  4. Homeconnect Fehlermeldung
55 Beiträge 5 Kommentatoren 7.2k Aufrufe 2 Beobachtet
    @timowald
    In der Web-GUI (admin) des iobrokers?
    Da bin ich immer als admin angemeldet.
    TimoWald
    @thomas-braun Ok, dann ist das richtig. In Proxmox bin ich als root angemeldet.
    • T TimoWald
      @tt-tom Hier mal der LOG nach 3 Minuten.
      Jede Minute passiert etwas.
      2024-07-04 16:52:01.914 - info: host.iobroker "system.adapter.homeconnect.0" enabled
      2024-07-04 16:52:02.309 - info: host.iobroker instance system.adapter.homeconnect.0 started with pid 101249
      2024-07-04 16:52:03.207 - debug: homeconnect.0 (101249) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-07-04 16:52:03.275 - debug: homeconnect.0 (101249) Objects client ready ... initialize now
      2024-07-04 16:52:03.277 - debug: homeconnect.0 (101249) Objects create System PubSub Client
      2024-07-04 16:52:03.277 - debug: homeconnect.0 (101249) Objects create User PubSub Client
      2024-07-04 16:52:03.441 - debug: homeconnect.0 (101249) Objects client initialize lua scripts
      2024-07-04 16:52:03.446 - debug: homeconnect.0 (101249) Objects connected to redis: 127.0.0.1:9001
      2024-07-04 16:52:03.535 - debug: homeconnect.0 (101249) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-07-04 16:52:03.638 - debug: homeconnect.0 (101249) States create System PubSub Client
      2024-07-04 16:52:03.639 - debug: homeconnect.0 (101249) States create User PubSub Client
      2024-07-04 16:52:03.768 - debug: homeconnect.0 (101249) States connected to redis: 127.0.0.1:9000
      2024-07-04 16:52:03.837 - debug: homeconnect.0 (101249) Plugin sentry Initialize Plugin (enabled=true)
      2024-07-04 16:52:04.158 - info: homeconnect.0 (101249) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v18.17.1, js-controller: 5.0.19
      2024-07-04 16:52:04.231 - debug: homeconnect.0 (101249) Found current session
      2024-07-04 16:52:04.232 - debug: homeconnect.0 (101249) Refresh Token
      2024-07-04 16:52:04.554 - debug: homeconnect.0 (101249) {"access_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.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.h05vzbNvOhLkpk6CTBVW8QUDpCTpPUzI9tHoDJGyPFqpNtX-oifpS7gRj_5KGQAb7ifxkzM_etF_wuvUVIHPVSSkSO0UWHaxQRHw8DLgyUKLTVDM4T7FAJ8cHAz6YM-e4_cd1Fbg8bq_O3-OYyMuWIQ1_w7Gp3X3tkUYiT5F1YEhQxHANgGGAtjrUUuw1AEnhIAmzmmJiX_6tYLFunAJ69zXrdc-ilE-BdVuLN6Yo6bonvayzI265D4bmLwIww_4x7enGUsUoLlkNx3ZDf4dEV1SWrZn2M6lwoMqxwzgdLQgGKCUdO7bIwD1mxLRoJzgV3kE6gEpLOKSPSs4XlDQOA","expires_in":86400,"id_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.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.h05vzbNvOhLkpk6CTBVW8QUDpCTpPUzI9tHoDJGyPFqpNtX-oifpS7gRj_5KGQAb7ifxkzM_etF_wuvUVIHPVSSkSO0UWHaxQRHw8DLgyUKLTVDM4T7FAJ8cHAz6YM-e4_cd1Fbg8bq_O3-OYyMuWIQ1_w7Gp3X3tkUYiT5F1YEhQxHANgGGAtjrUUuw1AEnhIAmzmmJiX_6tYLFunAJ69zXrdc-ilE-BdVuLN6Yo6bonvayzI265D4bmLwIww_4x7enGUsUoLlkNx3ZDf4dEV1SWrZn2M6lwoMqxwzgdLQgGKCUdO7bIwD1mxLRoJzgV3kE6gEpLOKSPSs4XlDQOA","refresh_token":"eyJyZWdpb24iOiJFVSIsInN0YWdlIjoiUFJEIiwiY3JlZiI6IjA4MjUxMkJEIiwidG9rZW4iOiJiZThjOTA5OC1hYmZlLTQ3N2ItODAwMi1kMzQwYjJhYjVjZmQiLCJjbHR5IjoicHJpdmF0ZSIsIngtcmVnIjoiRVUiLCJ4LWVudiI6IlBSRCJ9","scope":"IdentifyAppliance Monitor Settings Control","token_type":"Bearer"}
      2024-07-04 16:52:04.555 - debug: homeconnect.0 (101249) Get device list
      2024-07-04 16:52:04.735 - error: homeconnect.0 (101249) AxiosError: Request failed with status code 429
      2024-07-04 16:52:04.736 - error: homeconnect.0 (101249) {"error":{"description":"The rate limit \"1000 calls in 1 day\" was reached. Requests are blocked during the remaining period of 85880 seconds.","key":"429"}}
      2024-07-04 16:52:04.737 - debug: homeconnect.0 (101249) Start EventStream
