  4. iob Befehle werden nicht ausgeführt
35 Beiträge 5 Kommentatoren 4.3k Aufrufe 4 Beobachtet
  • M Merowinger
    @thomas-braun iobroker läuft auf einem Proxmox Container, der hat keinen ssh Zugang und wenn man vom host mit pct enter in den Container wechselt, ist man erst mal root
    nutzer@iobroker:/opt/iobroker$ iob diag
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    @merowinger sagte in iob Befehle werden nicht ausgeführt:
    warum nicht?
      warum nicht?
      Merowinger
      @homoran weil ich über den host per pct enter hinein komme.
      Iobroker läuft als Container auf Proxmox.
      Thomas BraunT HomoranH R 3 Antworten Letzte Antwort
      • M Merowinger
        @merowinger
        Zeig mal die Langfassung von
        iob diag
        nun.
        M 2 Antworten Letzte Antwort
          @merowinger
          iob diag
          nun.
          Merowinger
          Skript v.2024-05-22
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container
            Virtualization: lxc
          Operating System: Ubuntu 22.04.4 LTS
                    Kernel: Linux 6.8.8-4-pve
              Architecture: x86-64
          model name      : Intel(R) Xeon(R) W-2135 CPU @ 3.70GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           15:12:21 up 41 min,  1 user,  load average: 1.67, 1.88, 1.87
          CPU threads: 2
          *** Time and Time Zones ***
                         Local time: Sun 2024-08-18 15:12:21 CEST
                     Universal time: Sun 2024-08-18 13:12:21 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          Benny
          HOME=/home/Benny
          GROUPS=Benny sudo iobroker
          js-controller is not running
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.2G        488M        6.0G        0.0K        1.7G        7.7G
          Swap:           1.0G          0B        1.0G
          Total:          9.2G        488M        7.0G
          Active iob-Instances:   1
                   8192 M total memory
                    488 M used memory
                    500 M active memory
                   1338 M inactive memory
                   6020 M free memory
                      0 M buffer memory
                   1682 M swap cache
                   1024 M total swap
                      0 M used swap
                   1024 M free swap
          top - 15:12:21 up 41 min,  1 user,  load average: 1.70, 1.88, 1.87
          Tasks:  34 total,   1 running,  33 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8192.0 total,   6020.7 free,    488.6 used,   1682.7 buff/cache
          MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7703.2 avail Mem
          *** FAILED SERVICES ***
            UNIT                        LOAD   ACTIVE SUB    DESCRIPTION
          * apparmor.service            loaded failed failed Load AppArmor profiles
          * iobroker.service            loaded failed failed ioBroker Server
          * networkd-dispatcher.service loaded failed failed Dispatcher daemon for systemd-networkd
          * systemd-sysusers.service    loaded failed failed Create System Users
          * unattended-upgrades.service loaded failed failed Unattended Upgrades Shutdown
          5 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                       Type   Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--107--disk--0 ext4    98G   23G   71G  24% /
          none                             tmpfs  492K  4.0K  488K   1% /dev
          tmpfs                            tmpfs   32G     0   32G   0% /dev/shm
          tmpfs                            tmpfs   13G  148K   13G   1% /run
          tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
          tmpfs                            tmpfs  6.3G     0  6.3G   0% /run/user/1002
          [Fri Aug 16 23:00:14 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:00:14 2024] EXT4-fs (dm-29): mounted filesystem 6cb11462-725e-4ef5-a82e-1dd5619f4256 ro without journal. Quota mode: none.
          [Fri Aug 16 23:00:32 2024] EXT4-fs (dm-29): unmounting filesystem 6cb11462-725e-4ef5-a82e-1dd5619f4256.
          [Fri Aug 16 23:00:32 2024] EXT4-fs (dm-17): mounted filesystem 92d97cc4-4866-46a1-9c25-8700a3ec0e70 r/w with ordered data mode. Quota mode: none.
          [Fri Aug 16 23:00:41 2024] EXT4-fs (dm-17): unmounting filesystem 92d97cc4-4866-46a1-9c25-8700a3ec0e70.
