  4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
    1.0k
    6.1k
54 Beiträge 5 Kommentatoren 7.1k Aufrufe 3 Beobachtet
    @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
    der fix läuft eigentlich immer durch
    Soll es ja auch. Muss da ja aufräumen.
    iob stop
    iob fix
    iob update
    iob upgrade all -y
    iob upgrade self
    stoffel67
    i@raspberrypi:/opt/iobroker $
    pi@raspberrypi:/opt/iobroker $ iob stop
    iob fix
    iob update
    iob upgrade all -y
    iob upgrade self
    library: loaded
    Library version=2024-05-24
        Welcome to the ioBroker installation fixer!
        Script version: 2024-01-04
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    Used repository: stable
    Adapter    "admin"        : 7.0.22   , installed 7.0.22
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
    Adapter    "enet"         : 1.0.1    , installed 1.0.1
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "withings"     : 0.0.13   , installed 0.0.13
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
    Update radar2 from @2.1.0 to @2.2.0
    NPM version: 10.8.1
    Installing iobroker.radar2@2.2.0... (System call)
    npm error code 7
    npm error path /opt/iobroker/node_modules/@abandonware/noble
    npm error command failed
    npm error command sh -c node-gyp-build
    npm error gyp ERR! UNCAUGHT EXCEPTION
    npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
    npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
    npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
    npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
    npm error gyp ERR! System Linux 6.1.21-v7+
    npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
    npm error gyp ERR! node -v v20.16.0
    npm error gyp ERR! node-gyp -v v7.1.2
    npm error gyp ERR! Node-gyp failed to build your package.
    npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_07_10_998Z-debug-0.log
    host.raspberrypi Cannot install iobroker.radar2@2.2.0: 7
    Update js-controller from @5.0.12 to @6.0.9
    Stopped Objects DB
    Stopped States DB
    NPM version: 10.8.1
    Installing iobroker.js-controller@6.0.9... (System call)
    Try to solve ENOTEMPTY error automatically
    Could not handle ENOTEMPTY, because no deletable files were found
    npm error code ENOTEMPTY
    npm error syscall rename
    npm error path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    npm error dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
    npm error errno -39
    npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_08_31_744Z-debug-0.log
    host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
    sollte ich das ganze evtl. einfach neu aufsetzen…
    es ist wohl „nur“ meine Testumgebung, aber wenn da schon Probleme bekomme, trau ich mich nicht an meine Produktivumgebung, die muss laufen sonst gibts hier zuhause Ärger,
    der Auslöser war eigentlich ein Anwender meines Adapters, der upgegradet hat und darauf Problem bekam…
    Mein Adapter: JUNG/GIRA eNet-Adapter
    • S stoffel67
      iob fix
      iob update
      iob upgrade all -y
      iob upgrade self
      library: loaded
      Done.
      Autostart enabled!
      NPM version: 10.8.1
      npm error code 7
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.8.1
      npm error errno -39
      @stoffel67
      Du sollst die Befehle einzeln, zeilenweise eingeben.
      S 2 Antworten Letzte Antwort
        @stoffel67
        stoffel67
        ich muss hier unterbrechen… sonst bekomm ich Ärger, werden morgen weiter machen,
        vielen Dank für deine Hilfe!!!!super
          @stoffel67
          stoffel67
          so ich versuch es nochmal
          Zeilen einzeln... und es kommt das:
          pi@raspberrypi:~ $ iob fix
          library: loaded
          OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
          Es wurden 15,0 kB in 2 s geholt (7.092 B/s).
          Done.
          Autostart enabled!
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $ iob update
          pi@raspberrypi:~ $ iob upgrade all -y
          NPM version: 10.8.1
          npm error code 7
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_13_06_761Z-debug-0.log
          pi@raspberrypi:~ $ iob upgrade self
          Stopped Objects DB
          Stopped States DB
          NPM version: 10.8.1
          npm error errno -39
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_14_51_457Z-debug-0.log
          • S stoffel67
            library: loaded
            Done.
            Autostart enabled!
            pi@raspberrypi:~ $
            NPM version: 10.8.1
            npm error code 7
            Stopped Objects DB
            Stopped States DB
            NPM version: 10.8.1
            npm error errno -39
            @stoffel67
            Schmeiß den radar2-Adapter mal raus.
            Dann nochmal wie zuvor.
              @stoffel67
              stoffel67
              das hab ich gemacht… Instanz gelöscht, muss ich noch den Adapter (unter Adapter) löschen?
              Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
              • S stoffel67
                @stoffel67
                Ja natürlich den Adapter.
