  4. JavaScript
  5. ecoflow-connector-Script zur dynamischen Leistungsanpassung
    6.3k
1.7k Beiträge 124 Kommentatoren 938.5k Aufrufe 127 Beobachtet
  • A aherby
    @foxthefox Ja ist seit dem iOS-App Update, Frimware und WLAN Update vom Powerstream vorhanden.
    Heißt in der App Maximale Ausgangsleistung und ist einstellbar aktuell von 400 W stufenlos bis auf 800 W.
    Weitere Werte:
    warn: javascript.0 (61576) script.js.Echoflow.Ecoflow_DYM_Script_1_2_5.Ecoflow_DYM_Script_1_2_5: Nicht definierter cmd_func-Wert. [Homestation] cmdId:146 cmdFunc:20
    2024-06-04 23:58:55.206 - info: javascript.0 (61576) script.js.Echoflow.Ecoflow_DYM_Script_1_2_5.Ecoflow_DYM_Script_1_2_5: hexString: 0a3d0a0308cc031020181420012801380340144892015003580170bbb891aa06800113880101ba0103696f73ca0110485735315a4f48345346355434363434
    2024-06-04 23:58:55.206 - info: javascript.0 (61576) script.js.Echoflow.Ecoflow_DYM_Script_1_2_5.Ecoflow_DYM_Script_1_2_5: Nachricht: {"header":[{"pdata":"08cc03","src":32,"dest":20,"dSrc":1,"dDest":1,"checkType":3,"cmdFunc":20,"cmdId":146,"dataLen":3,"needAck":1,"seq":1698978875,"version":19,"payloadVer":1,"from":"ios","deviceSn":"HW51ZOH4SF5T4644"}]}
    2024-06-04 23:59:02.802 - warn: javascript.0 (61576) script.js.Echoflow.Ecoflow_DYM_Script_1_2_5.Ecoflow_DYM_Script_1_2_5: Nicht definierter cmd_func-Wert. [Homestation] cmdId:146 cmdFunc:20
    2024-06-04 23:59:02.802 - info: javascript.0 (61576) script.js.Echoflow.Ecoflow_DYM_Script_1_2_5.Ecoflow_DYM_Script_1_2_5: hexString: 0a3d0a030894051020181420012801380340144892015003580170c9f391aa06800113880101ba0103696f73ca0110485735315a4f48345346355434363434
    2024-06-04 23:59:02.802 - info: javascript.0 (61576) script.js.Echoflow.Ecoflow_DYM_Script_1_2_5.Ecoflow_DYM_Script_1_2_5: Nachricht: {"header":[{"pdata":"089405","src":32,"dest":20,"dSrc":1,"dDest":1,"checkType":3,"cmdFunc":20,"cmdId":146,"dataLen":3,"needAck":1,"seq":1698986441,"version":19,"payloadVer":1,"from":"ios","deviceSn":"HW51ZOH4SF5T4644"}]}
    2024-06-04 23:59:11.570 - warn: javascript.0 (61576) script.js.Echoflow.Ecoflow_DYM_Script_1_2_5.Ecoflow_DYM_Script_1_2_5: Nicht definierter cmd_func-Wert. [Homestation] cmdId:146 cmdFunc:20
    2024-06-04 23:59:11.570 - info: javascript.0 (61576) script.js.Echoflow.Ecoflow_DYM_Script_1_2_5.Ecoflow_DYM_Script_1_2_5: hexString: 0a3d0a0308a006102018142001280138034014489201500358017098b892aa06800113880101ba0103696f73ca0110485735315a4f48345346355434363434
    2024-06-04 23:59:11.570 - info: javascript.0 (61576) script.js.Echoflow.Ecoflow_DYM_Script_1_2_5.Ecoflow_DYM_Script_1_2_5: Nachricht: {"header":[{"pdata":"08a006","src":32,"dest":20,"dSrc":1,"dDest":1,"checkType":3,"cmdFunc":20,"cmdId":146,"dataLen":3,"needAck":1,"seq":1698995224,"version":19,"payloadVer":1,"from":"ios","deviceSn":"HW51ZOH4SF5T4644"}]}
    W Offline
    W Offline
    Waly_de
    schrieb am zuletzt editiert von Waly_de
    #1292
    @aherby da du die neue firmware hast. Kannst du bitte mal nachsehen, ob der eingestellte Wert anschließend unter den Objekten an der Stelle:
     0_userdata.0.ecoflow.app_device_property_XXXXXXXX.data.InverterHeartbeat.ratedPower
    Zu finden ist?
    P A 2 Antworten Letzte Antwort
    • F foxthefox
      @ponti92 sagte in ecoflow-connector-Script zur dynamischen Leistungsanpassung:
      @ponti92
      Nach kurzen Tests ist die Logik des Verhaltens leider noch falsch, da die Leistung des Shelly 3ems wie ein smartplug behandelt wird. Dadurch werden im geregelten Fall nur die Hälfte des Hausverbrauchs eingespeist.
      Wieso nur die Hälfte des Hausverbrauchs? Es müsste sich doch wie eine ganz normale Last verhalten und dann die 600(800)W ausnutzen?!
      Könntest du den Befehl (0->1, 1->0) mitloggen und posten (ich meine den HEX-string)?
      Theoretisch müsste es dann auch einen neuen Datenpunkt im Telegramm vom powerstream drin sein, wenn also möglich auch das mal posten.
      Ponti92
      #1293
      @foxthefox Weil der immer die Last einstellt, die am Shelly 3em anzeigt, einstellt. Bei manchen springt es auch von kompletter Deckung des Hausbedarfs (shelly = 0W) zu 100-200W Grundbedarf.
      Da ja der Shelly normalerweise den Gesamtverbrauch des Hauses misst, darf Ecoflow da nicht die Daten so behandeln wie einen Smartplug. Das tun sie aber zurzeit und dann kann es entweder hin und her pendeln, oder wie bei mir sich bei der Hälfte des Verbrauchs einpendeln.
