  4. Puppeteer Adapter
    6.5k
Puppeteer Adapter
76 Beiträge 8 Kommentatoren 13.1k Aufrufe 7 Beobachtet
  • OliverIOO OliverIO
    @jensen
    ok, das hängt direkt an der installation von iobroker und kommt wahrscheinlich von einer deiner
    manuellen versuche puppeteer zu installieren. daher dann auch manuell deinstallieren
    was passiert wenn du jetzt
    npm uninstall puppeteer
    eingibst?
    bitte dann auch nochmal
    npm ls puppeteer ausführen
    JensenJ Offline
    JensenJ Offline
    Jensen
    schrieb am zuletzt editiert von Jensen
    @oliverio
    c:\ioBroker>npm uninstall puppeteer
    npm error code EBUSY
    npm error syscall rename
    npm error path c:\ioBroker\node_modules\iobroker.admin
    npm error dest c:\ioBroker\node_modules\.iobroker.admin-FjHuUvU7
    npm error errno -4082
    npm error EBUSY: resource busy or locked, rename 'c:\ioBroker\node_modules\iobroker.admin' -> 'c:\ioBroker\node_modules\.iobroker.admin-FjHuUvU7'
    npm error A complete log of this run can be found in: C:\Users\IpsJensen\AppData\Local\npm-cache\_logs\2024-09-05T11_35_36_427Z-debug-0.log
    c:\ioBroker>npm ls puppeteer
    iobroker.inst@3.0.0 c:\ioBroker
    `-- iobroker.puppeteer@0.3.0
      `-- puppeteer@22.15.0
    JensenJ 1 Antwort Letzte Antwort
    • JensenJ Jensen
      @oliverio
      JensenJ Offline
      JensenJ Offline
      Jensen
      @OliverIO
      mit angehaltenem ioBroker sieht's so aus
      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
      npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
      npm warn deprecated npmlog@5.0.1: This package is no longer supported.
      npm warn deprecated npmlog@6.0.2: This package is no longer supported.
      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
      npm warn deprecated har-validator@5.1.5: this library is no longer supported
      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
      npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
      npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
      npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
      npm warn deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
      npm warn deprecated gauge@4.0.4: This package is no longer supported.
      npm warn deprecated gauge@3.0.2: This package is no longer supported.
      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm warn deprecated sinon@15.2.0: 16.1.1
      changed 1360 packages, and audited 1362 packages in 1m
      170 packages are looking for funding
        run `npm fund` for details
      57 vulnerabilities (6 low, 30 moderate, 20 high, 1 critical)
      To address issues that do not require attention, run:
        npm audit fix
      To address all issues possible (including breaking changes), run:
        npm audit fix --force
      Some issues need review, and may require choosing
      a different dependency.
      Run `npm audit` for details.
      • JensenJ Jensen
        @OliverIO
          npm audit fix
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @jensen
        ah ok,
        hab selbst was übersehen.
        siehst du im iobroker noch den adapter pupeteer?
        dann dort über die oberfläche den adapter entfernen.
        Meine Adapter und Widgets
        Links im Profil
          @jensen
          ah ok,
          JensenJ Offline
          JensenJ Offline
          Jensen
          @oliverio
          direkt aus der Adapterseite aufgerufen
          $ iobroker del puppeteer --custom --debug
          Delete adapter "puppeteer"
          host.IpsServerWB Deleting 1 object(s).
          You might have to delete it yourself!
          Process exited with code 0
          dann auf der Console
          • JensenJ Jensen
            @oliverio
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @jensen
            ok, dann mal mit gewalt
            du gehst direkt in das hauptverzeichnis von iobroker
            auf linux /opt/iobroker
            auf windows weiß ich nicht genau, aber in diesem verzeichnis muss
            sich eine datei package.json befinden.
            in diesem verzeichnis führst du den folgenden befehl aus
            npm uninstall iobroker.puppeteer
            und dann wieder den ls befehl und im iobroker in der adapter seite schauen ob der adapter weg ist.
            wenn das auch nicht richtig funktioniert, dann gebe ich die installation als verloren auf
            und du musst neu installieren. wahrscheinlich hat sich da was verrannt, was mit den normalen mitteln nicht auflösbar ist.
            evtl weiß dann noch jemand anderes was.
            Links im Profil
              @jensen
              JensenJ Offline
              JensenJ Offline
              Jensen
              @oliverio
              c:\ioBroker>npm uninstall iobroker.puppeteer
              added 1 package, removed 64 packages, changed 1296 packages, and audited 1299 packages in 1m
              165 packages are looking for funding
                npm audit fix
              • JensenJ Jensen
                @oliverio
                  npm audit fix
                JensenJ Offline
                JensenJ Offline
                Jensen
                @OliverIO
                das ist jetzt mal neu
                `-- (empty)
                • JensenJ Jensen
                  @OliverIO
                  `-- (empty)
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @jensen
                  und ist er in der adapter sicht des iobrokers auch weg?
                  wenn ja, kannst ihn wieder über die adaptersicht des iobrokers wieder installieren
                  und schauen ob alles funktioniert
                  und bitte nur noch die iobroker befehle und die iobroker oberfläche verwenden.
                  npm ist für dich tabu, ausser jemand der sich auskennt sagt es ausdrücklich.
                  dann aber auch immer nur mit vorhergehendem backup
                  Links im Profil
                    @jensen
                    JensenJ Offline
                    JensenJ Offline
                    Jensen
                    @oliverio
                    In der Adapteransicht wird er auch nicht mehr als installiert gelistet, sieht alles sehr gut aus.
