  3. Einsteigerfragen
  4. LG Adapter audio output steuern mit blockly
    5.4k
17 Beiträge 4 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • F Felix18
    "_id": "lgtv.0.states.soundOutput",
    "type": "state",
    "common": {
    "name": "Switch audio output",
    "role": "state",
    "type": "string",
    "states": {
    "tv_speaker": "TV Speaker",
    "external_optical": "External Optical",
    "external_arc": "External ARC",
    "lineout": "LineOut",
    "headphone": "Headphone",
    "tv_external_speaker": "TV + External Speaker",
    "tv_speaker_headphone": "TV + Speaker Headphone",
    "bt_soundbar": "Bluetooth"
    "read": true,
    "write": true
    "native": {},
    "from": "system.adapter.lgtv.0",
    "user": "system.user.admin",
    "ts": 1724098835867,
    "acl": {
    "object": 1636,
    "state": 1636,
    "file": 1632,
    "owner": "system.user.admin",
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @felix18
    die ersten Werte jeweils (tv_speaker, external_optical, usw) sind die Werte welche im Skript eingetragen werden müssen.
    Zeig mal Dein Blockly.
    Lehrling seit 1975 !!!
    F 1 Antwort Letzte Antwort
    • DJMarc75D DJMarc75
      @felix18
      Felix18
      @djmarc75
      <block type="on_ext" id="KDC!,0;Z13n~8W4AOm8k" x="-622" y="-427">
      <field name="CONDITION">true</field>
      <value name="OID0">
      <shadow type="field_oid" id="cn5W74N5L?H27AhE:dl,">
      <field name="oid">0_userdata.0.Terrasse_TV_Ton</field>
      </shadow>
      </value>
      <statement name="STATEMENT">
      <block type="controls_if" id="1-;7$VFf2pgYFjR}.m4"> <value name="IF0"> <block type="logic_compare" id="b!~6PpPZp}bL6s:t5sO">
      <field name="OP">EQ</field>
      <value name="A">
      <block type="get_value" id="}?aWRf969(L*Ie0_cTXa">
      <field name="OID">lgtv.0.states.power</field>
      </block>
      </value>
      <value name="B">
      <block type="logic_boolean" id="[SrkaN#Wj$(21JFTmoY"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="1u*bM+sm?X9iC|ye@a/">
      <field name="OID">denon.1.zoneMain.powerZone</field>
      <value name="VALUE">
      <block type="logic_boolean" id="Q8bTX/(/2{2Mh^|?K7w3">
      </block>
      </value>
      <next>
      <block type="control" id="9=ZtdWPy~s%i^|y4CsX!">
      <field name="OID">lgtv.0.states.soundOutput</field>
      <block type="text_multiline" id="n;Hbvd;Cs^n,y/Jp3:3N">
      <field name="TEXT">External Optical</field>
      </block>
      </value>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </xml>
      • F Felix18
        @djmarc75
        <value name="OID0">
        </shadow>
        </value>
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </xml>
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @felix18 bitte als Bild
          Felix18
          @djmarc75 meine altbekannte frage, wie geht das?
          • F Felix18
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @felix18 sagte in LG Adapter audio output steuern mit blockly:
            wie geht das?
            Na Du machst einen Screenshot und stellst diesen hier als Bild ein.
            Ich nutze das SnippingTool in Windows.
              wie geht das?
              Felix18
              • F Felix18
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @felix18 naja, abfotografieren ist eher suboptimal !
                Bitte beschäftige Dich mal mit solchen Basics und auch wie man Text hier in Codetags einbettet.