      Z.b. Shelly zeigt 80W an, Ecoflow speist 80W ein, da einfach der Wert vom Shelly übernommen wird. Grundlast ist aber 160W, sprich Ecoflow kann nur die Hälfte der geforderten Leistung bedienen.
      Bei manchen springt es herum, wahrscheinlich am Anfang und bei wechselnden Lastspitzen.
      Sagen wir du verbrauchst 200W und Ecolfow speist noch nichts ein. Dann startet die App und Ecoflow sieht die 200W am Shelly und stellt diese ein. Nun werden aber von den 200W die Einspeiseleistung von Ecoflow (~ 200W) abgezogen und der Shelly sieht theoretisch +-0W. Diesen Wert nimmt Ecoflow wieder und schaltet die Einspeisung womöglich aus. Und so schaukelt der Wert hin und her.
      Hier ist das log als ich es eingeschaltet habe:
      09:37:42.516	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a7d0a5270068801d51e9801de02a8018e03b001901fc001de02e801c4faffffffffffffff01b002008003a006880300f003bc05f803a0068004008804009004a0069804a006a00407900500e80605b808a1ffffff0f10351820200128014014480150525801800103880103ca0110485735315a4f48345346364c31353736
      09:37:42.558	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"llcStatue":6,"pv1OpVolt":3925,"pv1InputWatts":350,"pv2InputVolt":398,"pv2OpVolt":3984,"pv2InputWatts":350,"batInputWatts":-700,"invOutputWatts":0,"permanentWatts":800,"dynamicWatts":0}}}
      09:37:42.697	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a80010a558001a2028801d7169801de02b0018d17c001ca02e801d8faffffffffffffff01b002008003f805880300f003a805f803f8058004008804009004f8059804f805a00407d004f8b821900500e8060bb808a1ffffff0f10351820200128014014480150555801800103880103ca0110485735315a4f48345346355435353130
      09:37:42.728	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1InputVolt":290,"pv1OpVolt":2903,"pv1InputWatts":350,"pv2OpVolt":2957,"pv2InputWatts":330,"batInputWatts":-680,"invOutputWatts":0,"permanentWatts":760,"dynamicWatts":0}}}
      09:37:44.477	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a7e0a5370058801fd1e9801e802b001f61ec001d402e801c4faffffffffffffff01b002008003a006880300f003bc05f803a0068004008804009004a0069804a006a00407d0048ee520900500e80610b808a1ffffff0f10351820200128014014480150535801800103880103ca0110485735315a4f48345346364c31353736
      09:37:44.553	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"llcStatue":5,"pv1OpVolt":3965,"pv1InputWatts":360,"pv2OpVolt":3958,"pv2InputWatts":340,"batInputWatts":-700,"invOutputWatts":0,"permanentWatts":800,"dynamicWatts":0}}}
      09:37:44.601	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a770a4c8801eb169801de02b001a917c001ca02e801d8faffffffffffffff01b002008003f805880300f003a805f803f8058004008804009004f8059804f805a00407900500e80610b808a1ffffff0f103518202001280140144801504c5801800103880103ca0110485735315a4f48345346355435353130
      09:37:44.649	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2923,"pv1InputWatts":350,"pv2OpVolt":2985,"pv2InputWatts":330,"batInputWatts":-680,"invOutputWatts":0,"permanentWatts":760,"dynamicWatts":0}}}
      09:37:46.493	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a770a4c8801911f9801c002b001e31ec001fc02e801c4faffffffffffffff01b002008003a006880300f003bc05f803a0068004008804009004a0069804a006a00407900500e80604b808a1ffffff0f103518202001280140144801504c5801800103880103ca0110485735315a4f48345346364c31353736
      09:37:46.517	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":3985,"pv1InputWatts":320,"pv2OpVolt":3939,"pv2InputWatts":380,"batInputWatts":-700,"invOutputWatts":0,"permanentWatts":800,"dynamicWatts":0}}}
      09:37:46.630	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a81010a568801ff169801c002b001bd17c001e802e801d8faffffffffffffff01b002008003f805880300f003a805f803f8058004008804009004f8059804f805a00407d0048cb921d804b2c301900500e80604b808a1ffffff0f10351820200128014014480150565801800103880103ca0110485735315a4f48345346355435353130
      09:37:46.656	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2943,"pv1InputWatts":320,"pv2OpVolt":3005,"pv2InputWatts":360,"batInputWatts":-680,"invOutputWatts":0,"permanentWatts":760,"dynamicWatts":0}}}
      09:37:47.005	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510: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
      09:37:47.007	info	javascript.0 (21466) script.js.Ecoflow1_2_5: JSON-Nachricht empfangen:/app/device/property/R351ZEB4HF450475:{"addr":0,"cmdFunc":0,"cmdId":0,"id":1742357130892412700,"version":"1.0","timestamp":1717573066,"moduleType":"2","params":{"bms_kitInfo.watts":[{"appState":1,"curPower":-68,"appVer":83886814,"f32Soc":0,"soc":0,"avaFlag":1,"sn":"HW51ZOH4SF5T5510","detail":1,"type":75,"loadVer":83886338},{"appState":0,"curPower":0,"appVer":0,"f32Soc":0,"soc":0,"avaFlag":0,"sn":"","detail":0,"type":0,"loadVer":0}]}}
      09:37:47.115	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:37:48.458	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a80010a558801d51e9801de02a8018703b001cf1ec001de02e801c4faffffffffffffff01b002008003a006880300f003bc05f803a0068004008804009004a0069804a006a00407d004b2e320900500e80600b808a1ffffff0f10351820200128014014480150555801800103880103ca0110485735315a4f48345346364c31353736
