  4. kann keine Instanzen, Szenen, Skript, Host, Info aufrufen
20 Beiträge 3 Kommentatoren 1.7k Aufrufe 2 Beobachtet
  • F foto2004
    OK
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: pille
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.8.8-1-pve
          Architecture: x86-64
    model name	: Intel(R) Xeon(R) CPU E31240 @ 3.30GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     08:44:17 up  1:49,  1 user,  load average: 0.76, 1.02, 1.05
    CPU threads: 3
    *** Time and Time Zones ***
                   Local time: Sat 2024-06-29 08:44:17 CEST
               Universal time: Sat 2024-06-29 06:44:17 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    immanuel
    HOME=/home/immanuel
    GROUPS=immanuel sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            4.1G        3.3G        187M        8.0M        596M        790M
    Swap:             0B          0B          0B
    Total:          4.1G        3.3G        187M
    Active iob-Instances: 	38
             4098 M total memory
             3313 M used memory
             3438 M active memory
              223 M inactive memory
              187 M free memory
                0 M buffer memory
              596 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 08:44:17 up  1:49,  1 user,  load average: 0.76, 1.02, 1.05
    Tasks:  86 total,   2 running,  84 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 46.8 us,  8.5 sy,  0.0 ni, 44.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4098.0 total,    188.4 free,   3313.1 used,    596.5 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.    790.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
    * proc-fs-nfsd.mount            loaded failed failed NFSD configuration filesystem
    * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
    * pmcd.service                  loaded failed failed LSB: Control pmcd (the collection daemon for PCP)
    * pmie.service                  loaded failed failed LSB: Control pmie (performance inference engine for PCP)
    * pmlogger.service              loaded failed failed LSB: Control pmlogger (the performance metrics logger for PCP)
    * pmproxy.service               loaded failed failed LSB: Control pmproxy (the pmcd proxy daemon for PCP)
    * ufw.service                   loaded failed failed Uncomplicated firewall
    * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
    9 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--104--disk--1 ext4       49G   13G   34G  27% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                            tmpfs      16G  3.1M   16G   1% /dev/shm
    tmpfs                            tmpfs     6.3G  156K  6.3G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1000
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET                                SOURCE                           FSTYPE     OPTIONS
    /                                     /dev/mapper/pve-vm--104--disk--1 ext4       rw,relatime,stripe=16
    |-/run                                tmpfs                            tmpfs      rw,nosuid,nodev,size=6568608k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
    | |-/run/lock                         tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    | `-/run/user/1000                    tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=3284300k,nr_inodes=821075,mode=700,uid=101000,gid=101000,inode64
    |-/dev                                none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                          tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                       mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
    | |-/dev/.lxc/proc                    proc                             proc       rw,relatime
    | |-/dev/.lxc/sys                     sys                              sysfs      rw,relatime
    | |-/dev/full                         udev[/full]                      devtmpfs   rw,nosuid,relatime,size=16387608k,nr_inodes=4096902,mode=755,inode64
    | |-/dev/null                         udev[/null]                      devtmpfs   rw,nosuid,relatime,size=16387608k,nr_inodes=4096902,mode=755,inode64
    | |-/dev/random                       udev[/random]                    devtmpfs   rw,nosuid,relatime,size=16387608k,nr_inodes=4096902,mode=755,inode64
    | |-/dev/tty                          udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=16387608k,nr_inodes=4096902,mode=755,inode64
    | |-/dev/urandom                      udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=16387608k,nr_inodes=4096902,mode=755,inode64
    | |-/dev/zero                         udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=16387608k,nr_inodes=4096902,mode=755,inode64
    | |-/dev/pts                          devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                         devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                      devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                         devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                         devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                               proc                             proc       rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                         proc[/sys]                       proc       ro,relatime
    | | |-/proc/sys/net                   proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc       ro,relatime
    | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys                                sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
      |-/sys/fs/fuse/connections          fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
      |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/cgroup                    none                             cgroup2    rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    3.1G	/var/
    2.3G	/var/log
    2.0G	/var/log/journal/ee9bb29d93e54377b4cc06e74aed3dbf
    603M	/var/cache
    Archived and active journals take up 90.7M in the file system.
