  4. TibberLink Adapter
TibberLink Adapter
651 Beiträge 89 Kommentatoren 278.7k Aufrufe 80 Beobachtet
  • F flisse
    @reblausgt
    Danke. Meldungen treten jetzt nicht mehr auf.
    Die Werte kamen die ganze Zeit rein, ob über Cloud oder Lokal kann man nicht erkennen oder?
    ReblausGT
    #176
    @flisse said in TibberLink Adapter:
    @reblausgt
    Die Werte werden akut in unterschiedlichen Objekten bzw. Bereichen abgelegt. Man kann auch beides Nutzen. In sofern, ja, kann man unterscheiden.
    F 1 Antwort Letzte Antwort
    • R ReblausGT
      @reblausgt
      flisse
      #177
      @reblausgt
      Ich war gestern wohl etwas zu voreilig. Ich bekomme immer noch diese Log-Einträge, lediglich die Warnung vorher tritt nicht mehr auf
      tibberlink.0 2024-07-13 04:31:50.034	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.hub_attachments.node_version" has to be type "number" but received type "string"
      tibberlink.0 2024-07-13 04:31:49.989	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.type" has to be type "number" but received type "string"
      tibberlink.0 2024-07-13 04:30:49.922	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.hub_attachments.node_version" has to be type "number" but received type "string"
      tibberlink.0 2024-07-13 04:30:49.881	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.type" has to be type "number" but received type "string"
      tibberlink.0 2024-07-13 04:29:50.023	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.hub_attachments.node_version" has to be type "number" but received type "string"
      tibberlink.0 2024-07-13 04:29:49.979	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.type" has to be type "number" but received type "string"
      tibberlink.0 2024-07-13 04:28:49.873	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.hub_attachments.node_version" has to be type "number" but received type "string"
      tibberlink.0 2024-07-13 04:28:49.832	info	State value to set for "tibberlink.0.LocalPulse.0.PulseInfo.type" has to be type "number" but received type "string"
      Und so sieht der Objektbaum der lokalen Datenabfrage bei mir aus:
      R 1 Antwort Letzte Antwort
      • F flisse
        @reblausgt
        ReblausGT
        #178
        @reblausgt
        Bitte 3.4.2 installieren - denke bei Dir läuft noch 3.4.1 (wenn schon installiert nocheinmal stoppen und starten)
        und dann die beiden "fehlerhaften" states löschen:
        sind nach ~1 Minute wieder da.
        Dann sollte die Meldungen nicht mehr kommen.
        R F 2 Antworten Letzte Antwort
        • R ReblausGT
          @reblausgt
          ReblausGT
          #179
          Wie ist eigentlich eure Meinung zu:
          • Ausgabe der Zählerwerte in kWh statt Wh wie original vom Pulse gemeldet?
          • Runden der Zählerwerte auf ganze kWh oder 1/10 kWh?
          • Wegfall von eher unnützen Werten wie z.B. Firmware Version? Welche sind wichtig?
          • Umrechnung der Uptime in menschentaugliche Darstellung?
          • Ergänzen von Einheiten (V bei Batteriespannung etc.)
          paul53P A 2 Antworten Letzte Antwort
          • R ReblausGT
            #180
            @reblausgt sagte: Runden der Zählerwerte auf ganze kWh oder 1/10 kWh?
            Besser auf 10 Wh runden (2 Nachkomastellen).
            @reblausgt sagte in TibberLink Adapter:
            Solche Konstanten würde ich unter "native" des Geräteobjektes bringen.
            Unbedingt!
            • R ReblausGT
              ArnoD
              #181
              Habe gerade die Version 3.4.2 installiert und läuft ohne Fehlermeldung oder Warnung im LOG. :-)
              Zu deinen Fragen:
              Da bei dem Zähler nur ganze kWh entscheidend sind, würde eine Ausgabe in kWh aus meiner Sicht passen.
              • Runden der Zählerwerte auf ganze kWh oder 1/10 kWh?>
              Hier würde ich auf ganze kWh abrunden. Also 1000954 Wh = 1000 kWh, da so jeder Stromzähler abgelesen wird, die Nachkommastellen werden dabei ignoriert.
              Da für jeden wahrscheinlich andere Informationen wichtig sind, würde ich nichts wegfallen lassen.
              Jeder kann dann das verwenden, was er braucht und den Rest ignorieren.
              Gute Idee.
              Gute Idee.
                ArnoD
                #182
                Habe mir die Werte gerade etwas genauer angesehen und festgestellt das bei tibberlink.0.LocalPulse.0.PulseInfo.node_status.radio_tx_power nichts übertragen wird.
                Funktioniert das bei euch?
                Hier sollte eigentlich die Sendeleistung vom Tibber Puls übertragen werden.
                R A 2 Antworten Letzte Antwort
                • A ArnoD
                  ReblausGT
                  #183
                  @arnod said in TibberLink Adapter:
                  Wird übertragen, sonst würde der State nicht erzeugt werden.... habe ich aber auch ein "0" drin - müsste man mal auf der Web-Seite des Pulse schauen ob dort was geschrieben steht
                  • R ReblausGT
                    @reblausgt
                    flisse
                    schrieb am zuletzt editiert von flisse
                    #184
                    @reblausgt Hat leider auch nicht geholfen.
                    Die Objekte habe ich gelöscht, die kamen nach kurzer Zeit auch wieder, die Meldungen kommen dann aber auch wieder.
                    Werte über die lokale Schnittstelle bekomme ich auch nicht rein, bis auf die aus dem Screenshot, den ich gepostet hatte.