          [Fri Aug 16 23:00:42 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:00:42 2024] EXT4-fs (dm-29): mounted filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267 ro without journal. Quota mode: none.
          [Fri Aug 16 23:02:05 2024] EXT4-fs (dm-29): unmounting filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267.
          [Fri Aug 16 23:02:07 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:02:07 2024] EXT4-fs (dm-29): mounted filesystem 09c4fcf9-be1a-4e4b-9212-4fe9120b6112 ro without journal. Quota mode: none.
          [Fri Aug 16 23:02:20 2024] EXT4-fs (dm-29): unmounting filesystem 09c4fcf9-be1a-4e4b-9212-4fe9120b6112.
          [Fri Aug 16 23:02:21 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:02:21 2024] EXT4-fs (dm-29): mounted filesystem f55e38cf-c8af-4660-80fb-2b3874cf34b7 ro without journal. Quota mode: none.
          [Fri Aug 16 23:02:46 2024] EXT4-fs (dm-29): unmounting filesystem f55e38cf-c8af-4660-80fb-2b3874cf34b7.
          [Fri Aug 16 23:02:46 2024] EXT4-fs (dm-29): mounted filesystem e588106e-e4ec-4e88-82a7-a8283f7db9d5 ro without journal. Quota mode: none.
          [Fri Aug 16 23:02:56 2024] EXT4-fs (dm-29): unmounting filesystem e588106e-e4ec-4e88-82a7-a8283f7db9d5.
          [Fri Aug 16 23:02:56 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:02:56 2024] EXT4-fs (dm-29): mounted filesystem 2061cbc0-6630-423c-b25c-c45b8704b39c ro without journal. Quota mode: none.
          [Fri Aug 16 23:03:15 2024] EXT4-fs (dm-29): unmounting filesystem 2061cbc0-6630-423c-b25c-c45b8704b39c.
          [Fri Aug 16 23:03:16 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:03:16 2024] EXT4-fs (dm-29): mounted filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8 ro without journal. Quota mode: none.
          [Fri Aug 16 23:06:46 2024] EXT4-fs (dm-29): unmounting filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8.
          [Fri Aug 16 23:06:47 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:06:47 2024] EXT4-fs (dm-29): mounted filesystem 5292950e-3110-4b44-9627-ccb93466bdb6 ro without journal. Quota mode: none.
          [Fri Aug 16 23:06:56 2024] EXT4-fs (dm-29): unmounting filesystem 5292950e-3110-4b44-9627-ccb93466bdb6.
          [Fri Aug 16 23:06:57 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:06:57 2024] EXT4-fs (dm-29): mounted filesystem 6766b937-5cf1-4e3a-9ac0-8e52e0aa7706 ro without journal. Quota mode: none.
          [Fri Aug 16 23:07:13 2024] EXT4-fs (dm-29): unmounting filesystem 6766b937-5cf1-4e3a-9ac0-8e52e0aa7706.
          [Fri Aug 16 23:07:14 2024] EXT4-fs (dm-29): mounted filesystem bd4590c2-e9a3-4fd9-b4ce-b70b34d8743a ro without journal. Quota mode: none.
          [Fri Aug 16 23:07:43 2024] EXT4-fs (dm-29): unmounting filesystem bd4590c2-e9a3-4fd9-b4ce-b70b34d8743a.
          [Fri Aug 16 23:08:39 2024] EXT4-fs (dm-19): mounted filesystem fe8a5df3-16f8-4fa9-843c-800ebaac2ec8 r/w with ordered data mode. Quota mode: none.
          [Fri Aug 16 23:09:21 2024] EXT4-fs (dm-19): unmounting filesystem fe8a5df3-16f8-4fa9-843c-800ebaac2ec8.
          [Fri Aug 16 23:09:21 2024] EXT4-fs (dm-28): mounted filesystem 6e9a2031-1c35-477c-9fec-0026551869bd ro without journal. Quota mode: none.
          [Fri Aug 16 23:10:02 2024] EXT4-fs (dm-28): unmounting filesystem 6e9a2031-1c35-477c-9fec-0026551869bd.
