  3. Einsteigerfragen
  4. Zigbee Adapter nach Stromausfall keine Verbindung (gelöst)
    5.4k
148 Beiträge 9 Kommentatoren 20.8k Aufrufe 8 Beobachtet
  • stefu87_CHS stefu87_CH
    @asgothian Ich dreh jetzt denn komplett durch. Auch mit einem neuen Stick bringe ich die Verbindung nicht mehr zum laufen.
    2024-07-02 19:01:57.065 - info: zigbee.0 (3418) Got terminate signal TERMINATE_YOURSELF
    2024-07-02 19:01:57.066 - info: zigbee.0 (3418) cleaned everything up...
    2024-07-02 19:01:57.066 - info: zigbee.0 (3418) Zigbee: disabling joining new devices.
    2024-07-02 19:01:57.072 - warn: zigbee.0 (3418) Failed to stop zigbee during startup
    2024-07-02 19:01:57.072 - info: zigbee.0 (3418) terminating
    2024-07-02 19:01:57.072 - info: zigbee.0 (3418) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-07-02 19:01:57.189 - info: host.Iobroker stopInstance system.adapter.zigbee.0 send kill signal
    2024-07-02 19:01:57.566 - info: zigbee.0 (3418) terminating
    2024-07-02 19:01:57.630 - info: host.Iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-07-02 19:02:00.240 - info: host.Iobroker instance system.adapter.zigbee.0 started with pid 3669
    2024-07-02 19:02:01.549 - info: zigbee.0 (3669) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.15.0, js-controller: 5.0.19
    2024-07-02 19:02:01.573 - info: zigbee.0 (3669) delete old Backup files. keep only last 10
    2024-07-02 19:02:01.574 - info: zigbee.0 (3669) Starting Zigbee npm ...
    2024-07-02 19:02:01.723 - info: zigbee.0 (3669) Installed Version: iobroker.zigbee@1.10.3
    2024-07-02 19:02:18.283 - info: admin.0 (441) ==> Connected system.user.admin from ::ffff:192.168.0.20
    2024-07-02 19:02:18.380 - error: zigbee.0 (3669) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-07-02 19:02:18.465 - info: zigbee.0 (3669) List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    2024-07-02 19:02:21.805 - error: zigbee.0 (3669) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2024-07-02 19:02:21.805 - error: zigbee.0 (3669) Failed to start Zigbee
    2024-07-02 19:02:21.806 - error: zigbee.0 (3669) Error herdsman start
    2024-07-02 19:02:31.807 - info: zigbee.0 (3669) Try to reconnect. 1 attempts left
    2024-07-02 19:02:31.807 - info: zigbee.0 (3669) Starting Zigbee npm ...
    2024-07-02 19:02:31.810 - info: zigbee.0 (3669) Installed Version: iobroker.zigbee@1.10.3
    2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
    2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Failed to start Zigbee
    2024-07-02 19:02:31.904 - error: zigbee.0 (3669) Error herdsman start
    2024-07-02 19:02:44.154 - info: admin.0 (441) <== Disconnect system.user.admin from ::ffff:192.168.0.20
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #117
    @stefu87_ch sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
    Beschreib doch noch mal bitte den gesamten Aufbau. Ich weiss ich kann mir das hier auch irgendwo heraus suchen, aber es ist einfacher wenn du die betroffenen Komponenten beschreibst. Die Meldung
    deutet darauf hin das die Emulation des seriellen Ports prinzipiell klappt, aber keine Kommunikation mit der Firmware möglich ist. Das kann auch mit dem verwendeten USB Port / USB Verlängerungskabel zu tun haben. Auch hier solltest du ggf. einmal wechseln, bzw. den Stick (sofern du hast) mit einem RPI ausprobieren, bei dem du vorher WLAN und Bluetooth per boot Optionen deaktiviert hast.
    A.
    • stefu87_CHS Offline
      stefu87_CHS Offline
      stefu87_CH
      #118
      @asgothian Also habe einen komplett neuen Sonoff Zigbee Stick gekauft. Der steckt direkt am USB Port meines Proxmox Server. Der Proxmox Server läuft auf einem GIGABYTE mit diesen Informationen:
      Ein RPI habe ich leider keins zur Verfügung.
