  4. Node.js v16.20.2 update v18.20.4 sinvoll ?
55 Beiträge 9 Kommentatoren 6.1k Aufrufe 7 Beobachtet
  • K klaris
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7+
          Architecture: arm
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     10:02:18 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    Previously detected issues:
    ~ Under-voltage has occurred
    *** Time and Time Zones ***
                   Local time: Fri 2024-08-16 10:02:19 CEST
               Universal time: Fri 2024-08-16 08:02:19 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            921M        714M         66M        0.0K        140M        154M
    Swap:            99M         99M        0.0K
    Total:          1.0G        813M         67M
    Active iob-Instances:   4
              921 M total memory
              713 M used memory
              164 M active memory
              620 M inactive memory
               66 M free memory
               13 M buffer memory
              127 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    top - 10:02:19 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
    Tasks: 150 total,   4 running, 146 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 60.9 us,  8.7 sy,  0.0 ni, 29.0 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
    MiB Mem :    922.0 total,     65.2 free,    715.1 used,    141.6 buff/cache
    MiB Swap:    100.0 total,      0.9 free,     99.1 used.    153.3 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  6.4G   22G  23% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
    tmpfs          tmpfs     185M  716K  184M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    [Fri Aug 16 09:55:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f4bc8267-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Aug 16 09:55:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Aug 16 09:55:41 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET                       SOURCE         FSTYPE     OPTIONS
    /                            /dev/mmcblk0p2 ext4       rw,noatime
    |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=340460k,nr_inodes=85115,mode=755
    | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
    | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
    |-/proc                      proc           proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
    |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=188820k,nr_inodes=819200,mode=755
    | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
    | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94408k,nr_inodes=23602,mode=700,uid=1000,gid=1000
    `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.7G    /var/
    1.3G    /var/log/journal/12c8c2c8ac934bc8ad22f3445d207b46
    1.3G    /var/log
    193M    /var/cache
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    13M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    751M    /opt/iobroker/iobroker-data/
    608M    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2486562-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    nodejs:
      Installed: 20.16.0-1nodesource1
      Candidate: 20.16.0-1nodesource1
      Version table:
     *** 20.16.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.9
    admin:          7.0.22
    javascript:     8.7.6
    nodejs modules from github:     2
    +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
    +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
    Adapter State
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.countdown.0              : countdown             : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
      system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.govee-app.1              : govee-app             : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.iot.2                    : iot                   : raspberrypi                              - disabled
      system.adapter.iot.3                    : iot                   : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.meross.1                 : meross                : raspberrypi                              -  enabled
      system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
      system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
    + system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : raspberrypi                              - disabled
    + system.adapter.whatsapp-cmb.3           : whatsapp-cmb          : raspberrypi                              -  enabled
      system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
      system.adapter.wled.0                   : wled                  : raspberrypi                              - disabled
      system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                              │ auto upgrade │
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
    │ 1       │ 'beta'   │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
    │ 2       │ '__test' │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.22   , installed 7.0.22
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.16   , installed 3.0.16
    Adapter    "countdown"    : 2.2.0    , installed 2.2.0
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "deconz"       : 1.4.1    , installed 1.4.1
    Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "shelly"       : 7.0.0    , installed 6.4.1  [Updatable]
    Adapter    "sonoff"       : 3.1.0    , installed 2.5.3  [Updatable]
    Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
    Adapter    "telegram"     : 3.9.0    , installed 1.16.0 [Updatable]
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
    Adapter    "wifilight"    : 1.2.2    , installed 1.1.4  [Updatable]
    Adapter    "wled"         : 0.7.2    , installed 0.7.1  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    ^X
    Objects and States
    Please stand by - This may take a while        Objects:  9851
    States:         8648
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://phoscon.de/apt/deconz bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       14164      366/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12992      508/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14225      366/deCONZ
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25642      2374/io.sonoff.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23746      2236/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23741      2236/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12994      508/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23878      2254/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25453      2639/io.web.0
    udp        0      0 0.0.0.0:36041           0.0.0.0:*                           108        12950      360/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12948      360/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24391      2462/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13070      366/deCONZ
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25998      2367/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10182      650/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12949      360/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       24393      2462/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       24392      2462/io.deconz.0
    udp6       0      0 :::37277                :::*                                108        12951      360/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13007      650/dhcpcd
    2024-08-16 10:02:15.183  - info: iot.3 (2660) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2024-08-16 10:02:16.607  - info: shelly.0 (2367) [CoAP] Device 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1) connected! Polltime set to 15 sec.
    2024-08-16 10:02:16.674  - info: shelly.0 (2367) [CoAP] Device 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1) connected! Polltime set to 15 sec.
    2024-08-16 10:02:19.220  - info: iot.3 (2660) Connection changed: connect "paramithi_arcor_de"
    2024-08-16 10:02:23.821  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:02:24.022  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:02:26.300  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:02:40.487  - info: alexa2.0 (2356) Using cached smart home devices list from Fri Aug 16 2024 09:35:48 GMT+0200 (Central European Summer Time)
    2024-08-16 10:02:40.747  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:02:41.972  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:02:43.555  - info: alexa2.0 (2356) No smart home devices to query
    2024-08-16 10:02:43.994  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:02:44.474  - info: alexa2.0 (2356) Subscribing to states...
