  4. Roborock - Adapter stürzt ständig ab
    6.8k
30 Beiträge 10 Kommentatoren 4.3k Aufrufe 9 Beobachtet
  • Michael SauerM Michael Sauer
    habe das Problem das ich den Adapter bisher nicht richtig nutzen kann.
    Mein Saugroboter ist ein S8+. Verbindung wird aufgebaut jedoch stürzt der Adapter im Minuten Takt ab.
    Habe den Adapter auf Debug gestellt:
    roborock.0
    2023-09-28 20:32:33.060	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    roborock.0
    2023-09-28 20:32:33.043	error	adapter disabled
    roborock.0
    2023-09-28 20:32:33.023	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 20:31:50.150	warn	setInterval called, but adapter is shutting down
    roborock.0
    2023-09-28 20:31:44.518	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 20:31:44.515	info	terminating
    roborock.0
    2023-09-28 20:31:44.502	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:31:44.502	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 20:31:44.500	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:31:44.499	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 20:31:32.436	info	MQTT initialized
    roborock.0
    2023-09-28 20:31:27.501	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 20:31:26.946	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 20:30:35.148	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 20:30:35.143	info	terminating
    roborock.0
    2023-09-28 20:30:35.127	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:30:35.126	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 20:30:35.124	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:30:35.122	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 20:30:08.135	info	MQTT initialized
    roborock.0
    2023-09-28 20:30:04.677	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 20:30:04.393	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 20:01:20.818	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 20:01:20.815	info	terminating
    roborock.0
    2023-09-28 20:01:20.806	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:01:20.806	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 20:01:20.805	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:01:20.804	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 20:01:06.531	info	MQTT initialized
    roborock.0
    2023-09-28 20:01:05.376	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 20:01:05.189	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 20:00:24.153	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 20:00:24.150	info	terminating
    roborock.0
    2023-09-28 20:00:24.120	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:00:24.119	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 20:00:24.118	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 20:00:24.116	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 20:00:08.550	info	MQTT initialized
    roborock.0
    2023-09-28 20:00:03.663	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 20:00:03.375	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 19:59:19.285	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-28 19:59:19.282	info	terminating
    roborock.0
    2023-09-28 19:59:19.274	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 19:59:19.273	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-28 19:59:19.272	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-28 19:59:19.271	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-28 19:59:07.700	info	MQTT initialized
    roborock.0
    2023-09-28 19:59:05.970	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
    roborock.0
    2023-09-28 19:59:05.760	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-28 19:58:55.753	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    roborock.0
    2023-09-28 19:58:55.751	info	terminating
    roborock.0
    2023-09-28 19:58:55.746	info	Got terminate signal TERMINATE_YOURSELF
    Jemand eine Idee?
    GlasfaserG Offline
    GlasfaserG Offline
    @michael-sauer
    kannst du den Thread Titel anpassen auf :
    roborock Adapter stürzt ständig ab
    • GlasfaserG Glasfaser
      @michael-sauer sagte in Adapter stürzt ständig ab:
      Version 0.4.4
      Die Version ist BETA , läuft es auch nicht mit dem Stable !?
      Keine Verbindung !?
