  4. Beim Update von Adaptern stürzt der ioBroker ab
89 Beiträge 7 Kommentatoren 17.4k Aufrufe 4 Beobachtet
    @flommaster
    npm i https://github.com/iobroker-community-adapters/ioBroker.ical
    Könnte sein, das da recht viel Output bei rumkommt.
    flommaster
    @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
    @flommaster
    flo@ioBrokerdebian:/opt/iobroker$ npm i https://github.com/iobroker-community-adapters/ioBroker.ical
    [sudo] Passwort für flo:
    npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
    npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
    npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
    npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
    npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
    npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
    npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
    npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
    npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
    npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
    npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
    npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
    npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
    npm warn deprecated uid-number@0.0.6: This package is no longer supported.
    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
    npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm warn deprecated npmlog@6.0.2: This package is no longer supported.
    npm warn deprecated har-validator@5.1.5: this library is no longer supported
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
    npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
    npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
    npm warn deprecated
    npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
    npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
    npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
    npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
    npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
    npm warn deprecated gauge@3.0.2: This package is no longer supported.
    npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm warn deprecated gauge@4.0.4: This package is no longer supported.
    npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
    npm error code 127
    npm error path /opt/iobroker/node_modules/zlib
    npm error command failed
    npm error command sh -c node-waf clean || true; node-waf configure build
    npm error sh: 1: node-waf: not found
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T21_40_39_197Z-debug-0.log
    • F flommaster
      @flommaster
      npm warn deprecated
      npm error code 127
      @flommaster
      Ist jetzt nur noch gerate von mir.
      npm uninstall iobroker.mihome-vacuum
      Ich glaube der war in dem anderen Fall der Verursacher. Bzw. eine der Dependencies.
      F 1 Antwort Letzte Antwort
      • Thomas BraunT Online
        @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
        npm ls zlib
          @flommaster
          flommaster
          Das hat leider nicht geklappt.
          Bevor die Deinstallation startet habe ich wieder ein Haufen an Hinweisen erhalten...
          flo@ioBrokerdebian:/opt/iobroker$ npm uninstall iobroker.mihome-vacuum
          npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
          npm warn deprecated
          npm error code 1
          npm error path /opt/iobroker/node_modules/node-libcurl
          npm error command sh -c node-pre-gyp install --fallback-to-build
          npm error Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v115' (1)
          npm error node-pre-gyp info it worked if it ends with ok
          npm error node-pre-gyp info using node-pre-gyp@1.0.10
          npm error node-pre-gyp info using node@20.16.0 | linux | x64
          npm error node-pre-gyp info check checked for "/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" (not found)
          npm error node-pre-gyp http GET https://github.com/JCMais/node-libcurl/releases/download/v3.0.0/node_libcurl-v3.0.0-node-v115-linux-x64-glibc.tar.gz
          npm error node-pre-gyp ERR! install response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v3.0.0/node_libcurl-v3.0.0-node-v115-linux-x64-glibc.tar.gz
          npm error node-pre-gyp WARN Pre-built binaries not installable for node-libcurl@3.0.0 and node@20.16.0 (node-v115 ABI, glibc) (falling back to source compile with node-gyp)
          npm error node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v3.0.0/node_libcurl-v3.0.0-node-v115-linux-x64-glibc.tar.gz
          npm error gyp info it worked if it ends with ok
          npm error gyp info using node-gyp@10.1.0
          npm error gyp info using node@20.16.0 | linux | x64
          npm error gyp info ok
          npm error gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
          npm error gyp http GET https://nodejs.org/download/release/v20.16.0/node-v20.16.0-headers.tar.gz
          npm error gyp http 200 https://nodejs.org/download/release/v20.16.0/node-v20.16.0-headers.tar.gz
          npm error gyp http GET https://nodejs.org/download/release/v20.16.0/SHASUMS256.txt
          npm error gyp http 200 https://nodejs.org/download/release/v20.16.0/SHASUMS256.txt
          npm error gyp info spawn /usr/bin/python3
          npm error gyp info spawn args [
          npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
          npm error gyp info spawn args 'binding.gyp',
          npm error gyp info spawn args '-f',
          npm error gyp info spawn args 'make',
          npm error gyp info spawn args '-I',
          npm error gyp info spawn args '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',
          npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
          npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.16.0/include/node/common.gypi',
          npm error gyp info spawn args '-Dlibrary=shared_library',
          npm error gyp info spawn args '-Dvisibility=default',
          npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.16.0',
          npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
          npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.16.0/<(target_arch)/node.lib',
          npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',
          npm error gyp info spawn args '-Dnode_engine=v8',
          npm error gyp info spawn args '--depth=.',
          npm error gyp info spawn args '--no-parallel',
          npm error gyp info spawn args '--generator-output',
          npm error gyp info spawn args 'build',
          npm error gyp info spawn args '-Goutput_dir=.'
