  4. Roborock - Adapter stürzt ständig ab
    6.8k
30 Beiträge 10 Kommentatoren 4.3k Aufrufe 9 Beobachtet
  • Michael SauerM Michael Sauer
    @glasfaser Hast recht.
    Hier der vollständige Log:
    roborock.0
    2023-09-29 20:44:27.997	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
    roborock.0
    2023-09-29 20:44:27.787	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-29 20:44:27.769	debug	Plugin sentry Initialize Plugin (enabled=true)
    roborock.0
    2023-09-29 20:43:40.797	warn	Failed to execute get_clean_summary on robot 5Eo7zrAcFZhjGJqyG5saSx TypeError: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-29 20:43:40.797	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
    roborock.0
    2023-09-29 20:43:40.791	warn	Failed to execute get_clean_record_map on robot 5Eo7zrAcFZhjGJqyG5saSx retry
    roborock.0
    2023-09-29 20:43:40.790	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
    roborock.0
    2023-09-29 20:43:40.775	debug	Length of message queue: 0
    roborock.0
    2023-09-29 20:43:40.774	debug	dps debug: {"id":3403,"result":["retry"]}
    roborock.0
    2023-09-29 20:43:40.614	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
    roborock.0
    2023-09-29 20:43:40.611	warn	setTimeout called, but adapter is shutting down
    roborock.0
    2023-09-29 20:43:40.610	warn	setTimeout called, but adapter is shutting down
    roborock.0
    2023-09-29 20:43:40.591	debug	Length of message queue: 0
    roborock.0
    2023-09-29 20:43:40.591	debug	dps debug: {"id":8382,"result":[{"begin":1695980402,"end":1695981303,"duration":901,"area":11682500,"error":0,"complete":0,"start_type":3,"clean_type":3,"finish_reason":62,"dust_collection_status":1,"avoid_count":2,"map_flag":0}]}
    roborock.0
    2023-09-29 20:43:40.379	warn	Failed to create map. retry
    roborock.0
    2023-09-29 20:43:40.377	warn	setTimeout called, but adapter is shutting down
    roborock.0
    2023-09-29 20:43:40.344	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-29 20:43:40.343	debug	Plugin sentry destroyed
    roborock.0
    2023-09-29 20:43:40.341	info	terminating
    roborock.0
    2023-09-29 20:43:40.321	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-29 20:43:40.320	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-29 20:43:40.319	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-29 20:43:40.319	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-29 20:43:40.316	debug	Length of message queue: 2
    roborock.0
    2023-09-29 20:43:40.316	debug	Not clearing messageQueue. null - 24752
    roborock.0
    2023-09-29 20:43:40.315	debug	dps debug: {"id":5996,"result":["retry"]}
    roborock.0
    2023-09-29 20:43:40.312	debug	Length of message queue: 2
    roborock.0
    2023-09-29 20:43:40.312	debug	dps debug: {"id":1492,"result":{"clean_time":202871,"clean_area":2843662500,"clean_count":144,"dust_collection_count":128,"records":[1695980402,1695978009,1695807600,1695805205,1695718805,1695634800,1695632403,1695546005,1695459607,1695375600,1695373208,1695286806,1695202799,1695200405,1695114008,1695030000,1695027609,1694941211,1694854807,1694770801]}}
    roborock.0
    2023-09-29 20:43:39.961	debug	downloadURL: https://github.com/AlexxIT/go2rtc/releases/download/v1.3.0/go2rtc_linux_arm
    roborock.0
    2023-09-29 20:43:39.961	debug	System type: go2rtc_linux_arm
    roborock.0
    2023-09-29 20:43:39.961	debug	platform: linux
    roborock.0
    2023-09-29 20:43:39.960	debug	arch: arm
    roborock.0
    2023-09-29 20:43:39.958	debug	Update map
    roborock.0
    2023-09-29 20:43:39.955	debug	Length of message queue: 1
    roborock.0
    2023-09-29 20:43:39.954	debug	dps debug: {"id":1643,"result":{"water_box_mode":201}}
    roborock.0
    2023-09-29 20:43:39.684	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_water_box_custom_mode
    roborock.0
    2023-09-29 20:43:39.681	debug	Length of message queue: 1
    roborock.0
    2023-09-29 20:43:39.679	debug	dps debug: {"id":3641,"result":[{"carpet_clean_mode":3}]}
    roborock.0
    2023-09-29 20:43:39.388	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_clean_mode
    roborock.0
    2023-09-29 20:43:39.386	debug	Length of message queue: 1
    roborock.0
    2023-09-29 20:43:39.384	debug	dps debug: {"id":5183,"result":[{"enable":1,"current_integral":1000,"current_high":500,"current_low":1000,"stall_time":10}]}
    roborock.0