      Stelle mal auf DEBUG
      Michael SauerM Offline
      Michael Sauer
      @glasfaser
      Steht auf Debug. System ist aktualisiert:
      roborock.0
      2023-09-29 08:17:46.345	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      roborock.0
      2023-09-29 08:17:46.334	error	adapter disabled
      roborock.0
      2023-09-29 08:17:46.317	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      roborock.0
      2023-09-29 08:17:10.665	info	terminating
      roborock.0
      2023-09-29 08:17:10.373	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
      roborock.0
      2023-09-29 08:17:10.370	warn	setTimeout called, but adapter is shutting down
      roborock.0
      2023-09-29 08:17:10.369	warn	setTimeout called, but adapter is shutting down
      roborock.0
      2023-09-29 08:17:10.271	warn	setTimeout called, but adapter is shutting down
      roborock.0
      roborock.0
      2023-09-29 08:17:10.185	warn	setTimeout called, but adapter is shutting down
      roborock.0
      2023-09-29 08:17:10.181	warn	Failed to create map. retry
      roborock.0
      2023-09-29 08:17:10.161	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2023-09-29 08:17:10.160	info	terminating
      roborock.0
      2023-09-29 08:17:10.146	error	Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-29 08:17:10.146	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
      roborock.0
      2023-09-29 08:17:10.145	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-29 08:17:10.144	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      2023-09-29 08:17:07.454	warn	Failed to execute load_multi_map on robot 5Eo7zrAcFZhjGJqyG5saSx Error: There was an error processing the request with id 3224 error: {"code":-10003,"message":"action locked"}
      roborock.0
      2023-09-29 08:16:54.267	info	MQTT initialized
      roborock.0
      2023-09-29 08:16:52.229	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
      roborock.0
      2023-09-29 08:16:52.080	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      S GlasfaserG 2 Antworten Letzte Antwort
        @glasfaser
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        SpacerX
        schrieb am zuletzt editiert von SpacerX
        @michael-sauer Hast du einen Raspi laufen? Wenn ja dort funzt das mit der Map nicht richtig. Deshalb vielleicht die deine Probs. Schau mal in den Beitrag zum Adapter.
        https://forum.iobroker.net/topic/67186/neuer-adapter-f%C3%BCr-roborock-staubsauger
        DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
          @glasfaser
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          GlasfaserG Offline
          GlasfaserG Offline
          @michael-sauer sagte in Roborock - Adapter stürzt ständig ab:
          Steht auf Debug.
          Nö ist nicht , ist die gleiche Info wie zuvor !
          Die Adapter Instanz auf DEBUG stellen .
          Beispiel :
          Was war hiermit !?
          @glasfaser sagte in Roborock - Adapter stürzt ständig ab:
          Und Zeige mal die Full Ausgabe von
          iob diag
          Michael SauerM 1 Antwort Letzte Antwort
          • T Nicht stören
            T Nicht stören
            ticaki
            Kannst du das versenden von anonymisierten Daten mal aktivieren? Sentry
            Spenden
              Steht auf Debug.
              Beispiel :
              Was war hiermit !?
              iob diag
              Michael Sauer
              @glasfaser Hast recht.
              Hier der vollständige Log:
              roborock.0
              2023-09-29 20:44:27.997	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
              roborock.0
              2023-09-29 20:44:27.787	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              roborock.0
              2023-09-29 20:44:27.769	debug	Plugin sentry Initialize Plugin (enabled=true)
              roborock.0
              2023-09-29 20:43:40.797	warn	Failed to execute get_clean_summary on robot 5Eo7zrAcFZhjGJqyG5saSx TypeError: Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-29 20:43:40.797	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
              roborock.0
              2023-09-29 20:43:40.791	warn	Failed to execute get_clean_record_map on robot 5Eo7zrAcFZhjGJqyG5saSx retry
              roborock.0
              2023-09-29 20:43:40.790	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
              roborock.0
              2023-09-29 20:43:40.775	debug	Length of message queue: 0
              roborock.0
              2023-09-29 20:43:40.774	debug	dps debug: {"id":3403,"result":["retry"]}
              roborock.0
              2023-09-29 20:43:40.614	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
              roborock.0
              2023-09-29 20:43:40.611	warn	setTimeout called, but adapter is shutting down
              roborock.0
              2023-09-29 20:43:40.610	warn	setTimeout called, but adapter is shutting down
              roborock.0
              2023-09-29 20:43:40.591	debug	Length of message queue: 0
              roborock.0
              2023-09-29 20:43:40.591	debug	dps debug: {"id":8382,"result":[{"begin":1695980402,"end":1695981303,"duration":901,"area":11682500,"error":0,"complete":0,"start_type":3,"clean_type":3,"finish_reason":62,"dust_collection_status":1,"avoid_count":2,"map_flag":0}]}