          [Fri Aug 16 23:10:03 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:10:03 2024] EXT4-fs (dm-29): mounted filesystem 7946a8f2-4b31-47db-ab3b-45c146de8f9f ro without journal. Quota mode: none.
          [Fri Aug 16 23:12:10 2024] EXT4-fs (dm-29): unmounting filesystem 7946a8f2-4b31-47db-ab3b-45c146de8f9f.
          [Fri Aug 16 23:12:11 2024] EXT4-fs (dm-29): mounted filesystem 6064ea71-3cd7-4c09-add6-d57d0062cfaf ro without journal. Quota mode: none.
          [Fri Aug 16 23:12:33 2024] EXT4-fs (dm-29): unmounting filesystem 6064ea71-3cd7-4c09-add6-d57d0062cfaf.
          [Fri Aug 16 23:12:34 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Fri Aug 16 23:12:34 2024] EXT4-fs (dm-29): mounted filesystem 2d0f14a9-f7f8-4e27-99f8-fe6600e75602 ro without journal. Quota mode: none.
          [Fri Aug 16 23:13:59 2024] EXT4-fs (dm-29): unmounting filesystem 2d0f14a9-f7f8-4e27-99f8-fe6600e75602.
          [Fri Aug 16 23:39:22 2024] EXT4-fs (dm-23): unmounting filesystem 3531f713-7070-49bd-baf7-cea479bbbe46.
          [Sat Aug 17 23:00:13 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:00:13 2024] EXT4-fs (dm-29): mounted filesystem 6cb11462-725e-4ef5-a82e-1dd5619f4256 ro without journal. Quota mode: none.
          [Sat Aug 17 23:00:41 2024] EXT4-fs (dm-29): unmounting filesystem 6cb11462-725e-4ef5-a82e-1dd5619f4256.
          [Sat Aug 17 23:00:41 2024] EXT4-fs (dm-17): mounted filesystem 92d97cc4-4866-46a1-9c25-8700a3ec0e70 r/w with ordered data mode. Quota mode: none.
          [Sat Aug 17 23:00:52 2024] EXT4-fs (dm-17): unmounting filesystem 92d97cc4-4866-46a1-9c25-8700a3ec0e70.
          [Sat Aug 17 23:00:53 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:00:53 2024] EXT4-fs (dm-29): mounted filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267 ro without journal. Quota mode: none.
          [Sat Aug 17 23:02:26 2024] EXT4-fs (dm-29): unmounting filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267.
          [Sat Aug 17 23:02:27 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:02:27 2024] EXT4-fs (dm-29): mounted filesystem 09c4fcf9-be1a-4e4b-9212-4fe9120b6112 ro without journal. Quota mode: none.
          [Sat Aug 17 23:02:41 2024] EXT4-fs (dm-29): unmounting filesystem 09c4fcf9-be1a-4e4b-9212-4fe9120b6112.
          [Sat Aug 17 23:02:42 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:02:42 2024] EXT4-fs (dm-29): mounted filesystem f55e38cf-c8af-4660-80fb-2b3874cf34b7 ro without journal. Quota mode: none.
          [Sat Aug 17 23:03:12 2024] EXT4-fs (dm-29): unmounting filesystem f55e38cf-c8af-4660-80fb-2b3874cf34b7.
          [Sat Aug 17 23:03:13 2024] EXT4-fs (dm-29): mounted filesystem e588106e-e4ec-4e88-82a7-a8283f7db9d5 ro without journal. Quota mode: none.
          [Sat Aug 17 23:03:22 2024] EXT4-fs (dm-29): unmounting filesystem e588106e-e4ec-4e88-82a7-a8283f7db9d5.
          [Sat Aug 17 23:03:23 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:03:23 2024] EXT4-fs (dm-29): mounted filesystem 2061cbc0-6630-423c-b25c-c45b8704b39c ro without journal. Quota mode: none.
          [Sat Aug 17 23:03:41 2024] EXT4-fs (dm-29): unmounting filesystem 2061cbc0-6630-423c-b25c-c45b8704b39c.
          [Sat Aug 17 23:03:42 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:03:42 2024] EXT4-fs (dm-29): mounted filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8 ro without journal. Quota mode: none.
