  4. Kein autostart debian stretch
    apollon77A
83 Beiträge 19 Kommentatoren 28.1k Aufrufe
  • C
    C
    chrram
    das kommt wenn ich iobroker.service per hand starte
    [b]sudo systemctl start iobroker.service[/b]
    Warning: iobroker.service changed on disk. Run 'systemctl daemon-reload' to reload units.
    Job for iobroker.service failed because the control process exited with error code. See "systemctl status iobroker.service" and "journalctl -xe" for details.
    christopher@HomeServer:[b]/etc/systemd/system$ journalctl -xe
    [/b]Jan 02 15:21:31 HomeServer sudo[1527]: christopher : TTY=pts/0 ; PWD=/etc/systemd/system ; USER=root ; COMMAND=/bin/nano iobroker.service
    Jan 02 15:21:31 HomeServer sudo[1527]: pam_unix(sudo:session): session opened for user root by christopher(uid=0)
    Jan 02 15:21:41 HomeServer sudo[1527]: pam_unix(sudo:session): session closed for user root
    Jan 02 15:21:44 HomeServer sudo[1529]: christopher : TTY=pts/0 ; PWD=/etc/systemd/system ; USER=root ; COMMAND=/bin/systemctl status iobroker.service
    Jan 02 15:21:44 HomeServer sudo[1529]: pam_unix(sudo:session): session opened for user root by christopher(uid=0)
    Jan 02 15:21:44 HomeServer sudo[1529]: pam_unix(sudo:session): session closed for user root
    Jan 02 15:21:55 HomeServer sudo[1532]: christopher : TTY=pts/0 ; PWD=/etc/systemd/system ; USER=root ; COMMAND=/bin/systemctl start iobroker.service
    Jan 02 15:21:55 HomeServer sudo[1532]: pam_unix(sudo:session): session opened for user root by christopher(uid=0)
    Jan 02 15:21:55 HomeServer systemd[1]: Starting ioBroker server task...
    -- Subject: Unit iobroker.service has begun start-up
    -- Defined-By: systemd
    -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
    -- Unit iobroker.service has begun starting up.
    Jan 02 15:21:55 HomeServer iobroker.sh[1535]: Usage: iobroker {start|stop|restart}
    Jan 02 15:21:55 HomeServer systemd[1]: iobroker.service: Control process exited, code=exited status=1
    Jan 02 15:21:55 HomeServer systemd[1]: Failed to start ioBroker server task.
    -- Subject: Unit iobroker.service has failed
    -- Unit iobroker.service has failed.
    -- The result is failed.
    Jan 02 15:21:55 HomeServer systemd[1]: iobroker.service: Unit entered failed state.
    Jan 02 15:21:55 HomeServer systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Jan 02 15:21:55 HomeServer sudo[1532]: pam_unix(sudo:session): session closed for user root
    Jan 02 15:22:00 HomeServer sudo[1538]: christopher : TTY=pts/0 ; PWD=/etc/systemd/system ; USER=root ; COMMAND=/bin/systemctl status iobroker.service
    Jan 02 15:22:00 HomeServer sudo[1538]: pam_unix(sudo:session): session opened for user root by christopher(uid=0)
    Jan 02 15:22:00 HomeServer sudo[1538]: pam_unix(sudo:session): session closed for user root
    Jan 02 15:22:03 HomeServer sudo[1541]: christopher : TTY=pts/0 ; PWD=/etc/systemd/system ; USER=root ; COMMAND=/bin/nano iobroker.service
    Jan 02 15:22:03 HomeServer sudo[1541]: pam_unix(sudo:session): session opened for user root by christopher(uid=0)
    Jan 02 15:22:09 HomeServer sudo[1541]: pam_unix(sudo:session): session closed for user root
    Jan 02 15:22:11 HomeServer sudo[1543]: christopher : TTY=pts/0 ; PWD=/etc/systemd/system ; USER=root ; COMMAND=/bin/systemctl start iobroker.service
    Jan 02 15:22:11 HomeServer sudo[1543]: pam_unix(sudo:session): session opened for user root by christopher(uid=0)
    Jan 02 15:22:11 HomeServer systemd[1]: Starting ioBroker server task...
    Jan 02 15:22:11 HomeServer iobroker.sh[1546]: Usage: iobroker {start|stop|restart}
    Jan 02 15:22:11 HomeServer systemd[1]: iobroker.service: Control process exited, code=exited status=1
    Jan 02 15:22:11 HomeServer systemd[1]: Failed to start ioBroker server task.
