  4. [Adapter] cloudfreie Auslesung von Deye-Invertern
1.2k Beiträge 114 Kommentatoren 514.7k Aufrufe 93 Beobachtet
    @rene55
    Hab nochmal geupdated, hier das komplette log:
    2024-07-30 19:34:01.818  - info: deyeidc.0 (27892) Got terminate signal TERMINATE_YOURSELF
    2024-07-30 19:34:01.821  - info: deyeidc.0 (27892) terminating
    2024-07-30 19:34:01.822  - info: deyeidc.0 (27892) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-07-30 19:34:02.323  - info: deyeidc.0 (27892) terminating
    2024-07-30 19:34:02.364  - info: host.iobroker instance system.adapter.deyeidc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-07-30 19:34:03.616  - error: deyeidc.1 (27898) TypeError: Cannot read properties of undefined (reading 'register') | TypeError: Cannot read properties of undefined (reading 'register')
        at Deyeidc.onData (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:166:11)
        at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:152:10)
        at Socket.emit (node:events:520:28)
        at addChunk (node:internal/streams/readable:559:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:510:3)
        at Readable.push (node:internal/streams/readable:390:5)
        at TCP.onStreamRead (node:internal/stream_base_commons:191:23)
    2024-07-30 19:34:05.743  - info: host.iobroker instance system.adapter.deyeidc.0 in version "0.0.15" started with pid 28018
    2024-07-30 19:34:06.049  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570,1705223,1298708,1044933,1522909","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254,48672,22736,41801,43259","Newprio_realtime_bps":"4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773,7709,2165,601,4247","Newprio_high_bps":"39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064,40081,18365,40277,37998","Newprio_default_bps":"1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417,882,2206,923,1014","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
    2024-07-30 19:34:06.548  - debug: deyeidc.0 (28018) Redis Objects: Use Redis connection: 10.10.2.10:6379
    2024-07-30 19:34:06.575  - debug: deyeidc.0 (28018) Objects client ready ... initialize now
    2024-07-30 19:34:06.576  - debug: deyeidc.0 (28018) Objects create System PubSub Client
    2024-07-30 19:34:06.578  - debug: deyeidc.0 (28018) Objects create User PubSub Client
    2024-07-30 19:34:06.832  - debug: deyeidc.0 (28018) Objects client initialize lua scripts
    2024-07-30 19:34:06.840  - debug: deyeidc.0 (28018) Objects connected to redis: 10.10.2.10:6379
    2024-07-30 19:34:06.858  - debug: deyeidc.0 (28018) Redis States: Use Redis connection: 10.10.2.10:6379
    2024-07-30 19:34:06.864  - debug: deyeidc.0 (28018) States create System PubSub Client
    2024-07-30 19:34:06.865  - debug: deyeidc.0 (28018) States create User PubSub Client
    2024-07-30 19:34:06.871  - debug: deyeidc.0 (28018) States connected to redis: 10.10.2.10:6379
    2024-07-30 19:34:07.443  - info: deyeidc.0 (28018) starting. Version 0.0.15 in /opt/iobroker/node_modules/iobroker.deyeidc, node: v22.5.1, js-controller: 6.0.9
    2024-07-30 19:34:07.469  - debug: deyeidc.0 (28018) IP address [10.1.1.100] seems to be valid.
    2024-07-30 19:34:07.470  - info: deyeidc.0 (28018) Retrieving data from the inverter will be done every 60 seconds
    2024-07-30 19:34:07.470  - debug: deyeidc.0 (28018) checkUserData is ready
    2024-07-30 19:34:07.470  - debug: deyeidc.0 (28018) try to connect . . .