          [Sat Aug 17 23:07:19 2024] EXT4-fs (dm-29): unmounting filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8.
          [Sat Aug 17 23:07:20 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:07:20 2024] EXT4-fs (dm-29): mounted filesystem 5292950e-3110-4b44-9627-ccb93466bdb6 ro without journal. Quota mode: none.
          [Sat Aug 17 23:07:30 2024] EXT4-fs (dm-29): unmounting filesystem 5292950e-3110-4b44-9627-ccb93466bdb6.
          [Sat Aug 17 23:07:31 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:07:31 2024] EXT4-fs (dm-29): mounted filesystem 6766b937-5cf1-4e3a-9ac0-8e52e0aa7706 ro without journal. Quota mode: none.
          [Sat Aug 17 23:07:46 2024] EXT4-fs (dm-29): unmounting filesystem 6766b937-5cf1-4e3a-9ac0-8e52e0aa7706.
          [Sat Aug 17 23:07:47 2024] EXT4-fs (dm-29): mounted filesystem bd4590c2-e9a3-4fd9-b4ce-b70b34d8743a ro without journal. Quota mode: none.
          [Sat Aug 17 23:08:14 2024] EXT4-fs (dm-29): unmounting filesystem bd4590c2-e9a3-4fd9-b4ce-b70b34d8743a.
          [Sat Aug 17 23:09:52 2024] EXT4-fs (dm-19): mounted filesystem fe8a5df3-16f8-4fa9-843c-800ebaac2ec8 r/w with ordered data mode. Quota mode: none.
          [Sat Aug 17 23:10:16 2024] EXT4-fs (dm-19): unmounting filesystem fe8a5df3-16f8-4fa9-843c-800ebaac2ec8.
          [Sat Aug 17 23:10:16 2024] EXT4-fs (dm-28): mounted filesystem 6e9a2031-1c35-477c-9fec-0026551869bd ro without journal. Quota mode: none.
          [Sat Aug 17 23:11:02 2024] EXT4-fs (dm-28): unmounting filesystem 6e9a2031-1c35-477c-9fec-0026551869bd.
          [Sat Aug 17 23:11:03 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:11:03 2024] EXT4-fs (dm-29): mounted filesystem 7946a8f2-4b31-47db-ab3b-45c146de8f9f ro without journal. Quota mode: none.
          [Sat Aug 17 23:13:01 2024] EXT4-fs (dm-29): unmounting filesystem 7946a8f2-4b31-47db-ab3b-45c146de8f9f.
          [Sat Aug 17 23:13:02 2024] EXT4-fs (dm-29): mounted filesystem 6064ea71-3cd7-4c09-add6-d57d0062cfaf ro without journal. Quota mode: none.
          [Sat Aug 17 23:13:24 2024] EXT4-fs (dm-29): unmounting filesystem 6064ea71-3cd7-4c09-add6-d57d0062cfaf.
          [Sat Aug 17 23:13:24 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
          [Sat Aug 17 23:13:24 2024] EXT4-fs (dm-29): mounted filesystem 2d0f14a9-f7f8-4e27-99f8-fe6600e75602 ro without journal. Quota mode: none.
          [Sat Aug 17 23:14:50 2024] EXT4-fs (dm-29): unmounting filesystem 2d0f14a9-f7f8-4e27-99f8-fe6600e75602.
          [Sun Aug 18 11:12:58 2024] EXT4-fs (dm-16): unmounting filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267.
          [Sun Aug 18 11:12:59 2024] EXT4-fs (dm-16): mounted filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267 r/w with ordered data mode. Quota mode: none.
          [Sun Aug 18 11:26:08 2024] EXT4-fs (dm-16): unmounting filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267.
          [Sun Aug 18 11:26:09 2024] EXT4-fs (dm-16): mounted filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267 r/w with ordered data mode. Quota mode: none.
          [Sun Aug 18 14:31:18 2024] EXT4-fs (dm-15): unmounting filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8.
          [Sun Aug 18 14:31:19 2024] EXT4-fs (dm-15): mounted filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8 r/w with ordered data mode. Quota mode: none.