          npm error gyp info spawn args ]
          npm error Could not run curl-config, please make sure libcurl dev package is installed.
          npm error Output: /bin/sh: 1: curl-config: not found
          npm error
          npm error gyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/scripts/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
          npm error gyp ERR! configure error
          npm error gyp ERR! stack Error: `gyp` failed with exit code: 1
          npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:297:18)
          npm error gyp ERR! stack at ChildProcess.emit (node:events:519:28)
          npm error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)
          npm error gyp ERR! System Linux 6.1.0-23-amd64
          npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v115"
          npm error gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
          npm error gyp ERR! node -v v20.16.0
          npm error gyp ERR! node-gyp -v v10.1.0
          npm error gyp ERR! not ok
          npm error node-pre-gyp ERR! build error
          npm error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v115' (1)
          npm error node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-libcurl/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
          npm error node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
          npm error node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1105:16)
          npm error node-pre-gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:305:5)
          npm error node-pre-gyp ERR! System Linux 6.1.0-23-amd64
          npm error node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-libcurl/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
          npm error node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
          npm error node-pre-gyp ERR! node -v v20.16.0
          npm error node-pre-gyp ERR! node-pre-gyp -v v1.0.10
          npm error node-pre-gyp ERR! not ok
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-20T13_59_25_128Z-debug-0.log
            npm ls zlib
            flommaster
            npm ls zlib
            Hier ist noch das Ergebnis von npm ls zlib
            flo@ioBrokerdebian:/opt/iobroker$ npm ls zlib
            iobroker.inst@2.0.3 /opt/iobroker
            └─┬ iobroker.mihome-vacuum@3.11.0
              └── zlib@1.0.5
            • F flommaster
              npm ls zlib
                └── zlib@1.0.5
              @flommaster
              Du hast da nicht nur eine oder zwei Baustellen, das ist eine ausgewachsene Großbaustelle da bei dir...
              apt policy libcurl*
              apt policy libcurl*dev
              Es muss das entsprechende -dev-Paket zu der bei dir installierten Version von libcurl installiert werden.
              Zu mihome-vacuum versuch mal ein
              iob update
              iob upgrade iobroker.mihome-vacuum@4.2.0
              F 2 Antworten Letzte Antwort
                @flommaster
                apt policy libcurl*
                iob update
                flommaster
                apt policy libcurl*
                flo@ioBrokerdebian:/opt/iobroker$ apt policy libcurl*
                libcurl4-openssl-dev:
                  Installiert:           (keine)
                  Installationskandidat: 7.88.1-10+deb12u6
                  Versionstabelle:
                     7.88.1-10+deb12u6 500
                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                     7.88.1-10+deb12u5 500
                        500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                libcurl3:
                  Installationskandidat: (keine)
                  Versionstabelle:
                libcurl4:
                  Installiert:           7.88.1-10+deb12u6
                  Versionstabelle:
                 *** 7.88.1-10+deb12u6 500
                libcurl3-gnutls:
                  Versionstabelle:
                libcurl-ocaml:
                  Installationskandidat: 0.9.2-3
                  Versionstabelle:
                     0.9.2-3 500
                libcurl3-openssl-dev:
                  Versionstabelle:
                libcurl3-gnutls-dev:
                  Versionstabelle:
                libcurl4-gnutls-dev:
                  Versionstabelle:
                libcurl-dev:
                  Versionstabelle:
                libcurlpp0:
                  Installationskandidat: 0.8.1-5.1
                  Versionstabelle:
                     0.8.1-5.1 500
                libcurl-ocaml-dev:
                  Versionstabelle:
                     0.9.2-3 500
                libcurl-ocaml-80io7:
                  Versionstabelle:
                libcurlpp-dev:
                  Versionstabelle:
                     0.8.1-5.1 500
                libcurl-ssl-dev:
                  Versionstabelle:
                libcurl3-nss-dev:
                  Versionstabelle:
                libcurl3-dev:
                  Versionstabelle:
                libcurl-ocaml-dev-80io7:
                  Versionstabelle:
                libcurl4-dev:
                  Versionstabelle:
                libcurl4-doc:
                  Versionstabelle:
                libcurl3-nss:
                  Versionstabelle:
                libcurl4-nss-dev:
                  Versionstabelle:
                  Versionstabelle:
                  Versionstabelle:
                  Versionstabelle:
                  Versionstabelle:
                libcurl-dev:
                  Versionstabelle:
                libcurl-ocaml-dev:
                  Versionstabelle:
                     0.9.2-3 500
                libcurlpp-dev:
                  Versionstabelle:
                     0.8.1-5.1 500
                libcurl-ssl-dev:
                  Versionstabelle:
                libcurl3-nss-dev:
                  Versionstabelle:
                libcurl3-dev:
                  Versionstabelle:
                libcurl4-dev:
                  Versionstabelle:
                libcurl4-nss-dev:
                  Versionstabelle:
                  @flommaster
                  apt policy libcurl*
                  iob update
