  4. timedatectl failed
timedatectl failed
4 Beiträge 4 Kommentatoren 584 Aufrufe 2 Beobachtet
  • N Offline
    N Offline
    Nordischerjung
    Moin,
    ich habe im iOBroker als Hinweis, dass die Zeiten zwischen Browser und iOBroker Server einen Unterschiede von 66 Minuten haben.
    Da dachte ich mir, gut guckste mal mit timedatectl, was da eingestellt ist und dann kam das dabei heraus:
    sb@iOBroker:~$ timedatectl
    Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
    sb@iOBroker:~$ sudo systemctl restart systemd-timedated
    Job for systemd-timedated.service failed because the control process exited with error code.
    See "systemctl status systemd-timedated.service" and "journalctl -xeu systemd-timedated.service" for details.
    Das steht inm Status:
    sb@iOBroker:~$ systemctl status systemd-timedated.service
    x systemd-timedated.service - Time & Date Service
         Loaded: loaded (/lib/systemd/system/systemd-timedated.service; static)
         Active: failed (Result: exit-code) since Mon 2024-08-19 10:28:08 CEST; 1min 4s ago
           Docs: man:systemd-timedated.service(8)
                 man:localtime(5)
                 man:org.freedesktop.timedate1(5)
        Process: 4908 ExecStart=/lib/systemd/systemd-timedated (code=exited, status=226/NAMESPACE)
       Main PID: 4908 (code=exited, status=226/NAMESPACE)
            CPU: 14ms
    Aug 19 10:28:08 iOBroker systemd[1]: Starting systemd-timedated.service - Time & Date Service...
    Aug 19 10:28:08 iOBroker (imedated)[4908]: systemd-timedated.service: Failed to set up mount namespacing: /run/systemd/unit-root/proc: Permission denied
    Aug 19 10:28:08 iOBroker (imedated)[4908]: systemd-timedated.service: Failed at step NAMESPACE spawning /lib/systemd/systemd-timedated: Permission denied
    Aug 19 10:28:08 iOBroker systemd[1]: systemd-timedated.service: Main process exited, code=exited, status=226/NAMESPACE
    Aug 19 10:28:08 iOBroker systemd[1]: systemd-timedated.service: Failed with result 'exit-code'.
    Aug 19 10:28:08 iOBroker systemd[1]: Failed to start systemd-timedated.service - Time & Date Service.
    ich habe auch schon den iob fix laufen lassen.
    Ich weiß auch gar nicht, seit wann das Problem besteht.
    Hat jemand einen Tip?
    und hier noch iob diag
    Skript v.2024-05-22
    *** BASE SYSTEM ***
    Failed to query system properties: Connection timed out
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:56:08 up  3:32,  2 users,  load average: 0.79, 0.77, 0.79
    CPU threads: 4
    *** Time and Time Zones ***
    *** Users and Groups ***
    User that called 'iob diag':
    sb
    HOME=/home/sb
    GROUPS=sb adm sudo iobroker lxc_shares
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            6.4G        3.6G        1.7G         98K        1.2G        2.8G
    Swap:           6.4G          0B        6.4G
    Total:           12G        3.6G        8.1G
    Active iob-Instances:   38
             6144 M total memory
             3452 M used memory
             3012 M active memory
              976 M inactive memory
             1585 M free memory
                0 M buffer memory
             1106 M swap cache
             6144 M total swap
                0 M used swap
             6144 M free swap
    top - 11:56:33 up  3:33,  2 users,  load average: 0.98, 0.82, 0.81
    Tasks:  64 total,   1 running,  62 sleeping,   1 stopped,   0 zombie
    %Cpu(s): 25.0 us, 25.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   6144.0 total,   1584.0 free,   3454.1 used,   1106.0 buff/cache
    MiB Swap:   6144.0 total,   6144.0 free,      0.0 used.   2689.9 avail Mem
    *** FAILED SERVICES ***
      UNIT                      LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount      loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount   loaded failed failed Kernel Configuration File System
    * influxdb.service          loaded failed failed InfluxDB is an open-source, distributed, time series database
    * networking.service        loaded failed failed Raise network interfaces
    * systemd-hostnamed.service loaded failed failed Hostname Service
    * systemd-logind.service    loaded failed failed User Login Management
    * systemd-timedated.service loaded failed failed Time & Date Service
    7 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0 ext4       25G   15G  8.7G  63% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs     1.6G   92K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysctl.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup.service
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET                                                  SOURCE                           FSTYPE     OPTIONS
    /                                                       /dev/mapper/pve-vm--101--disk--0 ext4       rw,relatime,stripe=16
    |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=1596100k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
    | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    | |-/run/credentials/systemd-sysctl.service             tmpfs                            tmpfs      ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
    | |-/run/credentials/systemd-sysusers.service           tmpfs                            tmpfs      ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
    | |-/run/credentials/systemd-tmpfiles-setup-dev.service tmpfs                            tmpfs      ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
    | `-/run/credentials/systemd-tmpfiles-setup.service     tmpfs                            tmpfs      ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
    |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
    | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
    | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
    | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
    | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
    | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
    | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
    | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
    | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
    | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
      |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
      |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    1.1G    /var/
    597M    /var/lib
    432M    /var/cache
    427M    /var/cache/apt
    400M    /var/lib/influxdb
    Archived and active journals take up 24.0M in the file system.
