  4. Node-Red
  5. PAJ GPS mit Node-Red abfragen
    6.0k
153 Beiträge 6 Kommentatoren 29.4k Aufrufe 6 Beobachtet
  • NegaleinN Negalein
    @mickym sagte in PAJ GPS mit Node-Red abfragen:
    müsstest Du Dein token ggf. mitteilen
    aktueller Token (per PN auch gerne die Zugangsdaten an dich und Oliver)
      "success": {
        "token": "eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJhdWQiOiIzOCIsImp0aSI6IjA0NDYzYjMzZGQ0NGM2OTExOTcyOWYwNzk1MGJiNjg2MWZjZWVjMmQwYzNiY2E5ZjQ3Y2U1MjM1YWIzNGM1YWQwOTM3MTNkYmIzODg2MGE5IiwiaWF0IjoxNzIwMjgwOTMwLjIyODE0MiwibmJmIjoxNzIwMjgwOTMwLjIyODE0NSwiZXhwIjoxNzIyODcyOTMwLjE5OTYzOCwic3ViIjoiMjk1MjM0NSIsInNjb3BlcyI6W119.f5oY-BKAoDaxyO-jskPIQdZe3Hy7fK_YRidCRRyKXSZ3TGS0iy5U_21wnkasgQVlTkMk-7Kxvk30CWZx6PdI3bAJypTmXsiQ7j6sLVCNdpjbY6uedCnDoXSP50W8sYLPZy8ws-Z_qXc3s3Ylld2TUeiH-9r-LYImFi1s2jO1Jrk9PSoQp2f7EVuvfZFDRV9izewU0GgsQ7QdT3h5xrxDYvI1vzOfJu8CnltKy20E-w2YBRKVUWVdAKQMyNhLNMJFNFWnJBH5maV5Y5dELoPgjAGwiVKYont0GYLUmsKdy4bFyEZFbguJbuyR4thNKEEzQpZx3hWDbe2_BSyCDSzltw0nywumVTHRYjsHutCL3AcwHxw5AY5WBziPa5mTrXwi4K1aaUPGP7ixmKT3kVR56c2_HHUKOsiFJaodjwG6SIpocMqJJxdIqGfuNAzztmtO4Ck5oMOMp67jP6wjsJJ9MQgxY-lrx5wgpzVJ8hgwsG7cLTKbjPqUKiVZfwUzigzwO3uPurZ7K0jUq1ifCzR1-iYml1CvKeZLYG0ZG5qPDBiPkwMFbpFHLnLsA2fjfU-G9h6klYJyxpC7w5jzrCJ_Iboqs-WVXU2wyUF_syZrPf4PQav3h86ClJInvh9EvREnFQ7Ndzks-QAis7cuFp3vB6XmAf4YVY-55kOrFVrN1Yc",
        "refresh_token": "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",
        "expires_in": 2592000,
        "isAdmin": 0,
        "userID": 2952345,
        "routeIcon": "arrow",
        "Petsevices": 0
    Wenn Du eine Node auswählst und rechts im Fenster auf das Buch klickst, dann bekommst Du in der Regel einen Hilfetext zu einer Node.
    hab ich gefunden und gelesen :)
    Flow verläuft in der Regel von links nach rechts so wie Du liest
    müsste dann obiger Screenshot mit 2 Request nacheinander passen?
    Aber wo macht er den Login inkl. Token?
    mickymM Offline
    mickymM Offline
    mickym
    @negalein Ja im Moment wollte ich den noch gar nicht. Hast Du mal meinen Flow importiert und verstanden wie ein Nachrichtenobjekt aufgebaut ist und welche Möglichkeiten Du hast, Eigenschaften des Nachrichtenobjektes im Debugfenster ausgeben zu lassen?
        "success": {
          "isAdmin": 0,
          "userID": 2952345,
          "Petsevices": 0
      mickymM Offline
      mickymM Offline
      mickym
      @negalein sagte in PAJ GPS mit Node-Red abfragen:
      Nein das passt noch lange nicht. Aber ich dachte, wir entwickeln das zusammen?
      • mickymM Offline
        mickymM Offline
        mickym
        @Negalein Wenn Du soweit bist, dann melde Dich halt - sonst warte ich hier, wenn keine Rückmeldung kommt.
        • mickymM mickym
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          Ja, die 3 grünen Nodes sind alles eigene Debugs.
