  4. Test Adapter OpenLigaDB
    6.0k
adapteropenligadbtest
716 Beiträge 59 Kommentatoren 222.3k Aufrufe 52 Beobachtet
  • OliverIOO OliverIO
    @einstein2002 sagte in Test Adapter OpenLigaDB:
    du hast eine spitze klammer beim einfügen gelöscht
    und du hast einfach am anfang nur ergänzt.
    ich dachte die zeile davor und danach sei hinweis genug, das du die stelle findest zum einfügen
    let dp_currgameday = "openligadb.0.bl1.2024.currgameday";
    let dp_signal="0_userdata.0.Fussball.bvb";
    async function main(){
        let allmatches = await getStateAsync(dp_allmatches);
        let currgameday = await getStateAsync(dp_currgameday);
        let fav = filterFavGames(JSON.parse(allmatches.val),"",1,currgameday.val,"Borussia Dortmund",false,"");
        fav = fav.filter(el=>checkDateInRange(el.matchDateTime,24));
        setState(dp_signal,!!fav.length);        }
    main();
    function filterFavGames(allmatches, gameday, gamedaycount, currgameday, filter, shortname, abbreviation) {
        if (!Array.isArray(allmatches)) return [];
        gameday = gameday || currgameday || "";
        gameday = parseInt(gameday) || "";
        gamedaycount = parseInt(gamedaycount) || 9999;
        currgameday = parseInt(currgameday);
        abbreviation = abbreviation || "";
        shortname = shortname || false;
        filter = filter || "";
        return allmatches.reduce(function (result, item) {
            let found;
            item.abbreviation = abbreviation;
            if (gameday > 0 && item.group.groupOrderID >= gameday && item.group.groupOrderID < gameday + gamedaycount) found = item;
            if (gameday < 0 && item.group.groupOrderID >= currgameday + gameday && item.group.groupOrderID < currgameday + gameday + gamedaycount) found = item;
            item.filter = filter;
            item.shortname = shortname;
            if (found && (checkHighlite(item.team1.teamName, filter) || checkHighlite(item.team2.teamName, filter))) result.push(item);
            return result;
    function checkHighlite(value, highlights, sep) {
        sep = typeof sep !== "undefined" ? sep : ";";
        const highlight = highlights.split(sep);
        return highlight.reduce(function (acc, cur) {
            if (cur == "") return acc;
            return acc || value.toLowerCase().indexOf(cur.toLowerCase()) >= 0;
        }, false);
    function checkDateInRange(date,hours) {
        let futureDate=new Date(date).getTime();
        return futureDate < Date.now()+hours*60*60*1000 ;
    Einstein2002
    #607
    @oliverio
    Die erste Zeile war weg, hab ich ergänzt, aber ist noch immer ein Bug drinnen.
    let dp_allmatches = "openligadb.0.bl1.2024.allmatches";
        main();
            let found;
            return result;
        }, false);
    Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
    Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
    • E Einstein2002
      @oliverio
          main();
              let found;
              return result;
          }, false);
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      #608
      @einstein2002
      da war noch ein zusätzliches zeichen
          main();
              let found;
              return result;
          }, false);
      Meine Adapter und Widgets
      Links im Profil
        @einstein2002
            main();
                let found;
                return result;
            }, false);
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #609
        @oliverio sagte in Test Adapter OpenLigaDB:
        nochmal, da war immer noch ein fehler drin
            console.log(fav);
        main();
                let found;
                return result;
            }, false);
        Links im Profil
        • E Offline
          Einstein2002
          #610
          Ja danke,
          jetzt läuft das Script, aber leider alle DP noch immer auf True.
          Wenn es nicht sein soll.... dann lassen wir es?
          Ich kann leider nichts dazu tun und ich habe schon sehr deine Zeit in Anspruch genommen.
          Nur wenn Du magst machen wir weiter. Ich kann gut verstehen wenn Du keine Lust mehr hast.
          Hilft ein Neustart von IOB?
          Oder kann ich sonst noch etwas an Infos geben?
          Ich würde ja gerne Helfen, aber das Versteh ich nicht.. Leider.
          • E Einstein2002
            Ja danke,
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #611
            @einstein2002
            also genau in der letzten version ist mein datenpunkt false, da borussia erst
            am 2024-09-13T20:30:00 spielt
            wenn man die stunden auf 27 einstellt, dann geht es wieder auf true
            wie hast du den datenpunkt angelegt?
            gibt es hinweise im iobroker log?
