  4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
    1.0k
    6.1k
54 Beiträge 5 Kommentatoren 7.1k Aufrufe 3 Beobachtet
    TT-Tom
    @stoffel67
    Nix mit npm install machen, sondern über
    iob upgrade self
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      @stoffel67
      iob upgrade self
      stoffel67
      @tt-tom
      OK werden den JS-controller updaten
      Mein Adapter: JUNG/GIRA eNet-Adapter
      S Thomas BraunT T 3 Antworten Letzte Antwort
      • S stoffel67
        @tt-tom
        stoffel67
        @stoffel67
        pi@raspberrypi:/opt/iobroker $ iob stop
        pi@raspberrypi:/opt/iobroker $ iob upgrade self
        Update js-controller from @5.0.12 to @6.0.9
        Stopped Objects DB
        Stopped States DB
        NPM version: 10.8.1
        Installing iobroker.js-controller@6.0.9... (System call)
        Try to solve ENOTEMPTY error automatically
        Could not handle ENOTEMPTY, because no deletable files were found
        npm error code ENOTEMPTY
        npm error syscall rename
        npm error path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types
        npm error dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue
        npm error errno -39
        npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue'
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_32_43_299Z-debug-0.log
        host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
        • S stoffel67
          @tt-tom
          @stoffel67
          Hau den javascript-Adapter nochmal drüber.
          • S stoffel67
            @tt-tom
            TT-Tom
            @stoffel67
            Das mine-db Problem löst du damit aber nicht.
            Gruß Tom
            Public Transport
            • S stoffel67
              @stoffel67
              Stopped Objects DB
              Stopped States DB
              NPM version: 10.8.1
              npm error errno -39
              @stoffel67
              iob stop
              iob fix
              iob update
              iob upgrade all -y
              iob upgrade self
                @stoffel67
                iob stop
                iob fix
                iob update
                iob upgrade all -y
                iob upgrade self
                stoffel67
                es wird immer schlimmer
                iob fix
                iob update
                iob upgrade all -y
                iob upgrade self
                library: loaded
                Library version=2024-05-24
                    Welcome to the ioBroker installation fixer!
                    Script version: 2024-01-04
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/5)
                Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                Holen:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13,2 MB]
                Es wurden 13,3 MB in 15 s geholt (855 kB/s).
                    Checking ioBroker user and directory permissions (2/5)
                    Check and cleanup npm temporary directories (3/5)
                Done.
                    Database maintenance (4/5)
                Checking for uncompressed JSONL databases... This might take a while!
                Compressing /opt/iobroker/iobroker-data/states.jsonl
                Compressing /opt/iobroker/iobroker-data/objects.jsonl
                Compressed 2 JSONL files. Done
                    Checking autostart (5/5)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                Used repository: stable
                Adapter    "admin"        : 7.0.22   , installed 7.0.22
                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                Adapter    "ble"          : 0.14.0   , installed 0.14.0
                Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
                Adapter    "enet"         : 1.0.1    , installed 1.0.1
                Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
                Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
                Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
                Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
                Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
                Adapter    "web"          : 6.2.5    , installed 6.2.5
                Adapter    "withings"     : 0.0.13   , installed 0.0.13
                Adapter    "ws"           : 2.6.1    , installed 2.6.1
                Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                Update radar2 from @2.1.0 to @2.2.0
                NPM version: 10.8.1
                Installing iobroker.radar2@2.2.0... (System call)
                npm error code 7
                npm error path /opt/iobroker/node_modules/@abandonware/noble
                npm error command failed
                npm error command sh -c node-gyp-build
                npm error gyp ERR! UNCAUGHT EXCEPTION
                npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
                npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
                npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
                npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
                npm error gyp ERR! System Linux 6.1.21-v7+
                npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
                npm error gyp ERR! node -v v20.16.0
                npm error gyp ERR! node-gyp -v v7.1.2
                npm error gyp ERR! Node-gyp failed to build your package.
                npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_39_25_194Z-debug-0.log
                host.raspberrypi Cannot install iobroker.radar2@2.2.0: 7
                Stopped Objects DB
                Stopped States DB
                NPM version: 10.8.1
                npm error path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                npm error dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
                npm error errno -39
                npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_40_47_269Z-debug-0.log
                • S stoffel67
                  iob fix
                  iob update
                  iob upgrade all -y
                  iob upgrade self
                  library: loaded
                  Done.
