  4. ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!
92 Beiträge 5 Kommentatoren 19.3k Aufrufe 4 Beobachtet
    @iotechnik konntest du denn inzwischen die Langfassung von iob diag bekommen?
    I Offline
    I Offline
    ioTechnik
    #82
    Die Langfassung hatte ich, konnte sie aber nicht hochladen. Ich probiers gleich noch mal.
    • I Offline
      I Offline
      ioTechnik
      #83
      Hier iob diag
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: raspibroker
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7+
            Architecture: arm
      Model           : Raspberry Pi 3 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       13:10:30 up  9:10,  1 user,  load average: 0.61, 0.42, 0.28
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      ~ Under-voltage detected
      ~ Arm frequency capped
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** Time and Time Zones ***
                     Local time: Wed 2024-08-21 13:10:30 CEST
                 Universal time: Wed 2024-08-21 11:10:30 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      js-controller is not running
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:           972M         43M        305M        3.0M        624M        862M
      Swap:           99M        4.0M         95M
      Total:         1.1G         47M        400M
      Active iob-Instances:   0
                972 M total memory
                 43 M used memory
                292 M active memory
                273 M inactive memory
                305 M free memory
                199 M buffer memory
                424 M swap cache
                 99 M total swap
                  4 M used swap
                 95 M free swap
      top - 13:10:30 up  9:10,  1 user,  load average: 0.61, 0.42, 0.28
      Tasks: 116 total,   1 running, 115 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  3.9 us,  2.6 sy,  0.0 ni, 93.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :    972.8 total,    305.2 free,     43.5 used,    624.1 buff/cache
      MiB Swap:    100.0 total,     95.7 free,      4.3 used.    862.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4      7.1G  5.7G  1.1G  85% /
      devtmpfs       devtmpfs  454M     0  454M   0% /dev
      tmpfs          tmpfs     487M     0  487M   0% /dev/shm
      tmpfs          tmpfs     487M  6.6M  480M   2% /run
      tmpfs          tmpfs     487M     0  487M   0% /sys/fs/cgroup
      /dev/sda1      vfat      247M   49M  198M  20% /boot
      tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
      [Wed Aug 21 04:00:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=32e689ec-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Aug 21 04:00:34 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Wed Aug 21 04:00:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Wed Aug 21 04:00:36 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET                                SOURCE     FSTYPE     OPTIONS
      /                                     /dev/sda2  ext4       rw,noatime
      |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=464768k,nr_inodes=116192,mode=755
      | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
      | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
      |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
      | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
      | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
      | | |-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
      | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
      | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
      | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
      | | `-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
      | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
      | |-/sys/kernel/config                configfs   configfs   rw,relatime
      | `-/sys/fs/fuse/connections          fusectl    fusectl    rw,relatime
      |-/proc                               proc       proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=26,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
      | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
      | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=99608k,mode=700,uid=1000,gid=1000
      `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      300M    /var/
      94M     /var/lib
      85M     /var/cache
      78M     /var/cache/apt
      69M     /var/lib/apt/lists
      Archived and active journals take up 6.0M in the file system.
      /opt/iobroker/backups:
      1.3M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      908M    /opt/iobroker/iobroker-data/
      658M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      9.9M    /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
      9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v10.24.0
      /usr/bin/node           v10.24.0
      npm:                    N/A
      npx:                    N/A
      corepack:       N/A
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 10.24.0~dfsg-1~deb10u3
        Candidate: 10.24.0~dfsg-1~deb10u3
        Version table:
       *** 10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      (node:6853) UnhandledPromiseRejectionWarning: Error: Not supported
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
          at startup (internal/bootstrap/node.js:283:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
      (node:6853) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
      (node:6853) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      Core adapters versions
      (node:6863) UnhandledPromiseRejectionWarning: Error: Not supported
      (node:6863) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
      (node:6863) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      js-controller:
      (node:6872) UnhandledPromiseRejectionWarning: Error: Not supported
      (node:6872) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
      (node:6872) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      admin:
      (node:6881) UnhandledPromiseRejectionWarning: Error: Not supported
      (node:6881) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
      (node:6881) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      javascript:
      nodejs modules from github:     0
      Adapter State
      ioBroker-Repositories
      (node:6898) UnhandledPromiseRejectionWarning: Error: Not supported
      (node:6898) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
      (node:6898) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      Installed ioBroker-Instances
      (node:6907) UnhandledPromiseRejectionWarning: Error: Not supported
      (node:6907) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
      (node:6907) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      Objects and States
      Objects:        0
      States:         0
      W: GPG error: https://deb.nodesource.com/node_18.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
      E: The repository 'https://deb.nodesource.com/node_18.x nodistro InRelease' is not signed.