            Links im Profil
            • E Offline
              Einstein2002
              #612
              Ich habe die Datenpunkte jetzt gelöscht und neu angelegt,
              jetzt alle auf False!
              Ich Starte mal alles neu!
              Moment bitte!
              Irgendwas ist hier ganz komisch.
              • E Offline
                Einstein2002
                #613
                So da bin ich wieder,
                habe mal von allem ein paar Fotos gemacht, ist aber nichts faul !
                Der eine Verein spielt heute vielleicht fällt dir ja noch was auf?
                Screenshot 2024-09-12 184609.png Screenshot 2024-09-12 184439.png Screenshot 2024-09-12 184429.png Screenshot 2024-09-12 184409.png Screenshot 2024-09-12 184241.png Screenshot 2024-09-12 184125.png Screenshot 2024-09-12 184105.png Screenshot 2024-09-12 184041.png
                • E Offline
                  Einstein2002
                  schrieb am zuletzt editiert von Einstein2002
                  #614
                  hier ist script besser zu sehen:
                  Dort spielen die gerade
                  • E Einstein2002
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    #615
                    @einstein2002
                    du suchst in der bundesliga 1 nach Mühlberg?
                    es wäre gut wenn wir ein konsistentes beispiel innerhalb einer liga nehmen könnten
                    Links im Profil
                    E 1 Antwort Letzte Antwort
                      @einstein2002
                      Einstein2002
                      #616
                      @oliverio
                      ja habe es gerade bemerkt! Durch das ganze Kopieren habe ich es nicht umgeändert! Mist!!!!
                      • E Offline
                        Einstein2002
                        #617
                        Bleibt aber trotzdem auf False.
                        • E Einstein2002
                          @oliverio
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #618
                          @einstein2002
                          ob der datenpunkt gesetzt wird oder nicht hängt auch von der anzahl der stunden ab.
                          wenn du es größer machst, dann findet das skript das spiel
                          muss halt ein wenig rechnen
                          Links im Profil
                          • E Einstein2002
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            #619
                            @einstein2002
                            hier funktioniert es.
                            gib mal nur
                            mühlberg
                            als suchbegriff ein
                            Links im Profil
                            • E Offline
                              Einstein2002
                              #620
                              nein bleibt sturr auf false.
                              Auch der BVB mit 27 Stunden falsch.
                              Mir gehen die Ideen aus.
                              • E Offline
                                Einstein2002
                                #621
                                kann ich bei der Einrichtung was falsch gemacht haben?? Vorhin ging es ja einmal auf True und dann nicht wieder zurück!
                                Jetzt bleibt der Wert auf False und verändert sich nicht.
                                • E Einstein2002
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  #622
                                  @einstein2002
                                  so dann nochmal komplett ersetzen
                                  ich habe ein paar logausgaben hinzugefügt.
                                  da müsste dann unten so etwas angezeigt werden
                                  datenpunktname für signal noch anpassen
                                  let dp_allmatches = "openligadb.0.KOLWTBJ.2024.allmatches";
                                  let dp_currgameday = "openligadb.0.KOLWTBJ.2024.currgameday";
                                  let dp_signal="0_userdata.0.testFolder.bool";
                                  let suchbegriff = "mühlberg"
                                      let fav = filterFavGames(JSON.parse(allmatches.val),"",1,currgameday.val,suchbegriff,false,"");
                                      console.log("ungefiltert");
                                      console.log(fav);
                                      console.log("gefiltert");
                                      console.log(fav);
                                      console.log("statuswert");
                                      console.log(!!fav.length);
                                  main();
                                          let found;
                                          return result;
                                      }, false);
                                  Links im Profil
                                  E 2 Antworten Letzte Antwort
                                    @einstein2002
                                        console.log(fav);
                                        console.log(fav);
                                    main();
                                            let found;
                                            return result;
                                        }, false);
                                    Einstein2002
                                    #623
                                    @oliverio
                                    Es funktioniert! Einwandfrei.
                                    Ich habe alles noch einmal neu angelegt und eingerichtet.
                                    Jetzt läuft es nach Deinem Update.
                                    Super!! Jetzt kann ich weitermachen.
                                    Gaaaanz lieben Dank für Deine Geduld und Wissen!!!