                  Autostart enabled!
                  NPM version: 10.8.1
                  npm error code 7
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 10.8.1
                  npm error errno -39
                  @stoffel67
                  iob delete ble
                  iob fix
                    @stoffel67
                    iob delete ble
                    iob fix
                    stoffel67
                    pi@raspberrypi:/opt/iobroker $ iob delete  ble
                    Delete adapter "ble"
                    host.raspberrypi Counted 1 instances of ble
                    host.raspberrypi Counted 1 meta of ble
                    host.raspberrypi Counted 1 adapter for ble
                    host.raspberrypi Counted 2 channels of ble
                    host.raspberrypi Counted 3 states of ble
                    host.raspberrypi Counted 14 states of system.adapter.ble
                    host.raspberrypi Counted 1 states (system.adapter.ble.*) from states
                    host.raspberrypi file ble.admin deleted
                    host.raspberrypi object ble deleted
                    host.raspberrypi object ble.admin deleted
                    host.raspberrypi Deleting 22 object(s).
                    host.raspberrypi Deleting 1 state(s).
                    Error deleting adapter ble from disk: host.raspberrypi: Cannot uninstall iobroker.ble: 217
                    You might have to delete it yourself!
                    • S stoffel67
                      @stoffel67
                      iob list adapters
                      iob fix
                        @stoffel67
                        iob list adapters
                        iob fix
                        stoffel67
                        der fix läuft eigentlich immer durch
                        pi@raspberrypi:/opt/iobroker $ iob list adapters
                        iob fix
                        system.adapter.admin                   : admin          - v7.0.22
                        system.adapter.backitup                : backitup       - v2.11.0
                        system.adapter.discovery               : discovery      - v4.5.0
                        system.adapter.ds18b20                 : ds18b20        - v2.0.5
                        system.adapter.enet                    : enet           - v1.0.1
                        system.adapter.info                    : info           - v1.9.26
                        system.adapter.javascript              : javascript     - v8.7.6
                        system.adapter.linkeddevices           : linkeddevices  - v1.5.5
                        system.adapter.modbus                  : modbus         - v6.1.0
                        system.adapter.node-red                : node-red       - v5.2.1
                        system.adapter.palazzetti              : palazzetti     - v0.0.6
                        system.adapter.proxy                   : proxy          - v1.3.2
                        system.adapter.radar2                  : radar2         - v2.1.0
                        system.adapter.rpi2                    : rpi2           - v1.3.2
                        system.adapter.shelly                  : shelly         - v7.0.0
                        system.adapter.simple-api              : simple-api     - v2.8.0
                        system.adapter.slideshow               : slideshow      - v0.1.4
                        system.adapter.smartmeter              : smartmeter     - v3.4.0
                        system.adapter.socketio                : socketio       - v6.7.0
                        system.adapter.sonoff                  : sonoff         - v3.0.3
                        system.adapter.terminal                : terminal       - v0.2.2
                        system.adapter.tr-064                  : tr-064         - v4.2.18
                        system.adapter.vis                     : vis            - v1.5.6
                        system.adapter.vw-connect              : vw-connect     - v0.0.67
                        system.adapter.web                     : web            - v6.2.5
                        system.adapter.withings                : withings       - v0.0.13
                        system.adapter.ws                      : ws             - v2.6.1
                        system.adapter.yahka                   : yahka          - v1.0.3
                        pi@raspberrypi:/opt/iobroker $ iob fix
                        library: loaded
                        OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Done.
