  4. Roborock - Adapter stürzt ständig ab
    6.8k
30 Beiträge 10 Kommentatoren 4.3k Aufrufe 9 Beobachtet
  • Michael SauerM Michael Sauer
    @glasfaser
    Steht auf Debug. System ist aktualisiert:
    roborock.0
    2023-09-29 08:17:46.345	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    roborock.0
    2023-09-29 08:17:46.334	error	adapter disabled
    roborock.0
    2023-09-29 08:17:46.317	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    roborock.0
    2023-09-29 08:17:10.665	info	terminating
    roborock.0
    2023-09-29 08:17:10.373	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
    roborock.0
    2023-09-29 08:17:10.370	warn	setTimeout called, but adapter is shutting down
    roborock.0
    2023-09-29 08:17:10.369	warn	setTimeout called, but adapter is shutting down
    roborock.0
    2023-09-29 08:17:10.271	warn	setTimeout called, but adapter is shutting down
    roborock.0
    roborock.0
    2023-09-29 08:17:10.185	warn	setTimeout called, but adapter is shutting down
    roborock.0
    2023-09-29 08:17:10.181	warn	Failed to create map. retry
    roborock.0
    2023-09-29 08:17:10.161	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-09-29 08:17:10.160	info	terminating
    roborock.0
    2023-09-29 08:17:10.146	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-29 08:17:10.146	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
    roborock.0
    2023-09-29 08:17:10.145	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2023-09-29 08:17:10.144	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2023-09-29 08:17:07.454	warn	Failed to execute load_multi_map on robot 5Eo7zrAcFZhjGJqyG5saSx Error: There was an error processing the request with id 3224 error: {"code":-10003,"message":"action locked"}
    roborock.0
    2023-09-29 08:16:54.267	info	MQTT initialized
    roborock.0
    2023-09-29 08:16:52.229	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
    roborock.0
    2023-09-29 08:16:52.080	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    GlasfaserG Offline
    GlasfaserG Offline
    @michael-sauer sagte in Roborock - Adapter stürzt ständig ab:
    Steht auf Debug.
    Nö ist nicht , ist die gleiche Info wie zuvor !
    Die Adapter Instanz auf DEBUG stellen .
    Beispiel :
    Was war hiermit !?
    @glasfaser sagte in Roborock - Adapter stürzt ständig ab:
    Die Version ist BETA , läuft es auch nicht mit dem Stable !?
    Und Zeige mal die Full Ausgabe von
    iob diag
    Michael SauerM 1 Antwort Letzte Antwort
    • T Nicht stören
      T Nicht stören
      ticaki
      Kannst du das versenden von anonymisierten Daten mal aktivieren? Sentry
      Spenden
      • GlasfaserG Glasfaser
        Steht auf Debug.
        Beispiel :
        Was war hiermit !?
        iob diag
        Michael SauerM Offline
        Michael Sauer
        @glasfaser Hast recht.
        Hier der vollständige Log:
        roborock.0
        2023-09-29 20:44:27.997	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
        roborock.0
        2023-09-29 20:44:27.787	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        roborock.0
        2023-09-29 20:44:27.769	debug	Plugin sentry Initialize Plugin (enabled=true)
        roborock.0
        2023-09-29 20:43:40.797	warn	Failed to execute get_clean_summary on robot 5Eo7zrAcFZhjGJqyG5saSx TypeError: Cannot read properties of undefined (reading 'captureException')
        roborock.0
        2023-09-29 20:43:40.797	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
        roborock.0
        2023-09-29 20:43:40.791	warn	Failed to execute get_clean_record_map on robot 5Eo7zrAcFZhjGJqyG5saSx retry
        roborock.0
        2023-09-29 20:43:40.790	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
        roborock.0
        2023-09-29 20:43:40.775	debug	Length of message queue: 0
        roborock.0
        2023-09-29 20:43:40.774	debug	dps debug: {"id":3403,"result":["retry"]}
        roborock.0
        2023-09-29 20:43:40.614	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
        roborock.0
        2023-09-29 20:43:40.611	warn	setTimeout called, but adapter is shutting down
