  3. Off Topic
  4. "certifi"-Sicherheitslücke bei iobroker Raspberry Pi
    6.0k
Geplant Angeheftet Gesperrt Verschoben Ungelöst Off Topic
20 Beiträge 3 Kommentatoren 2.1k Aufrufe 2 Beobachtet
  • S sticks
    Hi, nein, das habe ich noch nicht gemacht.
    Hier die Ergebnisse:
    # npm audit report
    @75lb/deep-merge  <=1.1.1
    Severity: high
    @75lb/deep-merge Prototype Pollution vulnerability - https://github.com/advisori        es/GHSA-28mc-g557-92m7
    fix available via `npm audit fix`
    node_modules/@75lb/deep-merge
    axios  0.8.1 - 0.27.2 || 1.0.0 - 1.7.3
    Severity: high
    Axios Cross-Site Request Forgery Vulnerability - https://github.com/advisories/G        HSA-wf5p-g6vw-rhxx
    Server-Side Request Forgery in axios - https://github.com/advisories/GHSA-8hc4-v        h64-cxmj
    fix available via `npm audit fix --force`
    Will install iobroker.unifi@0.6.3, which is a breaking change
    node_modules/@alcalzone/pak/node_modules/axios
    node_modules/axios
    node_modules/iobroker.daswetter/node_modules/axios
    node_modules/iobroker.javascript/node_modules/axios
    node_modules/iobroker.parser/node_modules/axios
    node_modules/iobroker.socketio/node_modules/axios
    node_modules/iobroker.switchbot-hub/node_modules/axios
    node_modules/iobroker.ws/node_modules/axios
    node_modules/node-hue-api/node_modules/axios
    node_modules/node-ical/node_modules/axios
    node_modules/node-unifi/node_modules/axios
      @alcalzone/pak  0.3.0 - 0.10.0
      Depends on vulnerable versions of axios
        @iobroker/js-controller-adapter  *
        Depends on vulnerable versions of @alcalzone/pak
        Depends on vulnerable versions of @iobroker/db-objects-file
        Depends on vulnerable versions of @iobroker/db-objects-jsonl
        Depends on vulnerable versions of @iobroker/db-objects-redis
        Depends on vulnerable versions of @iobroker/db-states-file
        Depends on vulnerable versions of @iobroker/db-states-jsonl
        Depends on vulnerable versions of @iobroker/db-states-redis
        Depends on vulnerable versions of @iobroker/js-controller-common
        Depends on vulnerable versions of @iobroker/js-controller-common-db
        node_modules/@iobroker/js-controller-adapter
          iobroker.js-controller  >=4.0.0-alpha.1-20210830-d9828cd3
          Depends on vulnerable versions of @iobroker/js-controller-adapter
          Depends on vulnerable versions of @iobroker/js-controller-cli
          node_modules/iobroker.js-controller
        @iobroker/js-controller-common-db  >=6.0.1-alpha.0-20240522-6037ce8ae
        node_modules/@iobroker/js-controller-common-db
          @iobroker/db-base  >=6.0.1-alpha.0-20240522-6037ce8ae
          node_modules/@iobroker/db-base
            @iobroker/db-objects-file  >=6.0.1-alpha.0-20240522-6037ce8ae
            Depends on vulnerable versions of @iobroker/db-base
            node_modules/@iobroker/db-objects-file
            @iobroker/db-objects-jsonl  >=6.0.1-alpha.0-20240522-6037ce8ae
            node_modules/@iobroker/db-objects-jsonl
            @iobroker/db-objects-redis  >=6.0.1-alpha.0-20240522-6037ce8ae
            node_modules/@iobroker/db-objects-redis
            @iobroker/db-states-file  >=6.0.1-alpha.0-20240522-6037ce8ae
            node_modules/@iobroker/db-states-file
            @iobroker/db-states-jsonl  >=6.0.1-alpha.0-20240522-6037ce8ae
            node_modules/@iobroker/db-states-jsonl
            @iobroker/db-states-redis  >=6.0.1-alpha.0-20240522-6037ce8ae
            node_modules/@iobroker/db-states-redis
          @iobroker/js-controller-cli  >=6.0.1-alpha.0-20240522-6037ce8ae
          node_modules/@iobroker/js-controller-cli
          @iobroker/js-controller-common  >=6.0.1-alpha.0-20240522-6037ce8ae
      iobroker.switchbot-hub  *
      iobroker.unifi  >=0.6.4
      Depends on vulnerable versions of node-unifi
      node_modules/iobroker.unifi
      node-hue-api  2.0.0-RC1 - 5.0.0-alpha.2
        iobroker.hue  >=0.6.2
        Depends on vulnerable versions of node-hue-api
        node_modules/iobroker.hue
      node-ical  0.15.3 - 0.16.1
        iobroker.jarvis  >=3.0.0
        Depends on vulnerable versions of ip
        Depends on vulnerable versions of node-ical
        Depends on vulnerable versions of semver
