  4. Restlaufzeit Shelly Plug S
    5.8k
36 Beiträge 8 Kommentatoren 4.7k Aufrufe 6 Beobachtet
  • E Erich 1
      <variables>
        <variable id="`3-s]Pi^V2d8N9J-76fO">Rest</variable>
        <variable type="interval" id="Intervall">Intervall</variable>
      </variables>
      <block type="on" id=".0K53IaR?_D^E^0Qr5}A" x="63" y="88">
        <field name="OID">shelly.0.SHPLG-S#DDB4D9#1.Relay0.Switch</field>
        <field name="CONDITION">gt</field>
        <statement name="STATEMENT">
          <block type="variables_set" id="=VB)QX`VIsFqa?%dv*/+">
            <field name="VAR" id="`3-s]Pi^V2d8N9J-76fO">Rest</field>
            <value name="VALUE">
              <block type="math_arithmetic" id="eS{QUa6y@lfj^#6,Oh#m">
                <field name="OP">MULTIPLY</field>
                <value name="A">
                  <shadow type="math_number" id="7nK#jz~d3KX?o]fQ:M/w">
                    <field name="NUM">10</field>
                  </shadow>
                </value>
                <value name="B">
                  <shadow type="math_number" id="K~b;$sQw#)NjQwQh`Aw.">
                    <field name="NUM">1</field>
                  </shadow>
                  <block type="get_value" id="P$3Tge$tbi#ee:DJmDR2">
                    <field name="OID">0_userdata.0.Datenpunkte.Gartenpumpe.Laufzeit</field>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="timeouts_setinterval" id="OIwHQs|PCd5#%oEjIa7K">
                <field name="NAME">Intervall</field>
                <field name="INTERVAL">6</field>
                  <block type="math_change" id="s;cX%Jh7wG?9Q!7Jqy=;">
                    <value name="DELTA">
                      <shadow type="math_number" id="Uivu%JL?GZJ%KmTMlk7;">
                        <field name="NUM">-1</field>
                      </shadow>
                    </value>
                    <next>
                      <block type="update" id="7t(p,Syit;%jem/{G5!j">
                        <field name="OID">0_userdata.0.Datenpunkte.Gartenpumpe.Restminuten</field>
                          <block type="math_arithmetic" id="]3]MzdqtYE0:d;}ou0b-">
                            <field name="OP">DIVIDE</field>
                            <value name="A">
                              <shadow type="math_number" id="1yb@9@Vr^BR+-y4E?QsB">
                              </shadow>
                              <block type="variables_get" id="!~y2XoKP0yV0OQyK8pTw">
                              </block>
                            </value>
                            <value name="B">
                              <shadow type="math_number" id="|nHD{4P4Q+|Wekr{5[Sj">
                              </shadow>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="controls_if" id="oVv#NBAx]^NjD$#isELN">
                            <value name="IF0">
                              <block type="logic_compare" id="r/.r#tf.+]ku0qZxOpfa">
                                <field name="OP">LT</field>
                                <value name="A">
                                  <block type="variables_get" id=".3XFGd.-1ZO~#./41o^v">
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="math_number" id="VeJQlK+PMZ4{+In3D*Cc">
                                    <field name="NUM">0</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <statement name="DO0">
                              <block type="timeouts_clearinterval" id=".Swg1BM$Y*6{hK:7giFF">
                                <next>
                                  <block type="control" id="zv)}0mRZW|7pJKeJD(5w">
                                      <block type="logic_boolean" id="6,b[sF=en3kx5ZbgERlr">
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    HomoranH Offline
    HomoranH Offline
    @erich-1
    Das hier
    sieht irgendwie ganz anders aus als das
    E 1 Antwort Letzte Antwort
      @erich-1
      Das hier
      Erich 1
      • E Erich 1
        HomoranH Offline
        HomoranH Offline
        @erich-1 wie weit zählt er ins negstive?
        dein Vergleichsoperator stimmt nicht ganz
          Erich 1
          @homoran Ich lass ihn mal laufen. Aber auch wenn der Shelly vor dem Ablauf der vorgegebenen Zeit ausgeschaltet wird, dann läuft der Zähler ebenso weiter und dann eben auch in den Bereich unter 0.
