  4. JavaScript
  5. ERLEDIGT: Jimp.read is not a function
20 Beiträge 3 Kommentatoren 3.0k Aufrufe 2 Beobachtet
  • OliverIOO OliverIO
    @uwe72 sagte in TypeError: Jimp.read is not a function:
    script.js.common.Automatisierungen.KI_Detection.TestNG: [Module: null prototype] { BlendMode: { SRC_OVER: 'srcOver', DST_OVER: 'dstOver', MULTIPLY: 'multiply', ADD: 'add', SCREEN: 'screen', OVERLAY: 'overlay', DARKEN: 'darken', LIGHTEN: 'lighten', HARD_LIGHT: 'hardLight', DIFFERENCE: 'difference', EXCLUSION: 'exclusion' }, BmpCompression: { '0': 'NONE', '1': 'BI_RLE8', '2': 'BI_RLE4', '3': 'BI_BIT_FIELDS', '6': 'BI_ALPHA_BIT_FIELDS', NONE: 0, BI_RLE8: 1, BI_RLE4: 2, BI_BIT_FIELDS: 3, BI_ALPHA_BIT_FIELDS: 6 }, HorizontalAlign: { '1': 'LEFT', '2': 'CENTER', '4': 'RIGHT', LEFT: 1, CENTER: 2, RIGHT: 4 }, Jimp: [class Jimp], PNGColorType: { '0': 'GRAYSCALE', '2': 'COLOR', '4': 'GRAYSCALE_ALPHA', '6': 'COLOR_ALPHA', GRAYSCALE: 0, COLOR: 2, GRAYSCALE_ALPHA: 4, COLOR_ALPHA: 6 }, PNGFilterType: { '0': 'NONE', '1': 'SUB', '2': 'UP', '3': 'AVERAGE', '4': 'PATH', AUTO: -1, '-1': 'AUTO', NONE: 0, SUB: 1, UP: 2, AVERAGE: 3, PATH: 4 }, ResizeStrategy: { NEAREST_NEIGHBOR: 'nearestNeighbor', BILINEAR: 'bilinearInterpolation', BICUBIC: 'bicubicInterpolation', HERMITE: 'hermiteInterpolation', BEZIER: 'bezierInterpolation' }, VerticalAlign: { '8': 'TOP', '16': 'MIDDLE', '32': 'BOTTOM', TOP: 8, MIDDLE: 16, BOTTOM: 32 }, colorDiff: [Function: colorDiff], compareHashes: [Function: compareHashes], cssColorToHex: [Function: cssColorToHex], defaultFormats: [ [Function: bmp], [Function: msBmp], [Function: gif], [Function: jpeg], [Function: png], [Function: tiff] ], defaultPlugins: [ { blit: [Function: blit] }, { blur: [Function: blur], gaussian: [Function: gaussian] }, { circle: [Function: circle] }, { normalize: [Function: normalize], invert: [Function: invert], brightness: [Function: brightness], contrast: [Function: contrast], posterize: [Function: posterize], greyscale: [Function: greyscale], opacity: [Function: opacity], sepia: [Function: sepia], fade: [Function: fade], convolution: [Function: convolution], opaque: [Function: opaque], pixelate: [Function: pixelate], convolute: [Function: convolute], color: [Function: color] }, { contain: [Function: contain] }, { cover: [Function: cover] }, { crop: [Function: crop], autocrop: [Function: autocrop] }, { displace: [Function: displace] }, { dither: [Function: dither] }, { fisheye: [Function: fisheye] }, { flip: [Function: flip] }, { pHash: [Function: pHash], hash: [Function: hash], distanceFromHash: [Function: distanceFromHash] }, { mask: [Function: mask] }, { print: [Function: print] }, { resize: [Function: resize], scale: [Function: scale], scaleToFit: [Function: scaleToFit] }, { rotate: [Function: rotate] }, { threshold: [Function: threshold] }, { quantize: [Function: quantize] } ], diff: [Function: diff], distance: [Function: distance], intToRGBA: [Function: intToRGBA], limit255: [Function: limit255], loadFont: [AsyncFunction: loadFont], rgbaToInt: [Function: rgbaToInt] }
    ja objekt existiert, nur gibt es kein read, aber ein weiteres Jimp.
    probier mal
    Jimp.Jimp.read(
    Ich konnte es leider nicht probieren, da er bei mir die bibliothek in den javascript einstellungen zwar geladen hat, aber mit require jimp er das modul nicht findet.
    ohne doku ist schwierig
    evtl könnte auch ein
    var Jimp = require('jimp').default;
    helfen
    U Offline
    U Offline
    uwe72
    @oliverio Danke dir. Hat leider beides nicht funktioniert. Bei "Jimp.Jimp.read(" kommt kein Fehler mehr, funktioniert aber auch nicht. Die Variante mit dem "default" wirft einen Fehler.