    2023-09-29 20:43:39.303	debug	get_timer: []
    roborock.0
    2023-09-29 20:43:39.302	debug	Length of message queue: 2
    roborock.0
    2023-09-29 20:43:39.301	debug	dps debug: {"id":1710,"result":[]}
    roborock.0
    2023-09-29 20:43:39.299	debug	get_server_timer: [["1688127243968","on",0],["1688127295244","on",0]]
    roborock.0
    2023-09-29 20:43:39.298	debug	Length of message queue: 3
    roborock.0
    2023-09-29 20:43:39.297	debug	dps debug: {"id":9140,"result":[["1688127243968","on",0],["1688127295244","on",0]]}
    roborock.0
    2023-09-29 20:43:38.906	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_mode
    roborock.0
    2023-09-29 20:43:38.905	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_timer
    roborock.0
    2023-09-29 20:43:38.904	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_server_timer
    roborock.0
    2023-09-29 20:43:38.903	debug	Length of message queue: 1
    roborock.0
    2023-09-29 20:43:38.902	debug	dps debug: {"id":1525,"result":{"ssid":"S-Home","ip":"192.168.78.122","mac":"b0:4a:39:6b:e2:59","bssid":"b0:f2:08:d9:88:ed","rssi":-68}}
    roborock.0
    2023-09-29 20:43:38.555	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_network_info
    roborock.0
    2023-09-29 20:43:38.554	debug	Consumables of robot: [{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]
    roborock.0
    2023-09-29 20:43:38.551	debug	Length of message queue: 1
    roborock.0
    2023-09-29 20:43:38.550	debug	dps debug: {"id":1936,"result":[{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]}
    roborock.0
    2023-09-29 20:43:38.287	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_consumable
    roborock.0
    2023-09-29 20:43:38.286	debug	Mapped room matched: 11316198 with name: Küche
    roborock.0
    2023-09-29 20:43:38.285	debug	Mapped room matched: 11316194 with name: Flur
    roborock.0
    2023-09-29 20:43:38.284	debug	Mapped room matched: 12646380 with name: Esszimmer
    roborock.0
    2023-09-29 20:43:38.283	debug	Mapped room matched: 11309675 with name: Wohnzimmer
    roborock.0
    2023-09-29 20:43:38.282	debug	All mapped rooms: [[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]
    roborock.0
    2023-09-29 20:43:38.281	debug	Length of message queue: 1
    roborock.0
    2023-09-29 20:43:38.281	debug	dps debug: {"id":8606,"result":[[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]}
    roborock.0
    2023-09-29 20:43:38.238	debug	foreign.message attribute: 128 with value: 4
    roborock.0
    2023-09-29 20:43:38.237	debug	dps debug: {"128":4}
    roborock.0
    2023-09-29 20:43:38.143	debug	Length of message queue: 1
    roborock.0
    2023-09-29 20:43:38.142	debug	dps debug: {"id":8398,"result":[{"msg_ver":2,"msg_seq":126,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
    roborock.0
    2023-09-29 20:43:37.907	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_room_mapping
    roborock.0
    2023-09-29 20:43:37.891	debug	get_status: {"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}
    roborock.0
    2023-09-29 20:43:37.889	debug	Length of message queue: 0
    roborock.0
    2023-09-29 20:43:37.888	debug	dps debug: {"id":5982,"result":[{"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
    roborock.0
    2023-09-29 20:43:37.645	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_status
    roborock.0
    2023-09-29 20:43:37.644	debug	Latest data requested
    roborock.0
    2023-09-29 20:43:37.642	debug	Length of message queue: 0
    roborock.0
    2023-09-29 20:43:37.640	debug	dps debug: {"id":1305,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1695979052,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1695806345}]},{"mapFlag":1,"add_time":1692254347,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1688451884}]}]}]}
    roborock.0
    2023-09-29 20:43:37.486	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_multi_maps_list
    roborock.0
    2023-09-29 20:43:37.382	debug	Length of message queue: 0
    roborock.0
    2023-09-29 20:43:37.379	debug	dps debug: {"id":3178,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
    roborock.0
    2023-09-29 20:43:37.164	debug	Firmware features request
    roborock.0
    2023-09-29 20:43:37.164	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_fw_features
    roborock.0
    2023-09-29 20:43:37.160	debug	5Eo7zrAcFZhjGJqyG5saSx online. Starting mainUpdateInterval.