    2024-08-16 10:02:44.487  - info: alexa2.0 (2356) Deleting the following states: ["Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#delete","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#enabled","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#query","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.powerState","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#delete","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#enabled","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#query","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.powerState","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#delete","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#enabled","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#query","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.connectivity","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#delete","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#enabled","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#query","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.powerState","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#delete","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#enabled","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#query","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.powerState","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#delete","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#enabled","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#query","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.powerState","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#delete","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#enabled","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#query","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.powerState","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#delete","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#enabled","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#query","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.powerState","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#delete","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#enabled","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#query","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.powerState","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#delete","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#enabled","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#query","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.powerState","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#delete","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#enabled","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#query","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.powerState","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#delete","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#enabled","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#query","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.powerState","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#delete","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#enabled","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#query","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.powerState","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#delete","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#enabled","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#query","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.connectivity","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#delete","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#enabled","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#query","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.powerState","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#delete","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#delete","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#query","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.powerState","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#delete","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#enabled","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#query","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.powerState","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#delete","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#enabled","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#query","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.powerState","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#delete","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#enabled","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#query","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.powerState","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#delete","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#enabled","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#query","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.powerState","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#delete","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#enabled","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#query","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.powerState","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#delete","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#enabled","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#query","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-hue","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-saturation","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorName","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorRgb","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.connectivity","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.powerState","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#delete","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#enabled","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#query","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.powerState","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#delete","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#enabled","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#query","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.powerState","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#delete","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#enabled","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#query","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.powerState","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#delete","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#enabled","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#query","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.powerState","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#delete","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#enabled","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#query","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.powerState","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#delete","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#enabled","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#query","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-hue","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-saturation","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorRgb","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureInKelvin","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.connectivity","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.powerState","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#delete","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#enabled","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#query","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.powerState","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#delete","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#enabled","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#query","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.powerState","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#delete","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#enabled","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#query","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.powerState","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#delete","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#enabled","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#query","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.powerState","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#delete","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#enabled","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#query","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.connectivity","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.powerState","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#delete","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#enabled","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#query","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.connectivity","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#delete","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#enabled","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#query","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.powerState","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#delete","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#enabled","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#query","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.powerState","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#delete","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#enabled","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#query","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.powerState","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#delete","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#enabled","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#query","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.powerState","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#delete","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#enabled","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#query","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.powerState","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#delete","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#enabled","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#query","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.powerState","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#delete","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#enabled","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#query","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.powerState","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#delete","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#enabled","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#query","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.powerState","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#delete","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#enabled","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#query","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.powerState","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#delete","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#enabled","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#query","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.powerState","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#delete","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#enabled","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#query","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.powerState","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#delete","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#enabled","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#query","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.powerState","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#delete","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#enabled","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#query","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.powerState","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#delete","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#enabled","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#query","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.powerState","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#delete","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#enabled","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#query","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.powerState","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#delete","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#enabled","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#query","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.connectivity","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#delete","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#enabled","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#query","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.powerState","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#delete","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#enabled","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#query","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.powerState","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#delete","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#enabled","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#query","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.powerState","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#delete","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#enabled","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#query","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.connectivity","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.powerState","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#delete","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#enabled","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#query","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.connectivity","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.powerState","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#delete","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#enabled","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#query","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.powerState","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#delete","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#enabled","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#query","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.powerState","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#delete","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#enabled","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#query","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.connectivity","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#delete","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#enabled","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#query","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.powerState","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#delete","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#enabled","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#query","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.powerState","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#delete","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#enabled","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#query","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.powerState","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#delete","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#enabled","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#query","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.powerState","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#delete","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#enabled","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#query","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.powerState","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#delete","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#enabled","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#query","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.powerState","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#delete","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#enabled","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#query","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.powerState","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#delete","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#enabled","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#query","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.connectivity","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#delete","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#enabled","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#query","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.powerState","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#delete","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#enabled","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#query","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.powerState","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#delete","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#enabled","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#query","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.powerState","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#delete","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#enabled","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#query","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.powerState","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#delete","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#enabled","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#query","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.powerState","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#delete","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#enabled","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#query","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.powerState","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#delete","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#enabled","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#query","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.powerState","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#delete","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#enabled","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#query","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.powerState","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#delete","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#enabled","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#query","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.powerState","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#delete","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#enabled","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#query","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.powerState","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#delete","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#enabled","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#query","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.powerState","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#delete","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#enabled","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#query","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.powerState","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#delete","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#enabled","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#query","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.powerState","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#delete","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#enabled","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#query","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.powerState","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#delete","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#enabled","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#query","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.powerState","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#delete","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#enabled","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#query","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.powerState","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#delete","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#enabled","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#query","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.powerState","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#delete","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#enabled","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#query","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.powerState","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#delete","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#enabled","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#query","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.powerState","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#delete","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#enabled","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#query","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.powerState","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#delete","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#enabled","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#query","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.powerState","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#delete","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#enabled","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#query","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.powerState","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#delete","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#enabled","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#query","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.powerState","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#delete","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#enabled","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#query","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.powerState","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#delete","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#enabled","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#query","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.powerState","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#delete","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#enabled","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#query","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.powerState","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#delete","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#enabled","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#query","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.connectivity","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#delete","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#enabled","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#query","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.powerState","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#delete","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#delete","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#query","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.powerState","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#delete","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#delete","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#query","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.powerState","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#delete","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#enabled","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#query","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.connectivity","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.lockState","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#delete","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#enabled","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#query","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.powerState","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#delete","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#enabled","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#query","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.powerState","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#delete","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#enabled","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#query","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.connectivity","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.powerState","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#delete","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#enabled","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#query","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.powerState","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#delete","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#enabled","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#query","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.powerState","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#delete","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#enabled","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#query","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.powerState","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#delete","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#enabled","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#query","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.powerState","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#delete","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#enabled","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#query","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.powerState","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#delete","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#enabled","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#query","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.powerState","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#delete","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#enabled","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#query","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.powerState","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#delete","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#enabled","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#query","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.powerState","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#delete","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#enabled","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#query","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.powerState","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#delete","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#enabled","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#query","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.powerState","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#delete","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#enabled","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#query","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.powerState","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#delete","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#enabled","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#query","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.powerState","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#delete","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#enabled","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#query","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.powerState","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#delete","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#enabled","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#query","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.connectivity","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.powerState","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#delete","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#enabled","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#query","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.powerState","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#delete","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#enabled","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#query","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.powerState","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#delete","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#enabled","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#query","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.powerState","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#delete","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#enabled","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#query","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.powerState","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#delete","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#enabled","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#query","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.powerState","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#delete","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#enabled","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#query","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.powerState","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#delete","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#enabled","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#query","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.powerState","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#delete","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#enabled","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#query","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.connectivity","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.powerState","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#delete","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#enabled","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#query","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.powerState","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#delete","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#enabled","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#query","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.powerState","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#delete","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#enabled","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#query","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.powerState","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#delete","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#enabled","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#query","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.powerState","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#delete","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#enabled","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#query","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.powerState","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#delete","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#enabled","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#query","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.connectivity","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.powerState","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#delete","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#enabled","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#query","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.powerState","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#delete","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#enabled","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#query","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.powerState","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#delete","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#enabled","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.powerState","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#delete","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#enabled","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#query","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.powerState","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#delete","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#enabled","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#query","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.powerState","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#delete","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#enabled","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#query","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.powerState","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#delete","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#enabled","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#query","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.powerState","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#delete","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#enabled","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#query","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.powerState","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#delete","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#enabled","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#query","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.powerState","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#delete","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#enabled","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#query","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.powerState","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#delete","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#enabled","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#query","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.powerState","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#delete","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#enabled","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.powerState","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#delete","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#enabled","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#query","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.connectivity","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#delete","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#enabled","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#query","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.powerState","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#delete","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#enabled","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#query","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.powerState","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#delete","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#enabled","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#query","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.powerState","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#delete","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#enabled","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#query","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.powerState","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#enabled","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#delete","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.powerState","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#enabled","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#delete","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.powerState","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#enabled","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#delete","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#enabled","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#delete","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity-reason","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#query","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#includeInAllQuery","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#enabled","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#delete","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.powerState","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#enabled","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#delete","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.powerState","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#enabled","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#delete","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.powerState","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#enabled","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#delete","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.powerState","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#enabled","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#delete","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.powerState","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#enabled","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#delete","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.powerState","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#enabled","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#delete","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.powerState","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#enabled","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#delete","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.powerState","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#enabled","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#delete","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.powerState","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#enabled","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#delete","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.powerState","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#enabled","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#delete","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.powerState","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#enabled","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#delete","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.powerState","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#enabled","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#delete","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.powerState","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#enabled","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#delete","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.powerState","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#enabled","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#delete","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.powerState","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#enabled","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#delete","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.powerState","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#enabled","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#delete","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.powerState","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#enabled","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#delete","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.powerState","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#enabled","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#delete","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.powerState","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#enabled","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#delete","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.powerState","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#enabled","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#delete","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.powerState","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#enabled","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#delete","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.powerState","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#enabled","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#delete","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.powerState","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#enabled","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#delete","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.powerState","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#enabled","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#delete","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.powerState","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#enabled","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#delete","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.powerState","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#enabled","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#delete","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.powerState","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#enabled","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#delete","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.powerState","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#enabled","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#delete","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.powerState","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#enabled","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#delete","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.powerState","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#enabled","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#delete","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.powerState","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#enabled","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#delete","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.powerState","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#enabled","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#delete","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.powerState","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#enabled","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#delete","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.powerState"]
    2024-08-16 10:02:46.462  - info: alexa2.0 (2356) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2024-08-16 10:02:50.879  - info: alexa2.0 (2356) Initialization Done ...