    • U uwe72
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @uwe72
      Hier eine Alternative mit Doku
      https://www.npmjs.com/package/sharp
      Meine Adapter und Widgets
      Links im Profil
      U 1 Antwort Letzte Antwort
      • F Online
        F Online
        fastfoot
        so geht es teilweise, die auskommentierten Funktionen werfen einen Fehler
        const Jimp = require('jimp').Jimp;
        // let Jimp=Jimp1.Jimp;
        async function jmpRead() {
            let a=await Jimp.read('/opt/iobroker/Astro.jpg')
                log(a)
                    a
                        // .resize(256, 256)
                        //  .quality(60)
                         .greyscale()
                        .write('/opt/iobroker/Astro2.jpg');
        jmpRead();
        • F fastfoot
                  log(a)
                      a
                          //  .quality(60)
                           .greyscale()
          jmpRead();
          U Offline
          U Offline
          uwe72
          @fastfoot said in TypeError: Jimp.read is not a function:
                  log(a)
                      a
                          //  .quality(60)
                           .greyscale()
          jmpRead();
          Danke dir! Ja, funktioniert. Muss schauen, dass ich alles wieder hinbekomme.
            @uwe72
            U Offline
            U Offline
            uwe72
            @oliverio said in TypeError: Jimp.read is not a function:
            @uwe72
            Danke dir! Werde schauen, ob ich es vollends so hinkriege. Falls nicht, versuche ich es mit sharp. Danke und Grüße!
            F 1 Antwort Letzte Antwort
            • U uwe72
              @uwe72
              F Online
              F Online
              fastfoot
              schrieb am zuletzt editiert von fastfoot
              @uwe72 Also wenn es nur die anfangs geposteten Funktionen sind die du brauchst dann geht das so:
              const Jimp = require("jimp").Jimp;
              Jimp.read("./Astro.jpg").then(image => {
                // console.log(image);
                  .resize({ h: 256, w: 256 })
                  .greyscale()
                  .write("./Astro2.jpg", { quality: 60 });
              Da ändert sich ständig was, bestimmt kommt auch bald ne Doku. Das hier habe ich dem Source entnommen
              • F fastfoot
                    .greyscale()
                U Offline
                U Offline
                uwe72
                @fastfoot Funktioniert prima!
                Ich benötige "scan" für das Zeichnen von Linien und "print" für das Schreiben von Text. Das kriege ich auf Anhieb nicht hin. Ich versuche nun auch mal den Sourcecode zu finden.
                • U uwe72
                  F Online
                  F Online
                  fastfoot
                  @uwe72
                  das geht so:
                  const { Jimp, loadFont } = require("jimp");
                  const { SANS_32_BLACK } = require("jimp/fonts");
                  async function test() {
                    const image = await new Jimp({ width: 192, height: 128, color: "00ff00ff" });
                    const font = await loadFont(SANS_32_BLACK);
                      .print({ font, x: 0, y: 10, text: "Hello World" })
                      .scan(0, 64, image.bitmap.width, image.bitmap.height, (x, y, idx) => {
                        if (x < y) {
                          image.bitmap.data[idx + 0] = 255;
                          image.bitmap.data[idx + 1] = 255;
                          image.bitmap.data[idx + 2] = 255;
                          image.bitmap.data[idx + 3] = 255;
                      .write("./Astro2.png", { quality: 60 });
                  await test();
                  • F fastfoot
                    @uwe72
                    das geht so:
                          if (x < y) {
                    await test();
                    U Offline
                    U Offline
                    uwe72
                    schrieb am zuletzt editiert von uwe72
                    @fastfoot DANKESCHÖN!!!
                    javascript.1
                    2024-09-09 10:29:54.883	error	at processImmediate (node:internal/timers:485:21)
                    javascript.1
                    2024-09-09 10:29:54.883	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1732:17)
                    javascript.1
                    2024-09-09 10:29:54.883	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2320:17
                    javascript.1
                    2024-09-09 10:29:54.883	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2222:37)
                    javascript.1
                    2024-09-09 10:29:54.883	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1954:21)
                    javascript.1
                    2024-09-09 10:29:54.883	error	at new Script (node:vm:116:7)
                    javascript.1
                    2024-09-09 10:29:54.883	error	SyntaxError: Cannot use import statement outside a module
                    javascript.1
                    2024-09-09 10:29:54.883	error	^^^^^^
                    javascript.1
                    2024-09-09 10:29:54.883	error	import { Jimp, loadFont } from "jimp";
                    javascript.1
                    2024-09-09 10:29:54.883	error	script.js.common.Automatisierungen.KI_Detection.TEST_JIMP compile failed: at script.js.common.Automatisierungen.KI_Detection.TEST_JIMP:38
                    Ich kriege es leider noch nicht wirklich hin. Im IoBroker-Script funktioniert dies denke ich nicht mit dem import. Brauche man da das request?
                    So fit bin ich leider nicht. Danke dir für deine Zeit. Bin dafür sehr dankbar!
                    Hintergrund: Ich sende einem AI-Server alle x ms ein Bild von der IP-Kamera. Der AI-Server sendet dann die Info zurück, ob ein Gesicht erkannt wurde und falls ja, welches. Es kommen auch die Koordinaten zurück vom Gesicht. Auf dem Originalbild zeichne ich dann eben über "Jimp" ein Rechteck um das Gesicht und schreibe noch den erkannten Namen dazu und die Prozentzahl. Dieses Bild verarbeite ich dann weiter....Versand nach Telegram....