    roborock.0
    2023-09-29 20:43:23.804	debug	Robot key: roborock.vacuum.a51
    roborock.0
    2023-09-29 20:43:23.803	debug	RoomIDs debug: {"11309675":"Wohnzimmer","11314643":"Wohnzimmer1","11316194":"Flur","11316198":"Küche","11316201":"Küche1","11319794":"Badezimmer","11319802":"Spielzimmer","11319804":"Kinderzimmer","11319806":"Schlafzimmer","12646380":"Esszimmer","13421850":"Standard","13421863":"Phillip Schlafzimmer","13421865":"Badezimmer1"}
    roborock.0
    2023-09-29 20:43:23.801	info	MQTT initialized
    roborock.0
    2023-09-29 20:43:20.623	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
    roborock.0
    2023-09-29 20:43:20.491	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-29 20:43:20.474	debug	Plugin sentry Initialize Plugin (enabled=true)
    roborock.0
    2023-09-29 20:43:20.348	debug	States connected to redis: 127.0.0.1:6379
    roborock.0
    2023-09-29 20:43:20.336	debug	States create User PubSub Client
    roborock.0
    2023-09-29 20:43:20.335	debug	States create System PubSub Client
    roborock.0
    2023-09-29 20:43:20.327	debug	Redis States: Use Redis connection: 127.0.0.1:6379
    roborock.0
    2023-09-29 20:43:20.307	debug	Objects connected to redis: 127.0.0.1:6379
    roborock.0
    2023-09-29 20:43:20.300	debug	Objects client initialize lua scripts
    roborock.0
    2023-09-29 20:43:19.846	debug	Objects create User PubSub Client
    roborock.0
    2023-09-29 20:43:19.844	debug	Objects create System PubSub Client
    roborock.0
    2023-09-29 20:43:19.842	debug	Objects client ready ... initialize now
    roborock.0
    2023-09-29 20:43:19.803	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
            Machine ID: 5f09e0dc24364fc8951dcf01ea03774d
               Boot ID: 687f969e56cf41c2bcbbdd9cffef19bb
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     20:55:52 up 23:02,  1 user,  load average: 4.01, 3.35, 2.81
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=57.4'C
    volt=0.8500V
    *** Time and Time Zones ***
                   Local time: Fri 2023-09-29 20:55:53 CEST
               Universal time: Fri 2023-09-29 18:55:53 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        2.7G        111M         13M        1.0G        971M
    Swap:           99M         99M        0.0K
    Total:         3.9G        2.8G        111M
             3838 M total memory
             2706 M used memory
              670 M active memory
             2888 M inactive memory
              111 M free memory
              167 M buffer memory
              853 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G   19G   38G  34% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  2.2M  1.9G   1% /dev/shm
    tmpfs          tmpfs     1.9G   18M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/loop1     squashfs   41M   41M     0 100% /snap/certbot/3025
    /dev/loop0     squashfs   54M   54M     0 100% /snap/core20/2018
    /dev/loop2     squashfs   91M   91M     0 100% /snap/core/15929
    /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16098
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    TARGET               SOURCE         FSTYPE   OPTIONS
    /                    /dev/mmcblk0p2 ext4     rw,noatime
    |-/sys/fs/bpf        none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
    |-/snap/certbot/3025 /dev/loop1     squashfs ro,nodev,relatime
    |-/snap/core20/2018  /dev/loop0     squashfs ro,nodev,relatime
    |-/snap/core/15929   /dev/loop2     squashfs ro,nodev,relatime
    |-/snap/core/16098   /dev/loop3     squashfs ro,nodev,relatime
    `-/boot              /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.6G    /var/
    3.1G    /var/lib
    1.9G    /var/lib/mysql
    1.7G    /var/lib/mysql/iobroker
    525M    /var/lib/piVCCU3
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    197M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    695M    /opt/iobroker/iobroker-data/
    466M    /opt/iobroker/iobroker-data/files
    136M    /opt/iobroker/iobroker-data/backup-objects
    87M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    28M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
    20M     /opt/iobroker/iobroker-data/objects.json.migrated
    20M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    redis on 127.0.0.1
    States:                     redis on 127.0.0.1
    Core adapters versions
    admin:          6.10.2
    javascript:     7.1.4
    Adapters from github:   2
    Adapter State
      system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 42001