    /opt/iobroker/backups:
    110M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G	/opt/iobroker/iobroker-data/
    704M	/opt/iobroker/iobroker-data/history
    413M	/opt/iobroker/iobroker-data/files
    138M	/opt/iobroker/iobroker-data/files/javascript.admin
    118M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    40M	/opt/iobroker/iobroker-data/states.jsonl
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.20.3
    /usr/bin/node 		v18.20.3
    /usr/bin/npm 		10.7.0
    /usr/bin/npx 		10.7.0
    /usr/bin/corepack 	0.28.0
    nodejs:
      Installed: 18.20.3-1nodesource1
      Candidate: 18.20.3-1nodesource1
      Version table:
     *** 18.20.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.19
    admin: 		6.13.16
    javascript: 	8.3.1
    nodejs modules from github: 	1
    +-- iobroker.omada@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#5d3eb7060ba75407dbb96ef9c8c2951efe8c0eb2)
    Adapter State
    + system.adapter.admin.0                  : admin                 : pille                                    -  enabled, port: 9081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.artnet.0                 : artnet                : pille                                    - disabled, port: 6454
    + system.adapter.backitup.0               : backitup              : pille                                    -  enabled
      system.adapter.cloud.0                  : cloud                 : pille                                    - disabled
      system.adapter.device-reminder.0        : device-reminder       : pille                                    - disabled
      system.adapter.devices.0                : devices               : pille                                    - disabled
      system.adapter.discovery.0              : discovery             : pille                                    - disabled
      system.adapter.dwd.0                    : dwd                   : pille                                    -  enabled
      system.adapter.flot.0                   : flot                  : pille                                    - disabled
      system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : pille                                    -  enabled
    + system.adapter.history.0                : history               : pille                                    -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : pille                                    -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : pille                                    -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : pille                                    -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : pille                                    -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : pille                                    -  enabled, port: 18701
    + system.adapter.hm-rpc.4                 : hm-rpc                : pille                                    -  enabled, port: 12001
    + system.adapter.hm-rpc.5                 : hm-rpc                : pille                                    -  enabled, port: 12010
      system.adapter.homeconnect.0            : homeconnect           : pille                                    - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : pille                                    - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : pille                                    - disabled
    + system.adapter.influxdb.0               : influxdb              : pille                                    -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : pille                                    -  enabled
    + system.adapter.javascript.0             : javascript            : pille                                    -  enabled
    + system.adapter.linux-control.0          : linux-control         : pille                                    -  enabled
    + system.adapter.lovelace.0               : lovelace              : pille                                    -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.moma.0                   : moma                  : pille                                    -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : pille                                    -  enabled, port: 1883
    + system.adapter.mqtt.0                   : mqtt                  : pille                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : pille                                    -  enabled
    + system.adapter.node-red.0               : node-red              : pille                                    -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.node-red.1               : node-red              : pille                                    -  enabled, port: 1881, bind: 0.0.0.0
      system.adapter.octoprint.0              : octoprint             : pille                                    - disabled
    + system.adapter.omada.0                  : omada                 : pille                                    -  enabled, port: 8043
    + system.adapter.parser.0                 : parser                : pille                                    -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : pille                                    -  enabled
      system.adapter.ping.0                   : ping                  : pille                                    - disabled
    + system.adapter.proxmox.0                : proxmox               : pille                                    -  enabled, port: 8006
      system.adapter.proxy.0                  : proxy                 : pille                                    - disabled
    + system.adapter.roomba.0                 : roomba                : pille                                    -  enabled
      system.adapter.rpi2.0                   : rpi2                  : pille                                    - disabled
    + system.adapter.scenes.0                 : scenes                : pille                                    -  enabled
      system.adapter.schoolfree.0             : schoolfree            : pille                                    -  enabled
    + system.adapter.simple-api.0             : simple-api            : pille                                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : pille                                    -  enabled
    + system.adapter.statistics.0             : statistics            : pille                                    -  enabled
