  4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
    1.0k
    6.1k
54 Beiträge 5 Kommentatoren 7.1k Aufrufe 3 Beobachtet
  • S stoffel67
    @stoffel67
    pi@raspberrypi:/opt/iobroker $ iob stop
    pi@raspberrypi:/opt/iobroker $ iob upgrade self
    Update js-controller from @5.0.12 to @6.0.9
    Stopped Objects DB
    Stopped States DB
    NPM version: 10.8.1
    Installing iobroker.js-controller@6.0.9... (System call)
    Try to solve ENOTEMPTY error automatically
    Could not handle ENOTEMPTY, because no deletable files were found
    npm error code ENOTEMPTY
    npm error syscall rename
    npm error path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types
    npm error dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue
    npm error errno -39
    npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue'
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_32_43_299Z-debug-0.log
    host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
    @stoffel67
    iob stop
    iob fix
    iob update
    iob upgrade all -y
    iob upgrade self
      @stoffel67
      iob stop
      iob fix
      iob update
      iob upgrade all -y
      iob upgrade self
      stoffel67
      es wird immer schlimmer
      iob fix
      iob update
      iob upgrade all -y
      iob upgrade self
      library: loaded
      Library version=2024-05-24
          Welcome to the ioBroker installation fixer!
          Script version: 2024-01-04
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Holen:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13,2 MB]
      Es wurden 13,3 MB in 15 s geholt (855 kB/s).
          Checking ioBroker user and directory permissions (2/5)
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
      Adapter    "enet"         : 1.0.1    , installed 1.0.1
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
      Update radar2 from @2.1.0 to @2.2.0
      NPM version: 10.8.1
      Installing iobroker.radar2@2.2.0... (System call)
      npm error code 7
      npm error path /opt/iobroker/node_modules/@abandonware/noble
      npm error command failed
      npm error command sh -c node-gyp-build
      npm error gyp ERR! UNCAUGHT EXCEPTION
      npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
      npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
      npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
      npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
      npm error gyp ERR! System Linux 6.1.21-v7+
      npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
      npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
      npm error gyp ERR! node -v v20.16.0
      npm error gyp ERR! node-gyp -v v7.1.2
      npm error gyp ERR! Node-gyp failed to build your package.
      npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_39_25_194Z-debug-0.log
      host.raspberrypi Cannot install iobroker.radar2@2.2.0: 7
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.8.1
      npm error path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      npm error dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
      npm error errno -39
      npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_40_47_269Z-debug-0.log
      Mein Adapter: JUNG/GIRA eNet-Adapter
      • S stoffel67
        iob fix
        iob update
        iob upgrade all -y
        iob upgrade self
        library: loaded
        Done.
        Autostart enabled!
        NPM version: 10.8.1
        npm error code 7
        Stopped Objects DB
        Stopped States DB
        NPM version: 10.8.1
        npm error errno -39
        @stoffel67
        iob delete ble
        iob fix
          @stoffel67
          iob delete ble
          iob fix
          stoffel67
          pi@raspberrypi:/opt/iobroker $ iob delete  ble
          Delete adapter "ble"
          host.raspberrypi Counted 1 instances of ble
          host.raspberrypi Counted 1 meta of ble
          host.raspberrypi Counted 1 adapter for ble
          host.raspberrypi Counted 2 channels of ble
          host.raspberrypi Counted 3 states of ble
          host.raspberrypi Counted 14 states of system.adapter.ble
          host.raspberrypi Counted 1 states (system.adapter.ble.*) from states
          host.raspberrypi file ble.admin deleted
          host.raspberrypi object ble deleted
          host.raspberrypi object ble.admin deleted
          host.raspberrypi Deleting 22 object(s).
          host.raspberrypi Deleting 1 state(s).
          Error deleting adapter ble from disk: host.raspberrypi: Cannot uninstall iobroker.ble: 217
          You might have to delete it yourself!