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14266      678/sshd
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17461      971/exim4
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14268      678/sshd
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17462      971/exim4
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14851      625/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13707      385/avahi-daemon: r
      udp        0      0 0.0.0.0:60864           0.0.0.0:*                           108        13709      385/avahi-daemon: r
      udp6       0      0 :::45260                :::*                                108        13710      385/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13708      385/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          16690      625/dhcpcd
      2024-08-20 09:12:38.956  - info: host.raspibroker stopInstance timeout system.adapter.admin.1 killing pid 800
      2024-08-20 09:12:38.959  - info: host.raspibroker stopInstance timeout system.adapter.javascript.0 killing pid 807
      2024-08-20 09:12:38.960  - info: host.raspibroker stopInstance timeout system.adapter.backitup.0 killing pid 853
      2024-08-20 09:12:38.961  - info: host.raspibroker stopInstance timeout system.adapter.tr-064.0 killing pid 859
      2024-08-20 09:12:38.961  - info: host.raspibroker stopInstance timeout system.adapter.ems-esp.0 killing pid 900
      2024-08-20 09:12:38.962  - info: host.raspibroker stopInstance timeout system.adapter.hm-rega.0 killing pid 932
      2024-08-20 09:12:38.964  - info: host.raspibroker stopInstance timeout system.adapter.web.0 killing pid 1138
      2024-08-20 09:12:39.162  - info: host.raspibroker instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:39.164  - info: host.raspibroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:39.166  - info: host.raspibroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:40.639  - info: host.raspibroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:40.641  - info: host.raspibroker instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:40.642  - info: host.raspibroker instance system.adapter.pollenflug.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:40.686  - info: host.raspibroker instance system.adapter.admin.1 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:40.864  - info: host.raspibroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:40.866  - info: host.raspibroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:40.867  - info: host.raspibroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:40.868  - info: host.raspibroker instance system.adapter.ems-esp.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:40.869  - warn: host.raspibroker instance system.adapter.hm-rega.0 terminated due to SIGKILL
      2024-08-20 09:12:40.870  - info: host.raspibroker instance system.adapter.hm-rega.0 terminated with code null ()
      2024-08-20 09:12:40.871  - warn: host.raspibroker instance system.adapter.web.0 terminated due to SIGKILL
      2024-08-20 09:12:40.871  - info: host.raspibroker instance system.adapter.web.0 terminated with code null ()
      2024-08-20 09:12:41.153  - info: host.raspibroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
      2024-08-20 09:12:41.155  - info: host.raspibroker All instances are stopped.
      2024-08-20 09:12:41.396  - info: host.raspibroker terminated
      iob diag has finished.
      • I ioTechnik
        Hier iob diag
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           99M        4.0M         95M
                  972 M total memory
                   43 M used memory
                  292 M active memory
                  305 M free memory
                  199 M buffer memory
                  424 M swap cache
                   99 M total swap
                    4 M used swap
                   95 M free swap
        *** FILESYSTEM ***
        /var:
        300M    /var/
        94M     /var/lib
        85M     /var/cache
        78M     /var/cache/apt
        USB-Devices by-id:
        npm:                    N/A
        npx:                    N/A
        corepack:       N/A
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        js-controller:
        admin:
        javascript:
        Adapter State
        Objects and States
        Objects:        0
        States:         0
        Pending Updates: 0
        #84
        @iotechnik sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!:
        nach wie vor!!
        und mit
        wird das auch nichts.