          Show mounted filesystems:
          TARGET                                SOURCE                           FSTYPE     OPTIONS
          /                                     /dev/mapper/pve-vm--107--disk--0 ext4       rw,relatime,stripe=16
          |-/run                                tmpfs                            tmpfs      rw,nosuid,nodev,size=13084708k,nr_inodes=819200,mode=755,inode64
          | |-/run/lock                         tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
          | |-/run/rpc_pipefs                   sunrpc                           rpc_pipefs ro,relatime
          | `-/run/user/1002                    tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=6542352k,nr_inodes=1635588,mode=700,uid=1002,gid=1002,inode64
          |-/dev                                none                             tmpfs      rw,relatime,size=492k,mode=755,inode64
          | |-/dev/shm                          tmpfs                            tmpfs      rw,nosuid,nodev,inode64
          | |-/dev/hugepages                    hugetlbfs                        hugetlbfs  rw,relatime,pagesize=2M
          | |-/dev/mqueue                       mqueue                           mqueue     rw,relatime
          | |-/dev/bus/usb/001/003              udev[/bus/usb/001/003]           devtmpfs   rw,nosuid,relatime,size=32677884k,nr_inodes=8169471,mode=755,inode64
          | |-/dev/ttyUSB0                      udev[/ttyUSB0]                   devtmpfs   rw,nosuid,relatime,size=32677884k,nr_inodes=8169471,mode=755,inode64
          | |-/dev/bus/usb/001/002              udev[/bus/usb/001/002]           devtmpfs   rw,nosuid,relatime,size=32677884k,nr_inodes=8169471,mode=755,inode64
          | |-/dev/ttyUSB1                      udev[/ttyUSB1]                   devtmpfs   rw,nosuid,relatime,size=32677884k,nr_inodes=8169471,mode=755,inode64
          | |-/dev/pts                          devpts                           devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
          | |-/dev/ptmx                         devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
          | |-/dev/lxc/console                  devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
          | |-/dev/console                      devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
          | |-/dev/lxc/tty1                     devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
          | `-/dev/lxc/tty2                     devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
          |-/proc                               proc                             proc       rw,nosuid,nodev,noexec,relatime
          | |-/proc/sys                         proc[/sys]                       proc       ro,relatime
          | | |-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,inode64
          | | `-/proc/sys/net                   proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
          | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc       ro,relatime
          | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          `-/sys                                sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
            |-/sys/fs/fuse/connections          fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
            |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
            |-/sys/kernel/debug                 debugfs                          debugfs    rw,nosuid,nodev,noexec,relatime
            |-/sys/kernel/security              securityfs                       securityfs rw,nosuid,nodev,noexec,relatime
            |-/sys/fs/pstore                    pstore                           pstore     rw,nosuid,nodev,noexec,relatime
            |-/sys/fs/cgroup                    none                             cgroup2    rw,nosuid,nodev,noexec,relatime
            `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          5.2G    /var/
          4.3G    /var/log
          4.0G    /var/log/journal/2a2fff2f04dc408d995be9b80a65a02e
          756M    /var/lib
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          1.1G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          sort: write failed: 'standard output': Broken pipe
          sort: write error
          1.6G    /opt/iobroker/iobroker-data/
          1.3G    /opt/iobroker/iobroker-data/files
          442M    /opt/iobroker/iobroker-data/files/javascript.admin
          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          sort: write error
          35M     /opt/iobroker/iobroker-data/objects.jsonl
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.16.0
          /usr/bin/node           v20.16.0
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          /usr/bin/corepack       0.28.2
          nodejs:
            Installed: 20.16.0-1nodesource1
            Candidate: 20.16.0-1nodesource1
            Version table:
           *** 20.16.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               12.22.9~dfsg-1ubuntu3.6 500
                  500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                  500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
               12.22.9~dfsg-1ubuntu3 500
                  500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          iobroker is not running on this host.