      Ich habe nur 3 USB Anschlüsse zur Verfügung. 2 davon sind USB 2.0 und 1 x USB 3.0
      Cores: 1 × 8 = 8 cores
      Threads: 16
      mit Proxmox
      LXC Container mit Iobroker
      HomoranH crunchipC 2 Antworten Letzte Antwort
        #119
        und wo läuft in dem Konstrukt iobroker?
          stefu87_CHS Offline
          stefu87_CHS Offline
          stefu87_CH
          #120
          @homoran iobroker läuft in einem Ubuntu Container
          Threads: 16
          mit Proxmox
            #121
            und dem sind alle USB Ports bekannt?
              crunchipC Offline
              crunchipC Offline
              #122
              hast du beide mal probiert?
              2te Frage, hast du nun den Stick nach der herkömmlichen Anleitung eingebunden oder nach der neuen Variante, die seit kurzen möglich ist?
                stefu87_CHS Offline
                stefu87_CHS Offline
                stefu87_CH
                #123
                @homoran sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                Wird jedenfalls mit dem Befehl
                admin@Iobroker:~$ lsusb
                Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                Bus 001 Device 004: ID 8087:0aa7 Intel Corp. Wireless-AC 3168 Bluetooth
                Bus 001 Device 010: ID 1a86:55d4 QinHeng Electronics SONOFF Zigbee 3.0 USB Dongle Plus V2
                Bus 001 Device 008: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
                erkannt.
                Threads: 16
                mit Proxmox
                  stefu87_CHS Offline
                  stefu87_CHS Offline
                  stefu87_CH
                  #124
                  @crunchip sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                  Bis jetzt immer mit dem gleichen Port wie mit dem alten USB Stick.
                  Ich habe es nach der alten Variante versucht, da mit der neuen Variante ich es auch nicht geschafft habe.
                  Threads: 16
                  mit Proxmox
                    crunchipC Offline
                    crunchipC Offline
                    #125
                    dann steck doch mal um und passe die Eingaben entsprechend an
                    stefu87_CHS HomoranH 2 Antworten Letzte Antwort
                      stefu87_CHS Offline
                      stefu87_CHS Offline
                      stefu87_CH
                      #126
                      Ok werde ich morgen mal testen. Was ich noch vermute, ist das die Pan ID nie die richtige ist, aber im Log wird nach jedem neustarten eine neue ID angezeigt.
                      Threads: 16
                      mit Proxmox
                        #127
                        üblicherweise soll man ja den /dev/serial/by-id/ Link nehmen, dann braucht man nichts anzupassen
                        stefu87_CHS crunchipC 2 Antworten Letzte Antwort
                          stefu87_CHS Offline
                          stefu87_CHS Offline
                          stefu87_CH
                          #128
                          Dann soll ich eher über USB Passthrough versuchen, anstelle in den Log anzupassen?
                          Threads: 16
                          mit Proxmox
                            #129
                            was ?
                            in der Konfig muss der /dev... link statt USB0 o.ä rein
                              was ?
                              stefu87_CHS Offline
                              stefu87_CHS Offline
                              stefu87_CH
                              #130
                              was ?
                              In diesem Post Link Text wurde eben empfohlen so einzubinden.
                              Threads: 16
                              mit Proxmox
                                crunchipC Offline
                                crunchipC Offline
                                #131
                                ja doch, das entsprechende Gerät muss doch in der LXC-config hinterlegt werden
                                  stefu87_CHS Offline
                                  stefu87_CHS Offline
                                  stefu87_CH
                                  #132
                                  Habe ich so drin:
                                  Threads: 16
                                  mit Proxmox
                                  DJMarc75D crunchipC 2 Antworten Letzte Antwort
                                    Habe ich so drin:
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #133
                                    @stefu87_ch
                                    Falls das 1 bei "unpriviliged" in Deinem Screenshot bedeutet dass der LXC "priviligiert" ist dann klappt das mit dem ganzen Durchreichen eh nicht.
                                    Lehrling seit 1975 !!!
                                    HomoranH stefu87_CHS 2 Antworten Letzte Antwort
                                    • DJMarc75D DJMarc75
                                      @stefu87_ch
                                      #134
                                      @djmarc75 1 ist üblicherweise true
                                        @stefu87_ch
                                        stefu87_CHS Offline
                                        stefu87_CHS Offline
                                        stefu87_CH
                                        #135
                                        @djmarc75 sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                                        @stefu87_ch
                                        Threads: 16
                                        mit Proxmox
                                          @stefu87_ch
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #136
                                          @stefu87_ch na dann :)
                                          edit: ist unpreviligiert
