  4. Unifi Steuern ohne Adapter (Script,SSH)
    6.3k
152 Beiträge 16 Kommentatoren 38.7k Aufrufe 4 Beobachtet
  • A Adnim
    @liv-in-sky
    ja habe ich und auch die info gesehen das "node-unifi" installiert wird.
    javascript.0
    2024-06-02 08:16:31.172	error	script.js.common.unifivoucher: ERROR: TypeError: Cannot read properties of undefined (reading '0')
    javascript.0
    2024-06-02 08:16:31.172	error	script.js.common.unifivoucher: Fehler beim Logout: Error: getaddrinfo ENOTFOUND unifi
    javascript.0
    2024-06-02 08:16:31.149	error	script.js.common.unifivoucher: ERROR: Error: getaddrinfo ENOTFOUND unifi
    admin.0
    2024-06-02 08:16:22.436	info	<== Disconnect system.user.admin from 192.165.175.19 javascript
    javascript.0
    2024-06-02 08:16:17.914	info	script.js.common.unifivoucher: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    liv-in-skyL Offline
    liv-in-skyL Offline
    #103
    @adnim poste mal dein script
    • A Adnim
      @liv-in-sky
      javascript.0
      javascript.0
      javascript.0
      admin.0
      javascript.0
      liv-in-skyL Offline
      liv-in-skyL Offline
      #104
      @adnim ohne login daten :-)
      • liv-in-skyL liv-in-sky
        Adnim
        schrieb am zuletzt editiert von Adnim
        #105
        @liv-in-sky
        // V0.1 initialer release
        // V0.2 Fixed Login/Logout, THX to liv-in-sky. Changed Log output
        // V0.3 moved logout, THX to liv-in-sky.
        const Unifi = require('node-unifi');
        // Konfiguration
        const config = {
            hostname: "192.165.175.201",
            port: '8443', // 443 UDM Pro, 8443 für andere Controller
            username: 'hotspot-manager',
            password: 'xxxx',
            sslverify: false
        // Erstelle die benötigten Datenpunkte für die Voucher-Konfiguration
        createState("0_userdata.0.Unifi.Voucher.config.minutes", 123, { type: 'number', name: 'minutes', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.config.count", 1, { type: 'number', name: 'count', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.config.quota", 0, { type: 'number', name: 'quota', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.config.note", "testthis", { type: 'string', name: 'note', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.config.up", null, { type: 'number', name: 'up', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.config.down", null, { type: 'number', name: 'down', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.config.megabytes", null, { type: 'number', name: 'megabytes', read: true, write: true });
        // Erstelle die benötigten Datenpunkte für die Voucher-Daten
        createState("0_userdata.0.Unifi.Voucher.data.latestJson", "{}", { type: 'string', name: 'latestJson', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.code", "", { type: 'string', name: 'code', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.duration", 0, { type: 'number', name: 'duration', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.qos_overwrite", false, { type: 'boolean', name: 'qos_overwrite', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.note", "", { type: 'string', name: 'note', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.for_hotspot", false, { type: 'boolean', name: 'for_hotspot', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.create_time", 0, { type: 'number', name: 'create_time', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.quota", 0, { type: 'number', name: 'quota', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.site_id", "", { type: 'string', name: 'site_id', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.admin_name", "", { type: 'string', name: 'admin_name', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.used", 0, { type: 'number', name: 'used', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.status", "", { type: 'string', name: 'status', read: true, write: true });
        createState("0_userdata.0.Unifi.Voucher.data.status_expires", 0, { type: 'number', name: 'status_expires', read: true, write: true });
        // Erstelle den Datenpunkt für den Trigger
        createState("0_userdata.0.Unifi.Voucher.trigger", false, { type: 'boolean', name: 'trigger', read: true, write: true });
        let lastVoucherCreateTime = 0; // Speichert die create_time des letzten erstellten Vouchers
        // Reagiere auf Änderungen des Datenpunkts "trigger"
