  3. Einsteigerfragen
  4. LG Adapter audio output steuern mit blockly
    5.4k
17 Beiträge 4 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • DJMarc75D DJMarc75
    @felix18
    "tv_speaker": "TV Speaker",
    "external_optical": "External Optical",
    "external_arc": "External ARC",
    "lineout": "LineOut",
    "headphone": "Headphone",
    "tv_external_speaker": "TV + External Speaker",
    "tv_speaker_headphone": "TV + Speaker Headphone",
    "bt_soundbar": "Bluetooth"
    die ersten Werte jeweils (tv_speaker, external_optical, usw) sind die Werte welche im Skript eingetragen werden müssen.
    Zeig mal Dein Blockly.
    Felix18
    @djmarc75
    <block type="on_ext" id="KDC!,0;Z13n~8W4AOm8k" x="-622" y="-427">
    <field name="CONDITION">true</field>
    <value name="OID0">
    <shadow type="field_oid" id="cn5W74N5L?H27AhE:dl,">
    <field name="oid">0_userdata.0.Terrasse_TV_Ton</field>
    </shadow>
    </value>
    <statement name="STATEMENT">
    <block type="controls_if" id="1-;7$VFf2pgYFjR}.m4"> <value name="IF0"> <block type="logic_compare" id="b!~6PpPZp}bL6s:t5sO">
    <field name="OP">EQ</field>
    <value name="A">
    <block type="get_value" id="}?aWRf969(L*Ie0_cTXa">
    <field name="OID">lgtv.0.states.power</field>
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="[SrkaN#Wj$(21JFTmoY"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="1u*bM+sm?X9iC|ye@a/">
    <field name="OID">denon.1.zoneMain.powerZone</field>
    <value name="VALUE">
    <block type="logic_boolean" id="Q8bTX/(/2{2Mh^|?K7w3">
    </block>
    </value>
    <next>
    <block type="control" id="9=ZtdWPy~s%i^|y4CsX!">
    <field name="OID">lgtv.0.states.soundOutput</field>
    <block type="text_multiline" id="n;Hbvd;Cs^n,y/Jp3:3N">
    <field name="TEXT">External Optical</field>
    </block>
    </value>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </xml>
    • F Felix18
      @djmarc75
      <value name="OID0">
      </shadow>
      </value>
      <value name="A">
      </block>
      </value>
      <value name="B">
      </block>
      </value>
      <next>
      </block>
      </value>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </xml>
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @felix18 bitte als Bild
      Lehrling seit 1975 !!!
      F 1 Antwort Letzte Antwort
        Felix18
        @djmarc75 meine altbekannte frage, wie geht das?
        • F Felix18
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @felix18 sagte in LG Adapter audio output steuern mit blockly:
          wie geht das?
          Na Du machst einen Screenshot und stellst diesen hier als Bild ein.
          Ich nutze das SnippingTool in Windows.
            wie geht das?
            Felix18
            • F Felix18
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @felix18 naja, abfotografieren ist eher suboptimal !
              Bitte beschäftige Dich mal mit solchen Basics und auch wie man Text hier in Codetags einbettet.
              Hier das Blockly als Bild und zum Importieren:
                  <value name="OID0">
                    </shadow>
                  </value>
                      <value name="IF0">
                        </block>
                      </value>
                            </block>
                          </value>
                          <next>
                                <block type="text" id="nnjNU+G3CyXE]E{/2m{:">
                                  <field name="TEXT">external_optical</field>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
              </xml>
                    <value name="OID0">
                      </shadow>
                    </value>
                        <value name="IF0">
                          </block>
                        </value>
                              </block>
                            </value>
                            <next>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                </xml>
                Felix18
                @djmarc75 sagte in LG Adapter audio output steuern mit blockly:
                <xml xmlns="https://developers.google.com/blockly/xml"> <block type="on_ext" id="KDC!,0;Z13n~8W4AOm8k" x="-622" y="-427"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">true</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="cn5W74N5L?H27AhE:dl,"> <field name="oid">0_userdata.0.Terrasse_TV_Ton</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="1-;7$VFf2pgYFjR}.m4"> <value name="IF0"> <block type="get_value" id="}?aWRf969(LIe0_cTXa"> <field name="ATTR">val</field> <field name="OID">lgtv.0.states.power</field> </block> </value> <statement name="DO0"> <block type="control" id="1ubM+sm?X9iC|ye@a/"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">denon.1.zoneMain.powerZone</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="Q8bTX/(/2{2Mh^|?K7w3"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="9=ZtdWPy~s%i^|y4CsX!"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">lgtv.0.states.soundOutput</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="nnjNU+G3CyXE]E{/2m{:"> <field name="TEXT">external_optical</field> </block> </value> </block> </next> </block> </statement> </block> </statement> </block> </xml>
                @DJMarc75 du bist ein Freak!!! Es funktioniert!!! Danke !!!
                Also muss ich den rechten wert eintragen vom Datenpunkt der in der ( ) liegt und nicht den linken!!!
                Ja ich werde mich damit beschäftigen. Ich danke Dir vielmals und super, das du immer sofort antwortest!!
                • F Felix18
                  CodierknechtC Offline
                  Codierknecht
                  Andersrum!
                  Wenn Du auf den rechten Wert umschalten willst, musst Du den linken Wert im Blockly verwenden.
                  Um auf "Bluetooth" umzuschalten, musst Du "bt_soundbar" eintragen.
                      "bt_soundbar": "Bluetooth",
                  Edit
                  Das Prinzip gilt übrigens überall, wo man im Objektbaum etwas "auswählen" kann.
                  Da werden auch gerne mal Textwerte angezeigt, obwohl in den Objektdaten die States als Zahlen hinterlegt sind.
                  In solchen Fällen muss logischerweise auch eine Zahl in Blockly eingesetzt werden (und keine Zeichenfolge).
                  Beispiel:
                  "states": {
                      0: stay arm;
                      1: away arm;
                      2: night arm;
                      3: disarm;
                      4: alarm triggered
                  Es kommt also darauf an, welchen Typ (string, number) der zu schaltende DP hat!
                  HmIP|ZigBee|Tasmota|Unifi
                  Zabbix Certified Specialist
                  F liv-in-skyL 2 Antworten Letzte Antwort
                  • CodierknechtC Codierknecht
                    Andersrum!
                    Edit
                    Beispiel:
                    "states": {
                        0: stay arm;
                        1: away arm;
                        2: night arm;
                        3: disarm;
                        4: alarm triggered
                    Felix18
                    @codierknecht ahh guter hinweis @Codierknecht,
                    also ist es am besten man schaltet auf Expertenmodus um, und sieht in den Objektdaten nach.
                    Also vielen dank für eure Unterstützung, Hilfsbereitschaft und natürlich eure kostbare Zeit!!!
                      Andersrum!
                      Edit
                      Beispiel:
                      "states": {
                          0: stay arm;
                          1: away arm;
                          2: night arm;
                          3: disarm;
                          4: alarm triggered
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @codierknecht sagte in LG Adapter audio output steuern mit blockly:
                      bluetooth umschalten funktioniert leider nicht - es gibt keinen dp um das bluetooth device anzugeben - zumindest bei mir ist es so - ich gehe dann sehr umständlich mit den pfeiltaten über blockly um das device auszuwählen
                      • F Felix18
                        Codierknecht
                        Im Zweifelsfall: Ja!
                        Bei Zahlen erkennt man das in der Regel an der in Klammern gezeigten Zahl.