                    Ich lasse es bis morgen ruhen, damit heute Nacht erst mal das Backup durchläuft.
                    Dann ein neuer Versuch, ohne npm :-)
                    Danke für die Hilfe und die Geduld mit mir.
                    • JensenJ Jensen
                      @oliverio
                      JensenJ Offline
                      JensenJ Offline
                      Jensen
                      Wie versprochen werde ich jetzt alle Schritte dokumentieren, die ich unternehme um den Puppeteer Adapter wieder ins System zu bringen.
                      Adapter installieren
                      Eigentlich denke ich, man sollte über die Adapterseite jeden Adapter bei laufendem System installieren können. Der Versuch, den Puppeteer Adapter zu installieren gibt mir folgende Rückmeldung:
                      $ iobroker add puppeteer auto --host IpsServerWB --debug
                      NPM version: 10.8.2
                      Installing iobroker.puppeteer@0.3.0... (System call)
                      npm error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-09-06T05_46_44_817Z-debug-0.log
                      host.IpsServerWB Cannot install iobroker.puppeteer@0.3.0: 4294963214
                      ERROR: Process exited with code 25
                      Der komplette Log umfasst über 8000 Zeilen, ich hänge ihn hier als Datei ran.
                      Wenn ich mir die Log Datei anschaue, dann verstehe ich meistens nur Bahnhof, aber irgendwie beschleicht mich das Gefühl, an meinem System ist immer noch was im Argen.
                      • JensenJ Jensen
                        NPM version: 10.8.2
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @jensen
                        hm, der konkrete fehler ist der
                        7083 verbose stack Error: EBUSY: resource busy or locked, rename 'C:\ioBroker\node_modules\iobroker.admin' -> 'C:\ioBroker\node_modules\.iobroker.admin-GBn0lhRQ'
                        da wird versucht das verzeichnis umzubenennen. jetzt bin ich nicht firm im detailprozess der adapter installation. umgehen kannst du das, indem du den iobroker stoppst, prüfst ob iobroker wirklich beendet ist und dann von der kommandozeile aus installierst.
                        ich hab mal noch das fix kommando hinzugefügt, das prüft deine installation ob die richtigen berechtigungen überall gesetzt sind.
                        durch deine wilden npm befehle hast du sicherlich auch mal mit sudo gearbeitet, weil linux wegen berechtigung gemeckert hat?
                        iobroker stop
                        iobroker fix
                        iobroker isrun
                        iobroker install iobroker.puppeteer
                        iobroker start
                        der adapter ist dann installiert, eine neue instanz musst du dann noch selbst von der adapterseite aus erzeugen
                        Links im Profil
                          @jensen
                          iobroker stop
                          iobroker fix
                          iobroker isrun
                          iobroker start
                          JensenJ Offline
                          JensenJ Offline
                          Jensen
                          @oliverio
                          Ist ein Windows System, nix sudo.
                          Die Variante mit Anhalten des Systems habe ich ja bereits mehrmals gemacht.
                          Ich würde gerne erst mal klären, warum sich der Adapter nicht mit laufendem System installieren läßt, ich denke, das ist nicht normal.
                          Es sei denn, jemand kann erklären, warum das so ist.
                          Ein iob fix kann ich aber morgen mal machen, mal sehen, was da so passiert.
                          Und falls jemand erklären kann, ob die vielen Meldungen im npm Log so ihre Richtigkeit haben, das wäre auch eine prima Sache.
                          • JensenJ Jensen
                            @oliverio
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @jensen
                            Im npm log wird detailliert berichtet was
                            Alles bei der Installation gemacht wird.
                            Von daher erstmal alles ok, bis auf die eine Fehlermeldung
                            Das ebusy sagt das ein Prozess aktuell in diesem Verzeichnis läuft und daher das umbenennen der Verzeichnisses nicht funktioniert.
                            Daher iobroker stoppen.
                            Das sollte normalerweise schon funktionieren.
                            Deine Installation hat wahrscheinlich schon einen hau.
                            Besser wäre es schon alles komplett neu zu installieren.
                            Die Abfolge ist um aktuell weiterzukommen
                            Links im Profil
                              @jensen
                              JensenJ Offline
                              JensenJ Offline
                              Jensen
                              @oliverio
                              Ok, dann mal mit stoppen
                              c:\ioBroker>npm install iobroker.puppeteer
                              npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (github.com/visionmedia/debug/issues/797)
                              npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See v8.dev/blog/math-random for details.