    2024-07-30 19:34:07.477  - debug: deyeidc.0 (28018) Connected to server
    2024-07-30 19:34:07.650  - debug: deyeidc.0 (28018) Response: {"register":1,"modbus":{"type":"Buffer","data":[1,3,44,0,4,1,0,2,1,50,50,48,50,50,52,49,52,56,56,0,1,0,0,18,12,7,0,0,0,1,18,2,7,0,0,11,184,0,0,1,1,0,75,0,0,0,60,59]}}
    2024-07-30 19:34:08.243  - debug: deyeidc.0 (28018) Response: {"register":2,"modbus":{"type":"Buffer","data":[1,3,64,0,4,0,13,0,0,0,0,20,106,0,0,0,13,0,0,0,0,0,0,20,106,0,0,0,0,0,0,9,46,0,0,0,0,0,0,0,0,0,0,19,136,0,0,0,0,0,0,0,0,0,0,0,0,6,54,0,0,0,0,0,0,21,54,117]}}
    2024-07-30 19:34:08.469  - debug: deyeidc.0 (28018) Response: {"register":3,"modbus":{"type":"Buffer","data":[1,3,8,1,97,0,45,0,0,0,0,136]}}
    2024-07-30 19:34:08.564  - debug: deyeidc.0 (28018) Response: {"register":4,"modbus":{"type":"Buffer","data":[1,3,8,10,190,7,8,20,80,18,142,34]}}
    2024-07-30 19:34:08.579  - debug: deyeidc.0 (28018) Data reception for 4 registersets completed
    2024-07-30 19:34:08.580  - debug: deyeidc.0 (28018) [computeData]  {"value1":"DV1","value2":"DC1","key":"DP1","name":"DC Power PV1","unit":"W","factor":0,"values":"DV1*DC1"}
    2024-07-30 19:34:08.581  - debug: deyeidc.0 (28018) [computeData]  {"value1":"DV2","value2":"DC2","key":"DP2","name":"DC Power PV2","unit":"W","factor":0,"values":"DV2*DC2"}
    2024-07-30 19:34:08.581  - debug: deyeidc.0 (28018) [computeData] ResultJson: [{"key":"DP1","value":"158.85","unit":"W","name":"DC Power PV1"},{"key":"DP2","value":"0.00","unit":"W","name":"DC Power PV2"}]
    2024-07-30 19:34:08.600  - debug: deyeidc.0 (28018) [watchStates] set to Power_Set
    2024-07-30 19:34:09.059  - info: tuya.0 (10496) bf51aaad135aa1ced0dhmw: Error on Reconnect (5): connect EHOSTUNREACH 10.1.12.101:6668
    2024-07-30 19:34:10.353  - info: influxdb.0 (7447) Store 1001 buffered influxDB history points
    2024-07-30 19:34:12.050  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"1523785,1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570,1705223,1298708,1044933","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"49992,45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254,48672,22736,41801","Newprio_realtime_bps":"10254,4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773,7709,2165,601","Newprio_high_bps":"38753,39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064,40081,18365,40277","Newprio_default_bps":"985,1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417,882,2206,923","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
    2024-07-30 19:34:18.052  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"921663,1523785,1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570,1705223,1298708","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"27837,49992,45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254,48672,22736","Newprio_realtime_bps":"3840,10254,4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773,7709,2165","Newprio_high_bps":"21802,38753,39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064,40081,18365","Newprio_default_bps":"2195,985,1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417,882,2206","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
    2024-07-30 19:34:19.827  - info: tuya.0 (10496) bf36cda59741f65a3evbfd: Error on Reconnect (7): connect EHOSTUNREACH 10.1.5.86:6668
    2024-07-30 19:34:21.228  - info: linux-control.0 (2133) getting data from Influxdb (10.1.1.4:22)
    2024-07-30 19:34:22.803  - info: tuya.0 (10496) bf36cda59741f65a3evbfd: Connect locally to device
    2024-07-30 19:34:22.803  - info: tuya.0 (10496) bf36cda59741f65a3evbfd Init with IP=10.1.5.86, Key=Y''bS^'ldE@_g'}d, Version=3.3
    2024-07-30 19:34:22.833  - info: tuya.0 (10496) bf36cda59741f65a3evbfd: Error on Reconnect (1): connect EHOSTUNREACH 10.1.5.86:6668
    2024-07-30 19:34:24.017  - info: host.iobroker instance system.adapter.oilfox.0 in version "4.3.0" started with pid 28087
    2024-07-30 19:34:24.432  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"1817837,921663,1523785,1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570,1705223","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"47909,27837,49992,45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254,48672","Newprio_realtime_bps":"1609,3840,10254,4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773,7709","Newprio_high_bps":"45132,21802,38753,39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064,40081","Newprio_default_bps":"1168,2195,985,1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417,882","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
    2024-07-30 19:34:25.255  - info: linux-control.0 (2133) successful received data from Influxdb (10.1.1.4:22)
    2024-07-30 19:34:26.003  - info: oilfox.0 (28087) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v22.5.1, js-controller: 6.0.9
    2024-07-30 19:34:27.653  - info: oilfox.0 (28087) Terminated (NO_ERROR): Without reason
    2024-07-30 19:34:28.179  - info: host.iobroker instance system.adapter.oilfox.0 having pid 28087 terminated with code 0 (NO_ERROR)
    2024-07-30 19:34:30.046  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"1492501,1817837,921663,1523785,1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"52177,47909,27837,49992,45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254","Newprio_realtime_bps":"14472,1609,3840,10254,4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773","Newprio_high_bps":"36303,45132,21802,38753,39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064","Newprio_default_bps":"1402,1168,2195,985,1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
    2024-07-30 19:34:33.132  - error: deyeidc.0 (28018) TypeError: Cannot read properties of undefined (reading 'register') | TypeError: Cannot read properties of undefined (reading 'register')
    ^C
    Auch die Instanzen geloescht, dann nur eine neu angelegt, die Konfig importiert, aber gleicher Fehler...