              roborock.0
              2023-09-29 20:43:40.379	warn	Failed to create map. retry
              roborock.0
              2023-09-29 20:43:40.377	warn	setTimeout called, but adapter is shutting down
              roborock.0
              2023-09-29 20:43:40.344	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2023-09-29 20:43:40.343	debug	Plugin sentry destroyed
              roborock.0
              2023-09-29 20:43:40.341	info	terminating
              roborock.0
              2023-09-29 20:43:40.321	error	Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-29 20:43:40.320	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
              roborock.0
              2023-09-29 20:43:40.319	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
              roborock.0
              2023-09-29 20:43:40.319	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-09-29 20:43:40.316	debug	Length of message queue: 2
              roborock.0
              2023-09-29 20:43:40.316	debug	Not clearing messageQueue. null - 24752
              roborock.0
              2023-09-29 20:43:40.315	debug	dps debug: {"id":5996,"result":["retry"]}
              roborock.0
              2023-09-29 20:43:40.312	debug	Length of message queue: 2
              roborock.0
              2023-09-29 20:43:40.312	debug	dps debug: {"id":1492,"result":{"clean_time":202871,"clean_area":2843662500,"clean_count":144,"dust_collection_count":128,"records":[1695980402,1695978009,1695807600,1695805205,1695718805,1695634800,1695632403,1695546005,1695459607,1695375600,1695373208,1695286806,1695202799,1695200405,1695114008,1695030000,1695027609,1694941211,1694854807,1694770801]}}
              roborock.0
              2023-09-29 20:43:39.961	debug	downloadURL: https://github.com/AlexxIT/go2rtc/releases/download/v1.3.0/go2rtc_linux_arm
              roborock.0
              2023-09-29 20:43:39.961	debug	System type: go2rtc_linux_arm
              roborock.0
              2023-09-29 20:43:39.961	debug	platform: linux
              roborock.0
              2023-09-29 20:43:39.960	debug	arch: arm
              roborock.0
              2023-09-29 20:43:39.958	debug	Update map
              roborock.0
              2023-09-29 20:43:39.955	debug	Length of message queue: 1
              roborock.0
              2023-09-29 20:43:39.954	debug	dps debug: {"id":1643,"result":{"water_box_mode":201}}
              roborock.0
              2023-09-29 20:43:39.684	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_water_box_custom_mode
              roborock.0
              2023-09-29 20:43:39.681	debug	Length of message queue: 1
              roborock.0
              2023-09-29 20:43:39.679	debug	dps debug: {"id":3641,"result":[{"carpet_clean_mode":3}]}
              roborock.0
              2023-09-29 20:43:39.388	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_clean_mode
              roborock.0
              2023-09-29 20:43:39.386	debug	Length of message queue: 1
              roborock.0
              2023-09-29 20:43:39.384	debug	dps debug: {"id":5183,"result":[{"enable":1,"current_integral":1000,"current_high":500,"current_low":1000,"stall_time":10}]}
              roborock.0
              2023-09-29 20:43:39.303	debug	get_timer: []
              roborock.0
              2023-09-29 20:43:39.302	debug	Length of message queue: 2
              roborock.0
              2023-09-29 20:43:39.301	debug	dps debug: {"id":1710,"result":[]}
              roborock.0
              2023-09-29 20:43:39.299	debug	get_server_timer: [["1688127243968","on",0],["1688127295244","on",0]]
              roborock.0
              2023-09-29 20:43:39.298	debug	Length of message queue: 3
              roborock.0
              2023-09-29 20:43:39.297	debug	dps debug: {"id":9140,"result":[["1688127243968","on",0],["1688127295244","on",0]]}
              roborock.0
              2023-09-29 20:43:38.906	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_mode
              roborock.0
              2023-09-29 20:43:38.905	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_timer
              roborock.0
              2023-09-29 20:43:38.904	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_server_timer
              roborock.0
              2023-09-29 20:43:38.903	debug	Length of message queue: 1
              roborock.0
              2023-09-29 20:43:38.902	debug	dps debug: {"id":1525,"result":{"ssid":"S-Home","ip":"192.168.78.122","mac":"b0:4a:39:6b:e2:59","bssid":"b0:f2:08:d9:88:ed","rssi":-68}}
              roborock.0
              2023-09-29 20:43:38.555	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_network_info
              roborock.0
              2023-09-29 20:43:38.554	debug	Consumables of robot: [{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]
              roborock.0
              2023-09-29 20:43:38.551	debug	Length of message queue: 1
              roborock.0
              2023-09-29 20:43:38.550	debug	dps debug: {"id":1936,"result":[{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]}
              roborock.0
              2023-09-29 20:43:38.287	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_consumable