    2024-08-16 10:02:58.087  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:02:58.468  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:03:04.559  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:03:14.693  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:03:15.762  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:03:32.089  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:03:34.866  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:03:48.956  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-16 10:03:51.851  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
    iob diag has finished.
    Press any key for a summary
    BananaJoeB Offline
    BananaJoeB Offline
    BananaJoe
    @klaris sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    Previously detected issues:
    ~ Under-voltage has occurred
    Der Grund warum die Buchse so lahm ist ... Netzteil ist zu schwach, da fährt das System auf Sparbetrieb in dem es drosselt
    • K klaris
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7+
            Architecture: arm
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       10:02:18 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
      CPU threads: 4
      Current issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-08-16 10:02:19 CEST
                 Universal time: Fri 2024-08-16 08:02:19 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            921M        714M         66M        0.0K        140M        154M
      Swap:            99M         99M        0.0K
      Total:          1.0G        813M         67M
      Active iob-Instances:   4
                921 M total memory
                713 M used memory
                164 M active memory
                620 M inactive memory
                 66 M free memory
                 13 M buffer memory
                127 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      top - 10:02:19 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
      Tasks: 150 total,   4 running, 146 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 60.9 us,  8.7 sy,  0.0 ni, 29.0 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
      MiB Mem :    922.0 total,     65.2 free,    715.1 used,    141.6 buff/cache
      MiB Swap:    100.0 total,      0.9 free,     99.1 used.    153.3 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  6.4G   22G  23% /
      devtmpfs       devtmpfs  333M     0  333M   0% /dev
      tmpfs          tmpfs     461M     0  461M   0% /dev/shm
      tmpfs          tmpfs     185M  716K  184M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
      [Fri Aug 16 09:55:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f4bc8267-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Aug 16 09:55:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Aug 16 09:55:41 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET                       SOURCE         FSTYPE     OPTIONS
      /                            /dev/mmcblk0p2 ext4       rw,noatime
      |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=340460k,nr_inodes=85115,mode=755
      | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
      | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
      |-/proc                      proc           proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
      |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=188820k,nr_inodes=819200,mode=755
      | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
      | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94408k,nr_inodes=23602,mode=700,uid=1000,gid=1000
      `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.7G    /var/
      1.3G    /var/log/journal/12c8c2c8ac934bc8ad22f3445d207b46
      1.3G    /var/log
      193M    /var/cache
      Archived and active journals take up 1.2G in the file system.
      /opt/iobroker/backups:
      13M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      751M    /opt/iobroker/iobroker-data/
      608M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2486562-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     2
      +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
      +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
      Adapter State
        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.countdown.0              : countdown             : raspberrypi                              - disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
        system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.govee-app.1              : govee-app             : raspberrypi                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.iot.2                    : iot                   : raspberrypi                              - disabled
        system.adapter.iot.3                    : iot                   : raspberrypi                              -  enabled
        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.meross.1                 : meross                : raspberrypi                              -  enabled
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
        system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
        system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      + system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : raspberrypi                              - disabled
      + system.adapter.whatsapp-cmb.3           : whatsapp-cmb          : raspberrypi                              -  enabled
        system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
        system.adapter.wled.0                   : wled                  : raspberrypi                              - disabled
        system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name     │ url                                              │ auto upgrade │
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
      │ 1       │ 'beta'   │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
      │ 2       │ '__test' │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.16   , installed 3.0.16
      Adapter    "countdown"    : 2.2.0    , installed 2.2.0
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "shelly"       : 7.0.0    , installed 6.4.1  [Updatable]
      Adapter    "sonoff"       : 3.1.0    , installed 2.5.3  [Updatable]
      Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
      Adapter    "telegram"     : 3.9.0    , installed 1.16.0 [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
      Adapter    "wifilight"    : 1.2.2    , installed 1.1.4  [Updatable]
      Adapter    "wled"         : 0.7.2    , installed 0.7.1  [Updatable]
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      ^X
      Objects and States
      Please stand by - This may take a while        Objects:  9851
      States:         8648
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://phoscon.de/apt/deconz bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       14164      366/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12992      508/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14225      366/deCONZ
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25642      2374/io.sonoff.1
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23746      2236/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23741      2236/iobroker.js-co
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12994      508/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23878      2254/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25453      2639/io.web.0
      udp        0      0 0.0.0.0:36041           0.0.0.0:*                           108        12950      360/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12948      360/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24391      2462/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13070      366/deCONZ
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25998      2367/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10182      650/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        12949      360/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       24393      2462/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       24392      2462/io.deconz.0
      udp6       0      0 :::37277                :::*                                108        12951      360/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13007      650/dhcpcd
      2024-08-16 10:02:15.183  - info: iot.3 (2660) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2024-08-16 10:02:16.607  - info: shelly.0 (2367) [CoAP] Device 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1) connected! Polltime set to 15 sec.