                • S stoffel67
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @stoffel67 said in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                  Instanz löschen:
                  löscht im wesentlichen die Konfigurationsdaten und States einer Instanz. Der Code des Adapetrs wird dabei nicht gelöscht.
                  Adapter löschen:
                  Löscht den Adaptercode und seine Dependencies
                  Löscht auch alle Instanzen.
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • mcm1957M mcm1957
                    Instanz löschen:
                    Adapter löschen:
                    stoffel67
                    @mcm1957
                    es ist seltsam, ichbekomm den Adapter nicht weg....
                    $ iobroker del radar2 --debug
                    Delete adapter "radar2"
                    host.raspberrypi Counted 1 meta of radar2
                    host.raspberrypi Counted 1 adapter for radar2
                    host.raspberrypi Counted 1 states (io.radar2.*) from states
                    host.raspberrypi Counted 1 states (system.adapter.radar2.*) from states
                    host.raspberrypi file radar2.admin deleted
                    host.raspberrypi object radar2 deleted
                    host.raspberrypi object radar2.admin deleted
                    host.raspberrypi Deleting 2 object(s).
                    host.raspberrypi Deleting 2 state(s).
                    Error deleting adapter radar2 from disk: host.raspberrypi: Cannot uninstall iobroker.radar2: 217
                    You might have to delete it yourself!
                    Process exited with code 0
                    • S stoffel67
                      @mcm1957
                      @stoffel67
                      iob fix
                      iob list adapters
                        @stoffel67
                        iob fix
                        iob list adapters
                        stoffel67
                        schrieb am zuletzt editiert von stoffel67
                        auf ein neues...
                        pi@raspberrypi:/opt/iobroker $ iob fix
                        library: loaded
                        Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                        Es wurden 15,0 kB in 2 s geholt (6.669 B/s).
                        Done.
                        Autostart enabled!
                        pi@raspberrypi:/opt/iobroker $ iob list adapters
                        system.adapter.admin                   : admin          - v7.0.22
                        system.adapter.backitup                : backitup       - v2.11.0
                        system.adapter.discovery               : discovery      - v4.5.0
                        system.adapter.ds18b20                 : ds18b20        - v2.0.5
                        system.adapter.enet                    : enet           - v1.0.1
                        system.adapter.info                    : info           - v1.9.26
                        system.adapter.javascript              : javascript     - v8.7.6
                        system.adapter.linkeddevices           : linkeddevices  - v1.5.5
                        system.adapter.modbus                  : modbus         - v6.1.0
                        system.adapter.node-red                : node-red       - v5.2.1
                        system.adapter.palazzetti              : palazzetti     - v0.0.6
                        system.adapter.proxy                   : proxy          - v1.3.2
                        system.adapter.rpi2                    : rpi2           - v1.3.2
                        system.adapter.shelly                  : shelly         - v7.0.0
                        system.adapter.simple-api              : simple-api     - v2.8.0
                        system.adapter.slideshow               : slideshow      - v0.1.4
                        system.adapter.smartmeter              : smartmeter     - v3.4.0
                        system.adapter.socketio                : socketio       - v6.7.0
                        system.adapter.sonoff                  : sonoff         - v3.0.3
                        system.adapter.terminal                : terminal       - v0.2.2
                        system.adapter.tr-064                  : tr-064         - v4.2.18
                        system.adapter.vis                     : vis            - v1.5.6
                        system.adapter.vw-connect              : vw-connect     - v0.0.67
                        system.adapter.web                     : web            - v6.2.5
                        system.adapter.withings                : withings       - v0.0.13
                        system.adapter.ws                      : ws             - v2.6.1
                        system.adapter.yahka                   : yahka          - v1.0.3
                        • S stoffel67
                          auf ein neues...
                          library: loaded
                          Done.
                          Autostart enabled!
                          @stoffel67
                          Also ist sowohl ble wie auch radar2 nun weg.
                          iob update
                          iog upgrade all -y
                          iob stop
                          iob upgrade self
                          iob start
                            @stoffel67
                            iob update
                            iog upgrade all -y
                            iob stop
                            iob upgrade self
                            iob start
                            stoffel67
                            scheinbar nicht, obwohl ich die Adapter gelöscht habe
                            in "iob list adpaters" sind sie weg
                            bei "iob update" tauchen sie wieder auf
                            pi@raspberrypi:/opt/iobroker $ iob update
                            und nochmal von vorne...