    Jan 02 15:22:11 HomeServer systemd[1]: iobroker.service: Unit entered failed state.
    Jan 02 15:22:11 HomeServer systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Jan 02 15:22:11 HomeServer sudo[1543]: pam_unix(sudo:session): session closed for user root
    @paul53:
    @chrram:
    das steht im journal
    systemd[1]: Starting ioBroker server task…
    Jan 02 14:35:07 HomeServer iobroker.sh[957]: Usage: iobroker {start|stop|restart} Dann wurde ioBroker wohl nicht automatisch gestartet. Für das "Weshalb" reichen meine Linux-Kenntnisse nicht :(
    danke dir trozdem vielmals für deine jetzige hilfe
    • ruhr70R
      ruhr70R
      ruhr70
      Mit der Kombination des Tipps von Paul53 und der iobroker.sh Datei von Homoran hat es jetzt funktioniert. :)
      http://forum.iobroker.net/viewtopic.php … 20#p109170
      @paul53:
      update-rc.d iobroker.sh defaults
      reboot
      http://forum.iobroker.net/viewtopic.php … 54#p108996
      @Homoran:
      MIt dieser klappt es bei mir
      Ich musste sie auf .txt umbenennen! Bitte wieder eine .sh daraus machen `
      Der Einfachhalthalber habe ich HFS auf einem Windows Rechner gestartet (einfacher Webserver, über den man Dateien per http:// bereitstellen kann). http://www.rejetto.com/hfs/?f=dl
      Es ist keine Installation erforderlich. Die hfs.exe als Admin starten und den Ordner hinzufügen, in der die gewünschte Datei liegt. Dort liegt die iobroker.sh von Homoran (vorher von .txt in .sh geändert)
      Natürlich gibt es zig andere Wege die Datei auf den Linux Rechner zu bekommen.
      Dann folgender Ablauf über die Konsole:
      sudo su
      cd /home
      wget http://[ip des windows Rechner]/[Ordnername]/iobroker.sh
      mv /home/iobroker.sh /etc/init.d/iobroker.sh
      ls /etc/init.d/iobroker.sh -l
      chmod +x /etc/init.d/iobroker.sh
      reboot
      update-rc.d iobroker.sh defaults hatte ich vor dem Reboot wohl nicht ausgeführt. :?
      beim ls +l sah man, dass die kopierte Datei nicht die Rechte zum Ausführen hat (das x).
      Mit der vorhandenen Datei (iobroker.sh) hatten alle Versuche mit update-rc.d iobroker.sh defaults im Verzeichnis /etc/init.d nicht funktioniert (mit Rechte ergänzen, usw.).
      • HomoranH
        Ich bin geistig gerade woanders, aber:
        @ruhr70:
        Mit der Kombination des Tipps von Paul53 und der iobroker.sh Datei von Homoran hat es jetzt funktioniert `
        genau dafür hatte ich sie gepostet.
        Was ist jetzt an euren anders als bei meiner - und vor allem warum.
        Wenn jemand, der sich damit auskennt, das beantworten kann, kommen wir vielleicht auch der Ursache auf den Grund.
        Danke erst mal an alle die hier mitkämpfen!
        • kmxakK
          kmxakK
          kmxak
          also ich hatte wie bereits in mehreren Beiträgen geschrieben auch das Problem.
          Stretch unter root (su root) installiert und kein autostart.
          Ich musste sudo nachinstallieren und habe dann root als sudoer eingefügt sowie hatte ich was mit der iobroker.sh irgendwas gemacht sowie nochmals irgendein install script ausgeführt.
          #!/bin/bash
          BEGIN INIT INFO
          Provides: iobroker.sh
          Required-Start: $network $local_fs $remote_fs
          Required-Stop:: $network $local_fs $remote_fs
          Default-Start: 2 3 4 5
          Default-Stop: 0 1 6
          Short-Description: starts ioBroker
          END INIT INFO
          (( EUID )) && echo .You need to have root privileges.. && exit 1
          PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
          NODECMD=/usr/bin/node
          IOBROKERCMD=/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          RETVAL=0
          IOBROKERUSER=root
          ! start() {
          export IOBROKER_HOME=/opt/iobroker
          echo -n "Starting ioBroker"
          sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD start
          RETVAL=$?