    /opt/iobroker/backups:
    494M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    4.3G    /opt/iobroker/iobroker-data/
    1.9G    /opt/iobroker/iobroker-data/files
    1.6G    /opt/iobroker/iobroker-data/history
    656M    /opt/iobroker/iobroker-data/files/vis-2-beta
    573M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
    90M     /opt/iobroker/iobroker-data/states.jsonl
    55M     /opt/iobroker/iobroker-data/objects.jsonl
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    nodejs:
      Installed: 20.16.0-1nodesource1
      Candidate: 20.16.0-1nodesource1
      Version table:
     *** 20.16.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.9
    admin:          7.0.22
    javascript:     8.7.6
    nodejs modules from github:     9
    +-- iobroker.esphome@0.2.4 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#479f1eec57b0fa67cb6b72e14d3db853ca778801)
    +-- iobroker.hm-rega@4.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.hm-rega.git#ce42f9cfcb88d4884c204ffc8545e2c0c65a2b73)
    +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#119cfa311105f1dbe4e674909c975cce7046977f)
    +-- iobroker.mytime@0.7.12 (git+ssh://git@github.com/oweitman/ioBroker.mytime.git#e14111fe835aab072d9a53d1d16fdbb004906c44)
    +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.tapo@0.2.9 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#bded02134bbcc37543a2af51224c4d50c718088f)
    +-- iobroker.vaillant@0.7.2 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#3567516e477b37552195d02f4cc8d94d0bf9de65)
    +-- iobroker.vofo-speedtest@0.0.13 (git+ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git#31b8cdda3ad63524bfa926060845b920cf4f151d)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iOBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iOBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iOBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iOBroker                                 -  enabled
      system.adapter.device-watcher.0         : device-watcher        : iOBroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iOBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iOBroker                                 -  enabled
      system.adapter.easee.0                  : easee                 : iOBroker                                 - disabled
      system.adapter.echarts.0                : echarts               : iOBroker                                 - disabled
    + system.adapter.enigma2.0                : enigma2               : iOBroker                                 -  enabled
    + system.adapter.esphome.0                : esphome               : iOBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iOBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iOBroker                                 - disabled
      system.adapter.ford.0                   : ford                  : iOBroker                                 - disabled
      system.adapter.fritzdect.0              : fritzdect             : iOBroker                                 - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iOBroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : iOBroker                                 -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iOBroker                                 -  enabled
      system.adapter.hiob.0                   : hiob                  : iOBroker                                 - disabled, port: 8090
      system.adapter.history.0                : history               : iOBroker                                 - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iOBroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iOBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iOBroker                                 -  enabled, port: 0
      system.adapter.hue-extended.0           : hue-extended          : iOBroker                                 - disabled
    + system.adapter.hue.0                    : hue                   : iOBroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : iOBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iOBroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : iOBroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : iOBroker                                 -  enabled
      system.adapter.ical.4                   : ical                  : iOBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iOBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iOBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iOBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iOBroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iOBroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iOBroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iOBroker                                 -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iOBroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iOBroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iOBroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iOBroker                                 -  enabled
      system.adapter.logparser.0              : logparser             : iOBroker                                 - disabled
      system.adapter.material.0               : material              : iOBroker                                 - disabled
    + system.adapter.meross.0                 : meross                : iOBroker                                 -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iOBroker                                 - disabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : iOBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iOBroker                                 -  enabled, port: 1899, bind: 0.0.0.0
      system.adapter.mytime.0                 : mytime                : iOBroker                                 - disabled
      system.adapter.onkyo.0                  : onkyo                 : iOBroker                                 - disabled
      system.adapter.openweathermap.0         : openweathermap        : iOBroker                                 - disabled
      system.adapter.ping.0                   : ping                  : iOBroker                                 - disabled
      system.adapter.proxmox.0                : proxmox               : iOBroker                                 - disabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iOBroker                                 -  enabled
    + system.adapter.radar2.0                 : radar2                : iOBroker                                 -  enabled
      system.adapter.reolink.0                : reolink               : iOBroker                                 - disabled
      system.adapter.roborock.0               : roborock              : iOBroker                                 - disabled
    + system.adapter.s7.0                     : s7                    : iOBroker                                 -  enabled
      system.adapter.sayit.0                  : sayit                 : iOBroker                                 - disabled