      2024-08-16 10:02:16.674  - info: shelly.0 (2367) [CoAP] Device 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1) connected! Polltime set to 15 sec.
      2024-08-16 10:02:19.220  - info: iot.3 (2660) Connection changed: connect "paramithi_arcor_de"
      2024-08-16 10:02:23.821  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:24.022  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:26.300  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:40.487  - info: alexa2.0 (2356) Using cached smart home devices list from Fri Aug 16 2024 09:35:48 GMT+0200 (Central European Summer Time)
      2024-08-16 10:02:40.747  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:41.972  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:43.555  - info: alexa2.0 (2356) No smart home devices to query
      2024-08-16 10:02:43.994  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:44.474  - info: alexa2.0 (2356) Subscribing to states...
      2024-08-16 10:02:44.487  - info: alexa2.0 (2356) Deleting the following states: ["Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#delete","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#enabled","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#query","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.powerState","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#delete","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#enabled","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#query","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.powerState","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#delete","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#enabled","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#query","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.connectivity","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#delete","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#enabled","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#query","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.powerState","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#delete","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#enabled","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#query","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.powerState","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#delete","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#enabled","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#query","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.powerState","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#delete","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#enabled","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#query","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.powerState","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#delete","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#enabled","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#query","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.powerState","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#delete","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#enabled","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#query","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.powerState","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#delete","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#enabled","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#query","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.powerState","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#delete","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#enabled","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#query","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.powerState","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#delete","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#enabled","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#query","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.powerState","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#delete","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#enabled","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#query","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.powerState","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#delete","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#enabled","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#query","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.connectivity","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#delete","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#enabled","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#query","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.powerState","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#delete","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#delete","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#query","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.powerState","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#delete","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#enabled","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#query","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.powerState","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#delete","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#enabled","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#query","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.powerState","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#delete","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#enabled","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#query","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.powerState","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#delete","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#enabled","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#query","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.powerState","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#delete","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#enabled","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#query","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.powerState","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#delete","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#enabled","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#query","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-hue","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-saturation","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorName","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorRgb","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.connectivity","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.powerState","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#delete","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#enabled","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#query","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.powerState","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#delete","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#enabled","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#query","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.powerState","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#delete","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#enabled","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#query","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.powerState","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#delete","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#enabled","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#query","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.powerState","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#delete","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#enabled","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#query","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.powerState","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#delete","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#enabled","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#query","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-hue","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-saturation","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorRgb","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureInKelvin","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.connectivity","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.powerState","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#delete","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#enabled","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#query","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.powerState","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#delete","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#enabled","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#query","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.powerState","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#delete","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#enabled","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#query","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.powerState","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#delete","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#enabled","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#query","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.powerState","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#delete","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#enabled","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#query","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.connectivity","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.powerState","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#delete","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#enabled","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#query","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.connectivity","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#delete","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#enabled","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#query","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.powerState","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#delete","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#enabled","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#query","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.powerState","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#delete","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#enabled","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#query","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.powerState","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#delete","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#enabled","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#query","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.powerState","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#delete","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#enabled","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#query","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.powerState","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#delete","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#enabled","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#query","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.powerState","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#delete","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#enabled","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#query","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.powerState","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#delete","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#enabled","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#query","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.powerState","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#delete","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#enabled","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#query","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.powerState","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#delete","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#enabled","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#query","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.powerState","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#delete","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#enabled","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#query","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.powerState","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#delete","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#enabled","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#query","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.powerState","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#delete","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#enabled","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#query","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.powerState","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#delete","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#enabled","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#query","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.powerState","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#delete","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#enabled","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#query","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.powerState","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#delete","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#enabled","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#query","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.connectivity","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#delete","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#enabled","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#query","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.powerState","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#delete","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#enabled","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#query","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.powerState","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#delete","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#enabled","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#query","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.powerState","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#delete","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#enabled","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#query","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.connectivity","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.powerState","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#delete","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#enabled","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#query","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.connectivity","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.powerState","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#delete","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#enabled","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#query","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.powerState","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#delete","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#enabled","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#query","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.powerState","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#delete","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#enabled","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#query","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.connectivity","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#delete","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#enabled","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#query","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.powerState","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#delete","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#enabled","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#query","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.powerState","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#delete","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#enabled","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#query","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.powerState","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#delete","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#enabled","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#query","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.powerState","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#delete","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#enabled","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#query","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.powerState","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#delete","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#enabled","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#query","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.powerState","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#delete","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#enabled","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#query","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.powerState","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#delete","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#enabled","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#query","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.connectivity","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#delete","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#enabled","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#query","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.powerState","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#delete","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#enabled","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#query","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.powerState","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#delete","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#enabled","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#query","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.powerState","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#delete","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#enabled","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#query","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.powerState","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#delete","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#enabled","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#query","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.powerState","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#delete","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#enabled","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#query","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.powerState","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#delete","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#enabled","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#query","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.powerState","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#delete","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#enabled","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#query","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.powerState","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#delete","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#enabled","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#query","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.powerState","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#delete","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#enabled","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#query","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.powerState","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#delete","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#enabled","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#query","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.powerState","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#delete","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#enabled","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#query","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.powerState","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#delete","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#enabled","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#query","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.powerState","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#delete","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#enabled","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#query","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.powerState","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#delete","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#enabled","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#query","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.powerState","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#delete","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#enabled","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#query","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.powerState","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#delete","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#enabled","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#query","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.powerState","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#delete","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#enabled","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#query","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.powerState","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#delete","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#enabled","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#query","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.powerState","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#delete","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#enabled","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#query","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.powerState","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#delete","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#enabled","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#query","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.powerState","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#delete","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#enabled","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#query","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.powerState","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#delete","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#enabled","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#query","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.powerState","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#delete","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#enabled","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#query","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.powerState","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#delete","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#enabled","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#query","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.powerState","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#delete","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#enabled","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#query","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.powerState","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#delete","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#enabled","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#query","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.connectivity","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#delete","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#enabled","