        Hattest du nicht iob fix gefahren?
        und danach iob nodejs-update?
        kann natürlich am vergammelten
        liegen.
        Da das ganz aus xem Support raus ist, könnte es sein, dasss da gar kein update mehr möglich ist.
        • I ioTechnik
          Hier iob diag
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : 32 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M        4.0M         95M
                    972 M total memory
                     43 M used memory
                    292 M active memory
                    305 M free memory
                    199 M buffer memory
                    424 M swap cache
                     99 M total swap
                      4 M used swap
                     95 M free swap
          *** FILESYSTEM ***
          /var:
          300M    /var/
          94M     /var/lib
          85M     /var/cache
          78M     /var/cache/apt
          USB-Devices by-id:
          npm:                    N/A
          npx:                    N/A
          corepack:       N/A
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          js-controller:
          admin:
          javascript:
          Adapter State
          Objects and States
          Objects:        0
          States:         0
          Pending Updates: 0
          #85
          @iotechnik
          Noch ein paar Hinweise:
          Setz das neue System als reines 64Bit-System auf.
          Spendier der Kiste ein gescheites, richtiges Netzteil. Die jetzige Spannungsversorgung ist zu schlapp.
          Mit
          kannst du auch gar nichts mehr reißen. Mit der dfsg-Version schon gerade nicht.
          Versuch das mal mit der Betaversion von hier zu beackern. :
          Aufruf des Skriptes dann per
          ./iob_node_update 18
          • I Offline
            I Offline
            ioTechnik
            #86
            Hallo Thomas
            habe das System neu aufgesetzt (64bit). Das mit dem Netzteil ist auch OK - es lag am USB-Kabel - habe jetzt direkt verkabelt.
            Bin dabei die Adapter zu aktualisieren - leider lassen sich einige nicht über die Adapteroberfläche aktualisieren.
            Es scheitert momentan beim web-Adapter
            $ iobroker upgrade web@6.2.5
            Update web from @6.2.3 to @6.2.5
            NPM version: 10.8.2
            Installing iobroker.web@6.2.5... (System call)
            Could not handle ENOTEMPTY, because no deletable files were foundnpm error code ENOTEMPTYnpm error syscall renamenpm error path /opt/iobroker/node_modules/aggregate-errornpm error dest /opt/iobroker/node_modules/.aggregate-error-rAKexGiKnpm error errno -39npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/aggregate-error' -> '/opt/iobroker/node_modules/.aggregate-error-rAKexGiK'npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-23T14_35_28_536Z-debug-0.log
            host.raspberrypi Cannot install iobroker.web@6.2.5: 217
            ERROR: Process exited with code 25
            ebenso beim backitup-Adapter. Habe diesen schon neu installiert - ohne Erfolg
            • I ioTechnik
              Hallo Thomas
              NPM version: 10.8.2
              #87
              @iotechnik
              iob stop
              iob fix
              iob start
              try again!
              • I Offline
                I Offline
                ioTechnik
                #88
                Hallo Thomas, Hallo Homoran
                nach der Neuinstallation und dem Durchlauf der angebotenen Updates läuft der admin nicht mehr.
                Ich komme nicht mehr auf meinen Pi3. Verschiedene Hinweise aus dem Forum brachten auch keinen Erfolg.
                Hier iob diag
                *** iob diag is starting up, please wait ***
                The state system.host.raspberrypi.versions.nodeNewestNext was not found!
                The state system.host.raspberrypi.versions.npmNewestNext was not found!
                The state system.host.raspberrypi.versions.nodeCurrent was not found!