                Hier das Blockly als Bild und zum Importieren:
                    <value name="OID0">
                      </shadow>
                    </value>
                        <value name="IF0">
                          </block>
                        </value>
                              </block>
                            </value>
                            <next>
                                  <block type="text" id="nnjNU+G3CyXE]E{/2m{:">
                                    <field name="TEXT">external_optical</field>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                </xml>
                      <value name="OID0">
                        </shadow>
                      </value>
                          <value name="IF0">
                            </block>
                          </value>
                                </block>
                              </value>
                              <next>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </statement>
                    </block>
                  </xml>
                  Felix18
                  @djmarc75 sagte in LG Adapter audio output steuern mit blockly:
                  <xml xmlns="https://developers.google.com/blockly/xml"> <block type="on_ext" id="KDC!,0;Z13n~8W4AOm8k" x="-622" y="-427"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">true</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="cn5W74N5L?H27AhE:dl,"> <field name="oid">0_userdata.0.Terrasse_TV_Ton</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="1-;7$VFf2pgYFjR}.m4"> <value name="IF0"> <block type="get_value" id="}?aWRf969(LIe0_cTXa"> <field name="ATTR">val</field> <field name="OID">lgtv.0.states.power</field> </block> </value> <statement name="DO0"> <block type="control" id="1ubM+sm?X9iC|ye@a/"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">denon.1.zoneMain.powerZone</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="Q8bTX/(/2{2Mh^|?K7w3"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="9=ZtdWPy~s%i^|y4CsX!"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">lgtv.0.states.soundOutput</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="nnjNU+G3CyXE]E{/2m{:"> <field name="TEXT">external_optical</field> </block> </value> </block> </next> </block> </statement> </block> </statement> </block> </xml>
                  @DJMarc75 du bist ein Freak!!! Es funktioniert!!! Danke !!!
                  Also muss ich den rechten wert eintragen vom Datenpunkt der in der ( ) liegt und nicht den linken!!!
                  Ja ich werde mich damit beschäftigen. Ich danke Dir vielmals und super, das du immer sofort antwortest!!
                  • F Felix18
                    CodierknechtC Offline
                    Codierknecht
                    Andersrum!
                    Wenn Du auf den rechten Wert umschalten willst, musst Du den linken Wert im Blockly verwenden.
                    Um auf "Bluetooth" umzuschalten, musst Du "bt_soundbar" eintragen.
                        "bt_soundbar": "Bluetooth",
                    Edit
                    Das Prinzip gilt übrigens überall, wo man im Objektbaum etwas "auswählen" kann.
                    Da werden auch gerne mal Textwerte angezeigt, obwohl in den Objektdaten die States als Zahlen hinterlegt sind.
                    In solchen Fällen muss logischerweise auch eine Zahl in Blockly eingesetzt werden (und keine Zeichenfolge).
                    Beispiel:
                    "states": {
                        0: stay arm;
                        1: away arm;
                        2: night arm;
                        3: disarm;
                        4: alarm triggered
                    Es kommt also darauf an, welchen Typ (string, number) der zu schaltende DP hat!
                    HmIP|ZigBee|Tasmota|Unifi
                    Zabbix Certified Specialist
                    F liv-in-skyL 2 Antworten Letzte Antwort
                    • CodierknechtC Codierknecht
                      Andersrum!
                      Edit
                      Beispiel:
                      "states": {
                          0: stay arm;
                          1: away arm;
                          2: night arm;
                          3: disarm;
                          4: alarm triggered
                      Felix18
                      @codierknecht ahh guter hinweis @Codierknecht,
                      also ist es am besten man schaltet auf Expertenmodus um, und sieht in den Objektdaten nach.
                      Also vielen dank für eure Unterstützung, Hilfsbereitschaft und natürlich eure kostbare Zeit!!!
                        Andersrum!
                        Edit
                        Beispiel:
                        "states": {
                            0: stay arm;
                            1: away arm;
                            2: night arm;
                            3: disarm;
                            4: alarm triggered
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @codierknecht sagte in LG Adapter audio output steuern mit blockly:
                        bluetooth umschalten funktioniert leider nicht - es gibt keinen dp um das bluetooth device anzugeben - zumindest bei mir ist es so - ich gehe dann sehr umständlich mit den pfeiltaten über blockly um das device auszuwählen
                        • F Felix18
                          Codierknecht
                          Im Zweifelsfall: Ja!
                          Bei Zahlen erkennt man das in der Regel an der in Klammern gezeigten Zahl.
