  4. Test Adapter toyota v.0.0.x
    6.3k
101 Beiträge 26 Kommentatoren 19.1k Aufrufe 25 Beobachtet
  • F Filo
    ich habe 3 Instanzen laufen, ab Version 0.2.25 funktioniert nut noch die Instanz Toyota.0, die anderen bleiben gelb. Vorher haben alle Instazen funktioniert.
    toyota.1
    	2024-01-20 10:35:29.807	error	No Token Response
    toyota.1
    	2024-01-20 10:35:29.806	error	"\r\n\r\n\r\n\r\n\r\n\r\n<!DOCTYPE html>\r\n<html lang=\"en\" xmlns=\"http://www.w3.org/1999/html\">\r\n\r\n<head>\r\n <link rel=\"preconnect\" href=\"https://fonts.gstatic.com\">\r\n <link href=\"https://fonts.googleapis.com/css2?family=Roboto&display=swap\" rel=\"stylesheet\">\r\n <link rel=\"stylesheet\" href=\"css/styles_tme.css\">\r\n <meta charset=\"UTF-8\">\r\n <title>Einloggen</title>\r\n</head>\r\n<body>\r\n\r\n\r\n <div id=\"logoDiv\" class=\"toyota_logo\"></div>\r\n \r\n<div class=\"prompt-text\">Einloggen<hr class=\"line\"></hr></div>\r\n<form action=\"doAuth\" method=\"POST\" onsubmit=\"javascript:reEnableUname();\">\r\n <input type=\"text\" placeholder=\"E-Mail-Adresse/Nutzername\" id=\"uname\" name=\"uname\" value=\"\" required onkeyup=changeSubmitColour()>\r\n <input type=\"password\" placeholder=\"Passwort\" id=\"pass\" name=\"pass\" required onkeyup=\"javascript:changeSubmitColour();\">\r\n <input class=\"submit\" type=\"submit\" value=\"Einloggen\" id=\"submit\"/>\r\n <input type=\"hidden\" id=\"login_hint\" name=\"login_hint\" value=\"\">\r\n <input type=\"hidden\" id=\"goto\" name=\"goto\" value=\"https://b2c-login.toyota-europe.com/oauth2/realms/root/realms/tme/authorize?response_type=code&realm=tme&redirect_uri=com.toyota.oneapp:/oauth2Callback&client_id=oneapp&scope=openid%20profile%20write&code_challenge_method=S256&code_challenge=Bx88SxgIEnvxrsobwijnUlzg3rrb-zNV4wzDlndWFVc\">\r\n <input type=\"hidden\" id=\"brand\" name=\"brand\" value=\"TOYOTA\">\r\n \r\n \r\n</form>\r\n<div class=\"outer-popup\">\r\n <div id=\"failure-popup\" style=\"display: none;\" class=\"mm21-toast\">\r\n Bitte gib gültige Anmeldeinformationen ein\r\n </div>\r\n</div>\r\n<script>\r\n window.onload = function handleOnLoad(){\r\n console.log(\"window.onload is completed. extracting goto url.\");\r\n const urlParams = new URLSearchParams(window.location.search);\r\n for (const param of urlParams) {\r\n console.log(param)\r\n }\r\n\r\n const loginFailed = urlParams.get('login_failed');\r\n if(loginFailed !== null && loginFailed){\r\n showError();\r\n }\r\n }\r\n\r\n function showError(){\r\n var popEle = document.getElementById(\"failure-popup\");\r\n popEle.style = \"display: block;\";\r\n setTimeout(function(){\r\n console.log(\"timeout complete\");\r\n var popEle2 = document.getElementById(\"failure-popup\");\r\n popEle2.style = \"display: none;\";\r\n }, 3000);\r\n }\r\n\r\n function changeSubmitColour() {\r\n if(document.getElementById(\"uname\").value != \"\" && document.getElementById(\"pass\").value != \"\") {\r\n document.getElementById(\"submit\").style.backgroundColor = \"#d92429\";\r\n document.getElementById(\"submit\").disabled = false;\r\n } else {\r\n document.getElementById(\"submit\").style.backgroundColor = \"rgb(119, 119, 119)\";\r\n document.getElementById(\"submit\").disabled = true;\r\n }\r\n }\r\n\r\n function reEnableUname(){\r\n var unameEle = document.getElementById(\"uname\");\r\n unameEle.disabled = false;\r\n }\r\n </script>\r\n</body>\r\n</html>\r\n"
    toyota.1
    	2024-01-20 10:35:29.805	error	Failed code receive step
    bitte sag bescheid, wenn Du weitere Informationen benötigst.