        roborock.0
        2023-09-29 20:43:40.610	warn	setTimeout called, but adapter is shutting down
        roborock.0
        2023-09-29 20:43:40.591	debug	Length of message queue: 0
        roborock.0
        2023-09-29 20:43:40.591	debug	dps debug: {"id":8382,"result":[{"begin":1695980402,"end":1695981303,"duration":901,"area":11682500,"error":0,"complete":0,"start_type":3,"clean_type":3,"finish_reason":62,"dust_collection_status":1,"avoid_count":2,"map_flag":0}]}
        roborock.0
        2023-09-29 20:43:40.379	warn	Failed to create map. retry
        roborock.0
        2023-09-29 20:43:40.377	warn	setTimeout called, but adapter is shutting down
        roborock.0
        2023-09-29 20:43:40.344	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        roborock.0
        2023-09-29 20:43:40.343	debug	Plugin sentry destroyed
        roborock.0
        2023-09-29 20:43:40.341	info	terminating
        roborock.0
        2023-09-29 20:43:40.321	error	Cannot read properties of undefined (reading 'captureException')
        roborock.0
        2023-09-29 20:43:40.320	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
        roborock.0
        2023-09-29 20:43:40.319	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
        roborock.0
        2023-09-29 20:43:40.319	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        roborock.0
        2023-09-29 20:43:40.316	debug	Length of message queue: 2
        roborock.0
        2023-09-29 20:43:40.316	debug	Not clearing messageQueue. null - 24752
        roborock.0
        2023-09-29 20:43:40.315	debug	dps debug: {"id":5996,"result":["retry"]}
        roborock.0
        2023-09-29 20:43:40.312	debug	Length of message queue: 2
        roborock.0
        2023-09-29 20:43:40.312	debug	dps debug: {"id":1492,"result":{"clean_time":202871,"clean_area":2843662500,"clean_count":144,"dust_collection_count":128,"records":[1695980402,1695978009,1695807600,1695805205,1695718805,1695634800,1695632403,1695546005,1695459607,1695375600,1695373208,1695286806,1695202799,1695200405,1695114008,1695030000,1695027609,1694941211,1694854807,1694770801]}}
        roborock.0
        2023-09-29 20:43:39.961	debug	downloadURL: https://github.com/AlexxIT/go2rtc/releases/download/v1.3.0/go2rtc_linux_arm
        roborock.0
        2023-09-29 20:43:39.961	debug	System type: go2rtc_linux_arm
        roborock.0
        2023-09-29 20:43:39.961	debug	platform: linux
        roborock.0
        2023-09-29 20:43:39.960	debug	arch: arm
        roborock.0
        2023-09-29 20:43:39.958	debug	Update map
        roborock.0
        2023-09-29 20:43:39.955	debug	Length of message queue: 1
        roborock.0
        2023-09-29 20:43:39.954	debug	dps debug: {"id":1643,"result":{"water_box_mode":201}}
        roborock.0
        2023-09-29 20:43:39.684	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_water_box_custom_mode
        roborock.0
        2023-09-29 20:43:39.681	debug	Length of message queue: 1
        roborock.0
        2023-09-29 20:43:39.679	debug	dps debug: {"id":3641,"result":[{"carpet_clean_mode":3}]}
        roborock.0
        2023-09-29 20:43:39.388	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_clean_mode
        roborock.0
        2023-09-29 20:43:39.386	debug	Length of message queue: 1
        roborock.0
        2023-09-29 20:43:39.384	debug	dps debug: {"id":5183,"result":[{"enable":1,"current_integral":1000,"current_high":500,"current_low":1000,"stall_time":10}]}
        roborock.0
        2023-09-29 20:43:39.303	debug	get_timer: []
        roborock.0
        2023-09-29 20:43:39.302	debug	Length of message queue: 2
        roborock.0
        2023-09-29 20:43:39.301	debug	dps debug: {"id":1710,"result":[]}
        roborock.0
        2023-09-29 20:43:39.299	debug	get_server_timer: [["1688127243968","on",0],["1688127295244","on",0]]
        roborock.0
        2023-09-29 20:43:39.298	debug	Length of message queue: 3
        roborock.0
        2023-09-29 20:43:39.297	debug	dps debug: {"id":9140,"result":[["1688127243968","on",0],["1688127295244","on",0]]}
        roborock.0