        on({ id: '0_userdata.0.Unifi.Voucher.trigger', change: 'ne', val: true }, async (obj) => {
            console.debug('Trigger-Datenpunkt geändert: ' + obj.state.val);
            console.debug('Versuche, mich bei UniFi anzumelden...');
            const unifi = new Unifi.Controller({ hostname: config.hostname, port: config.port, sslverify: config.sslverify });
            await unifi.login(config.username, config.password)
                .then(loginData => {
                    console.debug('Login erfolgreich: ' + JSON.stringify(loginData));
                .catch(error => {
                    console.error('ERROR: ' + error);
            try {
                // Lese die Konfigurationswerte aus den Datenpunkten
                const minutes = getState("0_userdata.0.Unifi.Voucher.config.minutes").val;
                const count = getState("0_userdata.0.Unifi.Voucher.config.count").val;
                const quota = getState("0_userdata.0.Unifi.Voucher.config.quota").val;
                const note = getState("0_userdata.0.Unifi.Voucher.config.note").val;
                const up = getState("0_userdata.0.Unifi.Voucher.config.up").val;
                const down = getState("0_userdata.0.Unifi.Voucher.config.down").val;
                const megabytes = getState("0_userdata.0.Unifi.Voucher.config.megabytes").val;
                // Erzeuge einen neuen Voucher
                console.debug('Trigger aktiviert, erstelle neuen Voucher...');
                const clientVoucher = await unifi.createVouchers(
                    minutes,
                    count,
                    quota,
                    note,
                    up,
                    down,
                    megabytes
                ).catch(async error => {
                    console.debug('Fehler beim Anlegen: ' + error);
                    console.debug('Logout bei UniFi...');
                    await unifi.logout().then(() => {
                        console.debug('Logout erfolgreich.');
                    }).catch(error => {
                        console.error('Fehler beim Logout: ' + error);
                    setState('0_userdata.0.Unifi.Voucher.trigger', false);
                console.debug('Voucher erstellt: ' + JSON.stringify(clientVoucher));
                // Erfasse die create_time des erstellten Vouchers
                const newVoucherCreateTime = clientVoucher[0].create_time;
                // Hole nur den neuesten Voucher basierend auf create_time
                console.debug('Hole den neuesten Voucher...');
                const myVoucher = await unifi.getVouchers(newVoucherCreateTime);
                console.debug("Neuester Voucher: " + JSON.stringify(myVoucher));
                }).catch(error => {
                // Schreibe die Voucher-Daten in den Datenpunkt "latestJson"
                console.debug('Schreibe Voucher-Daten in den Datenpunkt "latestJson"...');
                setState('0_userdata.0.Unifi.Voucher.data.latestJson', JSON.stringify(myVoucher));
                // Extrahiere die Werte aus dem Voucher-Objekt und setze die Datenpunkte
                const voucher = myVoucher[0];
                setState('0_userdata.0.Unifi.Voucher.data.code', voucher.code);
                setState('0_userdata.0.Unifi.Voucher.data.duration', voucher.duration);
                setState('0_userdata.0.Unifi.Voucher.data.qos_overwrite', voucher.qos_overwrite);
                setState('0_userdata.0.Unifi.Voucher.data.note', voucher.note);
                setState('0_userdata.0.Unifi.Voucher.data.for_hotspot', voucher.for_hotspot);
                setState('0_userdata.0.Unifi.Voucher.data.create_time', voucher.create_time);
                setState('0_userdata.0.Unifi.Voucher.data.quota', voucher.quota);
                setState('0_userdata.0.Unifi.Voucher.data.site_id', voucher.site_id);
                setState('0_userdata.0.Unifi.Voucher.data.admin_name', voucher.admin_name);
                setState('0_userdata.0.Unifi.Voucher.data.used', voucher.used);
                setState('0_userdata.0.Unifi.Voucher.data.status', voucher.status);
                setState('0_userdata.0.Unifi.Voucher.data.status_expires', voucher.status_expires);
                // Setze den Trigger wieder auf false
                console.debug('Setze den Trigger wieder auf false...');
            } catch (error) {
        ist hier irgendwo noch ein Unifi- unifi Typo drin?
