  4. BackItUp macht keine Backups mehr.
44 Beiträge 7 Kommentatoren 8.8k Aufrufe 6 Beobachtet
  • J Offline
    JB72
    Da liegt prompt noch ein Update vor.
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v18.20.4. Do you want to install recommended version 20.17.0?
    Ich werde das mal ausführen.
    • J Offline
      JB72
      Copy text starting here:
      ```bash
                              v.2024-08-12
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 10 (buster)
                  Kernel: Linux 4.19.0-27-amd64
            Architecture: x86-64
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1000
      Display-Server:         false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      Recommended versions are nodejs 20.17.0 and npm 10.8.2
      MEMORY:
      Mem:           3.9G         88M        2.6G        5.0M        1.2G        3.6G
      Swap:          4.1G          0B        4.1G
      Total:         8.0G         88M        6.7G
      Active iob-Instances:   1
      Upgrade policy: none
      ioBroker Core:          js-controller           6.0.11
                              admin                   7.1.5
      ioBroker Status:        iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                15593
      States:                 14035
      Size of iob-Database:
      21M     /opt/iobroker/iobroker-data/objects.jsonl
      13M     /opt/iobroker/iobroker-data/objects.json.migrated
      13M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      0       /opt/iobroker/iobroker-data/objects.json.broken
      3.3M    /opt/iobroker/iobroker-data/states.json.migrated
      3.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      3.1M    /opt/iobroker/iobroker-data/states.jsonl
      0       /opt/iobroker/iobroker-data/states.json.broken
      === Mark text until here for copying ===
      jerry@iobroker:~$
      • J JB72
        ```bash
                                v.2024-08-12
                   Chassis: vm
            Virtualization: kvm
        Installation:           kvm
        Kernel:                 x86_64
        Userland:               64 bit
        User-ID:                1000
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        MEMORY:
        Swap:          4.1G          0B        4.1G
                                admin                   7.1.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                15593
        States:                 14035
        jerry@iobroker:~$
        @jb72 sagte in BackItUp macht keine Backups mehr.:
        buster
        Ist tot und muss durch was noch lebendes ersetzt werden.
          buster
          JB72
          Ja den Rüffeln habe ich schon vor dir bekommen, aber kann es daran liegen? Ich kümmere mich sonst mal um eine neue VM die Tage.
          • J JB72
            Das ist egal, ob es daran liegt. Das Ding ist seit Jahren abgekündigt.
            souly75S 1 Antwort Letzte Antwort
              souly75S Online
              souly75S Online
              souly75
              schrieb am zuletzt editiert von souly75
              hallo, ich hänge mich mal hier an
              bei mir ist es auch so, dass backitup das letzte Mal am 14.9. ein Backup auf mein Google Drive geladen hat.
              ich hatte auch keine Fehlermeldung.
              ich hoffe, ich mache hier alles richtig.
              ```bash        Skript v.2024-08-12
              *** BASE SYSTEM ***        Static hostname: iobrokerpi
                     Icon name: computer
                        Kernel: Linux 6.6.31+rpt-rpi-v8
                  Architecture: arm64                                                            OS is similar to:
              Model           : Raspberry Pi 4 Model B Rev 1.1
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               11:37:17 up 2 min,  2 users,  load average: 2.57, 1.28, 0.50
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              ~ Under-voltage detected
              ~ Arm frequency capped
              Previously detected issues:
              ~ Under-voltage has occurred
              ~ Arm frequency capping has occurred
              *** Time and Time Zones ***
                             Local time: Sun 2024-09-29 11:37:17 CEST
                         Universal time: Sun 2024-09-29 09:37:17 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              souly75
              HOME=/home/souly75
              GROUPS=souly75 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              *** Display-Server-Setup ***
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            4.0G        1.2G        2.4G        1.2M        510M        2.8G
              Swap:           209M          0B        209M
              Total:          4.2G        1.2G        2.6G
              Active iob-Instances:   17
                       3841 M total memory
                       1185 M used memory
                       1320 M active memory
                        169 M inactive memory
                       2242 M free memory
                         49 M buffer memory
                        437 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              top - 11:37:18 up 2 min,  2 users,  load average: 2.57, 1.28, 0.50
              Tasks: 186 total,   1 running, 185 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 15.4 us, 15.4 sy,  0.0 ni, 69.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3842.0 total,   2242.6 free,   1184.7 used,    487.5 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2657.2 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     385M  1.2M  384M   1% /run
              /dev/sda2      ext4      220G  7.8G  201G   4% /
              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
              /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
              tmpfs          tmpfs     385M     0  385M   0% /run/user/1000
              [Sun Sep 29 11:34:54 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:FD:76 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=96f3cba4-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sun Sep 29 11:34:57 2024] EXT4-fs (sda2): mounted filesystem e63d7b06-d5b1-4d77-8a29-e8b07c4ae474 ro with ordered data mode. Quota mode: none.