                            pi@raspberrypi:/opt/iobroker $ iob upgrade all -y
                            Update modbus from @6.1.0 to @6.2.3
                            NPM version: 10.8.1
                            Installing iobroker.modbus@6.2.3... (System call)
                            changed 1 package in 35s
                            153 packages are looking for funding
                              run `npm fund` for details
                            Update "system.adapter.modbus.0"
                            upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
                            upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                            upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
                            upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
                            upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                            upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
                            upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
                            upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
                            upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
                            upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
                            pi@raspberrypi:/opt/iobroker $ iob upgrade self
                            Stopped Objects DB
                            Stopped States DB
                            NPM version: 10.8.1
                            added 7 packages, removed 45 packages, and changed 26 packages in 2m
                            pi@raspberrypi:/opt/iobroker $ iob start
                            ich denke... Systemseitig ist fast alles wieder Ok... im Log kommt nach iob start noch folgendes:
                            javascript.0
                            2024-08-03 17:16:09.567	error	at Script.runInContext (node:vm:148:12)
                            javascript.0
                            2024-08-03 17:16:09.565	error	at script.js.common.sh1106:707:3
                            javascript.0
                            2024-08-03 17:16:09.563	error	at script.js.common.sh1106:5:18
                            javascript.0
                            2024-08-03 17:16:09.561	error	script.js.common.sh1106: TypeError: Cannot read properties of undefined (reading 'openSync')
                            javascript.0
                            2024-08-03 17:16:09.544	error	at Script.runInContext (node:vm:148:12)
                            javascript.0
                            2024-08-03 17:16:09.543	error	at script.js.common.sh1106:707:3
                            javascript.0
                            2024-08-03 17:16:09.541	error	at script.js.common.sh1106:4:11
                            javascript.0
                            2024-08-03 17:16:09.538	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
                            javascript.0
                            2024-08-03 17:16:09.536	error	at require (node:internal/modules/helpers:179:18)
                            javascript.0
                            2024-08-03 17:16:09.534	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                            javascript.0
                            2024-08-03 17:16:09.531	error	script.js.common.sh1106: Error: Cannot find module '@iobroker-javascript.0/i2c-bus'
                            javascript.0
                            2024-08-03 17:15:27.591	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`). at Object.Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:4:32) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32)
                            javascript.0
                            2024-08-03 17:15:27.589	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
                            javascript.0
                            2024-08-03 17:15:27.583	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                            rpi2.0
                            2024-08-03 17:12:24.679	error	Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: → /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node  /opt/iobroker/node_modules/epoll/out/Release/epoll.node /opt/iobroker/node_modules/epoll/Release/epoll.node  /opt/iobroker/node_modules/epoll/build/default/epoll.node  /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
                            • S stoffel67
                              NPM version: 10.8.1
                              Stopped Objects DB
                              Stopped States DB
                              NPM version: 10.8.1
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              javascript.0
                              rpi2.0
                              Das dürfte von einem zusätzlich im javascript-Adapter eingetragenen Modul kommen.
                                stoffel67
                                ich glaube ich habs jetzt wieder "im Griff"...
                                hab ein npm rebuild für i2c-bus gemacht... jetzt scheint dieser Fehler weg zu sein..
                                nur noch etwas vom RPI2 adapter
                                rpi2.0
                                2024-08-03 17:53:04.517	error
                                Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node /opt/iobroker/node_modules/epoll/out/Release/epoll.node  /opt/iobroker/node_modules/epoll/Release/epoll.node /opt/iobroker/node_modules/epoll/build/default/epoll.node /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
                                • S stoffel67
                                  rpi2.0
                                  Installier den mal in der Beta-Version 2.0. Der ist relativ umfangreich umgebaut worden.
                                  mcm1957M S 2 Antworten Letzte Antwort
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    Ja - ist unbedingt notwendig.
                                    Falls es mit rpi2 Probleme gibt bitte ium diesbezüglichen Test Topic ansprechen.
                                    • mcm1957M mcm1957
                                      stoffel67
                                      @mcm1957 @Thomas-Braun
                                      ja werde ich testen, heute nicht mehr
                                      vielen Dank an euch für eure Hilfe… ist einfach super die Unterstützung hier…
                                        stoffel67
                                        so, habe mal die 2.0.0 installiert....läuft auch nicht ...
                                        rpi2.0
                                        2024-08-04 11:12:46.507	error	Cannot initialize/setMode GPIO: Error: Cannot find module 'opengpio' Require stack: - /opt/iobroker/node_modules/iobroker.rpi2/lib/gpioControl.js - /opt/iobroker/node_modules/iobroker.rpi2/main.js
                                        • S stoffel67
                                          rpi2.0
                                          Wie installiert? Denn das vermisste Modul 'opengpio' wird bei der sauberen Installation mitinstalliert:
                                          echad@chet:/opt/iobroker $ npm ls opengpio
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          └─┬ iobroker.rpi2@2.0.0
                                            └── opengpio@1.1.0
