  4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
    1.0k
    6.1k
54 Beiträge 5 Kommentatoren 7.1k Aufrufe 3 Beobachtet
  • S stoffel67
    so ich versuch es nochmal
    Zeilen einzeln... und es kommt das:
    pi@raspberrypi:~ $ iob fix
    library: loaded
    Library version=2024-05-24
        Welcome to the ioBroker installation fixer!
        Script version: 2024-01-04
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
    OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Es wurden 15,0 kB in 2 s geholt (7.092 B/s).
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ iob update
    Used repository: stable
    Adapter    "admin"        : 7.0.22   , installed 7.0.22
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
    Adapter    "enet"         : 1.0.1    , installed 1.0.1
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "withings"     : 0.0.13   , installed 0.0.13
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    pi@raspberrypi:~ $ iob upgrade all -y
    Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
    Update radar2 from @2.1.0 to @2.2.0
    NPM version: 10.8.1
    Installing iobroker.radar2@2.2.0... (System call)
    npm error code 7
    npm error path /opt/iobroker/node_modules/@abandonware/noble
    npm error command failed
    npm error command sh -c node-gyp-build
    npm error gyp ERR! UNCAUGHT EXCEPTION
    npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
    npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
    npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
    npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
    npm error gyp ERR! System Linux 6.1.21-v7+
    npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
    npm error gyp ERR! node -v v20.16.0
    npm error gyp ERR! node-gyp -v v7.1.2
    npm error gyp ERR! Node-gyp failed to build your package.
    npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_13_06_761Z-debug-0.log
    host.raspberrypi Cannot install iobroker.radar2@2.2.0: 7
    pi@raspberrypi:~ $ iob upgrade self
    Update js-controller from @5.0.12 to @6.0.9
    Stopped Objects DB
    Stopped States DB
    NPM version: 10.8.1
    Installing iobroker.js-controller@6.0.9... (System call)
    Try to solve ENOTEMPTY error automatically
    Could not handle ENOTEMPTY, because no deletable files were found
    npm error code ENOTEMPTY
    npm error syscall rename
    npm error path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    npm error dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
    npm error errno -39
    npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_14_51_457Z-debug-0.log
    host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
    @stoffel67
    Schmeiß den radar2-Adapter mal raus.
    Dann nochmal wie zuvor.
      @stoffel67
      stoffel67
      das hab ich gemacht… Instanz gelöscht, muss ich noch den Adapter (unter Adapter) löschen?
      Mein Adapter: JUNG/GIRA eNet-Adapter
      Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
      • S stoffel67
        @stoffel67
        Ja natürlich den Adapter.
        • S stoffel67
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @stoffel67 said in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
          Instanz löschen:
          löscht im wesentlichen die Konfigurationsdaten und States einer Instanz. Der Code des Adapetrs wird dabei nicht gelöscht.
          Adapter löschen:
          Löscht den Adaptercode und seine Dependencies
          Löscht auch alle Instanzen.
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • mcm1957M mcm1957
            Instanz löschen:
            Adapter löschen:
            stoffel67
            @mcm1957
            es ist seltsam, ichbekomm den Adapter nicht weg....
            $ iobroker del radar2 --debug
            Delete adapter "radar2"
            host.raspberrypi Counted 1 meta of radar2
            host.raspberrypi Counted 1 adapter for radar2
            host.raspberrypi Counted 1 states (io.radar2.*) from states
            host.raspberrypi Counted 1 states (system.adapter.radar2.*) from states
            host.raspberrypi file radar2.admin deleted
            host.raspberrypi object radar2 deleted
            host.raspberrypi object radar2.admin deleted
            host.raspberrypi Deleting 2 object(s).
            host.raspberrypi Deleting 2 state(s).
            Error deleting adapter radar2 from disk: host.raspberrypi: Cannot uninstall iobroker.radar2: 217
            You might have to delete it yourself!
            Process exited with code 0
            • S stoffel67
              @mcm1957
              @stoffel67
              iob fix
              iob list adapters
                @stoffel67
                iob fix
                iob list adapters
                stoffel67
                schrieb am zuletzt editiert von stoffel67
                auf ein neues...
                pi@raspberrypi:/opt/iobroker $ iob fix
                library: loaded
                Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Es wurden 15,0 kB in 2 s geholt (6.669 B/s).