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                 Static hostname: raspberrypi
                       Icon name: computer
                          Kernel: Linux 6.6.31+rpt-rpi-v8
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 09:04:41 up  2:42,  3 users,  load average: 2.06, 1.49, 1.10
                CPU threads: 4
                Current issues:
                               Local time: Mon 2024-08-26 09:04:41 CEST
                           Universal time: Mon 2024-08-26 07:04:41 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            951M        747M         93M         28K        167M        204M
                Swap:           209M        206M        3.2M
                Total:          1.2G        953M         96M
                Active iob-Instances:   11
                          907 M total memory
                          712 M used memory
                          378 M active memory
                          351 M inactive memory
                           88 M free memory
                           18 M buffer memory
                          140 M swap cache
                          199 M total swap
                          196 M used swap
                            3 M free swap
                top - 09:04:42 up  2:42,  3 users,  load average: 2.05, 1.49, 1.11
                Tasks: 167 total,   1 running, 166 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 11.1 us, 22.2 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :    907.3 total,     88.9 free,    712.3 used,    159.8 buff/cache
                MiB Swap:    200.0 total,      3.1 free,    196.9 used.    195.0 avail Mem
                *** FILESYSTEM ***
                udev           devtmpfs  318M     0  318M   0% /dev
                tmpfs          tmpfs      91M  1.1M   90M   2% /run
                /dev/sda2      ext4      6.8G  5.1G  1.4G  79% /
                tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                [Mon Aug 26 06:22:24 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c80d8e3a-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Mon Aug 26 06:22:31 2024] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                [Mon Aug 26 06:22:34 2024] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2867
                |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=325396k,nr_inodes=81349,mode=755
                | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=92912k,mode=755
                | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=92908k,nr_inodes=23227,mode=700,uid=1000,gid=1000
                `-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                1.1G    /var/
                356M    /var/log
                355M    /var/log/journal/6dc99cd23c35495a81d44ed7c87f33e1
                349M    /var/cache
                Archived and active journals take up 354.9M in the file system.
                25M     /opt/iobroker/backups/
                457M    /opt/iobroker/iobroker-data/
                431M    /opt/iobroker/iobroker-data/files
                142M    /opt/iobroker/iobroker-data/files/vis-2
                81M     /opt/iobroker/iobroker-data/files/vis-2/static
                80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                19M     /opt/iobroker/iobroker-data/objects.jsonl
                19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                USB-Devices by-id:
                /usr/bin/nodejs         v20.17.0
                /usr/bin/node           v20.17.0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.29.3
                nodejs:
                  Installed: 20.17.0-1nodesource1
                  Candidate: 20.17.0-1nodesource1
                  Version table:
                 *** 20.17.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                     18.19.0+dfsg-6~deb12u2 500
                        500 http://deb.debian.org/debian bookworm/main arm64 Packages
                     18.19.0+dfsg-6~deb12u1 500
                        500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                js-controller:  6.0.9
                admin:          7.0.23
                javascript:     7.8.0
                Adapter State
                  system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  system.adapter.awattar.0                : awattar               : raspberrypi                              - disabled
                  system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                + system.adapter.ems-esp.0                : ems-esp               : raspberrypi                              -  enabled
                  system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                  system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                  system.adapter.material.0               : material              : raspberrypi                              - disabled
                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                  system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
                  system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                  system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                  system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                  system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
                + instance is alive
                Active repo(s): stable
                Upgrade policy: none
                Used repository: stable
                Adapter    "admin"        : 7.0.23   , installed 7.0.23
                Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                Adapter    "backitup"     : 3.0.19   , installed 3.0.19
                Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
                Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
                Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                Adapter    "javascript"   : 8.7.6    , installed 7.8.0  [Updatable]
                Controller "js-controller": 6.0.9    , installed 6.0.9
                Adapter    "material"     : 1.3.1    , installed 1.3.1
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                Adapter    "web"          : 6.2.5    , installed 6.2.5
                Objects and States
                Objects:        6117
                States:         5526