                              npm warn deprecated request@2.88.2: request has been deprecated, see github.com/request/request/issues/3142
                              added 64 packages, removed 2 packages, changed 1295 packages, and audited 1361 packages in 3m
                                npm audit fix
                              jetzt sieht das wieder so aus
                              Bei dem Versuch, über die Adapterseite eine Instanz zu erzeugen, kommt dann das
                              node:internal/modules/cjs/loader:1225 const err = new Error(message); ^ Error: Cannot find module 'C:\ioBroker\node_modules\deep-clone\index.js' at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15) at Module._load (node:internal/modules/cjs/loader:1051:27) at cjsLoader (node:internal/modules/esm/translators:346:17) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:286:7) at ModuleJob.run (node:internal/modules/esm/module_job:234:25) at async ModuleLoader.import (node:internal/modules/esm/loader:473:24) { code: 'MODULE_NOT_FOUND', requireStack: [] } Node.js v20.17.0
                              ERROR: Process exited with code 1
                              Ich glaube, das ist alles zwecklos.
                              Eine Neuinstallation muß her.
                              JensenJ OliverIOO 2 Antworten Letzte Antwort
                              • JensenJ Jensen
                                @oliverio
                                  npm audit fix
                                JensenJ Offline
                                JensenJ Offline
                                Jensen
                                Ich habe also den Puppeteer Adapter über die Console wieder deinstalliert.
                                Bei der Vorbereitung einer Neuinstallation wollte ich alle Scripte exportieren, da kommt dann sowas:
                                • JensenJ Jensen
                                  JensenJ Offline
                                  JensenJ Offline
                                  Jensen
                                  iob fix
                                  c:\ioBroker>iob fix
                                  Need to install the following packages:
                                  @iobroker/fix@6.0.1
                                  Ok to proceed? (y) y
                                  Windows installation starting... (fixing = true)
                                  NPM version: 10.8.3
                                  No path given, using c:\ioBroker\iobroker-data
                                  Compressing c:\ioBroker\iobroker-data\states.jsonl
                                  Cannot compress states.jsonl: Error: Failed to lock DB file "c:\ioBroker\iobroker-data\states.jsonl"!
                                      at JsonlDB.open (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@alcalzone\jsonl-db\build\lib\db.js:185:19)
                                      at async compressDB (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:37:9)
                                      at async main (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:78:17)
                                  Compressing c:\ioBroker\iobroker-data\objects.jsonl
                                  Cannot compress objects.jsonl: Error: Failed to lock DB file "c:\ioBroker\iobroker-data\objects.jsonl"!
                                      at async main (C:\Users\IpsJensen\AppData\Local\npm-cache\_npx\36bee06d4228a674\node_modules\@iobroker\jsonltool\index.js:93:17)
                                  No relevant JSONL files found to compress, skip
                                  NPM version: 10.8.3
                                  Write "iobroker start" to start the ioBroker
                                  npm install dotenv@^16.4.5 --force --loglevel error --production --save --prefix "c:/ioBroker"
                                  npm error A complete log of this run can be found in: C:\Users\IpsJensen\AppData\Local\npm-cache\_logs\2024-09-07T06_21_00_662Z-debug-0.log
                                  Error when installing dotenv Library: Error: Command failed: npm install dotenv@^16.4.5 --force --loglevel error --production --save --prefix "c:/ioBroker"
                                  sieht auch nicht berauschend aus
                                  • JensenJ Jensen
                                    iob fix
                                    c:\ioBroker>iob fix
                                    @iobroker/fix@6.0.1
                                    NPM version: 10.8.3
                                    NPM version: 10.8.3
                                    JensenJ Offline
                                    JensenJ Offline
                                    Jensen
                                    Und was mir noch auffällt, ich habe kein admin.0, sondern nur ein admin.1
                                    Das ist doch auch nicht normal, oder?
                                    • JensenJ Jensen
                                      JensenJ Offline
                                      JensenJ Offline
                                      Jensen
                                      Nach Einrichten der Istanz admin.0 und Löschen von admin.1 kann ich die Skripte jetzt wieder problemlos exportieren.
                                      • JensenJ Jensen
                                        @oliverio
                                          npm audit fix
                                        OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        @jensen
                                        Schon seltsam.
                                        Er meckert das ein bestimmtes Modul nicht gefunden worden ist.
                                        Neuinstallation macht Sinn. Es sind Zuviel kleinklein Probleme
                                        Und ob das dann später noch stabil läuft ist auch keine Garantie.
                                        Was für Hardware und Festplatte hast du im Einsatz?
                                        Links im Profil
                                          @jensen
                                          Schon seltsam.
                                          JensenJ Offline
                                          JensenJ Offline
                                          Jensen
                                          @oliverio
                                          NUC i5 mit SSD