      09:37:48.556	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":3925,"pv1InputWatts":350,"pv2InputVolt":391,"pv2OpVolt":3919,"pv2InputWatts":350,"batInputWatts":-700,"invOutputWatts":0,"permanentWatts":800,"dynamicWatts":0}}}
      09:37:48.695	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a81010a568801eb169801de02b001a917c001ca02e801d8faffffffffffffff01b002008003f805880300f003a805f803f8058004008804009004f8059804f805a00407d004eeb821d804eac101900500e80600b808a1ffffff0f10351820200128014014480150565801800103880103ca0110485735315a4f48345346355435353130
      09:37:48.750	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2923,"pv1InputWatts":350,"pv2OpVolt":2985,"pv2InputWatts":330,"batInputWatts":-680,"invOutputWatts":0,"permanentWatts":760,"dynamicWatts":0}}}
      09:37:48.797	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a80030ad20208ffff0312240880d5feb20610011a1a48486bca02bd011500000000000000000000000000000000000012220880d5feb20610021a1800000000000000000000000000000000000000000000000012220880d5feb20610031a180000000000253d290000000000000000000000000000000012240880d5feb20610041a1a494a6ed302b7011100000000000000000000000000000000000012220880d5feb20610071a180000000004131d130000000000000000000000000000000012220880d5feb20610081a180000000004151f160000000000000000000000000000000012240880d5feb20610101a1a48486bca02bc011500000000000000000000000000000000000012240880d5feb20610111a1a484a6bcb02bd014722350000000000000000000000000000000012240880d5feb20610121a1a484a6bcb02bd0147223500000000000000000000000000000000103518202001280140fe01482050d2025801800103880103ca0110485735315a4f48345346364c31353736
      09:37:48.847	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:37:50.495	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a740a498801e91e9801de02b001bb1ec001de02e801c4faffffffffffffff01b002008003a006880300f003bc05f803a0068004008804009004a0069804a006a00407900500b808a1ffffff0f10351820200128014014480150495801800103880103ca0110485735315a4f48345346364c31353736
      09:37:50.521	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":3945,"pv1InputWatts":350,"pv2OpVolt":3899,"pv2InputWatts":350,"batInputWatts":-700,"invOutputWatts":0,"permanentWatts":800,"dynamicWatts":0}}}
      09:37:50.593	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a7d0a528801d7169801de02a801a402b001ed16c001ca02e801d8faffffffffffffff01b002008003f805880300f003a805f803f8058004008804009004f8059804f805a00407d0048cb921900500b808a1ffffff0f10351820200128014014480150525801800103880103ca0110485735315a4f48345346355435353130
      09:37:50.625	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2903,"pv1InputWatts":350,"pv2InputVolt":292,"pv2OpVolt":2925,"pv2InputWatts":330,"batInputWatts":-680,"invOutputWatts":0,"permanentWatts":760,"dynamicWatts":0}}}
      09:37:52.540	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a7a0a4f70068801d41e9801de02b001d61ec001de02e801c4faffffffffffffff01b00200800300880300f003bc05f80300800400880400900400980400a00407d0048ee520900500e8060eb808a1ffffff0f103518202001280140144801504f5801800103880103ca0110485735315a4f48345346364c31353736
      09:37:52.573	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"llcStatue":6,"pv1OpVolt":3924,"pv1InputWatts":350,"pv2OpVolt":3926,"pv2InputWatts":350,"batInputWatts":-700,"invOutputWatts":0,"permanentWatts":0,"dynamicWatts":0}}}
      09:37:52.651	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a81010a568801eb169801c002b0018117c001e802e801d8faffffffffffffff01b002008003f805880300f003a805f803f8058004008804009004f8059804f805a00407d00482b921d804b2c301900500e80607b808a1ffffff0f10351820200128014014480150565801800103880103ca0110485735315a4f48345346355435353130
      09:37:52.743	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2923,"pv1InputWatts":320,"pv2OpVolt":2945,"pv2InputWatts":360,"batInputWatts":-680,"invOutputWatts":0,"permanentWatts":760,"dynamicWatts":0}}}
      09:37:54.487	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a7b0a5070058801e81e9801de02b001c21ec001de02e801c4faffffffffffffff01b00200800300880300f003bc05f80300800400880400900400980400a00407e00405900500a80500e80610b808a1ffffff0f10351820200128014014480150505801800103880103ca0110485735315a4f48345346364c31353736
      09:37:54.517	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"llcStatue":5,"pv1OpVolt":3944,"pv1InputWatts":350,"pv2OpVolt":3906,"pv2InputWatts":350,"batInputWatts":-700,"invOutputWatts":0,"permanentWatts":0,"dynamicWatts":0}}}
      09:37:54.600	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a83010a588801d7169801c002b0019b17c001e802e801d8faffffffffffffff01b00200800300880300f003a805f80300800400880400900400980400a00407d004aab921d804eac101e00405900500a80500e80614b808a1ffffff0f10351820200128014014480150585801800103880103ca0110485735315a4f48345346355435353130
      09:37:54.677	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2903,"pv1InputWatts":320,"pv2OpVolt":2971,"pv2InputWatts":360,"batInputWatts":-680,"invOutputWatts":0,"permanentWatts":0,"dynamicWatts":0}}}
      09:37:55.580	info	javascript.0 (21466) script.js.Ecoflow1_2_5: SetBasePower !
