  4. slave start nicht mehr nach nodejs-update 20
    1.0k
    6.1k
nodejs update
58 Beiträge 5 Kommentatoren 6.7k Aufrufe 3 Beobachtet
  • bahnuhrB bahnuhr
    anbei mal iob diag (ohne summary)
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: Pi-Strom-Wasser
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7+
          Architecture: arm
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     09:40:01 up 10 min,  1 user,  load average: 0.94, 1.09, 0.54
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    VCHI initialization failed
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** Time and Time Zones ***
                   Local time: Sat 2024-06-15 09:40:01 CEST
               Universal time: Sat 2024-06-15 07:40:01 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dieter
    HOME=/home/dieter
    GROUPS=dieter sudo iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           923M        125M        128M        6.0M        668M        727M
    Swap:           99M          0B         99M
    Total:         1.0G        125M        228M
    Active iob-Instances:   50
              923 M total memory
              126 M used memory
              345 M active memory
              360 M inactive memory
              128 M free memory
              175 M buffer memory
              493 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 09:40:01 up 10 min,  1 user,  load average: 0.94, 1.09, 0.54
    Tasks: 121 total,   1 running, 120 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    923.2 total,    128.2 free,    125.7 used,    669.3 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.    727.3 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       14G  4.6G  8.9G  34% /
    devtmpfs       devtmpfs  430M     0  430M   0% /dev
    tmpfs          tmpfs     462M     0  462M   0% /dev/shm
    tmpfs          tmpfs     462M  6.2M  456M   2% /run
    tmpfs          tmpfs     462M     0  462M   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1002
    [Sat Jun 15 09:29:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Jun 15 09:29:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Jun 15 09:29:26 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Jun 15 09:29:30 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET                                SOURCE         FSTYPE     OPTIONS
    /                                     /dev/mmcblk0p2 ext4       rw,noatime
    |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=439400k,nr_inodes=109850,mode=755
    | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
    | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
    |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
    | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
    | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
    | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
    | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
    | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
    | | |-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
    | | `-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
    | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
    | `-/sys/kernel/config                configfs       configfs   rw,relatime
    |-/proc                               proc           proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=33,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
    | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
    | `-/run/user/1002                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94536k,mode=700,uid=1002,gid=1002
    `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.5G    /var/
    1.3G    /var/cache/apt/archives
    1.3G    /var/cache/apt
    1.3G    /var/cache
    93M     /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    du: cannot access '/opt/iobroker/backups/': No such file or directory
    /opt/iobroker/iobroker-data:
    11M     /opt/iobroker/iobroker-data/
    3.3M    /opt/iobroker/iobroker-data/files
    2.8M    /opt/iobroker/iobroker-data/files/info.admin
    2.4M    /opt/iobroker/iobroker-data/files/info.admin/lib
    2.4M    /opt/iobroker/iobroker-data/backup-objects
    1.6M    /opt/iobroker/iobroker-data/objects.jsonl
    1.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    1.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    464K    /opt/iobroker/iobroker-data/backup-objects/2020-09-04_16-49_objects.json.gz
    464K    /opt/iobroker/iobroker-data/backup-objects/2020-09-03_11-33_objects.json.gz
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907T3PS-if00-port0
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH06GH5Y-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.3
    /usr/bin/node           v18.20.3
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.3-1nodesource1
      Candidate: 18.20.3-1nodesource1
      Version table:
     *** 18.20.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
    + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
      system.adapter.komoot.0                 : komoot                : iobroker                                 - disabled
    + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
    + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
    + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          - disabled
    + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
      system.adapter.sql.1                    : sql                   : iobroker                                 - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.1               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
      system.adapter.wled.0                   : wled                  : iobroker                                 - disabled
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "mbus"         : 2.6.1    , installed 2.6.1
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Objects and States
    Objects:        27223
    States:         22733
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17690      652/sshd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17692      652/sshd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17469      644/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14616      441/avahi-daemon: r
    udp        0      0 0.0.0.0:54543           0.0.0.0:*                           108        14618      441/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14617      441/avahi-daemon: r
    udp6       0      0 :::49598                :::*                                108        14619      441/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16577      644/dhcpcd
    2024-06-15 08:46:14.622  - info: host.Pi-Strom-Wasser stopInstance system.adapter.mbus.0 send kill signal
    2024-06-15 08:46:15.099  - info: smartmeter.1 (28095) terminating
    2024-06-15 08:46:15.103  - info: mbus.0 (28106) terminating
    2024-06-15 08:46:15.519  - info: host.Pi-Strom-Wasser instance system.adapter.smartmeter.1 terminated with code 0 (NO_ERROR)
    2024-06-15 08:46:15.673  - info: host.Pi-Strom-Wasser instance system.adapter.mbus.0 terminated with code 0 (NO_ERROR)
    2024-06-15 08:46:15.675  - info: host.Pi-Strom-Wasser All instances are stopped.
