  4. TibberLink Adapter
TibberLink Adapter
651 Beiträge 89 Kommentatoren 278.8k Aufrufe 80 Beobachtet
  • F flisse
    @reblausgt
    Ich war gestern wohl etwas zu voreilig. Ich bekomme immer noch diese Log-Einträge, lediglich die Warnung vorher tritt nicht mehr auf
    tibberlink.0 2024-07-13 04:31:50.034	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.hub_attachments.node_version" has to be type "number" but received type "string"
    tibberlink.0 2024-07-13 04:31:49.989	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.type" has to be type "number" but received type "string"
    tibberlink.0 2024-07-13 04:30:49.922	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.hub_attachments.node_version" has to be type "number" but received type "string"
    tibberlink.0 2024-07-13 04:30:49.881	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.type" has to be type "number" but received type "string"
    tibberlink.0 2024-07-13 04:29:50.023	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.hub_attachments.node_version" has to be type "number" but received type "string"
    tibberlink.0 2024-07-13 04:29:49.979	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.type" has to be type "number" but received type "string"
    tibberlink.0 2024-07-13 04:28:49.873	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.hub_attachments.node_version" has to be type "number" but received type "string"
    tibberlink.0 2024-07-13 04:28:49.832	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.type" has to be type "number" but received type "string"
    Und so sieht der Objektbaum der lokalen Datenabfrage bei mir aus:
    ReblausGT
    #178
    @flisse said in TibberLink Adapter:
    @reblausgt
    Bitte 3.4.2 installieren - denke bei Dir läuft noch 3.4.1 (wenn schon installiert nocheinmal stoppen und starten)
    und dann die beiden "fehlerhaften" states löschen:
    sind nach ~1 Minute wieder da.
    Dann sollte die Meldungen nicht mehr kommen.
    R F 2 Antworten Letzte Antwort
    • R ReblausGT
      @reblausgt
      ReblausGT
      #179
      Wie ist eigentlich eure Meinung zu:
      • Ausgabe der Zählerwerte in kWh statt Wh wie original vom Pulse gemeldet?
      • Runden der Zählerwerte auf ganze kWh oder 1/10 kWh?
      • Wegfall von eher unnützen Werten wie z.B. Firmware Version? Welche sind wichtig?
      • Umrechnung der Uptime in menschentaugliche Darstellung?
      • Ergänzen von Einheiten (V bei Batteriespannung etc.)
      paul53P A 2 Antworten Letzte Antwort
      • R ReblausGT
        #180
        @reblausgt sagte: Runden der Zählerwerte auf ganze kWh oder 1/10 kWh?
        Besser auf 10 Wh runden (2 Nachkomastellen).
        @reblausgt sagte in TibberLink Adapter:
        Solche Konstanten würde ich unter "native" des Geräteobjektes bringen.
        Unbedingt!
        • R ReblausGT
          ArnoD
          #181
          Habe gerade die Version 3.4.2 installiert und läuft ohne Fehlermeldung oder Warnung im LOG. :-)
          Zu deinen Fragen:
          Da bei dem Zähler nur ganze kWh entscheidend sind, würde eine Ausgabe in kWh aus meiner Sicht passen.
          • Runden der Zählerwerte auf ganze kWh oder 1/10 kWh?>
          Hier würde ich auf ganze kWh abrunden. Also 1000954 Wh = 1000 kWh, da so jeder Stromzähler abgelesen wird, die Nachkommastellen werden dabei ignoriert.
          Da für jeden wahrscheinlich andere Informationen wichtig sind, würde ich nichts wegfallen lassen.
          Jeder kann dann das verwenden, was er braucht und den Rest ignorieren.
          Gute Idee.
          Gute Idee.
            ArnoD
            #182
            Habe mir die Werte gerade etwas genauer angesehen und festgestellt das bei tibberlink.0.LocalPulse.0.PulseInfo.node_status.radio_tx_power nichts übertragen wird.