        node_modules/iobroker.jarvis
      node-unifi  >=2.3.0
    braces  <3.0.3
    Severity: high
    Uncontrolled resource consumption in braces - https://github.com/advisories/GHSA        -grv7-fg5c-xmjg
    node_modules/braces
    debug  <=2.6.8 || 4.0.0 - 4.3.0
    Severity: high
    debug Inefficient Regular Expression Complexity vulnerability - https://github.c        om/advisories/GHSA-9vvw-cc9w-f27h
    Regular Expression Denial of Service in debug - https://github.com/advisories/GH        SA-gxpj-cx7g-858c
    Depends on vulnerable versions of ms
    Will install iobroker.tr-064@0.0.8, which is a breaking change
    node_modules/engine.io-client/node_modules/debug
    node_modules/iobroker.socketio/node_modules/debug
    node_modules/iobroker.web/node_modules/debug
    node_modules/mdns-discovery/node_modules/debug
    node_modules/socket.io-client/node_modules/debug
    node_modules/socket.io-parser/node_modules/debug
      engine.io  0.7.8 - 0.7.9 || 3.4.0 - 6.5.4
      Depends on vulnerable versions of debug
      Depends on vulnerable versions of ws
      node_modules/iobroker.socketio/node_modules/engine.io
      node_modules/iobroker.web/node_modules/engine.io
        socket.io  2.2.0 - 3.0.4
        Depends on vulnerable versions of engine.io
        Depends on vulnerable versions of socket.io-parser
        node_modules/iobroker.socketio/node_modules/socket.io
        node_modules/iobroker.web/node_modules/socket.io
          iobroker.socketio  3.0.0 - 3.0.13 || 3.1.3 - 3.1.5 || 4.1.0 - 5.0.2 || 6.1        .0 - 6.5.7 || >=6.6.0
          node_modules/iobroker.web/node_modules/iobroker.socketio
            iobroker.web  4.2.1 - 4.3.0 || >=5.2.3
            Depends on vulnerable versions of iobroker.socketio
      engine.io-client  <=3.1.1 || 3.5.0 - 3.5.3 || 4.0.0-alpha.0 - 5.2.0
      Depends on vulnerable versions of parsejson
      node_modules/iobroker.web/node_modules/engine.io-client
        socket.io-client  1.0.0-pre - 2.1.1
        Depends on vulnerable versions of engine.io-client
          iobroker.cloud  <=2.4.6 || 2.8.0 - 3.0.2 || >=4.0.11
          Depends on vulnerable versions of socket.io-client
          node_modules/iobroker.cloud
      mdns-discovery  >=0.0.4
      Depends on vulnerable versions of dns-packet
        iobroker.discovery  *
        Depends on vulnerable versions of mdns-discovery
        Depends on vulnerable versions of node-ssdp
        node_modules/iobroker.discovery
        iobroker.tr-064  >=0.1.1
        Depends on vulnerable versions of tr-O64
        Depends on vulnerable versions of xml2js
        node_modules/iobroker.tr-064
      socket.io-parser  <=3.3.3 || 3.4.0 - 4.0.2
      node_modules/iobroker.socketio/node_modules/socket.io-parser
      node_modules/iobroker.web/node_modules/socket.io-client/node_modules/socket.io        -parser
      node_modules/iobroker.web/node_modules/socket.io-parser
    ip  *
    Severity: high
    ip SSRF improper categorization in isPublic - https://github.com/advisories/GHSA        -2p57-rm9w-gvfp
    Will install iobroker.jarvis@3.1.3, which is a breaking change
    node_modules/ip
      dns-packet  <=5.2.4
      node_modules/dns-packet
      node-ssdp  >=1.0.1
      node_modules/node-ssdp
    lodash  <=4.17.20
    Severity: critical
    Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advi        sories/GHSA-x5rq-j2xg-h7qm
    Prototype Pollution in lodash - https://github.com/advisories/GHSA-4xc9-xhrj-v57        4
    Regular Expression Denial of Service (ReDoS) in lodash - https://github.com/advi        sories/GHSA-29mw-wpgm-hmr9
    Prototype Pollution in lodash - https://github.com/advisories/GHSA-p6mc-m468-83g        w
    Command Injection in lodash - https://github.com/advisories/GHSA-35jh-r3h4-6jhm
    Prototype Pollution in lodash - https://github.com/advisories/GHSA-fvqr-27wr-82f        m
    Prototype Pollution in lodash - https://github.com/advisories/GHSA-jf85-cpcp-j69        5
    Will install iobroker.modbus@0.3.11, which is a breaking change
    node_modules/stampit/node_modules/lodash
      stampit  2.0.1 - 2.1.2
      Depends on vulnerable versions of lodash
        iobroker.modbus  >=0.4.5
        Depends on vulnerable versions of put
        Depends on vulnerable versions of stampit
        Depends on vulnerable versions of stampit-event-bus