                        Autostart enabled!
                        • S stoffel67
                          iob fix
                          library: loaded
                          Done.
                          Autostart enabled!
                          @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                          Soll es ja auch. Muss da ja aufräumen.
                          iob stop
                          iob fix
                          iob update
                          iob upgrade all -y
                          iob upgrade self
                          HomoranH S 2 Antworten Letzte Antwort
                            iob stop
                            iob fix
                            iob update
                            iob upgrade all -y
                            iob upgrade self
                            @thomas-braun sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                            iob stop
                            iob fix
                            iob update
                            iob upgrade all -y
                            iob upgrade self
                            @stoffel67
                            bitte einzeln aufrufen!
                              iob stop
                              iob fix
                              iob update
                              iob upgrade all -y
                              iob upgrade self
                              stoffel67
                              iob fix
                              iob update
                              iob upgrade all -y
                              iob upgrade self
                              library: loaded
                              OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Done.
                              Autostart enabled!
                              NPM version: 10.8.1
                              npm error code 7
                              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_07_10_998Z-debug-0.log
                              Stopped Objects DB
                              Stopped States DB
                              NPM version: 10.8.1
                              npm error errno -39
                              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_08_31_744Z-debug-0.log
                              sollte ich das ganze evtl. einfach neu aufsetzen…
                              es ist wohl „nur“ meine Testumgebung, aber wenn da schon Probleme bekomme, trau ich mich nicht an meine Produktivumgebung, die muss laufen sonst gibts hier zuhause Ärger,
                              der Auslöser war eigentlich ein Anwender meines Adapters, der upgegradet hat und darauf Problem bekam…
                              • S stoffel67
                                iob fix
                                iob update
                                iob upgrade all -y
                                iob upgrade self
                                library: loaded
                                Done.
                                Autostart enabled!
                                NPM version: 10.8.1
                                npm error code 7
                                Stopped Objects DB
                                Stopped States DB
                                NPM version: 10.8.1
                                npm error errno -39
                                @stoffel67
                                Du sollst die Befehle einzeln, zeilenweise eingeben.
                                  @stoffel67
                                  stoffel67
                                  ich muss hier unterbrechen… sonst bekomm ich Ärger, werden morgen weiter machen,
                                  vielen Dank für deine Hilfe!!!!super
                                    @stoffel67
                                    stoffel67
                                    so ich versuch es nochmal
                                    Zeilen einzeln... und es kommt das:
                                    pi@raspberrypi:~ $ iob fix
                                    library: loaded
                                    Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                                    Es wurden 15,0 kB in 2 s geholt (7.092 B/s).
                                    Done.
                                    Autostart enabled!
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~ $ iob update
                                    pi@raspberrypi:~ $ iob upgrade all -y
                                    NPM version: 10.8.1
                                    npm error code 7
                                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_13_06_761Z-debug-0.log
                                    pi@raspberrypi:~ $ iob upgrade self
                                    Stopped Objects DB
                                    Stopped States DB
                                    NPM version: 10.8.1
                                    npm error errno -39
                                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_14_51_457Z-debug-0.log
                                    • S stoffel67
                                      library: loaded
                                      Done.
                                      Autostart enabled!
                                      pi@raspberrypi:~ $
                                      NPM version: 10.8.1
                                      npm error code 7
                                      Stopped Objects DB
                                      Stopped States DB
                                      NPM version: 10.8.1
                                      npm error errno -39
                                      @stoffel67
                                      Schmeiß den radar2-Adapter mal raus.
                                      Dann nochmal wie zuvor.
                                        @stoffel67
                                        stoffel67
                                        das hab ich gemacht… Instanz gelöscht, muss ich noch den Adapter (unter Adapter) löschen?
                                        Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                                        • S stoffel67
                                          @stoffel67
                                          Ja natürlich den Adapter.