      09:37:55.666	info	javascript.0 (21466) script.js.Ecoflow1_2_5: otherPS (PSonly): 0
      09:37:55.677	info	javascript.0 (21466) script.js.Ecoflow1_2_5: otherPS (all): 81.94
      09:37:55.678	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Gap_Durchschnitt: PS:[PowerStream] : 0
      09:37:55.678	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Gap_Durchschnitt: PS:[PowerStream2] : 0
      09:37:55.679	info	javascript.0 (21466) script.js.Ecoflow1_2_5: *************************************
      09:37:55.679	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Hausstrom: 213.33
      09:37:55.680	info	javascript.0 (21466) script.js.Ecoflow1_2_5: lowestValue Realpower: 259
      09:37:55.680	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Lastcutoff: 0
      09:37:55.680	info	javascript.0 (21466) script.js.Ecoflow1_2_5: gapSumme: 0
      09:37:55.681	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Bedarf : 167.06
      09:37:55.681	info	javascript.0 (21466) script.js.Ecoflow1_2_5: PStotalPV (+10 W/PS): 152
      09:37:55.682	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Gobal totalPV: 216
      09:37:55.682	info	javascript.0 (21466) script.js.Ecoflow1_2_5: PVBedarf : 152
      09:37:55.682	info	javascript.0 (21466) script.js.Ecoflow1_2_5: BatBedarf: 15
      09:37:55.683	info	javascript.0 (21466) script.js.Ecoflow1_2_5: PVfaktor:1
      09:37:55.683	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Batfaktor:1.1538461538461537
      09:37:55.684	info	javascript.0 (21466) script.js.Ecoflow1_2_5: ueberschuss:0
      09:37:55.684	info	javascript.0 (21466) script.js.Ecoflow1_2_5: *************************************
      09:37:55.716	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Änderung für Einspeisung gesendet PS:[PowerStream] : 75 W
      09:37:55.740	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Änderung für Einspeisung gesendet PS:[PowerStream2] : 71 W
      09:37:55.757	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Die MQTT-Nachricht wurde erfolgreich veröffentlicht.
      09:37:55.758	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Die MQTT-Nachricht wurde erfolgreich veröffentlicht.
      09:37:55.764	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF6L1576/thing/property/set:0a3d0a0308ee051020183520012801380340144881015003580170e485d5ba0e800113880101ba0103696f73ca0110485735315a4f48345346364c31353736
      09:37:55.765	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF5T5510/thing/property/set:0a3d0a0308c60510201835200128013803401448810150035801708586d5ba0e800113880101ba0103696f73ca0110485735315a4f48345346355435353130
      09:37:55.796	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"setValue":{"value":750}}}
      09:37:55.829	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"setValue":{"value":710}}}
      09:37:56.528	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a780a4d8801d41e9801de02b001d61ec001de02e801c4faffffffffffffff01b00200800300880300f003bc05f80300800400880400900400980400a00407d004b2e320900500e8060eb808a1ffffff0f103518202001280140144801504d5801800103880103ca0110485735315a4f48345346364c31353736
      09:37:56.553	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":3924,"pv1InputWatts":350,"pv2OpVolt":3926,"pv2InputWatts":350,"batInputWatts":-700,"invOutputWatts":0,"permanentWatts":0,"dynamicWatts":0}}}
      09:37:56.647	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a790a4e9801de02b0018717c001d402e801cefaffffffffffffff01b00200800300880300f003b205f80300800400880400900400980400a00407d004a0b921d804a8c301900500e8060eb808a1ffffff0f103518202001280140144801504e5801800103880103ca0110485735315a4f48345346355435353130
      09:37:56.703	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1InputWatts":350,"pv2OpVolt":2951,"pv2InputWatts":340,"batInputWatts":-690,"invOutputWatts":0,"permanentWatts":0,"dynamicWatts":0}}}
      09:37:57.040	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510: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
      09:37:57.060	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:37:57.726	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Die MQTT-Nachricht wurde erfolgreich veröffentlicht.
      09:37:57.727	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Die MQTT-Nachricht wurde erfolgreich veröffentlicht.
      09:37:57.728	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Die MQTT-Nachricht wurde erfolgreich veröffentlicht.
      09:37:57.729	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Die MQTT-Nachricht wurde erfolgreich veröffentlicht.
      09:37:57.730	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Die MQTT-Nachricht wurde erfolgreich veröffentlicht.
      09:37:57.736	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF6L1576/thing/property/get:0a0a1020182070c694d5ba0e
      09:37:57.738	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF6L1576/thing/property/get:0a0a1020182070c694d5ba0e
      09:37:57.739	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF6L1576/thing/property/get:0a0a1020182070c694d5ba0e
      09:37:57.740	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF6L1576/thing/property/set:0a3d0a0408c58801102018352001280138034020480b5004580170f494d5ba0e800113880101ba0103696f73ca0110485735315a4f48345346364c31353736
      09:37:57.740	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF5T5510/thing/property/get:0a0a10201820708495d5ba0e
      09:37:57.743	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF5T5510/thing/property/get:0a0a10201820708495d5ba0e
      09:37:57.744	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF5T5510/thing/property/get:0a0a10201820708495d5ba0e
      09:37:57.745	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/HW51ZOH4SF5T5510/thing/property/set:0a3d0a0408c58801102018352001280138034020480b5004580170c395d5ba0e800113880101ba0103696f73ca0110485735315a4f48345346355435353130
      09:37:57.767	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:37:57.786	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:37:57.811	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:37:57.827	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"setValue":{"value":17477}}}