          ! stop() {
          echo -n "Stopping ioBroker"
          sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD stop
          RETVAL=$?
          case "$1" in
          start)
          start
          stop)
          stop
          restart)
          stop
          start
          echo "Usage: iobroker {start|stop|restart}"
          exit 1
          esac
          exit $RETVAL
          Gruß Alex
          • C
            C
            chrram
            also ich habe root in der /etc/sudoers oder sollte er noch woanders drinen sein
            User privilege specification
            root ALL=(ALL:ALL) ALL
            denke das es evt was mit der
            systemctl start iobroker.service zu tun hat das Script funktioniert ja so
            • paul53P
              paul53P
              @chrram:
              root@HomeServer:/etc/init.d# iobroker stop
              module.js:327
              throw err;
              Error: Cannot find module '/etc/init.d/node_modules/iobroker.js-controller/iobroker.js' `
              Das würde mich stutzig machen, da es nichts mit dem Skript /etc/init.d/iobroker.sh zu tun hat, sondern vom Skript /usr/bin/iobroker ausgelöst wird. Woher kommt die Referenz auf das Verzeichnis /etc/init.d/node_modules ?
              @chrram:
              root@HomeServer:/etc/init.d# ./iobroker.sh start
              Starting ioBrokerStarting iobroker controller daemon…
              iobroker controller daemon started. PID: 1722
              root@HomeServer:/etc/init.d# update-rc.d iobroker.sh defaults
              insserv: script iobroker.dos: service iobroker.sh already provided! `
              Offenbar wird ioBroker vom Skript /etc/init.d/iobroker.sh gestartet. Dass in der Meldung von update-rc.d iobroker.dos auftaucht macht mich ebenfalls stutzig. Was sagt die Ausgabe von ?
              ls -l /etc/rc?.d/*iob*
              • C
                C
                chrram
                lrwxrwxrwx 1 root root 18 Jan  1 15:23 /etc/rc0.d/K01iobroker -> ../init.d/iobroker
                lrwxrwxrwx 1 root root 21 Jan  2 14:33 /etc/rc0.d/K01iobroker.sh -> ../init.d/iobroker.sh
                lrwxrwxrwx 1 root root 18 Jan  1 15:23 /etc/rc1.d/K01iobroker -> ../init.d/iobroker
                lrwxrwxrwx 1 root root 21 Jan  2 14:33 /etc/rc1.d/K01iobroker.sh -> ../init.d/iobroker.sh
                lrwxrwxrwx 1 root root 18 Jan  1 15:23 /etc/rc2.d/S01iobroker -> ../init.d/iobroker
                lrwxrwxrwx 1 root root 21 Jan  2 14:33 /etc/rc2.d/S01iobroker.sh -> ../init.d/iobroker.sh
                lrwxrwxrwx 1 root root 18 Jan  1 15:23 /etc/rc3.d/S01iobroker -> ../init.d/iobroker
                lrwxrwxrwx 1 root root 21 Jan  2 14:33 /etc/rc3.d/S01iobroker.sh -> ../init.d/iobroker.sh
                lrwxrwxrwx 1 root root 18 Jan  1 15:23 /etc/rc4.d/S01iobroker -> ../init.d/iobroker
                lrwxrwxrwx 1 root root 21 Jan  2 14:33 /etc/rc4.d/S01iobroker.sh -> ../init.d/iobroker.sh
                lrwxrwxrwx 1 root root 18 Jan  1 15:23 /etc/rc5.d/S01iobroker -> ../init.d/iobroker
                lrwxrwxrwx 1 root root 21 Jan  2 14:33 /etc/rc5.d/S01iobroker.sh -> ../init.d/iobroker.sh
                lrwxrwxrwx 1 root root 18 Jan  1 15:23 /etc/rc6.d/K01iobroker -> ../init.d/iobroker
                lrwxrwxrwx 1 root root 21 Jan  2 14:33 /etc/rc6.d/K01iobroker.sh -> ../init.d/iobroker.sh
                • paul53P
                  paul53P
                  Die Einträge mit ../init.d/iobroker gehören nicht dahin ! Auch die Datei /etc/init.d/iobroker ist zuviel !