        2023-09-29 20:43:38.906	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_mode
        roborock.0
        2023-09-29 20:43:38.905	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_timer
        roborock.0
        2023-09-29 20:43:38.904	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_server_timer
        roborock.0
        2023-09-29 20:43:38.903	debug	Length of message queue: 1
        roborock.0
        2023-09-29 20:43:38.902	debug	dps debug: {"id":1525,"result":{"ssid":"S-Home","ip":"192.168.78.122","mac":"b0:4a:39:6b:e2:59","bssid":"b0:f2:08:d9:88:ed","rssi":-68}}
        roborock.0
        2023-09-29 20:43:38.555	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_network_info
        roborock.0
        2023-09-29 20:43:38.554	debug	Consumables of robot: [{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]
        roborock.0
        2023-09-29 20:43:38.551	debug	Length of message queue: 1
        roborock.0
        2023-09-29 20:43:38.550	debug	dps debug: {"id":1936,"result":[{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]}
        roborock.0
        2023-09-29 20:43:38.287	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_consumable
        roborock.0
        2023-09-29 20:43:38.286	debug	Mapped room matched: 11316198 with name: Küche
        roborock.0
        2023-09-29 20:43:38.285	debug	Mapped room matched: 11316194 with name: Flur
        roborock.0
        2023-09-29 20:43:38.284	debug	Mapped room matched: 12646380 with name: Esszimmer
        roborock.0
        2023-09-29 20:43:38.283	debug	Mapped room matched: 11309675 with name: Wohnzimmer
        roborock.0
        2023-09-29 20:43:38.282	debug	All mapped rooms: [[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]
        roborock.0
        2023-09-29 20:43:38.281	debug	Length of message queue: 1
        roborock.0
        2023-09-29 20:43:38.281	debug	dps debug: {"id":8606,"result":[[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]}
        roborock.0
        2023-09-29 20:43:38.238	debug	foreign.message attribute: 128 with value: 4
        roborock.0
        2023-09-29 20:43:38.237	debug	dps debug: {"128":4}
        roborock.0
        2023-09-29 20:43:38.143	debug	Length of message queue: 1
        roborock.0
        2023-09-29 20:43:38.142	debug	dps debug: {"id":8398,"result":[{"msg_ver":2,"msg_seq":126,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
        roborock.0
        2023-09-29 20:43:37.907	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_room_mapping
        roborock.0
        2023-09-29 20:43:37.891	debug	get_status: {"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}
        roborock.0
        2023-09-29 20:43:37.889	debug	Length of message queue: 0
        roborock.0
        2023-09-29 20:43:37.888	debug	dps debug: {"id":5982,"result":[{"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
        roborock.0
        2023-09-29 20:43:37.645	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_status
        roborock.0
        2023-09-29 20:43:37.644	debug	Latest data requested
        roborock.0
        2023-09-29 20:43:37.642	debug	Length of message queue: 0
        roborock.0
        2023-09-29 20:43:37.640	debug	dps debug: {"id":1305,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1695979052,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1695806345}]},{"mapFlag":1,"add_time":1692254347,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1688451884}]}]}]}
        roborock.0
        2023-09-29 20:43:37.486	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_multi_maps_list
        roborock.0
        2023-09-29 20:43:37.382	debug	Length of message queue: 0
        roborock.0
        2023-09-29 20:43:37.379	debug	dps debug: {"id":3178,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
        roborock.0
        2023-09-29 20:43:37.164	debug	Firmware features request
        roborock.0
        2023-09-29 20:43:37.164	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_fw_features
        roborock.0
        2023-09-29 20:43:37.160	debug	5Eo7zrAcFZhjGJqyG5saSx online. Starting mainUpdateInterval.