      2024-07-04 16:52:04.838 - error: homeconnect.0 (101249) 429 Too Many Requests
      2024-07-04 16:52:04.838 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
      2024-07-04 16:52:04.838 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
      2024-07-04 16:52:14.813 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
      2024-07-04 16:52:14.814 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
      2024-07-04 16:52:40.625 - info: solax.0 (21770) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2024-07-04 16:53:14.742 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
      2024-07-04 16:53:14.743 - debug: homeconnect.0 (101249) Start EventStream
      2024-07-04 16:53:14.817 - error: homeconnect.0 (101249) 429 Too Many Requests
      2024-07-04 16:53:14.818 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
      2024-07-04 16:53:14.818 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
      2024-07-04 16:53:16.253 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
      2024-07-04 16:53:16.254 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
      2024-07-04 16:54:13.597 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
      2024-07-04 16:54:13.598 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
      2024-07-04 16:54:24.749 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
      2024-07-04 16:54:24.750 - debug: homeconnect.0 (101249) Start EventStream
      2024-07-04 16:54:24.826 - error: homeconnect.0 (101249) 429 Too Many Requests
      2024-07-04 16:54:24.826 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
      2024-07-04 16:54:24.826 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
      2024-07-04 16:55:15.037 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
      2024-07-04 16:55:15.038 - error: wled.0 (22162) Sending command to WLED device + http://192.168.9.91/json failed with error Error: connect ETIMEDOUT 192.168.9.91:80
      2024-07-04 16:55:34.756 - info: homeconnect.0 (101249) Keep Alive failed Reconnect EventStream
      2024-07-04 16:55:34.756 - debug: homeconnect.0 (101249) Start EventStream
      2024-07-04 16:55:34.862 - error: homeconnect.0 (101249) 429 Too Many Requests
      2024-07-04 16:55:34.862 - error: homeconnect.0 (101249) Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
      2024-07-04 16:55:34.862 - info: homeconnect.0 (101249) Too many requests. Please wait 24h.
      haselchenH Offline
      haselchenH Offline
      haselchen
      @timowald
      Wie lautet die Einstellung im Adapter für den Polling Intervall?
      T T 2 Antworten Letzte Antwort
      • haselchenH haselchen
        @timowald
        TimoWald
        @haselchen diese Einstellung habe ich im VIS2 Adapter nicht.
        • T TimoWald
          haselchenH Offline
          haselchenH Offline
          haselchen
          @timowald
          Wieso VIS?
          Aber ich hab mich vertan. Hab an den HAM Adapter gedacht.
          Dann aber jetzt , Screenshot bitte von den Homeconnect Einstellungen im Adapter.
            @timowald
            Wieso VIS?
            TimoWald
            @haselchen Hallo hier der Screenshot von meinem Homeconnect Adapter.
              @timowald
              TT-Tom
              @haselchen wo gibt es bei dem Adapter ein Polling Intervall zum einstellen?
              Gruß Tom
              Public Transport
              NSPanel Adapter Wiki
              • T TimoWald
                TT-Tom
                @timowald
                wie ist jetzt der aktuelle Status vom Adapter? Setzte ihn mal jetzt auf debug und starte ihn einmal durch.
                Gruß Tom
                Public Transport
                • T TT-Tom
                  @timowald
                  TimoWald
                  @tt-tom So sieht der LOG nach dem Starten aus.