      09:37:57.857	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:37:57.891	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:37:57.929	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:37:57.949	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"setValue":{"value":17477}}}
      09:37:58.501	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a83010a588801901f9801e802b001ea1ec001de02e801bafaffffffffffffff01b0020080039008880300f003c605f80390088004008804009004900898049008a00407d0048ee520e00404900500a805f403e80600b808a1ffffff0f10351820200128014014480150585801800103880103ca0110485735315a4f48345346364c31353736
      09:37:58.526	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":3984,"pv1InputWatts":360,"pv2OpVolt":3946,"pv2InputWatts":350,"batInputWatts":-710,"invOutputWatts":0,"permanentWatts":1040,"dynamicWatts":0}}}
      09:37:58.633	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a85010a5a70068801eb169801de02b001f316c001d402e801cefaffffffffffffff01b0020080039008880300f003b205f80390088004008804009004900898049008a00407d004f8b821e00404900500a805f403e80600b808a1ffffff0f103518202001280140144801505a5801800103880103ca0110485735315a4f48345346355435353130
      09:37:58.676	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"llcStatue":6,"pv1OpVolt":2923,"pv1InputWatts":350,"pv2OpVolt":2931,"pv2InputWatts":340,"batInputWatts":-690,"invOutputWatts":0,"permanentWatts":1040,"dynamicWatts":0}}}
      09:37:58.784	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a80030ad20208ffff0312240880d5feb20610011a1a48486bca02bd011500000000000000000000000000000000000012220880d5feb20610021a1800000000000000000000000000000000000000000000000012220880d5feb20610031a180000000000253d290000000000000000000000000000000012240880d5feb20610041a1a494a6ed302b7011100000000000000000000000000000000000012220880d5feb20610071a180000000004131d130000000000000000000000000000000012220880d5feb20610081a180000000004151f160000000000000000000000000000000012240880d5feb20610101a1a48486bca02bc011500000000000000000000000000000000000012240880d5feb20610111a1a484a6bcb02bd014722350000000000000000000000000000000012240880d5feb20610121a1a484a6bcb02bd0147223500000000000000000000000000000000103518202001280140fe01482050d2025801800103880103ca0110485735315a4f48345346364c31353736
      09:37:58.855	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:38:00.455	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF6L1576:0a780a4d8801fc1e9801e802a8018d03b001fe1ec001de02e801bafaffffffffffffff01b0020080039008880300f003c605f80390088004008804009004900898049008a00407900500b808a1ffffff0f103518202001280140144801504d5801800103880103ca0110485735315a4f48345346364c31353736
      09:38:00.480	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":3964,"pv1InputWatts":360,"pv2InputVolt":397,"pv2OpVolt":3966,"pv2InputWatts":350,"batInputWatts":-710,"invOutputWatts":0,"permanentWatts":1040,"dynamicWatts":0}}}
      09:38:00.631	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/HW51ZOH4SF5T5510:0a770a4c70058801ff169801c002c001e802e801d8faffffffffffffff01b0020080039008880300f003a805f80390088004008804009004900898049008a00407d804b2c301900500b808a1ffffff0f103518202001280140144801504c5801800103880103ca0110485735315a4f48345346355435353130
      09:38:00.668	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"llcStatue":5,"pv1OpVolt":2943,"pv1InputWatts":320,"pv2InputWatts":360,"batInputWatts":-680,"invOutputWatts":0,"permanentWatts":1040,"dynamicWatts":0}}}
      09:38:01.888	info	javascript.0 (21466) Stop script script.js.Ecoflow1_2_5
      09:38:01.899	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Ecoflow MQTT-Client beendet
      Und hier beim Ausschalten:
      09:49:05.968	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a7b0a5080018e0388018a1f98018804b001ee1ec0019204e801e6f7ffffffffffffff01b002008003e204880300f0039a08f803e2048004008804009004e2049804e204a00407900500e80600b808a1ffffff0f10351820200128014014480150505801800103880103ca0110485735315a4f48345346364c31353736
      09:49:06.012	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1InputVolt":398,"pv1OpVolt":3978,"pv1InputWatts":520,"pv2OpVolt":3950,"pv2InputWatts":530,"batInputWatts":-1050,"invOutputWatts":0,"permanentWatts":610,"dynamicWatts":0}}}
      09:49:06.945	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a85010a5a8801fe169801f403b001ba17c0018804e80184f8ffffffffffffff01b0020080038005880300f003fc07f80380058004008804009004800598048005a00407d00496be21d804faf6019005009006ea35e80609b808a1ffffff0f103518202001280140144801505a5801800103880103ca0110485735315a4f48345346355435353130
      09:49:06.954	info	javascript.0 (21466) script.js.Ecoflow1_2_5: JSON-Nachricht empfangen:/app/device/property/R351ZEB4HF450475:{"addr":0,"cmdFunc":0,"cmdId":0,"id":1742362972390819300,"version":"1.0","timestamp":1717573746,"moduleType":"2","params":{"bms_kitInfo.watts":[{"appState":1,"curPower":-102,"appVer":83886814,"f32Soc":0,"soc":0,"avaFlag":1,"sn":"XXXXXXXXXXXXXXXXX","detail":1,"type":75,"loadVer":83886338},{"appState":0,"curPower":0,"appVer":0,"f32Soc":0,"soc":0,"avaFlag":0,"sn":"","detail":0,"type":0,"loadVer":0}]}}
      09:49:07.083	info	javascript.0 (21466) script.js.Ecoflow1_2_5: PowerStream [PowerStream] Batteriestand unter Limit:10% (8%). Limitiere Einspeiseleistung auf: 150W
      09:49:07.104	info	javascript.0 (21466) script.js.Ecoflow1_2_5: PowerStream [PowerStream2] Batteriestand unter Limit:10% (7%). Limitiere Einspeiseleistung auf: 150W
      09:49:07.159	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2942,"pv1InputWatts":500,"pv2OpVolt":3002,"pv2InputWatts":520,"batInputWatts":-1020,"invOutputWatts":0,"permanentWatts":640,"dynamicWatts":0}}}
      09:49:07.319	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Die MQTT-Nachricht wurde erfolgreich veröffentlicht.
      09:49:07.320	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Die MQTT-Nachricht wurde erfolgreich veröffentlicht.