        roborock.0
        2023-09-29 20:43:23.804	debug	Robot key: roborock.vacuum.a51
        roborock.0
        2023-09-29 20:43:23.803	debug	RoomIDs debug: {"11309675":"Wohnzimmer","11314643":"Wohnzimmer1","11316194":"Flur","11316198":"Küche","11316201":"Küche1","11319794":"Badezimmer","11319802":"Spielzimmer","11319804":"Kinderzimmer","11319806":"Schlafzimmer","12646380":"Esszimmer","13421850":"Standard","13421863":"Phillip Schlafzimmer","13421865":"Badezimmer1"}
        roborock.0
        2023-09-29 20:43:23.801	info	MQTT initialized
        roborock.0
        2023-09-29 20:43:20.623	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
        roborock.0
        2023-09-29 20:43:20.491	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        roborock.0
        2023-09-29 20:43:20.474	debug	Plugin sentry Initialize Plugin (enabled=true)
        roborock.0
        2023-09-29 20:43:20.348	debug	States connected to redis: 127.0.0.1:6379
        roborock.0
        2023-09-29 20:43:20.336	debug	States create User PubSub Client
        roborock.0
        2023-09-29 20:43:20.335	debug	States create System PubSub Client
        roborock.0
        2023-09-29 20:43:20.327	debug	Redis States: Use Redis connection: 127.0.0.1:6379
        roborock.0
        2023-09-29 20:43:20.307	debug	Objects connected to redis: 127.0.0.1:6379
        roborock.0
        2023-09-29 20:43:20.300	debug	Objects client initialize lua scripts
        roborock.0
        2023-09-29 20:43:19.846	debug	Objects create User PubSub Client
        roborock.0
        2023-09-29 20:43:19.844	debug	Objects create System PubSub Client
        roborock.0
        2023-09-29 20:43:19.842	debug	Objects client ready ... initialize now
        roborock.0
        2023-09-29 20:43:19.803	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
        Skript v.2023-06-20
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
                Machine ID: 5f09e0dc24364fc8951dcf01ea03774d
                   Boot ID: 687f969e56cf41c2bcbbdd9cffef19bb
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         20:55:52 up 23:02,  1 user,  load average: 4.01, 3.35, 2.81
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=57.4'C
        volt=0.8500V
        *** Time and Time Zones ***
                       Local time: Fri 2023-09-29 20:55:53 CEST
                   Universal time: Fri 2023-09-29 18:55:53 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G        2.7G        111M         13M        1.0G        971M
        Swap:           99M         99M        0.0K
        Total:         3.9G        2.8G        111M
                 3838 M total memory
                 2706 M used memory
                  670 M active memory
                 2888 M inactive memory
                  111 M free memory
                  167 M buffer memory
                  853 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4       59G   19G   38G  34% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G  2.2M  1.9G   1% /dev/shm
        tmpfs          tmpfs     1.9G   18M  1.9G   1% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/loop1     squashfs   41M   41M     0 100% /snap/certbot/3025
        /dev/loop0     squashfs   54M   54M     0 100% /snap/core20/2018
        /dev/loop2     squashfs   91M   91M     0 100% /snap/core/15929
        /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16098
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        TARGET               SOURCE         FSTYPE   OPTIONS
        /                    /dev/mmcblk0p2 ext4     rw,noatime
        |-/sys/fs/bpf        none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
        |-/snap/certbot/3025 /dev/loop1     squashfs ro,nodev,relatime
        |-/snap/core20/2018  /dev/loop0     squashfs ro,nodev,relatime
        |-/snap/core/15929   /dev/loop2     squashfs ro,nodev,relatime
        |-/snap/core/16098   /dev/loop3     squashfs ro,nodev,relatime
        `-/boot              /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.6G    /var/
        3.1G    /var/lib
        1.9G    /var/lib/mysql
        1.7G    /var/lib/mysql/iobroker
        525M    /var/lib/piVCCU3
        Archived and active journals take up 16.0M in the file system.
        /opt/iobroker/backups:
        197M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        695M    /opt/iobroker/iobroker-data/
        466M    /opt/iobroker/iobroker-data/files
        136M    /opt/iobroker/iobroker-data/backup-objects
        87M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        28M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
        20M     /opt/iobroker/iobroker-data/objects.json.migrated
        20M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.0
        /usr/bin/node           v18.18.0
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Installed: 18.18.0-1nodesource1
          Candidate: 18.18.0-1nodesource1
          Version table:
         *** 18.18.0-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        At least one iobroker host is running.
        Objects type: redis
        States  type: redis
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    redis on 127.0.0.1
        States:                     redis on 127.0.0.1
        Core adapters versions
        admin:          6.10.2
        javascript:     7.1.4
        Adapters from github:   2
        Adapter State
          system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 42001
        + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
        + system.adapter.radar2.1                 : radar2                : iobroker                                 -  enabled
          system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
          system.adapter.roadtraffic.0            : roadtraffic           : iobroker                                 - disabled
          system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
          system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
          system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
          system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
        Adapter    "alarm"        : 3.3.13   , installed 3.3.13
        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
        Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
        Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "eusec"        : 1.1.2    , installed 1.1.0  [Updatable]
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pvforecast"   : 2.8.1    , installed 2.8.1
        Adapter    "radar2"       : 2.0.7    , installed 2.0.7
        Adapter    "ring"         : 5.0.0-alpha.0, installed 3.4.0 [Updatable]
        Adapter    "roadtraffic"  : 0.2.0    , installed 0.2.0
        Adapter    "roborock"     : 0.4.4    , installed 0.4.4
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
        Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
        Adapter    "sonos"        : 2.3.3    , installed 2.3.1  [Updatable]
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
        Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
        Objects and States
        Objects:        32411
        States:         52049
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://phoscon.de/apt/deconz buster InRelease
        Ign:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:4 http://archive.raspberrypi.org/debian buster InRelease
        Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
        Err:6 https://deb.nodesource.com/node_18.x nodistro Release
          Could not handshake: Error in the pull function. [IP: 2606:4700:10::6816:41a 443]
        Get:7 https://apt.grafana.com stable InRelease [5984 B]
        Reading package lists...
