  4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
    1.0k
    6.1k
54 Beiträge 5 Kommentatoren 7.1k Aufrufe 3 Beobachtet
  • S stoffel67
    auf ein neues...
    pi@raspberrypi:/opt/iobroker $ iob fix
    library: loaded
    Library version=2024-05-24
        Welcome to the ioBroker installation fixer!
        Script version: 2024-01-04
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Es wurden 15,0 kB in 2 s geholt (6.669 B/s).
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:/opt/iobroker $ iob list adapters
    system.adapter.admin                   : admin          - v7.0.22
    system.adapter.backitup                : backitup       - v2.11.0
    system.adapter.discovery               : discovery      - v4.5.0
    system.adapter.ds18b20                 : ds18b20        - v2.0.5
    system.adapter.enet                    : enet           - v1.0.1
    system.adapter.info                    : info           - v1.9.26
    system.adapter.javascript              : javascript     - v8.7.6
    system.adapter.linkeddevices           : linkeddevices  - v1.5.5
    system.adapter.modbus                  : modbus         - v6.1.0
    system.adapter.node-red                : node-red       - v5.2.1
    system.adapter.palazzetti              : palazzetti     - v0.0.6
    system.adapter.proxy                   : proxy          - v1.3.2
    system.adapter.rpi2                    : rpi2           - v1.3.2
    system.adapter.shelly                  : shelly         - v7.0.0
    system.adapter.simple-api              : simple-api     - v2.8.0
    system.adapter.slideshow               : slideshow      - v0.1.4
    system.adapter.smartmeter              : smartmeter     - v3.4.0
    system.adapter.socketio                : socketio       - v6.7.0
    system.adapter.sonoff                  : sonoff         - v3.0.3
    system.adapter.terminal                : terminal       - v0.2.2
    system.adapter.tr-064                  : tr-064         - v4.2.18
    system.adapter.vis                     : vis            - v1.5.6
    system.adapter.vw-connect              : vw-connect     - v0.0.67
    system.adapter.web                     : web            - v6.2.5
    system.adapter.withings                : withings       - v0.0.13
    system.adapter.ws                      : ws             - v2.6.1
    system.adapter.yahka                   : yahka          - v1.0.3
    @stoffel67
    Also ist sowohl ble wie auch radar2 nun weg.
    iob update
    iog upgrade all -y
    iob stop
    iob upgrade self
    iob start
      @stoffel67
      iob update
      iog upgrade all -y
      iob stop
      iob upgrade self
      iob start
      stoffel67
      schrieb am zuletzt editiert von stoffel67
      scheinbar nicht, obwohl ich die Adapter gelöscht habe
      in "iob list adpaters" sind sie weg
      bei "iob update" tauchen sie wieder auf
      pi@raspberrypi:/opt/iobroker $ iob update
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
      Adapter    "enet"         : 1.0.1    , installed 1.0.1
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      und nochmal von vorne...
      pi@raspberrypi:/opt/iobroker $ iob upgrade all -y
      Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
      Update modbus from @6.1.0 to @6.2.3
      NPM version: 10.8.1
      Installing iobroker.modbus@6.2.3... (System call)
      changed 1 package in 35s
      153 packages are looking for funding
        run `npm fund` for details
      Update "system.adapter.modbus.0"
      upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
      upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
      upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
      upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
      upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
      upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
      upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
      upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
      upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
      pi@raspberrypi:/opt/iobroker $ iob stop
      pi@raspberrypi:/opt/iobroker $ iob upgrade self
      Update js-controller from @5.0.12 to @6.0.9
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.8.1
      Installing iobroker.js-controller@6.0.9... (System call)
      added 7 packages, removed 45 packages, and changed 26 packages in 2m
      pi@raspberrypi:/opt/iobroker $ iob start
      ich denke... Systemseitig ist fast alles wieder Ok... im Log kommt nach iob start noch folgendes:
      javascript.0
      2024-08-03 17:16:09.567	error	at Script.runInContext (node:vm:148:12)
      javascript.0
      2024-08-03 17:16:09.565	error	at script.js.common.sh1106:707:3
      javascript.0