    Marc
    tombox
    @filo Alle Instanzen sind eigentlich identisch.
    Bitte überprüfen ob alles mit der schwarzen mytoyota app funktioniert und wie in Beitrag 1 bitt die 0.2.6 verwenden
    MarvinTheRobotM 1 Antwort Letzte Antwort
    • T tombox
      MarvinTheRobotM Offline
      MarvinTheRobot
      Hi!
      Ich bekomme genau den gleichen Fehler wie @Filo
      Version ist 0.2.6 aus GitHub installiert - habe vorher alle altern adapter und instanzen gelöscht. Habe auch die Sonderzeichen bis auf "dashes" aus dem Passwort entfernt. Über App am Handy oder Web funktioniert es problemlos....
      Gib mir bitte auch bescheid wenn du weitere Informationen benötigst.
      • MarvinTheRobotM MarvinTheRobot
        Hi!
        tombox
        @marvintherobot Ich bräuchte dann ein nicht funktionierenden Zugang zum testen entweder via pn oder email
        tombox2020@gmail.com
        • F Offline
          Filo
          sorry, dass ich so spät antworte, es ist mir jetzt ja schon ein bisschen peinlich, aber als ich mit die Toyota App auf dem Handy meiner Frau mal genauer angeschaut habe stellte sich tatsächlich heraus, dass sie noch die allte Version installiert hatte, Nach Update auf die neue Version der App hab ich jetzt keine Fehler mehr im IOB. Vielen Dank an dieser Stelle an Tombox für den Adapter und die Arbeit
          Filo
          • T tombox
            Hi ich habe ein neuen Adapter für Toyota Fahrzeug die mit der myToyota App gesteuert werden können
            geschrieben.
            https://github.com/TA2k/ioBroker.toyota
            Steuerung über toyota.0.id.remote
            Loginablauf:
            Die myToyota App Mail und Passwort eingeben.
            N Offline
            N Offline
            norme
            @tombox Hallo!
            Da der alte Adapter 0.0.3 nicht mehr funktionierte, hab ich den 0.2.6 via Github installiert. Läuft soweit, nur vermisse ich Datenpunkte wie "motion" (also Fahrzeug bewegt sich), Durchschnittsgeschwindigkeit, Jahreswert km, sowie die Geodaten.
            Sehe ich den Wald vor lauter Bäumen nicht? Habe alle Ordner imObjektbaum aufgeklappt...
            • N norme
              @tombox Hallo!
              @norme sagte in Test Adapter toyota v.0.0.x:
              Besser aus dem Beta-Zweig nehmen.
              N 1 Antwort Letzte Antwort
                N Offline
                N Offline
                norme
                @thomas-braun Danke dir! Aber auch das bringt keine Änderung
                • N norme
                  #66
                  @norme
                  Hab ich auch nicht behauptet.
                  Aber die Reihenfolge ist immer stable - beta/latest - GitHub
                  • J Offline
                    Jason 0
                    schrieb am zuletzt editiert von Jason 0
                    #67
                    ich nutze den Adapter für einen Lexus und er funktioniert. Vielen Dank dafür.
                    Ich habe 2 Fragen:
                    Ich würde gerne den SOC auslesen und an die Wallbox weiterreichen. Das sollte natürlich relativ regelmäßig funktionieren. Obwohl 5min Aktualisierungszeit in der Instanz eingestellt sind, habe ich morgens oft 6, 7h keine Aktualisierung erhalten. Kann man das irgendwie aktiv anstoßen?