      system.adapter.systeminfo.0             : systeminfo            : pille                                    - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : pille                                    -  enabled
    + system.adapter.telegram.0               : telegram              : pille                                    -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : pille                                    -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : pille                                    -  enabled
      system.adapter.vis-bars.0               : vis-bars              : pille                                    - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pille                                    - disabled
      system.adapter.vis-history.0            : vis-history           : pille                                    - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pille                                    - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pille                                    - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : pille                                    - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : pille                                    -  enabled
      system.adapter.vis-metro.0              : vis-metro             : pille                                    - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : pille                                    - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : pille                                    - disabled
      system.adapter.vis-weather.0            : vis-weather           : pille                                    - disabled
      system.adapter.vis.0                    : vis                   : pille                                    - disabled
    + system.adapter.web.0                    : web                   : pille                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: immanuel
      system.adapter.windows-control.0        : windows-control       : pille                                    - disabled
    + system.adapter.wireguard.0              : wireguard             : pille                                    -  enabled
    + system.adapter.wled.0                   : wled                  : pille                                    -  enabled
      system.adapter.youtube.0                : youtube               : pille                                    - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.17.14  , installed 6.13.16 [Updatable]
    Adapter    "artnet"       : 1.2.2    , installed 1.2.2
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "fuelpricemonitor": 0.4.0 , installed 0.4.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "javascript"   : 8.3.1    , installed 8.3.1
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
    Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "parser"       : 2.1.0    , installed 2.1.0
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "roomba"       : 1.3.0    , installed 1.3.0
    Adapter    "scenes"       : 3.0.4    , installed 3.0.4
    Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.3.2    , installed 3.3.2
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wireguard"    : 1.6.4    , installed 1.6.4
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "youtube"      : 5.0.0    , installed 5.0.0
    Objects and States
    Objects: 	29437
    States: 	27880
    Hit:1 http://security.debian.org bullseye-security InRelease
    Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:3 http://ftp.debian.org/debian bullseye InRelease
    Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
    Reading package lists...
    Pending Updates: 5
    *** Listening Ports ***
    tcp        0      0 192.168.2.165:12010     0.0.0.0:*               LISTEN      1001       44904082   2264/io.hm-rpc.5
    tcp        0      0 192.168.2.165:12001     0.0.0.0:*               LISTEN      1001       44904032   2234/io.hm-rpc.4
    tcp        0      0 192.168.2.165:8701      0.0.0.0:*               LISTEN      1001       44904677   2178/io.hm-rpc.2
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       44743405   201/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       44745271   201/iobroker.js-con
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        44745001   161/systemd-resolve
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       44904354   2332/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       44904353   2332/io.mqtt.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       44895876   1951/node-red
    tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       44895944   1992/node-red
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      998        44746915   309/pihole-FTL
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          44743239   323/lighttpd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          44736508   1/init
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          44746790   507/master
    tcp        0      0 192.168.2.165:2010      0.0.0.0:*               LISTEN      1001       44904574   2148/io.hm-rpc.1
    tcp        0      0 192.168.2.165:2001      0.0.0.0:*               LISTEN      1001       44903710   2122/io.hm-rpc.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      112        44737390   200/influxd
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      998        44746921   309/pihole-FTL
    tcp6       0      0 :::8086                 :::*                    LISTEN      112        44743404   200/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       44926308   3727/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       44931105   4413/io.web.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       44930694   4852/io.lovelace.0
    tcp6       0      0 ::1:4711                :::*                    LISTEN      998        44746922   309/pihole-FTL
    tcp6       0      0 :::5355                 :::*                    LISTEN      104        44745004   161/systemd-resolve
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          44746791   507/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          44743009   1/init
    tcp6       0      0 :::53                   :::*                    LISTEN      998        44746917   309/pihole-FTL