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
    + system.adapter.radar2.1                 : radar2                : iobroker                                 -  enabled
      system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
      system.adapter.roadtraffic.0            : roadtraffic           : iobroker                                 - disabled
      system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
      system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
      system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
    Adapter    "alarm"        : 3.3.13   , installed 3.3.13
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
    Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "eusec"        : 1.1.2    , installed 1.1.0  [Updatable]
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pvforecast"   : 2.8.1    , installed 2.8.1
    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
    Adapter    "ring"         : 5.0.0-alpha.0, installed 3.4.0 [Updatable]
    Adapter    "roadtraffic"  : 0.2.0    , installed 0.2.0
    Adapter    "roborock"     : 0.4.4    , installed 0.4.4
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
    Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
    Adapter    "sonos"        : 2.3.3    , installed 2.3.1  [Updatable]
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
    Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        32411
    States:         52049
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://phoscon.de/apt/deconz buster InRelease
    Ign:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:4 http://archive.raspberrypi.org/debian buster InRelease
    Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
    Err:6 https://deb.nodesource.com/node_18.x nodistro Release
      Could not handshake: Error in the pull function. [IP: 2606:4700:10::6816:41a 443]
    Get:7 https://apt.grafana.com stable InRelease [5984 B]
    Reading package lists...
    E: The repository 'https://deb.nodesource.com/node_18.x nodistro Release' no longer has a Release file.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1318755    12061/io.jarvis.0
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          22913      809/lighttpd
    tcp        0      0 192.168.78.83:42001     0.0.0.0:*               LISTEN      1001       87501      6525/io.hm-rpc.0
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        21806      724/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18356      738/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          332335     14432/cupsd
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       88205      6262/node-red
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       86309      6281/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       87235      6402/io.mqtt.0
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          22964      818/smbd
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21812      724/pihole-FTL
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        16875      808/mysqld
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          22965      818/smbd
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16819      772/redis-server 12
    tcp6       0      0 :::80                   :::*                    LISTEN      0          22914      809/lighttpd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3021956    27005/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2963823    25413/io.web.0
    tcp6       0      0 :::53                   :::*                    LISTEN      999        21808      724/pihole-FTL
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18358      738/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          332334     14432/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      113        136316     8949/grafana
    tcp6       0      0 :::445                  :::*                    LISTEN      0          22962      818/smbd
    tcp6       0      0 ::1:4711                :::*                    LISTEN      999        21813      724/pihole-FTL
    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16820      772/redis-server 12
    tcp6       0      0 :::139                  :::*                    LISTEN      0          22963      818/smbd
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       90354      6593/io.sonos.0
    udp        0      0 0.0.0.0:41879           0.0.0.0:*                           1001       601710     9411/io.backitup.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        21805      724/pihole-FTL