                  Versuche mal als user root
                  update-rc.d -f iobroker remove
                  EDIT: So sieht es auf meinem RPi aus:
                  root@rpihm:~# ls -l /etc/rc?.d/*iob*
                  lrwxrwxrwx 1 root root 21 Apr  7  2016 /etc/rc0.d/K01iobroker.sh -> ../init.d/iobroker.sh
                  lrwxrwxrwx 1 root root 21 Apr  7  2016 /etc/rc1.d/K01iobroker.sh -> ../init.d/iobroker.sh
                  lrwxrwxrwx 1 root root 21 Apr  7  2016 /etc/rc2.d/S01iobroker.sh -> ../init.d/iobroker.sh
                  lrwxrwxrwx 1 root root 21 Apr  7  2016 /etc/rc3.d/S01iobroker.sh -> ../init.d/iobroker.sh
                  lrwxrwxrwx 1 root root 21 Apr  7  2016 /etc/rc4.d/S01iobroker.sh -> ../init.d/iobroker.sh
                  lrwxrwxrwx 1 root root 21 Apr  7  2016 /etc/rc5.d/S01iobroker.sh -> ../init.d/iobroker.sh
                  lrwxrwxrwx 1 root root 21 Apr  7  2016 /etc/rc6.d/K01iobroker.sh -> ../init.d/iobroker.sh
                  • C
                    C
                    chrram
                    @paul53:
                    so sieht meine jetzt auch aus
                    dann ein reboot aber kein autostart
                    • paul53P
                      paul53P
                      @chrram:
                      dann ein reboot aber kein autostart `
                      Doch, genau mittels iobroker.sh soll das Killen und der Autostart von ioBroker erfolgen. Jedenfalls funktioniert es auf meinem RPi so (ohne Eingriffe meinerseits).
                      • C
                        C
                        chrram
                        @paul53:
                        @chrram:
                        dann ein reboot aber kein autostart Doch, genau mittels iobroker.sh soll das Killen und der Autostart von ioBroker erfolgen. Jedenfalls funktioniert es auf meinem RPi so (ohne Eingriffe meinerseits).
                        bei mir leider nicht wenn ich wieder die iobroker.service starte kommt der gleiche fehler wie vohere :( solangsam verzweile ich 😢
                        • paul53P
                          paul53P
                          @chrram:
                          solangsam verzweile ich `
                          Verständlich, aber nun bin ich auch mit meinem Latein am Ende. Starten und Stoppen funktioniert aber mit iobroker.sh ?
                          cd /etc/init.d
                          ./iobroker.sh start
                          ./iobroker.sh stop
                          • C
                            C
                            chrram
                            @paul53:
                            @chrram:
                            cd /etc/init.d
                            ./iobroker.sh start
                            ./iobroker.sh stop
                            Alle 3 funktionen gehen start webif lässt sich aufrufen stop und restart. deshalb wundert mich das ob es evt an der tvheadend.service oder so liegt
                            root@HomeServer:/usr/bin# cd /etc/init.d
                            Starting ioBrokerStarting iobroker controller daemon...
                            iobroker controller daemon started. PID: 1611
                            root@HomeServer:/etc/init.d# ./iobroker.sh stop
                            Stopping ioBrokerStopping iobroker controller daemon...
                            iobroker controller daemon stopped.
                            Exit code for "killall.sh": 0
                            root@HomeServer:/etc/init.d# ./iobroker.sh restart
                            Stopping ioBrokeriobroker controller daemon is not running
                            iobroker controller daemon started. PID: 1684
                            /etc/systemd/system/iobroker.service
                            # Start ioBroker Daemon
                            # /etc/systemd/system/iobroker.service
                            # Invoking scripts to start/shutdown ioBroker
                            [Unit]
                            Description=ioBroker server task
                            Requires=network.target
                            [Service]
                            #User=roker
                            User=root
                            Type=forking
                            RemainAfterExit=yes
                            Restart=no
                            ExecStart=/etc/init.d/iobroker.sh
                            [Install]
                            WantedBy=multi-user.target
                            • paul53P
                              paul53P
                              @chrram:
                              /etc/systemd/system/iobroker.service `
                              Das Kommando existiert auf meinem RPi nicht.