    tcp6       0      0 :::80                   :::*                    LISTEN      0          44743240   323/lighttpd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          44736510   1/init
    tcp6       0      0 :::9081                 :::*                    LISTEN      1001       44857155   1806/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       46477892   471512/io.wled.0
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        44745000   161/systemd-resolve
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           998        44746914   309/pihole-FTL
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           998        44746911   309/pihole-FTL
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          44736509   1/init
    udp6       0      0 :::5355                 :::*                                104        44745003   161/systemd-resolve
    udp6       0      0 :::53                   :::*                                998        44746916   309/pihole-FTL
    udp6       0      0 :::111                  :::*                                0          44736511   1/init
    2024-06-29 08:44:29.708  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 27.56
    2024-06-29 08:44:29.712  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.tempWarmwasser =======================
    2024-06-29 08:44:29.712  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 50.88
    2024-06-29 08:44:29.712  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.relayVorlauf =======================
    2024-06-29 08:44:29.713  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 0
    2024-06-29 08:44:29.714  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.relayWarmwasser =======================
    2024-06-29 08:44:29.714  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 0
    2024-06-29 08:44:29.736  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.relayWP =======================
    2024-06-29 08:44:29.736  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 0
    2024-06-29 08:44:33.047  - info: mqtt.0 (2332) Client [Wetter1] connection closed: timeout
    2024-06-29 08:44:33.241  - info: mqtt.0 (2332) Client [Wetter1] connected with secret 1719643473241_3786
    2024-06-29 08:44:33.294  - info: mqtt.0 (2332) Client [Wetter1] subscribes on "mqtt.0.ESPtest.led1"
    2024-06-29 08:44:33.494  - info: mqtt.0 (2332) Client [Wetter1] publishOnSubscribe
    2024-06-29 08:44:38.026  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.switch1 =======================
    2024-06-29 08:44:38.026  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 0
    2024-06-29 08:44:38.048  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.tempVorlauf =======================
    2024-06-29 08:44:38.049  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 27.56
    2024-06-29 08:44:38.050  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.tempWarmwasser =======================
    2024-06-29 08:44:38.050  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 50.88
    2024-06-29 08:44:38.050  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.relayVorlauf =======================
    2024-06-29 08:44:38.050  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 0
    2024-06-29 08:44:38.053  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.relayWarmwasser =======================
    2024-06-29 08:44:38.053  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 0
    2024-06-29 08:44:38.054  - debug: statistics.0 (3744) [STATE CHANGE] ======================= mqtt.0.Heizung.Steuerung1.relayWP =======================
    2024-06-29 08:44:38.054  - debug: statistics.0 (3744) [STATE CHANGE] stateChange => 0
    @foto2004 Ich sehe da nichts wozu ich etwas sagen könnte.
    lediglich deine 4GB RAM gehen auch bald zur Neige, und die Logstufe von statistics.0 solltest du niedriger stellen, sonst müllt das das Log zu.
    Vielleicht kann @Thomas-Braun sehen warum Herr Kant nichts darf, aber das ist möglicherweise auch nur in den User Einstellungen zu sehen.
    F 1 Antwort Letzte Antwort
      foto2004
      ok danke für die Info ich werde es beherzigen. Habe ich übersehen die Logstufe wieder runter zu schrauben.
      • F foto2004
        @foto2004
        Ich sehe da nur port: 9081 für den admin.
        Adressierst du den auch?
        F 2 Antworten Letzte Antwort
        • F foto2004
          das was vorher stand OK muss ich in eine Datei umleiten weil das eine ganze Menge ist die das Terminal nachher nicht hergibt.
          Einen kleinen Moment bitte
          @foto2004 sagte in kann keine Instanzen, Szenen, Skript, Host, Info aufrufen:
          Dann verwende ein anderes Terminal...
          So viel Text ist das nicht.
          Ein log wird übrigens ganz ohne Umleitung unter /home/iobroker/iob_diag.log abgelegt.
            @foto2004
            foto2004
            wie meinst du das?
            • F foto2004
              wie meinst du das?
              @foto2004
              Manche Terminals haben einen größeren Puffer als andere.
              Die Ausgabe von iob diag passt aber in der Regel hinein.
              Wenn nicht gerade im Log des ioBroker eine sehr lange Fehlermeldung auftaucht jedenfalls.
                @foto2004
                foto2004
                ich habe die Ausgabe eh schon gepostet.
                  @foto2004
                  foto2004
                  @thomas-braun said in kann keine Instanzen, Szenen, Skript, Host, Info aufrufen:
                  @foto2004
                  Wie meinst du "Adressierst den auch?"
                  • F foto2004
                    @foto2004
                    @foto2004
                    Ob du den admin über diesen Port auch aufrufst.
                    Standard ist ja eigentlich
                    ip.des.io.broker:8081
                      @foto2004
                      foto2004
                      @foto2004
                      ja ich rufe ihn über diesen Port 9081 auf
                      • F foto2004
                        @foto2004
                        foto2004
                        ich habe jetzt mal einen neuen user erstellt und da ist es das selbe Problem
                        • F foto2004
                          foto2004
                          schrieb am zuletzt editiert von foto2004
                          wenn ich da die Konsole im Browser aufmache bekomme ich dieses