                Done.
                Autostart enabled!
                pi@raspberrypi:/opt/iobroker $ iob list adapters
                system.adapter.admin                   : admin          - v7.0.22
                system.adapter.backitup                : backitup       - v2.11.0
                system.adapter.discovery               : discovery      - v4.5.0
                system.adapter.ds18b20                 : ds18b20        - v2.0.5
                system.adapter.enet                    : enet           - v1.0.1
                system.adapter.info                    : info           - v1.9.26
                system.adapter.javascript              : javascript     - v8.7.6
                system.adapter.linkeddevices           : linkeddevices  - v1.5.5
                system.adapter.modbus                  : modbus         - v6.1.0
                system.adapter.node-red                : node-red       - v5.2.1
                system.adapter.palazzetti              : palazzetti     - v0.0.6
                system.adapter.proxy                   : proxy          - v1.3.2
                system.adapter.rpi2                    : rpi2           - v1.3.2
                system.adapter.shelly                  : shelly         - v7.0.0
                system.adapter.simple-api              : simple-api     - v2.8.0
                system.adapter.slideshow               : slideshow      - v0.1.4
                system.adapter.smartmeter              : smartmeter     - v3.4.0
                system.adapter.socketio                : socketio       - v6.7.0
                system.adapter.sonoff                  : sonoff         - v3.0.3
                system.adapter.terminal                : terminal       - v0.2.2
                system.adapter.tr-064                  : tr-064         - v4.2.18
                system.adapter.vis                     : vis            - v1.5.6
                system.adapter.vw-connect              : vw-connect     - v0.0.67
                system.adapter.web                     : web            - v6.2.5
                system.adapter.withings                : withings       - v0.0.13
                system.adapter.ws                      : ws             - v2.6.1
                system.adapter.yahka                   : yahka          - v1.0.3
                • S stoffel67
                  auf ein neues...
                  library: loaded
                  Done.
                  Autostart enabled!
                  @stoffel67
                  Also ist sowohl ble wie auch radar2 nun weg.
                  iob update
                  iog upgrade all -y
                  iob stop
                  iob upgrade self
                  iob start
                    @stoffel67
                    iob update
                    iog upgrade all -y
                    iob stop
                    iob upgrade self
                    iob start
                    stoffel67
                    scheinbar nicht, obwohl ich die Adapter gelöscht habe
                    in "iob list adpaters" sind sie weg
                    bei "iob update" tauchen sie wieder auf
                    pi@raspberrypi:/opt/iobroker $ iob update
                    und nochmal von vorne...
                    pi@raspberrypi:/opt/iobroker $ iob upgrade all -y
                    Update modbus from @6.1.0 to @6.2.3
                    NPM version: 10.8.1
                    Installing iobroker.modbus@6.2.3... (System call)
                    changed 1 package in 35s
                    153 packages are looking for funding
                      run `npm fund` for details
                    Update "system.adapter.modbus.0"
                    upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
                    upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                    upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
                    upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
                    upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                    upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
                    upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
                    upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
                    upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
                    upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
                    pi@raspberrypi:/opt/iobroker $ iob stop
                    pi@raspberrypi:/opt/iobroker $ iob upgrade self
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.8.1
                    added 7 packages, removed 45 packages, and changed 26 packages in 2m
                    pi@raspberrypi:/opt/iobroker $ iob start
                    ich denke... Systemseitig ist fast alles wieder Ok... im Log kommt nach iob start noch folgendes:
                    javascript.0
                    2024-08-03 17:16:09.567	error	at Script.runInContext (node:vm:148:12)
                    javascript.0
                    2024-08-03 17:16:09.565	error	at script.js.common.sh1106:707:3
                    javascript.0
                    2024-08-03 17:16:09.563	error	at script.js.common.sh1106:5:18
                    javascript.0
                    2024-08-03 17:16:09.561	error	script.js.common.sh1106: TypeError: Cannot read properties of undefined (reading 'openSync')