          Objects type: jsonl
          States  type: redis
          Core adapters versions
          js-controller:  6.0.9
          admin:          7.0.22
          javascript:     8.7.6
          nodejs modules from github:     2
          | | | | | `-- reconnect-core@0.0.1 invalid: "https://github.com/dodo/reconnect-core/tarball/merged" from node_modules/node-xmpp-core
          +-- iobroker.icons-open-icon-library-png@0.1.3 invalid: "https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master" from the root project
          Adapter State
            system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.backitup.1               : backitup              : raspberrypi                              -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
            system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
            system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
            system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 - disabled
            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 - disabled
            system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
            system.adapter.gruenbeck.0              : gruenbeck             : iobroker                                 - disabled
            system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 - disabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
            system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
            system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
            system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.kecontact.0              : kecontact             : iobroker                                 -  enabled
            system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
            system.adapter.mpd.0                    : mpd                   : raspberrypi                              -  enabled, port: 6600
            system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
            system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
            system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
            system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 - disabled
            system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
            system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
            system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
            system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
            system.adapter.reolink.0                : reolink               : iobroker                                 - disabled
            system.adapter.robonect.0               : robonect              : iobroker                                 - disabled
            system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
            system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.signal-cmb.0             : signal-cmb            : iobroker                                 -  enabled
            system.adapter.signal-cmb.1             : signal-cmb            : iobroker                                 -  enabled
            system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
            system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
            system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
            system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.0.22   , installed 7.0.22
          Adapter    "backitup"     : 3.0.16   , installed 3.0.16
          Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "devices"      : 1.1.5    , installed 1.1.5
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
          Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
          Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
          Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.43
          Adapter    "homekit-controller": 0.5.10, installed 0.5.10
          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.9    , installed 6.0.9
          Adapter    "kecontact"    : 2.2.0    , installed 2.2.0
          Adapter    "modbus"       : 6.2.3    , installed 6.2.3
          Adapter    "mpd"          : 2.1.0    , installed 2.1.0
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
          Adapter    "reolink"      : 1.1.0    , installed 1.1.0
          Adapter    "robonect"     : 1.3.6    , installed 1.3.6
          Adapter    "scenes"       : 3.2.1    , installed 3.2.1
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
          Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 6.2.5    , installed 6.2.5
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Objects and States
          Objects:        16130
          States:         10635
          Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
          Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        161129393  104/systemd-resolve
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          161145003  383/master
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      108        161144945  161/influxd
          tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      112        161144011  165/redis-server 0.
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          161129157  1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          161144026  244/sshd: /usr/sbin
          tcp6       0      0 ::1:6379                :::*                    LISTEN      112        161144012  165/redis-server 0.
          tcp6       0      0 :::8086                 :::*                    LISTEN      108        161145391  161/influxd
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          161145004  383/master
          tcp6       0      0 :::111                  :::*                    LISTEN      0          161129159  1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          161144037  244/sshd: /usr/sbin
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        161129392  104/systemd-resolve
          udp        0      0 192.168.178.138:68      0.0.0.0:*                           101        161137405  94/systemd-networkd
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          161129158  1/init
          udp6       0      0 :::111                  :::*                                0          161129160  1/init
          2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]:     at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3032:37)
          2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]:     at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3093:33)
          2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:478:21)
          2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]: Error: DB closed
          2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
          2024-08-18 15:08:17.588  - error: host.iobroker Caught by controller[1]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
          2024-08-18 15:08:17.588  - error: host.iobroker Caught by controller[1]:     at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3032:37)
          2024-08-18 15:08:17.588  - error: host.iobroker Caught by controller[1]:     at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3093:33)
          2024-08-18 15:08:17.588  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:478:21)
          2024-08-18 15:08:17.588  - info: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
          2024-08-18 15:08:17.626  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
          2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]: Error: Connection is closed.
          2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
          2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
          2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at ObjectsInRedisClient._setObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3455:45)
          2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3687:44)
          2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at processImmediate (node:internal/timers:478:21)
          2024-08-18 15:08:17.641  - info: host.iobroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
          2024-08-18 15:08:17.641  - info: host.iobroker All instances are stopped.
          2024-08-18 15:08:17.682  - warn: host.iobroker instance system.adapter.pushover.0 terminated due to SIGKILL
          2024-08-18 15:08:17.682  - info: host.iobroker instance system.adapter.pushover.0 terminated with code null ()
          2024-08-18 15:08:17.683  - info: host.iobroker All instances are stopped.