            Funktioniert das bei euch?
            Hier sollte eigentlich die Sendeleistung vom Tibber Puls übertragen werden.
            R A 2 Antworten Letzte Antwort
            • A ArnoD
              ReblausGT
              #183
              @arnod said in TibberLink Adapter:
              Wird übertragen, sonst würde der State nicht erzeugt werden.... habe ich aber auch ein "0" drin - müsste man mal auf der Web-Seite des Pulse schauen ob dort was geschrieben steht
              • R ReblausGT
                @reblausgt
                flisse
                schrieb am zuletzt editiert von flisse
                #184
                @reblausgt Hat leider auch nicht geholfen.
                Die Objekte habe ich gelöscht, die kamen nach kurzer Zeit auch wieder, die Meldungen kommen dann aber auch wieder.
                Werte über die lokale Schnittstelle bekomme ich auch nicht rein, bis auf die aus dem Screenshot, den ich gepostet hatte.
                R 1 Antwort Letzte Antwort
                • R ReblausGT
                  ArnoD
                  #185
                  Das hat sich erledigt, es wird bereits auf der Webseite nichts eingetragen:
                  Das kann somit nur Tibber korrigieren. :-)
                  • F flisse
                    ReblausGT
                    #186
                    Jetzt seh ich es erst.... dein Pulse Node meldet meter_mode=4 .... alles was funktioniert war bisher mode 3.
                    Die gute Nachricht: du kannst die Spannung deiner Pulse Batterie sehen....
                    Die schlechte: bei den Verbrauchsdaten müssen wir noch Forschen.
                    -> Kannst Du bitte mal den Inhalt der SMLHexData posten?
                    F 1 Antwort Letzte Antwort
                    • R Offline
                      root_
                      #187
                      Ich bräuchte mal eure Hilfe bzw nen Denkanstoß.
                      Was ich machen möchte:
                      Ich möchte 4 Stundenblöcke anlegen, bester 5h, 6h, 7h, 8h Preis. Das ist ja noch easy. Hab ich mit LTF gemacht.
                      Jetzt möchte ich anzeigen ob der günstige Block heute oder morgen ist, das habe ich noch nicht verstanden wie ich das Filtern kann. Am besten wäre, günstigster Block heute: ...ct und günstigster Block morgen: ...ct.
                      Dann will ich noch die Differenz zwischen den 5-8h Blöcken berechnen. Das bekomme ich hin.
                      Hintergrund des Ganzen: ich Steuer Steuer damit meine Wallbox und die soll zur günstigsten Zeit angehen. Wenn es zb wie dieses WE ist, wo der Preis am Samstag schon günstig ist aber am Sonntag noch mal viel günstiger, möchte ich eine Routine programmieren die dann direkt auf den nächsten Tag verweist. sollte dann die Differenz des Durchschnittspreises vom 5h zum 8h Block zb nur 0.03ct betragen, dann soll direkt der 8h Block verwendet werden.
                      Ich hoffe ihr versteht was sich mein kleines Hirn da ausgedacht hat. ;-)
                      • R root_
                        ReblausGT
                        #188
                        @root_ said in TibberLink Adapter:
                        .... Der LTF mode ist genau dafür gedacht.... du kannst die Zeit in der der beste Block von z.B. 6h gesucht wird über 2 Tage suchen.... bzw. ~35h, da die Daten für "Morgen" ja erst um ca. 13:00 kommen. Warum due Blöcke nimmst verstehe ich allerdings noch nicht - ich würde "best single hours (LTF)" nehmen.... dort kommt die gewünscht ladezeit rein und fertig. Damit holst du dir die günstigsten Stunden an Strom in den Auto-Akku - innerhalb der gegebenen Zeit UND verfügbaren Informationen.
