  4. Adapter: Amtron Wallbox
    6.3k
28 Beiträge 10 Kommentatoren 3.6k Aufrufe 9 Beobachtet
  • D dorsen
    @rene_hm Danke für den tollen Adapter! 👍
    Aktuell bekomme ich für meine Charge Control folgende Hinweise im Log:
    info State value to set for "amtronwallbox.0.Charge Control.CableAttached" has to be type "boolean" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.MaxCurrent" has to be type "number" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.ContactcyclesType2" has to be type "number" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.ContactCyclesSchuko" has to be type "number" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.EnergyManagerCurrent" has to be type "number" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.Current" has to be type "number" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.FreeCharging" has to be type "boolean" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.SigCurrent" has to be type "number" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.Transaction" has to be type "number" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.Power" has to be type "number" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.Meter" has to be type "number" but received type "string"
    info State value to set for "amtronwallbox.0.Charge Control.TimeSinceChargingStart" has to be type "number" but received type "string"
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    @dorsen sagte in Adapter: Amtron Wallbox:
    ja, die sind in der nächsten Version behoben.
    Wo hast du die API Dokumentation gefunden?
    Es gibt zwei verschieden API:
    1. die Version für die Wallbox mit App (also die teure Variante der Box)
      Dort wird diese REST Api verwendet. Hier kann man auch den Ladestrom beeinflussen.
    2. die "billige" Version der Wallbox ohne App (die habe leider ich :-( )
      Dort wird diese REST Api verwendet und das ist aktuell auch im Adapter implementiert. Leider kann man hier den Ladestrom nicht beeinflussen. Ich hoffe, das geht dann mit SMA Semp
    • Rene_HMR Offline
      Rene_HMR Offline
      Rene_HM
      Es gibt eine neue Version des Adapters auf github.
      Diese Version unterstützt nun die RestAPI und damit auch die XTRA, Premium usw.
      Derzeit werden folgende Daten gelesen:
      • allgemeine Geräte-Informationen
      • Ladedaten
      • Statistik-Daten
      Im nächsten step kommt dann noch das Schreiben der Daten (z.Bsp. max. Ladestrom).
      Achtung Die Auswahl des Gerätetypes in der Geräte-Liste ist nicht schön lesbar. Einfach ein wenig hoch und runtersrcollen:
      • icebearI Online
        icebearI Online
        icebear
        schrieb am zuletzt editiert von icebear
        Hallo, ich hab jetzt auch mal den Adapter installiert und hab eine kurze Frage.
        Was ist mit API-Schlüssel gemeint? Was muß ich da eintragen?
        WB= Amtron xtra C11 mit App
        EDIT: Hat sich erledigt, hatte mich nur verschrieben beim API-Schlüssel, jetzt gehts
        H 1 Antwort Letzte Antwort
        • icebearI icebear
          helpme
          schrieb am zuletzt editiert von helpme
          @icebear said in Adapter: Amtron Wallbox:
          Hallo zusammen, hab gerade auch den Adapter installiert.
          Was ist mit API Schlüssel gemeint? Ist das die PIN1 von der Wallbox?
          Wenn ich diese eingebe, werden mir allerdings keine Daten im Apdater angezeigt.
          Amtron xtra 11
          icebearI 1 Antwort Letzte Antwort
          • H helpme
            Amtron xtra 11
            icebearI Online
            icebearI Online
            icebear
            @helpme said in Adapter: Amtron Wallbox:
            Ja das ist die PIN
            Name, IP und Typ sind richtig eingetragen?
            • Rene_HMR Rene_HM
              • Ladedaten
              • Statistik-Daten
              jrichl
              @rene_hm
              Hallo, ich habe den Adapter jetzt auch einmal installiert, und er funktioniert auf meiner XTRA soweit auch gut. Ich wollte nur nachfragen ob inzwischen auch das Schreiben von Daten - also der Ladestrom implementiert ist? Einen entsprechenden Datenpunkt dazu kann ich nicht finden.
              Oder ist das ActPwr der entsprechend gesetzt werden muss?
              • G Offline
                goudi
                Hy, ich habe die Amtron Professional mit Firmwarestand 5.22.5
                Nach diesem Link habe ich die REST api aktiviert und kann wie auch auslesen.
                https://www.adminlabs.de/mennekes-amtron-wallbox-api-auslesen/
                Aber ich bekomme leider keine Verbindung im IObroker. Wo ist um alles in der Welt die PIN einzustellen?
                Noch ne Frage zur Anwendung:
                Kann ich über IObroker dann irgendwann die Energiesteuerung (Überschussladen) einstellen?
                Kann ich je nach Authorisierung mit unterschiedlichen RFID Chips zwischen "normalem Laden" und "überschussladen" umschalten?
                Sollte das jetzt schon gehen, würde ich mich freuen wenn mir jemand verrät wie...
                • G goudi
                  icebearI Online
                  icebearI Online
                  icebear
                  @goudi said in Adapter: Amtron Wallbox:
                  Hier:
                  G 1 Antwort Letzte Antwort
                  • icebearI icebear
                    Hier:
                    goudi
                    @icebear Vielen Dank für den Hinweis,
                    im Iobroker ist mir das klar - aber nicht in der BOX - Oberfläche - dort finde ich eine solche Angabe nicht.
                    Ich hoffe, mir kann das jemand auf der anderen Seite auch zeigen.
                    liebe Grüße
                    • icebearI Online
                      icebearI Online
                      icebear
                      Ah, Sorry ich hab grad mal nachgeschaut und gesehen das die Amtron Professional mit einer anderen Oberfläche arbeitet als die Xtra.
                      Ich weiß nicht ob der Adapter mit der Professional funktioniert, da mußte den Adapter Entwickler fragen, am besten im Git-Hub.
                      Du kannst ja versuchen was passiert wenn du in den Einstellungen auf der Box bei 'Rest-Schnittstelle' einstellen kannst, also vielleicht ohne UUID
                      • Rene_HMR Rene_HM
                        Für die Mennekes Amtron Wallbox gibt es nun einen Adapter für ioBroker.
                        Features:
                        • Lesen von System- und Status-Informationen
                        • derzeit wird die REST API unterstützt. Diese bietet nur das Lesen von Daten.
                        • getestet auf einer AMTRON Charge Control 11 C2
                        to do:
                        • Erweiterung auf andere Typen von Amtron
                        • Schreiben von Daten
                        Der Adapter kann über github oder NPM installiert werden.
                        Für feedback, Anregungen und Testergebnisse wäre ich dankbar...
                        Lennerocker
                        ich bin seit gestern Besitzer einer Mennekes Amtron 4you 500, die ich auch in iobroker einbinden will. Bei der Suche nach einem passenden Adapter bin ich auf deinen gestoßen. Installation ohne Probleme. Die Instanz ist aktiviert (verbunden mit Host, Lebenszeichen). Danach aber eine Fehlermeldung: exception in read_rest [Error: connect ETIMEDOUT
                        Kann es sein, dass der Adapter für meine Box nicht funktioniert oder mache ich da einen grundlegenden Fehler?
                        VG Bernard
                        @rene_hm said in Adapter: Amtron Wallbox:
                        Features:
                        to do:
                        Rene_HMR 1 Antwort Letzte Antwort
                        • L Lennerocker
                          VG Bernard
                          Features:
                          to do:
                          Rene_HMR Offline
                          Rene_HMR Offline
                          Rene_HM
                          @lennerocker
                          Die Amtron 4you 500 kenne ich noch gar nicht, deshalb gehe ich erst mal davon aus, dass sie noch nicht unterstützt wird. Wir müssen also erst mal herausfinden, wie man mit dem Teil reden muss.
                          Wenn die Box die RestApi unterstützt, du dieses Interface aktiviert hast, könnte sie als Type "ChargeControl"
                          funktionieren.
                          Du kannst aber auch testweise im browser mal diese URL aufrufen (natürlich mit der IP, wie sie bei dir im Netzwerk eingerichtet ist)
                          http:// DEINE_IP /rest/full_state
                          L 1 Antwort Letzte Antwort
                          • Rene_HMR Rene_HM
                            @lennerocker
                            funktionieren.
                            Lennerocker
                            @rene_hm
                            mit dem Link startet das Webinterface der Box mit der Loginaufforderung. Im Protokollbereich wird für den erfolgreichen Loginversuch die Event-ID REST_API-2 angegeben. Kannst Du damit was anfangen?