                  2024-07-05 12:49:57.741 - info: admin.0 (17537) ==> Connected system.user.admin from ::ffff:192.168.9.241
                  2024-07-05 12:49:59.994 - info: admin.0 (17537) <== Disconnect system.user.admin from ::ffff:192.168.9.241
                  2024-07-05 12:50:03.903 - info: luxtronik2.0 (16839) Heatpump busy, will retry later
                  2024-07-05 12:50:12.630 - info: host.iobroker "system.adapter.homeconnect.0" enabled
                  2024-07-05 12:50:13.014 - info: host.iobroker instance system.adapter.homeconnect.0 started with pid 32710
                  2024-07-05 12:50:13.903 - debug: homeconnect.0 (32710) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2024-07-05 12:50:13.969 - debug: homeconnect.0 (32710) Objects client ready ... initialize now
                  2024-07-05 12:50:13.970 - debug: homeconnect.0 (32710) Objects create System PubSub Client
                  2024-07-05 12:50:13.971 - debug: homeconnect.0 (32710) Objects create User PubSub Client
                  2024-07-05 12:50:14.125 - debug: homeconnect.0 (32710) Objects client initialize lua scripts
                  2024-07-05 12:50:14.131 - debug: homeconnect.0 (32710) Objects connected to redis: 127.0.0.1:9001
                  2024-07-05 12:50:14.239 - debug: homeconnect.0 (32710) Redis States: Use Redis connection: 127.0.0.1:9000
                  2024-07-05 12:50:14.290 - debug: homeconnect.0 (32710) States create System PubSub Client
                  2024-07-05 12:50:14.291 - debug: homeconnect.0 (32710) States create User PubSub Client
                  2024-07-05 12:50:14.423 - debug: homeconnect.0 (32710) States connected to redis: 127.0.0.1:9000
                  2024-07-05 12:50:14.511 - debug: homeconnect.0 (32710) Plugin sentry Initialize Plugin (enabled=true)
                  2024-07-05 12:50:14.849 - info: homeconnect.0 (32710) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v20.15.0, js-controller: 5.0.19
                  2024-07-05 12:50:14.909 - debug: homeconnect.0 (32710) Found current session
                  2024-07-05 12:50:14.910 - debug: homeconnect.0 (32710) Refresh Token
                  2024-07-05 12:50:15.220 - debug: homeconnect.0 (32710)
                  • T TimoWald
                    TT-Tom
                    @timowald hat der Connect geklappt? Wenn ja, dann lass mal laufen und kontrolliere mal nach 2h ob es Auffälligkeiten gibt.
                    Gruß Tom
                    Public Transport
                    • T TT-Tom
                      TimoWald
                      @tt-tom grün ist der Adapter aber es kommen keine Daten.
                      • T TimoWald
                        TT-Tom
                        @timowald
                        Was sagt denn das log, hat es die Geräte gefunden. Du kannst in der Protokollansicht nach dem Adapter filtern. Zeig doch mal was er bist jetzt gemacht hat.
                        Gruß Tom
                        Public Transport
                        • T TT-Tom
                          @timowald
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @tt-tom
                          Hatte ich oben schon korrigiert mit dem Polling.
                          @TimoWald
                          Mach mal nen Haken im 2.Feld ( steht ja auch was von reduziert Rate Limit )
                            @tt-tom
                            @TimoWald
                            TT-Tom
                            @haselchen
                            Wie er schreibt kommen keine Daten. Frage ist, ob er nach dem Connect auch die Geräte findet bzw auslesen kann.
                            @TimoWald
                            Wie sieht es denn in der App aus. Bekommst du da alles angezeigt?
                            Gruß Tom
                            Public Transport
                            haselchenH T 2 Antworten Letzte Antwort
                            • T TT-Tom
                              @haselchen
                              @TimoWald
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @tt-tom
                              Mag ja sein , dass seine 24Std Sperre noch wirksam ist .
                              Der Screenshot ist von Mittags.
                              Seine Sperre war gestern um 16-17Uhr
                                TimoWald
                                @tt-tom Aktuell kommt das im LOG.