        Depends on vulnerable versions of stampit-state-machine
        node_modules/iobroker.modbus
        stampit-event-bus  *
        node_modules/stampit-event-bus
        stampit-state-machine  *
        node_modules/stampit-state-machine
    micromatch  <4.0.8
    Severity: moderate
    Regular Expression Denial of Service (ReDoS) in micromatch - https://github.com/        advisories/GHSA-952p-6rrq-rcjv
    node_modules/micromatch
    ms  <2.0.0
    Severity: moderate
    Vercel ms Inefficient Regular Expression Complexity vulnerability - https://gith        ub.com/advisories/GHSA-w9mr-4mfr-499f
    node_modules/engine.io-client/node_modules/ms
    node_modules/mdns-discovery/node_modules/ms
    node_modules/socket.io-client/node_modules/ms
    node_modules/socket.io-parser/node_modules/ms
    parsejson  *
    Severity: high
    Regular Expression Denial of Service in parsejson - https://github.com/advisorie        s/GHSA-q75g-2496-mxpp
    Will install iobroker.cloud@4.0.10, which is a breaking change
    node_modules/parsejson
    path-to-regexp  <=0.1.9 || 0.2.0 - 7.2.0
    Severity: high
    path-to-regexp outputs backtracking regular expressions - https://github.com/adv        isories/GHSA-9wv6-86v2-598j
    Will install iobroker.simple-api@2.7.2, which is a breaking change
    node_modules/nise/node_modules/path-to-regexp
      express  4.0.0-rc1 - 4.19.2 || 5.0.0-alpha.1 - 5.0.0-beta.3
      Depends on vulnerable versions of path-to-regexp
      node_modules/express
      nise  *
      node_modules/nise
        sinon  >=3.0.0
        Depends on vulnerable versions of nise
        node_modules/sinon
          @iobroker/testing  *
          Depends on vulnerable versions of sinon
          Depends on vulnerable versions of sinon-chai
          node_modules/@iobroker/testing
            iobroker.simple-api  >=2.8.0
            Depends on vulnerable versions of @iobroker/testing
            node_modules/iobroker.simple-api
          sinon-chai  >=3.0.0
          node_modules/sinon-chai
    put  *
    Sensitive Data Exposure in put - https://github.com/advisories/GHSA-v6gv-fg46-h8        9j
    node_modules/put
    request  *
    Severity: moderate
    Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7        -x288-28g6
    Depends on vulnerable versions of tough-cookie
    Will install iobroker.backitup@0.2.7, which is a breaking change
    node_modules/request
      dropbox-v2-api  *
      Depends on vulnerable versions of request
      node_modules/dropbox-v2-api
        iobroker.backitup  >=0.3.0
        Depends on vulnerable versions of dropbox-v2-api
        node_modules/iobroker.backitup
      iobroker.javascript  *
      iobroker.vw-connect  *
      node_modules/iobroker.vw-connect
      tr-O64  *
      node_modules/tr-O64
    semver  7.0.0 - 7.5.1
    Severity: high
    semver vulnerable to Regular Expression Denial of Service - https://github.com/a        dvisories/GHSA-c2qf-rxjj-qqgw
    node_modules/iobroker.jarvis/node_modules/semver
    tough-cookie  <4.1.3
    Severity: moderate
    tough-cookie Prototype Pollution vulnerability - https://github.com/advisories/G        HSA-72xf-g2v4-qvf3
    node_modules/tough-cookie
    ws  2.1.0 - 5.2.3 || 7.0.0 - 7.5.9 || 8.0.0 - 8.17.0
    Severity: high
    ws affected by a DoS when handling a request with many HTTP headers - https://gi        thub.com/advisories/GHSA-3h5v-q93c-6h6q
    node_modules/engine.io/node_modules/ws
    node_modules/iobroker.web/node_modules/ws
    node_modules/socket.io-adapter/node_modules/ws
    node_modules/websocket-stream/node_modules/ws
      socket.io-adapter  2.5.2 - 2.5.4
      websocket-stream  4.0.0 - 5.1.2 || >=5.4.0
        iobroker.mqtt  >=2.1.0
        Depends on vulnerable versions of websocket-stream
        node_modules/iobroker.mqtt
    xml2js  <0.5.0
    Severity: moderate
    xml2js is vulnerable to prototype pollution - https://github.com/advisories/GHSA        -776f-qx25-q3cc
    node_modules/xml2js
      iobroker.onkyo  >=2.0.0
      node_modules/iobroker.onkyo
    68 vulnerabilities (4 low, 28 moderate, 34 high, 2 critical)
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues possible (including breaking changes), run:
    Some issues need review, and may require choosing
    a different dependency.