    2024-06-15 08:46:15.825  - info: host.Pi-Strom-Wasser terminated
    2024-06-15 09:38:12.825  - info: host.Pi-Strom-Wasser iobroker.js-controller version 5.0.19 js-controller starting
    2024-06-15 09:38:12.839  - info: host.Pi-Strom-Wasser Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2024-06-15 09:38:12.841  - info: host.Pi-Strom-Wasser hostname: Pi-Strom-Wasser, node: v18.20.3
    2024-06-15 09:38:12.842  - info: host.Pi-Strom-Wasser ip addresses: 192.168.243.121 2a03:93e0:200:990:1a81:eafd:7b4e:8439 fe80::ba9d:7d05:f73f:4dd5
    2024-06-15 09:38:13.248  - info: host.Pi-Strom-Wasser connected to Objects and States
    2024-06-15 09:38:13.303  - info: host.Pi-Strom-Wasser Node.js version has changed from 18.20.2 to 18.20.3
    2024-06-15 09:38:13.326  - info: host.Pi-Strom-Wasser added notifications configuration of host
    2024-06-15 09:38:13.351  - info: host.Pi-Strom-Wasser Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2024-06-15 09:38:15.097  - info: host.Pi-Strom-Wasser 90 instances found
    2024-06-15 09:38:15.191  - info: host.Pi-Strom-Wasser starting 2 instances
    2024-06-15 09:38:15.551  - info: host.Pi-Strom-Wasser instance system.adapter.smartmeter.1 started with pid 1757
    2024-06-15 09:38:19.523  - info: host.Pi-Strom-Wasser instance system.adapter.mbus.0 started with pid 1764
    2024-06-15 09:38:22.437  - info: smartmeter.1 (1757) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.20.3, js-controller: 5.0.19
    2024-06-15 09:38:23.711  - info: smartmeter.1 (1757) Received 10 values, 10 updated
    2024-06-15 09:38:25.325  - info: mbus.0 (1764) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.mbus, node: v18.20.3, js-controller: 5.0.19
    2024-06-15 09:38:25.408  - info: mbus.0 (1764) Default Update Interval: 900
    2024-06-15 09:38:25.411  - info: mbus.0 (1764) Initialize M-Bus Serial to /dev/lesewasser with 115200baud
    2024-06-15 09:38:25.418  - info: mbus.0 (1764) Schedule initialization for M-Bus-ID 17834338B4090107 with update interval 900
    @bahnuhr sagte in slave start nicht mehr nach nodejs-update 20:
    immerhin, und damit
    Kernel : armv7l
    aber wie befürchtet
    und dafür gibt es kein node20 mehr
      immerhin, und damit
      Kernel : armv7l
      aber wie befürchtet
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      War der Raspi wo wir vor 5 jahren (oder so; am Anfang von smartmeter) rum probiert hatten, dass wir die Verbindung zum smartmeter und mbus hin bekommen.
      hatten wir damals extra noch ne rules geschrieben um die id korrekt zuzuweisen.
      sowas damals:
      SUBSYSTEM=="tty", ATTRS{product}=="FT232R USB UART", ATTRS{serial}=="AH06GH5Y", SYMLINK+="lesestrom"
      SUBSYSTEM=="tty", ATTRS{product}=="FT232R USB UART", ATTRS{serial}=="AH06GH5Z", SYMLINK+="lesevoltaik"
      SUBSYSTEM=="tty", ATTRS{product}=="FT232R USB UART", ATTRS{serial}=="A907T3PS", SYMLINK+="lesewasser"
      Mittlerweile müsste smartmeter dies ja auslesen können.
      @Thomas-Braun
      Und deshalb hatte ich dies bisher nicht geändert.
      Aber jetzt hab ich ja einen Grund.
      Danke.
      • bahnuhrB bahnuhr
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        dieter
        HOME=/home/dieter
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           99M          0B         99M
                  923 M total memory
                  126 M used memory
                  345 M active memory
                  128 M free memory
                  175 M buffer memory
                  493 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        1.5G    /var/
        1.3G    /var/cache/apt
        1.3G    /var/cache
        93M     /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.13.16
        Adapter State
        + instance is alive
        Objects and States
        Objects:        27223
        States:         22733
        Pending Updates: 0
        Dann installier da jetzt neu ein reines 64Bit-System.
        Und die Spannungsversorgung und die Kühlung würde ich mir auch anschauen:
        • bahnuhrB bahnuhr
          sowas damals:
          @Thomas-Braun
          @bahnuhr nimm ne neue Karte und spiel den Bücherwurm drauf.
          iobroker ohne jeden Adapter
          Dann koppeln.
          Wenn's schief geht hast du noch die alte Karte.
            Dann koppeln.
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @homoran sagte in slave start nicht mehr nach nodejs-update 20:
            Dann koppeln.
            yes, genau das war auch meine Idee eben.
            Danke.
            • bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              So, neue SD funktioniert.
              bookworm ist installiert.
              Nun klappt multihost nicht.
              Wie immer nach folgender Anleitung:
              https://www.iobroker.net/#de/documentation/config/multihost.md
              Beim Master kommt:
              Beim Slave kommt:
              Jemand eine Idee ?
              Danke.
              • bahnuhrB bahnuhr
                Beim Master kommt:
                Beim Slave kommt:
                Jemand eine Idee ?