                                2024-07-05 17:44:43.277 - debug: homeconnect.0 (37662) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2024-07-05 17:44:43.343 - debug: homeconnect.0 (37662) Objects client ready ... initialize now
                                2024-07-05 17:44:43.344 - debug: homeconnect.0 (37662) Objects create System PubSub Client
                                2024-07-05 17:44:43.345 - debug: homeconnect.0 (37662) Objects create User PubSub Client
                                2024-07-05 17:44:43.531 - debug: homeconnect.0 (37662) Objects client initialize lua scripts
                                2024-07-05 17:44:43.538 - debug: homeconnect.0 (37662) Objects connected to redis: 127.0.0.1:9001
                                2024-07-05 17:44:43.635 - debug: homeconnect.0 (37662) Redis States: Use Redis connection: 127.0.0.1:9000
                                2024-07-05 17:44:43.681 - debug: homeconnect.0 (37662) States create System PubSub Client
                                2024-07-05 17:44:43.682 - debug: homeconnect.0 (37662) States create User PubSub Client
                                2024-07-05 17:44:43.803 - debug: homeconnect.0 (37662) States connected to redis: 127.0.0.1:9000
                                2024-07-05 17:44:43.862 - debug: homeconnect.0 (37662) Plugin sentry Initialize Plugin (enabled=true)
                                2024-07-05 17:44:44.139 - info: homeconnect.0 (37662) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v20.15.0, js-controller: 5.0.19
                                2024-07-05 17:44:44.177 - debug: homeconnect.0 (37662) Found current session
                                2024-07-05 17:44:44.177 - debug: homeconnect.0 (37662) Refresh Token
                                2024-07-05 17:44:44.497 - debug: homeconnect.0 (37662) {"access_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.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.DuB3kKLNgqMQNxU3DEvrsLSVggVG51Q0giKS3LFyc30AbqD4mbqxxm8bUOsPiQCfzfMbo8Pe4UNoSc9D-GEhNZyNsVewUMNHNCuwM38ng2Akdzp_HruizbSRvW6OIMmDuEGuDRs0FGertEg60cBDugRT3G9ok6t4S0PCMzmOfhGfcUaQa7FJnXzKJWbUrCgYMxQrRhKRxbsEl3QxG5ZEkVC88a2tjMmoqUwA5AKWU_3PeR9pGMYn7fXlzFKEiPjjWp2GjSKa6VlvAkEjrH2EDkZRf_2vFowzyVKybkkvkZIKXLGiWKeqc0wRJHCxjpb9UKiCGfwD3vquRzjfxPPVcw","expires_in":86400,"id_token":"eyJ4LWVudiI6IlBSRCIsImFsZyI6IlJTMjU2IiwieC1yZWciOiJFVSIsImtpZCI6InJldS1wcm9kdWN0aW9uIn0.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.DuB3kKLNgqMQNxU3DEvrsLSVggVG51Q0giKS3LFyc30AbqD4mbqxxm8bUOsPiQCfzfMbo8Pe4UNoSc9D-GEhNZyNsVewUMNHNCuwM38ng2Akdzp_HruizbSRvW6OIMmDuEGuDRs0FGertEg60cBDugRT3G9ok6t4S0PCMzmOfhGfcUaQa7FJnXzKJWbUrCgYMxQrRhKRxbsEl3QxG5ZEkVC88a2tjMmoqUwA5AKWU_3PeR9pGMYn7fXlzFKEiPjjWp2GjSKa6VlvAkEjrH2EDkZRf_2vFowzyVKybkkvkZIKXLGiWKeqc0wRJHCxjpb9UKiCGfwD3vquRzjfxPPVcw","refresh_token":"eyJyZWdpb24iOiJFVSIsInN0YWdlIjoiUFJEIiwiY3JlZiI6IjA4MjUxMkJEIiwidG9rZW4iOiJiZThjOTA5OC1hYmZlLTQ3N2ItODAwMi1kMzQwYjJhYjVjZmQiLCJjbHR5IjoicHJpdmF0ZSIsIngtcmVnIjoiRVUiLCJ4LWVudiI6IlBSRCJ9","scope":"IdentifyAppliance Monitor Settings Control","token_type":"Bearer"}
                                2024-07-05 17:44:44.498 - debug: homeconnect.0 (37662) Get device list
                                2024-07-05 17:44:44.678 - debug: homeconnect.0 (37662) {"data":{"homeappliances":[{"brand":"Siemens","connected":false,"enumber":"WM14VG93/04","haId":"SIEMENS-WM14VG93-68A40E9041F2","name":"Waschmaschine","type":"Washer","vib":"WM14VG93"},{"brand":"Siemens","connected":true,"enumber":"CT636LES6/09","haId":"SIEMENS-CT636LES6-68A40E7F934D","name":"Kaffeevollautomat","type":"CoffeeMaker","vib":"CT636LES6"},{"brand":"Siemens","connected":true,"enumber":"HS658GXS7/B6","haId":"SIEMENS-HS658GXS7-68A40E869CE1","name":"Backofen","type":"Oven","vib":"HS658GXS7"},{"brand":"Siemens","connected":true,"enumber":"SN53HS60CE/24","haId":"012080386473004974","name":"Geschirrspüler Eltern","type":"Dishwasher","vib":"SN53HS60CE"},{"brand":"Siemens","connected":true,"enumber":"SN63HX36VE/40","haId":"402030386678002229","name":"Geschirrspüler","type":"Dishwasher","vib":"SN63HX36VE"}]}}
                                2024-07-05 17:44:44.678 - info: homeconnect.0 (37662) Found 5 devices
                                2024-07-05 17:44:45.308 - debug: homeconnect.0 (37662) active.options.