    Also wenn das Nachvollziehbar ist, dann sollte der Fehler doch zu finden sein.. ?
    Rene55R Online
    Rene55R Online
    Rene55
    #949
    @ilovegym Ich habe heute nochmal geforscht. Kannst du bitte mal den Adapter direkt von Github installieren?
    • Rene55R Rene55
      #950
      @rene55
      Siehe da, kaum macht man's richtig... :). die Github Version geht ohne Fehler!
      Danke!!
        @rene55
        Danke!!
        Rene55R Online
        Rene55R Online
        Rene55
        #951
        @ilovegym Super. Ich hab ja auch dran gearbeitet. 😊
        Wenn keine Fehler mehr auftreten mache ich morgen die 0.0.16
          MPF
          schrieb am zuletzt editiert von MPF
          #952
          Moin,
          ich habe komischerweise jetzt die Adapterversion 0.1.0 drauf und diese Warnungen im Log :
          • Rene55R Online
            Rene55R Online
            Rene55
            #953
            @mpf Ist nicht komisch, 'is a feature'. Der Adapter prüft jetzt, ob der Datenpunkt - in dem Fall "DV1" auch vorhanden ist. Eventuell bei den Coils mal nachsehen oder bei den Berechnungen die Formel prüfen.
            • Rene55R Rene55
              MPF
              #954
              @rene55 und die Version 0.1.0 ist so korrekt ?
              • M MPF
                Rene55R Online
                Rene55R Online
                Rene55
                #955
                @mpf Ich denke ja.
                • Rene55R Rene55
                  @mpf Ich denke ja.
                  MPF
                  #956
                  @rene55 sagte in [Adapter] cloudfreie Auslesung von Deye-Invertern:
                  @mpf Ich denke ja.
                  ist ja aktueller als 0.0.16.....
                  einwandfrei
                  Berechnung so korrekt ?
                  Wo finde ich den DP "DV1" ?
                  Oder einfach löschen, wenn ich den nicht benötige ?
                  • M MPF
                    @mpf Ich denke ja.
                    einwandfrei
                    Rene55R Online
                    Rene55R Online
                    Rene55
                    #957
                    @mpf Die Formel sieht doch gut aus. Der "DP1" wird bei der nächsten Datenabholung angelegt.
                    • J Offline
                      JoeM
                      #958
                      Hallo Rene, hallo Forum,
                      bei den Versuchen an gewisse Daten von meiner Solaranlage zu kommen, bin ich über diesen IOBroker Adapter gestolpert und habe ihn gleich installiert. Einrichten mit IP und Seriennummer war total einfach. Dafür also auf alle Fälle schonmal Danke Rene55.
                      Ich habe den SUN-5K-SG03LP1-EU und nachdem ich einige JSON Dateien von verschiedenen Geräten getestet habe, erhielt ich mit der SUN2000.json erste brauchbare Ergebnisse. Ich habe auch schon unnötige Datenpunkte aus dem Setting heraus gelöscht.
                      Jetzt stellt sich mir nur die Frage, wo finde ich Informationen welche Register welche (sinnvollen) Daten enthalten, damit ich evtl. das Setting erweitern kann?
                      Ich danke Euch schon einmal für Eure Hilfe.