              [Sun Sep 29 11:34:58 2024] EXT4-fs (sda2): re-mounted e63d7b06-d5b1-4d77-8a29-e8b07c4ae474 r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET           SOURCE    FSTYPE OPTIONS
              /                /dev/sda2 ext4   rw,noatime
              `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              2.0G    /var/
              1.2G    /var/cache/apt
              1.2G    /var/cache
              1.1G    /var/cache/apt/archives
              504M    /var/log/journal/2103d4f986c847b78abb08fc632c7148
              Archived and active journals take up 503.4M in the file system.
              /opt/iobroker/backups:
              232M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              715M    /opt/iobroker/iobroker-data/
              648M    /opt/iobroker/iobroker-data/files
              441M    /opt/iobroker/iobroker-data/files/javascript.admin
              409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js13M     /opt/iobroker/iobroker-data/objects.jsonl
              8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO7B71NO-if00-port0
              /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
              Your zigbee.0 COM-Port is matching 'by-id'. Very good!
              *** NodeJS-Installation ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Installed: 20.17.0-1nodesource1
                Candidate: 20.17.0-1nodesource1
                Version table:
               *** 20.17.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2 500
                      500 http://deb.debian.org/debian bookworm/main arm64 Packages
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  6.0.11
              admin:          7.1.5
              javascript:     8.7.6
              nodejs modules from github:     1
              +-- iobroker.enocean@0.9.3 (git+ssh://git@github.com/Jey-Cee/ioBroker.enocean.git#798b7916713c80bf61cebee663e289194906fabc)
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobrokerpi                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alias-manager.0          : alias-manager         : iobrokerpi                               -  enabled
              + system.adapter.backitup.0               : backitup              : iobrokerpi                               -  enabled
              + system.adapter.discovery.0              : discovery             : iobrokerpi                               -  enabled
              + system.adapter.enocean.0                : enocean               : iobrokerpi                               -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobrokerpi                               -  enabled
                system.adapter.feiertage.0              : feiertage             : iobrokerpi                               -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : iobrokerpi                               -  enabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : iobrokerpi                               -  enabled
              + system.adapter.hue.0                    : hue                   : iobrokerpi                               -  enabled, port: 443
                system.adapter.ical.0                   : ical                  : iobrokerpi                               -  enabled
              + system.adapter.iqontrol.0               : iqontrol              : iobrokerpi                               -  enabled
              + system.adapter.jarvis.0                 : jarvis                : iobrokerpi                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.javascript.0             : javascript            : iobrokerpi                               -  enabled
              + system.adapter.opendtu.0                : opendtu               : iobrokerpi                               -  enabled
              + system.adapter.ping.0                   : ping                  : iobrokerpi                               -  enabled
              + system.adapter.telegram.0               : telegram              : iobrokerpi                               -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.web.0                    : web                   : iobrokerpi                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.zigbee.0                 : zigbee                : iobrokerpi                               -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "alias-manager": 1.2.6    , installed 1.2.6
              Adapter    "backitup"     : 3.0.22   , installed 3.0.22
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
              Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
              Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
              Adapter    "heatingcontrol": 2.12.10 , installed 2.12.10
              Adapter    "hue"          : 3.12.0   , installed 3.12.0
              Adapter    "ical"         : 1.15.0   , installed 1.15.0
              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
              Controller "js-controller": 6.0.11   , installed 6.0.11
              Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "web"          : 6.2.5    , installed 6.2.5
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Objects and States
              Objects:        2851
              States:         2100