                    Zum Beispiel:
                    • U uwe72
                      javascript.1
                      javascript.1
                      javascript.1
                      javascript.1
                      javascript.1
                      javascript.1
                      javascript.1
                      javascript.1
                      javascript.1
                      javascript.1
                      Zum Beispiel:
                      F Online
                      F Online
                      fastfoot
                      @uwe72 sorry, das kommt davon wenn man nicht unter iobroker entwickelt. Nimm statt import request, iobroker unterstützt ersteres wohl noch nicht
                      EDIT: Ich habe das Beispiel entsprechend angepasst
                      • F fastfoot
                        U Offline
                        U Offline
                        uwe72
                        @fastfoot DANKE dir!!
                        Habe dein Beispiel mal angepasst, so dass ich auf einem bestehendem Bild aufsetze und zeichne auf die Schnelle mal einen Text und eine Grafik (scan).
                        Beim scan ist mir noch nicht ganz klar, wie das konfiguriert wird um ein Rechteck zu erhalten. Auch ist mir nicht klar was die 4 Zeilen machen (z.B. image.bitmap.data[idx + 0] = 255;)
                        const { SANS_32_WHITE } = require("jimp/fonts");
                        const baseDirectory = "/opt/iobroker/";
                        var filename = baseDirectory + "/detection.jpg";
                        var filenameBoundingBox = baseDirectory + "_detection_plate_boundingbox_UWE.jpg";
                          const font = await loadFont(SANS_32_WHITE);
                          Jimp.read(filename).then(image => {
                              .print({ font, x: 200, y: 50, text: "DANKESCHÖN!" })
                              .scan(/*x*/ 200, /*y*/ 100, /*width*/ 1000, /*height*/ 3300, (x, y, idx) => {
                                if (x < y) {
                              .write(filenameBoundingBox, { quality: 100 });
                        await test();
                        • U uwe72
                                  if (x < y) {
                          await test();
                          F Online
                          F Online
                          fastfoot
                          @uwe72 ich hatte da auf dich gehofft, zeig doch mal den bisherigen code. Mit meinem sehr beschränkten Wissen stelle ich mir das schwer vor, wenn auch nicht unmöglich. Was ich bräuchte wären die Koordinaten des Gesichts und was du dann in der scan() Funktion stehen hattest. Das Beispiel hab ich aus der Doku(ältere Versionen haben die noch)
                          U 2 Antworten Letzte Antwort
                          • F fastfoot
                            U Offline
                            U Offline
                            uwe72
                            @fastfoot Nein, brauchst Du dir nicht anschauen, wenn Du hier auch nicht fit bist. Ich werde mir das in Ruhe anschauen im Laufe der Woche. Das kriege ich schon vollends hin. Wichtigste war dein Input, dass es prinzipiell funktioniert, war eine große Hilfe für mich, danke hierfür!
                            • F fastfoot
                              U Offline
                              U Offline
                              uwe72
                              @fastfoot Habs nun umgebaut. DANKE nochmals für deinen Input!
                              const fillCrimson = makeIteratorThatFillsWithColor(0xED143DFF);
                              async function appendBoundingBox(response, inputFileName, outputFileName) {
                                Jimp.read(inputFileName).then(image => {
                                  var imageJimp = image.print({ font, x: 50, y: 50, text: "Nummernschilderkennung" });
                                      response.data.predictions.forEach(function (prediction) {
                                          if (prediction.confidence > (minimumConfidencePercent/100)) {
                                              // Prozentzahl als Text:
                                              imageJimp.scan(prediction.x_min, prediction.y_max+5, 75, 40, makeIteratorThatFillsWithColor(0x00000040));
                                              imageJimp.print({ font, x: prediction.x_min+7, y: prediction.y_max+8, text: (prediction.confidence*100).toFixed(0)+"%" });
                                              // Waagrecht; x1, y1, Länge Strich, Strichbreite (obere waagreche Linie):
                                              imageJimp.scan(prediction.x_min, prediction.y_min, (prediction.x_max-prediction.x_min), 3, fillCrimson);
                                              // Waagrecht; x1, y1, Länge Strich, Strichbreite (untere waagreche Linie):
                                              imageJimp.scan(prediction.x_min, prediction.y_max, (prediction.x_max-prediction.x_min), 3, fillCrimson);
                                              // Senkrecht; x1, y1, Strichbreite, Länge Strich (linke sekrechte Linie)
                                              imageJimp.scan(prediction.x_min, prediction.y_min, 3, (prediction.y_max-prediction.y_min), fillCrimson);
                                              // Senkrecht; x1, y1, Strichbreite, Länge Strich (rechte sekrechte Linie)
                                              imageJimp.scan(prediction.x_max, prediction.y_min, 3, (prediction.y_max-prediction.y_min), fillCrimson);
                                      log("Output: " + outputFileName);
                                    imageJimp.write(outputFileName, { quality: 100 });
                              function makeIteratorThatFillsWithColor(color) {
                                  return function (x, y, offset) {
                                      this.bitmap.data.writeUInt32BE(color, offset, true);