                    1. Es gibt (bei mir) auch drei Datenpunkte, auf die ich schreiben könnte.
                    Ist es so gedacht, dass ich darüber Fahrzeugfunktionen steuern/schalten können sollte? Ein Setzen der Werte in der Instanz funktioniert, führt aber keine "reale Funktion" am Fahrzeug aus.
                    Viele Grüße und vielen Dank für die Unterstützung vorab
                    Jason
                    • J Jason 0
                      Ich habe 2 Fragen:
                      Jason
                      andrebu
                      #68
                      @jason-0 Bei mir das gleiche. Ich mach malnen Issue dazu auf.
                      Intel NUC
                      Proxmox
                      Raspberry Pi 4
                      Conbee 2 Stick
                      Adapter: deConz Zigbee
                      • A andrebu
                        MarvinTheRobot
                        #69
                        hallo!
                        Ich grabe das Ganze wieder mal aus - habe v0.2.6 installiert und kann mich einloggen und der Adapter wird grün. Allerdings findet er keine Fahrzeuge. Logge ich mich mit den selben Zugangsdaten auf toyota.at ein sehe ich sehr wohl mein Fahrzeug... (Ist ein E-Fahrzeug). Was kann da das Problem sein?
                        lg!
                        • E Offline
                          ETGermany
                          #70
                          Und nun hat Toyota mal wieder eine, für den Adapter wohl fatale Änderung eingeführt. Anscheinend wird jetzt noch überprüft, ob der den Status abfragende Client dazu überhaupt berechtigt ist:
                          2025-04-22 18:35:01.187 - info: toyota.0 (5974) Login to Toyota
                          2025-04-22 18:35:01.961 - info: toyota.0 (5974) Start token exchange
                          2025-04-22 18:35:02.102 - info: toyota.0 (5974) Login successful
                          2025-04-22 18:35:02.104 - info: toyota.0 (5974) Get Vehicles
                          2025-04-22 18:35:02.228 - error: toyota.0 (5974) AxiosError: Request failed with status code 403
                          2025-04-22 18:35:02.229 - error: toyota.0 (5974) {"status":{"messages":[{"responseCode":"APIGW-403","description":"Unauthorized","detailedDescription":"Unauthorized client "}]}}
                          2025-04-22 18:58:00.051 - info: host.n51-ubuntu "system.adapter.toyota.0" disabled
                          Bis 21.04.2025 war es noch in Ordnung:
                          2025-04-21 18:35:01.285 - info: toyota.0 (38960) Login to Toyota
                          2025-04-21 18:35:02.051 - info: toyota.0 (38960) Start token exchange
                          2025-04-21 18:35:02.190 - info: toyota.0 (38960) Login successful
                          2025-04-21 18:35:02.193 - info: toyota.0 (38960) Get Vehicles
                          2025-04-21 18:35:02.472 - info: toyota.0 (38960) Found 1 vehicles
                          2025-04-21 18:35:02.477 - info: toyota.0 (38960) Create vehicle JTMXYZ1234567890 RAV4 PHEV Rav4 PHEV - NG '20
                          2025-04-21 18:58:00.075 - info: host.n51-ubuntu "system.adapter.toyota.0" disabled
                          Nichts ist von Dauer.
                          • E ETGermany
                            MarvinTheRobot
                            #71
                            @etgermany
                            Von Dauer ist gut - wir hier in Österreich sind von der MyT App (die auf AT lokalisiert war) auf die myToyota App (global) umgestellt worden - ENDLICH! Weil vorher hat gar nix funktioniert.
                            Und dann hab ich gleich mal v.0.2.6 aktiviert und mich eingeloggt und gefreut dass ich endlich wieder Fahrzeugdaten bekomme. Das hat heiße 2 Tage gehalten. GRML!
                            Wahrscheinlich liegts an der Umstellung der AT Kunden dass jetz zusätzlich von Toyota auch noch was geändert wurde. Das dürfte hier "gut" zusammenpassen....
                            • E Offline
                              ETGermany
                              #72
                              Hallo @tombox
                              Um den Adapter wieder zum Funktionieren zu bringen, ist es wohl erforderlich, dass eine CLIENT_VERSION bei der Anmeldung mitgegeben werden muss.