    + system.adapter.scenes.0                 : scenes                : iOBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iOBroker                                 -  enabled, port: 4882, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : iOBroker                                 - disabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : iOBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iOBroker                                 -  enabled
      system.adapter.synology.0               : synology              : iOBroker                                 - disabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iOBroker                                 -  enabled
      system.adapter.tapo.0                   : tapo                  : iOBroker                                 - disabled
    + system.adapter.telegram.0               : telegram              : iOBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iOBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : iOBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : iOBroker                                 - disabled
      system.adapter.tr-064.0                 : tr-064                : iOBroker                                 - disabled
    + system.adapter.trashschedule.0          : trashschedule         : iOBroker                                 -  enabled
    + system.adapter.vaillant.0               : vaillant              : iOBroker                                 -  enabled
      system.adapter.vis-2-beta.0             : vis-2-beta            : iOBroker                                 - disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iOBroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iOBroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iOBroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iOBroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iOBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iOBroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iOBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iOBroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iOBroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iOBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iOBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iOBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iOBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iOBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iOBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iOBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iOBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iOBroker                                 -  enabled
      system.adapter.vofo-speedtest.0         : vofo-speedtest        : iOBroker                                 - disabled
    + system.adapter.web.0                    : web                   : iOBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iOBroker                                 - disabled
    + system.adapter.ws.0                     : ws                    : iOBroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.22   , installed 7.0.22
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.16   , installed 3.0.16
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "ford"         : 1.0.4    , installed 1.0.4
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "harmony"      : 1.4.0    , installed 1.4.0
    Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
    Adapter    "hiob"         : 0.1.5    , installed 0.1.5
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "hue"          : 3.11.0   , installed 3.11.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
    Adapter    "reolink"      : 1.1.0    , installed 1.1.0
    Adapter    "roborock"     : 0.6.4    , installed 0.6.4
    Adapter    "s7"           : 1.4.3    , installed 1.4.3
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scenes"       : 3.2.1    , installed 3.2.1
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "vis-2-widgets-energy": 1.0.0, installed 1.0.0
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Objects and States
    Objects:        42575
    States:         41949
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       28824      872/io.mqtt.0
    tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      109        20309      207/mosquitto
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       27545      726/io.hm-rpc.2
    tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1001       27279      711/io.hm-rpc.0
    tcp        0      0 0.0.0.0:4882            0.0.0.0:*               LISTEN      1001       28502      955/io.shelly.1
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       21813      206/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       20756      206/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20602      212/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9808       1/systemd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          20416      359/master
    tcp6       0      0 :::1899                 :::*                    LISTEN      109        20310      207/mosquitto
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       26880      681/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20604      212/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          9810       1/systemd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22892      371/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       34157      1181/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       33837      1119/io.socketio.0
    tcp6       0      0 :::8085                 :::*                    LISTEN      1001       31640      1196/io.ws.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          20417      359/master
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       31226      1025/io.esphome.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       31117      928/io.shelly.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       28877      898/io.radar2.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9809       1/systemd
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       26881      681/io.harmony.0
    udp6       0      0 :::111                  :::*                                0          9811       1/systemd
    2024-08-19 08:37:38.757  - info: scenes.0 (490) Got terminate signal TERMINATE_YOURSELF
    2024-08-19 08:37:38.759  - info: scenes.0 (490) terminating
    2024-08-19 08:37:38.761  - info: scenes.0 (490) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-08-19 08:37:39.263  - info: scenes.0 (490) terminating
    2024-08-19 08:37:47.394  - info: scenes.0 (1571) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.scenes, node: v20.16.0, js-controller: 6.0.9
    2024-08-19 08:37:51.539  - warn: host.iOBroker instance system.adapter.telegram.0 terminated due to SIGKILL
    2024-08-19 08:37:52.136  - warn: host.iOBroker instance system.adapter.telegram.1 terminated due to SIGKILL
    2024-08-19 08:37:52.270  - warn: host.iOBroker instance system.adapter.telegram.2 terminated due to SIGKILL
    2024-08-19 09:03:20.086  - error: influxdb.0 (409) Error during ping: Error: connect ECONNREFUSED 192.168.170.119:8086. Attempting reconnect.