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#query","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.powerState","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#delete","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#delete","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#query","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.powerState","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#delete","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#delete","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#query","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.powerState","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#delete","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#enabled","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#query","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.connectivity","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.lockState","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#delete","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#enabled","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#query","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.powerState","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#delete","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#enabled","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#query","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.powerState","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#delete","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#enabled","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#query","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.connectivity","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.powerState","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#delete","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#enabled","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#query","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.powerState","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#delete","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#enabled","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#query","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.powerState","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#delete","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#enabled","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#query","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.powerState","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#delete","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#enabled","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#query","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.powerState","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#delete","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#enabled","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#query","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.powerState","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#delete","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#enabled","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#query","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.powerState","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#delete","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#enabled","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#query","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.powerState","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#delete","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#enabled","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#query","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.powerState","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#delete","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#enabled","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#query","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.powerState","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#delete","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#enabled","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#query","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.powerState","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#delete","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#enabled","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#query","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.powerState","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#delete","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#enabled","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#query","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.powerState","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#delete","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#enabled","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#query","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.powerState","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#delete","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#enabled","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#query","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.connectivity","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.powerState","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#delete","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#enabled","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#query","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.powerState","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#delete","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#enabled","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#query","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.powerState","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#delete","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#enabled","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#query","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.powerState","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#delete","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#enabled","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#query","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.powerState","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#delete","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#enabled","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#query","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.powerState","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#delete","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#enabled","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#query","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.powerState","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#delete","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#enabled","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#query","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.powerState","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#delete","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#enabled","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#query","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.connectivity","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.powerState","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#delete","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#enabled","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#query","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.powerState","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#delete","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#enabled","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#query","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.powerState","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#delete","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#enabled","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#query","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.powerState","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#delete","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#enabled","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#query","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.powerState","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#delete","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#enabled","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#query","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.powerState","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#delete","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#enabled","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#query","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.connectivity","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.powerState","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#delete","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#enabled","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#query","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.powerState","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#delete","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#enabled","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#query","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.powerState","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#delete","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#enabled","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.powerState","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#delete","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#enabled","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#query","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.powerState","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#delete","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#enabled","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#query","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.powerState","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#delete","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#enabled","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#query","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.powerState","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#delete","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#enabled","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#query","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.powerState","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#delete","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#enabled","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#query","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.powerState","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#delete","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#enabled","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#query","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.powerState","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#delete","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#enabled","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#query","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.powerState","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#delete","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#enabled","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#query","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.powerState","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#delete","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#enabled","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.powerState","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#delete","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#enabled","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#query","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.connectivity","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#delete","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#enabled","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#query","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.powerState","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#delete","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#enabled","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#query","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.powerState","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#delete","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#enabled","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#query","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.powerState","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#delete","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#enabled","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#query","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.powerState","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#enabled","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#delete","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.powerState","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#enabled","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#delete","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.powerState","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#enabled","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#delete","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#enabled","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#delete","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity-reason","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#query","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#includeInAllQuery","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#enabled","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#delete","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.powerState","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#enabled","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#delete","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.powerState","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#enabled","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#delete","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.powerState","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#enabled","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#delete","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.powerState","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#enabled","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#delete","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.powerState","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#enabled","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#delete","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.powerState","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#enabled","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#delete","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.powerState","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#enabled","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#delete","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.powerState","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#enabled","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#delete","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.powerState","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#enabled","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#delete","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.powerState","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#enabled","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#delete","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.powerState","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#enabled","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#delete","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.powerState","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#enabled","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#delete","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.powerState","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#enabled","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#delete","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.powerState","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#enabled","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#delete","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.powerState","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#enabled","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#delete","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.powerState","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#enabled","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#delete","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.powerState","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#enabled","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#delete","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.powerState","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#enabled","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#delete","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.powerState","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#enabled","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#delete","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.powerState","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#enabled","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#delete","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.powerState","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#enabled","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#delete","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.powerState","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#enabled","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#delete","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.powerState","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#enabled","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#delete","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.powerState","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#enabled","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#delete","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.powerState","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#enabled","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#delete","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.powerState","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#enabled","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#delete","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.powerState","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#enabled","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#delete","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.powerState","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#enabled","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#delete","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.powerState","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#enabled","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#delete","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.powerState","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#enabled","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#delete","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.powerState","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#enabled","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#delete","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.powerState","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#enabled","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#delete","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.powerState","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#enabled","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#delete","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.powerState"]
      2024-08-16 10:02:46.462  - info: alexa2.0 (2356) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2024-08-16 10:02:50.879  - info: alexa2.0 (2356) Initialization Done ...
      2024-08-16 10:02:58.087  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:58.468  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:04.559  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:14.693  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:15.762  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:32.089  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:34.866  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:48.956  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:51.851  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      iob diag has finished.
      Press any key for a summary
      @klaris sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
      load average: 6.16, 3.09, 1.37
      da hast du wohl deinen
      Raspberry Pi 3 Model B Plus Rev 1.3
      etwas überfordert.
      dein 1GB RAM geht auch zu Ende
      • BananaJoeB Offline
        BananaJoeB Offline
        BananaJoe
        Und ja, ein neuerer Pi mit mehr Power könnte nicht schaden ... so ein 3er ist echt in die Jahre gekommen, ein 4er 5er wäre um ein vielfaches schneller.
        • K klaris
          Skript v.2024-05-22
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v7+
                Architecture: arm
          Model           : Raspberry Pi 3 Model B Plus Rev 1.3
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : 32 bit
          Systemuptime and Load:
           10:02:18 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          ~ Under-voltage detected
          Previously detected issues:
          ~ Under-voltage has occurred
          *** Time and Time Zones ***
                         Local time: Fri 2024-08-16 10:02:19 CEST
                     Universal time: Fri 2024-08-16 08:02:19 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          *** Display-Server-Setup ***
          Display-Server: true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            921M        714M         66M        0.0K        140M        154M
          Swap:            99M         99M        0.0K
          Total:          1.0G        813M         67M
          Active iob-Instances:   4
                    921 M total memory
                    713 M used memory
                    164 M active memory
                    620 M inactive memory
                     66 M free memory
                     13 M buffer memory
                    127 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          top - 10:02:19 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
          Tasks: 150 total,   4 running, 146 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 60.9 us,  8.7 sy,  0.0 ni, 29.0 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
          MiB Mem :    922.0 total,     65.2 free,    715.1 used,    141.6 buff/cache
          MiB Swap:    100.0 total,      0.9 free,     99.1 used.    153.3 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G  6.4G   22G  23% /
          devtmpfs       devtmpfs  333M     0  333M   0% /dev
          tmpfs          tmpfs     461M     0  461M   0% /dev/shm
          tmpfs          tmpfs     185M  716K  184M   1% /run
          /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
          [Fri Aug 16 09:55:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f4bc8267-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): recovery complete
          [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Aug 16 09:55:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Fri Aug 16 09:55:41 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET                       SOURCE         FSTYPE     OPTIONS
          /                            /dev/mmcblk0p2 ext4       rw,noatime
          |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=340460k,nr_inodes=85115,mode=755
          | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
          | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
          |-/proc                      proc           proc       rw,relatime
          | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
          |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
          | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
          | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
          |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=188820k,nr_inodes=819200,mode=755
          | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
          | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94408k,nr_inodes=23602,mode=700,uid=1000,gid=1000
          `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          1.7G    /var/
          1.3G    /var/log/journal/12c8c2c8ac934bc8ad22f3445d207b46
          1.3G    /var/log
          193M    /var/cache
          Archived and active journals take up 1.2G in the file system.
          /opt/iobroker/backups:
          13M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          751M    /opt/iobroker/iobroker-data/
          608M    /opt/iobroker/iobroker-data/files
          441M    /opt/iobroker/iobroker-data/files/javascript.admin
          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          14M     /opt/iobroker/iobroker-data/objects.jsonl
          8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
          8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2486562-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.16.0
          /usr/bin/node           v20.16.0
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          /usr/bin/corepack       0.28.2
          nodejs:
            Installed: 20.16.0-1nodesource1
            Candidate: 20.16.0-1nodesource1
            Version table:
           *** 20.16.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  6.0.9
          admin:          7.0.22
          javascript:     8.7.6
          nodejs modules from github:     2
          +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
          +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
          Adapter State
            system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
            system.adapter.countdown.0              : countdown             : raspberrypi                              - disabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
            system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
            system.adapter.govee-app.1              : govee-app             : raspberrypi                              - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
            system.adapter.iot.2                    : iot                   : raspberrypi                              - disabled
            system.adapter.iot.3                    : iot                   : raspberrypi                              -  enabled
            system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            system.adapter.meross.1                 : meross                : raspberrypi                              -  enabled
            system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
            system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
            system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          + system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : raspberrypi                              - disabled
          + system.adapter.whatsapp-cmb.3           : whatsapp-cmb          : raspberrypi                              -  enabled
            system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
            system.adapter.wled.0                   : wled                  : raspberrypi                              - disabled
            system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
          + instance is alive
          ioBroker-Repositories
          │ (index) │ name     │ url                                              │ auto upgrade │
          │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
          │ 1       │ 'beta'   │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
          │ 2       │ '__test' │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.0.22   , installed 7.0.22
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.16   , installed 3.0.16
          Adapter    "countdown"    : 2.2.0    , installed 2.2.0
          Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
          Adapter    "deconz"       : 1.4.1    , installed 1.4.1
          Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
          Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.9    , installed 6.0.9
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "shelly"       : 7.0.0    , installed 6.4.1  [Updatable]
          Adapter    "sonoff"       : 3.1.0    , installed 2.5.3  [Updatable]
          Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
          Adapter    "telegram"     : 3.9.0    , installed 1.16.0 [Updatable]
          Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
          Adapter    "web"          : 6.2.5    , installed 6.2.5
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
          Adapter    "wifilight"    : 1.2.2    , installed 1.1.4  [Updatable]
          Adapter    "wled"         : 0.7.2    , installed 0.7.1  [Updatable]
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          ^X
          Objects and States
          Please stand by - This may take a while        Objects:  9851
          States:         8648
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://phoscon.de/apt/deconz bullseye InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       14164      366/deCONZ
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12992      508/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14225      366/deCONZ
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25642      2374/io.sonoff.1
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23746      2236/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23741      2236/iobroker.js-co
          tcp6       0      0 :::22                   :::*                    LISTEN      0          12994      508/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23878      2254/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25453      2639/io.web.0
          udp        0      0 0.0.0.0:36041           0.0.0.0:*                           108        12950      360/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12948      360/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24391      2462/io.deconz.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13070      366/deCONZ
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25998      2367/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10182      650/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        12949      360/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       24393      2462/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       24392      2462/io.deconz.0
          udp6       0      0 :::37277                :::*                                108        12951      360/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          13007      650/dhcpcd
          2024-08-16 10:02:15.183  - info: iot.3 (2660) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2024-08-16 10:02:16.607  - info: shelly.0 (2367) [CoAP] Device 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1) connected! Polltime set to 15 sec.
          2024-08-16 10:02:16.674  - info: shelly.0 (2367) [CoAP] Device 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1) connected! Polltime set to 15 sec.
          2024-08-16 10:02:19.220  - info: iot.3 (2660) Connection changed: connect "paramithi_arcor_de"
          2024-08-16 10:02:23.821  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:02:24.022  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:02:26.300  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:02:40.487  - info: alexa2.0 (2356) Using cached smart home devices list from Fri Aug 16 2024 09:35:48 GMT+0200 (Central European Summer Time)
          2024-08-16 10:02:40.747  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:02:41.972  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:02:43.555  - info: alexa2.0 (2356) No smart home devices to query
          2024-08-16 10:02:43.994  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:02:44.474  - info: alexa2.0 (2356) Subscribing to states...