          • E Erich 1
            HomoranH Offline
            HomoranH Offline
            @erich-1 sagte in Restlaufzeit Shelly Plug S:
            Davon war ja auch nie die Rede, dass das abgefangen werden soll.
            so steht es ja auch in deinem Blockly
              Erich 1
              @homoran Ja, das kann ich mir schon vorstellen. Aber den Fehler zu lokalisieren, ist für mich doch noch eine Herausforderung.
              • E Erich 1
                HomoranH Offline
                HomoranH Offline
                deswegen hab ich ihn dir ja genannt;
                @homoran sagte in Restlaufzeit Shelly Plug S:
                  Erich 1
                  @homoran Im Moment sagt er -5,9 Minuten und ein Ende ist nicht in Sicht. er zählt vermutlich ewig weiter.
                  Da stehe ich doch noch irgendwie auf dem Schlauch. So fit in den Blocklys bin ich dann doch noch nicht.
                  • E Erich 1
                    HomoranH Offline
                    HomoranH Offline
                    das wundert mich allerdings!
                    hiernach
                    darf er bis -0.1 gehen.
                    was genau hast du gemacht?
                    wie sehen die beiden Datenpunkte Laufzeit und Restminuten aus?
                    • E Erich 1
                      @erich-1 sagte: Im Moment sagt er -5,9 Minuten und ein Ende ist nicht in Sicht.
                      Wenn während der Laufzeit erneut aus- und wieder eingeschaltet wird, laufen mehrere Intervalle, die nicht gestoppt werden können. Um das zu verhindern, setze als ersten Befehl im Trigger zusätzlich ein "stop zyklische Ausführung Intervall".
                        Erich 1
                        schrieb am zuletzt editiert von Erich 1
                        So klappt es auch noch nicht, es wird nach wie vor weitergezählt ...
                        Aber er hört bei -0,1 auf !!!
                        paul53P HomoranH 2 Antworten Letzte Antwort
                          hiernach
                          Erich 1
                          @homoran said in Restlaufzeit Shelly Plug S:
                          Da mache ich am Abend weiter, jetzt muss ich dann weg ...
                          • E Erich 1
                            @erich-1 sagte: er hört bei -0,1 auf
                            Er hört bei 0 auf, wenn der Vergleich geändert wird in
                            falls Rest <= 0
                            • E Erich 1
                              HomoranH Offline
                              HomoranH Offline
                              Nichts nachträglich hinzufügen, auch nicht wenn es das ist, was ich die ganze Zeit sage;
                              hiernach
                              • E Erich 1
                                @erich-1 sagte: wenn der Shelly vor dem Ablauf der vorgegebenen Zeit ausgeschaltet wird, dann läuft der Zähler ebenso weiter
                                Soll er dann stehen bleiben? Dann müsste auf "wurde geändert" getriggert werden und "falls Wert" geprüft werden.
                                  HomoranH Offline
                                  HomoranH Offline
                                  @paul53 ...und im sonst wird die Restzeit auf 0 gesetzt und das Intervall gestoppt.
                                    @homoran sagte: ...und im sonst wird die Restzeit auf 0 gesetzt
                                    Das ist hier die Frage: Soll die Restanzeige beim vorzeitigen Ausschalten stehen bleiben oder auf 0 gesetzt werden?
                                      Erich 1
                                      @paul53 Wenn die Restlaufzeit auf 0 gesetzt werden könnte, wenn der Shelly vorzeitig ausgeschaltet wird, wäre das natürlich ideal.
                                      • E Erich 1
                                        @erich-1 sagte: Restlaufzeit auf 0 gesetzt werden könnte, wenn der Shelly vorzeitig ausgeschaltet wird
                                          Erich 1
                                          @paul53 Funktioniert hervorragend. Vielen Dank an alle Helfer!