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2608       693/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       9221       1171/io.jarvis.0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2641       666/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2636       666/iobroker.js-con
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6125       1160/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5852       834/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          2610       693/sshd: /usr/sbin
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5619       545/avahi-daemon: r
              udp        0      0 0.0.0.0:40968           0.0.0.0:*                           104        5621       545/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        5620       545/avahi-daemon: r
              udp6       0      0 :::52990                :::*                                104        5622       545/avahi-daemon: r
              udp6       0      0 fe80::cad9:8c9b:d93:546 :::*                                0          954        597/NetworkManager
              2024-09-29 11:36:20.552  - info: fritzdect.0 (1119) ____________________________________________
              2024-09-29 11:36:20.553  - info: fritzdect.0 (1119) create Main object DECT_ 109710491984 Bad thermo.heat
              2024-09-29 11:36:21.642  - info: fritzdect.0 (1119) finished creating devices/groups (if any)
              2024-09-29 11:36:21.646  - info: fritzdect.0 (1119) templates are used(false)
              2024-09-29 11:36:21.647  - info: fritzdect.0 (1119) start creating templates
              2024-09-29 11:36:21.968  - info: fritzdect.0 (1119) finished creating templates (if any)
              2024-09-29 11:36:21.969  - info: fritzdect.0 (1119) routines are used(false)
              2024-09-29 11:36:21.978  - info: fritzdect.0 (1119) start creating routines
              2024-09-29 11:36:22.307  - info: fritzdect.0 (1119) finished creating routines (if any)
              2024-09-29 11:36:22.308  - info: fritzdect.0 (1119) start initial updating devices/groups
              2024-09-29 11:36:22.973  - info: web.0 (1160) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
              2024-09-29 11:36:23.957  - info: web.0 (1160) socket.io server listening on port 8082
              2024-09-29 11:36:23.973  - info: web.0 (1160) http server listening on port 8082
              ```bash        ======================= SUMMARY =======================
                                      v.2024-08-12
                     Icon name: computer                                                         Operating System: Debian GNU/Linux 12 (bookworm)
                  Architecture: arm64
              Installation:           native                                                     Kernel:                 aarch64
              Userland:               64 bit
              Timezone:               Europe/Berlin (CEST, +0200)                                User-ID:                1000                                                       Display-Server:         false                                                      Boot Target:            multi-user.target
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              MEMORY:
              Mem:            4.0G        1.2G        2.2G        1.2M        766M        2.9G
              Swap:           209M          0B        209M
              Total:          4.2G        1.2G        2.4G
              ich sehe undervoltage. er hängt an einer kleinen USV. Bisher sind mir diesbezüglich keine Fehler aufgefallen.
              • souly75S souly75
                       Icon name: computer
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                souly75
                HOME=/home/souly75
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           209M          0B        209M
                         3841 M total memory
                         1185 M used memory
                         2242 M free memory
                           49 M buffer memory
                          437 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                *** FILESYSTEM ***
                /var:
                2.0G    /var/
                1.2G    /var/cache/apt
                1.2G    /var/cache
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          7.1.5
                javascript:     8.7.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2851
                States:         2100
                Pending Updates: 0
                                        v.2024-08-12
                    Architecture: arm64
                Userland:               64 bit
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                MEMORY:
                Swap:           209M          0B        209M
                @souly75 sagte in BackItUp macht keine Backups mehr.:
                Current issues:
                Deine Spannungsversorgung für den Pi4 ist zu schwach/instabil.
                Verwende ein richtiges Netzteil, kein USB-Ladegerät oder sowas.
                Ansonsten schaut das soweit gut aus. Wie sehen die Einstellungen im Backitup aus? Werden mehrere Backup-Verfahren eingesetzt?
                  Current issues:
                  souly75S Online
                  souly75S Online
                  souly75
                  ich lasse nur den iobroker sichern und nutze nur den backitup Adapter.
                  er sichert auf GoogleDrive und Oberdrive.