          2024-08-18 15:08:17.842  - info: host.iobroker terminated
            @merowinger
            iob diag
            nun.
            Merowinger
            @thomas-braun Copy text starting here:
                                    v.2024-05-22
                     Chassis: container
              Virtualization: lxc
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               64 bit
            User-ID:                1002
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:
            /usr/bin/npm            10.8.1
            /usr/bin/npx            10.8.1
            Recommended versions are nodejs 20.16.0 and npm 10.8.1
            MEMORY:
            Mem:            8.2G        493M        6.0G        0.0K        1.7G        7.7G
            Swap:           1.0G          0B        1.0G
            Total:          9.2G        493M        7.0G
            ioBroker Core:          js-controller           6.0.9
                                    admin                   7.0.22
            ioBroker Status:        iobroker is not running on this host.
            Objects type: jsonl
            States  type: redis
            Objects:                16130
            States:                 10635
            Size of iob-Database:
            11M     /opt/iobroker/iobroker-data/objects.json.migrated
            11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            9.3M    /opt/iobroker/iobroker-data/states.jsonl
            1.7M    /opt/iobroker/iobroker-data/states.json.migrated
            1.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
            === Mark text until here for copying ===
            • M Merowinger
              ja und?
              das wird genauso ringerichtet wie jede native Linux Installation.
              anscheinend ja nicht richtig, was immer das ist.
              • M Merowinger
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                         Chassis: container
                  Virtualization: lxc
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 2
                                 RTC time: n/a
                          RTC in local TZ: no
                Benny
                HOME=/home/Benny
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           1.0G          0B        1.0G
                         8192 M total memory
                          488 M used memory
                          500 M active memory
                         6020 M free memory
                            0 M buffer memory
                         1682 M swap cache
                         1024 M total swap
                            0 M used swap
                         1024 M free swap
                *** FILESYSTEM ***
                /var:
                5.2G    /var/
                4.3G    /var/log
                756M    /var/lib
                sort: write error
                sort: write error
                USB-Devices by-id:
                /usr/bin/npm            10.8.1
                /usr/bin/npx            10.8.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                admin:          7.0.22
                javascript:     8.7.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        16130
                States:         10635
                Pending Updates: 0
                Boot Target: graphical.target
                Schalt das auf multi-user um.
                sudo systemctl set-default multi-user.target
                Warum failen da gleich 5 Services?
                Setz den Benny da rein:
                sudo usermod -aG adm Benny
                Spendier ja in Kürze einen aktuellen Container. Schnubbibunti 20.04 'jammy' läuft läus.
                • M Merowinger
                  reutli
                  Das geht durchaus in Proxmox im Contaiber statt
                  pct enter
                  einen
                  ssh
                  zu nutzen:
                  einfach im Container die '/etc/ssh/sshd_config" editieren und dort aus
                  PermitRootLogin without-password
                  ein
                  PermitRootLogin yes
                  machen, dann klappt es auch mit SSH.
                  siehe z.B.: https://forum.proxmox.com/threads/cannot-ssh-to-new-container.38114/
                  iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                  *Wer freundlich ist, dem wird freundlich geholfen *
                  M HomoranH 2 Antworten Letzte Antwort
                  • R reutli
                    pct enter
                    einen
                    ssh
                    zu nutzen:
                    ein
                    PermitRootLogin yes
                    Merowinger
                    @reutli Vielen Dank. Ich weiß, versuche aber auch intern so wenig Ports offen zu haben wie möglich.
                    • R reutli
                      pct enter
                      einen
                      ssh
                      zu nutzen:
                      ein
                      PermitRootLogin yes
                      @reutli Wieso root-login?
                      Was soll der Quatsch!
                      und dann noch root login per SSH freischalten???
                      Da wird ein stinknormaler User angelegt und der SSH Zugang über diesen genutzt!
                      Der verlinkte Thread ist übrigens steinalt!
                      M R 2 Antworten Letzte Antwort
                        Merowinger
                        @homoran Ganz genau, dafür habe ich auch schon vor langer Zeit einen nutzer im iobroker angelegt. Nur hat noch was bei den Rechten gefehlt.