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       89218      6437/io.radar2.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       88118      6318/io.radar2.1
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16209      471/dhclient
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          332343     14433/cups-browsed
    udp        0      0 192.168.78.255:137      0.0.0.0:*                           0          21669      701/nmbd
    udp        0      0 192.168.78.83:137       0.0.0.0:*                           0          21668      701/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          21656      701/nmbd
    udp        0      0 192.168.78.255:138      0.0.0.0:*                           0          21671      701/nmbd
    udp        0      0 192.168.78.83:138       0.0.0.0:*                           0          21670      701/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          21657      701/nmbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17448      402/avahi-daemon: r
    udp        0      0 0.0.0.0:44942           0.0.0.0:*                           108        17450      402/avahi-daemon: r
    udp6       0      0 :::53                   :::*                                999        21807      724/pihole-FTL
    udp6       0      0 :::5353                 :::*                                108        17449      402/avahi-daemon: r
    udp6       0      0 :::52557                :::*                                108        17451      402/avahi-daemon: r
    2023-09-29 20:45:44.387  - warn: host.iobroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
    2023-09-29 20:46:00.229  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
        at /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/maps/core/core/modbus-client-core.js:79:156
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
    2023-09-29 20:46:00.249  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
    2023-09-29 20:48:08.985  - error: node-red.0 (6192) 29 Sep 20:48:08 - [error] [modbus-getter:n37000-37123] Error: Timed out
    2023-09-29 20:48:09.020  - error: node-red.0 (6192) 29 Sep 20:48:09 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
    2023-09-29 20:50:45.740  - info: javascript.0 (6113) script.js.common.Weather: Material Design Widgets: Wetter Skript triggered by 'linkeddevices.0.Sensor.Wetter.temperature'
    2023-09-29 20:55:00.944  - info: sql.0 (6216) Do not store value "NULL" for hm-rpc.0.LTK0086602.4.VALVE_STATE because no number
    2023-09-29 20:56:42.693  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Timed out
    2023-09-29 20:56:42.720  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
    Danke fürs ansehen.
    GlasfaserG Offline
    GlasfaserG Offline
    @michael-sauer sagte in Roborock - Adapter stürzt ständig ab:
    Bullseye ist aktuell
    free 111M
    Dein Speicher geht aus ...
    Redis OK , dann läuft aber
    redis-server 12
    Beta Tester ... OK ... aber nicht Aktuell ... up to Date!!!
    Dann
    Michael SauerM 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      free 111M
      redis-server 12
      Dann
      Michael SauerM Offline
      Michael Sauer
      @glasfaser Was möchtest du mir damit sagen?
      GlasfaserG S 2 Antworten Letzte Antwort
        GlasfaserG Offline
        GlasfaserG Offline
        @michael-sauer
        Ziemlich ausgelastet dein Raspberry und auch nicht ioBroker als "Beta Tester" gepflegt !
        Ich würde auf jeden Fall mal PiHole prüfen , denn ich habe oben geschrieben :
        @glasfaser sagte in Roborock - Adapter stürzt ständig ab:
        setInterval called, but adapter is shutting down
        Keine Verbindung !?
          SpacerX
          @michael-sauer ich bleibe dabei. Stelle die Maperstellung ab, dann sollte er laufen.
          DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
          • T Nicht stören
            T Nicht stören
            ticaki
            Der hängt in der Fehlerbehandlung(Map) beim Aufruf von Sentry. Das abschalten der Maperzeugung, so das diese Fehlerbehandlung nicht mehr aufgerufen wird, ist sicher ein Weg. @copystring
            Hab nur den Sauger aber nicht den Adapter im Einsatz, sollte wohl ein github issue aufgemacht werden.
            https://github.com/copystring/ioBroker.roborock
            Spenden
            Michael SauerM A 2 Antworten Letzte Antwort
              habe das Problem das ich den Adapter bisher nicht richtig nutzen kann.