        • A Adnim
          @liv-in-sky
          // Konfiguration
          const config = {
              password: 'xxxx',
              sslverify: false
                  .catch(error => {
              try {
                      minutes,
                      count,
                      quota,
                      note,
                      up,
                      down,
                      megabytes
                      }).catch(error => {
                  }).catch(error => {
              } catch (error) {
          liv-in-skyL Offline
          liv-in-skyL Offline
          #106
          @adnim wäre es ein problem, mal den iob server neuzustarten
          ich möchte sicherstellen, das absolut keine alten programmteile irgendwo im system sind
          es kommt ja nicht in den trigger - wann kommt der fehler ? beim speichern des scriptes oder beim ersten trigger
            Adnim
            #107
            @liv-in-sky
            Kommt bei manueller Änderung des Triggers.
            Habe die VM gerade neu gestartet, gleiche Fehlermeldung.
            Bei mir ist die Aktuelle Beta des JS Controllers drauf evtl. liegts daran, ein Downgrade kann ich aber erst später versuchen
            • A Adnim
              @liv-in-sky
              liv-in-skyL Offline
              liv-in-skyL Offline
              #108
              @adnim habe ich auch 5.0.19 und auch node 20
              irgendwie kann ich bei diesen fehlern nicht richtig nachvollziehen, an welcher stelle das script aussteigt - wenn getriggert wird, ist ja erstmal ein log - das kommt garnicht ?
              dann müßte es ja schon vorher was passieren - hast du node-unifi im setting der javascript instanz drin ?
              liv-in-skyL A 2 Antworten Letzte Antwort
              • A Adnim
                @liv-in-sky
                liv-in-skyL Offline
                liv-in-skyL Offline
                #109
                @adnim
                kannst du mal dieses kleine script testen
                const unifi22 = new Unifi.Controller({hostname:"192.168.168.xxx",port:'8443', sslverify: false});
                async function main() {
                 try {
                   // LOGIN
                   const loginData = await unifi22 .login('x', 'xxxxxx');
                   console.log('login: ' + loginData);
                const myVouchers = await unifi22 .getVouchers();
                   console.log("vouchers: "+ JSON.stringify(myVouchers))
                   // LOGOUT
                   const logoutData = await unifi22 .logout();
                   console.log('logout: ' + JSON.stringify(logoutData));
                 } catch (error) {
                   console.log('ERROR: ' + error);
                main();
                zeile 3 und 8 anpassen
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #110
                  @liv-in-sky sagte in Adapter: ioBroker.unifi:
                  @Adnim ich frage, da es irgenein thema gab mit älteren javascript adaptern - ich habe die neuste latest (8.4.2) installiert, ansonsten konnte ich es nicht eingeben in der instanz
                    Adnim
                    #111
                    ja genauso ist es hier auch
                    nee mehr kommt nicht
                    ja , mache es mal raus und wieder rein
                    mit dem kleinen skript sieht das so aus im log
                    javascript.0
                    2024-06-02 08:54:51.441	info	Stopping script script.js.common.unifitest
                    javascript.0
                    2024-06-02 08:54:45.918	info	script.js.common.unifitest: ERROR: Error: getaddrinfo ENOTFOUND unifi
                    javascript.0
                    2024-06-02 08:54:45.915	info	script.js.common.unifitest: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    javascript.0
                    2024-06-02 08:54:45.897	info	Start JavaScript script.js.common.unifitest (Javascript/js)
                    edit: nee auch node-unifi raus und Instanz speichern Neu starten und wieder rein machen ändert bei beiden Skripten nichts
                      Adnim
                      #112
                      Version 8.4.2 node: v20.14.0, js-controller: 5.0.19
                      • A Adnim
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #113
                        @adnim schaut echt nach einem problem mit der node-unifi aus - kannst du sie im filesystem finden bzw mal iob stop, iob fix aufrufen
                        scheint vom adapter zu kommen /opt/iobroker/node-modules/node-unifi
                        müßte zusatzmodul sein : /opt/iobroker/node-modules/iobroker.javascript/node-unifi
                        • liv-in-skyL Offline
                          liv-in-skyL Offline
                          #114
                          @haus-automatisierung
                          könntest du uns evtl helfen - wir versuchen einer verbindung zum unifi-controller herzustellen - bei mir gibt das kein problem - 2 user haben aber eines
                          node-unifi ist als zusätzliches module drin (obwohl auch der unifi adapter das modul installiert hat
                          dieses script soll laufen: https://forum.iobroker.net/post/1165996
                           try {
                             // LOGIN
                             // LOGOUT
                           } catch (error) {
                          main();
                          hier der fehler - mit dem ich einfach nix anfangen kann https://forum.iobroker.net/post/1166000
                          javascript.0
                          javascript.0
                          javascript.0
                          javascript.0
                          der fehler kommt, wenn man den trigger setzt - aber das erste log im trigger kommt schon nicht - irgendeine idee ?