                                2024-07-05 17:44:45.308 - debug: homeconnect.0 (37662) Delete: SIEMENS-CT636LES6-68A40E7F934D.programs.active.options
                                2024-07-05 17:44:45.760 - debug: homeconnect.0 (37662) active.options.
                                2024-07-05 17:44:45.760 - debug: homeconnect.0 (37662) Delete: SIEMENS-HS658GXS7-68A40E869CE1.programs.active.options
                                2024-07-05 17:44:46.108 - debug: homeconnect.0 (37662) active.options.
                                2024-07-05 17:44:46.109 - debug: homeconnect.0 (37662) Delete: 012080386473004974.programs.active.options
                                2024-07-05 17:44:46.164 - debug: homeconnect.0 (37662) Start EventStream
                                2024-07-05 17:44:46.358 - debug: homeconnect.0 (37662) active.options.
                                2024-07-05 17:44:46.359 - debug: homeconnect.0 (37662) Delete: 402030386678002229.programs.active.options
                                2024-07-05 17:44:47.732 - info: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D/programs/selected: There is no program selected.
                                2024-07-05 17:44:47.732 - debug: homeconnect.0 (37662) {"error":{"description":"There is no program selected","key":"SDK.Error.NoProgramSelected"}}
                                2024-07-05 17:44:47.736 - info: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D/programs/active: There is no program active.
                                2024-07-05 17:44:47.736 - debug: homeconnect.0 (37662) {"error":{"description":"There is no program active","key":"SDK.Error.NoProgramActive"}}
                                2024-07-05 17:44:47.739 - info: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D/programs/active/options: There is no program active.
                                2024-07-05 17:44:47.739 - debug: homeconnect.0 (37662) {"error":{"description":"There is no program active","key":"SDK.Error.NoProgramActive"}}
                                2024-07-05 17:44:47.742 - info: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D/programs/selected/options: There is no program selected.
                                2024-07-05 17:44:47.742 - debug: homeconnect.0 (37662) {"error":{"description":"There is no program selected","key":"SDK.Error.NoProgramSelected"}}
                                2024-07-05 17:44:47.749 - debug: homeconnect.0 (37662) {"data":{"settings":[{"key":"BSH.Common.Setting.ChildLock","value":false,"name":"Kindersicherung"},{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.Standby","name":"Energiezustand","displayvalue":"Standby"}]}}
                                2024-07-05 17:44:47.750 - debug: homeconnect.0 (37662) /settings
                                2024-07-05 17:44:47.750 - debug: homeconnect.0 (37662) {"data":{"settings":[{"key":"BSH.Common.Setting.ChildLock","value":false,"name":"Kindersicherung"},{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.Standby","name":"Energiezustand","displayvalue":"Standby"}]}}
                                2024-07-05 17:44:47.750 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.settings.BSH_Common_Setting_ChildLock
                                2024-07-05 17:44:47.752 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.settings.BSH_Common_Setting_PowerState
                                2024-07-05 17:44:47.754 - debug: homeconnect.0 (37662) {"data":{"status":[{"key":"BSH.Common.Status.OperationState","value":"BSH.Common.EnumType.OperationState.Inactive","name":"Betriebsstatus","displayvalue":"Inaktiv"},{"key":"BSH.Common.Status.RemoteControlStartAllowed","value":true,"name":"Fernstart"},{"key":"BSH.Common.Status.LocalControlActive","value":false,"name":"Lokale Bedienung aktiv"},{"key":"ConsumerProducts.CoffeeMaker.Status.BeverageCounterRistrettoEspresso","value":0,"name":"Anzahl Ristretto & Espresso"},{"key":"ConsumerProducts.CoffeeMaker.Status.BeverageCounterCoffee","value":3791,"name":"Anzahl Kaffeegetränke"},{"key":"ConsumerProducts.CoffeeMaker.Status.BeverageCounterCoffeeAndMilk","value":56,"name":"Anzahl Kaffee-Milch-Spezialitäten"},{"key":"ConsumerProducts.CoffeeMaker.Status.BeverageCounterFrothyMilk","value":1,"name":"Anzahl Milchschaum"},{"key":"ConsumerProducts.CoffeeMaker.Status.BeverageCounterHotMilk","value":20,"name":"Anzahl warme Milch"},{"key":"ConsumerProducts.CoffeeMaker.Status.BeverageCounterHotWater","value":360,"unit":"ml","name":"Menge Heißwasser"},{"key":"ConsumerProducts.CoffeeMaker.Status.BeverageCounterPowderCoffee","value":4,"name":"Anzahl Getränke mit Kaffeepulver"},{"key":"BSH.Common.Status.DoorState","value":"BSH.Common.EnumType.DoorState.Closed","name":"Tür","displayvalue":"Geschlossen"}]}}
                                2024-07-05 17:44:47.754 - debug: homeconnect.0 (37662) /status
                                2024-07-05 17:44:47.755 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.BSH_Common_Status_OperationState
                                2024-07-05 17:44:47.755 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.BSH_Common_Status_RemoteControlStartAllowed