                                    Grüße Michael
                                    • icebearI Online
                                      icebearI Online
                                      icebear
                                      schrieb am zuletzt editiert von icebear
                                      #624
                                      @OliverIO
                                      Du hattest ja mal diese Script geschrieben:
                                      // hier konfigurieren start
                                      let gameday= getState("openligadb.0.bl1.2023.currgameday").val;
                                      let allmatches = JSON.parse(getState("openligadb.0.bl1.2023.allmatches").val);
                                      let highlight="vfb;bayern"; //suchstrings für die lieblingsvereine, dessen ergebnisse herausgesucht werden sollen. mehrere mit ; getrennt
                                      let dp="0_userdata.0.test.test1"; // name des datenpunkts in dem der ergebnistext landen soll
                                      let separator=" | "; // zeichen, die die einzelnen ergebnisse voneinander trennen
                                      // hier konfigurieren ende
                                      console.log("matches:"+allmatches.length);
                                      console.log("gameday:"+gameday);
                                      console.log("highlight:"+highlight);
                                      let results = filterFavGames(allmatches,gameday,highlight,true);
                                      console.log("result:"+results.join(separator));
                                      setState(dp,results.join(separator));
                                      function filterFavGames(allmatches,gameday,highlight,short=false) {
                                          gameday = parseInt(gameday);
                                          let results =  allmatches.reduce(function(result,item){
                                              var found;
                                              item.short=short;
                                              if (gameday == item.group.groupOrderID) found=item;
                                              if (found && (checkFavorites(item.team1.teamName,highlight) || checkFavorites(item.team2.teamName,highlight)) ) result.push(prepareResultString(item));
                                              return result;
                                          return results;
                                      function getResult(results) {
                                          if (results.length==0) return {};
                                          results = results.reduce(function(acc,cur){
                                              if (cur.resultTypeID>(acc.resultTypeID||0)) acc = cur;
                                              return acc;
                                          return results;
                                      function checkFavorites(value,favorites,sep) {
                                          sep = typeof sep !== 'undefined' ? sep : ";";
                                          var favorite = favorites.split(sep);
                                          return favorite.reduce(function(acc,cur){
                                              if (cur=='') return acc;
                                              return acc || value.toLowerCase().indexOf(cur.toLowerCase())>=0;
                                          },false);
                                      function prepareResultString(item){
                                          var team1name = item.short ? item.team1.shortName : item.team1.teamName;
                                          var team2name = item.short ? item.team2.shortName : item.team2.teamName;
                                          var result = getResult(item.matchResults);
                                          var team1result = result.hasOwnProperty('pointsTeam1') ? result.pointsTeam1 : '-';
                                          var team2result = result.hasOwnProperty('pointsTeam2') ? result.pointsTeam2 : '-';
                                          return team1name + " "+team1result + " : " + team2result + " "+team2name;
                                      Wäre es möglich das Script so abzuändern, das es nur das Vereinswappen anzeigt anstatt den Vereinsnamen?
                                      Und zweite Frage: Was ist den daraus geworden das als Laufschrift anzeigen zulassen, z.B, in VIS-2?
                                      Edit: würde natürlich auch mit dem Favorite Club Widget gehen, wenn man da die Bezeichnung abwählen könnte, so das nur die Wappen da stehen.
                                      Edit2: Warum werden bei den Spielen der 2. Buli die Ergebnisse erst nach Spielende aktualisiert, bei der 1. Buli aber bei jedem Tor?
                                      ( Ich hab das Verhalten am WE festgestellt, weil ich die meisten Tore sowie Torschützen selber bei openliga eingetragen hab)
                                      • OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        #625
                                        @icebear
                                        ich baue da was ins widget ein
                                        kommt mit 1.5.0
                                        option only logo
                                        Links im Profil
                                        • OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          #626
                                          Neue Version 1.5.0
                                          • Hinzufügen eines CSS-Beispiels für das PivotTable-Widget
                                          • Hinzufügen des Befehls sendTo getMatchData um per javascript die spieldaten abzurufen und auf einen zeitbereich einzugrenzen. Details dazu siehe readme
                                          • Entfernen veralteter Widgets
                                          • Hinzufügen der Widget-Option „nur Logo“, um den Teamnamen zu unterdrücken
                                          Links im Profil
                                          icebearI E 2 Antworten Letzte Antwort