        E: The repository 'https://deb.nodesource.com/node_18.x nodistro Release' no longer has a Release file.
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1318755    12061/io.jarvis.0
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          22913      809/lighttpd
        tcp        0      0 192.168.78.83:42001     0.0.0.0:*               LISTEN      1001       87501      6525/io.hm-rpc.0
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        21806      724/pihole-FTL
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18356      738/sshd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          332335     14432/cupsd
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       88205      6262/node-red
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       86309      6281/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       87235      6402/io.mqtt.0
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          22964      818/smbd
        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21812      724/pihole-FTL
        tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        16875      808/mysqld
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          22965      818/smbd
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16819      772/redis-server 12
        tcp6       0      0 :::80                   :::*                    LISTEN      0          22914      809/lighttpd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3021956    27005/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2963823    25413/io.web.0
        tcp6       0      0 :::53                   :::*                    LISTEN      999        21808      724/pihole-FTL
        tcp6       0      0 :::22                   :::*                    LISTEN      0          18358      738/sshd
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          332334     14432/cupsd
        tcp6       0      0 :::3000                 :::*                    LISTEN      113        136316     8949/grafana
        tcp6       0      0 :::445                  :::*                    LISTEN      0          22962      818/smbd
        tcp6       0      0 ::1:4711                :::*                    LISTEN      999        21813      724/pihole-FTL
        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16820      772/redis-server 12
        tcp6       0      0 :::139                  :::*                    LISTEN      0          22963      818/smbd
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       90354      6593/io.sonos.0
        udp        0      0 0.0.0.0:41879           0.0.0.0:*                           1001       601710     9411/io.backitup.0
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        21805      724/pihole-FTL
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       89218      6437/io.radar2.0
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       88118      6318/io.radar2.1
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16209      471/dhclient
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          332343     14433/cups-browsed
        udp        0      0 192.168.78.255:137      0.0.0.0:*                           0          21669      701/nmbd
        udp        0      0 192.168.78.83:137       0.0.0.0:*                           0          21668      701/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          21656      701/nmbd
        udp        0      0 192.168.78.255:138      0.0.0.0:*                           0          21671      701/nmbd
        udp        0      0 192.168.78.83:138       0.0.0.0:*                           0          21670      701/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          21657      701/nmbd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17448      402/avahi-daemon: r
        udp        0      0 0.0.0.0:44942           0.0.0.0:*                           108        17450      402/avahi-daemon: r
        udp6       0      0 :::53                   :::*                                999        21807      724/pihole-FTL
        udp6       0      0 :::5353                 :::*                                108        17449      402/avahi-daemon: r
        udp6       0      0 :::52557                :::*                                108        17451      402/avahi-daemon: r
        2023-09-29 20:45:44.387  - warn: host.iobroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
        2023-09-29 20:46:00.229  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
            at /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/maps/core/core/modbus-client-core.js:79:156
            at processTicksAndRejections (node:internal/process/task_queues:95:5)
        2023-09-29 20:46:00.249  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
        2023-09-29 20:48:08.985  - error: node-red.0 (6192) 29 Sep 20:48:08 - [error] [modbus-getter:n37000-37123] Error: Timed out
        2023-09-29 20:48:09.020  - error: node-red.0 (6192) 29 Sep 20:48:09 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
        2023-09-29 20:50:45.740  - info: javascript.0 (6113) script.js.common.Weather: Material Design Widgets: Wetter Skript triggered by 'linkeddevices.0.Sensor.Wetter.temperature'
        2023-09-29 20:55:00.944  - info: sql.0 (6216) Do not store value "NULL" for hm-rpc.0.LTK0086602.4.VALVE_STATE because no number
        2023-09-29 20:56:42.693  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Timed out
        2023-09-29 20:56:42.720  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
        Danke fürs ansehen.
        • T ticaki
          Michael Sauer
          @ticaki Ist jetzt aktiviert.