                              root@rpihm:/etc/systemd/system# ls -l
                              total 52
                              -rw-r--r-- 1 root root 1551 Sep 18  2015 autologin@.service
                              drwxr-xr-x 2 root root 4096 Mar 18  2016 bluetooth.target.wants
                              lrwxrwxrwx 1 root root   37 Mar 18  2016 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
                              lrwxrwxrwx 1 root root   40 Mar 18  2016 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
                              lrwxrwxrwx 1 root root   37 Apr  7  2016 default.target -> /lib/systemd/system/multi-user.target
                              lrwxrwxrwx 1 root root   34 Mar 18  2016 dhcpcd5 -> /lib/systemd/system/dhcpcd.service
                              drwxr-xr-x 2 root root 4096 Apr  7  2016 dhcpcd.service.d
                              drwxr-xr-x 2 root root 4096 Apr  7  2016 getty.target.wants
                              drwxr-xr-x 2 root root 4096 Mar 18  2016 getty@tty1.service.d
                              drwxr-xr-x 2 root root 4096 Jun  5  2016 halt.target.wants
                              drwxr-xr-x 2 root root 4096 Apr  7  2016 multi-user.target.wants
                              drwxr-xr-x 2 root root 4096 Jun  5  2016 poweroff.target.wants
                              drwxr-xr-x 2 root root 4096 Mar 18  2016 rc-local.service.d
                              drwxr-xr-x 2 root root 4096 Jun  5  2016 reboot.target.wants
                              drwxr-xr-x 2 root root 4096 Mar 18  2016 sockets.target.wants
                              lrwxrwxrwx 1 root root   31 Mar 18  2016 sshd.service -> /lib/systemd/system/ssh.service
                              -rwxr-xr-x 1 root root  357 Apr  7  2016 susvd.service
                              drwxr-xr-x 2 root root 4096 Mar 18  2016 sysinit.target.wants
                              lrwxrwxrwx 1 root root   35 Mar 18  2016 syslog.service -> /lib/systemd/system/rsyslog.service
                              • C
                                C
                                chrram
                                @paul53:
                                @chrram:
                                total 52
                                so sieht meine Struktur aus hast du denn die iobroker.service? wo steht bei dir denn der autostart in der RC.local? oder kann das ein anderer bestätigen ob die bei ihm da liegt (im Moment Ubuntu Server 16.04.3 LTS x64)
                                insgesamt 44
                                lrwxrwxrwx 1 root root   40 Jan  1 14:03 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
                                drwxr-xr-x 2 root root 4096 Jan  1 13:09 default.target.wants
                                drwxr-xr-x 2 root root 4096 Jan  1 13:24 final.target.wants
                                drwxr-xr-x 2 root root 4096 Jan  1 13:09 getty.target.wants
                                drwxr-xr-x 2 root root 4096 Jan  1 13:21 graphical.target.wants
                                -rwxr-xr-x 1 root root  356 Jan  2 21:26 iobroker.service
                                lrwxrwxrwx 1 root root   38 Jan  1 13:22 iscsi.service -> /lib/systemd/system/open-iscsi.service
                                drwxr-xr-x 2 root root 4096 Jan  1 17:56 multi-user.target.wants
                                drwxr-xr-x 2 root root 4096 Jan  1 13:09 network-online.target.wants
                                drwxr-xr-x 2 root root 4096 Jan  1 13:24 paths.target.wants
                                drwxr-xr-x 2 root root 4096 Jan  1 14:03 sockets.target.wants
                                lrwxrwxrwx 1 root root   31 Jan  1 13:24 sshd.service -> /lib/systemd/system/ssh.service
                                drwxr-xr-x 2 root root 4096 Jan  1 13:23 sysinit.target.wants
                                lrwxrwxrwx 1 root root   35 Jan  1 13:09 syslog.service -> /lib/systemd/system/rsyslog.service
                                drwxr-xr-x 2 root root 4096 Jan  1 13:40 timers.target.wants
                                • paul53P
                                  paul53P
                                  @chrram:
                                  wo steht bei dir denn der autostart in der RC.local? `
                                  Unter Raspbian wird mit der Datei etc/rc.local nur die RTC gestartet. __ioBroke__r wird mittels des Skripts
                                  etc/init.d/iobroker.sh, auf das die Links in rc0.d … rc6.d verweisen, gestartet und gestoppt.
                                  • C
                                    C
                                    chrram
                                    okay evt meldet sich ja noch jemand der mehr zu der Datei sagen kann. komisch ist das ich das Problem bei Debian und bei ubuntu habe beiedes frisch installiert und dann iobroker installiert und bei beiden kein Auto start . bei Facebook ist auch ein Problem der auch beides probiert hat und das gleiche Problem hat.