      09:49:07.333	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/XXXXXXXXXXXXXXXXX/thing/property/set:0a3d0a0308ae0310201835200128013803401448810150035801709f84feba0e800113880101ba0103696f73ca0110485735315a4f48345346364c31353736
      09:49:07.342	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/1679030909605449730/XXXXXXXXXXXXXXXXX/thing/property/set:0a3d0a0308a4031020183520012801380340144881015003580170b484feba0e800113880101ba0103696f73ca0110485735315a4f48345346355435353130
      09:49:07.421	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"setValue":{"value":430}}}
      09:49:07.464	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"setValue":{"value":420}}}
      09:49:07.662	info	javascript.0 (21466) script.js.Ecoflow1_2_5: JSON-Nachricht empfangen:/app/device/property/R351ZEB4HF450475:{"addr":0,"cmdFunc":0,"cmdId":0,"id":1742362980637869000,"version":"1.0","timestamp":1717573747,"moduleType":"1","params":{"pd.XT150Watts1":-102,"pd.wattsInSum":102}}
      09:49:07.968	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX: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
      09:49:07.986	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:49:07.992	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a7c0a518801911f98018804b001961fc0019c04e801dcf7ffffffffffffff01b002008003f805880300f003a408f803f8058004008804009004f8059804f805a00407d004acea20900500e8060db808a1ffffff0f10351820200128014014480150515801800103880103ca0110485735315a4f48345346364c31353736
      09:49:08.021	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":3985,"pv1InputWatts":520,"pv2OpVolt":3990,"pv2InputWatts":540,"batInputWatts":-1060,"invOutputWatts":0,"permanentWatts":760,"dynamicWatts":0}}}
      09:49:08.994	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a81010a56880192179801f403b001e217c0018804e80184f8ffffffffffffff01b002008003a403880300f003fc07f803a4038004008804009004a4039804a403a00407d004aabe21d804f0f601900500e8060eb808a1ffffff0f10351820200128014014480150565801800103880103ca0110485735315a4f48345346355435353130
      09:49:09.029	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2962,"pv1InputWatts":500,"pv2OpVolt":3042,"pv2InputWatts":520,"batInputWatts":-1020,"invOutputWatts":0,"permanentWatts":420,"dynamicWatts":0}}}
      09:49:09.300	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX: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
      09:49:09.319	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{}
      09:49:09.913	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a8d010a6270068801fd1e9801fe03a8019403b001d21fc001a604e801dcf7ffffffffffffff01b002008003ae03880300f003a408f803ae038004008804009004ae039804ae03a00407d0048ee520e00405900500a805fc029006d635e8060ab808a1ffffff0f10351820200128014014480150625801800103880103ca0110485735315a4f48345346364c31353736
      09:49:09.942	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"llcStatue":6,"pv1OpVolt":3965,"pv1InputWatts":510,"pv2InputVolt":404,"pv2OpVolt":4050,"pv2InputWatts":550,"batInputWatts":-1060,"invOutputWatts":0,"permanentWatts":430,"dynamicWatts":0}}}
      09:49:10.953	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a88010a5d8801fe169801f403b001f617c0019204e801faf7ffffffffffffff01b002008003a403880300f0038608f803a4038004008804009004a4039804a403a00407d00496be21d804faf601e00405900500a805f202e80604b808a1ffffff0f103518202001280140144801505d5801800103880103ca0110485735315a4f48345346355435353130
      09:49:10.979	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2942,"pv1InputWatts":500,"pv2OpVolt":3062,"pv2InputWatts":530,"batInputWatts":-1030,"invOutputWatts":0,"permanentWatts":420,"dynamicWatts":0}}}
      09:49:11.900	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a7e0a5370058801a51f98018804b001c61fc0019c04e801dcf7ffffffffffffff01b002008003ae03880300f003a408f803ae038004008804009004ae039804ae03a00407d004f4e620900500e80600b808a1ffffff0f10351820200128014014480150535801800103880103ca0110485735315a4f48345346364c31353736
      09:49:11.924	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"llcStatue":5,"pv1OpVolt":4005,"pv1InputWatts":520,"pv2OpVolt":4038,"pv2InputWatts":540,"batInputWatts":-1060,"invOutputWatts":0,"permanentWatts":430,"dynamicWatts":0}}}
      09:49:13.012	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a80010a55880192179801f403b001d617c0019204e801faf7ffffffffffffff01b002008003a403880300f0038608f803a4038004008804009004a4039804a403a00407d004a0be219005009006f035e80601b808a1ffffff0f10351820200128014014480150555801800103880103ca0110485735315a4f48345346355435353130
      09:49:13.092	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2962,"pv1InputWatts":500,"pv2OpVolt":3030,"pv2InputWatts":530,"batInputWatts":-1030,"invOutputWatts":0,"permanentWatts":420,"dynamicWatts":0}}}
      09:49:13.927	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a7c0a518801911f98018804b001cf1fc0019c04e801dcf7ffffffffffffff01b002008003ae03880300f003a408f803ae038004008804009004ae039804ae03a00407d0048ee520900500e80603b808a1ffffff0f10351820200128014014480150515801800103880103ca0110485735315a4f48345346364c31353736
      09:49:14.008	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":3985,"pv1InputWatts":520,"pv2OpVolt":4047,"pv2InputWatts":540,"batInputWatts":-1060,"invOutputWatts":0,"permanentWatts":430,"dynamicWatts":0}}}
      09:49:14.971	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a80010a558801fe169801f403a801ac02b001be17c0019204e801faf7ffffffffffffff01b002008003a403880300f0038608f803a4038004008804009004a4039804a403a00407d0048cbe21900500e80603b808a1ffffff0f10351820200128014014480150555801800103880103ca0110485735315a4f48345346355435353130
      09:49:15.003	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":2942,"pv1InputWatts":500,"pv2InputVolt":300,"pv2OpVolt":3006,"pv2InputWatts":530,"batInputWatts":-1030,"invOutputWatts":0,"permanentWatts":420,"dynamicWatts":0}}}
      09:49:15.965	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Binäre Nachricht empfangen:/app/device/property/XXXXXXXXXXXXXXXXX:0a80010a558801fd1e9801fe03a8018c03b001ff1ec001a604e801dcf7ffffffffffffff01b002008003ae03880300f003a408f803ae038004008804009004ae039804ae03a00407d004d0e820900500e80601b808a1ffffff0f10351820200128014014480150555801800103880103ca0110485735315a4f48345346364c31353736
      09:49:16.029	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Decodierte Nachricht:{"data":{"InverterHeartbeat":{"pv1OpVolt":3965,"pv1InputWatts":510,"pv2InputVolt":396,"pv2OpVolt":3967,"pv2InputWatts":550,"batInputWatts":-1060,"invOutputWatts":0,"permanentWatts":430,"dynamicWatts":0}}}
      Weiß nicht ob da was dabei ist, da ziemlich viele EInträge in wenigen Sekunden kommen..