                  flommaster
                  iob update iob upgrade iobroker.mihome-vacuum@4.2.0
                  flo@ioBrokerdebian:/opt/iobroker$ iob update
                  node:internal/modules/esm/resolve:215
                    const resolvedOption = FSLegacyMainResolve(packageJsonUrlString, packageConfig.main, baseStringified);
                  Error: Cannot find package '/opt/iobroker/node_modules/@iobroker/js-controller-cli/package.json' imported from /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                      at legacyMainResolve (node:internal/modules/esm/resolve:215:26)
                      at packageResolve (node:internal/modules/esm/resolve:841:14)
                      at moduleResolve (node:internal/modules/esm/resolve:927:18)
                      at defaultResolve (node:internal/modules/esm/resolve:1169:11)
                      at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
                      at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
                      at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
                      at ModuleLoader.import (node:internal/modules/esm/loader:315:34)
                      at defaultImportModuleDynamically (node:internal/modules/esm/utils:194:31)
                      at importModuleDynamicallyCallback (node:internal/modules/esm/utils:216:12) {
                    code: 'ERR_MODULE_NOT_FOUND'
                  Node.js v20.16.0
                  Node.js v20.16.0
                  • F flommaster
                    Node.js v20.16.0
                    Node.js v20.16.0
                    @flommaster
                    iob update
                    zeilenweise einzeln eingeben.
                    • F flommaster
                      apt policy libcurl*
                        Versionstabelle:
                      libcurl3:
                        Versionstabelle:
                      libcurl4:
                        Versionstabelle:
                      libcurl3-gnutls:
                        Versionstabelle:
                      libcurl-ocaml:
                        Versionstabelle:
                           0.9.2-3 500
                        Versionstabelle:
                        Versionstabelle:
                        Versionstabelle:
                      libcurl-dev:
                        Versionstabelle:
                      libcurlpp0:
                        Versionstabelle:
                           0.8.1-5.1 500
                      libcurl-ocaml-dev:
                        Versionstabelle:
                           0.9.2-3 500
                        Versionstabelle:
                      libcurlpp-dev:
                        Versionstabelle:
                           0.8.1-5.1 500
                      libcurl-ssl-dev:
                        Versionstabelle:
                      libcurl3-nss-dev:
                        Versionstabelle:
                      libcurl3-dev:
                        Versionstabelle:
                        Versionstabelle:
                      libcurl4-dev:
                        Versionstabelle:
                      libcurl4-doc:
                        Versionstabelle:
                      libcurl3-nss:
                        Versionstabelle:
                      libcurl4-nss-dev:
                        Versionstabelle:
                        Versionstabelle:
                        Versionstabelle:
                        Versionstabelle:
                        Versionstabelle:
                      libcurl-dev:
                        Versionstabelle:
                      libcurl-ocaml-dev:
                        Versionstabelle:
                           0.9.2-3 500
                      libcurlpp-dev:
                        Versionstabelle:
                           0.8.1-5.1 500
                      libcurl-ssl-dev:
                        Versionstabelle:
                      libcurl3-nss-dev:
                        Versionstabelle:
                      libcurl3-dev:
                        Versionstabelle:
                      libcurl4-dev:
                        Versionstabelle:
                      libcurl4-nss-dev:
                        Versionstabelle:
                      apt policy libcurl*
                      Also libcurl4...
                      apt policy libcurl4*
                        @flommaster
                        iob update
                        flommaster
                        @flommaster
                        iob update
                        iob update
                        Node.js v20.16.0
                        flo@ioBrokerdebian:/opt/iobroker$ iob upgrade iobroker.mihome-vacuum@4.2.0
                        Node.js v20.16.0
                          apt policy libcurl*
                          Also libcurl4...
                          flommaster
                          flo@ioBrokerdebian:/opt/iobroker$ apt policy libcurl4*
                            Versionstabelle:
                          libcurl4:
                            Versionstabelle:
                            Versionstabelle:
                          libcurl4-dev:
                            Versionstabelle:
                          libcurl4-doc:
                            Versionstabelle:
                          libcurl4-nss-dev:
                            Versionstabelle:
                          • F flommaster
                              Versionstabelle:
                            libcurl4:
                              Versionstabelle:
                              Versionstabelle:
                            libcurl4-dev:
                              Versionstabelle:
                            libcurl4-doc:
                              Versionstabelle:
                            libcurl4-nss-dev:
                              Versionstabelle:
                            #66
                            Installier das mal:
                            sudo apt install libcurl4-openssl-dev
                              Installier das mal:
                              flommaster
                              #67
                              erledigt.