                              Ich habe gestern (24.04.2025) ein anderes Projekt gefunden: https://github.com/pytoyoda/pytoyoda
                              Vor 24 Stunden hatte es auch nicht funktioniert, aber vor einigen Stunden gab es Anpassungen im Projekt:
                              Mit dieser Änderung konnte ich die Abfrage wieder durchführen:
                              Wäre schön, wenn man deinen Adapter im ioBroker auch wieder verwenden könnte.
                              • E ETGermany
                                Hallo @tombox
                                tombox
                                #73
                                @etgermany GitHub version testen
                                E MarvinTheRobotM 3 Antworten Letzte Antwort
                                • T tombox
                                  ETGermany
                                  #74
                                  @tombox Danke für die erste Aktualisierung, aber leider noch der gleiche Fehler:
                                  2025-04-26 14:00:05.579 - info: host.n51-ubuntu "system.adapter.toyota.0" enabled
                                  2025-04-26 14:00:05.821 - info: host.n51-ubuntu instance system.adapter.toyota.0 in version "0.2.6" started with pid 11232
                                  2025-04-26 14:00:06.685 - info: toyota.0 (11232) starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.toyota, node: v20.19.1, js-controller: 7.0.6
                                  2025-04-26 14:00:06.697 - info: toyota.0 (11232) Login to Toyota
                                  2025-04-26 14:00:07.480 - info: toyota.0 (11232) Start token exchange
                                  2025-04-26 14:00:07.610 - info: toyota.0 (11232) Login successful
                                  2025-04-26 14:00:07.612 - info: toyota.0 (11232) Get Vehicles
                                  2025-04-26 14:00:07.692 - error: toyota.0 (11232) AxiosError: Request failed with status code 403
                                  2025-04-26 14:00:07.692 - error: toyota.0 (11232) {"status":{"messages":[{"responseCode":"APIGW-403","description":"Unauthorized","detailedDescription":"Unauthorized client "}]}}
                                  Ich gehe heute Abend bis 8. Mai in Ferien.
                                  Vielleicht könnte @MarvinTheRobot testen, wenn er den Chat noch verfolgt oder wir warten halt ab.
                                  @MarvinTheRobot bis du noch dabei?
                                  • T tombox
                                    ETGermany
                                    #75
                                    @tombox Bei der GitHub Version hast du aber noch keine Versionsnummer geändert, Installation war jedenfalls erfolgreich:
                                    drwxrwxr-x   4 iobroker iobroker   4096 Okt  9  2024  iobroker.sonoff/
                                    drwxr-xr-x   5 iobroker iobroker   4096 Apr  1 09:20  iobroker.tibberlink/
                                    drwxr-xr-x   5 iobroker iobroker   4096 Apr 26 14:00  iobroker.toyota/
                                    drwxr-xr-x   6 iobroker iobroker   4096 Sep 18  2024  iobroker.tuya/
                                    drwxrwxr-x   7 iobroker iobroker   4096 Jun 12  2024  iobroker.vis/
                                    • E ETGermany
                                      MarvinTheRobot
                                      #76
                                      @etgermany
                                      ja ich hab grad dieses WE meine Pi5 bekommen mit 16GB ram und hab gestern mein System aus einem Backup "neu gebaut" - endlich kann ich meinen Slave in Pension schicken und alles am master laufen lassen - teste jetzt mal den toyota adapter und melde mich dann mit ergebnissen.
                                      • T tombox
                                        MarvinTheRobot
                                        #77
                                        @tombox
                                        hab mir soeben die github version geholt 0.2.6
                                        bekomme leider auch eine fehlermeldung beim verbinden:
                                        toyota.0
                                        2025-04-27 11:59:55.016	error	AxiosError: Request failed with status code 403
                                        toyota.0
                                        2025-04-27 11:59:55.016	error	{"status":{"messages":[{"responseCode":"APIGW-403","description":"Unauthorized","detailedDescription":"Unauthorized client "}]}}
                                          @tombox
                                          toyota.0
                                          toyota.0
                                          tombox
                                          #78
                                          @marvintherobot nochmal drüber installieren und ein größeren log bitte