    @sticks
    Deine Herumgehampel als root halte ich im Übrigen für das größere Sicherheitsproblem...
    Sorry, der Report fängt mit einer Raute an...
    Ich wollte auch eigentlich nur deutlich machen, das jedes System offene 'Issues' hat. Die kannst du eh nicht alle angehen. Regelmäßige Systempflege sollte reichen. Um die konkrete Klassifizierung der Dinger kümmert sich im Fall von Debian halt das 'Debian Security Team'.
    Die können hoffentlich die konkrete Schwere des Problems für die einzelnen Releases bewerten.
      @sticks
      sticks
      schrieb am zuletzt editiert von sticks
      Da mir Tenable im "normalen" SSH-Context die ganze Linux-Befehlshistorie mit tausenden Prüfbefehlen auf Schwachstellen voll haut,arbeite ich gerne im Root Context da ich dort dann meine eigene Befehlshistorie sehe. Das das von manchen Linux-Profis nicht gern gesehen wird, ist mir klar.
      (PS: Stimmt, in dem Fall oben habe ich sogar im normalen User-Context gearbeitet. ;-) )
      Ich selbst habe alle meine Serversysteme (viele Raspberrys, 2x ESXi Server, paar Windows-Server, NAS-Systeme) in der kostenlosen Lösung von Tenable Nessus. Ich patche die meisten Linux-Systeme daher mindestens einmal die Woche, da immer einige Schwachstellen vorhanden sind, wie du schon sagst. Pro System sind oft 50-80 Schwachstellen völlig normal. - Wenn eine Schwachstelle aber als "hochkritisch" eingestuft wird, wie in diesem Fall geschehen, stecke ich meist einige Energie rein das abzustellen. - Manchmal ist dies nicht möglich, im Fall jetzt hätte es ja sein können das dies mit einem bestimmten Befehl oder Deinstallation eines bestimmten iobroker Adapters gelöst gewesen wäre. - Dies ist aber nicht der Fall, von daher muss ich das einfach so hinnehmen. Was beruhigt, das die Schwachstellenbewertung "kritisch" hier ja eher unzutreffend zu sein scheint.
      Demnach hat mein Raspberry mit iobroker derzeoit 92x harmlose Schwachstelllen, 5x medium Schwachstellen und eben diese 1x certifi die als kritisch eingestuft wird.
      • S sticks
        @sticks sagte in "certifi"-Sicherheitslücke bei iobroker Raspberry Pi:
        ??? Die Historie ist doch als user viel besser zu sehen. Inkl. eines Wechsels in die root-Rolle.
        Lass den Quark mit der root shell einfach bleiben.