                                2024-07-05 17:44:47.755 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.BSH_Common_Status_LocalControlActive
                                2024-07-05 17:44:47.755 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterRistrettoEspresso
                                2024-07-05 17:44:47.756 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterCoffee
                                2024-07-05 17:44:47.756 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterCoffeeAndMilk
                                2024-07-05 17:44:47.756 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterFrothyMilk
                                2024-07-05 17:44:47.756 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterHotMilk
                                2024-07-05 17:44:47.757 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterHotWater
                                2024-07-05 17:44:47.757 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.ConsumerProducts_CoffeeMaker_Status_BeverageCounterPowderCoffee
                                2024-07-05 17:44:47.757 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.status.BSH_Common_Status_DoorState
                                2024-07-05 17:44:47.760 - debug: homeconnect.0 (37662) {"data":{"active":{"constraints":{"access":"read"}},"programs":[{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Ristretto","name":"Ristretto"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Espresso","name":"Espresso"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoMacchiato","name":"Espresso Macchiato"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee","name":"Caffè Crema"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Cappuccino","name":"Cappuccino"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.LatteMacchiato","name":"Latte Macchiato"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.CaffeLatte","name":"Milchkaffee"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.MilkFroth","name":"Milchschaum"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.WarmMilk","name":"Warme Milch"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.HotWater","name":"Heißwasser"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KleinerBrauner","name":"Kleiner Brauner"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.GrosserBrauner","name":"Großer Brauner"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Verlaengerter","name":"Verlängerter"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.VerlaengerterBraun","name":"Verlängerter braun"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.WienerMelange","name":"Wiener Melange"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.FlatWhite","name":"Flat White"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Cortado","name":"Cortado"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeCortado","name":"Café cortado"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeConLeche","name":"Café con leche"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeAuLait","name":"Café au lait"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Doppio","name":"Doppio"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Kaapi","name":"Kaapi"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KoffieVerkeerd","name":"Koffie verkeerd"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Galao","name":"Galão"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Garoto","name":"Garoto"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Americano","name":"Americano"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.RedEye","name":"Red Eye"}],"selected":{"constraints":{"access":"read"}}}}
                                2024-07-05 17:44:47.760 - debug: homeconnect.0 (37662) /programs
                                2024-07-05 17:44:47.760 - info: homeconnect.0 (37662) No array: active
                                2024-07-05 17:44:47.761 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Ristretto","name":"Ristretto"}
                                2024-07-05 17:44:47.761 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_Ristretto
                                2024-07-05 17:44:47.761 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Espresso","name":"Espresso"}
                                2024-07-05 17:44:47.761 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_Espresso
                                2024-07-05 17:44:47.762 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoMacchiato","name":"Espresso Macchiato"}
                                2024-07-05 17:44:47.762 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_EspressoMacchiato
                                2024-07-05 17:44:47.762 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee","name":"Caffè Crema"}
                                2024-07-05 17:44:47.762 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_Coffee
                                2024-07-05 17:44:47.763 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Cappuccino","name":"Cappuccino"}
                                2024-07-05 17:44:47.763 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_Cappuccino
                                2024-07-05 17:44:47.763 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.LatteMacchiato","name":"Latte Macchiato"}