              Mein Saugroboter ist ein S8+. Verbindung wird aufgebaut jedoch stürzt der Adapter im Minuten Takt ab.
              Habe den Adapter auf Debug gestellt:
              roborock.0
              2023-09-28 20:32:33.060	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
              roborock.0
              2023-09-28 20:32:33.043	error	adapter disabled
              roborock.0
              2023-09-28 20:32:33.023	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              roborock.0
              2023-09-28 20:31:50.150	warn	setInterval called, but adapter is shutting down
              roborock.0
              2023-09-28 20:31:44.518	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2023-09-28 20:31:44.515	info	terminating
              roborock.0
              2023-09-28 20:31:44.502	error	Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 20:31:44.502	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
              roborock.0
              2023-09-28 20:31:44.500	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 20:31:44.499	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-09-28 20:31:32.436	info	MQTT initialized
              roborock.0
              2023-09-28 20:31:27.501	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
              roborock.0
              2023-09-28 20:31:26.946	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              roborock.0
              2023-09-28 20:30:35.148	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2023-09-28 20:30:35.143	info	terminating
              roborock.0
              2023-09-28 20:30:35.127	error	Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 20:30:35.126	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
              roborock.0
              2023-09-28 20:30:35.124	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 20:30:35.122	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-09-28 20:30:08.135	info	MQTT initialized
              roborock.0
              2023-09-28 20:30:04.677	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
              roborock.0
              2023-09-28 20:30:04.393	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              roborock.0
              2023-09-28 20:01:20.818	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2023-09-28 20:01:20.815	info	terminating
              roborock.0
              2023-09-28 20:01:20.806	error	Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 20:01:20.806	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
              roborock.0
              2023-09-28 20:01:20.805	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 20:01:20.804	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-09-28 20:01:06.531	info	MQTT initialized
              roborock.0
              2023-09-28 20:01:05.376	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
              roborock.0
              2023-09-28 20:01:05.189	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              roborock.0
              2023-09-28 20:00:24.153	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2023-09-28 20:00:24.150	info	terminating
              roborock.0
              2023-09-28 20:00:24.120	error	Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 20:00:24.119	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
              roborock.0
              2023-09-28 20:00:24.118	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 20:00:24.116	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-09-28 20:00:08.550	info	MQTT initialized
              roborock.0
              2023-09-28 20:00:03.663	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
              roborock.0
              2023-09-28 20:00:03.375	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              roborock.0
              2023-09-28 19:59:19.285	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2023-09-28 19:59:19.282	info	terminating
              roborock.0
              2023-09-28 19:59:19.274	error	Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 19:59:19.273	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
              roborock.0
              2023-09-28 19:59:19.272	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-28 19:59:19.271	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-09-28 19:59:07.700	info	MQTT initialized
              roborock.0
              2023-09-28 19:59:05.970	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
              roborock.0
              2023-09-28 19:59:05.760	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              roborock.0
              2023-09-28 19:58:55.753	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              roborock.0
              2023-09-28 19:58:55.751	info	terminating
              roborock.0
              2023-09-28 19:58:55.746	info	Got terminate signal TERMINATE_YOURSELF
              Jemand eine Idee?
              copystringC Offline
              copystringC Offline
              copystring
              @michael-sauer Die Kartenerstellung kann auf einem RPi nicht funktionieren. Da gibt es ein Problem mit der Canvas-Bibliothek.
              https://github.com/copystring/ioBroker.roborock#map-creation-does-not-work-on-raspberry-pi
              Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
              https://paypal.me/copystring
              • T ticaki
                Michael Sauer
                @ticaki sagte in Roborock - Adapter stürzt ständig ab:
                Das war die Lösung. Danke.