                                    • C
                                      C
                                      chrram
                                      so habe jetzt ein autostart aber würde sagen die dreckige variante evt kann mir jemand sagen ob das in Richtung Sicherheit des Server gefährlich werden kann.(root Login per ssh verboten und ssh port geändert und fail2 ban)
                                      also habe es so gelöst.
                                      in der sudo nano etc/rc.local habe ich
                                      sudo /etc/init.d/iobroker.sh start
                                      eingefügt
                                      in der
                                      sudo nano /etc/sudoers
                                      habe ich
                                      %users ALL = NOPASSWD: /etc/init.d/iobroker.sh
                                      eingefügt das sudo bei dem script kein passwort haben will so startet es bei mir.
                                      • S
                                        S
                                        simpixo
                                        Was zeigt denn der Befehl an
                                        Ich bin gerade auch am neuinstallieren und mein iobroker startete auch nicht mehr automatisch (Ich nutze Ubuntu 16.04)
                                        Meine Fehlermeldung war die folgende
                                        ` > root@HQ-ioBroker-01:~# systemctl status iobroker
                                        ● iobroker.service - LSB: starts ioBroker
                                        Loaded: loaded (/etc/init.d/iobroker.sh; bad; vendor preset: enabled)
                                        Active: failed (Result: exit-code) since Mi 2018-01-03 09:40:20 CET; 7min ago
                                        Docs: man:systemd-sysv-generator(8)
                                        Jan 03 09:40:20 HQ-ioBroker-01 iobroker.sh[1220]: at Function.Module._resolveFilename (module.js:469:15)
                                        Jan 03 09:40:20 HQ-ioBroker-01 iobroker.sh[1220]: at Function.Module._load (module.js:417:25)
                                        Jan 03 09:40:20 HQ-ioBroker-01 iobroker.sh[1220]: at Module.runMain (module.js:604:10)
                                        Jan 03 09:40:20 HQ-ioBroker-01 iobroker.sh[1220]: at run (bootstrap_node.js:383:7)
                                        Jan 03 09:40:20 HQ-ioBroker-01 iobroker.sh[1220]: at startup (bootstrap_node.js:149:9)
                                        Jan 03 09:40:20 HQ-ioBroker-01 iobroker.sh[1220]: at bootstrap_node.js:496:3
                                        Jan 03 09:40:20 HQ-ioBroker-01 systemd[1]: iobroker.service: Control process exited, code=exited status=1
                                        Jan 03 09:40:20 HQ-ioBroker-01 systemd[1]: Failed to start LSB: starts ioBroker.
                                        Jan 03 09:40:20 HQ-ioBroker-01 systemd[1]: iobroker.service: Unit entered failed state.
                                        Jan 03 09:40:20 HQ-ioBroker-01 systemd[1]: iobroker.service: Failed with result 'exit-code'. `
                                        Hast du die gleiche Meldung? Wenn ja dann hätte ich vielleicht eine Lösung für dich? :-) Bei mir startet nach langer suche nach einer Lösung, der IOBROKER nun wieder automatisch
                                        Adrian
                                        • C
                                          C
                                          chrram
                                          @simpixo:
                                          Adrian `
                                          root@HomeServer:/etc# systemctl status iobroker
                                          ● iobroker.service - ioBroker server task
                                             Loaded: loaded (/etc/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                                             Active: failed (Result: exit-code) since Mi 2018-01-03 09:55:10 CET; 46min ago
                                            Process: 946 ExecStart=/etc/init.d/iobroker.sh (code=exited, status=1/FAILURE)
                                          Jan 03 09:55:08 HomeServer systemd[1]: Starting ioBroker server task...
                                          Jan 03 09:55:09 HomeServer iobroker.sh[946]: Usage: iobroker {start|stop|restart}
                                          Jan 03 09:55:10 HomeServer systemd[1]: iobroker.service: Control process exited, code=exited stat
                                          Jan 03 09:55:10 HomeServer systemd[1]: Failed to start ioBroker server task.
                                          Jan 03 09:55:10 HomeServer systemd[1]: iobroker.service: Unit entered failed state.
                                          Jan 03 09:55:10 HomeServer systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                          ...skipping...
                                          etwas anderes er kann wohl die iobroker.sh nicht umsetzten oder so obwohl die ja startet wenn ich die manuel oder üner RC.local starte
                                          84.0k