          Und der blaue Timestamp ist das ausführbare Teil. Also der Start von Allem.
          Im Payload steht eine Nummer (wo kommt die her).
          Im Topic steht nichts.
          Und im Nachrichtenobjekt steht wieder die Nummer vom Payload.
          Also der Payload übergibt an das Nachrichtenobjekt.
          Und ich schätze im Topic wird mal das Ergebnis (zB GPS-Koordinaten) stehn.
          6.7.2024, 18:02:58node: payload
          msg.payload : number
          1720281778711
          6.7.2024, 18:02:58node: topic
          msg.topic : string[0]
          6.7.2024, 18:02:58node: gesamtes Nachrichtenobjekt
          msg : Object
          object
          _msgid: "8ec694ca908771a0"
          payload: 1720281778711
          topic: ""
          ° Fixer ---> iob fix
          • mickymM mickym
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            war zu voreilig ;)
              1720281778711
              msg : Object
              object
              topic: ""
              mickymM Offline
              mickymM Offline
              mickym
              Na sagen wir mal so. Der blaue Timestamp ist nicht der ausführbare Teil, sondern diese Node (wie jede andere Node) kann ein Nachrichtenobjekt erzeugen, dass dann an den Ausgang geschickt werden.
              Da wir in die payload einen timestamp gespeichert haben
              enthält die payload einer Zahl, die die aktuelle Zeit in ms seit dem 1.1.1970 also die Unix Zeit enthält.
              Die payload (Nutzdaten) kann alles sein.
              Das topic wird in der Regel verwendet, um zu beschreiben um was für Nutzdaten es sich handelt.
              Nehmen wir mal an Du hast eine Temperatur in einer Nachricht mit einer payload, zum Beispiel 25. Dann nützt Dir das sehr wenig, wenn Du mehrere Temperaturen hast, Dann nutzt man das topic um zum Beispiel zu beschreiben, um was für einen Wert es sich bei der payload 25 handelt. Also Temperatur-Wohnzimmer zum Beispiel.
              Nun erstell mal eine Inject Node, mit einem Nachrichtenobjekt, dass die Eigenschaften "eMail" und "password" hat. Wenn Du das hast, dann sag Bescheid. Der Datentyp ist natürlich in beiden Fällen ein String, also eine Zeichenkette.
              • mickymM mickym
                mickymM Offline
                mickymM Offline
                mickym
                Bist Du soweit? - Also wenn ich mich falsch ausgedrückt habe, dann sag Bescheid.
                Die Aufgabe war eigentllich total easy:
                Du kannst auch erst mal wie hier - Fakedaten eingeben. Es geht ja darum, Dir hier Zusammenhänge zu vermitteln.
                • mickymM mickym
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  hab mich am Anfang verklickt.
                  Aber schaut jetzt so aus :)
                  6.7.2024, 18:57:00node: debug 1
                  msg : Object
                  object
                  _msgid: "b147c438e5c144a0"
                  Mail: "hansi@seppi.de"
                  PWD: "irgendwas"
                  PS: bin dann mal weg; bei uns kommt gerade das starke Gewitter an.
                    msg : Object
                    object
                    PWD: "irgendwas"
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @negalein ok -dann melde Dich mal zurück. Wenn Du da bist.
                    Für die Zukunft - um die Daten aus dem Debugfenster hier einzustellen, nutze nicht die Maus zum markieren der Daten - sondern geh mit der Maus neben den Wert im Debugfenster, den Du hier einstellen willst, kopieren ihn mit der Schaltfläche "Wert kopieren" in die Zwischenablage und stell ihn dann hier in CodeTags hier ein.
                    {"_msgid":"a3c043dc39a1de4f","eMail":"mail@web.de","password":"meinPasswort"}
                    • mickymM mickym
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      im back 🕶
                        im back 🕶
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @negalein Welcome back oder wb. ;)
                        Nun dann zieh mal ein HTTP Request Node rein und schau Dir mal den Hilfetext an. Nachdem Du ja die Eigenschaften Deines Nachrichtenobjektes etwas anders benannt hast, musst Du halt die Eigenschaft Deines Nachrichtenobjektes verwenden.