                              flo@ioBrokerdebian:/opt/iobroker$ sudo apt install libcurl4-openssl-dev
                              Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                g++-10 libbpf0 libcbor0 libdns-export1110 libgdk-pixbuf-xlib-2.0-0 libgdk-pixbuf-xlib-2.0-dev libgdk-pixbuf2.0-dev libicu67 libisc-export1105 libjsoncpp24 libldap-2.4-2 liblua5.1-0 libmpdec3 libnspr4 libnss3 libpcre16-3
                                libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.32 libprocps8 libpython3.9 libpython3.9-minimal libpython3.9-stdlib libstdc++-10-dev libtiff5 liburing1 libusb-0.1-4 libwebp6 lua-bitop lua-cjson perl-modules-5.32 pigz
                                python3.9 python3.9-minimal telnet x11proto-xext-dev
                              Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                              Vorgeschlagene Pakete:
                                libcurl4-doc libidn-dev libkrb5-dev libldap2-dev librtmp-dev libssh2-1-dev libssl-dev
                              Die folgenden NEUEN Pakete werden installiert:
                              0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen 491 kB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 1.819 kB Plattenplatz zusätzlich benutzt.
                              Holen:1 http://deb.debian.org/debian bookworm/main amd64 libcurl4-openssl-dev amd64 7.88.1-10+deb12u6 [491 kB]
                              Es wurden 491 kB in 0 s geholt (2.021 kB/s).
                              Vormals nicht ausgewähltes Paket libcurl4-openssl-dev:amd64 wird gewählt.
                              (Lese Datenbank ... 63533 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../libcurl4-openssl-dev_7.88.1-10+deb12u6_amd64.deb ...
                              Entpacken von libcurl4-openssl-dev:amd64 (7.88.1-10+deb12u6) ...
                              libcurl4-openssl-dev:amd64 (7.88.1-10+deb12u6) wird eingerichtet ...
                              Trigger für man-db (2.11.2-2) werden verarbeitet ...
                              • F flommaster
                                erledigt.
                                #68
                                @flommaster
                                sudo apt autoremove
                                Jetzt die Holzhammermethode:
                                cd /opt/iobroker
                                npm install iobroker.js-controller@6.0.9 --force
                                  @flommaster
                                  sudo apt autoremove
                                  cd /opt/iobroker
                                  flommaster
                                  #69
                                  @flommaster
                                  sudo apt autoremove
                                  cd /opt/iobroker
                                  Das klappt leider auch nicht.
                                  Soll ich mal ein downgrade auf die Version 5.x versuchen?
                                  flo@ioBrokerdebian:/opt/iobroker$ cd /opt/iobroker
                                  npm warn using --force Recommended protections disabled.
                                  npm warn deprecated
                                  npm error code 127
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-20T18_16_12_082Z-debug-0.log
                                  • F flommaster
                                    @flommaster
                                    sudo apt autoremove
                                    cd /opt/iobroker
                                    npm warn deprecated
                                    npm error code 127
                                    #70
                                    @flommaster
                                    Du kannst die Kiste mal neuinstallieren.
                                      @flommaster
                                      flommaster
                                      #71
                                      @flommaster
                                      Alles klar.
                                      Dann bestelle ich mir gleich nen neuen NUC mit 8GB RAM und setze den komplett neu auf.
                                      Gibt es aktuelle Empfehlungen?
                                      Ein Backup mit meinen Daten kann ich danach aber einspielen?
                                      Thomas BraunT S 2 Antworten Letzte Antwort
                                      • F flommaster
                                        @flommaster
                                        Alles klar.
                                        #72
                                        Möglich. Vermutlich knallst du dir den Murks aber nur wieder rein.
                                        • F flommaster
                                          @flommaster
                                          Alles klar.
                                          S Abwesend
                                          S Abwesend
                                          Shadowhunter23
                                          schrieb am zuletzt editiert von Shadowhunter23
                                          #73
                                          @flommaster
                                          https://itreturn.at/HP-EliteDesk-800-G4-Tiny-/-Intel-i5-8500-360GHz-/-256-GB-SSD-/-16GB-RAM-/-Windows-11-Home-/-12-Monate-Garantie
                                          Aber kein HDMI für Monitor.
                                          Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                                          ioBroker Backup Analyzer
                                          BananaJoeB F 2 Antworten Letzte Antwort