      2024-08-03 17:16:09.563	error	at script.js.common.sh1106:5:18
      javascript.0
      2024-08-03 17:16:09.561	error	script.js.common.sh1106: TypeError: Cannot read properties of undefined (reading 'openSync')
      javascript.0
      2024-08-03 17:16:09.544	error	at Script.runInContext (node:vm:148:12)
      javascript.0
      2024-08-03 17:16:09.543	error	at script.js.common.sh1106:707:3
      javascript.0
      2024-08-03 17:16:09.541	error	at script.js.common.sh1106:4:11
      javascript.0
      2024-08-03 17:16:09.538	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
      javascript.0
      2024-08-03 17:16:09.536	error	at require (node:internal/modules/helpers:179:18)
      javascript.0
      2024-08-03 17:16:09.534	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
      javascript.0
      2024-08-03 17:16:09.531	error	script.js.common.sh1106: Error: Cannot find module '@iobroker-javascript.0/i2c-bus'
      javascript.0
      2024-08-03 17:15:27.591	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`). at Object.Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:4:32) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32)
      javascript.0
      2024-08-03 17:15:27.589	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      javascript.0
      2024-08-03 17:15:27.583	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      rpi2.0
      2024-08-03 17:12:24.679	error	Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: → /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node  /opt/iobroker/node_modules/epoll/out/Release/epoll.node /opt/iobroker/node_modules/epoll/Release/epoll.node  /opt/iobroker/node_modules/epoll/build/default/epoll.node  /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
      Mein Adapter: JUNG/GIRA eNet-Adapter
      • S stoffel67
        NPM version: 10.8.1
        Stopped Objects DB
        Stopped States DB
        NPM version: 10.8.1
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        rpi2.0
        @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
        Das dürfte von einem zusätzlich im javascript-Adapter eingetragenen Modul kommen.
          stoffel67
          ich glaube ich habs jetzt wieder "im Griff"...
          hab ein npm rebuild für i2c-bus gemacht... jetzt scheint dieser Fehler weg zu sein..
          nur noch etwas vom RPI2 adapter
          rpi2.0
          2024-08-03 17:53:04.517	error
          Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node /opt/iobroker/node_modules/epoll/out/Release/epoll.node  /opt/iobroker/node_modules/epoll/Release/epoll.node /opt/iobroker/node_modules/epoll/build/default/epoll.node /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
          • S stoffel67
            rpi2.0
            Installier den mal in der Beta-Version 2.0. Der ist relativ umfangreich umgebaut worden.
            mcm1957M S 2 Antworten Letzte Antwort
              mcm1957M Online
              mcm1957M Online
              mcm1957
              Ja - ist unbedingt notwendig.
              Falls es mit rpi2 Probleme gibt bitte ium diesbezüglichen Test Topic ansprechen.
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              • mcm1957M mcm1957
                stoffel67
                @mcm1957 @Thomas-Braun
                ja werde ich testen, heute nicht mehr
                vielen Dank an euch für eure Hilfe… ist einfach super die Unterstützung hier…
                  stoffel67
                  so, habe mal die 2.0.0 installiert....läuft auch nicht ...
                  rpi2.0
                  2024-08-04 11:12:46.507	error	Cannot initialize/setMode GPIO: Error: Cannot find module 'opengpio' Require stack: - /opt/iobroker/node_modules/iobroker.rpi2/lib/gpioControl.js - /opt/iobroker/node_modules/iobroker.rpi2/main.js
                  Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                  • S stoffel67
                    rpi2.0
                    Wie installiert? Denn das vermisste Modul 'opengpio' wird bei der sauberen Installation mitinstalliert:
                    echad@chet:/opt/iobroker $ npm ls opengpio
                    iobroker.inst@3.0.0 /opt/iobroker
                    └─┬ iobroker.rpi2@2.0.0
                      └── opengpio@1.1.0
                    • S stoffel67
                      rpi2.0
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @stoffel67
                      rpi2 test thread:
                      https://forum.iobroker.net/topic/75290/test-adapter-rpi2-2-x
                      Dort liest / antwortet auch der Dev
                          └── opengpio@1.1.0
                        stoffel67
                        pi@raspberrypi:~ $ cd /opt/iobroker/
                        pi@raspberrypi:/opt/iobroker $ npm ls opengpio
                          └── opengpio@1.1.0