                        Nachdem Du diese HTTP-Request Node an Deine Inject Node gesetzt hast, mit der URL Deines Logins mit den Platzhaltern für eMail und password, hängst Du ein Debug Node hinten dran und lässt Dir die payload, erst mal mit Dummy Login Daten ausgeben und postest mal das Ergebnis als Objekt in code tags - wie ich es eben mit "Wert kopieren" gezeigt habe.
                        • mickymM mickym
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          zu spät gelesen ;)
                          ok, also mit {{{xxxx}}} nimmt er die Daten aus dem Inject.
                          Ausgabe erfolgreich
                          eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJhdWQiOiIzOCIsImp0aSI6IjkyMWU4MTQ3MmMxNzg5MzQ0OTM3MDE1ODcyZTEzMTMxMTE4YjUwMDM3ZGNmODc3OThiM2NmNDUxMmFjNWRiMDg2YTQ5N2FmNWI5MTRhZGJmIiwiaWF0IjoxNzIwMjk3NzExLjE3MTU0NywibmJmIjoxNzIwMjk3NzExLjE3MTU1LCJleHAiOjE3MjI4ODk3MTEuMTA5NTU2LCJzdWIiOiIyOTUyMzQ1Iiwic2NvcGVzIjpbXX0.NFTOlZG_h4WlFemD4pz3LD9nrvDAkjpkaPJzAlqT1bJDx5YOXz4DJzkL-EUU9hiqxl4sYukRro851oSwNE1dHztjgNVtPTXKb7h4SBD3MOYjz6OV8AByCPirpDzTg24QFQQRS9YzqKt9kfzHKSD2uQSZQfSqDWYzJ7HRjJMDXDtzMMgpz_9SadUdkgRFLlbELsIAF-XHIEPsaIYdxlPlAimodBaEWr_c3xQsHy1O9djtmXP0hYOCkjJ7ojWaGeJ56iRxLzIGhuOTv4Ro_CJ77yPiBHcc7jrYDoeAq1D2qrrqh_tUvCUSguOdxUYilGjaVv61WGlCxWHTtO3EPo1tn7WYYaRnWJHvAbEa7dUflP6E6QsSceLyO-xNwpbpw9gLOjdhn8IzcEEduDeGf8vhuXtIsL7cnlwQShht_5oOwkS3DKkoLrP8k2mPM-snAecUemSrgA4ZghXrvQsUDEV0p1QggkIQcdskyiKpzyLpwXTi5cbwFjfwo1IybnEnvinrp-D86TTudrOSgKPzeaq7MqfHab8jPwUVZjw4BOxnLYxTiBu2qr7qr3Xdo5lZJJEXPtF3Mw4hKy_PVWGTqqnj3RMQ0j7vQz4R7dXii2OhP8MZIrbhq4QOfIYuReiFZQiFKvNxgGdxKtRw6O9Us-yV0BAxZKiQXiZ3Fcg-cuOcuJo
                            zu spät gelesen ;)
                            Ausgabe erfolgreich
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @negalein Nein ich will nicht das Token haben, sondern Du sollst mit Dummy Daten die payload ausgeben.
                            • mickymM mickym
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @mickym
                              ah, damit ich seh, dass bei falschen Daten zB das retour kommt?
                              Email is not valid.
                                @mickym
                                Email is not valid.
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @negalein Ja aber das ist nicht das Objekt der payload. Kannst Du mal das ganze Objekt hier in code tags reinkopieren?
                                Das ganze Objekt sollte also wenn Du es mit Wert kopieren und hier in CodeTags kopierst auch wie ein Objekt aussehen. ;)
                                Falls das ALLERDINGS ein STRING ist, dann hast Du die HTTP-Request Node nicht richtig eingestellt.
                                • mickymM mickym
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  {"error":{"emailError":"Email is not valid."}}
                                  so?
                                    so?
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @negalein Sehr gut. :)
                                    Und wenn Du die richtigen Daten eingibst in die Inject Node, dann bekommst Du hoffentlich ein success Objekt. Nun werden wir den Flow verzweigen, in dem wir abfragen, ob Du ein Objekt mit der Eigenschaft success oder error zurückbekommst. Unten hast Du ja schon mal ein success Objekt kopiert.
                                    Also error:
                                    Also success:
                                      "success": {
                                        "isAdmin": 0,
                                        "userID": 2952345,
                                        "Petsevices": 0
                                    Wir werden nun also filtern, dass wir einerseits ein zürückgegebenes Error Objekt anders behandeln als ein Success Objekt.