                        -> Oder ich hatte deinen Ansatz jetzt noch nicht verstanden - 🤗
                        • Merlin123M Offline
                          Merlin123M Offline
                          Merlin123
                          #189
                          Die lokalen Funktionen sind cool :) Danke dafür!
                          Gibt es Empfehlungen, ab welcher Batteriespannung man langsam an nen Austausch denken sollte?
                          Beta-Tester
                          • Merlin123M Merlin123
                            ReblausGT
                            #190
                            @merlin123 said in TibberLink Adapter:
                            Das würde mich auch interessieren.... ich habe 2,77V und die App meint Batterie sei"OK" ..... wer bietet einen schlimmeren Wert?
                            O 1 Antwort Letzte Antwort
                            • R ReblausGT
                              flisse
                              #191
                              @reblausgt
                              Super, ich habe schon an mir gezweifelt.
                              Hier der gewünschte SMLDataHEX Code:
                              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
                              • R ReblausGT
                                O Offline
                                O Offline
                                oxident
                                #192
                                @reblausgt 2.66V ... und auch noch OK
                                Merlin123M 1 Antwort Letzte Antwort
                                • F flisse
                                  @reblausgt
                                  ReblausGT
                                  #193
                                  @reblausgt
                                  2f45425a35444433325......
                                  Also ich bin da kein Experte, aber das scheint keine SML Message zu sein... von daher wird es nicht funktionieren - wenn das jemand decodieren kann, baue ich es gern in den Adapter ein.
                                  • R ReblausGT
                                    @reblausgt
                                    ArnoD
                                    #194
                                    Bekomme jetzt wieder eine Fehlermeldung und eine Warnung, die sich ständig wiederholen:
                                    tibberlink.0 	2024-07-14 20:20:23.792	warn	Error local polling of Tibber Pulse RAW data: Error: connect ETIMEDOUT
                                    tibberlink.0	2024-07-14 20:20:23.788	error	An error occured during local poll of Pulse data (getDataAsHexString)
                                    Hat das noch jemand?
                                    Nachtrag: Scheint ein Verbindungsproblem zu sein, nach einmal ausstecken und wieder einstecken läuft es wieder.
                                    • O oxident
                                      Merlin123M Offline
                                      Merlin123M Offline
                                      Merlin123
                                      #195
                                      @oxident sagte in TibberLink Adapter:
                                      Hab jetzt mal gegoogelt:
                                      Wenn eine 1,5V Batterie im Leerlauf unter 1.3 -1.35V hat wird sie als leer angesehen.
                                      Der Pulse verursacht ja keine große Last, also wird die Batterie nicht deutlich unter die Leerlaufspannung gehen.
                                      Gefühlt würde ich dann ab 2.6V spätestens tauschen.... Leider hab ich meine gerade getauscht, sonst hätte ich nen Wert gehabt, wo die App zum Tausch rät...
                                      Beta-Tester
                                      • ? Offline
                                        #196
                                        @starbug
                                        Seit heute habe ich das Probelm mit dem TibberLink Adapter das ich immer die Fehlermeldung bekommen: "Got no homes in your account - probably by a Tibber Server Error - adapter restarts in 2 minutes"
                                        Auf der Tibber Developer Api Explorer Seite bekomme ich die info der Homes ganz normal.
                                        Ich habe die aktuelle Version 3.3.3.
                                        Ich wäre super dankbar wenn mir hier jemand helfen könnte.
                                        MOD-EDIT: Es gab ein Problem mit diesem Nutzerprofil. Bitte neu anmelden
                                        Samson71S R 2 Antworten Letzte Antwort
                                          @starbug
                                          Samson71S Offline
                                          Samson71S Offline
                                          Samson71
                                          #197
                                          @jeremias-baur
                                          Bei Deiner Anmeldung ist irgendwas schief gelaufen. Dein Profil ist kaputt und wir mussten es löschen. Bitte melde Dich gerne mit den gleichen Daten nochmal neu an.
                                          Markus
                                          Bitte beachten:
