  4. mal wieder node und npm update
42 Beiträge 8 Kommentatoren 12.7k Aufrufe 8 Beobachtet
  • D docsnyder7
    Nabend zusammen.. ich hab heute mal wieder nodejs aktualisiert und dabei festgestellt, dass auch npm von 10.5.2 auf 10.7 angehoben werden kann.. allerdings bekomme ich
    npm ERR! code EACCES
    npm ERR! syscall rename
    npm ERR! path /usr/lib/node_modules/npm
    npm ERR! dest /usr/lib/node_modules/.npm-qUIFSsiV
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, rename '/usr/lib/node_modules/npm' -> '/usr/lib/node_modules/.npm-qUIFSsiV'
    npm ERR!     at async Object.rename (node:internal/fs/promises:779:10)
    npm ERR!     at async moveFile (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/move-file.js:30:5)
    npm ERR!     at async Promise.allSettled (index 0)
    npm ERR!     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:246:11)
    npm ERR!     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:165:5)
    npm ERR!     at async Update.exec (/usr/lib/node_modules/npm/lib/commands/update.js:65:5)
    npm ERR!     at async module.exports (/usr/lib/node_modules/npm/lib/cli-entry.js:61:5)
    npm ERR!     at async module.exports (/usr/lib/node_modules/npm/lib/cli-entry.js:61:5) {
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'rename',
    npm ERR!   path: '/usr/lib/node_modules/npm',
    npm ERR!   dest: '/usr/lib/node_modules/.npm-qUIFSsiV'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR! A complete log of this run can be found in: /home/docsn/.npm/_logs/2024-05-22T17_57_32_781Z-debug-0.log
    jetzt hab ich schon einige Anleitungen gelesen, bin mir aber nicht sicher, ob das alles für mich so passt... gibts ein kurze interne Anleitung zu dieser Fehlerlage?
    Muss ich als root angemeldet sein?
    Erledigt... ein reboot und ein erneutes iob fix hats erledigt.
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @docsnyder7 sagte in Wichtige Hinweise bei neueren npm-Versionen und sudo:
    Frage: Wie?
    Denn npm wird nicht separat angelangt. Das kommt immer schon passend mit nodejs daher...
      Frage: Wie?
      D
      D
      docsnyder7
      schrieb am zuletzt editiert von docsnyder7
      Recht du hast, war wohl etwas hibbelig und ungeduldig 😕
      nodejs über den Leitfaden hier aus dem Forum
      iob nodejs-update 20
      • D docsnyder7
        Thomas BraunT
        Thomas BraunT
        @docsnyder7
        Eigentlich wollte ich auch nicht wissen ob ich Recht habe sondern wie du nodejs aktualisierst...
          @docsnyder7
          D
          D
          docsnyder7
          • D docsnyder7
            J
            J
            Jan1
            npm bleibt so lange in der "alten" Version, bis es mit dem nächsten Node Update mit aktualisiert wird. Also jetzt einfach so lassen und Finger weg ;)
            • HomoranH
              @docsnyder7
              ich hab das mal von dem alten Thread abgetrennt.
              Hat auch gar nichts mit sudo npm.... zu tun.
              Bitte ggf. den provisorischen Threadtitel anpassen
              • D docsnyder7
                Thomas BraunT
                Thomas BraunT
                @docsnyder7
                Hier noch die derzeitig im Umlauf befindlichen nodejs/npm-Bundles:
                  @docsnyder7
                  D
                  D
                  docsnyder7
                  danke dafür.. mit dem Update auf 20.13.1 hab ich die 10.8.0 npm bekommen
                  • D docsnyder7
                    Thomas BraunT
                    Thomas BraunT
                    @docsnyder7
                    Dann hast du da irgendwas anderes reingeknallt, denn wie du oben siehst wird npm 10.8.0 derzeitig mit gar keinem nodejs-Paket ausgeliefert.
                    Das 'irgendwas anderes' dürfte auch die Meldungen aus dem ersten Beitrag verursachen.
                      @docsnyder7
                      D
                      D
                      docsnyder7
                      die Meldung kam vor dem reboot und dem iob fix, aber nach dem iob nodejs-update 20
                      macht es Sinn das 20er Update nochmals anzuwerfen
                      ich hatte mit
                      npm install -g npm@latest
                      versucht die Version anzupassen, dies führte dann zu den obigen Fehlermeldungen
                      • D docsnyder7
                        ich hatte mit
                        Thomas BraunT
                        Thomas BraunT
                        @docsnyder7
                        Und genau DAS macht man halt nicht.