                            Adnim
                            #115
                            @liv-in-sky
                            ja das Modul ist im File System zu sehen. Den fixer hab ich mal laufen lassen ändert aber nichts an den Fehlermeldungen.
                              @adnim vielleicht kommt hilfe von @haus-automatisierung
                              haus-automatisierungH Offline
                              #116
                              @liv-in-sky Kann ich mir frühestens morgen Vormittag ansehen
                              📚 Meine Dokumentation
                              • kmxakK Offline
                                kmxakK Offline
                                kmxak
                                schrieb am zuletzt editiert von kmxak
                                #117
                                ich hatte das script die log meldungen auf debug gestellt. wenn die kommen sollen den js adapter auf debug stellen. Man könnte ja die letzte nehmen wenn es mit i.O durchgelaufen ist als info aber mir waren es so zu viele.
                                Wifi Operator ist die Admin Rolle im Unifi User Managment.
                                Dazu habe ich mal die Readme angepasst.
                                Gruß Alex
                                • kmxakK kmxak
                                  Adnim
                                  #118
                                  @kmxak sagte in Adapter: ioBroker.unifi:
                                  javascript.0
                                  2024-06-02 09:47:45.323	error	script.js.common.unifivoucher: ERROR: TypeError: Cannot read properties of undefined (reading '0')
                                  javascript.0
                                  2024-06-02 09:47:45.323	debug	script.js.common.unifivoucher: Voucher erstellt: undefined
                                  javascript.0
                                  2024-06-02 09:47:45.323	error	script.js.common.unifivoucher: Fehler beim Logout: Error: getaddrinfo ENOTFOUND unifi
                                  javascript.0
                                  2024-06-02 09:47:45.316	debug	script.js.common.unifivoucher: Logout bei UniFi...
                                  javascript.0
                                  2024-06-02 09:47:45.316	debug	script.js.common.unifivoucher: Fehler beim Anlegen: Error: getaddrinfo ENOTFOUND unifi
                                  javascript.0
                                  2024-06-02 09:47:45.303	debug	script.js.common.unifivoucher: Trigger aktiviert, erstelle neuen Voucher...
                                  javascript.0
                                  2024-06-02 09:47:45.303	error	script.js.common.unifivoucher: ERROR: Error: getaddrinfo ENOTFOUND unifi
                                  javascript.0
                                  2024-06-02 09:47:45.234	debug	script.js.common.unifivoucher: Versuche, mich bei UniFi anzumelden...
                                  javascript.0
                                  2024-06-02 09:47:45.234	debug	script.js.common.unifivoucher: Trigger-Datenpunkt geändert: true
                                  • kmxakK Offline
                                    kmxakK Offline
                                    kmxak
                                    #119
                                    für mich deutet das
                                    javascript.0
                                    auf ein verbindungsproblem hin.
                                    IP und Passwort sowie port richtig eingegeben? Bzw kann der Unifi Adapter falls installiert drauf zugreifen?
                                    Gruß Alex
                                    • kmxakK kmxak
                                      für mich deutet das
                                      javascript.0
                                      Adnim
                                      #120
                                      nochmal geprüft , definitiv richtig
                                      Der läuft und ich sehe die vouchers mit ihm, kann halt keine neuen erstellen.
                                      • A Adnim
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #121
                                        @adnim
                                        bei deinem neuen log fehlt der login - hast du besondere zeichen im password ?
                                          @adnim
                                          Adnim
                                          #122
                                          Nee habe mit meinem Admin Acount und dem extra angelegten hotspot Acount versucht PW ist nur eine normale Zahl