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            Skript v.2023-06-20
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : armhf
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=57.4'C
            volt=0.8500V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           99M         99M        0.0K
                     3838 M total memory
                     2706 M used memory
                      670 M active memory
                      111 M free memory
                      167 M buffer memory
                      853 M swap cache
                       99 M total swap
                       99 M used swap
                        0 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            3.6G    /var/
            3.1G    /var/lib
            1.9G    /var/lib/mysql
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
            ioBroker Status
            Objects type: redis
            States  type: redis
            admin:          6.10.2
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        32411
            States:         52049
            Pending Updates: 0
            Danke fürs ansehen.
            GlasfaserG Offline
            GlasfaserG Offline
            Bullseye ist aktuell
            free 111M
            Dein Speicher geht aus ...
            Redis OK , dann läuft aber
            redis-server 12
            Beta Tester ... OK ... aber nicht Aktuell ... up to Date!!!
            Dann
              free 111M
              redis-server 12
              Dann
              Michael Sauer
              @glasfaser Was möchtest du mir damit sagen?
              GlasfaserG S 2 Antworten Letzte Antwort
                GlasfaserG Offline
                GlasfaserG Offline
                @michael-sauer
                Ziemlich ausgelastet dein Raspberry und auch nicht ioBroker als "Beta Tester" gepflegt !
                Ich würde auf jeden Fall mal PiHole prüfen , denn ich habe oben geschrieben :
                setInterval called, but adapter is shutting down
                Keine Verbindung !?
                  SpacerX
                  @michael-sauer ich bleibe dabei. Stelle die Maperstellung ab, dann sollte er laufen.
                  DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
                  • T Nicht stören
                    T Nicht stören
                    ticaki
                    Der hängt in der Fehlerbehandlung(Map) beim Aufruf von Sentry. Das abschalten der Maperzeugung, so das diese Fehlerbehandlung nicht mehr aufgerufen wird, ist sicher ein Weg. @copystring
                    Hab nur den Sauger aber nicht den Adapter im Einsatz, sollte wohl ein github issue aufgemacht werden.
                    https://github.com/copystring/ioBroker.roborock
                    Spenden
                    Michael SauerM A 2 Antworten Letzte Antwort
                      habe das Problem das ich den Adapter bisher nicht richtig nutzen kann.
                      Mein Saugroboter ist ein S8+. Verbindung wird aufgebaut jedoch stürzt der Adapter im Minuten Takt ab.
                      Habe den Adapter auf Debug gestellt:
                      roborock.0
                      2023-09-28 20:32:33.060	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                      roborock.0
                      2023-09-28 20:32:33.043	error	adapter disabled
                      roborock.0
                      2023-09-28 20:32:33.023	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      roborock.0
                      2023-09-28 20:31:50.150	warn	setInterval called, but adapter is shutting down
                      roborock.0
                      2023-09-28 20:31:44.518	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      roborock.0
                      2023-09-28 20:31:44.515	info	terminating
                      roborock.0
                      2023-09-28 20:31:44.502	error	Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 20:31:44.502	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
                      roborock.0
                      2023-09-28 20:31:44.500	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 20:31:44.499	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      roborock.0
                      2023-09-28 20:31:32.436	info	MQTT initialized
                      roborock.0
                      2023-09-28 20:31:27.501	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
                      roborock.0
                      2023-09-28 20:31:26.946	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      roborock.0
                      2023-09-28 20:30:35.148	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      roborock.0
                      2023-09-28 20:30:35.143	info	terminating
                      roborock.0
                      2023-09-28 20:30:35.127	error	Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 20:30:35.126	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
                      roborock.0
                      2023-09-28 20:30:35.124	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 20:30:35.122	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      roborock.0
                      2023-09-28 20:30:08.135	info	MQTT initialized
                      roborock.0
                      2023-09-28 20:30:04.677	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
                      roborock.0
                      2023-09-28 20:30:04.393	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      roborock.0
                      2023-09-28 20:01:20.818	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      roborock.0
                      2023-09-28 20:01:20.815	info	terminating
                      roborock.0
                      2023-09-28 20:01:20.806	error	Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 20:01:20.806	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
                      roborock.0
                      2023-09-28 20:01:20.805	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 20:01:20.804	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      roborock.0
                      2023-09-28 20:01:06.531	info	MQTT initialized
                      roborock.0
                      2023-09-28 20:01:05.376	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
                      roborock.0
                      2023-09-28 20:01:05.189	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      roborock.0
                      2023-09-28 20:00:24.153	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      roborock.0
                      2023-09-28 20:00:24.150	info	terminating
                      roborock.0
                      2023-09-28 20:00:24.120	error	Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 20:00:24.119	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
                      roborock.0
                      2023-09-28 20:00:24.118	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 20:00:24.116	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      roborock.0
                      2023-09-28 20:00:08.550	info	MQTT initialized
                      roborock.0
                      2023-09-28 20:00:03.663	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
                      roborock.0
                      2023-09-28 20:00:03.375	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      roborock.0
                      2023-09-28 19:59:19.285	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      roborock.0
                      2023-09-28 19:59:19.282	info	terminating
                      roborock.0
                      2023-09-28 19:59:19.274	error	Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 19:59:19.273	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
                      roborock.0
                      2023-09-28 19:59:19.272	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                      roborock.0
                      2023-09-28 19:59:19.271	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      roborock.0
                      2023-09-28 19:59:07.700	info	MQTT initialized
                      roborock.0
                      2023-09-28 19:59:05.970	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
                      roborock.0
                      2023-09-28 19:59:05.760	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      roborock.0
                      2023-09-28 19:58:55.753	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      roborock.0
                      2023-09-28 19:58:55.751	info	terminating
                      roborock.0
                      2023-09-28 19:58:55.746	info	Got terminate signal TERMINATE_YOURSELF
                      Jemand eine Idee?