          2024-08-16 10:02:44.487  - info: alexa2.0 (2356) Deleting the following states: ["Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#delete","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#enabled","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#query","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.powerState","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#delete","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#enabled","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#query","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.powerState","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#delete","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#enabled","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#query","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.connectivity","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#delete","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#enabled","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#query","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.powerState","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#delete","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#enabled","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#query","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.powerState","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#delete","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#enabled","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#query","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.powerState","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#delete","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#enabled","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#query","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.powerState","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#delete","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#enabled","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#query","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.powerState","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#delete","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#enabled","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#query","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.powerState","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#delete","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#enabled","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#query","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.powerState","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#delete","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#enabled","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#query","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.powerState","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#delete","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#enabled","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#query","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.powerState","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#delete","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#enabled","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#query","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.powerState","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#delete","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#enabled","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#query","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.connectivity","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#delete","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#enabled","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#query","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.powerState","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#delete","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#delete","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#query","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.powerState","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#delete","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#enabled","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#query","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.powerState","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#delete","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#enabled","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#query","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.powerState","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#delete","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#enabled","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#query","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.powerState","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#delete","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#enabled","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#query","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.powerState","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#delete","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#enabled","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#query","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.powerState","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#delete","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#enabled","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#query","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-hue","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-saturation","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorName","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorRgb","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.connectivity","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.powerState","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#delete","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#enabled","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#query","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.powerState","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#delete","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#enabled","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#query","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.powerState","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#delete","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#enabled","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#query","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.powerState","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#delete","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#enabled","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#query","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.powerState","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#delete","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#enabled","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#query","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.powerState","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#delete","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#enabled","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#query","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-hue","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-saturation","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorRgb","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureInKelvin","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.connectivity","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.powerState","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#delete","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#enabled","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#query","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.powerState","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#delete","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#enabled","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#query","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.powerState","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#delete","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#enabled","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#query","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.powerState","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#delete","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#enabled","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#query","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.powerState","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#delete","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#enabled","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#query","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.connectivity","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.powerState","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#delete","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#enabled","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#query","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.connectivity","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#delete","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#enabled","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#query","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.powerState","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#delete","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#enabled","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#query","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.powerState","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#delete","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#enabled","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#query","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.powerState","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#delete","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#enabled","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#query","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.powerState","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#delete","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#enabled","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#query","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.powerState","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#delete","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#enabled","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#query","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.powerState","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#delete","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#enabled","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#query","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.powerState","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#delete","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#enabled","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#query","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.powerState","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#delete","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#enabled","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#query","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.powerState","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#delete","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#enabled","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#query","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.powerState","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#delete","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#enabled","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#query","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.powerState","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#delete","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#enabled","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#query","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.powerState","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#delete","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#enabled","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#query","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.powerState","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#delete","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#enabled","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#query","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.powerState","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#delete","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#enabled","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#query","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.powerState","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#delete","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#enabled","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#query","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.connectivity","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#delete","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#enabled","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#query","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.powerState","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#delete","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#enabled","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#query","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.powerState","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#delete","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#enabled","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#query","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.powerState","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#delete","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#enabled","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#query","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.connectivity","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.powerState","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#delete","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#enabled","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#query","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.connectivity","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.powerState","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#delete","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#enabled","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#query","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.powerState","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#delete","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#enabled","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#query","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.powerState","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#delete","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#enabled","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#query","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.connectivity","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#delete","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#enabled","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#query","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.powerState","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#delete","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#enabled","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#query","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.powerState","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#delete","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#enabled","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#query","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.powerState","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#delete","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#enabled","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#query","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.powerState","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#delete","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#enabled","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#query","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.powerState","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#delete","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#enabled","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#query","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.powerState","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#delete","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#enabled","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#query","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.powerState","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#delete","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#enabled","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#query","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.connectivity","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#delete","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#enabled","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#query","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.powerState","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#delete","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#enabled","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#query","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.powerState","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#delete","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#enabled","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#query","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.powerState","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#delete","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#enabled","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#query","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.powerState","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#delete","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#enabled","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#query","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.powerState","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#delete","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#enabled","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#query","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.powerState","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#delete","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#enabled","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#query","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.powerState","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#delete","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#enabled","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#query","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.powerState","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#delete","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#enabled","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#query","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.powerState","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#delete","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#enabled","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#query","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.powerState","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#delete","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#enabled","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#query","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.powerState","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#delete","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#enabled","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#query","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.powerState","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#delete","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#enabled","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#query","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.powerState","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#delete","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#enabled","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#query","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.powerState","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#delete","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#enabled","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#query","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.powerState","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#delete","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#enabled","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#query","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.powerState","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#delete","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#enabled","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#query","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.powerState","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#delete","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#enabled","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#query","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.powerState","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#delete","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#enabled","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#query","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.powerState","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#delete","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#enabled","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#query","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.powerState","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#delete","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#enabled","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#query","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.powerState","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#delete","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#enabled","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#query","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.powerState","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#delete","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#enabled","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#query","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.powerState","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#delete","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#enabled","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#query","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.powerState","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#delete","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#enabled","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#query","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.powerState","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#delete","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#enabled","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#query","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.powerState","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#delete","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#enabled","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#query","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.connectivity","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#delete","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#enabled","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#query","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.powerState","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#delete","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#delete","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#query","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.powerState","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#delete","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#delete","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#query","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.powerState","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#delete","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#enabled","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#query","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.connectivity","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.lockState","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#delete","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#enabled","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#query","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.powerState","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#delete","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#enabled","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#query","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.powerState","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#delete","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#enabled","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#query","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.connectivity","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.powerState","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#delete","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#enabled","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#query","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.powerState","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#delete","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#enabled","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#query","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.powerState","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#delete","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#enabled","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#query","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.powerState","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#delete","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#enabled","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#query","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.powerState","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#delete","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#enabled","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#query","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.powerState","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#delete","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#enabled","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#query","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.powerState","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#delete","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#enabled","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#query","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.powerState","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#delete","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#enabled","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#query","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.powerState","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#delete","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#enabled","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#query","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.powerState","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#delete","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#enabled","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#query","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.powerState","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#delete","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#enabled","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#query","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.powerState","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#delete","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#enabled","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#query","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.powerState","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#delete","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#enabled","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#query","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.powerState","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#delete","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#enabled","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#query","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.connectivity","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.powerState","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#delete","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#enabled","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#query","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.powerState","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#delete","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#enabled","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#query","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.powerState","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#delete","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#enabled","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#query","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.powerState","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#delete","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#enabled","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#query","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.powerState","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#delete","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#enabled","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#query","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.powerState","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#delete","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#enabled","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#query","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.powerState","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#delete","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#enabled","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#query","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.powerState","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#delete","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#enabled","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#query","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.connectivity","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.powerState","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#delete","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#enabled","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#query","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.powerState","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#delete","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#enabled","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#query","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.powerState","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#delete","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#enabled","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#query","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.powerState","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#delete","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#enabled","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#query","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.powerState","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#delete","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#enabled","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#query","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.powerState","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#delete","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#enabled","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#query","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.connectivity","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.powerState","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#delete","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#enabled","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#query","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.powerState","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#delete","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#enabled","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#query","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.powerState","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#delete","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#enabled","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.powerState","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#delete","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#enabled","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#query","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.powerState","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#delete","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#enabled","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#query","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.powerState","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#delete","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#enabled","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#query","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.powerState","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#delete","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#enabled","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#query","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.powerState","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#delete","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#enabled","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#query","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.powerState","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#delete","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#enabled","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#query","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.powerState","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#delete","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#enabled","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#query","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.powerState","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#delete","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#enabled","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#query","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.powerState","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#delete","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#enabled","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.powerState","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#delete","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#enabled","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#query","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.connectivity","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#delete","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#enabled","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#query","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.powerState","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#delete","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#enabled","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#query","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.powerState","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#delete","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#enabled","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#query","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.powerState","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#delete","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#enabled","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#query","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.powerState","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#enabled","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#delete","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.powerState","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#enabled","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#delete","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.powerState","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#enabled","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#delete","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#enabled","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#delete","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity-reason","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#query","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#includeInAllQuery","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#enabled","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#delete","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.powerState","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#enabled","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#delete","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.powerState","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#enabled","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#delete","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.powerState","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#enabled","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#delete","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.powerState","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#enabled","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#delete","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.powerState","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#enabled","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#delete","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.powerState","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#enabled","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#delete","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.powerState","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#enabled","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#delete","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.powerState","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#enabled","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#delete","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.powerState","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#enabled","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#delete","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.powerState","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#enabled","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#delete","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.powerState","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#enabled","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#delete","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.powerState","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#enabled","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#delete","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.powerState","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#enabled","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#delete","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.powerState","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#enabled","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#delete","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.powerState","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#enabled","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#delete","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.powerState","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#enabled","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#delete","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.powerState","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#enabled","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#delete","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.powerState","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#enabled","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#delete","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.powerState","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#enabled","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#delete","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.powerState","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#enabled","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#delete","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.powerState","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#enabled","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#delete","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.powerState","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#enabled","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#delete","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.powerState","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#enabled","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#delete","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.powerState","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#enabled","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#delete","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.powerState","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#enabled","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#delete","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.powerState","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#enabled","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#delete","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.powerState","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#enabled","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#delete","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.powerState","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#enabled","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#delete","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.powerState","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#enabled","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#delete","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.powerState","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#enabled","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#delete","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.powerState","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#enabled","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#delete","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.powerState","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#enabled","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#delete","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.powerState","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#enabled","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#delete","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.powerState"]
          2024-08-16 10:02:46.462  - info: alexa2.0 (2356) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2024-08-16 10:02:50.879  - info: alexa2.0 (2356) Initialization Done ...