                                2024-07-05 17:44:47.763 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_LatteMacchiato
                                2024-07-05 17:44:47.764 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.CaffeLatte","name":"Milchkaffee"}
                                2024-07-05 17:44:47.764 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_CaffeLatte
                                2024-07-05 17:44:47.764 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.MilkFroth","name":"Milchschaum"}
                                2024-07-05 17:44:47.764 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_MilkFroth
                                2024-07-05 17:44:47.765 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.WarmMilk","name":"Warme Milch"}
                                2024-07-05 17:44:47.765 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_WarmMilk
                                2024-07-05 17:44:47.765 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.HotWater","name":"Heißwasser"}
                                2024-07-05 17:44:47.765 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_Beverage_HotWater
                                2024-07-05 17:44:47.766 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KleinerBrauner","name":"Kleiner Brauner"}
                                2024-07-05 17:44:47.766 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_KleinerBrauner
                                2024-07-05 17:44:47.766 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.GrosserBrauner","name":"Großer Brauner"}
                                2024-07-05 17:44:47.767 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_GrosserBrauner
                                2024-07-05 17:44:47.767 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Verlaengerter","name":"Verlängerter"}
                                2024-07-05 17:44:47.767 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_Verlaengerter
                                2024-07-05 17:44:47.767 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.VerlaengerterBraun","name":"Verlängerter braun"}
                                2024-07-05 17:44:47.767 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_VerlaengerterBraun
                                2024-07-05 17:44:47.768 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.WienerMelange","name":"Wiener Melange"}
                                2024-07-05 17:44:47.768 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_WienerMelange
                                2024-07-05 17:44:47.768 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.FlatWhite","name":"Flat White"}
                                2024-07-05 17:44:47.768 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_FlatWhite
                                2024-07-05 17:44:47.768 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Cortado","name":"Cortado"}
                                2024-07-05 17:44:47.769 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_Cortado
                                2024-07-05 17:44:47.769 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeCortado","name":"Café cortado"}
                                2024-07-05 17:44:47.769 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_CafeCortado
                                2024-07-05 17:44:47.769 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeConLeche","name":"Café con leche"}
                                2024-07-05 17:44:47.770 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_CafeConLeche
                                2024-07-05 17:44:47.770 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeAuLait","name":"Café au lait"}
                                2024-07-05 17:44:47.770 - debug: homeconnect.0 (37662) Create State: SIEMENS-CT636LES6-68A40E7F934D.programs.available.ConsumerProducts_CoffeeMaker_Program_CoffeeWorld_CafeAuLait
                                2024-07-05 17:44:47.770 - debug: homeconnect.0 (37662) SIEMENS-CT636LES6-68A40E7F934D available: {"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Doppio","name":"Doppio"}
                                • T TT-Tom
                                  @haselchen
                                  @TimoWald
                                  TimoWald
                                  @tt-tom Ja die HomeConnect App funktioniert.
                                  • T TimoWald
                                    TT-Tom
                                    @timowald sieht erstmal gut aus. Die Geräte wurden erkannt und der Status abgefragt. Keine aktiven Programme aktuell. Für die Kaffeemaschine wurden die möglichen Kaffee eingelesen. Ob sich jetzt Daten ändern musst du jetzt mal testen.
                                    Prüfe auch mal wie oft er die Daten abruft. Wenn die zu oft angefragt werden, landest du wieder in die Blockade.
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      TimoWald
                                      @tt-tom der Adapter scheint jetzt wieder zu laufen wie er soll. Ich teste es mal noch 2 Tage ausgiebig. Danke für eure Hilfe.