              roborock.0
              2023-09-29 20:43:38.286	debug	Mapped room matched: 11316198 with name: Küche
              roborock.0
              2023-09-29 20:43:38.285	debug	Mapped room matched: 11316194 with name: Flur
              roborock.0
              2023-09-29 20:43:38.284	debug	Mapped room matched: 12646380 with name: Esszimmer
              roborock.0
              2023-09-29 20:43:38.283	debug	Mapped room matched: 11309675 with name: Wohnzimmer
              roborock.0
              2023-09-29 20:43:38.282	debug	All mapped rooms: [[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]
              roborock.0
              2023-09-29 20:43:38.281	debug	Length of message queue: 1
              roborock.0
              2023-09-29 20:43:38.281	debug	dps debug: {"id":8606,"result":[[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]}
              roborock.0
              2023-09-29 20:43:38.238	debug	foreign.message attribute: 128 with value: 4
              roborock.0
              2023-09-29 20:43:38.237	debug	dps debug: {"128":4}
              roborock.0
              2023-09-29 20:43:38.143	debug	Length of message queue: 1
              roborock.0
              2023-09-29 20:43:38.142	debug	dps debug: {"id":8398,"result":[{"msg_ver":2,"msg_seq":126,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
              roborock.0
              2023-09-29 20:43:37.907	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_room_mapping
              roborock.0
              2023-09-29 20:43:37.891	debug	get_status: {"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}
              roborock.0
              2023-09-29 20:43:37.889	debug	Length of message queue: 0
              roborock.0
              2023-09-29 20:43:37.888	debug	dps debug: {"id":5982,"result":[{"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
              roborock.0
              2023-09-29 20:43:37.645	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_status
              roborock.0
              2023-09-29 20:43:37.644	debug	Latest data requested
              roborock.0
              2023-09-29 20:43:37.642	debug	Length of message queue: 0
              roborock.0
              2023-09-29 20:43:37.640	debug	dps debug: {"id":1305,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1695979052,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1695806345}]},{"mapFlag":1,"add_time":1692254347,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1688451884}]}]}]}
              roborock.0
              2023-09-29 20:43:37.486	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_multi_maps_list
              roborock.0
              2023-09-29 20:43:37.382	debug	Length of message queue: 0
              roborock.0
              2023-09-29 20:43:37.379	debug	dps debug: {"id":3178,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
              roborock.0
              2023-09-29 20:43:37.164	debug	Firmware features request
              roborock.0
              2023-09-29 20:43:37.164	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_fw_features
              roborock.0
              2023-09-29 20:43:37.160	debug	5Eo7zrAcFZhjGJqyG5saSx online. Starting mainUpdateInterval.
              roborock.0
              2023-09-29 20:43:23.804	debug	Robot key: roborock.vacuum.a51
              roborock.0
              2023-09-29 20:43:23.803	debug	RoomIDs debug: {"11309675":"Wohnzimmer","11314643":"Wohnzimmer1","11316194":"Flur","11316198":"Küche","11316201":"Küche1","11319794":"Badezimmer","11319802":"Spielzimmer","11319804":"Kinderzimmer","11319806":"Schlafzimmer","12646380":"Esszimmer","13421850":"Standard","13421863":"Phillip Schlafzimmer","13421865":"Badezimmer1"}
              roborock.0
              2023-09-29 20:43:23.801	info	MQTT initialized
              roborock.0
              2023-09-29 20:43:20.623	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
              roborock.0
              2023-09-29 20:43:20.491	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              roborock.0
              2023-09-29 20:43:20.474	debug	Plugin sentry Initialize Plugin (enabled=true)
              roborock.0
              2023-09-29 20:43:20.348	debug	States connected to redis: 127.0.0.1:6379
              roborock.0
              2023-09-29 20:43:20.336	debug	States create User PubSub Client
              roborock.0
              2023-09-29 20:43:20.335	debug	States create System PubSub Client
              roborock.0
              2023-09-29 20:43:20.327	debug	Redis States: Use Redis connection: 127.0.0.1:6379
              roborock.0
              2023-09-29 20:43:20.307	debug	Objects connected to redis: 127.0.0.1:6379
              roborock.0
              2023-09-29 20:43:20.300	debug	Objects client initialize lua scripts
              roborock.0
              2023-09-29 20:43:19.846	debug	Objects create User PubSub Client
              roborock.0
              2023-09-29 20:43:19.844	debug	Objects create System PubSub Client
              roborock.0
              2023-09-29 20:43:19.842	debug	Objects client ready ... initialize now
              roborock.0
              2023-09-29 20:43:19.803	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer
                      Machine ID: 5f09e0dc24364fc8951dcf01ea03774d
                         Boot ID: 687f969e56cf41c2bcbbdd9cffef19bb
                Operating System: Raspbian GNU/Linux 10 (buster)
                          Kernel: Linux 5.10.103-v7l+
                    Architecture: arm
              Model           : Raspberry Pi 4 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : armv7l
              Userland        : armhf
              Systemuptime and Load:
               20:55:52 up 23:02,  1 user,  load average: 4.01, 3.35, 2.81
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              Other values than 0x0 hint to temperature/voltage problems
              temp=57.4'C
              volt=0.8500V
              *** Time and Time Zones ***
                             Local time: Fri 2023-09-29 20:55:53 CEST
                         Universal time: Fri 2023-09-29 18:55:53 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:           3.8G        2.7G        111M         13M        1.0G        971M
              Swap:           99M         99M        0.0K
              Total:         3.9G        2.8G        111M
                       3838 M total memory
                       2706 M used memory
                        670 M active memory
                       2888 M inactive memory
                        111 M free memory
                        167 M buffer memory
                        853 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4       59G   19G   38G  34% /
              devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
              tmpfs          tmpfs     1.9G  2.2M  1.9G   1% /dev/shm
              tmpfs          tmpfs     1.9G   18M  1.9G   1% /run
              tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
              /dev/loop1     squashfs   41M   41M     0 100% /snap/certbot/3025
              /dev/loop0     squashfs   54M   54M     0 100% /snap/core20/2018
              /dev/loop2     squashfs   91M   91M     0 100% /snap/core/15929
              /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16098
              /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
              tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
              TARGET               SOURCE         FSTYPE   OPTIONS
              /                    /dev/mmcblk0p2 ext4     rw,noatime
              |-/sys/fs/bpf        none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
              |-/snap/certbot/3025 /dev/loop1     squashfs ro,nodev,relatime
              |-/snap/core20/2018  /dev/loop0     squashfs ro,nodev,relatime
              |-/snap/core/15929   /dev/loop2     squashfs ro,nodev,relatime
              |-/snap/core/16098   /dev/loop3     squashfs ro,nodev,relatime
              `-/boot              /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              3.6G    /var/
              3.1G    /var/lib
              1.9G    /var/lib/mysql
              1.7G    /var/lib/mysql/iobroker
              525M    /var/lib/piVCCU3
              Archived and active journals take up 16.0M in the file system.
              /opt/iobroker/backups:
              197M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              695M    /opt/iobroker/iobroker-data/
              466M    /opt/iobroker/iobroker-data/files
              136M    /opt/iobroker/iobroker-data/backup-objects
              87M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              28M     /opt/iobroker/iobroker-data/objects.jsonl
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
              20M     /opt/iobroker/iobroker-data/objects.json.migrated
              20M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.18.0
              /usr/bin/node           v18.18.0
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Installed: 18.18.0-1nodesource1
                Candidate: 18.18.0-1nodesource1
                Version table:
               *** 18.18.0-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                   18.17.1-1nodesource1 500
                   18.17.0-1nodesource1 500
                   18.16.1-1nodesource1 500
                   18.16.0-1nodesource1 500
                   18.15.0-1nodesource1 500
                   18.14.2-1nodesource1 500
                   18.14.1-1nodesource1 500
                   18.14.0-1nodesource1 500
                   18.13.0-1nodesource1 500
                   18.12.0-1nodesource1 500
                   18.11.0-1nodesource1 500
                   18.10.0-1nodesource1 500
                   18.9.1-1nodesource1 500
                   18.9.0-1nodesource1 500
                   18.8.0-1nodesource1 500
                   18.7.0-1nodesource1 500
                   18.6.0-1nodesource1 500
                   18.5.0-1nodesource1 500
                   18.4.0-1nodesource1 500
                   18.3.0-1nodesource1 500
                   18.2.0-1nodesource1 500
                   18.1.0-1nodesource1 500
                   18.0.0-1nodesource1 500
                   10.24.0~dfsg-1~deb10u3 500
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              At least one iobroker host is running.
              Objects type: redis
              States  type: redis
              No configuration change needed.
              Multihost discovery server: disabled
              Discovery authentication:   enabled
              Persistent activation:      disabled
              Objects:                    redis on 127.0.0.1
              States:                     redis on 127.0.0.1
              Core adapters versions
              admin:          6.10.2
              javascript:     7.1.4
              Adapters from github:   2
              Adapter State
                system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
              + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
                system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
              + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
                system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 42001
              + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
              + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
              + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
              + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
              + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
              + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
              + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
              + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
              + system.adapter.radar2.1                 : radar2                : iobroker                                 -  enabled
                system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
                system.adapter.roadtraffic.0            : roadtraffic           : iobroker                                 - disabled
                system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
              + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
              + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
                system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
              + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
              + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
              + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): beta
              Installed ioBroker-Instances
              Used repository: beta
              Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
              Adapter    "alarm"        : 3.3.13   , installed 3.3.13
              Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
              Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
              Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
              Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "email"        : 1.2.0    , installed 1.2.0
              Adapter    "eusec"        : 1.1.2    , installed 1.1.0  [Updatable]
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
              Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
              Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "info"         : 2.0.0    , installed 2.0.0
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
              Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
              Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
              Adapter    "node-red"     : 4.0.3    , installed 4.0.3
              Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "pvforecast"   : 2.8.1    , installed 2.8.1
              Adapter    "radar2"       : 2.0.7    , installed 2.0.7
              Adapter    "ring"         : 5.0.0-alpha.0, installed 3.4.0 [Updatable]
              Adapter    "roadtraffic"  : 0.2.0    , installed 0.2.0
              Adapter    "roborock"     : 0.4.4    , installed 0.4.4
              Adapter    "samsung"      : 0.5.11   , installed 0.5.11
              Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
              Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
              Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
              Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
              Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
              Adapter    "sonos"        : 2.3.3    , installed 2.3.1  [Updatable]
              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
              Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
              Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
              Objects and States
              Objects:        32411
              States:         52049
              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:2 http://phoscon.de/apt/deconz buster InRelease
              Ign:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:4 http://archive.raspberrypi.org/debian buster InRelease
              Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
              Err:6 https://deb.nodesource.com/node_18.x nodistro Release
                Could not handshake: Error in the pull function. [IP: 2606:4700:10::6816:41a 443]
              Get:7 https://apt.grafana.com stable InRelease [5984 B]
              Reading package lists...
              E: The repository 'https://deb.nodesource.com/node_18.x nodistro Release' no longer has a Release file.
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1318755    12061/io.jarvis.0
              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          22913      809/lighttpd
              tcp        0      0 192.168.78.83:42001     0.0.0.0:*               LISTEN      1001       87501      6525/io.hm-rpc.0
              tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        21806      724/pihole-FTL
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18356      738/sshd
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          332335     14432/cupsd
              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       88205      6262/node-red
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       86309      6281/io.shelly.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       87235      6402/io.mqtt.0
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          22964      818/smbd
              tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21812      724/pihole-FTL
              tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        16875      808/mysqld
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          22965      818/smbd
              tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16819      772/redis-server 12
              tcp6       0      0 :::80                   :::*                    LISTEN      0          22914      809/lighttpd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3021956    27005/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2963823    25413/io.web.0
              tcp6       0      0 :::53                   :::*                    LISTEN      999        21808      724/pihole-FTL
              tcp6       0      0 :::22                   :::*                    LISTEN      0          18358      738/sshd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          332334     14432/cupsd
              tcp6       0      0 :::3000                 :::*                    LISTEN      113        136316     8949/grafana
              tcp6       0      0 :::445                  :::*                    LISTEN      0          22962      818/smbd
              tcp6       0      0 ::1:4711                :::*                    LISTEN      999        21813      724/pihole-FTL
              tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16820      772/redis-server 12
              tcp6       0      0 :::139                  :::*                    LISTEN      0          22963      818/smbd
              tcp6       0      0 :::3500                 :::*                    LISTEN      1001       90354      6593/io.sonos.0
              udp        0      0 0.0.0.0:41879           0.0.0.0:*                           1001       601710     9411/io.backitup.0
              udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        21805      724/pihole-FTL
              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       89218      6437/io.radar2.0
              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       88118      6318/io.radar2.1
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16209      471/dhclient
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          332343     14433/cups-browsed
              udp        0      0 192.168.78.255:137      0.0.0.0:*                           0          21669      701/nmbd
              udp        0      0 192.168.78.83:137       0.0.0.0:*                           0          21668      701/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          21656      701/nmbd
              udp        0      0 192.168.78.255:138      0.0.0.0:*                           0          21671      701/nmbd
              udp        0      0 192.168.78.83:138       0.0.0.0:*                           0          21670      701/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          21657      701/nmbd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17448      402/avahi-daemon: r
              udp        0      0 0.0.0.0:44942           0.0.0.0:*                           108        17450      402/avahi-daemon: r
              udp6       0      0 :::53                   :::*                                999        21807      724/pihole-FTL
              udp6       0      0 :::5353                 :::*                                108        17449      402/avahi-daemon: r
              udp6       0      0 :::52557                :::*                                108        17451      402/avahi-daemon: r
              2023-09-29 20:45:44.387  - warn: host.iobroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
              2023-09-29 20:46:00.229  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                  at /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/maps/core/core/modbus-client-core.js:79:156
                  at processTicksAndRejections (node:internal/process/task_queues:95:5)
              2023-09-29 20:46:00.249  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
              2023-09-29 20:48:08.985  - error: node-red.0 (6192) 29 Sep 20:48:08 - [error] [modbus-getter:n37000-37123] Error: Timed out
              2023-09-29 20:48:09.020  - error: node-red.0 (6192) 29 Sep 20:48:09 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
              2023-09-29 20:50:45.740  - info: javascript.0 (6113) script.js.common.Weather: Material Design Widgets: Wetter Skript triggered by 'linkeddevices.0.Sensor.Wetter.temperature'
              2023-09-29 20:55:00.944  - info: sql.0 (6216) Do not store value "NULL" for hm-rpc.0.LTK0086602.4.VALVE_STATE because no number
              2023-09-29 20:56:42.693  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Timed out
              2023-09-29 20:56:42.720  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
              Danke fürs ansehen.
              • T ticaki
                Michael Sauer
                @ticaki Ist jetzt aktiviert.
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                  Docker          : false
                  Kernel          : armv7l
                  Userland        : armhf
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=57.4'C
                  volt=0.8500V
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           99M         99M        0.0K
                           3838 M total memory
                           2706 M used memory
                            670 M active memory
                            111 M free memory
                            167 M buffer memory
                            853 M swap cache
                             99 M total swap
                             99 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  3.6G    /var/
                  3.1G    /var/lib
                  1.9G    /var/lib/mysql
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: redis
                  States  type: redis
                  admin:          6.10.2
                  javascript:     7.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        32411
                  States:         52049
                  Pending Updates: 0
                  Danke fürs ansehen.
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Bullseye ist aktuell
                  free 111M
                  Dein Speicher geht aus ...
                  Redis OK , dann läuft aber
                  redis-server 12
                  Beta Tester ... OK ... aber nicht Aktuell ... up to Date!!!
                  Dann
                    free 111M
                    redis-server 12
                    Dann
                    Michael Sauer
                    @glasfaser Was möchtest du mir damit sagen?
                    GlasfaserG S 2 Antworten Letzte Antwort
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @michael-sauer
                      Ziemlich ausgelastet dein Raspberry und auch nicht ioBroker als "Beta Tester" gepflegt !
                      Ich würde auf jeden Fall mal PiHole prüfen , denn ich habe oben geschrieben :
                      Keine Verbindung !?
                        SpacerX
                        @michael-sauer ich bleibe dabei. Stelle die Maperstellung ab, dann sollte er laufen.
                        • T Nicht stören
                          T Nicht stören
                          ticaki
                          Der hängt in der Fehlerbehandlung(Map) beim Aufruf von Sentry. Das abschalten der Maperzeugung, so das diese Fehlerbehandlung nicht mehr aufgerufen wird, ist sicher ein Weg. @copystring
                          Hab nur den Sauger aber nicht den Adapter im Einsatz, sollte wohl ein github issue aufgemacht werden.
                          https://github.com/copystring/ioBroker.roborock
                          Spenden
                          Michael SauerM A 2 Antworten Letzte Antwort
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            Jemand eine Idee?
                            copystringC Offline
                            copystringC Offline
                            copystring
                            @michael-sauer Die Kartenerstellung kann auf einem RPi nicht funktionieren. Da gibt es ein Problem mit der Canvas-Bibliothek.
                            https://github.com/copystring/ioBroker.roborock#map-creation-does-not-work-on-raspberry-pi
                            Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
                            https://paypal.me/copystring
                            • T ticaki
                              Michael Sauer
                              @ticaki sagte in Roborock - Adapter stürzt ständig ab:
                              Das war die Lösung. Danke.
                              • T ticaki
                                Almeda
                                @ticaki said in Roborock - Adapter stürzt ständig ab:
                                ich möchte mich an dieses Thema kurz mit anhängen. Nutze den Roborock Adapter seit ca. 4 Wochen und habe seit Anbeginn, trotz ausgeschalteter Map Erstellung, das Problem, dass der Adapter laut dem Host ständig abstürzt und er ihn daher regelhaft nach 1-2 Tagen aus dem Rennen nimmt und den Neustart verhindert.
                                Tatsächlich hat die Einrichtung nach der Installation problemlos geklappt und auch die Anbindung an Node-Red zum Ausspielen der Stati über Telegramm hat sofort funktioniert.
                                Eine De- und Neuinstallation des Apdaters hat nichts gebracht. Ich habe dann auf das aktuelle Update gewartet, weil ich es für ein vllt. bekanntes Problem hielt. Das Update von vor einigen Tagen hat jedoch keine Besserung gebracht.
                                IoB läuft auf einem Synology 918+ mit ausreichend RAM. Kein anderer Adapter macht Probleme.
                                Kann einer weiterhelfen?
                                Vielen Dank
                                Almeda
                                Thomas BraunT haselchenH 2 Antworten Letzte Antwort
                                • A Almeda
                                  Vielen Dank
                                  Almeda
                                  @almeda sagte in Roborock - Adapter stürzt ständig ab:
                                  Ohne Log? Schwierig.
                                  • A Almeda
                                    Vielen Dank
                                    Almeda
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @almeda
                                    Warum nicht den Mihome-Vacuum?
                                    Der funktioniert völlig unkompliziert und macht meines Erachtens das Gleiche wie Dein Adapter.
                                    Bei meinem weiß ich allerdings, dass er funktioniert 😉
                                      Almeda
                                      @thomas-braun said in Roborock - Adapter stürzt ständig ab:
                                      Sorry, vergessen anzuhängen. Es erscheint die Warnung:
                                      Failed to execute get_fw_features on robot 4d98R7TEpn6C0ZcYPNY52Q Error: Local request with id 5 with method get_fw_features timed out after 10 seconds
                                      @haselchen said in Roborock - Adapter stürzt ständig ab:
                                      @almeda
                                      Den hatte ich bisher nicht auf dem Schirm. Ich danke dir für den Hinweis. Probiere ihn gerne mal aus!
                                      • A Almeda
                                        @almeda
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @almeda
                                        Gib dann mal bitte Feedback….
                                        • haselchenH haselchen
                                          @almeda
                                          Almeda
                                          @almeda
                                          Eben versucht und in der Dokumentation festgestellt, dass der S7 nicht funktioniert. Damit ist die Option leider auch raus :(