          • S stoffel67
            @stoffel67
            iob list adapters
            iob fix
              @stoffel67
              iob list adapters
              iob fix
              stoffel67
              der fix läuft eigentlich immer durch
              pi@raspberrypi:/opt/iobroker $ iob list adapters
              iob fix
              system.adapter.admin                   : admin          - v7.0.22
              system.adapter.backitup                : backitup       - v2.11.0
              system.adapter.discovery               : discovery      - v4.5.0
              system.adapter.ds18b20                 : ds18b20        - v2.0.5
              system.adapter.enet                    : enet           - v1.0.1
              system.adapter.info                    : info           - v1.9.26
              system.adapter.javascript              : javascript     - v8.7.6
              system.adapter.linkeddevices           : linkeddevices  - v1.5.5
              system.adapter.modbus                  : modbus         - v6.1.0
              system.adapter.node-red                : node-red       - v5.2.1
              system.adapter.palazzetti              : palazzetti     - v0.0.6
              system.adapter.proxy                   : proxy          - v1.3.2
              system.adapter.radar2                  : radar2         - v2.1.0
              system.adapter.rpi2                    : rpi2           - v1.3.2
              system.adapter.shelly                  : shelly         - v7.0.0
              system.adapter.simple-api              : simple-api     - v2.8.0
              system.adapter.slideshow               : slideshow      - v0.1.4
              system.adapter.smartmeter              : smartmeter     - v3.4.0
              system.adapter.socketio                : socketio       - v6.7.0
              system.adapter.sonoff                  : sonoff         - v3.0.3
              system.adapter.terminal                : terminal       - v0.2.2
              system.adapter.tr-064                  : tr-064         - v4.2.18
              system.adapter.vis                     : vis            - v1.5.6
              system.adapter.vw-connect              : vw-connect     - v0.0.67
              system.adapter.web                     : web            - v6.2.5
              system.adapter.withings                : withings       - v0.0.13
              system.adapter.ws                      : ws             - v2.6.1
              system.adapter.yahka                   : yahka          - v1.0.3
              pi@raspberrypi:/opt/iobroker $ iob fix
              library: loaded
              OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
              OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Done.
              Autostart enabled!
              • S stoffel67
                iob fix
                library: loaded
                Done.
                Autostart enabled!
                @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                Soll es ja auch. Muss da ja aufräumen.
                iob stop
                iob fix
                iob update
                iob upgrade all -y
                iob upgrade self
                HomoranH S 2 Antworten Letzte Antwort
                  iob stop
                  iob fix
                  iob update
                  iob upgrade all -y
                  iob upgrade self
                  @thomas-braun sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                  iob stop
                  iob fix
                  iob update
                  iob upgrade all -y
                  iob upgrade self
                  @stoffel67
                  bitte einzeln aufrufen!
                    iob stop
                    iob fix
                    iob update
                    iob upgrade all -y
                    iob upgrade self
                    stoffel67
                    iob fix
                    iob update
                    iob upgrade all -y
                    iob upgrade self
                    library: loaded
                    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Done.
                    Autostart enabled!
                    NPM version: 10.8.1
                    npm error code 7
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_07_10_998Z-debug-0.log
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.8.1
                    npm error errno -39
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_08_31_744Z-debug-0.log
                    sollte ich das ganze evtl. einfach neu aufsetzen…
                    es ist wohl „nur“ meine Testumgebung, aber wenn da schon Probleme bekomme, trau ich mich nicht an meine Produktivumgebung, die muss laufen sonst gibts hier zuhause Ärger,
                    der Auslöser war eigentlich ein Anwender meines Adapters, der upgegradet hat und darauf Problem bekam…
                    • S stoffel67
                      iob fix
                      iob update
                      iob upgrade all -y
                      iob upgrade self
                      library: loaded
                      Done.
                      Autostart enabled!
                      NPM version: 10.8.1
                      npm error code 7
                      Stopped Objects DB
                      Stopped States DB
                      NPM version: 10.8.1
                      npm error errno -39
                      @stoffel67
                      Du sollst die Befehle einzeln, zeilenweise eingeben.