                        Nie per npm install -g 'irgendwas' global in das System klatschen.
                        Wie gesagt, das ist der Auslöser für die Meldung aus dem ersten Beitrag.
                        sudo apt update
                        sudo apt install --reinstall nodejs
                        sollte das richtige Paket aber jetzt auf die Kiste bügeln.
                        D DuffyD 2 Antworten Letzte Antwort
                          @docsnyder7
                          sudo apt update
                          D
                          D
                          docsnyder7
                          Danke für die Hilfe!
                          Werde ich umgehend erledigen... mir war bis dato nicht bewußt, dass npm mit dem nodejs Paket daherkommt
                          Update: alles erledigt.. npm wieder auf 10.5.2
                          • D docsnyder7
                            J
                            J
                            Jan1
                            @docsnyder7
                            Genau deshalb habe ich das auch oben geschrieben, dass es mit dem nächsten Node Update mitkommt und Du die Finger nun weglassen sollst ;)
                            • J Jan1
                              @docsnyder7
                              D
                              D
                              docsnyder7
                              @jan1
                              das hatte ich ja auch, aber das war das Kind schon Richtung Brunnen abgesprungen 😬
                                @docsnyder7
                                sudo apt update
                                DuffyD
                                DuffyD
                                Duffy
                                @thomas-braun sagte in mal wieder node und npm update:
                                @docsnyder7
                                sudo apt update
                                Ohh weh ist das alles kompliziert (wenn man ahnungslos ist)
                                Ich hatte mir vor ca. einem 1/2 Jahr
                                folgendes zum node-js Update dokumentiert.
                                Warum sieht der Befehl zum Update von Node-js nun so aus?
                                sudo apt update
                                Hängt es damit zusammen, dass es andere Voraussetzungen waren da bei docsnyder7 etwas verbogen war?
                                Ich habe es an meinem Testpi, so wie von dir geschrieben gemacht, es hat auch funktioniert ich würde nur gerne die Hintergründe für die unterschiedlichen Befehle kennen.
                                VG Duffy
                                Mini PC ASUS PN42 N100 / 32 GB RAM
                                Node.js: v24.22.2
                                NPM: 11.19.1
                                js-controller 7.2.5
                                Linux: Trixie
                                • DuffyD Duffy
                                  @docsnyder7
                                  sudo apt update
                                  sudo apt update
                                  VG Duffy
                                  Thomas BraunT
                                  Thomas BraunT
                                  @duffy sagte in mal wieder node und npm update:
                                  Das hängt damit zusammen dass der Doktor die falsche Behandlungsmethoden gewählt hat und der Patient jetzt nochmal mit dem richtigen Besteck operiert werden musste.
                                  DuffyD 1 Antwort Letzte Antwort
                                    DuffyD
                                    DuffyD
                                    Duffy
                                    :-) anschaulich formuliert, danke dafür.
                                    D.h. so sollte es nach wie vor klappen?
                                    iob stop
                                    iob fix
                                    iob nodejs-update
                                    iob upload all
                                    Gruß Duffy
                                    Node.js: v24.22.2
                                    NPM: 11.19.1
                                    js-controller 7.2.5
                                    Linux: Trixie
                                    • DuffyD Duffy
                                      iob stop
                                      iob fix
                                      iob nodejs-update
                                      iob upload all
                                      Gruß Duffy
                                      Thomas BraunT
                                      Thomas BraunT
                                      @duffy
                                      Ja, so sollte das funktionieren.
                                      Bzw. bei Updates innerhalb des Major Releases läuft es natürlich über das ordentliche System-Update mit.
                                      iob nodejs-update ist eigentlich nur bei Wechsel des Releases oder notwendigen Reparaturen der Pfade erforderlich.
                                        @duffy
                                        DuffyD
                                        DuffyD
                                        Duffy
                                        Major Release
                                        Heisst das für mich das ich node-js 20.xx wenn ich aktuell Bookworm habe im Rahmen eines:
                                        sudo apt update && sudo apt full-upgrade
                                        das automatisch bekomme?
                                        Node.js: v24.22.2
                                        NPM: 11.19.1
                                        js-controller 7.2.5
                                        Linux: Trixie
                                        • DuffyD Duffy
                                          Major Release
                                          Major Release
                                          nein!
                                          du bekommst die xx automatisch, aber nicht die 20
                                          84.2k
