  4. ZIGBEE: Ping Intervall ändern (DeviceAvailability)
9 Beiträge 5 Kommentatoren 673 Aufrufe 7 Beobachtet
  • P Offline
    pluto8
    Hallo!
    Habe ein Zigbee Rolladenmodul verbaut und soweit lässt es sich auch ansteuern. Mich stören 2 Dinge:
    1. Lässt sich das Ping-Intervall ändern? Das Modul wird exakt alle 5 Minuten abgefragt.
    2. Im gleichen Log taucht auch der Fehler "DeviceAvailability:Exception in readState" auf. Fragt IOBroker hier aktiv den Status des Moduls ab? Kann man das auch ausstellen, oder hängen Punkt 1 und 2 zusammen?
    Danke für eine Antwort!
    Rolladenmodul: QS-Zigbee-C03 / Quelle
    2024-08-05 14:04:48.800 - debug: zigbee.0 (16616) DeviceAvailability:Exception in readState of '0xa4c138a0a203ee06' - error : 'TypeError: converter.convertGet is not a function'
    2024-08-05 14:04:49.025 - debug: zigbee.0 (16616) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859489024,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":32,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":32,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":28,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2024-08-05 14:04:49.025 - debug: zigbee.0 (16616) Received Zigbee message from '0xa4c138a0a203ee06', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID 0
    2024-08-05 14:04:49.026 - debug: zigbee.0 (16616) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859489024,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":32,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"mapped":{"fingerprint":[{"modelID":"TS130F","manufacturerName":"_TZ3000_zirycpws"},{"modelID":"TS130F","manufacturerName":"_TZ3210_ol1uhvza"}],"model":"QS-Zigbee-C03","vendor":"Lonsonho","description":"Curtain/blind motor controller","fromZigbee":[{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["position","tilt"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"key":["calibration"]},{"key":["motor_reversal"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"meta":{"coverInverted":true},"exposes":[{"type":"cover","features":[{"name":"state","label":"State","access":3,"type":"enum","property":"state","values":["OPEN","CLOSE","STOP"]},{"name":"position","label":"Position","access":7,"type":"numeric","property":"position","description":"Position of this cover","unit":"%","value_max":100,"value_min":0}]},{"name":"moving","label":"Moving","access":1,"type":"enum","property":"moving","values":["UP","STOP","DOWN"]},{"name":"calibration","label":"Calibration","access":7,"type":"binary","property":"calibration","value_on":"ON","value_off":"OFF"},{"name":"motor_reversal","label":"Motor reversal","access":7,"type":"binary","property":"motor_reversal","value_on":"ON","value_off":"OFF"},{"name":"calibration_time","label":"Calibration time","access":1,"type":"numeric","property":"calibration_time","description":"Calibration time","unit":"s"},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"options":["[Circular]"]},"name":"0xa4c138a0a203ee06"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859489024,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":32,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":32,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":28,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2024-08-05 14:04:49.026 - debug: zigbee.0 (16616) DeviceAvailability:Successfully pinged 0xa4c138a0a203ee06 TS130F
    2024-08-05 14:09:49.029 - debug: zigbee.0 (16616) DeviceAvailability:Exception in readState of '0xa4c138a0a203ee06' - error : 'TypeError: converter.convertGet is not a function'
    2024-08-05 14:09:49.301 - debug: zigbee.0 (16616) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859789300,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":98,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":98,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":29,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2024-08-05 14:09:49.301 - debug: zigbee.0 (16616) Received Zigbee message from '0xa4c138a0a203ee06', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID 0
    2024-08-05 14:09:49.302 - debug: zigbee.0 (16616) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859789300,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":98,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"mapped":{"fingerprint":[{"modelID":"TS130F","manufacturerName":"_TZ3000_zirycpws"},{"modelID":"TS130F","manufacturerName":"_TZ3210_ol1uhvza"}],"model":"QS-Zigbee-C03","vendor":"Lonsonho","description":"Curtain/blind motor controller","fromZigbee":[{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["position","tilt"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"key":["calibration"]},{"key":["motor_reversal"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"meta":{"coverInverted":true},"exposes":[{"type":"cover","features":[{"name":"state","label":"State","access":3,"type":"enum","property":"state","values":["OPEN","CLOSE","STOP"]},{"name":"position","label":"Position","access":7,"type":"numeric","property":"position","description":"Position