                    • R ReblausGT
                      ArnoD
                      #185
                      Das hat sich erledigt, es wird bereits auf der Webseite nichts eingetragen:
                      Das kann somit nur Tibber korrigieren. :-)
                      • F flisse
                        ReblausGT
                        #186
                        Jetzt seh ich es erst.... dein Pulse Node meldet meter_mode=4 .... alles was funktioniert war bisher mode 3.
                        Die gute Nachricht: du kannst die Spannung deiner Pulse Batterie sehen....
                        Die schlechte: bei den Verbrauchsdaten müssen wir noch Forschen.
                        -> Kannst Du bitte mal den Inhalt der SMLHexData posten?
                        • R Offline
                          root_
                          #187
                          Ich bräuchte mal eure Hilfe bzw nen Denkanstoß.
                          Was ich machen möchte:
                          Ich möchte 4 Stundenblöcke anlegen, bester 5h, 6h, 7h, 8h Preis. Das ist ja noch easy. Hab ich mit LTF gemacht.
                          Jetzt möchte ich anzeigen ob der günstige Block heute oder morgen ist, das habe ich noch nicht verstanden wie ich das Filtern kann. Am besten wäre, günstigster Block heute: ...ct und günstigster Block morgen: ...ct.
                          Dann will ich noch die Differenz zwischen den 5-8h Blöcken berechnen. Das bekomme ich hin.
                          Hintergrund des Ganzen: ich Steuer Steuer damit meine Wallbox und die soll zur günstigsten Zeit angehen. Wenn es zb wie dieses WE ist, wo der Preis am Samstag schon günstig ist aber am Sonntag noch mal viel günstiger, möchte ich eine Routine programmieren die dann direkt auf den nächsten Tag verweist. sollte dann die Differenz des Durchschnittspreises vom 5h zum 8h Block zb nur 0.03ct betragen, dann soll direkt der 8h Block verwendet werden.
                          Ich hoffe ihr versteht was sich mein kleines Hirn da ausgedacht hat. ;-)
                          • R root_
                            ReblausGT
                            #188
                            @root_ said in TibberLink Adapter:
                            .... Der LTF mode ist genau dafür gedacht.... du kannst die Zeit in der der beste Block von z.B. 6h gesucht wird über 2 Tage suchen.... bzw. ~35h, da die Daten für "Morgen" ja erst um ca. 13:00 kommen. Warum due Blöcke nimmst verstehe ich allerdings noch nicht - ich würde "best single hours (LTF)" nehmen.... dort kommt die gewünscht ladezeit rein und fertig. Damit holst du dir die günstigsten Stunden an Strom in den Auto-Akku - innerhalb der gegebenen Zeit UND verfügbaren Informationen.
                            -> Oder ich hatte deinen Ansatz jetzt noch nicht verstanden - 🤗
                            • Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #189
                              Die lokalen Funktionen sind cool :) Danke dafür!
                              Gibt es Empfehlungen, ab welcher Batteriespannung man langsam an nen Austausch denken sollte?
                              Beta-Tester
                              • Merlin123M Merlin123
                                ReblausGT
                                #190
                                @merlin123 said in TibberLink Adapter:
                                Das würde mich auch interessieren.... ich habe 2,77V und die App meint Batterie sei"OK" ..... wer bietet einen schlimmeren Wert?
                                O 1 Antwort Letzte Antwort
                                • R ReblausGT
                                  flisse
                                  #191
                                  @reblausgt
                                  Super, ich habe schon an mir gezweifelt.
                                  Hier der gewünschte SMLDataHEX Code:
                                  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
                                  • R ReblausGT
                                    O Offline
                                    O Offline
                                    oxident
                                    #192
                                    @reblausgt 2.66V ... und auch noch OK
                                    Merlin123M 1 Antwort Letzte Antwort
                                    • F flisse
                                      @reblausgt
                                      ReblausGT
                                      #193
                                      @reblausgt
                                      2f45425a35444433325......
                                      Also ich bin da kein Experte, aber das scheint keine SML Message zu sein... von daher wird es nicht funktionieren - wenn das jemand decodieren kann, baue ich es gern in den Adapter ein.
                                      • R ReblausGT
                                        @reblausgt
                                        ArnoD
                                        #194
                                        Bekomme jetzt wieder eine Fehlermeldung und eine Warnung, die sich ständig wiederholen:
                                        tibberlink.0 	2024-07-14 20:20:23.792	warn	Error local polling of Tibber Pulse RAW data: Error: connect ETIMEDOUT
                                        tibberlink.0	2024-07-14 20:20:23.788	error	An error occured during local poll of Pulse data (getDataAsHexString)
                                        Hat das noch jemand?
                                        Nachtrag: Scheint ein Verbindungsproblem zu sein, nach einmal ausstecken und wieder einstecken läuft es wieder.
                                        • O oxident
                                          Merlin123M Offline
                                          Merlin123M Offline
                                          Merlin123
                                          #195
                                          @oxident sagte in TibberLink Adapter:
                                          Hab jetzt mal gegoogelt:
                                          Wenn eine 1,5V Batterie im Leerlauf unter 1.3 -1.35V hat wird sie als leer angesehen.
                                          Der Pulse verursacht ja keine große Last, also wird die Batterie nicht deutlich unter die Leerlaufspannung gehen.
                                          Gefühlt würde ich dann ab 2.6V spätestens tauschen.... Leider hab ich meine gerade getauscht, sonst hätte ich nen Wert gehabt, wo die App zum Tausch rät...
                                          Beta-Tester