                      copystringC Offline
                      copystringC Offline
                      copystring
                      @michael-sauer Die Kartenerstellung kann auf einem RPi nicht funktionieren. Da gibt es ein Problem mit der Canvas-Bibliothek.
                      https://github.com/copystring/ioBroker.roborock#map-creation-does-not-work-on-raspberry-pi
                      Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
                      https://paypal.me/copystring
                      • T ticaki
                        Michael Sauer
                        @ticaki sagte in Roborock - Adapter stürzt ständig ab:
                        Das war die Lösung. Danke.
                        • T ticaki
                          Almeda
                          @ticaki said in Roborock - Adapter stürzt ständig ab:
                          ich möchte mich an dieses Thema kurz mit anhängen. Nutze den Roborock Adapter seit ca. 4 Wochen und habe seit Anbeginn, trotz ausgeschalteter Map Erstellung, das Problem, dass der Adapter laut dem Host ständig abstürzt und er ihn daher regelhaft nach 1-2 Tagen aus dem Rennen nimmt und den Neustart verhindert.
                          Tatsächlich hat die Einrichtung nach der Installation problemlos geklappt und auch die Anbindung an Node-Red zum Ausspielen der Stati über Telegramm hat sofort funktioniert.
                          Eine De- und Neuinstallation des Apdaters hat nichts gebracht. Ich habe dann auf das aktuelle Update gewartet, weil ich es für ein vllt. bekanntes Problem hielt. Das Update von vor einigen Tagen hat jedoch keine Besserung gebracht.
                          IoB läuft auf einem Synology 918+ mit ausreichend RAM. Kein anderer Adapter macht Probleme.
                          Kann einer weiterhelfen?
                          Vielen Dank
                          Almeda
                          Thomas BraunT haselchenH 2 Antworten Letzte Antwort
                          • A Almeda
                            Vielen Dank
                            Almeda
                            @almeda sagte in Roborock - Adapter stürzt ständig ab:
                            Ohne Log? Schwierig.
                            • A Almeda
                              Vielen Dank
                              Almeda
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @almeda
                              Warum nicht den Mihome-Vacuum?
                              Der funktioniert völlig unkompliziert und macht meines Erachtens das Gleiche wie Dein Adapter.
                              Bei meinem weiß ich allerdings, dass er funktioniert 😉
                                Almeda
                                @thomas-braun said in Roborock - Adapter stürzt ständig ab:
                                Sorry, vergessen anzuhängen. Es erscheint die Warnung:
                                Failed to execute get_fw_features on robot 4d98R7TEpn6C0ZcYPNY52Q Error: Local request with id 5 with method get_fw_features timed out after 10 seconds
                                @haselchen said in Roborock - Adapter stürzt ständig ab:
                                @almeda
                                Den hatte ich bisher nicht auf dem Schirm. Ich danke dir für den Hinweis. Probiere ihn gerne mal aus!
                                • A Almeda
                                  @almeda
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @almeda
                                  Gib dann mal bitte Feedback….
                                  • haselchenH haselchen
                                    @almeda
                                    Almeda
                                    @almeda
                                    Eben versucht und in der Dokumentation festgestellt, dass der S7 nicht funktioniert. Damit ist die Option leider auch raus :(
                                    • A Almeda
                                      @almeda
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @almeda
                                      Wird der Roboter in der Instanz gefunden ?