of this cover","unit":"%","value_max":100,"value_min":0}]},{"name":"moving","label":"Moving","access":1,"type":"enum","property":"moving","values":["UP","STOP","DOWN"]},{"name":"calibration","label":"Calibration","access":7,"type":"binary","property":"calibration","value_on":"ON","value_off":"OFF"},{"name":"motor_reversal","label":"Motor reversal","access":7,"type":"binary","property":"motor_reversal","value_on":"ON","value_off":"OFF"},{"name":"calibration_time","label":"Calibration time","access":1,"type":"numeric","property":"calibration_time","description":"Calibration time","unit":"s"},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"options":["[Circular]"]},"name":"0xa4c138a0a203ee06"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859789300,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":98,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":98,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":29,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2024-08-05 14:09:49.302 - debug: zigbee.0 (16616) DeviceAvailability:Successfully pinged 0xa4c138a0a203ee06 TS130F
    2024-08-05 14:14:49.310 - debug: zigbee.0 (16616) DeviceAvailability:Exception in readState of '0xa4c138a0a203ee06' - error : 'TypeError: converter.convertGet is not a function'
    2024-08-05 14:14:49.715 - debug: zigbee.0 (16616) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722860089715,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":87,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":87,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":30,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2024-08-05 14:14:49.716 - debug: zigbee.0 (16616) Received Zigbee message from '0xa4c138a0a203ee06', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID 0
    2024-08-05 14:14:49.716 - debug: zigbee.0 (16616) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722860089715,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":87,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"mapped":{"fingerprint":[{"modelID":"TS130F","manufacturerName":"_TZ3000_zirycpws"},{"modelID":"TS130F","manufacturerName":"_TZ3210_ol1uhvza"}],"model":"QS-Zigbee-C03","vendor":"Lonsonho","description":"Curtain/blind motor controller","fromZigbee":[{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["position","tilt"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"key":["calibration"]},{"key":["motor_reversal"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"meta":{"coverInverted":true},"exposes":[{"type":"cover","features":[{"name":"state","label":"State","access":3,"type":"enum","property":"state","values":["OPEN","CLOSE","STOP"]},{"name":"position","label":"Position","access":7,"type":"numeric","property":"position","description":"Position of this cover","unit":"%","value_max":100,"value_min":0}]},{"name":"moving","label":"Moving","access":1,"type":"enum","property":"moving","values":["UP","STOP","DOWN"]},{"name":"calibration","label":"Calibration","access":7,"type":"binary","property":"calibration","value_on":"ON","value_off":"OFF"},{"name":"motor_reversal","label":"Motor reversal","access":7,"type":"binary","property":"motor_reversal","value_on":"ON","value_off":"OFF"},{"name":"calibration_time","label":"Calibration time","access":1,"type":"numeric","property":"calibration_time","description":"Calibration time","unit":"s"},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"options":["[Circular]"]},"name":"0xa4c138a0a203ee06"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722860089715,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":87,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":87,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":30,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
    2024-08-05 14:14:49.717 - debug: zigbee.0 (16616) DeviceAvailability:Successfully pinged 0xa4c138a0a203ee06 TS130F
    AsgothianA arteckA 2 Antworten Letzte Antwort
    • P pluto8
      Hallo!
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @pluto8 sagte in ZIGBEE: Ping Intervall ändern (DeviceAvailability):
      Hallo!
      Welche Version ?
      Bleibt der Fehler auch bei der 1.10.5 von github erhalten ?
      P 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        Hallo!
        Welche Version ?
        pluto8
        Welche Version ?
        ioBroker v7.0.22
        Zigbee jetzt manuell auf 1.10.5 geupdated
        Leider sind Fehlermeldungen und Abstand zwischen den (unerwünschten) Reports gleich geblieben. Gibt es keine Möglichkeit diese DeviceAvalability-Anfragen abzuschalten?