                • T ticaki
                  Almeda
                  @ticaki said in Roborock - Adapter stürzt ständig ab:
                  ich möchte mich an dieses Thema kurz mit anhängen. Nutze den Roborock Adapter seit ca. 4 Wochen und habe seit Anbeginn, trotz ausgeschalteter Map Erstellung, das Problem, dass der Adapter laut dem Host ständig abstürzt und er ihn daher regelhaft nach 1-2 Tagen aus dem Rennen nimmt und den Neustart verhindert.
                  Tatsächlich hat die Einrichtung nach der Installation problemlos geklappt und auch die Anbindung an Node-Red zum Ausspielen der Stati über Telegramm hat sofort funktioniert.
                  Eine De- und Neuinstallation des Apdaters hat nichts gebracht. Ich habe dann auf das aktuelle Update gewartet, weil ich es für ein vllt. bekanntes Problem hielt. Das Update von vor einigen Tagen hat jedoch keine Besserung gebracht.
                  IoB läuft auf einem Synology 918+ mit ausreichend RAM. Kein anderer Adapter macht Probleme.
                  Kann einer weiterhelfen?
                  Vielen Dank
                  Almeda
                  Thomas BraunT haselchenH 2 Antworten Letzte Antwort
                  • A Almeda
                    Vielen Dank
                    Almeda
                    @almeda sagte in Roborock - Adapter stürzt ständig ab:
                    Ohne Log? Schwierig.
                    • A Almeda
                      Vielen Dank
                      Almeda
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @almeda
                      Warum nicht den Mihome-Vacuum?
                      Der funktioniert völlig unkompliziert und macht meines Erachtens das Gleiche wie Dein Adapter.
                      Bei meinem weiß ich allerdings, dass er funktioniert 😉
                        Almeda
                        @thomas-braun said in Roborock - Adapter stürzt ständig ab:
                        Sorry, vergessen anzuhängen. Es erscheint die Warnung:
                        Failed to execute get_fw_features on robot 4d98R7TEpn6C0ZcYPNY52Q Error: Local request with id 5 with method get_fw_features timed out after 10 seconds
                        @haselchen said in Roborock - Adapter stürzt ständig ab:
                        @almeda
                        Den hatte ich bisher nicht auf dem Schirm. Ich danke dir für den Hinweis. Probiere ihn gerne mal aus!
                        • A Almeda
                          @almeda
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @almeda
                          Gib dann mal bitte Feedback….
                          • haselchenH haselchen
                            @almeda
                            Almeda
                            @almeda
                            Eben versucht und in der Dokumentation festgestellt, dass der S7 nicht funktioniert. Damit ist die Option leider auch raus :(
                            • A Almeda
                              @almeda
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @almeda
                              Wird der Roboter in der Instanz gefunden ?
                              Werden Objekte angelegt ?
                              Was sagt das Log?
                              Da S8 und ich meine S10 unterstützt werden, warum sollte der S7 da nicht bei sein?
                              Hab noch nen S50 2. Gen.
                                @almeda
                                Was sagt das Log?
                                Almeda
                                schrieb am zuletzt editiert von Almeda
                                @almeda
                                Was sagt das Log?
                                So zurück aus dem Urlaub und Zeit fürs Hobby ;)
                                Danke für deine Rückfrage:
                                Es geht ja schon damit los, dass der Mihome-Vacuum Adapter einen Xiaomi Login will, denn ich für den Roborock S7 ja nicht habe. Der Roborock wird ja über den Roborock eigenen Cloudserver verwaltet.
                                Darüber habe ich mich dann gewundert und im Logg nachgesehen. Da steht eindeutig drin, dass alle Roboter, ausgenommen S7, unterstützt werden. Liegt wohl daran, dass der S7 anders kommuniziert, als die anderen Roboter.
                                Zurück zu meinem eigentlichen Problem eines ständig abstürzenden Roborock-Adapters:
                                Seit dem letzten Update ist der Adapter nicht mehr abgestürzt. Aber ob er stabil läuft, kann ich auch nicht sagen, da ich nun gelbe Warnungen bekomme:
                                code_text
                                ```2024-05-24 00:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                2024-05-24 00:44:00.485 - warn: roborock.0 (508) MQTT connection close.
