                                          2. Nach deiner Vorgehensweise auf https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht Iobroker neu installieren
                                          3. Backitup Adapter installieren
                                          4. Backups zurückspielen
                                          Allerdings läuft bei mir auch noch PIvCCU auf dem gleichen Raspi. Das wäre ja dann weg.
                                          Also klappt das bei mir nicht ganz so....
                                          Gruß,
                                          Thomas
                                          Thomas BraunT Samson71S 2 Antworten Letzte Antwort