                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       5841       969/io.mqtt.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6367       619/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6362       619/iobroker.js-con
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          826        647/sshd: /usr/sbin
                tcp        0      0 192.168.2.16:2001       0.0.0.0:*               LISTEN      1001       6665       962/io.hm-rpc.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8706       1152/io.web.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          828        647/sshd: /usr/sbin
                udp        0      0 0.0.0.0:52009           0.0.0.0:*                           104        712        498/avahi-daemon: r
                udp        0      0 192.168.2.16:5353       0.0.0.0:*                           1001       6016       984/io.tr-064.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        710        498/avahi-daemon: r
                udp6       0      0 :::57842                :::*                                104        713        498/avahi-daemon: r
                udp6       0      0 fe80::aa28:f59d:ff7:546 :::*                                0          6357       565/NetworkManager
                udp6       0      0 :::5353                 :::*                                104        711        498/avahi-daemon: r
                2024-08-26 07:24:53.890  - info: weatherunderground.0 (2135) Terminated (NO_ERROR): Without reason
                2024-08-26 07:24:54.485  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2135 terminated with code 0 (NO_ERROR)
                2024-08-26 07:30:48.064  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 2156
                2024-08-26 07:30:53.116  - info: dwd.0 (2156) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                2024-08-26 07:30:54.762  - info: dwd.0 (2156) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-08-26 07:30:55.325  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 2156 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-08-26 07:59:50.814  - info: host.raspberrypi "system.adapter.weatherunderground.0" disabled
                2024-08-26 07:59:50.823  - info: host.raspberrypi stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
                2024-08-26 07:59:50.825  - info: host.raspberrypi stopInstance canceled schedule system.adapter.weatherunderground.0
                2024-08-26 08:00:48.124  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 2347
                2024-08-26 08:00:53.234  - info: dwd.0 (2347) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                2024-08-26 08:00:54.878  - info: dwd.0 (2347) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-08-26 08:00:55.449  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 2347 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-08-26 08:24:54.735  - info: web.0 (1152) ==> Connected system.user.admin from ::ffff:192.168.2.21
                2024-08-26 08:25:08.352  - info: web.0 (1152) <== Disconnect system.user.admin from ::ffff:192.168.2.21 vis.0
                2024-08-26 08:25:08.595  - info: web.0 (1152) ==> Connected system.user.admin from ::ffff:192.168.2.21
                2024-08-26 08:30:48.086  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 2498
                2024-08-26 08:30:54.414  - info: dwd.0 (2498) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                2024-08-26 08:30:56.287  - info: dwd.0 (2498) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-08-26 08:30:56.927  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 2498 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-08-26 09:00:48.156  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 3776
                2024-08-26 09:00:56.331  - info: dwd.0 (3776) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                2024-08-26 09:00:58.375  - info: dwd.0 (3776) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-08-26 09:00:58.947  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 3776 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                • I ioTechnik
                  Hier iob diag
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                            907 M total memory
                            712 M used memory
                            378 M active memory
                             88 M free memory
                             18 M buffer memory
                            140 M swap cache
                            199 M total swap
                            196 M used swap
                              3 M free swap
                  *** FILESYSTEM ***
                  /var:
                  1.1G    /var/
                  356M    /var/log
                  349M    /var/cache
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          7.0.23
                  javascript:     7.8.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        6117
                  States:         5526
                  Pending Updates: 0
                  #89
                  @iotechnik
                  Hat zwar mit dem ursprünglichen Thema nix mehr zu tun, aber starte den Admin mal.
                  iob start admin.1
                  Edit: Wenn ich mir die jetzige Auslastung anschaue und was da alles an Adaptern noch gar nicht gestartet ist würde ich sagen: Raspi3 mehr als ausgereizt.
                  I 1 Antwort Letzte Antwort
                    @iotechnik
                    iob start admin.1
                    I Offline
                    I Offline
                    ioTechnik
                    #90
                    Danke Thomas und Homoran. Habe mir sowas schon gedacht. Die Adapter werden wie bei Windows-updates o.ä. immer größer und der RAM reicht dann nicht mehr.
                    Ich habe hier einen alten Laptop 64-bit mit Linux vorbereitet und werde versuchen mein System dahin umzusiedeln.
                    • I ioTechnik
                      #91
                      1GB ist halt auch nicht so wirklich üppig.
                      Mittlerweile würde ich mindestens 4GB veranschlagen, wenn da eine durchschnittliche Installation laufen soll.
                      • I ioTechnik
                        #92
                        aber >20Adapter hat noch nie mit 1GB RAM funktioniert. auch nicht vor 5-10 Jahren
                        Seit Beginn wurde schon immer empfohlen mind. 2GB RAM zu verwenden (noch mehr war damals fast nicht zu bekommen)