                                      Werden Objekte angelegt ?
                                      Was sagt das Log?
                                      Da S8 und ich meine S10 unterstützt werden, warum sollte der S7 da nicht bei sein?
                                      Hab noch nen S50 2. Gen.
                                        @almeda
                                        Was sagt das Log?
                                        Almeda
                                        schrieb am zuletzt editiert von Almeda
                                        @almeda
                                        Was sagt das Log?
                                        So zurück aus dem Urlaub und Zeit fürs Hobby ;)
                                        Danke für deine Rückfrage:
                                        Es geht ja schon damit los, dass der Mihome-Vacuum Adapter einen Xiaomi Login will, denn ich für den Roborock S7 ja nicht habe. Der Roborock wird ja über den Roborock eigenen Cloudserver verwaltet.
                                        Darüber habe ich mich dann gewundert und im Logg nachgesehen. Da steht eindeutig drin, dass alle Roboter, ausgenommen S7, unterstützt werden. Liegt wohl daran, dass der S7 anders kommuniziert, als die anderen Roboter.
                                        Zurück zu meinem eigentlichen Problem eines ständig abstürzenden Roborock-Adapters:
                                        Seit dem letzten Update ist der Adapter nicht mehr abgestürzt. Aber ob er stabil läuft, kann ich auch nicht sagen, da ich nun gelbe Warnungen bekomme:
                                        code_text
                                        ```2024-05-24 00:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                        2024-05-24 00:44:00.485 - warn: roborock.0 (508) MQTT connection close.
                                        2024-05-24 00:44:00.485 - warn: roborock.0 (508) MQTT connection reconnect.
                                        2024-05-24 01:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                        2024-05-24 01:44:00.445 - warn: roborock.0 (508) MQTT connection close.
                                        2024-05-24 01:44:00.445 - warn: roborock.0 (508) MQTT connection reconnect.
                                        2024-05-24 02:44:00.429 - warn: roborock.0 (508) Reconnecting mqtt client!
                                        2024-05-24 02:44:00.446 - warn: roborock.0 (508) MQTT connection close.
                                        2024-05-24 02:44:00.446 - warn: roborock.0 (508) MQTT connection reconnect.
                                        2024-05-24 03:10:28.073 - warn: roborock.0 (508) Unable to decode message for 4d98R7TEpn6C0ZcYPNY52Q. The the device is most likely offline. data: {"version":"1.0","seq":74,"random":641679,"timestamp":1716513028,"protocol":500,"payload":{"type":"Buffer","data":[123,34,111,110,108,105,110,101,34,58,102,97,108,115,101,125]},"crc32":2579086837}
                                        2024-05-24 03:11:07.991 - warn: roborock.0 (508) Unable to decode message for 4d98R7TEpn6C0ZcYPNY52Q. The the device is most likely offline. data: {"version":"1.0","seq":87,"random":721864,"timestamp":1716513067,"protocol":500,"payload":{"type":"Buffer","data":[123,34,111,110,108,105,110,101,34,58,116,114,117,101,125]},"crc32":3231908517}
                                        2024-05-24 03:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                        2024-05-24 03:44:00.445 - warn: roborock.0 (508) MQTT connection close.
                                        2024-05-24 03:44:00.445 - warn: roborock.0 (508) MQTT connection reconnect.
                                        2024-05-24 04:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                        2024-05-24 04:44:00.445 - warn: roborock.0 (508) MQTT connection close.
                                        2024-05-24 04:44:00.446 - warn: roborock.0 (508) MQTT connection reconnect.
                                        2024-05-24 05:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                        2024-05-24 05:44:00.446 - warn: roborock.0 (508) MQTT connection close.
                                        2024-05-24 05:44:00.446 - warn: roborock.0 (508) MQTT connection reconnect.```
                                        code_text
                                        So geht das jede Stunde in der 44. Minute der Stunde einmal durch...
                                        • A Almeda
                                          @almeda
                                          Was sagt das Log?
                                          code_text
                                          code_text
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @almeda
                                          Wie gesagt, beim Roborock Adaper wäre ich raus.
                                          Was spricht aber dagegen, dass Du ihn in der Xiaomi App registrierst?
                                          Hab ich, und logischerweise alle anderen Nutzer, auch.
                                          Und dann könnte man mal weitersehen , wie es im Mihome-Vacuum Adapter aussieht.