          2024-08-16 10:02:58.087  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:02:58.468  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:03:04.559  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:03:14.693  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:03:15.762  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:03:32.089  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:03:34.866  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:03:48.956  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
          2024-08-16 10:03:51.851  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
          iob diag has finished.
          Press any key for a summary
          @klaris sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
          Operating System: Raspbian GNU/Linux 11 (bullseye)
          Setz das in nächster Zeit komplett neu auf. Als Bookworm / Debian 12 in der 64Bit-Version.
          Mit einem User, der weder pi noch iobroker oder ähnlich heißt.
          *** RASPBERRY THROTTLING ***
          Current issues:
          ~ Under-voltage detected
          Deine Stromversorgung ist zu wackelig. Verwende ein gutes Netzteil, kein Handyladegerät oder sowas.
          *** Display-Server-Setup ***
          Display-Server: true
          Server immer ohne Desktop.
          [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): recovery complete
          Kiste immer sauber herunterfahren. Schont das Dateisystem.
          ioBroker-Repositories
          Sind falsch angelegt.
          sobald ich den backitup adapter instalieren möchte hängt das system sich auf ...
          Die hängt sich nicht auf, die Kiste ist nur mehr als überlastet.
          • BananaJoeB BananaJoe
            Und ja, ein neuerer Pi mit mehr Power könnte nicht schaden ... so ein 3er ist echt in die Jahre gekommen, ein 4er 5er wäre um ein vielfaches schneller.
            @bananajoe sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
            vor allem bei 25 geplanten Adaptern!
            @klaris
            1GB reicht maximal für <10, eher weniger.
            Aber nur wenn sonst nichts drauf läuft.
              @klaris
              klaris
              schrieb am zuletzt editiert von klaris
              @homoran danke Leute für die schnelle antwort und die guten tipps!! also lag es nicht daran das ich was falsch gemacht habe ....ich muss mir ein aktuelles model kaufen ...habe mein gute anker ladegerät erst mal angeschlossen 😊
              • K klaris
                Naja, das Setup ist auch strubbelig.
                • K klaris
                  @thomas-braun sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                    klaris
                    @thomas-braun das kannst du laut sagen ... wie gesagt BackItUp lässt sich auch mit laaange warten nicht instalieren "system hängt sich auf ..der Adaptere kann den Genauen Gerätestatus nicht anfordern,der status wird anhand der zuletzt gesendeten Befehls vermutet"
                      klaris
                      @homoran wie das anker netzteil 30W ist auch nicht gut ?
                      • K klaris
                        wie der ist auch nicht gut ?
                        Ein LADEgerät ist halt kein NETZTEIL.
                          klaris
                          @thomas-braun ok wieder was gelernt !!!!
                          • K klaris
                            nein, es braucht nur unheimlich lange wenn die Load >4 wird.
                            Wenn dann noch der RAM ausgeht und alles über den
                            MiB Swap: 100.0 total, 0.9 free, 99.1 used.
                            SWAP ausgelagert wird ist nicht nur zähflüsdiger Verkehr, sondern massiver Stau
                              klaris
                              @homoran wenn ich unötige adapter deinstaliere bringt das was ?
                              • K klaris
                                im Moment sind ja nur wenige aktiv, wenn ich das diag sehe. Also nein!
                                Wenn jetzt eine stabilere Stromversorgung dazu führt, dass die CPU nicht mehr gedrosselt wird, könntest du Glück mit dem Anker haben.
                                was sagt denn aktuell incl. Header top?
                                  klaris
                                  @homoran said in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                                  so wie das system jetz läuft ist es ok....mehr brauche ich nicht ..wurde gerne noch einen backup adapter instalieren aber leider kein speicher..oder ich setze das system neu mit einer kleineren js und node version ?
                                  top - 11:25:33 up 14 min,  1 user,  load average: 0.17, 0.49, 0.62
                                  Tasks: 140 total,   1 running, 139 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  2.3 us,  0.6 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.2 si,  0.0 st
                                  MiB Mem :    922.0 total,    104.5 free,    660.4 used,    157.0 buff/cache
                                  MiB Swap:    100.0 total,      1.7 free,     98.3 used.    209.5 avail Mem
                                  • K klaris
                                    @klaris
                                    und der rest?
                                    die load ist runter, aber Speicher ist da nicht wirklich frei.
                                    der Swap ist auch schon wieder verbraucht
                                    EDIT:
                                    Keine nachträglichen Änderungen ohne Kennzeichnung!!
                                    da steht ja mittlerweile ganz was anderes
                                      @klaris
                                      und der rest?
                                      EDIT:
                                      klaris
                                      @homoran ja der gute alte raspberry kommt an seine grenze
                                      was meinst du damit"Keine nachträglichen Änderungen ohne Kennzeichnung!!
                                      • K klaris
                                        hast du wenigstens diesen unnötigen Desktop Kram deaktiviert?
                                          klaris
                                          @homoran welchen unötigen desktop kram ?
                                          vielen dank für deine GEDULD ...