                Jemand eine Idee ?
                Viele!
                gleiche Datenbank?
                jsonl, redis, file?
                selber Hostname beim slave?
                beide Hosts neu gestartet?
                iob setup custom probiert?
                  Jemand eine Idee ?
                  Viele!
                  gleiche Datenbank?
                  jsonl, redis, file?
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  Danke Rainer.
                  gleiche Datenbank?
                  ja, beide jsonl
                  natürlich nicht.
                  slave hat: stromwasser
                  natürlich
                  Ja, siehe oben.
                  nach dieser Anleitung:
                  Danke.
                  • bahnuhrB bahnuhr
                    Danke Rainer.
                    gleiche Datenbank?
                    ja, beide jsonl
                    natürlich nicht.
                    natürlich
                    Ja, siehe oben.
                    natürlich nicht.
                    sorry! Frage war nicht exakt.
                    Selber Name wie vorher?
                    Ja, siehe oben.
                    ich finde den output dazu nicht (als text in code-tags 😁 )
                    • bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      jetzt wird es merkwürdig.
                      Wenn ich auf dem slave eingebe, kommt:
                      dieter@stromwasser:~ $ iob multihost browse
                      No Multihost server found. Make sure iobroker is running on the host where you enabled multihost discovery (and it is not this host)!
                      Wenn ich bei meinem master auf host gehe, sehe ich den neuen aber:
                      stromwasser ist der neue.
                      PI-Strom-Wasser der alte.
                      Frage:
                      Warum wird bei iob multihost browse dies nicht angezeigt ?
                      Danke.
                      • bahnuhrB bahnuhr
                        Frage:
                        also nicht der selbe Hostname!
                        Abgesehen davon dass ich das nicht mag, weil ich nicht sehe was da passiert:
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          Ja, und was sagt mir das jetzt.
                          Na klar läuft iob auf dem host und auch auf dem master. Ich verstehe diese Satz nicht wirklich.
                          Danke.
                          • bahnuhrB bahnuhr
                            Na klar läuft iob auf dem host.
                            auf dem Master, auf dem auch hoffentlich noch das multihost enable aktiv ist.
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              Ja, ist es.
                              Multihost discovery server: enabled
                              Discovery authentication:   enabled
                              Persistent activation:      disabled
                              Objects:                    jsonl on 0.0.0.0
                              States:                     jsonl on 0.0.0.0
                              Danke.
                              • bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                @Homoran
                                @Thomas-Braun
                                So, mal Rückinfo von mir.
                                bookworm installiert nach der Anleitung von @Thomas-Braun
                                file:///Z:/iobroker/Installation%20_%20Update/Installation%20auf%20Raspi%20-%20Einfacher%20geht's%20nicht.html
                                Dies hat geklappt und dann iob installiert.
                                Erst war der host ein anderer. Dann wieder alles neu. Passt.
                                Aber multihost klappt nicht mehr mit nodejs 20
                                Es kommt immer o.g. Fehler. Im master bei hosts wird der slave grün dargestellt. Aber mbus und auch smartmeter lesen den slave nicht mehr aus. Die angeschlossenen Geräte werden in der Instanz nicht angezeigt.
                                Fazit für mich:
                                Ich bekomme es nicht hin und habe die nodejs18 SD wieder rein getan.
                                i.S. von Thomas: never change hat zumindest aktuell für mich dann doch wieder Sinn.
                                Weil ich es einfach nicht hinbekomme.
                                Vielleicht könnte das ja mal jemand mit mehr know how mal testen.
                                mfg
                                Dieter
                                Danke.
                                • bahnuhrB bahnuhr
                                  @Homoran
                                  @Thomas-Braun
                                  Fazit für mich:
                                  mfg
                                  Dieter
                                  und wo kam dann dein neuer Host stromwasser her?
                                  Da muss die Kopplung doch geklappt haben.
                                  Der war doch grün.
                                  Weil du einen andeten Hostmnamen nutzst!
                                  Dann musst du die Instanzen diesem neuen Host zuordnen.
                                  Deswegen solltest du ja den selben Hostnamen verwenden
                                  bahnuhrB 2 Antworten Letzte Antwort
                                    Der war doch grün.
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    Rainer, das hab ich alles durch.
                                    Wie geschrieben hab ich nochmal alles neu gemacht.
                                    und dann mit dem richtigen host.
                                    Auch das klappte nicht.
                                    Danke.
                                      Der war doch grün.
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      Hab sogar das backup vom master von heute nacht eingespielt.
                                      Daten von heute sind nun weg.
                                      Aber mit nodejs20 geht es nicht.
                                      Alte SD beim slave rein; und alles läuft.
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        Es gibt mit Sicherheit einige, die auch mit nodejs@20 einen solchen Verbund von zwei Systemen betreiben.
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          @thomas-braun sagte in slave start nicht mehr nach nodejs-update 20:
                                          Ja, das mag sein.
                                          Nur ich bekomme es halt nicht hin.
                                          Und deshalb bleibt es nun bei dem "never change" System.
                                          Halte ich grundsätzlich auch für falsch. Aber es klappt halt nicht.
                                          Danke.