        • P pluto8
          Welche Version ?
          ioBroker v7.0.22
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @pluto8
          Ähmmm
          ist ein DEBUG Meldung. Was stört dich an der?
          Wenn du keine Debug Meldungen sehen willst, stell den Adapter einfach auf die normale Einstellung (Info) zurück.
          Und was das Intervall betrifft:
          Was ist da das Problem? Ist dir die Abfrage zu selten? Zu oft ? Und warum?
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • P pluto8
            Hallo!
            arteckA Offline
            arteckA Offline
            arteck
            @pluto8 das sind alles DEBUG Meldungen.. warum steht der Adapter auf Debug ???
            ioBroker v7.0.22
            ich weiss zwar nicht aus welchen Jahrhundert du schreibst aber.. 7.x Version von iobroker ist sehr weit in der Zukunft
            wir sind gerade bei 6.x seid paar Tagen
            • arteckA arteck
              ioBroker v7.0.22
              CodierknechtC Offline
              Codierknecht
              @arteck
              Er meint wohl den Admin ;-)
              @pluto8
              Der Admin-Adapter ist für die Verwaltung und Einstellung Deines ioBroker zuständig.
              Viel interessanter und wichtiger ist die Version des JS-Controllers. Die wird Dir beim Host angezeigt.
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
              • mcm1957M mcm1957
                @pluto8
                Ähmmm
                pluto8
                @mcm1957 said in ZIGBEE: Ping Intervall ändern (DeviceAvailability):
                Ich möchte noch viele Rolladen und weitere Dinge im Haus mit Zigbee regeln. Da sind schnell mal 30 bis 40 Zigbee-Module verbaut.
                Zigbee sendet im Gegensatz zu Wlan nur bei Anforderung, sonst im Ruhe im Bus. ;)
                Es ist jetzt kein Problem, wenn das System alle 5 Minuten den Status ermittelt, aber bevorzugen würde ich längere Intervalle oder auch niemals. Daher noch meine Fragen:
                • Sind diese 5 Minuten fix programmiert und lassen sich nicht ändern?
                • Werden batteriebetriebene Module dann auch in dem Intervall abgefragt?
                • Ich hatte auch mal Z2M über HA laufen. Da war tatsächlich Ruhe im Bus (auch im Debug) ;)
                Ansonsten Danke für die Rückmeldung.
                Übrigens: js-controller: 6.0.9
                • P pluto8
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  • die Ping-Zeit lässt sich (absichtlich) nicht einstellen, sie ist aber dynamisch, und wird mit Grösse des Netzes langsamer, um den Netztraffic zu begrenzen
                  • die Batteriebetriebenen Geräte werden per Definition nicht angeping, da diese im Normalfall sowieso nicht antworten. Bei denen wird die Erreichbarkeit anders festgestellt.
                  • Z2M nutzt prinzipiell ein ähnliches verfahren, allerdings hatten wir Probleme bei der Übernahme der Erreichbarkeit der Geräte so das wir das selber neu programmieren mussten. Dazu nutzen wir vom z2m gemeldete Abfragbare Werte - wobei bei Deinem Gerät da offensichtlich ein Fehler in der Definition vorliegt. Um was für ein Gerät handelt es sich - dann nehmen wir das mit in die nicht abfragbaren Geräte auf.
                    pluto8
                    @asgothian
                    Schade, dass man das nicht einstellen kann. Es geht um das schon oben beschriebene Rolladenmodul.
                    Geräteinformation:
                    model:QS-Zigbee-C03
                    description:Curtain/blind motor controller
                    modelZigbee:TS130F
                    type:Router
                    nwk:65420
                    manuf id:4417
                    manufacturer:_TZ3000_zirycpws
                    power:Mains (single phase)
                    app version:64
                    hard version:1
                    zcl version:3
                    stack version:0
                    date code:
                    interviewed:true
                    configured:false
                    endpoint:1
                    profile:260
                    input clusters:genGroups (4)
                    genScenes (5)
                    genOnOff (6)
                    closuresWindowCovering (258)
                    genBasic (0)
                    output clusters:genOta (25)
                    genTime (10)
                    endpoint:242
                    profile:41440
                    output clusters:greenPower (33)