                                    Zum Filtern oder Aufspalten des Flows bedienen wir uns einer Switch Node - die jenachdem das Nachrichtenobjekt an unterschiedlichen Ausgängen ausgibt.
                                    Wir lassen uns also oben das Nachrichtenobjekt ausgeben, wenn die PAYLOAD ein error Objekt enthält, unten wenn es ein success Objekt enhält. Die Debug Node benennen wir dementsprechend einmal error, einmal sucess.
                                    Die switch Node -die das Nachrichtenobjekt an die Ausgänge dirigiert wird wie folgt konfiguriert:
                                    Es wird also die Nachrichteneigenschaft payload untersucht und geschaut, ob das Objekt ein success oder eine error Eigenschaft (bzw. Schlüssel) hat.
                                    NegaleinN mickymM 2 Antworten Letzte Antwort
                                    • mickymM mickym
                                      Also error:
                                      Also success:
                                        "success": {
                                          "isAdmin": 0,
                                          "userID": 2952345,
                                          "Petsevices": 0
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      bei korrekten Daten:
                                      {"success":{"token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJhdWQiOiIzOCIsImp0aSI6Ijg1ZjBhMTM0ZGU2MWZkMGVjNjY2OTY5ZTEyNjgzZjM1MGFhOTlkZTFlOTQzMmY5NTc0OWM5NWU1OWVkNGYyMDkyNjJhMDQxZDFhOTQwNWRkIiwiaWF0IjoxNzIwMjk5Nzk5LjI4NjI2LCJuYmYiOjE3MjAyOTk3OTkuMjg2MjYyLCJleHAiOjE3MjI4OTE3OTkuMjI1NDIzLCJzdWIiOiIyOTUyMzQ1Iiwic2NvcGVzIjpbXX0.MxmKFobCwVg1mXjZr2Ef9KcQ24ySiM9ldcON7WuI5avsdXKliVdsdmem9fJMtdtv5ruyWZZFaqzsXwG9QhbpwbaycbSuL9GOfjmMtaInmBhULNtWo7F-7F-8k3lwYdabtcZ5n9ov2CFgE4JHPrHDevU6YfbyopHf-IxdQhtTM_mckVTVbJ37y9KxDlo5xYYU9KUvXn05nnYVJa3wubD4dITM5ILXBDtGVGszp5gtjsG7Bse39r_PPVBLfRS36ZUwDA2-VlYP8ItpC5jT5CjgtNN9K7GtrX1xffwS-K3mpYRKJsJwVOzPEp6KUA-VFIykZofwYlt7EXBLgjJfKH5g_Iona2DmQ04Fs9TytU9becauNzLXRzmoqp8Ac-seFIBh4r5UV7AeZKNkK5uHwWNLsSIUJ28UutOYiyN7EsvVvk4fzKynjVHQbSEtcqXYsS5OtfAm_eYZxV-yHQzRT3u1Al79gWZqSrTtcmWHhHOjnXbOcgPH7RA6VddI_8fVRAvGhXemdS5gZnPJ-hVKfDje7g0m9Yvx9yWbwGZsX3r1DBbxZOv_nrOkIyeeIwqNreRxDCAmG4mV-VwjrDdZqqDRW6FrHnn2DHLWpTUcFTOzW9dAOUxuYOtu0rteckw8NOqj07_wiT6YBA7VuWrILB-AOhaeM9tKNrmt-9OYodOtPjM","refresh_token":"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","expires_in":2592000,"isAdmin":0,"userID":1234567,"routeIcon":"arrow","Petsevices":0}}
                                      bei falschen Daten:
                                      • mickymM mickym
                                        Also error:
                                        Also success:
                                          "success": {
                                            "isAdmin": 0,
                                            "userID": 2952345,
                                            "Petsevices": 0
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        Wenn Du fertig bist, dann bestätige, dass das Nachrichtenobjekt einmal in der Debug Node mit dem Namen error rauskommt, wenn Du fehlerhafte Daten eingegeben hast und einmal in der Debug Node mit dem Namen success wenn Du korrekte Daten eingegeben hast.
                                          bei falschen Daten:
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @negalein Gut und die kommen auch - wie oben unterstrichen in unterschiedlichen Debug Nodes raus?
                                          Also die switch Node hast Du eingebaut - so wie in meinem Flow zu sehen.