                  Auf onedrive war am 20.9. das letzte Backup.
                  unter den Zusatzeinstellungen habe ich Benachrichtigung mit eingestellt, aber da kam tatsächlich nichts.
                  Danke für den Hinweis. dann nutze ich das richtige Netzteil
                  edit:
                  im Backitup steht, dass das letzte erfolgreiche Backup am 14.9. war
                  allerdings konnte ich eben manuell auch eines für onedrive erstellen.
                  es sieht so aus, als wenn sich GoogleDrive sperrt
                  • souly75S souly75
                    edit:
                    @souly75
                    Zeig mal das Log zu einem manuellen Backup-Lauf.
                      @souly75
                      souly75S Online
                      souly75S Online
                      souly75
                      Wiederherstellen
                      Backup Quelle
                      local
                      Alle Backup-Einstellungen können in der Adapterkonfiguration von Backitup geändert werden.
                      Backitup-Ausführung:
                      11:57:29.728INFOguiBackup gestartet ...
                      [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"03:26","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","nameSuffix":"ioBroker_Backup","deleteBackupAfter":0,"onedrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"M.C554_BL2.0.U.-CuBqxTGlSVTisUh00DkH1DRPW3U6HGwheffou1l0dY6rv16WfM5WUkDi3lgdk7Mj3!yKnXlzSk5kV6bWbzWA7pmUEQENPabdUE*EObflUUsxg0xM*nL8vdQ4oass2k8NLmM2nLuQwOFFiykH8mW9A7VeS9HwBMfhFnQjnB*RDfpbkQKoxwlNiGlKC6fXWCwCWmLajjcmSwi1nF427ni8PP5ss48DyMX7YYdH7!ONEg2TrfcK!C*PUaAqgsuwb7fmmpahqsJOWRgHIc1qo!nY6Eikovl5d*HZ4LFl*IXnSfZQtpy8ZY6LIJlOG4uMAv5O2Kem6g9dClR5JM96szQQTNHqO*63A877cFE2YI92CAgZkb9g7J3ZnVShqG8aWC4uM1iYDU3cbbFDrEbvGsDfZms$","ownDir":false,"dir":"/Dokumente/Wohnung BS/Smarthome/Backup","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/Wohnung BS/Smarthome/Backup","dirMinimal":"/Wohnung BS/Smarthome/Backup/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":5000,"hostName":"ioBroker_Backup","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"ioBroker_Backup","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"ioBroker_Backup","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"ioBroker_Backup","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"ioBroker_Backup","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"ioBroker_Backup","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"ioBroker_Backup","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"ioBroker_Backup","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1727603849643}
                      11:57:33.320DEBUGiobrokerhost.iobrokerpi 2068 states saved
                      11:57:33.627DEBUGiobrokerhost.iobrokerpi 2855 objects saved
                      11:57:35.983DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:36.026DEBUGiobrokerThis backup can only be restored with js-controller version up from 4.1
                      11:57:37.016DEBUGiobrokerdone
                      [DEBUG] [onedrive] start with {"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"M.C554_BL2.0.U.-CuBqxTGlSVTisUh00DkH1DRPW3U6HGwheffou1l0dY6rv16WfM5WUkDi3lgdk7Mj3!yKnXlzSk5kV6bWbzWA7pmUEQENPabdUE*EObflUUsxg0xM*nL8vdQ4oass2k8NLmM2nLuQwOFFiykH8mW9A7VeS9HwBMfhFnQjnB*RDfpbkQKoxwlNiGlKC6fXWCwCWmLajjcmSwi1nF427ni8PP5ss48DyMX7YYdH7!ONEg2TrfcK!C*PUaAqgsuwb7fmmpahqsJOWRgHIc1qo!nY6Eikovl5d*HZ4LFl*IXnSfZQtpy8ZY6LIJlOG4uMAv5O2Kem6g9dClR5JM96szQQTNHqO*63A877cFE2YI92CAgZkb9g7J3ZnVShqG8aWC4uM1iYDU3cbbFDrEbvGsDfZms$","ownDir":false,"dir":"/Dokumente/Wohnung BS/Smarthome/Backup","dirMinimal":"backupDir/iobroker","ignoreErrors":false,"deleteBackupAfter":0}
                      11:57:40.387DEBUGonedriveOnedrive: Copy iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz...
                      11:57:43.768DEBUGonedrive9% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:44.485DEBUGonedrive17% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:45.363DEBUGonedrive26% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:46.238DEBUGonedrive35% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:46.999DEBUGonedrive43% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:47.861DEBUGonedrive52% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:48.582DEBUGonedrive60% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:49.402DEBUGonedrive69% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:50.220DEBUGonedrive78% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:51.139DEBUGonedrive86% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:51.963DEBUGonedrive95% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:53.188DEBUGonedrive100% uploaded from iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz
                      11:57:53.208DEBUGonedrivedone
                      11:57:53.803DEBUGgoogledriveGoogle Drive: Copy iobroker_2024_09_29-11_57_29_ioBroker_Backup_backupiobroker.tar.gz...
                      [DEBUG] [googledrive] start with {"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/Wohnung BS/Smarthome/Backup","dirMinimal":"/Wohnung BS/Smarthome/Backup/iobroker","ignoreErrors":false,"deleteBackupAfter":0}
                      es läuft noch...ich glaube, es halt bei google
                      • J Offline
                        JB72
                        CCU war es bei mir ein Update der Raspberrymatic. Firewall Einstelung angepasst. Geht wieder.
                        Googledrive nutze ich auch wo die Backups hin sollen, das geht nicht mehr wie es aussieht. Platz ist genug da. Googledrive versucht erneut einzurichten
                        klappt scheinbar nicht. Die Backups landen nun alle local.
                        • J JB72
                          @jb72
                          Hier funktioniert ein Backup auf GoogleDrive. Ist erst diese Nacht zum letzten mal erfolgreich gelaufen.
                          • souly75S souly75
                            Wiederherstellen
                            Backup Quelle
                            local
                            /Wohnung BS/
                            Nimm mal das Leerzeichen da raus. Das kann funktionieren, kann aber auch in die Hose gehen. Verwende einen Unterstrich oder gar kein Zeichen.
                              /Wohnung BS/
                              souly75S Online
                              souly75S Online
                              souly75
                              @thomas-braun Danke dir. probiere ich wenn ich den Ersatz Raspberry bekomme. habe meinen vorhin mit falschem Netzteil geschrottet. 🙈💩 hätte vorher schauen sollen.
                              • souly75S souly75
                                MartinPM Online
                                MartinPM Online
                                MartinP
                                Gab es bei Google Drive nicht Probleme mit ioBroker?
                                Irgendein Bann von Google?
                                • MartinPM MartinP
                                  @martinp
                                  Nee, da musste die Anwendung von Google freigegeben werden. Das ist aber wohl geklärt worden.
                                    @martinp
                                    simatecS Online
                                    simatecS Online
                                    simatec
                                    Am besten ml die Autorisierung bei Google erneuern.
                                    • Besuche meine Github Seite
                                    • HowTo Restore ioBroker
                                    • simatecS simatec
                                      JB72
                                      schrieb am zuletzt editiert von JB72
                                      Habe Googledrive mal neu autorisiert. Bringt nichts.
                                      Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
                                      ccu: Error: connect ECONNREFUSED 192.168.100.130:443
                                      Für iOBroker hat er nicht mal angefangen.
                                      Bis zum 14.09.2024 ging beides ohne Probleme.
                                      • J JB72
                                        simatecS Online
                                        simatecS Online
                                        simatec
                                        @jb72 Zeige mal deine Config von Backitup als JSON. Laut Fehlermeldung ist deine CCU nicht erreichbar. Ist in deiner CCU SSL aktiv?
                                        • simatecS simatec
                                          JB72
                                          @simatec
                                          Ja das ist seltsam, ich habe gerade geschaut und statt .30 steht bei BackItup .130 ... warum die 1 dazu gekommen ist, verstehe ich nicht. Im Homematicadapter passt alles.
                                          Habe das korrigiert, aber will dennoch nicht.