    2024-08-19 09:03:30.094  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:03:40.097  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:03:50.100  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:04:00.103  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:04:10.105  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:04:20.108  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:04:30.111  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:04:40.116  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:04:50.122  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:05:00.125  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:05:10.129  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
    2024-08-19 09:06:14.040  - info: admin.0 (371) ==> Connected system.user.admin from ::ffff:192.168.160.132
    2024-08-19 09:06:48.218  - info: admin.0 (371) <== Disconnect system.user.admin from ::ffff:192.168.160.132
    2024-08-19 09:08:24.130  - error: fullybrowser.0 (2623) No Fully devices defined in adapter instance settings!
    2024-08-19 09:08:24.132  - error: fullybrowser.0 (2623) Adapter settings initialization failed.  ---> Please check your adapter instance settings!
    2024-08-19 09:30:14.274  - warn: ical.2 (4004) get state error: Connection is closed.
    Gruß Nordischerjung
    sonnige Grüße von der Ostsee
    • N Nordischerjung
      Moin,
                   man:localtime(5)
              CPU: 14ms
      Skript v.2024-05-22
      *** BASE SYSTEM ***
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
      sb
      HOME=/home/sb
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           6.4G          0B        6.4G
               6144 M total memory
               3452 M used memory
               1585 M free memory
                  0 M buffer memory
               1106 M swap cache
               6144 M total swap
                  0 M used swap
               6144 M free swap
      *** FILESYSTEM ***
      /var:
      1.1G    /var/
      597M    /var/lib
      432M    /var/cache
      427M    /var/cache/apt
      USB-Devices by-id:
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.0.22
      javascript:     8.7.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        42575
      States:         41949
      Pending Updates: 0
      @nordischerjung sagte in timedatectl failed:
      Es gibt ja eine ganze Latte an Services, die nicht auf die Beine kommen.
      Da die sich tw. gegenseitig bedingen würde ich da ansetzen.
      Bei LXCs kann ich aber nicht weiterhelfen.
      • Ro75R Online
        Ro75R Online
        Ro75
        Die abweichende Zeit ist aber ein generelles Problem und wird auf GIT diskutiert.
        https://github.com/ioBroker/ioBroker.admin/issues/2606
        *** FAILED SERVICES *** ist wie @Thomas-Braun schon schrieb eine andere Nummer und ist davon unabhängig zu betrachten und bearbeiten.
        Ro75
        • Ro75R Ro75
          Ro75
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @ro75 said in timedatectl failed:
          Ro75
          Bitte schau dir doch das Issue an bevor du Querveerweie behauptest.
          Das Issue hat nichts mit dem hier diskutierten Problem, dass auf dem hier beteiligten System die automatische Aktualisiserung der Systemzeit nicht funktioniert. Das Issue betrifft eine Fehlanzeige nachdem ein Browsertab im Hintergrund ist/war - dieses Topic betrifft ein Service das nicht läuft. Und ioBroker kann kein fehlerhaftes / nicht laufendes Systemservice "richten".
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