                                2024-05-24 00:44:00.485 - warn: roborock.0 (508) MQTT connection reconnect.
                                2024-05-24 01:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                2024-05-24 01:44:00.445 - warn: roborock.0 (508) MQTT connection close.
                                2024-05-24 01:44:00.445 - warn: roborock.0 (508) MQTT connection reconnect.
                                2024-05-24 02:44:00.429 - warn: roborock.0 (508) Reconnecting mqtt client!
                                2024-05-24 02:44:00.446 - warn: roborock.0 (508) MQTT connection close.
                                2024-05-24 02:44:00.446 - warn: roborock.0 (508) MQTT connection reconnect.
                                2024-05-24 03:10:28.073 - warn: roborock.0 (508) Unable to decode message for 4d98R7TEpn6C0ZcYPNY52Q. The the device is most likely offline. data: {"version":"1.0","seq":74,"random":641679,"timestamp":1716513028,"protocol":500,"payload":{"type":"Buffer","data":[123,34,111,110,108,105,110,101,34,58,102,97,108,115,101,125]},"crc32":2579086837}
                                2024-05-24 03:11:07.991 - warn: roborock.0 (508) Unable to decode message for 4d98R7TEpn6C0ZcYPNY52Q. The the device is most likely offline. data: {"version":"1.0","seq":87,"random":721864,"timestamp":1716513067,"protocol":500,"payload":{"type":"Buffer","data":[123,34,111,110,108,105,110,101,34,58,116,114,117,101,125]},"crc32":3231908517}
                                2024-05-24 03:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                2024-05-24 03:44:00.445 - warn: roborock.0 (508) MQTT connection close.
                                2024-05-24 03:44:00.445 - warn: roborock.0 (508) MQTT connection reconnect.
                                2024-05-24 04:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                2024-05-24 04:44:00.445 - warn: roborock.0 (508) MQTT connection close.
                                2024-05-24 04:44:00.446 - warn: roborock.0 (508) MQTT connection reconnect.
                                2024-05-24 05:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                2024-05-24 05:44:00.446 - warn: roborock.0 (508) MQTT connection close.
                                2024-05-24 05:44:00.446 - warn: roborock.0 (508) MQTT connection reconnect.```
                                code_text
                                So geht das jede Stunde in der 44. Minute der Stunde einmal durch...
                                • A Almeda
                                  @almeda
                                  Was sagt das Log?
                                  code_text
                                  code_text
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @almeda
                                  Wie gesagt, beim Roborock Adaper wäre ich raus.
                                  Was spricht aber dagegen, dass Du ihn in der Xiaomi App registrierst?
                                  Hab ich, und logischerweise alle anderen Nutzer, auch.
                                  Und dann könnte man mal weitersehen , wie es im Mihome-Vacuum Adapter aussieht.
                                  • Z Offline
                                    Z Offline
                                    ZeroQool
                                    Wenn ich den Adapter installieren möchte kommt der Fehler:
                                    $ iobroker add roborock --host iobroker
                                    file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5import tar from 'tar'; ^^^SyntaxError: The requested module 'tar' does not provide an export named 'default' at ModuleJob._instantiate (node:internal/modules/esm/module_job:134:21) at async ModuleJob.run (node:internal/modules/esm/module_job:217:5) at async ModuleLoader.import (node:internal/modules/esm/loader:316:24)Node.js v20.15.1
                                    ERROR: Process exited with code 1
                                    Weißt jemand was das sein könnte?
                                    • Z ZeroQool
                                      wendy2702W Online
                                      wendy2702W Online
                                      @zeroqool warum Doppelpost?
                                      https://forum.iobroker.net/topic/67186/neuer-adapter-für-roborock-staubsauger/810#
                                      Zumal es hier um Absturz geht.
                                      Z 1 Antwort Letzte Antwort
                                      • wendy2702W wendy2702
                                        Z Offline
                                        Z Offline
                                        ZeroQool
                                        @wendy2702 Habe erst danach gesehen, dass dies der falsche Thread ist.