                        Vielen Dank!
                        • M Merowinger
                          Vielen Dank!
                          nee, im Linux musst du den anlegen!
                            Merowinger
                            @homoran hihi für mich ists der iobroker-Container :-)
                              reutli
                              schrieb am zuletzt editiert von reutli
                              @homoran sagte in iob Befehle werden nicht ausgeführt:
                              ...das hat mit "root" nichts zu tun, sondern damit, dass man sich per ssh und passwort auf den container verbinden kann. ich melde mich auf meinen proxmox containern nie mit root an....
                              aber immer noch gültig.
                              • R reutli
                                Merowinger
                                @reutli Also vielen lieben Dank für die Hilfe.
                                Für mich sind alle Fragen geklärt.
                                Von mir aus kann der Thread gerne geschlossen werden.
                                • R reutli
                                  @reutli sagte in iob Befehle werden nicht ausgeführt:
                                  Natürlich hat es das!
                                  dazu musst du aber nicht den root-login freischalten!
                                  Der SSH Server muss bei der Installation des OS aktiviert, und ein User angelegt werden.
                                  Der Root darf kein Passwort bekommen!
                                  R 1 Antwort Letzte Antwort
                                    reutli
                                    Gut, nehme ich so hin.
                                    Vielleicht gibt es hier noch Proxmox Spezialisten, die das Verhalten des SSH Deamon in Proxmox erklären können. Wenn man nach SSH Zugriff (ganz ohne root) sucht, findet man überall die gleichen Anleitungen.
                                    Wenn das also alles Quatsch ist, was ich nciht bewerten aknn, dann lösch bitte alle meine Einträge in diesem Post.
                                    Nichts für ungut... :man-shrugging:
                                    • R reutli
                                      @reutli du musst unterscheiden ob es sich um Zugriff auf das PVE oder um den Zugriff in einen lcx/VM handelt!
                                      EDIT:
                                      Vorgehen bei der Installation siehe hier
                                      https://www.iobroker.net/#de/documentation/install/proxmox.md
                                      lxc etwas weiter unten
                                        EDIT:
                                        Meister MopperM Online
                                        Meister Mopper
                                        schrieb am zuletzt editiert von Meister Mopper
                                        EDIT:
                                        Der root login ist auf VM/LXC bei mir tatsächlich nicht möglich. Beim node aber sehr wohl.
                                        Weiß jetzt nicht wie und warum ich das ändern sollte.
                                        ╭╴at  ~ took 30m56s
                                        ╰─ ssh root@192.168.178.10
                                        root@192.168.178.10's password:
                                        Permission denied, please try again.
                                        root@192.168.178.10: Permission denied (publickey,password).
                                        ╭╴at  ~ took 49s
                                        ╰─ ssh root@192.168.1.7
                                        root@192.168.1.7's password:
                                        Linux HA-PVE-01 6.8.12-1-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-1 (2024-08-05T16:17Z) x86_64
                                        permitted by applicable law.
                                        Last login: Sun Aug 18 18:39:30 2024
                                        root@HA-PVE-01:~#
                                        Proxmox und HA ...
                                          EDIT:
                                          ╭╴at  ~ took 49s
                                          root@HA-PVE-01:~#
                                          @meister-mopper sagte in iob Befehle werden nicht ausgeführt:
                                          ich arbeite mich jetztvzwar seit einigen Jahren immer ein wenig tiefer in Linux ein (Thomas sei Dank!) aber so richtig kenne ich mich auch noch nicht aus.
                                          Ganz prinzipiell ist der root-Zugriff per Remote natürlich ein Sicherheitsrisiko, insbesondere, wenn man dann noch die Passwortabfrage deaktivieren würde.
                                          Da man auch über die GUI da als root einsteigt, wäre das aber erstmal alles.
                                          ich glaube allerdings inzwischen kann man auch in der pve einen normalen User mit Sudo-Rechten anlegen.
                                          Ob das bei Proxmox einen Unterschied ausmacht was die Rechteverbiegung angeht, weiss ich nicht.