                        @stoffel67
                        stoffel67
                        ich muss hier unterbrechen… sonst bekomm ich Ärger, werden morgen weiter machen,
                        vielen Dank für deine Hilfe!!!!super
                          @stoffel67
                          stoffel67
                          so ich versuch es nochmal
                          Zeilen einzeln... und es kommt das:
                          pi@raspberrypi:~ $ iob fix
                          library: loaded
                          Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                          Es wurden 15,0 kB in 2 s geholt (7.092 B/s).
                          Done.
                          Autostart enabled!
                          pi@raspberrypi:~ $
                          pi@raspberrypi:~ $ iob update
                          pi@raspberrypi:~ $ iob upgrade all -y
                          NPM version: 10.8.1
                          npm error code 7
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_13_06_761Z-debug-0.log
                          pi@raspberrypi:~ $ iob upgrade self
                          Stopped Objects DB
                          Stopped States DB
                          NPM version: 10.8.1
                          npm error errno -39
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_14_51_457Z-debug-0.log
                          • S stoffel67
                            library: loaded
                            Done.
                            Autostart enabled!
                            pi@raspberrypi:~ $
                            NPM version: 10.8.1
                            npm error code 7
                            Stopped Objects DB
                            Stopped States DB
                            NPM version: 10.8.1
                            npm error errno -39
                            @stoffel67
                            Schmeiß den radar2-Adapter mal raus.
                            Dann nochmal wie zuvor.
                              @stoffel67
                              stoffel67
                              das hab ich gemacht… Instanz gelöscht, muss ich noch den Adapter (unter Adapter) löschen?
                              Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                              • S stoffel67
                                @stoffel67
                                Ja natürlich den Adapter.
                                • S stoffel67
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  @stoffel67 said in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                                  Instanz löschen:
                                  löscht im wesentlichen die Konfigurationsdaten und States einer Instanz. Der Code des Adapetrs wird dabei nicht gelöscht.
                                  Adapter löschen:
                                  Löscht den Adaptercode und seine Dependencies
                                  Löscht auch alle Instanzen.
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                  • mcm1957M mcm1957
                                    Instanz löschen:
                                    Adapter löschen:
                                    stoffel67
                                    @mcm1957
                                    es ist seltsam, ichbekomm den Adapter nicht weg....
                                    $ iobroker del radar2 --debug
                                    Delete adapter "radar2"
                                    host.raspberrypi Counted 1 meta of radar2
                                    host.raspberrypi Counted 1 adapter for radar2
                                    host.raspberrypi Counted 1 states (io.radar2.*) from states
                                    host.raspberrypi Counted 1 states (system.adapter.radar2.*) from states
                                    host.raspberrypi file radar2.admin deleted
                                    host.raspberrypi object radar2 deleted
                                    host.raspberrypi object radar2.admin deleted
                                    host.raspberrypi Deleting 2 object(s).
                                    host.raspberrypi Deleting 2 state(s).
                                    Error deleting adapter radar2 from disk: host.raspberrypi: Cannot uninstall iobroker.radar2: 217
                                    Process exited with code 0
                                    • S stoffel67
                                      @mcm1957
                                      @stoffel67
                                      iob fix
                                      iob list adapters
                                        @stoffel67
                                        iob fix
                                        iob list adapters
                                        stoffel67
                                        schrieb am zuletzt editiert von stoffel67
                                        auf ein neues...
                                        library: loaded
                                        Es wurden 15,0 kB in 2 s geholt (6.669 B/s).
                                        Done.
                                        Autostart enabled!
                                        • S stoffel67
                                          auf ein neues...
                                          library: loaded
                                          Done.
                                          Autostart enabled!
                                          @stoffel67
                                          Also ist sowohl ble wie auch radar2 nun weg.
                                          iob update
                                          iog upgrade all -y
                                          iob stop
                                          iob upgrade self
                                          iob start