      F 1 Antwort Letzte Antwort
      • W Waly_de
        Zu finden ist?
        Ponti92
        schrieb am zuletzt editiert von Ponti92
        #1294
        @waly_de ratedPower ist bei mir obwohl ich auf Maximal 400W gestellt habe bei 8000
        Wenn ich den Wert in der App verstelle, dann zeigt mir das log folgendes an:
        10:10:34.569	info	javascript.0 (21466) script.js.Ecoflow1_2_5: hexString: 0a3d0a0308c20310201814200128013803401448920150035801709ecdccbb06800113880101ba0103696f73ca0110485735315a4f48345346355435353130
        10:10:34.570	info	javascript.0 (21466) script.js.Ecoflow1_2_5: Nachricht: {"header":[{"pdata":"08c203","src":32,"dest":20,"dSrc":1,"dDest":1,"checkType":3,"cmdFunc":20,"cmdId":146,"dataLen":3,"needAck":1,"seq":1735599774,"version":19,"payloadVer":1,"from":"ios","deviceSn":"XXXXXXXXXXXXXX"}]}
        • W Waly_de
          @foxthefox ist das 0_userdata.0.ecoflow.app_device_property_XXXXXXXX.data.InverterHeartbeat.ratedPower
          aus den Heartbeat Daten?
          foxthefox
          #1295
          @waly_de sagte in ecoflow-connector-Script zur dynamischen Leistungsanpassung:
          nein das waren die Dinge, die in aherby's Daten im Post zuvor drin waren.
          Ich konnte leider noch keinen heartbeat analysieren, da noch keiner gepostet wurde
          Adapterüberblick: Profil Github;
          Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
          Ein Aufruf: video
          • F foxthefox
            @aherby
            das sieht doch gut aus:
            {"max_watts_pack":{"maxWatts":460}}
            {"max_watts_pack":{"maxWatts":660}}
            {"max_watts_pack":{"maxWatts":800}}
            hoffe das waren deine Einstellungen.
            aherby
            schrieb am zuletzt editiert von aherby
            #1296
            @foxthefox Sollten die Werte gewesen sein.
            zu
            • P Ponti92
              foxthefox
              #1297
              dataLen
              also genaugenommen war {"max_watts_pack":{"maxWatts":450}} in dem Telegramm drin.
              "08c203" ist nicht direkt verwendbar, da noch protobuf codiert.
              Ein Aufruf: video
              • W Waly_de
                Zu finden ist?
                aherby
                #1298
                @waly_de der Wert hat sich wohl nach dem Update gestern verändert aber wenn ich in der App von 800 W runter gehe passiert da nichts.
                • P Ponti92
                  foxthefox
                  schrieb am zuletzt editiert von foxthefox
                  #1299
                  @ponti92
                  Danke für die Aufklärung wie es derzeitig läuft.
                  Es ist klar, daß ein ein Shelly3EM nicht direkt wie ein Stecker behandelt werden kann. Mindestens muß die derzeitig abgegebene Leistung mit berücksichtigt werden.
                  Hätte halt gedacht, daß dies schon so passiert. Aber woher soll es auch kommen.
                  Wenn man den shelly als mqtt über EF abboniert scheint ja der originale output übermittelt zu werden. Also braucht es einen Umsetzer, der aber zeitgleich noch die aktuelle Leistung braucht.
                  Wäre interessant ob es nunmehr ein ganz unbekanntes Gerät zu abbonieren gibt. Genaugenommen müsste das dann auch nicht JSON sein, sondern protobuf, da ja der powerstream nichts anderes kennt.
                  PS.
                  danke für die logs.
                  Hab mal ein paar angeschaut und dort stehen noch mehr Daten drin als die heutige protobuf Definition kennt.
                  Die Definition geht bisher bis Feld 61 und da gibt es nun Daten mit höheren Feldnummern!
                  Da braucht es noch ein paar unknownXX.
                  Edit.
                  In dem einen sind die Energiedaten drin und siehe da, nicht nur die bekannten watth1..7, sondern auch "watth16":729,"watth17":866,"watth18":866
                  Da muß man noch rausfinden, was die bedeuten könnten.
                  Ein Aufruf: video
                  • M MikeRow
                    Hallo, ich weiß nicht genau ob das Script mir bei meinem Vorhaben hilft, daher stelle ich mal meine Frage hier. Wenn das Falsch ist, mach ich gern auch ein neues Thema dazu auf.
                    Ich habe eine PV Anlage mit Speicher und möchte den Speicher ohne Elektriker erweitern. Ich habe mir eine Ecoflow Delta Pro + Powerstream 800 + Smart Plug bestellt.
                    Ich möchte bei Überschuss oder günstigem Tibber Preis folgende Werte anpassen oder Zustände erreichen.
                    Alle Werte wie Überschuss, Tibber Preise etc habe ich heute schon im IOBroker.
                    Wenn der primäre Speicher voll ist, soll der Überschuss in den Ecoflow gehen. Dazu muss ich die Beladung starten/stoppen und ggf die Ladeleistung anpassen können.
                    Nach bestimmten Uhrzeiten bzw wenn der primäre Speicher leer ist, will ich mit einem festen Wert (Grundlast) entladen.
                    Sehe ich das Richtig, das Beladen kann ganz einfach zb mit einem Shelly Plug (AN/AUS) gesteuert werden? Oder hilft mir da das Script. Ich habe auch einen MQTT Adapter gesehen. Kann der mir da helfen?? Ich habe auch in einem YT Video gesehen, dass jemand genau das gemacht hat mit einem Shelly am Delta Pro und einem am Powerstream.