                            • J jrichl
                              @rene_hm
                              jokeras
                              @jrichl
                              Ich habe auch die Xtra 11 C2. Im Folder charge habe ich allerdings nur "null" Daten. Im Folder info sind Daten da. Aber eben nicht die Total Energy, die ich gern auslesen würde.
                              Was hast du im Adapter eingestellt? IP + PIN 1 (App PIN)?
                                Trapper
                                Hallo, ich habe eine Amtron Charge Control 11 C2. Ixch habe sie schon drei Jahre und habe sie bisher mit dem Adapter abgefragt. Jetzt musste ich den iobroker neu aufsetzen und habe ein Backup eingespielt. Seitdem fragt der Adapter die Box nicht mehr ab. Eingestellt ist eine Minute als Abfrageintervall. Starte ich den Adapter per Hand neu, werden alle Daten abgerufen. Hat jemand eine Idee dazu? Wie macht der Adapter das wieder automatisch? Danke
                                Klaus
                                • T Trapper
                                  Klaus
                                  @Trapper sagte:
                                  Schau ins Log.
                                    @Trapper sagte:
                                    Schau ins Log.
                                    Trapper
                                    @Thomas-Braun
                                    im Log habe ich diese Zeile gefunden
                                    2026-06-08 23:03:54.003 - info: amtronwallbox.0 (75592) on message {"command":"checkCurrentVersion","message":{"test":"aaa","test2":"bbb"},"from":"system.adapter.admin.0","callback":{"message":{"test":"aaa","test2":"bbb"},"id":60,"ack":false,"time":1780952634002},"_id":32509577}
                                    und die
                                    2026-06-08 22:28:51.512 - info: amtronwallbox.0 (74198) amtronwallbox1: 1 cron job(s) created
                                    andere Einträge beschreiben das Neustarten, also terminate usw. bis start
                                    Alle diese Einträge immer im Zusammenhang mit den manuellen Neustarts, die ich gerade gemacht hatte. Sonst ist im ganzen Tag kein Amtron Eintrag.
                                    Adapter ist gün
                                    Klaus
                                    • T Trapper
                                      @Thomas-Braun
                                      und die
                                      Adapter ist gün
                                      Klaus
                                      @Trapper sagte:
                                      Zeig mehr Kontext, kürz da nichts weg.
                                        @Trapper sagte:
                                        Trapper
                                        schrieb am zuletzt editiert von Trapper
                                        @Thomas-Braun
                                        2026-06-08 22:46:20.911 - info: host.iobroker stopInstance system.adapter.amtronwallbox.0 (force=false, process=true)
                                        2026-06-08 22:46:20.913 - info: amtronwallbox.0 (74198) Got terminate signal TERMINATE_YOURSELF
                                        2026-06-08 22:46:20.915 - info: host.iobroker stopInstance system.adapter.amtronwallbox.0 send kill signal
                                        2026-06-08 22:46:20.914 - info: amtronwallbox.0 (74198) terminating
                                        2026-06-08 22:46:20.915 - info: amtronwallbox.0 (74198) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2026-06-08 22:46:21.415 - info: amtronwallbox.0 (74198) terminating
                                        2026-06-08 22:46:21.545 - info: host.iobroker instance system.adapter.amtronwallbox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2026-06-08 22:46:24.883 - info: host.iobroker instance system.adapter.amtronwallbox.0 in version "1.0.0" started with pid 74880
                                        2026-06-08 22:46:26.151 - info: amtronwallbox.0 (74880) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.amtronwallbox, node: v22.22.3, js-controller: 7.0.7
                                        2026-06-08 22:46:26.215 - info: amtronwallbox.0 (74880) amtronwallbox1: 1 cron job(s) created
                                        Das ist so eine Sequenz
                                        Muss jetzt schlafen, Frühschicht 🙄
                                        Danke erst einmal
                                        • T Trapper
                                          @Thomas-Braun
                                          Danke erst einmal
                                          @Trapper
                                          Das sind doch nur 6 Sekunden. Zeig mal 3-4 Minuten.
                                          Der Adapter scheint aber 'sheduled' zu sein.