                    javascript.0
                    2024-08-03 17:16:09.544	error	at Script.runInContext (node:vm:148:12)
                    javascript.0
                    2024-08-03 17:16:09.543	error	at script.js.common.sh1106:707:3
                    javascript.0
                    2024-08-03 17:16:09.541	error	at script.js.common.sh1106:4:11
                    javascript.0
                    2024-08-03 17:16:09.538	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
                    javascript.0
                    2024-08-03 17:16:09.536	error	at require (node:internal/modules/helpers:179:18)
                    javascript.0
                    2024-08-03 17:16:09.534	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                    javascript.0
                    2024-08-03 17:16:09.531	error	script.js.common.sh1106: Error: Cannot find module '@iobroker-javascript.0/i2c-bus'
                    javascript.0
                    2024-08-03 17:15:27.591	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`). at Object.Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:4:32) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32)
                    javascript.0
                    2024-08-03 17:15:27.589	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
                    javascript.0
                    2024-08-03 17:15:27.583	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                    rpi2.0
                    2024-08-03 17:12:24.679	error	Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: → /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node  /opt/iobroker/node_modules/epoll/out/Release/epoll.node /opt/iobroker/node_modules/epoll/Release/epoll.node  /opt/iobroker/node_modules/epoll/build/default/epoll.node  /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
                    • S stoffel67
                      NPM version: 10.8.1
                      Stopped Objects DB
                      Stopped States DB
                      NPM version: 10.8.1
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      rpi2.0
                      @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                      Das dürfte von einem zusätzlich im javascript-Adapter eingetragenen Modul kommen.
                        stoffel67
                        ich glaube ich habs jetzt wieder "im Griff"...
                        hab ein npm rebuild für i2c-bus gemacht... jetzt scheint dieser Fehler weg zu sein..
                        nur noch etwas vom RPI2 adapter
                        rpi2.0
                        2024-08-03 17:53:04.517	error
                        Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node /opt/iobroker/node_modules/epoll/out/Release/epoll.node  /opt/iobroker/node_modules/epoll/Release/epoll.node /opt/iobroker/node_modules/epoll/build/default/epoll.node /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
                        • S stoffel67
                          rpi2.0
                          Installier den mal in der Beta-Version 2.0. Der ist relativ umfangreich umgebaut worden.
                          mcm1957M S 2 Antworten Letzte Antwort
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            Ja - ist unbedingt notwendig.
                            Falls es mit rpi2 Probleme gibt bitte ium diesbezüglichen Test Topic ansprechen.
                            • mcm1957M mcm1957
                              stoffel67
                              @mcm1957 @Thomas-Braun
                              ja werde ich testen, heute nicht mehr
                              vielen Dank an euch für eure Hilfe… ist einfach super die Unterstützung hier…
                                stoffel67
                                so, habe mal die 2.0.0 installiert....läuft auch nicht ...
                                rpi2.0
                                2024-08-04 11:12:46.507	error	Cannot initialize/setMode GPIO: Error: Cannot find module 'opengpio' Require stack: - /opt/iobroker/node_modules/iobroker.rpi2/lib/gpioControl.js - /opt/iobroker/node_modules/iobroker.rpi2/main.js
                                • S stoffel67
                                  rpi2.0
                                  Wie installiert? Denn das vermisste Modul 'opengpio' wird bei der sauberen Installation mitinstalliert:
                                  echad@chet:/opt/iobroker $ npm ls opengpio
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  └─┬ iobroker.rpi2@2.0.0
                                    └── opengpio@1.1.0
                                  • S stoffel67
                                    rpi2.0
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @stoffel67
                                    rpi2 test thread:
                                    https://forum.iobroker.net/topic/75290/test-adapter-rpi2-2-x
                                    Dort liest / antwortet auch der Dev
                                        └── opengpio@1.1.0
                                      stoffel67
                                      pi@raspberrypi:~ $ cd /opt/iobroker/
                                      pi@raspberrypi:/opt/iobroker $ npm ls opengpio
                                        └── opengpio@1.1.0