                    Kann mir da jemand etwas Orientierung geben? Wir würdet ihr das machen? Danke und Gruß Mike
                    Accu
                    #1300
                    @mikerow ich habe hinter meiner Delta Pro mit ZA einen Shelly 1 PM plus sitzen. Diesen habe ich dem Skript bekannt gemacht in der Sektion Überschussladung. Wenn überschussladung auf TRUE ist, dann schaltet das Skript den Shelly automatisch an und aus und reguliert die AC Ladeleistung in Abhängigkeit vom Hausstrom verbrauch.
                    Du müsstest jetzt eigentlich nur noch irgendwie einen Datenpunkt haben, der deinen PV Batteriespeicher misst. Und kannst ja dann eine Bedingung basteln. WENN PV Speciher voll DANN schalte Überschussladung auf TRUE.
                    Weiter oben hier im Thread gibs ein Codeschnipsel wie man den Überschussladeparameter umsetzt.
                    • A Accu
                      MikeRow
                      #1301
                      @accu OK, Danke, da setze ich mal an. Vielen Dank
                        Accu
                        #1302
                        @Waly_de ich hatte jetzt paar mal den Fall dass abends meine PS nicht eingespeist hat. Hatte dann festgestellt dass auf "Stromspeicher Priorisieren" gestellt war. Ich hatte dann per Hand auf "Stromversorgung priorisieren" umgestellt und sofort ging's wieder.
                        Das Problem scheint aber sporadisch aufzutreten. Bzw. konnte ich noch kein Muster dafür erkennen. Hast Du einen Rat?
                          DerSmily
                          schrieb am zuletzt editiert von DerSmily
                          #1303
                          Ich versuche gerade das Skript mal wieder zum Laufen zu bringen:
                          Wie bekomme ich diesen Fehler weg?
                          javascript.0 11:31:21.934 info script.js.Ecoflow.DL: Fehler beim Abrufen des niedrigsten Werts: timeout
                          javascript.0 11:31:36.912 info script.js.Ecoflow.DL: getLowestValue-error: timeout
                          Zur Info vielleicht: Ich habe eine PS und nur einen Zusatzakku Delta
                          Thomas BucherT M 2 Antworten Letzte Antwort
                          • A Accu
                            aherby
                            #1304
                            @accu Hey kannst du das Verhalten näher beschreiben? Ich habe auch etwas das Gefühl das abends nicht mehr alles so funktioniert wie es soll. Durch meinen Aufbau sollte eigentlich auch bis Mitternacht odr länger quasi über Solar eingespeißt werden. Aber hin und wieder "steht" zwar eine Solarspannung an aber es kommt kein Strom. Dann nach Veränderungen, Warten plötzlich funktionert es dann wieder.
                            • A aherby
                              Accu
                              #1305
                              @aherby da gibt es eigentlich nicht viel zu beschreiben. Ich hatte ca. 3mal bisher das Problem dass der PS nach Sonnenuntergang nicht eingespeist hat. Hatte erst ewig gesucht und Geräte abgestöpselt aber dann festgestellt, dass der PS in der Setting Batterie bevorzugen stand. Habs dann manuell umgestellt und alles lief wieder. Keine Ahnung ob das im Skript irgendwo getriggert wurde und der Befehl es dann wieder zurück zu setzen nicht funktioniert hat. Wie gesagt kommt äußerst selten vor. Bei mir bisher 3x seitdem ich das Skript nutze.
                              • Maik BeckerM Maik Becker
                                @waly_de
                                0_userdata.0.ecoflow.app_1765798xxx_DCEBF8ZFAxxxxx_thing_property_set.writeables.slowChgPower sollte ja auch zum regeln der Ladegeschwindigkeit sein. Auch wenn ich diesen manuell ändere, wird es im der App nicht geändert, da scheint es irgend ein Problem zugeben.
                                Da wenn ich den gleichen Wert ecoflow-mqtt.0.xxxxx.inv.cfgSlowChgWatts ändere, ist dieser sofort in der App, sichtbar und angepasst.
                                PS: ich arbeite mit dem Zwischenschalter, ich hatte vorher die Delta Max da, lief alles ohne Probleme.
                                danke für die hilfe.
                                MikeRow
                                #1306
                                @maik-becker Ich kann das bei meiner Delta Pro auch feststellen. Konntest du das Problem lösen?
                                Maik BeckerM 1 Antwort Letzte Antwort
                                  Accu
                                  #1307
                                  ich meine hier mal was gelesen zu haben, dass jmd die EF outdoor Batterie mit dem PS betreibt. Kann hier jemand mal paar Erfarhungsberichte posten zum Gerät und vorallem in Verbindung mit dem Skript. Erkennt das Skript die neue EF 2KWH Outdoorbatterie? wie läuft das dann wenn man schon eine delta mit PS im einsatz hat. Kann das skript beide PS steuern vorallem dann auch beim Einspeisen?
                                    Milchbeck
                                    #1308
                                    Wenn ich im einspeise Script den wer von 1 auf 0.5 stelle wäre das dann alle 30 Sekunden
                                    MinValueMin 0.5
                                    • A Accu
                                      Mario1995
                                      #1309
                                      @accu Ich habe die Outdoor Batterie (2 Kwh). Das Skript funktioniert damit. Allerdings werden die Ganzen Werte (Akkustand etc.) direkt vom PowerStream geliefert. Zu deiner anderen Frage mit der Delta kann ich dir keine Auskunft geben.
                                      • M MikeRow
                                        Maik BeckerM Offline
                                        Maik Becker
                                        #1310
                                        @MikeRow ja ich habe die werte noch einmal wo anderes her geholt.
                                        • Maik BeckerM Offline
                                          Maik Becker
                                          #1311
                                          ich habe jetzt eine Delta Pro und eine Delta Max mit je einem Powerstream und einer Sellysteckdose zum einschalten der AC Ladung, wie kann ich die Überschussladung für beide Geräte einstellen?