        Das Verhalten ist gefährlicher als deine ganzen 'Issues', die du da panisch versuchst zu stopfen.
          sticks
          Panisch ist hier keiner. Ich gehe besonnen an die Sache heran:
          Nach Bekanntwerden der vermeintlich kritischen Lücke versucht man sich bestmöglich in die unbekannte Materie einzulesen. Habe mich eingearbeitet, durch das Github gelesen und dort stand ja mehr oder weniger: Wenn du genau dieses Problem/Sicherheitslücke hast dann mach mit pip ein Update und die Sache ist gelöst, denn der Maintainer con certifi hat sich schon drum gekümmert. - Ja, in diesem Fall war die Installation von pip unnötig, aber das konnte ich der Github Dokumentation zu certifi erstmal nicht entnehmen, stand da doch man kann die Lücke durch ein pip install certifi stopfen. - Als ich danach aber den Hinweis bekam, dass das ganze "externally-managed-environment" ist, war natürlich auch für mich klar, dass ich hiermit keinen Erfolg werden habe. Insofern, wenn das ganze "externally-managed-environment" ist, dann frage ich doch mal die Jungs im iobroker Forum, vielleicht ist das Problem dort ja schon bekannt. Hier habe ich nun die Hinweise auf Debian bekommen, damit ist die Sache für mich auch OK, habe ich doch jetzt die Gewissheit das ich hier nichts übersehen / fremdverursacht habe.
          Kommentare zu Herumgebastel, Quark und Panik halte ich hingegen für unangebracht für einen professionellen Austausch.
          • S sticks
            Da keiner von uns beiden offenbar Profi ist passt das wieder.
            • S sticks
              wo soll's denn sonst herkommen?
                sticks
                Woanders her. - Gibt ja viele Wege wie Dateien/Pakete in einem Linux-System landen können, evtl. eben auch durch iobroker selbst.
                In meinem Fall habe ich z.B. zwei unterschiedliche Raspberry Pis, beide haben ein topaktuelles Debian Bookworm als Betriebssystem. Der Raspberry mit iobroker-Installation meldet mir die certifi-Sicherheitslücke, der Raspberry auf dem nur FHEM läuft hat die Lücke (noch) nicht gemeldet. - Von daher habe ich natürlich im iobroker-Bereich mit Problematiken gerechnet.
                Edit: Der FHEM-PI hat die Lücke aber scheinbar auch, macht ja auch Sinn, das ist nur noch nicht über Tenable Nessus gemeldet:
                fhempi:~ $ apt policy python3-certifi
                python3-certifi:
                  Installiert:           2022.9.24-1
                  Installationskandidat: 2022.9.24-1
                  Versionstabelle:
                 *** 2022.9.24-1 500
                        500 http://deb.debian.org/debian bookworm/main arm64 Packages
                        500 http://deb.debian.org/debian bookworm/main armhf Packages
                • S sticks
                  python3-certifi:
                    Versionstabelle:
                   *** 2022.9.24-1 500
                  aber dann würde iobroker python ja auch über apt aus debian Quellen installieren.
                  iobroker selbst ist javascript/nodejs code
                  auch EDIT:
                  Das ergibt auch Sinn, weil meines Wissens Python mit dem OS mitkommt.
                    auch EDIT:
                    @homoran sagte in "certifi"-Sicherheitslücke bei iobroker Raspberry Pi:
                    Python selber schon. Die meisten (bzw. sehr viele) python-Pakete kann man direkt aus den Debian-Repos angeln. Pakete heißen dann immer 'python3-$PYTHONMODUL'. Dann sind die Versionen auch von Debian Security getrackt.
                    Nebenher kann man Pakete aber auch per python pip installieren. Dann läuft es natürlich an apt/dpkg ungesehen vorbei.
                    Und da dieses 'wilde installieren von irgendwas von irgendwoher' bei den Distributionen für Kopfschmerzen gesorgt hat, weil dann andere Dinge dadurch kaputt gingen hat man das ganze per 'externally managed system' ausgebremst. So einfach kann man nun nicht mehr per pip global python-Pakete nachinstallieren.
                    • S sticks
                      python3-certifi:
                        Versionstabelle:
                       *** 2022.9.24-1 500
                      und wo ist dann noch der Bezug zu ioBroker?
                      Hat sich das jetzt in Luft aufgelöst, und der Thread kann nach offTopic?
                        sticks
                        Ja genau. Der Bezug zu iobroker ließ sich insofern klären, dass es keinen gibt :-)
                        • S sticks
                          ich würde sogar doweit gehen zu behaupten, dass diese Lücke nur User betreffen könnte, die dieses Modul in Verbindung mit eigenen python Programmen verwenden.
                          Allerdi gs fehlt mir für eine gesicherte Aussage die notwendige Expertise
                            Weil es mir gerade beim Update meines siduction-Systems aufgefallen ist:
                            [2024-09-11] Accepted python-certifi 2024.8.30-1 (source) into unstable (Sebastien Delafond)
                            https://tracker.debian.org/pkg/python-certifi