                      • J JoeM
                        Rene55R Online
                        Rene55R Online
                        Rene55
                        #959
                        @joem Hallo, ja freut mich, dass der Adapter bei dir läuft.
                        Bei den Registern für die "großen" Wechselrichter war ich auch auf Input von eifrigen Nutzern angewiesen.
                        Gibt denn das Handbuch oder eine technische Anleitung keine Hinweise auf die verwendeten Register?
                        • F Offline
                          Fichte
                          #960
                          @Rene55
                          Ich habe das selbe Problem wie MPF.
                          Ich weiss aber nicht woran es liegt.
                          HAbe schon alles gecheckt und auch neu Installiert.
                          Evtl. Sehe ich den Wald vor Lauter bäumen nicht.
                          Was ist das problem?
                          @MPF Hast du schon eine Lösung?
                          Liebe Grüße
                          • Rene55R Online
                            Rene55R Online
                            Rene55
                            #961
                            @fichte Das bedeutet einfach, dass er zur Berechnung von Werten die Datenpunkte 'DV1' und 'DV2' haben möchte. Werden diese beiden Datenpunkte denn von den Coils erstellt/befüllt?
                            Ansonsten mal schauen, was in den 'Berechnungen' drin steht und ob du die Berechnung überhaupt brauchst.
                            F 1 Antwort Letzte Antwort
                            • Rene55R Rene55
                              Fichte
                              schrieb am zuletzt editiert von Fichte
                              #962
                              @rene55
                              Guten Morgen Rene
                              Danke für deine Antwort.
                              In meiner Berechnung steht dies ->
                              Woran sehe ich das die Daten Erstellt/Befüllt werden?
                              Die letze änderung war am 17.04.2024
                              • Rene55R Online
                                Rene55R Online
                                Rene55
                                schrieb am zuletzt editiert von Rene55
                                #963
                                @fichte Schau mal in den Objektbaum, da wo alle Werte abgelegt werden. Da sollten sich (neben vielen anderen Werten ) auch 'DV1', 'DV2', DC1' und 'DC2' finden lassen. Wenn die nicht da sind, müssen wir weiter forschen.
                                Sorry falsch gelesen:
                                BTW: 17.04.2024 ist auch schon ein bissl her. Das heißt aber auch, dass keine neuen Werte abgeholt werden.
                                • F Fichte
                                  @rene55
                                  Guten Morgen Rene
                                  Meintre 0
                                  #964
                                  @fichte
                                  Ich hatte auch diesen Fehler! Habe einfach die Berechnungen gelöscht und schon war der Fehler weg.
                                  Solltest Du die Berechnungen brauchen, mußt Du nachfolgendes kontrollieren:
                                  1. Gibt es unter Key im Objektbaum überhaupt alle Punkte "DV1" usw.
                                  2. Hast Du auch zwei Stränge am Deye angeschlossen? Bei mir fehlt der zweite Strang, dadurch ist wahrscheinlich der Fehler bei mir aufgetreten.
                                  Viel Spaß beim Überprüfen
                                  Gruß Meintre
                                  • F Offline
                                    Fichte
                                    #965
                                    @Meintre-0
                                    Ich habe die Berechnung raus genommen und der Fehler ist Tatsächlich weg 👍
                                    @Rene55
                                    Das Stimmt, die Werte werden seid dem 17.04 nicht meh geholt 🙄
                                    Woran kann dies liegen? Fehler habe ich sonst keine.
                                    Das sind meine Register
                                    Und hier meine Spulen
                                    • F Fichte
                                      @Meintre-0
                                      @Rene55
                                      Rene55R Online
                                      Rene55R Online
                                      Rene55
                                      #966
                                      @fichte Registerbereiche und Coils sehen gut aus (Standard). Ist der Wechselrichter denn überhaupt noch da ?? Hat sich die IP geändert? Ist der Adapter grün?
                                      • F Offline
                                        Fichte
                                        #967
                                        @Rene55
                                        Adapter Grün.
                                        Über IP Erreichbar (Webgui und Ping).
                                        Debug sieht so aus
                                        • F Fichte
                                          @Rene55
                                          Adapter Grün.
                                          Debug sieht so aus
                                          Rene55R Online
                                          Rene55R Online
                                          Rene55
                                          #968
                                          @fichte Ich bin etwas verstört. Welche Version vom Adapter ist das? Und welche Firmware ist auf dem WR?
